33-5340-01-10
33-5340-01-10
    TALLYSMANWIRELESS
    ANT GPS/GLONASS/SBAS 5V RS232
33-5340-01-10 数据手册
TW5340/TW5341 Multi-Constellation Smart Antenna The TW5340 is a multi-constellation GNSS Smart Antenna which provides simultaneous GPS/GLONASS/SBAS reception. It is designed for use in professional grade applications such as precision timing, network synchronization, low current applications, and tracking/positioning applications. The TW5340 GNSS Smart Antenna uses the state-of-the-art ST STA8088 receiver which provides 32 high sensitivity tracking channels plus 2 fast acquisition channels which can be assigned to acquire and track GPS, GLONASS, QZSS, and SBAS (WAAS, EGNOS, MSAS) signals simultaneously. The TW5340 employs Tallysman’s Accutenna™ dual feed antenna patch technology which greatly improves rejection of multi-path signal interference, across the whole GNSS band, making the TW5340 the most precise smart antenna in its size across all operating environments. The TW5340 accelerates GPS positioning by predicting satellite ephemeris data based on previous observations, resulting in extremely fast Time-To-First-Fix. The TW5340 can be configured to outputs up to three NMEA 0183 message lists with navigation update rates up to 10Hz. RS232, and CMOS interfaces are available with input voltage options of 3,3V, 5.0V and 12V to 36V with over voltage protection. A standard one pulse-per-second 1PPS synchronized to UTC time is available as a single ended output or as a differential output at RS422 levels. NMEA data can also be configured to output at RS422 levels, however the 1PPS output is disabled in this mode. Tallysman’s Windows™ based Configurator enables simple configuration of parameters such as baud rates, output message rates, constellation, tracking parameters, 1PPS configuration and Standby mode parameters. A non-magnetic version is available with Part Number TW5341 Features • • • • • • Multi-Constellation Receiver/Antenna 32 Channel simultaneous operation High performance tracking (-162 dBm) WAAS, EGNOS, & MSAS enabled 3 NMEA 0183 output Lists Navigation rates 1 to 10 Hz • • • • • • 1 PPS & NMEA configurable RS422 outputs Low Current Standby Mode Accutenna™ Technology Excellent multi-path signal rejection Industrial grade IP69K enclosure RoHS, REACH and RED Compliant. CE Marking TW5340/TW5341 Multi-Constellation Smart Antenna Mechanical: The TW5340/TW5341 is housed in an industrial grade weatherproof IP67 enclosure for 19mm diameter (¾”) thruhole mount or mast mount installations. It is available with low profile radome or with a conical radome. L-brackets and pipe mount brackets are available as installation options. Specifications Frequencies GPS / GLONASS / QZSS 1 PPS Output SBAS WAAS, EGNOS, MSAS Channels Antenna / Axial Ratio Cable Length Output Dual Feed / < 1 dB typical. 5m (15m & 25m special order) RS232, CMOS 3.3V, 5V (+/- 0.5V) and 12 V to 36V (9V min) 120 mA during acquisition 80 mA operating Standby mode < 1mA Voltages Current Dimensions 66.5 mm (dia) x 21 mm (h) Weight 135 g Mounting Method 19 mm dia. (¾”) thru-hole or mast-mount Navigation accuracy GPS+GLO 1.5m (50% CEP) Environmental: Operating Temp. Storage Temp. Weatherproof Shock Vibration Emissions Immunity -40̊C to +85̊C -45̊C to +85̊C IP69K Vertical axis 50G, other axis 30G 3 axis sweep – 15 min 10-200 Hz log sweep 3G EN 55022 EN 61000-4-3, EN 61000-4-4, EN 61000-4-6 Sensitivity Time to First Fix Serial Protocol Single ended & Differential RS422. +/-50 ns Accuracy 16Kv protection RS422 lines 32 simultaneous plus 2 fast acquisition Acquisition: -146 dBm Tracking: -162 dBm Cold start: 35 sec Warm start: 30 sec Hot start:
33-5340-01-10 价格&库存
很抱歉,暂时无法提供与“33-5340-01-10”相匹配的价格&库存,您可以联系我们找货
