SN220-001
SN220-001
    SYNAPSE
    MODULESNAPSTICKUSB2.4GHZ
SN220-001 数据手册
SNAPstick 220 USB to SNAP Bridge SNAP Network Access from a USB Port Product Highlights The SNAPstick 220 provides a USB connection between your computer • Up to 2Mbps radio data rate and a SNAP wireless network. It contains an SM220 SNAP module, and • Small form factor • Powered by SNAP Network Operating System has a user programmable multi-color LED for custom applications. The SNAPstick 220 is powered by the Synapse SNAP network operating system. The SNAP operating system automatically networks SNAP nodes (IoT) solutions. The SNAPstick 220 is ideal for: The SNAPstick 220 is an integral part of a SNAP development • SNAP application development Portal development environment. Portal is a free, comprehensive, • Data sniffing development and administration tool for SNAP networks that transforms • Deploying application scripts to remote nodes • Managing and configuring SNAP nodes • Troubleshooting SNAP networks to create a common communications infrastructure for Internet of Things environment, and is the link between a SNAP network and the Synapse your computer into a node within a SNAP wireless network, allowing it to participate as a peer or Internet gateway for connected nodes. 6723 Odyssey Drive // Huntsville, AL 35806 (877) 982-7888 // Synapse-Wireless.com ©2008-2016 Synapse, All Rights Reserved. All Synapse products are patent pending. Synapse, the Synapse logo, SNAP, and Portal are all registered trademarks of Synapse Wireless, Inc. 116-121513-021-D000 SNAPstick 220 Specifications* SNAP module SM220 Transmit Power up to +20 dBm Output Performance 250Kbps, 500Kbps, RF Data Rate 1Mbps, 2Mbps Receiver -103 dBm (1% PER, Sensitivity 250Kbps) General Frequency ISM 2.4 GHz Spreading Method Direct Sequence (DSSS) Modulation O-QPSK Operating Temperature 2.78” x 0.9” x 0.35” 7 cm x 2.29cm x .89cm 32 - 158 deg F. 0 to 70 deg C. Weight 13 grams Dimensions Orderable Part Number Information Part Number Description SN220-001 SNAPstick 220 USB to SNAP Bridge Device Topology SNAP Retries and Error Handling acknowledgment Networking Number of Channels Agency Approvals FCC Part 15.247 Industry Canada (IC) 15 channels. To avoid exceeding FCC limits, channel 15 operates in a receive only state. FCC ID: U9O-RF220UF1 7084A-RF220UF1 * at 23° C and 3.3V unless otherwise noted The SNAPstick 220 was designed to primarily act as a bridge device. The only user-accessible GPIO is connected to the multi-color LED, controlled by SNAP GPIOs D1, D2, and D3. LED State D1 D2 D3 Off High (True) High (True) High (True) Red Low (False) High (True) High (True) Green High (True) Low (False) High (True) Blue High (True) High (True) Low (False)
SN220-001 价格&库存
很抱歉,暂时无法提供与“SN220-001”相匹配的价格&库存,您可以联系我们找货
