STE-1428116RF96
STE-1428116RF96
    STEUTE
    UNIVERSALTRANSMITTERW/LITHIUM
STE-1428116RF96 数据手册
Wireless universal transmitter RF 96 ST SW915 Material-No.: 1428116 Features/Options Thermoplastic enclosure Mounting details to EN 50047 sWave® wireless technology Plug-in connector M12 Easy programming of receiver No wiring and pipe laying required Power supply by Lithium battery Output signal can be individually configurated at the receiver Note The RF 96 ST may be used in combination with an wireless inductive sensor RF IS Connection of external switching contact (potentialfree contact) with gold contacts possible. Dimensions Technical Data Standards Enclosure Tightening torque Connection Degree of protection Wireless protocol Ambient temperature Switching frequency Switching frequency Standby current Voltage supply Capacity Frequency Transmission power Data rate Channel bandwidth Sensing range Pin assignment Battery life SL-2770 (C) or TL-5920 Actuating time Approvals External switch contact Note EN 60947-5-1; EN 61000-6-2, -6-3, EN 61000-4-2, -4-20; EN 301 489-1; EN 301 489-3; EN 300 220-1; EN 300 220-2 glass-fibre reinforced, shock-proof thermoplastic, self-extinguishing UL 94-V0 M4 mounting screw enclosure: max. 1.2 Nm Plug-in connector M12 x 1; 4-pole IP 67 to IEC/EN 60529 sWave® 20 °C +65 °C approx. 12000 telegrams at repetitions/h max. 5 Hz 15 A Lithium battery SL 2770 (Europe) or TL-5920 (North America) 8.5 Ah (SL 2770) and (TL-5920) 915 MHz < 25 mW 66 kbps 266 kHz max. 450 m outside, max. 40 m inside according to switch frequency, 10 s approx. 1300 days, min. 80 ms USA: FCC: XK5-RFRXSW915; Canada: IC: 5158A-RFRXSW915 status signal configurable ex works, transmission of battery voltage Sensors Errors and omissions excepted. Created: 25.11.2016 Pe page 1/1 Status: Freigegeben steute Schaltgeräte GmbH & Co. KG Brückenstraße 91 32584 Löhne, Deutschland Revision: phone +49 (0) 5731 745-0 fax +49 (0) 5731 745-200 info@steute.com www.steute.com
STE-1428116RF96 价格&库存
很抱歉,暂时无法提供与“STE-1428116RF96”相匹配的价格&库存,您可以联系我们找货
