103990004
103990004
    SEEED(矽递科技)
    315MHZREMOTERELAYSWITCHKITS
103990004 数据手册
      315Mhz remote relay switch kits - 2 channels SKU 103990004    Description This remote switch allows you to remotely control any 12 Volt DC device. Perfect for controlling any 12V  devices such as Lights , Fans, Landscaping Lighting and more. This easy‐to‐wire kit is perfect for anybody with  a basic knowledge of electrical wiring, and can easily be wired to many 12V applications. For PC Modders, the  end of result of the Remote Control 12VDC kit are truly impressive and are sure to ooh and ah the crowds.  For DIYers, the kit will give some magical effect to your projects.  Basic Specification:        Frequency: 315Mhz.  Modulation: ASK  Working voltage for Receiver: 12VDC  Working voltage for Transmitter: 5~12V  Receiver sensibility: ‐105dbm  Emission distance: 100m in open ground  Pin Out:      Receiver:  Each Relay owns one group of 3 pins:  A ‐ Normally closed, open when relay activate  B ‐ Common node  C ‐ Normally open, close when relay activate    Transmitter:  10 ‐ CH2, HIGH trigger  11 ‐ NC  12 ‐ CH1, HIGH trigger  13 ‐ NC    Technical Details  Dimensions 80mm x 54mm x 28mm  Weight  G.W 72g      Battery  Exclude    Part List  315Mhz remote relay switch kits ‐ 2  channels 1  ECCN/HTS  ECCN Not Available  HSCODE  8538900000                                         https://www.seeedstudio.com/315Mhz‐remote‐relay‐switch‐kits‐2‐channels‐p‐150.html/12‐6‐18
103990004 价格&库存
很抱歉,暂时无法提供与“103990004”相匹配的价格&库存,您可以联系我们找货
