MTMMC-C-N3.R3-SP
MTMMC-C-N3.R3-SP
    MULTI-TECHSYSTEMS
    Module
    MODEM MODULE CDMA 800/1900 5V
MTMMC-C-N3.R3-SP 数据手册
MMCModem CDMA ™ Embedded Cellular Modem Benefits • Compact, rugged industrial chassis • Board-to-board or board-to-cable mounting • Quick time-to-market • Carrier approved The MMCModem™ CDMA cellular modem offers standards-based multi-band CDMA2000 1xRTT performance. Packaged in a compact, rugged industrial chassis, this quick-to-market communications device allows developers to add wireless communication to products with a minimum of development time and expense. The MMCModem CDMA cellular modem is based on industry-standard open interfaces and can be board-to-board or board-to-cable mounted. Features • CDMA2000 1xRTT • Qualcomm MSM6050 chipset • CDMA IS-95A, IS-95B backwards compatible • Dual-band 800/1900 MHz CDMA • Packet data up to 153.6K bps forward and reverse • Circuit-switched data up to 14.4K bps • Short Message Services (SMS) • Supports DTMF, AMPS Voice, QCELP (13K) and echo cancellation • Compatible with supplementary services • Advanced management features include phone book management, fixed dialing number, real time clock and alarm management • MMCX antenna connector • Board-to-board or board-to-cable mounting • Serial interface supports DTE speeds to 230K bps • AT command compatible • Two-year warranty Highlights Specifications Applications. With packet data speeds up to 153K bps, the MMCModem CDMA cellular modem is targeted at applications that periodically need to send or receive data over a wireless network. It is an ideal solution for: Packet Data Features • Appliances • Remote diagnostics • ATM terminals • Remote metering • Automotive • Security systems • Data collection • Vending/gaming machines • Gas pumps • Other devices requiring wireless connectivity • Industrial and medical remote monitoring systems Integration Reduces Space, Power and Cost. The MMCModem CDMA cellular modem integrates the controller, RF transceiver, and antenna interface into one compact unit. This integration requires low power, low real estate and provides an overall reduction in costs. MMCModem Pin-Out. The MMCModem CDMA cellular modem interfaces easily with existing products through a standard serial communication channel. The serial DTE channel is capable of transfer Pin Connector speeds to 230K bps and can be interfaced directly to a UART or microcontroller. The complete on-board RF transceiver interfaces with an antenna for direct connection to wireless SMS, circuit-switched dial-up, or packet data networks. It can be board-to-board or boardto-cable mounted. Developer's Kit. The Developer's Kit allows you to plug in the and use it for testing, programming and evaluation. The kit includes one development board with RS-232 DB-25 connector, universal power supply, antenna and RS-232 cable. 5/10 86002088 IS-95A, IS-95B up to 14.4K bps SMS Features Text & PDU, Point-to-Point, cell broadcast Connectors 50-pin Antenna: MMCX 5VDC; 400mA typical, 700mA maximum Physical Description 2.5" w x 1.8" h x 0.48" d; 2.8 oz. (6.4 cm x 4.6 cm x 1.2 cm; 79 g) Operating Environment -30° to +70° C Certifications EMC: FCC Part 2, 15, 22, 24, EN 55022, EN 55024 Safety: cUL, EN 60950, UL 60950 Network: CDG 1 & 2 Ordering Information Product MTMMC-C* Ordering Codes -N2 -N3 Description 800/1900 MHz CDMA2000 1xRTT Description For Sprint Networks For Verizon Networks Region Regional * Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. communications device www.multitech.com Circuit Switched Data/Fax Features Power Requirements Reduces Development Time. The MMCModem CDMA cellular modem enhances your product while you focus on developing its core features. It actually provides faster time-to-market because it relieves the burden and expense of obtaining CDG 1 and 2 network and RF approvals. World Headquarters Tel: (763) 785-3500 (800) 328-9717 CDMA2000 1xRTT, up to 153K bps forward & reverse channels Made in Mounds View, MN, U.S.A. Features and specifications are subject to change without notice. Trademarks & Registered Trademarks: MMCModem, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Copyright © 2010 by Multi-Tech Systems, Inc. All rights reserved. Multi-Tech Systems (EMEA) France Tel: +(33) 1 49 19 22 06
MTMMC-C-N3.R3-SP 价格&库存
很抱歉,暂时无法提供与“MTMMC-C-N3.R3-SP”相匹配的价格&库存,您可以联系我们找货
