SL485K-002
SL485K-002
    SYNAPSE
    SNAP LINK SERIAL ADAPTER RS485
SL485K-002 数据手册
SNAP Link Serial Wireless Adapter Replaces Cables in a SNAP! Features The SNAP® Link™ family of robust, mesh networking, serial wireless adapters makes it easy and quick to connect RS-232 and RS-485/422 devices, increasing distance beyond physical wire constraints while reducing installation and on-going maintenance cost and line noise problems. • SNAP — an Instant-On, Self-Healing Mesh Network • RS-232 version has a DB-9 port with full hardware flow control • RS-485/422 supports two & four wire, half & full duplex • Spread Spectrum (DSSS) technology overcomes noisy environments • Supports wireless ModBus • LEDs show signal strength & data transmission activity • Supports 1-to-1 and 1-to-Many Relationship Configurations • -40° to 85° C Operating Temperature, Industrial Use • No change to existing equipment • RP-SMA antenna connection • Micro-B USB port for easy connection to PCs (no adapter required) Compared to other serial wireless adapters, SNAP Link adapters provide the highest performance, longest distance and quickest configuration in the industry. Now, linking two (or more) physical serial ports or devices is a SNAP. Just connect each device to one of the SNAP Link adapters, press the Mode button to automatically pair them together, and you’re done. Units are powered by USB or an external AC adapter, included with the product. Benefits: • Longest Distance in the Industry • Most Reliable, Robust Mesh Network • Easiest Setup • BEST VALUE Two Form Factors available: SNAP Link RS-232 (external antenna) SNAP Link RS-485/422 (external antenna) Models Available with AES-128 encryption for added security. ©2015 Synapse Wireless, Inc. all rights reserved. Synapse products are patented or patent pending. Specifications subject to change without notice. 116-041613-025-A000 To learn more, visit synapse-wireless.com or call 877-982-7888 Digram A PC or Laptop using a pair of SNAP Link RS-232 or RS-485/422 wireless adapters to replace a cable, up to 3 miles (LoS). SNAP Link Process Customer Supplied PC or End Equipment The SNAP Link EasySet software applet is an easy-to-use configuration tool that streamlines the setup and configuration of SNAP Link wireless adapters. SNAP Link EasySet provides visual indicators and easy-to-change configuration parameters such as baud rate, channel and network ID, data bits, parity, stop bits, flow control and more. SNAP Link EasySet is a visually intuitive tool for defining and configuring the SNAP Link products. Equipment One SNAP Link Adaptor controls multiple SNAP Link serial wireless adapters (either RS-232 or RS485/422). Digram B - Option 2 SNAP Link Serial Customer Supplied PC or End Equipment Serial Serial Process Equipment
SL485K-002 价格&库存
很抱歉,暂时无法提供与“SL485K-002”相匹配的价格&库存,您可以联系我们找货
