DWM1000
DWM1000
    DECAWAVE
    模块
    DWM1000 收发器 RF mikroBUS™ Click™ 平台评估扩展板
DWM1000 数据手册
Product Overview The DWM1000 module is based on Decawave's DW1000 Ultra Wideband (UWB) transceiver IC. It integrates antenna, all RF circuitry, power management and clock circuitry in one module. It can be used in 2-way ranging or TDOA location systems to locate assets to a precision of 10 cm and supports data rates of up to 6.8 Mbps • • • • • • • • • • • • • IEEE 802.15.4-2011 UWB compliant Supports 4 RF bands from 3.5 GHz to 6.5 GHz Programmable transmitter output power Fully coherent receiver for maximum range and accuracy Designed to comply with FCC & ETSI UWB spectral masks Supply voltage 2.8 V to 3.6 V Low power consumption Data rates of 110 kbps, 850 kbps, 6.8 Mbps Maximum packet length of 1023 bytes for high data throughput applications Integrated MAC support features Supports 2-way ranging and TDOA SPI interface to host processor 23 mm x 13 mm x 2.9 mm 24pin side castellation package • • • • • • Simplifies integration, no RF design required Very precise location of tagged objects delivers enterprise efficiency gains and cost reductions Extended communications range minimises required infrastructure in RTLS High multipath fading immunity Supports very high tag densities in RTLS Low cost allows cost-effective implementation of solutions Low power consumption reduces the need to replace batteries and lowers system lifetime costs Applications • • Precision real time location systems (RTLS) using two-way ranging or TDOA schemes in a variety of markets. Location aware wireless sensor networks (WSNs) On-board Power Management On-board Antenna ANALOG RECEIVER PLL / CLOCK GENERATOR ANALOG TRANSMITTER POWER MANAGEMENT DIGITAL TRANSCEIVER • Key Benefits HOST INTERFACE / SPI STATE CONTROLLER DW1000 IC DWM1000 High Level Block Diagram DC/DC SPI I/F On-board Crystal and Clock Management 2.8 V to 3.6 V DC supply SPI Control Interface DWM1000 IEEE 802.15.4-2011 UWB Transceiver Module Key Features DWM1000 Datasheet Table of Contents 1 OVERVIEW ................................................... 5 1.1 DWM1000 FUNCTIONAL DESCRIPTION ........... 5 1.2 DWM1000 POWER UP ............................... 5 1.3 SPI HOST INTERFACE .................................... 6 1.3.1 SPI Signal Timing .............................. 6 1.4 GENERAL PURPOSE INPUT OUTPUT (GPIO) ...... 7 1.5 ALWAYS-ON (AON) MEMORY ....................... 7 1.6 ONE-TIME PROGRAMMABLE (OTP) MEMORY ... 7 1.7 INTERRUPTS AND DEVICE STATUS .................... 7 1.8 MAC ......................................................... 7 2 Crystal Oscillator Trim ...................... 8 Transmitter Calibration .................... 8 Antenna Delay Calibration ............... 8 5 7 ELECTRICAL SPECIFICATIONS ...................... 12 APPLICATION INFORMATION ..................... 17 5.1 ORDERING INFORMATION .......................... 24 7.1 TAPE AND REEL INFORMATION FOR DWM1000 V1 24 7.2 TAPE AND REEL INFORMATION FOR DWM1000 V2 26 7.3 DWM1000 PACKAGING INFORMATION ......... 27 7.3.1 Inner Box V2.................................... 27 7.3.2 Outer Box V2 ................................... 27 PIN NUMBERING .......................................... 9 PIN DESCRIPTIONS ........................................ 9 4.1 NOMINAL OPERATING CONDITIONS ............... 12 4.2 DC CHARACTERISTICS.................................. 12 4.3 RECEIVER AC CHARACTERISTICS .................... 12 4.4 RECEIVER SENSITIVITY CHARACTERISTICS ......... 13 4.5 REFERENCE CLOCK AC CHARACTERISTICS ........ 13 4.5.1 Reference Frequency ...................... 13 4.6 TRANSMITTER AC CHARACTERISTICS .............. 13 4.7 TEMPERATURE AND VOLTAGE MONITOR CHARACTERISTICS.................................................. 14 4.8 ANTENNA PERFORMANCE ............................ 14 4.9 ABSOLUTE MAXIMUM RATINGS .................... 16 PACKAGE INFORMATION ............................ 20 6.1 MODULE DRAWINGS ................................... 20 6.2 MODULE LAND PATTERN ............................. 20 6.3 DWM1000 V1 MODULE MARKING INFORMATION ...................................................... 22 6.4 DWM1000 V2 MODULE MARKING INFORMATION ...................................................... 22 6.5 MODULE SOLDER PROFILE ............................ 23 DWM1000 PIN CONNECTIONS ..................... 9 3.1 3.2 4 6 DWM1000 CALIBRATION ............................. 8 2.1.1 2.1.2 2.1.3 3 5.2 APPLICATION CIRCUIT DIAGRAM .................... 17 5.2.1 SPI Bus ............................................ 18 5.2.2 Configuring the SPI Mode ............... 18 5.2.3 Powering down the DWM1000 ...... 19 8 REGULATORY INFORMATION...................... 28 8.1 EUROPEAN UNION REQUIREMENTS ................ 28 8.1.1 Radio Equipment Directive ............. 28 8.1.2 ETSI harmonised standards ........... 29 9 GLOSSARY ................................................... 30 10 REFERENCES ............................................ 31 11 DOCUMENT HISTORY .............................. 31 12 FURTHER INFORMATION ......................... 33 APPLICATION BOARD LAYOUT GUIDELINES ...... 17 List of Figures FIGURE 1: DWM1000 POWER-UP SEQUENCE ................ 5 FIGURE 2: DW1000 SPIPHA=0 TRANSFER PROTOCOL.... 6 FIGURE 3: DWM1000 SPI TIMING DIAGRAM ................ 6 FIGURE 4: DWM1000 SPI DETAILED TIMING DIAGRAM .. 6 FIGURE 5: DWM1000 PIN DIAGRAM ........................... 9 FIGURE 6. DWM1000 CIRCUIT BOARD MOUNTING....... 14 FIGURE 7. MEASURED ANTENNA RADIATION PATTERNS... 15 FIGURE 8: DWM1000 APPLICATION BOARD KEEP-OUT AREAS ............................................................. 17 FIGURE 9: EXAMPLE DWM1000 APPLICATION CIRCUIT .. 18 FIGURE 10: SPI BUS CONNECTIONS ............................ 18 FIGURE 11: MODULE PACKAGE SIZE (UNITS: MM) ......... 20 FIGURE 12: DWM1000 MODULE LAND PATTERN (UNITS: MM) ............................................................... 21 FIGURE 13: DWM1000 V1 MODULE MARKING © Decawave Ltd 2016 INFORMATION ................................................... 22 FIGURE 14: DWM1000 V2 MODULE MARKING INFORMATION ................................................... 22 FIGURE 15: DWM1000 MODULE SOLDER PROFILE ....... 23 FIGURE 16: DWM1000 V1 MODULE CARRIER DIMENSION (UNITS: MM)..................................................... 24 FIGURE 17: DWM1000 V1 MODULE TAPE CARRIER DIMENSION (UNITS: MM) .................................... 25 FIGURE 16: DWM1000 V2 MODULE CARRIER DIMENSION (UNITS: MM)..................................................... 26 FIGURE 17: DWM1000 V2 MODULE TAPE CARRIER DIMENSION (UNITS: MM) .................................... 26 FIGURE 18: MODULE INNER BOX (UNITS: MM) .............. 27 FIGURE 19: MODULE OUTER BOX: (MODULE QUANTITY 2000 PIECES) ................................................... 27 Subject to change without notice Version 1.8 Page 2 DWM1000 Datasheet List of Tables TABLE 1: DW1000 POWER-UP TIMINGS ........................ 5 TABLE 2: DWM1000 SPI TIMING PARAMETERS ............. 6 TABLE 3: DWM1000 PIN FUNCTIONS ........................... 9 TABLE 4: EXPLANATION OF ABBREVIATIONS ................... 11 TABLE 5: DWM1000 OPERATING CONDITIONS ............ 12 TABLE 6: DWM1000 DC CHARACTERISTICS ................. 12 TABLE 7: DWM1000 RECEIVER AC CHARACTERISTICS ... 12 TABLE 8: DWM1000 TYPICAL RECEIVER SENSITIVITY CHARACTERISTICS .............................................. 13 TABLE 9: DWM1000 REFERENCE CLOCK AC CHARACTERISTICS .............................................. 13 TABLE 10: DWM1000 TRANSMITTER AC CHARACTERISTICS ...................................................................... 13 TABLE 11: DWM1000 TEMPERATURE AND VOLTAGE MONITOR CHARACTERISTICS................................ 14 TABLE 12: DWM1000 ABSOLUTE MAXIMUM RATINGS . 16 TABLE 13: DW1000 SPI MODE CONFIGURATION ......... 18 TABLE 14: MODULE WEIGHT ...................................... 21 TABLE 15: GLOSSARY OF TERMS .................................. 30 © Decawave Ltd 2016 Subject to change without notice Version 1.8 Page 3 DWM1000 Datasheet DOCUMENT INFORMATION Disclaimer Decawave reserves the right to change product specifications without notice. As far as possible changes to functionality and specifications will be issued in product specific errata sheets or in new versions of this document. Customers are advised to check with Decawave for the most recent updates on this product. Copyright © 2016 Decawave Ltd LIFE SUPPORT POLICY Decawave products are not authorized for use in safety-critical applications (such as life support) where a failure of the Decawave product would reasonably be expected to cause severe personal injury or death. Decawave customers using or selling Decawave products in such a manner do so entirely at their own risk and agree to fully indemnify Decawave and its representatives against any damages arising out of the use of Decawave products in such safety-critical applications. Caution! ESD sensitive device. Precaution should be used when handling the device in order to prevent permanent damage. REGULATORY APPROVALS The DWM1000, as supplied from Decawave, has not been certified for use in any particular geographic region by the appropriate regulatory body governing radio emissions in that region although it is capable of such certification depending on the region and the manner in which it is used. All products developed by the user incorporating the DWM1000 must be approved by the relevant authority governing radio emissions in any given jurisdiction prior to the marketing or sale of such products in that jurisdiction and user bears all responsibility for obtaining such approval as needed from the appropriate authorities. © Decawave Ltd 2016 Version 1.8 Page 4 DWM1000 Datasheet 1 OVERVIEW The DWM1000 module is an IEEE 802.15.4-2011 UWB implementation. RF components, Decawave DW1000 UWB transceiver, and other components reside on-module. DWM1000 enables cost effective and reduced complexity integration of UWB communications and ranging features, greatly accelerating design implementation. 1.1 DWM1000 Functional Description The DW1000 on board the DWM1000 is a fully integrated low-power, single chip CMOS RF transceiver IC compliant with the IEEE 802.15.4-2011 [1] UWB standard. The DWM1000 module requires no RF design as the antenna and associated analog and RF components are on the module. The module contains an on-board 38.4 MHz reference crystal. The crystal has been trimmed in production to reduce the initial frequency error to approximately 2 ppm, using the DW1000 IC’s internal on-chip crystal trimming circuit, see section 2.1.1. Always-On (AON) memory can be used to retain DWM1000 configuration data during the lowest power operational states when the on-chip voltage regulators are disabled. This data is uploaded and downloaded automatically. Use of DWM1000 AON memory is configurable. The on-chip voltage and temperature monitors allow the host to read the voltage on the VDDAON pin and the internal die temperature information from the DW1000. See the DW1000 Datasheet [2] for more detailed information on device functionality, electrical specifications and typical performance. 1.2 DWM1000 Power Up 3.3 V Supplies Von (VDDAON / VDD / VDD) EXTON Text_on RSTn Tdig_on STATE OFF POWER UP INIT Figure 1: DWM1000 Power-up Sequence When power is applied to the DWM1000, RSTn is driven low by internal circuitry as part of its power up sequence. See Figure 1 above. RSTn remains low until the on-module crystal oscillator has powered up and its output is suitable for use by the rest of the device, at which time RSTn is deasserted high. Table 1: DW1000 Power-up Timings Parameter Description Nominal Value Units 2.0 V VON Voltage threshold to enable power up TEXT_ON Time at which EXTON goes high before RSTn is released 3 ms TDIG_ON RSTn held low by internal reset circuit / driven low by external reset circuit 3 ms RSTn may be used as an output to reset external circuitry as part of system bring-up as power is applied. An external circuit can reset the DWM1000 by asserting RSTn for a minimum of 10 ns. RSTn is an asynchronous input. DW1000 initialization will proceed when the pin is released to high impedance. RSTn should never be driven high by an external source. © Decawave Ltd 2016 Version 1.8 Page 5 DWM1000 Datasheet Please see DW1000 Datasheet [2] for more details of DW1000 power up. 1.3 SPI Host Interface The DW1000 host communications interface is a slave-only SPI. Both clock polarities (SPIPOL=0/1) and phases (SPIPHA=0/1) are supported. The data transfer protocol supports single and multiple byte read/writes accesses. All bytes are transferred MSB first and LSB last. A transfer is initiated by asserting SPICSn low and terminated when SPICSn is deasserted high. See the DW1000 Datasheet [2] for full details of the SPI interface operation and mode configuration for clock phase and polarity. Cycle Number, # 1 2 3 4 5 6 7 8 8*Number of bytes 9 SPIPOL=0, SPIPHA=0 SPICLK SPIPOL=1, SPIPHA=0 SPICLK SPICSn SPIMISO z MSB 6 5 4 3 2 1 LSB MSB LSB X Z SPIMOSI z MSB 6 5 4 3 2 1 LSB MSB LSB X Z Figure 2: DW1000 SPIPHA=0 Transfer Protocol 1.3.1 SPI Signal Timing SPICSn S PICLK Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 SPIMOSI 7 SPIMISO 6 5 4 3 2 1 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 t7 7 6 5 4 3 2 1 Bit 7 Bit 6 Bit 5 0 7 t5 t8 6 5 t6 t9 Figure 3: DWM1000 SPI Timing Diagram SPICSn S PICLK Bit 7 SPIMOSI Bit 6 7 SPIMISO t3 t1 Bit 5 6 t4 5 t2 Figure 4: DWM1000 SPI Detailed Timing Diagram Table 2: DWM1000 SPI Timing Parameters Parameter SPICLK Period Min Max 50 t1 t2 Typ 38 12 © Decawave Ltd 2016 Unit Description ns The maximum SPI frequency is 20 MHz when the CLKPLL is locked, otherwise the maximum SPI frequency is 3 MHz. ns SPICSn select asserted low to valid slave output data ns SPICLK low to valid slave output data Version 1.8 Page 6 DWM1000 Datasheet Parameter Min t3 10 ns Master data setup time t4 10 ns Master data hold time t5 32 ns LSB last byte to MSB next byte ns SPICSn de-asserted high to SPIMISO tri-state t6 1.4 Typ Max 10 Unit Description t7 16 ns Start time; time from select asserted to first SPICLK t8 40 ns Idle time between consecutive accesses t9 40 ns Last SPICLK to SPICSn de-asserted General Purpose Input Output (GPIO) The DWM1000 provides 8 configurable pins. On reset, all GPIO pins default to input. GPIO inputs, when appropriately configured, are capable of generating interrupts to the host processor via the IRQ signal. GPIO0, 1, 2, & 3, as one of their optional functions, can drive LEDs to indicate the status of various chip operations. Any GPIO line being used to drive an LED in this way should be connected as shown. GPIO5 & 6 are used to configure the operating mode of the SPI as described in the DW1000 Datasheet [2]. See DW1000 Datasheet [2] and DW1000 User Manual [3] provide full details of the configuration and use of the GPIO lines. 1.5 Always-On (AON) Memory Configuration retention in lowest power states is enabled in DWM1000 by provision of an Always-On (AON) memory array with a separate power supply, VDDAON. The DWM1000 may be configured to upload its configuration to AON before entering a low-power state and to download the configuration when waking up from the low –power state. 1.6 One-Time Programmable (OTP) Memory The DWM1000 contains a 56x32 -bit user programmable OTP memory on the DW1000 device that is used to store per chip calibration information. 1.7 Interrupts and Device Status DWM1000 has a number of interrupt events that can be configured to drive the IRQ output pin. The default IRQ pin polarity is active high. A number of status registers are provided in the system to monitor and report data of interest. See DW1000 User Manual [3] for a full description of system interrupts and their configuration and of status registers. 1.8 MAC A number of MAC features are implemented including CRC generation, CRC checking and receive frame filtering. See the DW1000 Datasheet [2] and DW1000 User Manual [3] for full details. © Decawave Ltd 2016 Version 1.8 Page 7 DWM1000 Datasheet 2 DWM1000 CALIBRATION Depending on the end-use application s and the system design, DWM1000 settings may need to be tuned. To help with this tuning a number of built in functions such as continuous wave TX and continuous packet transmission can be enabled. See the DW1000 User Manual [3] for further details. 2.1.1 Crystal Oscillator Trim DWM1000 modules are calibrated at production to minimise initial frequency error to reduce carrier frequency offset between modules and thus improve receiver sensitivity. The calibration carried out at module production will trim the initial frequency offset to less than 2 ppm, typically. 2.1.2 Transmitter Calibration In order to maximise range, DWM1000 transmit power spectral density (PSD) should be set to the maximum allowable for the geographic region in which it will be used. For most regions this is -41.3 dBm/MHz. As the module contains an integrated antenna, the transmit power can only be measured over the air. The Effective Isotropic Radiated Power (EIRP) must be measured and the power level adjusted to ensure compliance with applicable regulations. The DWM1000 provides the facility to adjust the transmit power in coarse and fine steps; 3 dB and 0.5 dB nominally. It also provides the ability to adjust the spectral bandwidth. These adjustments can be used to maximise transmit power whilst meeting regulatory spectral mask. If required, transmit calibration should be carried out on a per DWM1000 module basis, see DW1000 User Manual [3] for full details. 1 2.1.3 Antenna Delay Calibration In order to measure range accurately, precise calculation of timestamps is required. To do this the antenna delay must be known. The DWM1000 allows this delay to be calibrated and provides the facility to compensate for delays introduced by PCB, external components, antenna and internal DWM1000 delays. To calibrate the antenna delay, range is measured at a known distance using two DWM1000 systems. Antenna delay is adjusted until the known distance and reported range agree. The antenna delay can be stored in OTP memory. Antenna delay calibration must be carried out as a once off measurement for each DWM1000 design implementation. If required, for greater accuracy, antenna delay calibration should be carried out on a per DWM1000 module basis, see DW1000 User Manual [3] for full details. 1To achieve best results when using the DWM1000 with Decawave’s DecaRanging software, you will need to adjust the default transmit power value programmed into the DWM1000 by the software. This is because DecaRanging software is targeted at Decawave’s EVB1000 evaluation board which has a different RF path compared to the DWM1000. You should increase the transmit power by approximately 3 dB. © Decawave Ltd 2016 Version 1.8 Page 8 DWM1000 Datasheet 3 DWM1000 PIN CONNECTIONS 3.1 Pin Numbering DWM1000 module pin assignments are as follows (viewed from top): - UWB Chip Antenna 22 IRQ / GPIO8 GPIO7 4 21 VSS VDDAON 5 20 SPICLK VDD3V3 6 19 SPIMISO VDD3V3 7 18 SPIMOSI VSS 8 17 SPICSn GPIO6 / EXTRXE / SPIPHA VSS 16 3 GPIO0 / RXOKLED 15 RSTn GPIO1 / SFDLED 14 23 VSS GPIO2 / RXLED 13 2 GPIO3 / TXLED 12 WAKEUP GPIO4 / EXTPA 11 24 VSS GPIO5 / EXTTXE / SPIPOL 10 1 9 EXTON Figure 5: DWM1000 Pin Diagram 3.2 Pin Descriptions Table 3: DWM1000 Pin functions SIGNAL NAME PIN I/O (Default) DESCRIPTION Digital Interface SPICLK 20 DI SPIMISO 19 DO (O–L) SPIMOSI 18 DI SPI data input. Refer to DW1000 Datasheet for more details [2]. DI SPI chip select. This is an active low enable input. The high-to-low transition on SPICSn signals the start of a new SPI transaction. SPICSn can also act as a wake-up signal to bring DW1000 out of either SLEEP or DEEPSLEEP states Refer to DW1000 Datasheet for more details [2]. DIO When asserted into its active high state, the WAKEUP pin brings the DW1000 out of SLEEP or DEEPSLEEP states into operational mode. If unused, this pin can be tied to ground. SPICSn WAKEUP © Decawave Ltd 2016 17 2 SPI clock SPI data output. Refer to DW1000 Datasheet for more details [2]. Version 1.8 Page 9 DWM1000 Datasheet SIGNAL NAME EXTON IRQ / GPIO8 GPIO7 GPIO6 / SPIPHA I/O (Default) DESCRIPTION DO (O-L) External device enable. Asserted during wake up process and held active until device enters sleep mode. Can be used to control external DC-DC converters or other circuits that are not required when the device is in sleep mode so as to minimize power consumption. Refer to DW1000 Datasheet for more details [2]. 22 DIO (O-L) Interrupt Request output from the DWM1000 to the host processor. By default IRQ is an active-high output but may be configured to be active low if required. For correct operation in SLEEP and DEEPSLEEP modes it should be configured for active high operation. This pin will float in SLEEP and DEEPSLEEP states and may cause spurious interrupts unless pulled low. When the IRQ functionality is not being used the pin may be reconfigured as a general purpose I/O line, GPIO8. 4 DIO (I) Defaults to operate as a SYNC input – refer [2]. THIS FUNCTIONALITY IS NOT APPLICABLE TO THE DWM1000. This pin may be reconfigured as a general purpose I/O pin, GPIO7 under software control. DIO (I) General purpose I/O pin. On power-up it acts as the SPIPHA (SPI phase selection) pin for configuring the SPI mode of operation. Refer to Section 5.2.2 and the DW1000 Datasheet for more details [2]. After power-up, the pin will default to a General Purpose I/O pin. PIN 1 9 GPIO5 / SPIPOL 10 DIO (I) General purpose I/O pin. On power-up it acts as the SPIPOL (SPI polarity selection) pin for configuring the SPI operation mode. Refer to Section 5.2.2 and the DW1000 Datasheet for more details [2]. After power-up, the pin will default to a General Purpose I/O pin. GPIO4 11 DIO (I) General purpose I/O pin. 12 DIO (I) General purpose I/O pin. It may be configured for use as a TXLED driving pin that can be used to light a LED following a transmission. Refer to the DW1000 User Manual [2] for details of LED use. 13 DIO (I) General purpose I/O pin. It may be configured for use as a RXLED driving pin that can be used to light a LED during receive mode. Refer to the DW1000 User Manual [2] for details of LED use. 14 DIO (I) General purpose I/O pin. It may be configured for use as a SFDLED driving pin that can be used to light a LED when SFD (Start Frame Delimiter) is found by the receiver. Refer to the DW1000 User Manual [2] for details of LED use. GPIO0 / RXOKLED 15 DIO (I) General purpose I/O pin. It may be configured for use as a RXOKLED driving pin that can be used to light a LED on reception of a good frame. Refer to the DW1000 User Manual [2] for details of LED use. RSTn 3 DIO (O-H) GPIO3 / TXLED GPIO2 / RXLED GPIO1 / SFDLED Reset pin. Active Low Output. May be pulled low by external open drain driver to reset the DW1000. Refer to DW1000 Datasheet for more details [2]. Power Supplies VDDAON 5 P External supply for the Always-On (AON) portion of the chip. VDD3V3 6,7 P 3.3 V supply pins. Note that for programming the OTP in the DWM1000 module this voltage may be increased to a nominal value of 3.8 V for short periods. © Decawave Ltd 2016 Version 1.8 Page 10 DWM1000 Datasheet SIGNAL NAME PIN I/O (Default) DESCRIPTION Ground GND 8,16, 21,23,24 G Common ground. Table 4: Explanation of Abbreviations ABBREVIATION I EXPLANATION Input IO Input / Output O Output G Ground P Power Supply PD Power Decoupling O-L Defaults to output, low level after reset O-H Defaults to output, high level after reset I Defaults to input. Note: Any signal with the suffix ‘n’ indicates an active low signal. © Decawave Ltd 2016 Version 1.8 Page 11 DWM1000 Datasheet 4 ELECTRICAL SPECIFICATIONS 4.1 Nominal Operating Conditions Table 5: DWM1000 Operating Conditions Parameter Min. Operating temperature -40 Supply voltage VDDAON, VDD3V3 2.8 Supply voltage VDD3V3 for programming OTP Typ. 3.3 3.7 3.8 Voltage on GPIO0..7, WAKEUP, RSTn, SPICSn, SPIMOSI, SPICLK Max. Units Condition/Note +85 ˚C 3.6 V Normal operation 3.9 V Note that for programming the OTP in the DWM1000 the VDD3V3 voltage must be increased to 3.8 V nominal for short periods. 3.6 V Note that 3.6 V is the max voltage that may be applied to these pins Note: Unit operation is guaranteed by design when operating within these ranges 4.2 DC Characteristics Tamb = 25 ˚C, all supplies centred on typical values Table 6: DWM1000 DC Characteristics Parameter Min. Supply current DEEP SLEEP mode Typ. Max. 200 Units nA Supply current SLEEP mode 550 nA Supply current IDLE mode 13.4 mA Supply current INIT mode 3.5 mA TX : 3.3 V supplies (VDDAON, VDD) RX : 3.3 V supplies (VDDAON, VDD) Digital input voltage high 4.3 mA Channel 5:TX Power: 9.3 dBm/500 MHz 160 mA Channel 5 0.3*VDD V V Assumes 500 Ω load 0.3*VDD V Assumes 500 Ω load V 0.7*VDD Digital output voltage low Digital Output Drive Current GPIOx, IRQ SPIMISO EXTON 4 8 3 Total current drawn from all supplies. 140 0.7*VDD Digital input voltage low Digital output voltage high Condition/Note 6 10 4 mA Receiver AC Characteristics Tamb = 25 ˚C, all supplies centred on nominal values Table 7: DWM1000 Receiver AC Characteristics Parameter Frequency range Min. Typ. 3244 Max. Units 6999 MHz Condition/Note Channel bandwidth 500 MHz Channel 1,2,3 and 5 In-band blocking level 30 dBc Continuous wave interferer Out-of-band blocking level 55 dBc Continuous wave interferer © Decawave Ltd 2016 Version 1.8 Page 12 DWM1000 Datasheet 4.4 Receiver Sensitivity Characteristics Tamb = 25 ˚C, all supplies centred on typical values. 20 byte payload. These sensitivity figures assume an antenna gain of 0 dBi and should be modified by the antenna characteristics quoted in Table 12 depending on the orientation of the DWM1000. Table 8: DWM1000 Typical Receiver Sensitivity Characteristics Packet Error Rate 1% 10% 4.5 Receiver Sensitivity Data Rate Units Condition/Note 110 kbps -102 dBm/500 MHz Preamble 2048 850 kbps -101 dBm/500 MHz Preamble 1024 6.8 Mbps -93 dBm/500 MHz Preamble 256 110 kbps -106 dBm/500 MHz Preamble 2048 850 kbps -102 dBm/500 MHz Preamble 1024 6.8 Mbps -94 dBm/500 MHz Preamble 256 All measurements performed on Channel 5, PRF 16 MHz Channel 2 is approximately 1 dB less sensitive Carrier frequency offset ±10 ppm Reference Clock AC Characteristics Tamb = 25 ˚C, all supplies centred on typical values 4.5.1 Reference Frequency Table 9: DWM1000 Reference Clock AC Characteristics Parameter Min. Typ. Max. Units Condition/Note On-board crystal oscillator reference frequency 38.4 MHz On-board crystal trimming range ±25 ppm Internally trimmed to +/- 2 ppm under typical conditions. ±30* ppm ppm -40⁰C to +85⁰ ±3 ppm/3year @25⁰C ±2⁰C 15 kHz On-board crystal frequency stability with temperature On-board crystal aging Low Power RC Oscillator 5 12 *By using the temperature monitoring capability of the DW1000 chip on the DWM1000 module it is possible to dynamically trim the crystal during run time to maintain the +/- 2ppm specification over the full temperature range of operation. 4.6 Transmitter AC Characteristics Tamb = 25 ˚C, all supplies centred on typical values Table 10: DWM1000 Transmitter AC Characteristics Parameter Frequency range Min. Typ. 3244 Max. Units 6999 MHz Channel Bandwidths 500 Output power spectral density (programmable) -39 Power level range 37 dB Coarse Power level step 3 dB Fine Power level step 0.5 dB Output power variation with temperature 0.05 dB/OC Output power variation with voltage 2.73 3.34 dB/V © Decawave Ltd 2016 MHz -35 dBm/MHz Condition/Note Channel 1, 2, 3 and 5 See DW1000 Datasheet [2] Channel 2 Channel 5 Version 1.8 Page 13 DWM1000 Datasheet 4.7 Temperature and Voltage Monitor Characteristics Table 11: DWM1000 Temperature and Voltage Monitor Characteristics Parameter Min. Voltage Monitor Range Typ. 2.4 Max. Units 3.75 V Voltage Monitor Precision 20 mV Voltage Monitor Accuracy 140 mV Temperature Monitor Range -40 Temperature Monitor Precision 4.8 +100 0.9 Condition/Note °C °C Antenna Performance The antenna used in the module is the Partron dielectric chip antenna, part number ACS5200HFAUWB, see [4] for full details. Antenna radiation patterns, measured in an anechoic chamber for three planes, are shown in Figure 7. As the antenna is linearly polarised, in the Azimuth plane the vertically polarised field (Theta) is measured and the horizontally polarised field (Phi) is measured for elevation planes 1 and 2. For these measurements, the DWM1000 module is mounted on a circuit board with dimensions shown in Figure 6. 2.85 cm 2.85 cm 7 cm 7 cm Figure 6. DWM1000 Circuit Board Mounting © Decawave Ltd 2016 Version 1.8 Page 14 DWM1000 Datasheet Gain (dBi) vs Angle (°) 320 310 Measurement Plane 180° 330 340 270° 10 5 0 -5 -10 -15 -20 -25 -30 300 290 90° 0 350 10 280 270 20 30 40 50 60 70 80 90 260 0° DUT rotated through 360° in this direction 100 250 110 240 120 230 220 210 200 190 180 170 160 150 130 140 Ch_5 Ch_2 Azimuth Plane (Theta) Gain (dBi) vs Angle (°) 320 310 330 340 300 180° 290 280 90° 270° 270 0 350 10 10 5 0 -5 -10 -15 -20 -25 -30 20 30 40 50 60 70 80 90 260 100 250 110 240 0° 120 230 220 210 200 190 180 170 160 150 130 140 Ch_5 Ch_2 Elevation 1 Plane (Phi) Gain (dBi) vs Angle (°) 320 180° 330 340 310 300 90° 270° 290 280 270 0° 350 10 0 10 5 0 -5 -10 -15 -20 -25 -30 20 30 40 50 60 70 80 90 100 260 110 250 120 240 130 230 220 210 200 190 180 170 160 150 140 Ch_5 Ch_2 Elevation 2 Plane (Phi) Figure 7. Measured Antenna Radiation Patterns © Decawave Ltd 2016 Version 1.8 Page 15 DWM1000 Datasheet 4.9 Absolute Maximum Ratings Table 12: DWM1000 Absolute Maximum Ratings Parameter Voltage VDD3V3 / VDDAON Min. Max. Units -0.3 4.0 V 0 dBm Receiver Power Temperature - Storage temperature -40 +85 ˚C Temperature – Operating temperature -40 +85 ˚C 2000 V ESD (Human Body Model) Stresses beyond those listed in this table may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions beyond those indicated in the operating conditions of the specification is not implied. Exposure to the absolute maximum rating conditions for extended periods may affect device reliability. © Decawave Ltd 2016 Version 1.8 Page 16 DWM1000 Datasheet 5 APPLICATION INFORMATION 5.1 Application Board Layout Guidelines When designing the PCB onto which DWM1000 will be soldered, the proximity of the DWM100 on-board ceramic monopole antenna to metal and other non-RF transparent materials needs to considered carefully. Two suggested placement schemes are shown below. For best RF performance, ground copper should be flooded in all areas of the application board, except in the areas marked “Keep-Out Area”, where there should be no metal either side, above or below (e.g. do not place battery under antenna). The placement schemes in Figure 8 show an application board with no non-RF transparent material in the keepout area, or an application board with the antenna projecting off of the board so that the keep out area is in freespace. In this second scheme it is still important not to place metal components above or below the antenna in a system implementation. It is also important to note that the ground plane on the application board affects the DWM1000 antenna radiation pattern. In Figure 8 below, d must be a minimum of 10 mm. This gives the most vertically polarized radiation pattern. As d is increased from 10 mm the degree of vertical polarization reduces. d d KeepOut Area KeepOut Area Antenna Antenna d d DWM1000 DWM1000 Application Board Application Board Figure 8: DWM1000 Application Board Keep-Out Areas 5.2 Application Circuit Diagram A simple application circuit integrating the DWM1000 module need only power the device and connect the device to a host controller, see Figure 9. UWB Chip Antenna DWM1000_RSTn 2 RSTn 3 GPIO7 4 VDDAON 5 VDD3V3 6 19 SPIMISO VDD3V3 7 18 SPIMOSI VSS 8 17 SPICSn DWM1000 22 IRQ / GPIO8 21 VSS GND Optional pulldown on IRQ to prevent spurious interrupts Host uProcessor VSS 16 GPIO1 / SFDLED 14 20 SPICLK GPIO0 / RXOKLED 15 GPIO3 / TXLED 12 GPIO6 / EXTRXE / SPIPHA © Decawave Ltd 2016 23 VSS Metal Cap 9 GND WAKEUP GPIO2 / RXLED 13 0.1uF +3.3 V 1 GPIO4 / EXTPA 11 Do not do this! RSTn must never be pulled high by an external source DWM1000_RSTn 24 VSS EXTON GPIO5 / EXTTXE / SPIPOL 10 +3.3 V GND Version 1.8 Page 17 DWM1000 Datasheet Figure 9: Example DWM1000 Application Circuit 5.2.1 SPI Bus The SPI signal bus and mode configuration pins may need to be treated carefully if it is desirable to connect additional SPI devices to the SPI bus, or to configure the SPI for a non-default clock polarity of phase behaviour. Please see the DW1000 Datasheet [2] for a description of all SPI clock polarity and phase configurations, referred to as SPI modes. The SPIMISO line may be connected to multiple slave SPI devices each of which is required to go open-drain when their respective SPICSn lines are de-asserted. The DW1000 has internal pull up and pull down circuits to ensure safe operation in the event of the host interface signals being disconnected. These are for internal use only, and should not be used to pull an external signal high or low. Internal pull-down resistance values are in the range 34 kΩ – 90 kΩ, internal pullup resistance values are in the range 40 kΩ - 90 kΩ. GPIO5 (SPIPOL) ~60kΩ ~55kΩ 30 DW1000 ~55 kΩ 24 39 ~55kΩ 40 41 SPICSn SPIMOSI SPIMISO SPI PORT GPIO6 (SPIPHA) VDDIOA 33 Host Controller SPICLK ~55kΩ Figure 10: SPI Bus Connections 5.2.2 Configuring the SPI Mode The SPI interface supports a number of different clock polarity and clock / data phase modes of operation. These modes are selected using GPIO5 & 6 as follows: Table 13: DW1000 SPI Mode Configuration GPIO 5 (SPIPOL) GPIO 6 (SPIPHA) SPI Mode 0 0 0 Data is sampled on the rising (first) edge of the clock and launched on the falling (second) edge. 0 1 1 Data is sampled on the falling (second) edge of the clock and launched on the rising (first) edge. 1 0 2 Data is sampled on the falling (first) edge of the clock and launched on the rising (second) edge. 1 1 3 Data is sampled on the rising (second) edge of the clock and launched on the falling (first) edge. Description (from the master / host point of view) Note: The 0 on the GPIO pins can either be open circuit or a pull down to ground. The 1 on the GPIO pins is a pull up to VDDIO. GPIO 5 / 6 are sampled / latched on the rising edge of the RSTn pin to determine the SPI mode. They are internally pulled low to configure a default SPI mode 0 without the use of external components. If a mode other than 0 is required then they should be pulled up using an external resistor of value no greater than 10 kΩ to the VDDIO output supply. If GPIO5 / 6 are also being used to control an external transmit / receive switch then external pull-up resistors of no less than 1 kΩ should be used so that the DW1000 can correctly drive these outputs in normal operation after the reset sequence / SPI configuration operation is complete. The recommended range of resistance values to pull-up GPIO 5 / 6 is in the range of 1-10 kΩ. If it is required to pull-down GPIO 5 / 6, such as in the case where the signal is also pulled high at the input to an external IC, the resistor value chosen needs to take account of the DW1000 internal pull-down resistor values as well as those of © Decawave Ltd 2016 Version 1.8 Page 18 DWM1000 Datasheet any connected external pull-up resistors. Refer to the DW1000 Data Sheet [2] and the DW1000 User Manual [3] for further details. 5.2.3 Powering down the DWM1000 The DWM1000 has a very low DEEPSLEEP current (typ. 200 nA – see Table 6). The recommended practise is to keep the DWM1000 powered up and use DEEPSLEEP mode when the device is inactive. In situations where the DWM1000 must be power-cycled (the +3.3V supply in figure 10 turned off and then back on) it is important to note that when power is removed the supply voltage will decay towards 0V at a rate determined by the characteristics of the power source and the amount of decoupling capacitance in the system. In this scenario, power should only be reapplied to the DWM1000 when: • • VDDAON is above 2.3 V or: VDDAON has fallen below 100 mV Reapplying power while VDDAON is between 100mV and 2.3V can lead to the DWM1000 powering up in an unknown state which can only be recovered by fully powering down the device until the voltage on VDDAON falls below 100 mV. © Decawave Ltd 2016 Version 1.8 Page 19 DWM1000 Datasheet 6 PACKAGE INFORMATION The DWM1000 V2 was introduced to the market in July 2020, replacing the previous DWM1000 V1 part which will no longer be produced. For more information on the changes from V1 to V2, see the product change notice PCN019. 6.1 Module Drawings All measurements are given in millimetres. Figure 11: Module Package Size (units: mm) 6.2 Module Land Pattern The diagram below shows the DWM1000 module land pattern. © Decawave Ltd 2016 Version 1.8 Page 20 DWM1000 Datasheet Figure 12: DWM1000 Module Land Pattern (units: mm) Table 14: Module weight Parameter Unit weight © Decawave Ltd 2016 Min Typ 1.4 Max Units g Version 1.8 Page 21 DWM1000 Datasheet 6.3 DWM1000 V1 Module Marking Information Figure 13: DWM1000 V1 Module Marking Information 6.4 DWM1000 V2 Module Marking Information YY WW 1 SSSSS Year Week DWM1000 Serial number Figure 14: DWM1000 V2 Module Marking Information © Decawave Ltd 2016 Version 1.8 Page 22 DWM1000 Datasheet 6.5 Module Solder Profile Figure 15: DWM1000 Module Solder Profile © Decawave Ltd 2016 Version 1.8 Page 23 DWM1000 Datasheet 7 ORDERING INFORMATION 7.1 Tape and Reel Information for DWM1000 V1 Figure 16: DWM1000 V1 Module Carrier Dimension (units: mm) © Decawave Ltd 2016 Version 1.8 Page 24 DWM1000 Datasheet Figure 17: DWM1000 V1 Module Tape Carrier Dimension (units: mm) © Decawave Ltd 2016 Version 1.8 Page 25 DWM1000 Datasheet 7.2 Tape and Reel Information for DWM1000 V2 Figure 18: DWM1000 V2 Module Carrier Dimension (units: mm) Figure 19: DWM1000 V2 Module Tape Carrier Dimension (units: mm) © Decawave Ltd 2016 Version 1.8 Page 26 DWM1000 Datasheet 7.3 7.3.1 DWM1000 Packaging Information Inner Box V2 Note 1) Recommendation: 72 hours floor time (30 degree C / 60 % RH) Note 2) Recommendation: The time between opening and chip mount should be within 72 hours Figure 20: Module Inner Box (units: mm) 7.3.2 Outer Box V2 Each box contents are 2000 x DWM1000 pieces total. In each box there are 4 Inner boxes containing 500 x DWM1000 each. Figure 21: Module Outer Box: (Module Quantity 2000 pieces) © Decawave Ltd 2016 Version 1.8 Page 27 DWM1000 Datasheet 8 REGULATORY INFORMATION 8.1 8.1.1 European Union requirements Radio Equipment Directive The DWM1000 Module has been certified for use in European Union countries. A copy of the EU Declaration of Conformity is available for download on our website. If these modules are incorporated into a product, the manufacturer must ensure continuing compliance of the final product to the Radio Equipment Directive 2014/53/EU. The manufacturer must then draw up a new written EU Declaration of Conformity as per RED Article 18. Furthermore, the manufacturer must ensure the final product does not exceed the specified power ratings, antenna specifications, and/or installation requirements as specified in this document. If any of these specifications are exceeded in the final product, the manufacturer must assess whether additional compliance testing is required. IMPORTANT: The “CE” marking must be in compliance with the RED Article 19. It must be affixed to a visible location on the OEM product. The CE mark shall have a height of at least 5mm except where this is not possible on account of the nature of the apparatus. The CE marking must be affixed visibly, legibly, and indelibly. © Decawave Ltd 2016 Version 1.8 Page 28 DWM1000 Datasheet 8.1.2 ETSI harmonised standards The DWM1000 module conforms with the requirements of the following ETSI standards: Essential requirement Art 3.1(a) – Health and safety Art 3.1(b) – EMC Art 3.2 – Spectrum use Art 3.3 – Delegated acts Standard EN 62479 Assessment of the compliance of low-power electronic and electrical equipment with the basic restrictions related to human exposure to electromagnetic fields (10 MHz to 300 GHz) EN62368-1 Audio/video, information and communication technology equipment. Safety requirements EN 301 489-33 Electromagnetic compatibility (EMC) standard for radio equipment and services; Part 33: Specific conditions for Ultra-WideBand (UWB) devices EN 302 065-1 Short Range Devices (SRD) using Ultra Wide Band technology (UWB); Harmonised Standard covering the essential requirements of article 3.2 of the Directive 2014/53/EU; Part 1: Requirements for generic UWB applications N/A Notes Also see (1). Products based on DWM1000 can comply with EN 301 48933(1). Products based on DWM1000 can comply with the EN 302 065 series(1). There are currently no delegated acts applicable to UWB products. (1) Guidance and instructions for manufacturers are available from the application note section on the web-site. https://www.decawave.com/APR003-Certification-Guide-Europe.pdf © Decawave Ltd 2016 Version 1.8 Page 29 DWM1000 Datasheet 9 GLOSSARY Table 15: Glossary of Terms Abbreviation Full Title Explanation EIRP Equivalent Isotropically Radiated Power The amount of power that a theoretical isotropic antenna (which evenly distributes power in all directions) would emit to produce the peak power density observed in the direction of maximum gain of the antenna being used ETSI European Telecommunication Standards Institute Regulatory body in the EU charged with the management of the radio spectrum and the setting of regulations for devices that use it FCC Federal Communications Commission Regulatory body in the USA charged with the management of the radio spectrum and the setting of regulations for devices that use it GPIO General Purpose Input / Output Pin of an IC that can be configured as an input or output under software control and has no specifically identified function IEEE Institute of Electrical and Electronic Engineers Is the world’s largest technical professional society. It is designed to serve professionals involved in all aspects of the electrical, electronic and computing fields and related areas of science and technology LIFS Long Inter-Frame Spacing Defined in the context of the IEEE 802.15.4-2011 [1] standard LNA Low Noise Amplifier Circuit normally found at the front-end of a radio receiver designed to amplify very low level signals while keeping any added noise to as low a level as possible LOS Line of Sight Physical radio channel configuration in which there is a direct line of sight between the transmitter and the receiver NLOS Non Line of Sight Physical radio channel configuration in which there is no direct line of sight between the transmitter and the receiver PGA Programmable Gain Amplifier Amplifier whose gain can be set / changed via a control mechanism usually by changing register values PLL Phase Locked Loop Circuit designed to generate a signal at a particular frequency whose phase is related to an incoming “reference” signal. PPM Parts Per Million Used to quantify very small relative proportions. Just as 1% is one out of a hundred, 1 ppm is one part in a million RF Radio Frequency Generally used to refer to signals in the range of 3 kHz to 300 GHz. In the context of a radio receiver, the term is generally used to refer to circuits in a receiver before down-conversion takes place and in a transmitter after up-conversion takes place RTLS Real Time Location System System intended to provide information on the location of various items in real-time. SFD Start of Frame Delimiter Defined in the context of the IEEE 802.15.4-2011 [1] standard. SPI Serial Peripheral Interface An industry standard method for interfacing between IC’s using a synchronous serial scheme first introduced by Motorola TCXO Temperature Controlled Crystal Oscillator A crystal oscillator whose output frequency is very accurately maintained at its specified value over its specified temperature range of operation. TWR Two Way Ranging Method of measuring the physical distance between two radio units by exchanging messages between the units and noting the times of transmission and reception. Refer to Decawave’s website for further information TDOA Time Difference of Arrival Method of deriving information on the location of a transmitter. The time of arrival of a transmission at two physically different locations whose clocks are synchronized is noted and the difference in the arrival times provides information on the location of the transmitter. A number of such TDOA measurements at different locations can be used to uniquely determine the position of the transmitter. Refer to Decawave’s website for further information. UWB Ultra Wideband A radio scheme employing channel bandwidths of, or in excess of, 500MHz WSN Wireless Sensor Network A network of wireless nodes intended to enable the monitoring and control of the physical environment © Decawave Ltd 2016 Version 1.8 Page 30 DW1000 Datasheet 10 REFERENCES [1] IEEE802.15.4-2011 or “IEEE Std 802.15.4™‐2011” (Revision of IEEE Std 802.15.4-2006). IEEE Standard for Local and metropolitan area networks – Part 15.4: Low-Rate Wireless Personal Area Networks (LRWPANs). IEEE Computer Society Sponsored by the LAN/MAN Standards Committee. Available from http://standards.ieee.org/ [2] Decawave DW1000 Datasheet www.decawave.com [3] Decawave DW1000 User Manual www.decawave.com [4] Partron(Now manufactured by Abracon) Dielectric Chip Antenna, P/N ACS5200HFAUWB(Now ACA-107-T), www.digikey.com also see www.abracon.com 11 DOCUMENT HISTORY Revision 1.01 Page Change Description All Update of version number to v1.01 1 Removal of range number 2 Update of table of contents 6 Modification of SPI timing diagrams figure 3 & 4 to correct timing definitions 7 Addition of note re external clock 8 Addition of footnote 20 Addition of section 4.2.3 re power down 27 Addition of v1.01 to table 16 Addition of this section & modification of heading numbers as a result Revision 1.1 Page Change Description All Update of version number to v1.1 4 Modification of copyright notice to 2015 12 Addition of note on Rx sensitivity 18 Addition of note on effect of application ground plane on antenna polarization 19 Addition of explanatory note to Table 14 column heading re SPI master 20 Addition of power supplies that should be removed to power down the chip 22 Addition of module weight in new Table 15 and update of all subsequent table captions 27 Addition of v1.1 to Table 17 Addition of this table © Decawave Ltd 2016 Version 1.8 Page 31 DW1000 Datasheet Revision 1.2 Page All Various Change Description Update of version number to v1.2 Minor typographical changes 7 Removal of section 1.9 External Synchronization 9 Modification to Figure 5 to correct pin names and correct the descriptions of GPIO5 & 6. 10 - 11 Modification to description of pin 4; removal of SYNC functionality as not applicable to DWM100. Modification to description of GPIO5 / 6 – SPIPHA and SPIPOL functionality was incorrectly stated. 12 Addition of OTP programming voltage to table 5 Addition of max digital input voltage to table 5 19 Modification to Figure 10 to correct pin names 27 - 28 Addition of v1.2 to table 17 Addition of this table Revision 1.3 Page All Various 18 27 - 28 Change Description Update of version number to v1.3 Minor typographical changes Modification to application board layout guidelines Addition of v1.3 to table 17 Addition of this table Revision 1.4 Page Change Description All Update of version number to v1.4 17 Insertion of measured antenna radiation pattern data 29 - 30 Addition of v1.4 to table 17 Addition of this table Revision 1.5 Page Change Description All Update of version number to v1.5 26 Update to refer to Abracon as antenna manufacturer. Revision 1.6 Page Change Description All Update of version number to v1.6 20 Update to Figure 11 to correct height dimension REVISION 1.7 Page All Change Description Update with new logo REVISION 1.8 Page All 22, 24 27 © Decawave Ltd 2016 Change Description Update with new logo Added V2 label details, packaging information. Add a regulatory information section Version 1.8 Page 32 DW1000 Datasheet 12 FURTHER INFORMATION Decawave develops semiconductors solutions, software, modules, reference designs - that enable real-time, ultra-accurate, ultra-reliable local area micro-location services. Decawave’s technology enables an entirely new class of easy to implement, highly secure, intelligent location functionality and services for IoT and smart consumer products and applications. For further information on this or any other Decawave product, please refer to our website www.decawave.com. © Decawave Ltd 2016 Version 1.8 Page 33
DWM1000 价格&库存
很抱歉,暂时无法提供与“DWM1000”相匹配的价格&库存,您可以联系我们找货
DWM1000
  • 1+93.84991
  • 10+89.99991
