XB8-DMUSB002
XB8-DMUSB002
    DIGIINTERNATIONAL
    模块
    XB8-DMUSB002
XB8-DMUSB002 数据手册
LOW-POWER RF MODULE FOR EUROPE XBEE® 868LP FOR EUROPE RF module family operates in the 863-870 MHz range utilizing 30 channels to deliver superior performance and interference immunity at 868 MHz The XBee 868LP module was designed to provide a high-performance, low-power module at an extremely competitive price point. The XBee 868LP module can run either a proprietary DigiMesh® or pointto-multipoint networking protocol utilizing a low-power Energy Micro microcontroller and an Analog Devices ADF7023 transceiver, which offers industry-leading interference blocking. The XBee 868LP operates between 863-870 MHz, making it deployable in several regions throughout the world including approved European countries and India by utilizing a software selectable channel masking feature. The XBee 868LP is also the industry’s first RF module using 868 MHz and surrounding frequencies for LBT + AFA (Listen Before Talk and Adaptive Frequency Agility). This virtually eliminates interference by BENEFITS listening to the radio environment before any transmission starts, and automatically shifting to a new channel when interference is detected. This patent-pending frequency scan occurs automatically and in a matter of microseconds so as not to impact performance. The programmable version of the XBee 868LP module makes customizing wireless applications easy. Programming directly on the module eliminates the need for a separate host processor. Because the wireless software is isolated, applications can be developed with no risk to RF performance, security or additional certifications. APPLICATION EXAMPLE – Industry’s first RF module to utilize LBT + AFA for interference immunity – Modules can operate in DigiMesh or point-to multipoint wireless networking topologies Ethernet – Programmable versions of the XBee 868LP enable custom application development - - 8-bit Freescale™ S08 microprocessor brings custom intelligence to the module XBee-specific CodeWarrior® development tools for easy programming – Pin-compatible with other XBee SMT modules UTILITY ENERGY MANAGEMENT SYSTEMS XBEE® 868 MHZ WIRELESS METER NETWORK XBEE® 868LP MODULE – RF throughput up to 50 Kbps Utility Meter Utility Meter Utility Meter Modules Digi Device CloudSM Technical Services Development Kits Cellular/VPN CONCENTRATOR GATEWAY RELATED PRODUCTS Gateways DEVICE CLOUD SPECIFICATIONS XBee® 868LP for Europe Programmable XBee® 868LP for Europe HARDWARE PROCESSOR ADF7023 transceiver, Cortex™-M3 EFM32G230 @ 32 MHz FREQUENCY BAND 863 MHz to 870 MHz ANTENNA OPTIONS U.FL, RF pad, PCB (PCB antenna only approved with 10 Kbps data rate) PERFORMANCE RF DATA RATE 10 Kbps or 80 Kbps INDOOR/URBAN RANGE Up to 370 ft (112 m) w/2.1 dBi antenna, up to 46 ft (14 m) w/PCB embedded antenna OUTDOOR/LINE-OF-SIGHT RANGE Up to 5.2 miles (8.4 km) w/2.1 dBi antenna, up to 0.4 miles (.64 km) w/PCB embedded antenna TRANSMIT POWER Up to 14 dBm (25 mW) E.I.R.P. w/ 2 dBi antenna, software selectable RECEIVER SENSITIVITY -101 dBm @ 80 Kbps, -106 dBm @ 10 Kbps FEATURES I/O 13 ANALOG INPUTS 4 channels 10-bit OPERATING TEMPERATURE -40° C to +85° C NETWORKING TOPOLOGIES DigiMesh®, Repeater, Point-to-point, Point-to-multipoint, Peer-to-peer PROGRAMMABILITY MEMORY N/A 32 KB Flash / 2 KB RAM CPU/CLOCK SPEED N/A HCS08 / Up to 50.33 MHz POWER SUPPLY VOLTAGE 2.7- 3.6 VDC TRANSMIT CURRENT 48 mA 62 mA RECEIVE CURRENT 27 mA 41 mA SLEEP CURRENT 1.7 uA 2.3 uA REGULATORY APPROVALS ETSI (EUROPE) CE ROHS Yes Point-to-Multipoint / Star DigiMesh Top View Side View Bottom View WWW.DIGI.COM PART NUMBERS DESCRIPTION XB8-DMRS-002 XBee 865/868LP RF pad Antenna 80kbps XB8-DMUS-002 XBee 865/868LP U.FL Antenna 80kbps XB8-DMPS-002 XBee 865/868LP PCB Antenna 80kbps (Not Approved in Europe) XB8-DPPS-001 XBee 865/868LP PCB Antenna 10kbps XB8-DPRS-001 XBee 865/868LP RF pad Antenna 10kbps XB8-DPUS-001 XBee 865/868LP U.FL Antenna 10kbps XB8-DMPSB002 XBee DigiMesh 865/868LP PCB Antenna 80Kbps, 32K Programmable (Not Approved in Europe) XB8-DMUSB002 XBee DigiMesh 865/868LP U.FL Antenna 80Kbps, 32K Programmable XB8-DMRSB002 XBee DigiMesh 865/868LP RF Pad Antenna 80Kbps, 32K Programmable XK8-DMS-0 XBee 865/868LP Dev Kit Modules in this kit require additional configuration for use in India. See the Product Manual for more details XK8-DMSB0 XBee 865/868LP Dev Kit 32K Programmable FOR MORE INFORMATION PLEASE VISIT WWW.DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2015 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001811 B1/915 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL FRANCE +33-1-55-61-98-98 / www.digi.fr DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XB8-DMUSB002 价格&库存
很抱歉,暂时无法提供与“XB8-DMUSB002”相匹配的价格&库存,您可以联系我们找货
