XBP9X-DMUS-001
XBP9X-DMUS-001
    DIGIINTERNATIONAL
    模块
    XBP9X-DMUS-001
XBP9X-DMUS-001 数据手册
XBee®/XBee-PRO SX Radio Frequency (RF) Module User Guide Revision history—90001477 Revision Date Description J January 2019 Updated the Brazilian certifications. K January 2020 Added IFETEL certifications. L November 2020 Added the C8 and R? commands. Added the Sleep Immediate and Synchronous pulse sections. Added information on randomizing a single I/O sample. Revised BC. M July 2021 Added safety instructions. N September 2021 Updated Mexican certifications. Trademarks and copyright Digi, Digi International, and the Digi logo are trademarks or registered trademarks in the United States and other countries worldwide. All other trademarks mentioned in this document are the property of their respective owners. © 2022 Digi International Inc. All rights reserved. Disclaimers Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International. Digi provides this document “as is,” without warranty of any kind, expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. Warranty To view product warranty information, go to the following website: www.digi.com/howtobuy/terms Customer support Gather support information: Before contacting Digi technical support for help, gather the following information:    Product name and model    Product serial number (s)    Firmware version    Operating system/browser (if applicable) XBee®/XBee-PRO SX RF Module User Guide 2    Logs (from time of reported issue)    Trace (if possible)    Description of issue    Steps to reproduce Contact Digi technical support: Digi offers multiple technical support plans and service packages. Contact us at +1 952.912.3444 or visit us at www.digi.com/support. Feedback To provide feedback on this document, email your comments to techcomm@digi.com Include the document title and part number (XBee®/XBee-PRO SX RF Module User Guide, 90001477 N) in the subject line of your email. XBee®/XBee-PRO SX RF Module User Guide 3 Contents XBee®/XBee-PRO SX RF Module User Guide Applicable firmware and hardware Safety instructions XBee modules 14 14 14 Technical specifications Regulatory conformity summary Power requirements Networking specifications Performance specifications General specifications GPIO specifications 16 16 16 17 18 19 Hardware Mechanical drawings Pin signals Pin connection recommendations 21 22 24 Getting started with the XBee/XBee-PRO SX RF Module Development Kit XBee SX Development Board Connect XBee-PRO SX development boards to a PC Connect the XBIB-U-SS development board to a PC Configure the device using XCTU Configure the devices for a range test Perform a range test Mesh network demonstration Software libraries XBee Network Assistant XBee Multi Programmer 26 27 28 28 28 29 30 32 32 33 Modes Transparent and API operating modes Transparent operating mode XBee®/XBee-PRO SX RF Module User Guide 35 35 4 API operating mode Comparing Transparent and API modes Modes of operation Receive mode Transmit mode Sleep mode Command mode 35 35 36 36 37 37 37 Sleep modes About sleep modes Asynchronous modes Synchronous modes Normal mode Asynchronous pin sleep mode Asynchronous cyclic sleep mode Asynchronous cyclic sleep with pin wake up mode Synchronous sleep support mode Synchronous cyclic sleep mode The sleep timer Indirect messaging and polling Indirect messaging Polling Sleeping routers Sleep coordinator sleep modes in the DigiMesh network Synchronization messages Become a sleep coordinator Preferred sleep coordinator option Resolution criteria and selection option Commissioning Pushbutton option Auto-early wake-up sleep option Select sleep parameters Sleep immediate Synchronous pulse Configuration Accuracy Start a sleeping synchronous network Add a new node to an existing network Change sleep parameters Rejoin nodes that lose sync Diagnostics Query sleep cycle Sleep status Missed sync messages command Sleep status API messages 41 41 41 41 42 42 42 42 43 43 43 43 44 44 44 45 47 47 47 48 50 50 50 51 51 51 51 52 53 54 54 54 55 55 55 Networking methods The MAC and PHY layers 64-bit addresses Make a unicast transmission Make a broadcast transmission Delivery methods Point to Point / Point to Multipoint (P2MP) XBee®/XBee-PRO SX RF Module User Guide 57 57 58 58 58 58 5 Repeater/directed broadcast DigiMesh networking 59 59 Serial communication UART data flow Serial data SPI signals Signal description Slave mode characteristics Full duplex operation Low power operation Configuration considerations SPI and API mode SPI parameters Serial port selection Serial receive buffer Serial transmit buffer UART flow control CTS flow control RTS flow control 64 64 64 65 65 66 66 67 67 67 67 68 68 68 68 68 AT commands Special commands AC (Apply Changes) FR (Software Reset) RE (Restore Defaults) WR (Write) MAC/PHY commands AF (Available Frequencies) CM (Channel Mask) MF (Minimum Frequencies) HP (Preamble ID) ID (Network ID) MT (Broadcast Multi-Transmits) BR (RF Data Rate) PL (TX Power Level) RR (Unicast Mac Retries) ED (Energy Detect) Diagnostic commands - MAC statistics and timeouts BC (Bytes Transmitted) DB (Last Packet RSSI) ER (Receive Count Error) GD (Good Packets Received) EA (MAC ACK Failure Count) TR (Transmission Failure Count) UA (Unicasts Attempted Count) %H (MAC Unicast One Hop Time) %8 (MAC Broadcast One Hop Time) Network commands CE (Routing / Messaging Mode) C8 (Compatibility Options) BH (Broadcast Hops) XBee®/XBee-PRO SX RF Module User Guide 71 71 71 71 71 72 72 72 73 74 74 74 75 75 76 77 77 77 77 78 78 78 79 79 79 79 79 80 80 81 6 NH (Network Hops) MR (Mesh Unicast Retries) NN (Network Delay Slots) Addressing commands SH (Serial Number High) SL (Serial Number Low) DH (Destination Address High) DL (Destination Address Low) TO (Transmit Options) NI (Node Identifier) NT (Network Discovery Back-off) NO (Network Discovery Options) CI (Cluster ID) Diagnostic - addressing commands N? (Network Discovery Timeout) R? (Region) Addressing discovery/configuration commands AG (Aggregator Support) DN (Discover Node) ND (Network Discover) FN (Find Neighbors) Security commands EE (Encryption Enable) KY (AES Encryption Key) KZ (Remote AT Command Password) Serial interfacing commands BD (Interface Data Rate) NB (Parity) SB (Stop Bits) RO (Packetization Timeout) FT (Flow Control Threshold) AP (API Enable) AO (API Options) I/O settings commands D0 (DIO0/AD0) D1 (DIO1/AD1) D2 (DIO2/AD2) D3 (DIO3/AD3) D4 (DIO4) D5 (DIO5/ASSOCIATED_INDICATOR) D6 (DIO6/RTS) D7 (DIO7/CTS) D8 (DIO8/SLEEP_REQUEST) D9 (DIO9/ON_SLEEP) P0 (DIO10/RSSI/PWM0 Configuration) P1 (DIO11/PWM1 Configuration) P2 (DIO12 Configuration) P3 (DIO13/DOUT) P4 (DIO14/DIN) P5 (DIO15/SPI_MISO) P6 (SPI_MOSI) P7 (DIO17/SPI_SSEL ) P8 (DIO18/SPI_SCLK) P9 (DIO19/SPI_ATTN) PD (Pull Direction) XBee®/XBee-PRO SX RF Module User Guide 81 81 81 82 82 82 82 83 83 83 84 84 85 85 85 85 86 86 86 87 88 88 88 89 89 90 90 91 92 92 92 92 93 93 93 94 94 95 95 96 96 97 97 98 98 99 99 100 100 101 101 102 102 103 103 7 PR (Pull-up/Down Resistor Enable) M0 (PWM0 Duty Cycle) M1 (PWM1 Duty Cycle) LT (Associated LED Blink Time) RP (RSSI PWM Timer) I/O sampling commands AV (Analog Voltage Reference) IC (DIO Change Detect) IF (Sleep Sample Rate) IR (Sample Rate) IS (Immediate Sample) TP (Board Temperature) %V (Voltage Supply Monitoring) I/O line passing commands IU (I/O Output Enable) IA (I/O Input Address) T0 (D0 Timeout) T1 (D1 Output Timeout) T2 (D2 Output Timeout) T3 (D3 Output Timeout) T4 (D4 Output Timeout) T5 (D5 Output Timeout) T6 (D6 Output Timeout) T7 (D7 Output Timeout) T8 (D8 Timeout) T9 (D9 Timeout) Q0 (P0 Timeout) Q1 (P1 Timeout) Q2 (P2 Timeout) Q3 (P3 Timeout) Q4 (P4 Timeout) PT (PWM Output Timeout) Sleep commands SM (Sleep Mode) SO (Sleep Options) SN (Number of Cycles Between ON_SLEEP) SP (Sleep Time) ST (Wake Time) WH (Wake Host Delay) Diagnostic - sleep status/timing commands SS (Sleep Status) OS (Operating Sleep Time) OW (Operating Wake Time) MS (Missed Sync Messages) SQ (Missed Sleep Sync Count) Command mode options CC (Command Sequence Character) CT (Command Mode Timeout) CN (Exit Command Mode) GT (Guard Times) Firmware version/information commands VR (Firmware Version) HV (Hardware Version) HS (Hardware Series) DD (Device Type Identifier) XBee®/XBee-PRO SX RF Module User Guide 103 104 105 105 105 106 106 106 107 107 108 108 108 108 109 109 109 110 110 110 110 111 111 111 111 112 112 112 112 113 113 113 113 113 114 115 115 116 116 116 116 117 117 118 118 118 118 119 119 119 119 119 120 120 120 8 NP (Maximum Packet Payload Bytes) CK (Configuration CRC) 120 120 Operate in API mode API mode overview Use the AP command to set the operation mode API frame format API operation (AP parameter = 1) API operation with escaped characters (AP parameter = 2) Length field Frame data Calculate and verify checksums 123 123 123 123 124 125 125 125 API frames API frame exchanges AT commands Transmit and Receive RF data Remote AT commands Device Registration Code to support future API frames 64-bit Transmit Request - 0x00 Description Format Examples Local AT Command Request - 0x08 Description Format Examples Queue Local AT Command Request - 0x09 Description Examples Transmit Request - 0x10 Description Transmit options bit field Examples Explicit Addressing Command Request - 0x11 Description 64-bit addressing Reserved endpoints Reserved cluster IDs Reserved profile IDs Transmit options bit field Examples Remote AT Command Request - 0x17 Description Format Examples Secure Remote AT Command Request frame - 0x18 Modem Status - 0x8A Description Examples Extended Transmit Status - 0x8B XBee®/XBee-PRO SX RF Module User Guide 128 128 128 129 129 130 131 131 131 132 133 133 133 133 135 135 135 137 137 138 138 140 140 140 140 140 140 141 142 144 144 144 145 147 150 150 151 152 9 Description Route Information - 0x8D Description Format Examples Aggregate Addressing Update - 0x8E Description Examples 64-bit Receive Packet - 0x80 Description Format Examples Local AT Command Response - 0x88 Description Examples Transmit Status - 0x89 Description Delivery status codes Examples Receive Packet - 0x90 Description Examples Explicit Receive Indicator - 0x91 Description Examples Node Identification Indicator - 0x95 Description Examples Remote AT Command Response- 0x97 Description Examples 152 154 154 154 155 156 156 156 158 158 158 159 160 160 160 162 162 163 163 164 164 165 166 166 167 168 168 169 171 171 172 Work with networked devices Network commissioning and diagnostics Local configuration Remote configuration Send a remote command Apply changes on remote devices Remote command response Secure remote AT commands How secure remote AT commands protect the network Password protection Password recovery Secure remote command control Security protections Secure a network Software downgrades Establish and maintain network links Build aggregate routes DigiMesh routing examples Replace nodes Test links in a network - loopback cluster Test links between adjacent devices Example XBee®/XBee-PRO SX RF Module User Guide 175 175 175 175 175 175 176 176 176 176 177 177 177 178 178 178 179 179 180 180 181 10 RSSI indicators Discover all the devices on a network Trace route option NACK messages The Commissioning Pushbutton Associate LED 182 182 183 184 184 186 Monitor I/O lines Pin configurations Queried sampling Periodic I/O sampling Detect digital I/O changes 188 189 190 190 I/O line passing Configuration example 192 General Purpose Flash Memory General Purpose Flash Memory Access General Purpose Flash Memory General Purpose Flash Memory commands PLATFORM_INFO_REQUEST (0x00) PLATFORM_INFO (0x80) ERASE (0x01) ERASE_RESPONSE (0x81) WRITE (0x02) and ERASE_THEN_WRITE (0x03) WRITE _RESPONSE (0x82) and ERASE_THEN_WRITE_RESPONSE (0x83) READ (0x04) READ_RESPONSE (0x84) FIRMWARE_VERIFY (0x05) and FIRMWARE_VERIFY_AND_INSTALL(0x06) FIRMWARE_VERIFY_RESPONSE (0x85) FIRMWARE_VERIFY _AND_INSTALL_RESPONSE (0x86) 196 196 197 197 197 198 198 199 200 200 201 201 202 202 Update the firmware over-the-air Over-the-air firmware updates Distribute the new application Example Verify the new application Install the application Important considerations 205 205 205 206 206 206 Regulatory information FCC (United States) OEM labeling requirements FCC notices RF exposure statement FCC antenna certifications XBee-PRO SX antenna options (30 dBm maximum RF power) XBee®/XBee-PRO SX RF Module User Guide 208 208 208 210 210 211 11 XBee SX antenna options (13 dBm maximum RF power) FCC publication 996369 related information ISED (Innovation, Science and Economic Development Canada) Labeling requirements Transmitters for detachable antennas Detachable antennas ACMA (Australia) Power requirements RSM (New Zealand) Power requirements Brazil (Anatel) ANATEL Brazil for XBee-PRO SX radio products (XBPSX) SX ANATEL Brazil for XK9X-DMS-1 XBee SX RF Module Dev Kit (XK9X-DMS-1) ANATEL Brazil for XBee SX radio products (XBSX) IFETEL (Mexico) OEM labeling requirements 216 221 223 223 223 223 224 224 224 224 225 225 226 227 228 228 PCB design and manufacturing Recommended footprint and keepout Design notes Host board design Improve antenna performance RF pad version Recommended solder reflow cycle Flux and cleaning Rework XBee®/XBee-PRO SX RF Module User Guide 230 232 232 233 233 234 235 235 12 XBee®/XBee-PRO SX RF Module User Guide The XBee/XBee-PRO SX RF Module is an embedded radio frequency (RF) device that provides wireless connectivity to end-point devices in mesh networks. The XBee/XBee-PRO SX RF Module delivers up to 1 Watt of RF power and has excellent receive sensitivity, low operating current, and exceptional performance in low power modes. The module’s frequency hopping technology offers advanced interference immunity, affording long range data throughput even in challenging RF environments. The XBee/XBee-PRO SX RF Module uses a microprocessor that supports host communication through Serial Peripheral Interface (SPI) or universal asynchronous receiver/transmitter (UART), as well as digital, analog, and pulse width modulation (PWM) lines for interfacing with peripherals. Applicable firmware and hardware Safety instructions XBee®/XBee-PRO SX RF Module User Guide 14 14 13 XBee®/XBee-PRO SX RF Module User Guide Applicable firmware and hardware Applicable firmware and hardware This manual supports the following firmware: n 0x900X USA and Canada, XBee/XBee-PRO SX n 0x920x Australia, XBee/XBee-PRO SX n 0x930X Brazil XBee/XBee-PRO SX n 0x960X New Zealand, XBee SX only Note The New Zealand firmware only works with non-PRO hardware. It supports the following hardware: n XBee/XBee-PRO SX RF Module Safety instructions XBee modules n The XBee radio module cannot be guaranteed operation due to the radio link and so should not be used for interlocks in safety critical devices such as machines or automotive applications. n The XBee radio module have not been approved for use in (this list is not exhaustive): l medical devices l nuclear applications l explosive or flammable atmospheres n There are no user serviceable components inside the XBee radio module. Do not remove the shield or modify the XBee in any way. Modifications may exclude the module from any warranty and can cause the XBee radio to operate outside of regulatory compliance for a given country, leading to the possible illegal operation of the radio. n Use industry standard ESD protection when handling the XBee module. n Take care while handling to avoid electrical damage to the PCB and components. n Do not expose XBee radio modules to water or moisture. n Use this product with the antennas specified in the XBee module user guides. n The end user must be told how to remove power from the XBee radio module or to locate the antennas 20 cm from humans or animals. XBee®/XBee-PRO SX RF Module User Guide 14 Technical specifications Regulatory conformity summary Power requirements Networking specifications Performance specifications General specifications GPIO specifications XBee®/XBee-PRO SX RF Module User Guide 16 16 16 17 18 19 15 Technical specifications Regulatory conformity summary Regulatory conformity summary This table describes the agency approvals for the devices. The Australia, New Zealand and Brazil certified devices are separate variants from the USA and Canada approved device. Country Approval XBee-PRO SX XBee SX United States FCC ID: MCQ-XBPSX FCC ID: MCQ-XBSX Canada IC: 1846A-XBPSX IC: 1846A-XBSX Australia RCM RCM New Zealand R-NZ Brazil ANATEL: 05774-16-01209 ANATEL: 05776-16-01209 Mexico RCPDIXB19-2288 RCPDIXB19-1819 Power requirements The following table describes the power requirements for the XBee/XBee-PRO SX RF Module. Specification Condition XBee SX value XBee-PRO SX value Supply voltage range 2.4 to 3.6 VDC 2.6 to 3.6 VDC Typical supply voltage 3.3 V Receive current VCC = 3.3 V 40 mA 40 mA Transmit current VCC = 3.3 V 55 mA @ 13 dBm 900 mA @ 30 dBm VCC = 3.3 V 45 mA @ 10 dBm 640 mA @ 27 dBm VCC = 3.3 V 35 mA @ 0 dBm 350 mA @ 21.5 dBm VCC 3.3 V, temperature = 25 °C 2.5 µA 2.5 µA Sleep current Networking specifications The following table provides the networking specifications for the device. Specification Value Modulation Gaussian Frequency Shift Keying (GFSK) Spreading technology Frequency Hopping Spread Spectrum (FHSS) Supported network Peer-to-peer (master/slave relationship not required), point-to-point/point-tomultipoint, mesh XBee®/XBee-PRO SX RF Module User Guide 16 Technical specifications Specification Performance specifications Value topologies (software selectable) Encryption Optional 256-bit Advanced Encryption Standard (AES) encryption which may be operated in either cipher block chaining (CBC) mode or counter (CTR) mode. Use the EE command to enable encryption. Use the KY command to set the encryption key. Performance specifications The following table describes the performance specifications for the devices. Note Range figure estimates are based on free-air terrain with limited sources of interference. Actual range will vary based on transmitting power, orientation of transmitter and receiver, height of transmitting antenna, height of receiving antenna, weather conditions, interference sources in the area, and terrain between receiver and transmitter, including indoor and outdoor structures such as walls, trees, buildings, hills, and mountains. Specification Condition Frequency range RF data rate (software selectable) Low data rate 10 kb/s Middle data rate 110 kb/s High data rate 250 kb/s Up to 13 dBm New Zealand specific Up to 13 dBm, at the high data rate (BR 2) it is capped at 7.5 dBm High data rate 120 kb/s Channels Available channel frequencies XBee-PRO value ISM 902 to 928 MHz Transmit power (software selectable) Maximum data throughput XBee value Up to 30 dBm1 10 hopping sequences share 50 frequencies Low/middle data rate 1012 High data rate 50 130 dBm typical at 3.3 V and above. Maximum power will decrease at lower voltages. For more information on adjustable power levels, see PL (TX Power Level). 2The device hops on 50 channels selected using the CM command, from 101 available frequencies. For more details, see CM (Channel Mask). XBee®/XBee-PRO SX RF Module User Guide 17 Technical specifications General specifications XBee-PRO value Specification Condition XBee value Rural range line of sight Low data rate Up to 14.5 km (9 mi) Up to 105 km (65 mi)1 Urban range line of sight Low data rate Up to 2.5 km (1.5 mi) Up to 18 km (11 mi)2 Receiver sensitivity Low data rate -113 dBm Middle data rate -106 dBm High data rate -103 dBm Low data rate ± 250 kHz 40 dB Low data rate ± 500 kHz 50 dB Middle data rate ± 250 kHz 30 dB Middle data rate ± 500 kHz 40 dB High data rate ± 500 kHz 30 dB High data rate ± 1000 kHz 45 dB Below 900 MHz and above 930 MHz > 50 dB Receiver IF selectivity Receiver RF selectivity UART data rate (software selectable) 1200 - 921600 baud SPI clock rate Up to 6 Mb/s General specifications The following table describes the general specifications for the devices. Specification Value Dimensions 3.38 x 2.21 x 0.32 cm (1.33 x 0.87 x 0.125 in) Weight 3g 1We estimate rural ranges based on a 14.5 km (9 mi) range test with dipole antennas. 2Range estimated assuming that the urban noise floor is approximately 15 dB higher than rural. The actual range depends on the setup and level of interference in your location. XBee®/XBee-PRO SX RF Module User Guide 18 Technical specifications GPIO specifications Specification Value Restriction of Hazardous Substances (RoHS) Compliant Manufacturing ISO 9001:2008 registered standards Host interface connector 37 castellated SMT pads Antenna connector options U.FL or RF pad Antenna impedance 50 Ω unbalanced Maximum input RF level at antenna port 6 dBm Operating temperature -40 °C to 85 °C Digital I/O 13 I/O lines, 5 output lines Analog-to-digital converter (ADC) 4 10-bit analog inputs Pulse width modulator (PWM) 2 outputs GPIO specifications The following table provides the electrical specifications for the GPIO pads. GPIO electrical specification Value Voltage - supply 2.4 - 3.6 V Low Schmitt switching threshold 0.3 * VCC High Schmitt switching threshold 0.7 * VCC Input current for logic 0 -0.1 μA Input current for logic 1 0.1 μA Input pull-up resistor value 40 kΩ Input pull-down resistor value 40 kΩ Output voltage for logic 0 0.05 * VCC Output voltage for logic 1 0.95 * VCC Output source/sink current 1 mA Total output current (for GPIO pads) 20 mA XBee®/XBee-PRO SX RF Module User Guide 19 Hardware Mechanical drawings Pin signals XBee®/XBee-PRO SX RF Module User Guide 21 22 20 Hardware Mechanical drawings Mechanical drawings The following figures show the XBee/XBee-PRO SX RF Module mechanical drawings. All dimensions are in centimeters. The XBee/XBee-PRO SX RF Module differs from other surface-mount XBee modules. It has an additional ground pad on the underside of the module used for heat dissipation. For more details, see PCB design and manufacturing. XBee®/XBee-PRO SX RF Module User Guide 21 Hardware Pin signals Pin signals The following table describes the pin signals. Low-asserted signals are distinguished with a horizontal line over the signal name. Pin Name I/O Default state Function 1 GND - - Ground 2 VCC I - Power supply 3 DIO13/DOUT I/O Output GPIO / UART data out 4 DIN/DIO14/CONFIG I/O Input GPIO / UART data in 5 DIO12 I/O Disabled GPIO XBee®/XBee-PRO SX RF Module User Guide 22 Hardware Pin signals Pin Name I/O Default state 6 RESET I - Drive low to reset device. Do not drive pin high; pin may only be driven open drain or low. Pin has an internal 20k pullup resistor. The minimum reset pulse time is 100 ns. 7 DIO10/RSSI/PWM0 I/O Output GPIO / RX Signal Strength Indicator 8 DIO11/PWM1 I/O Disabled GPIO / Pulse Width Modulator 9 [Reserved] - - Do not connect 10 DIO8/DTR /SLEEP_ RQ I/O Input GPIO / Pin Sleep Control line (DTR on the development board) 11 GND - - Ground 12 DO19/SPI_ATTN O Output GPO / Serial Peripheral Interface (SPI) Attention or UART Data Present indicator 13 GND - - Ground 14 DO18/SPI_CLK I/O1 Input GPO / SPI clock 15 DO17/SPI_SSEL I/O2 Input GPO / SPI not select 16 DO16/SPI_MOSI I/O3 Input GPO / SPI Data In 17 DO15/SPI_MISO O Output GPO/SPI Data Out Tri-stated when SPI_SSEL is high 18 [Reserved] - - Do not connect 19 [Reserved] - - Do not connect 20 [Reserved] - - Do not connect 21 [Reserved] - - Do not connect 22 GND - - Ground 23 [Reserved] - - Do not connect 24 DIO4 I/O Disabled GPIO 25 DIO7/CTS I/O Output GPIO / UART Clear to Send Flow Control 26 DIO9/ON/SLEEP I/O Output GPIO / Module Sleep Status Indicator 27 VREF - - Feature not supported on this device. Used on Function 1Pins 14-16 are inputs in SPI mode only. In general purpose I/O pin mode you can only use them as digital outputs. 2Pins 14-16 are inputs in SPI mode only. In general purpose I/O pin mode you can only use them as digital outputs. 3Pins 14-16 are inputs in SPI mode only. In general purpose I/O pin mode you can only use them as digital outputs. XBee®/XBee-PRO SX RF Module User Guide 23 Hardware Pin Pin signals Name I/O Default state Function other XBee devices for analog voltage reference. 28 DIO5/ASSOC I/O Output GPIO / Associate Indicator 29 DIO6/RTS I/O Disabled GPIO / UART Request to Send Flow Control 30 DIO3/AD3 I/O Disabled GPIO / Analog Input 31 DIO2/AD2 I/O Disabled GPIO / Analog Input 32 DIO1/AD1 I/O Disabled GPIO / Analog Input 33 DIO0/AD0 I/O Input GPIO / Analog Input / Commissioning Pushbutton 34 [Reserved] - - Do not connect 35 GND - - Ground 36 RF_PAD I/O - RF connection for RF pad variant 37 [Reserved] - - Do not connect 38 GND - - Ground pad for heat transfer to host PCB. Located on the underside of the XBee module. Pin connection recommendations The only required pin connections are VCC, GND, DOUT and DIN. To support serial firmware updates, you should connect VCC, GND, DOUT, DIN, RTS, and SLEEP (DTR). XBee®/XBee-PRO SX RF Module User Guide 24 Getting started with the XBee/XBee-PRO SX RF Module Development Kit This section provides getting started instructions if you have an XBee/XBee-PRO SX RF Module development kit: n USA XK9X-DMS-0 n Australia XK9X-DMS-2 n Brazil XK9X-DMS-1 This section describes how to set up an XBee network and adjust the XBee/XBee-PRO SX RF Module settings. This section provides information on the Development Board for the XBee/XBee-PRO SX RF Module and getting started instructions if you have an XBee/XBee-PRO SX RF Module Development Kit. XBee SX Development Board Connect XBee-PRO SX development boards to a PC Connect the XBIB-U-SS development board to a PC Configure the device using XCTU Configure the devices for a range test Perform a range test Mesh network demonstration Software libraries XBee Network Assistant XBee Multi Programmer XBee®/XBee-PRO SX RF Module User Guide 26 27 28 28 28 29 30 32 32 33 25 Getting started with the XBee/XBee-PRO SX RF Module Development Kit XBee SX Development Board XBee SX Development Board The following figure shows the XBee SX development board with onboard XBee-PRO SX RF pad module and the table that follows explains the callouts in the picture. Number Item Description 1 RSSI LEDs LEDs display the fade margin present in an active wireless link. No LEDs illuminated indicates either a weak or no signal. All three LEDs illuminated indicates a strong link. 2 Status LED indicators From bottom to top: Associated, Data In, Data Out 3 DIO pin LED indicators From bottom to top: DIO4, DIO11, DIO12 4 DC barrel plug 9 to 18 VDC DC supply is required for transmitting at 27 dBm or higher. WARNING! Do not exceed 18 VDC. Excessive voltage will damage the device and may cause injury. 5 Do not connect Do not connect to these pins. This development board does not support the device's self power feature. 6 USB connector Connect a mini USB cable from this port to the host PC. XBee®/XBee-PRO SX RF Module User Guide 26 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Connect XBee-PRO SX development boards to a PC Number Item Description 7 Reset button When pressed, the button switch resets the device by pulling pin 6 low. 8 Commissioning button When pressed, the button switch pulls the device's pin 33 low. 9 Development header 0.1” pitch header corresponds to pins 1 through 34 on the XBee/XBee-PRO SX RF Module. Abbreviated labels are silkscreened to the left of the header. 10 RPSMA connector Attach an antenna or RF cable to this jack. This connection is valid only if the board has an RF pad XBee. 11 XBee/XBee-PRO SX RF Modulefootprint Connect XBee-PRO SX development boards to a PC 1. Connect both SX development boards to power supplies and plug the power supplies into an outlet. The power supply is required when using the XBee-PRO SX because the current draw when transmitting will exceed what a USB port can supply. 2. Connect the SX development boards to the USB port on a PC via the mini-USB cables. Separate the SX development boards by at least 2 m (6 ft). 3. Connect the antennas to the RPSMA connector on the SX development boards. The following table shows the XBee SX development kit contents. Description Quantity Part number XBee surface-mount (SMT) socket development board 1 XBIB-U-SS SX development board with onboard XBee-PRO SX RF pad module 2 USA - XBIB-XBP9XR-0 Australia - XBIB-XBP9XR-2 Brazil - XBIB-XBP9XR-1 Standard USB cable 1 N/A Mini USB cable 2 N/A 12 VDC power supply 2 Australia and Brazil include packages of AC adapters RPSMA antenna 3 A09-HASM-675 U.FL to RPSMA adapter cable 1 JF1R6-CR3-4I XBee SX U.FL module 1 USA - XB9X-DMUS-001 Australia - XB9X-DMUS-021 Brazil - XB9X-DMUS-011 XBee®/XBee-PRO SX RF Module User Guide 27 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Connect the XBIB-U-SS development board to a PC Connect the XBIB-U-SS development board to a PC This step is optional. It shows how to set up the standalone XBee SX module on the XBIB-U-SS development board, which you can substitute as one of the range test devices or use with the other two devices to create a DigiMesh network. You can find reference information on the XBIB-U-SS at this link: http://ftp1.digi.com/support/documentation/xbibuss_referenceguide.pdf. To connect the XBee devices to the XBIB-U-SS development boards included in the kit: CAUTION! Make sure the board is not powered by either the USB or a battery when you plug in the XBee module. 1. Plug one XBee SX RF Module into the XBIB-U-SS development board. 2. Once the XBee module is plugged into the board (and not before), connect the board to your computer using the USB cable provided. 3. Connect the U.FL to RPSMA adapter cable to the XBee device and an antenna. Configure the device using XCTU XBee Configuration and Test Utility (XCTU) is a multi-platform program that enables users to interact with Digi radio frequency (RF) devices through a graphical interface. The application includes built-in tools that make it easy to set up, configure, and test Digi RF devices. For instructions on downloading and using XCTU, see the XCTU User Guide. Once you install XCTU, click the XCTU icon to open the program. Click Discover devices and follow the instructions. XCTU should discover the connected XBee/XBeePRO SX RF Modules using the provided settings. Click Add selected devices. The devices appear in the Radio Modules list. You can click a module to view and configure its individual settings. For more information on these items, see AT commands. Configure the devices for a range test For devices to communicate with each other, you must configure them so they are in the same network. To obtain all possible data from the remote device, you must also set the local device to API mode. For more information on API mode, see Operate in API mode. For devices to communicate with each other, you configure them so they are in the same network. You also set the local device to API mode to obtain all possible data of the remote device. When you connect the development board to a PC for the first time, the PC automatically installs drivers, which may take a few minutes to complete. 1. Add the two devices to XCTU. 2. Select the first module and click the Load default firmware settings button. 3. Configure the following parameters: ID: 2015 NI: LOCAL_DEVICE AP: API Mode Without Escapes [1] 4. Click the Write radio settings button. XBee®/XBee-PRO SX RF Module User Guide 28 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Perform a range test 5. Select the other module and click the Default firmware settings button. 6. Configure the following parameters: ID: 2015 NI: REMOTE_DEVICE AP: Transparent Mode [0] 7. Click the Write radio settings button. After you write the radio settings for each device, their names appear in the Radio Modules area. The Port indicates that the LOCAL_DEVICE is in API mode. 8. Disconnect REMOTE_DEVICE from your computer and remove it from XCTU; leave its power supply connected and plugged in. 9. Place REMOTE_DEVICE at the testing location and connect its power supply. 10. If you have not already done so, connect LOCAL_DEVICE to a battery. Its USB cable should still be connected to the laptop. Perform a range test A range test is a simple point to point wireless demonstration that tests the devices' ability to transmit to and receive from each other. Wireless environments vary dramatically depending on many factors and the range test allows you to experiment with the devices in your own environment. The range test instructions assume that you are using a laptop to configure the devices. You will need a battery to power the device connected to the laptop (the "local device") so that you can move around. Alternatively you can set the local device to PL: 21.5 dBm [0], and the device will run off of the USB port exclusively. However, the achievable range will significantly decrease if you use the lower power setting. WARNING! Keep the boards 2 m (6 ft) apart when transmitting to protect the device's front end. Follow these steps to perform the range test: 1. Open the Tools menu within XCTU and select the Range Test option. 2. Your local devices are listed on the left side of the Devices Selection section. Select the local device and click the Discover remote devices button . 3. When the discovery process finishes, the remote device is displayed in the Discovering remote devices... dialog. Click Add selected devices. 4. Select the remote device from the Discovered device list located on the right panel inside. 5. Click Start Range Test. 6. Range test data is represented in the chart. By default, 100 packets are sent for the test. XCTU displays the instant local and remote RSSI in two separate controls, as well as the number of packets sent and received. Remote devices only report their RSSI value when the local device is operating in API mode (by setting AP to 1). 7. Test the wireless link by moving your laptop and local device setup away from the remote device. Watch the range test status indicators: RSSI will decrease as you get farther away, and eventually you will see the percentage of successful packets drop below 100%, indicating you are approaching the limits of the range. XBee®/XBee-PRO SX RF Module User Guide 29 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Mesh network demonstration Watch the range test status indicators: RSSI will decrease the further away you are, and if you continue to move the setup further away, eventually you will see the percentage of successful packets drop below 100%, indicating you are approaching the limits of the range. 8. Click Stop Range Test to stop the process at any time. Mesh network demonstration 1. Connect the two XBee PRO SX development boards and the XBIB-U-SS (with the XBee SX installed) to your computer. Open XCTU and find the three XBee devices. 2. Configure all three devices with the following parameters and write the settings. Note that XBee A (SENDER) should be the XBee SX device running on the XBIB-U-SS development board. Parameter XBee A (XBee SX) XBee B XBee C (XBee PRO (XBee SX) PRO SX) NI SENDER RECEIVER BRIDGE Effect Defines the node identifier, a human-friendly name for the module. CAUTION! The default NI value is a blank space. Make sure to delete the space when you change the value. ID 2015 2015 2015 Defines the network that a device will attach to. This must be the same for all devices in your network. PL Lowest [0] Lowest [0] Lowest [0] Defines the transmitter output power level. Set it to the lowest level to facilitate the execution of the example. DH 0 0 0 Defines the destination address (high part) to transmit the data to. DL FFFF FFFF FFFF Defines the destination address (low part) to transmit the data to. You can use the 000000000000FFFF address to send a broadcast message. RP 5 5 5 Defines the time that the RSSI LED will be on when the device receives a packet. 5 (hexadecimal) = 5 (decimal) x 100 ms = 500 ms. To set up a DigiMesh network, you must first connect some XBee devices to a portable battery so you can move around with them. 1. Keep SENDER connected to the computer. 2. Disconnect RECEIVER from the computer and connect to a portable battery. 3. Disconnect BRIDGE from the computer and from power. XBee®/XBee-PRO SX RF Module User Guide 30 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Mesh network demonstration You can now start sending messages. Use the following steps to simulate a simple DigiMesh network by configuring SENDER and RECEIVER to communicate, moving the two devices out of range of each other, and adding the BRIDGE node to relay the messages between SENDER and RECEIVER. You will start by configuring SENDER to send a broadcast message every second. You can use the XCTU console or any serial port terminal application. This tutorial uses the XCTU console. 1. Switch to the Consoles working mode using the button in the top menu. 2. Open the serial connection of the device: select the SENDER device in the Radio Modules section, and click the Open serial connection button . The background changes to green to indicate that the connection is open. 3. Click the plus sign in the Send Frames panel to add a new packet. Type the message "Hello!". 4. To start sending this message every second, in the Send sequence box: a. Set 1000 ms as transmit interval. b. Select Loop infinitely. c. Click Start sequence. 5. Notice that the yellow Data Out LED of RECEIVER illuminates briefly every second. This means that the device is successfully receiving the messages. The white RSSI LEDs will also light up to indicate the strength of the signal received. 6. Move RECEIVER away from SENDER until the Data Out LED does not blink anymore, meaning it has moved out of range. 7. Place BRIDGE about halfway between SENDER and RECEIVER and plug it in. BRIDGE joins the network, creates a bridge between the other two nodes, and relays messages from SENDER to RECEIVER. XBee®/XBee-PRO SX RF Module User Guide 31 Getting started with the XBee/XBee-PRO SX RF Module Development Kit Software libraries Software libraries One way to communicate with the XBee/XBee-PRO SX RF Module is by using a software library. The libraries available for use with the XBee/XBee-PRO SX RF Module include: n XBee Java library n XBee Python library The XBee Java Library is a Java API. The package includes the XBee library, its source code and a collection of samples that help you develop Java applications to communicate with your XBee devices. The XBee Python Library is a Python API that dramatically reduces the time to market of XBee projects developed in Python and facilitates the development of these types of applications, making it an easy process. XBee Network Assistant The XBee Network Assistant is an application designed to inspect and manage RF networks created by Digi XBee devices. Features include: n Join and inspect any nearby XBee network to get detailed information about all the nodes it contains. n Update the configuration of all the nodes of the network, specific groups, or single devices based on configuration profiles. n Geo-locate your network devices or place them in custom maps and get information about the connections between them. n Export the network you are inspecting and import it later to continue working or work offline. n Use automatic application updates to keep you up to date with the latest version of the tool. XBee®/XBee-PRO SX RF Module User Guide 32 Getting started with the XBee/XBee-PRO SX RF Module Development Kit XBee Multi Programmer See the XBee Network Assistant User Guide for more information. To install the XBee Network Assistant: 1. Navigate to digi.com/xbeenetworkassistant. 2. Click General Diagnostics, Utilities and MIBs. 3. Click the XBee Network Assistant - Windows x86 link. 4. When the file finishes downloading, run the executable file and follow the steps in the XBee Network Assistant Setup Wizard. XBee Multi Programmer The XBee Multi Programmer is a combination of hardware and software that enables partners and distributors to program multiple Digi Radio frequency (RF) devices simultaneously. It provides a fast and easy way to prepare devices for distribution or large networks deployment. The XBee Multi Programmer board is an enclosed hardware component that allows you to program up to six RF modules thanks to its six external XBee sockets. The XBee Multi Programmer application communicates with the boards and allows you to set up and execute programming sessions. Some of the features include: n Each XBee Multi Programmer board allows you to program up to six devices simultaneously. Connect more boards to increase the programming concurrency. n Different board variants cover all the XBee form factors to program almost any Digi RF device. Download the XBee Multi Programmer application from: Digi XBee Multi Programmer See the XBee Multi Programmer User Guide for more information. XBee®/XBee-PRO SX RF Module User Guide 33 Modes Transparent and API operating modes Modes of operation XBee®/XBee-PRO SX RF Module User Guide 35 36 34 Modes Transparent and API operating modes Transparent and API operating modes The firmware operates in several different modes. Two top-level modes establish how the device communicates with other devices through its serial interface: Transparent operating mode and API operating mode. Transparent operating mode Devices operate in this mode by default. The device acts as a serial line replacement when it is in Transparent operating mode. The device queues all UART data it receives through the DIN pin for RF transmission. When a device receives RF data, it sends the data out through the DOUT pin. While operating in Transparent operating mode, the device uses the DH and DL parameters to determine the destination address used for RF transmissions. Transparent operating mode is not available when using the SPI interface. API operating mode API operating mode is an alternative to Transparent operating mode. API mode is a frame-based protocol that allows you to direct data on a packet basis. The device communicates UART or SPI data in packets, also known as API frames. This mode allows for structured communications with computers and microcontrollers. The advantages of API operating mode include: n It is easier to send information to multiple destinations n The host receives the source address for each received data frame n You can change parameters without entering Command mode n You can query or set a configuration parameter while a pending command—for example ND—is in progress. This cannot be done in Command mode. For more information, see API frame specifications. Comparing Transparent and API modes The XBee/XBee-PRO SX RF Module can use its serial connection in two ways: Transparent mode or API operating mode. You can use a mixture of devices running API mode and transparent mode in a network. The following table compares the advantages of transparent and API modes of operation: Feature Description Transparent mode features Simple interface All received serial data is transmitted unless the device is in Command mode Easy to support It is easier for an application to support Transparent operation and Command mode API mode features Easy to manage data transmissions to Transmitting RF data to multiple remote devices only requires the XBee®/XBee-PRO SX RF Module User Guide 35 Modes Modes of operation Feature Description multiple destinations application to change the address in the API frame. This process is much faster than in Transparent mode where the application must enter Command mode, change the address, exit Command mode, and then transmit data. Each API transmission can return a transmit status frame indicating the success or reason for failure Because acknowledgments are sent out of the serial interface, this provides more information about the health of the RF network and can be used to debug issues after the network has been deployed. Received data frames indicate the sender's address All received RF data API frames indicate the source address Advanced addressing support API transmit and receive frames can expose addressing fields including source and destination endpoints, cluster ID, and profile ID Advanced networking diagnostics API frames can provide indication of I/O samples from remote devices, and node identification messages. Some network diagnostic tools such as Trace Route, NACK, and Link Testing can only be performed in API mode. Remote Configuration Set/read configuration commands can be sent to remote devices to configure them as needed using the API Simultaneous Commands Query or set a configuration parameter while a pending command like ND is in progress. This cannot be done in Command mode. It is available in firmware versions 9009 or newer. Modes of operation Receive mode This is the default mode for the XBee/XBee-PRO SX RF Module. The device is in Receive mode when it is not transmitting data. If a destination node receives a valid RF packet, the destination node transfers the data to its serial transmit buffer. If a destination node receives a valid RF packet, the destination node transfers the data to its serial transmit buffer. For the serial interface to report received data on the RF network, that data must meet the following criteria: n Network ID match [ID (Network ID)] n Preamble ID match [HP (Preamble ID)] n Address match [SH (Serial Number High) and SL (Serial Number Low)] XBee®/XBee-PRO SX RF Module User Guide 36 Modes Modes of operation Transmit mode When DigiMesh data is transmitted from one node to another, the destination node transmits a network-level acknowledgment back across the established route to the source node. This acknowledgment packet indicates to the source node that the destination node received the data packet. If the source node does not receive a network acknowledgment, it retransmits the data. Sleep mode Sleep modes allow the device to enter states of low power consumption when not in use. The XBee/XBee-PRO SX RF Module supports both pin sleep (Sleep mode entered on pin transition) and cyclic sleep (device sleeps for a fixed time). Sleep modes allow the device to enter states of low power consumption when not in use. The device is almost completely off during sleep, and is incapable of sending or receiving data until it wakes up. XBee devices support pin sleep, where the device enters sleep mode upon pin transition, and cyclic sleep, where the device sleeps for a fixed time. For more information, see Sleep modes. Command mode Command mode is a state in which the firmware interprets incoming characters as commands. It allows you to modify the device’s configuration using parameters you can set using AT commands. When you want to read or set any parameter of the XBee/XBee-PRO SX RF Module using this mode, you have to send an AT command. Every AT command starts with the letters AT followed by the two characters that identify the command and then by some optional configuration values. The operating modes of the XBee/XBee-PRO SX RF Module are controlled by the AP (API Enable) setting, but Command mode is always available as a mode the device can enter while configured for any of the operating modes. Command mode is available on the UART interface for all operating modes. You cannot use the SPI interface to enter Command mode. XBee®/XBee-PRO SX RF Module User Guide 37 Modes Modes of operation Enter Command mode To get a device to switch into Command mode, you must issue the following sequence: +++ within one second. There must be at least one second preceding and following the +++ sequence. Both the command character (CC) and the silence before and after the sequence (GT) are configurable. When the entrance criteria are met the device responds with OK\r on UART signifying that it has entered Command mode successfully and is ready to start processing AT commands. If configured to operate in Transparent operating mode, when entering Command mode the XBee/XBee-PRO SX RF Module knows to stop sending data and start accepting commands locally. Note Do not press Return or Enter after typing +++ because it interrupts the guard time silence and prevents you from entering Command mode. When the device is in Command mode, it listens for user input and is able to receive AT commands on the UART. If CT time (default is 10 seconds) passes without any user input, the device drops out of Command mode and returns to the previous operating mode. You can force the device to leave Command mode by sending CN (Exit Command Mode). You can customize the command character, the guard times and the timeout in the device’s configuration settings. For more information, see CC (Command Sequence Character), CT (Command Mode Timeout) and GT (Guard Times). Troubleshooting Failure to enter Command mode is often due to baud rate mismatch. Ensure that the baud rate of the connection matches the baud rate of the device. By default, BD (Interface Data Rate) = 3 (9600 b/s). There are two alternative ways to enter Command mode: n A serial break for six seconds enters Command mode. You can issue the "break" command from a serial console, it is often a button or menu item. n Asserting DIN (serial break) upon power up or reset enters Command mode. XCTU guides you through a reset and automatically issues the break when needed. Both of these methods temporarily set the device's baud rate to 9600 and return an OK on the UART to indicate that Command mode is active. When Command mode exits, the device returns to normal operation at the baud rate that BD is set to. Send AT commands Once the device enters Command mode, use the syntax in the following figure to send AT commands. Every AT command starts with the letters AT, which stands for "attention." The AT is followed by two characters that indicate which command is being issued, then by some optional configuration values. To read a parameter value stored in the device’s register, omit the parameter field. The preceding example changes NI (Node Identifier) to My XBee. XBee®/XBee-PRO SX RF Module User Guide 38 Modes Modes of operation Multiple AT commands You can send multiple AT commands at a time when they are separated by a comma in Command mode; for example, ATNIMy XBee,AC. The preceding example changes the NI (Node Identifier) to My XBee and makes the setting active through AC (Apply Changes). Parameter format Refer to the list of AT commands for the format of individual AT command parameters. Valid formats for hexidecimal values include with or without a leading 0x for example FFFF or 0xFFFF. Response to AT commands When using AT commands to set parameters the XBee/XBee-PRO SX RF Module responds with OK if successful and ERROR if not. Apply command changes Any changes you make to the configuration command registers using AT commands do not take effect until you apply the changes. For example, if you send the BD command to change the baud rate, the actual baud rate does not change until you apply the changes. To apply changes: 1. Send AC (Apply Changes). 2. Send WR (Write). or: 3. Exit Command mode. Make command changes permanent Send a WR (Write) command to save the changes. WR writes parameter values to non-volatile memory so that parameter modifications persist through subsequent resets. Send as RE (Restore Defaults) to wipe settings saved using WR back to their factory defaults. Note You still have to use WR to save the changes enacted with RE. Exit Command mode 1. Send CN (Exit Command Mode) followed by a carriage return. or: 2. If the device does not receive any valid AT commands within the time specified by CT (Command Mode Timeout), it returns to Transparent or API mode. The default Command mode timeout is 10 seconds. For an example of programming the device using AT Commands and descriptions of each configurable parameter, see AT commands. XBee®/XBee-PRO SX RF Module User Guide 39 Sleep modes About sleep modes Normal mode Asynchronous pin sleep mode Asynchronous cyclic sleep mode Asynchronous cyclic sleep with pin wake up mode Synchronous sleep support mode Synchronous cyclic sleep mode The sleep timer Indirect messaging and polling Sleeping routers Sleep coordinator sleep modes in the DigiMesh network Synchronization messages Become a sleep coordinator Select sleep parameters Sleep immediate Synchronous pulse Start a sleeping synchronous network Add a new node to an existing network Change sleep parameters Rejoin nodes that lose sync Diagnostics XBee®/XBee-PRO SX RF Module User Guide 41 41 42 42 42 42 43 43 43 44 44 45 47 50 50 51 51 52 53 54 54 40 Sleep modes About sleep modes About sleep modes A number of low-power modes exist to enable devices to operate for extended periods of time on battery power. Use the SM command to enable these sleep modes. The sleep modes are characterized as either: n Asynchronous (SM = 1, 4, 5). n Synchronous (SM = 7, 8). In DigiMesh networks, a device functions in one of three roles: 1. A sleep coordinator. 2. A potential coordinator. 3. A non-coordinator. The difference between a potential coordinator and a non-coordinator is that a non-coordinator node has its SO parameter set so that it will not participate in coordinator election and cannot ever be a sleep coordinator. Asynchronous modes n Do not use asynchronous sleep modes in a synchronous sleeping network, and vice versa. n Use the asynchronous sleep modes to control the sleep state on a device by device basis. n Do not use devices operating in asynchronous sleep mode to route data. n We strongly encourage you to set asynchronous sleeping devices as end-devices using the CE command. This prevents the node from attempting to route data. n Transmissions sent to an asynchronously sleeping device are not buffered and will be lost if the receiving device is not actively awake when the transmission occurred. If you require two-way communication, you can use Indirect Messaging for P2MP unicast messages. For more information, see Indirect messaging and polling. Synchronous modes Synchronous sleep makes it possible for all nodes in the network to synchronize their sleep and wake times. All synchronized cyclic sleep nodes enter and exit a low power state at the same time. This forms a cyclic sleeping network. n A device acting as a sleep coordinator sends a special RF packet called a sync message to synchronize nodes. n To make a device in the network a coordinator, a node uses several resolution criteria. n The sleep coordinator sends one sync message at the beginning of each wake period. The coordinator sends the sync message as a broadcast and every node in the network repeats it. n You can change the sleep and wake times for the entire network by locally changing the settings on an individual device. The network uses the most recently set sleep settings. Normal mode Set SM to 0 to enter Normal mode. Normal mode is the default sleep mode. If a device is in this mode, it does not sleep and is always awake. XBee®/XBee-PRO SX RF Module User Guide 41 Sleep modes Asynchronous pin sleep mode Use mains-power for devices in Normal mode. A device in Normal mode synchronizes to a sleeping network, but does not observe synchronization data routing rules; it routes data at any time, regardless of the network's wake state. When synchronized, a device in Normal mode relays sync messages that sleep-compatible nodes generate, but does not generate sync messages itself. Once a device in Normal mode synchronizes with a sleeping network, you can put it into a sleepcompatible sleep mode at any time. Asynchronous pin sleep mode Set SM to 1 to enter asynchronous pin sleep mode. Pin sleep allows the device to sleep and wake according to the state of the SLEEP_RQ pin (pin 10). When you assert SLEEP_RQ (high), the device finishes any transmit or receive operations and enters a low-power state. When you de-assert SLEEP_RQ (low), the device wakes from pin sleep. Asynchronous cyclic sleep mode Set SM to 4 to enter asynchronous cyclic sleep mode. Cyclic sleep allows the device to sleep for a specific time and wake for a short time to poll. If the device receives serial or RF data while awake, it extends the time before it returns to sleep by the specific amount the ST command provides. Otherwise, it enters sleep mode immediately. The ON_SLEEP line (pin pin 26) is asserted (high) when the device wakes, and is de-asserted (low) when the device sleeps. If you use the D7 command to enable hardware flow control, the CTS pin asserts (low) when the device wakes and can receive serial data, and de-asserts (high) when the device sleeps. Asynchronous cyclic sleep with pin wake up mode Set SM to 5 to enter asynchronous cyclic sleep with pin wake up mode. This mode is a slight variation on asynchronous cyclic sleep mode (SM = 4) that allows you to wake a device prematurely by asserting the SLEEP_RQ pin (pin 10). In this mode, you can wake the device after the sleep period expires, or if a high-to-low transition occurs on the SLEEP_RQ pin. Synchronous sleep support mode Set SM to 7 to enter synchronous sleep support mode. A device in synchronous sleep support mode synchronizes itself with a sleeping network, but does not sleep itself. At any time, the node responds to new nodes that attempt to join the sleeping network with a sync message. A sleep support node only transmits normal data when the other nodes in the sleeping network are awake. Sleep support nodes are especially useful: n When you use them as preferred sleep coordinator nodes. n As aids in adding new nodes to a sleeping network. Note Because sleep support nodes do not sleep, they should be mains powered. XBee®/XBee-PRO SX RF Module User Guide 42 Sleep modes Synchronous cyclic sleep mode Synchronous cyclic sleep mode Set SM to 8 to enter synchronous cyclic sleep mode. A device in synchronous cyclic sleep mode sleeps for a programmed time, wakes in unison with other nodes, exchanges data and sync messages, and then returns to sleep. While asleep, it cannot receive RF messages or receive data (including commands) from the UART port. Generally, the network’s sleep coordinator specifies the sleep and wake times based on its SP and ST settings. The device only uses these parameters at startup until the device synchronizes with the network. When a device has synchronized with the network, you can query its sleep and wake times with the OS and OW commands respectively. If D9 = 1 (ON/SLEEP enabled) on a cyclic sleep node, the ON/SLEEP line asserts when the device is awake and de-asserts when the device is asleep. If D7 = 1, the device de-asserts CTS while asleep. A newly-powered, unsynchronized, sleeping device polls for a synchronized message and then sleeps for the period that the SP command specifies, repeating this cycle until it synchronizes by receiving a sync message. Once it receives a sync message, the device synchronizes itself with the network. Note Configure all nodes in a synchronous sleep network to operate in either synchronous sleep support mode or synchronous cyclic sleep mode. asynchronous sleeping nodes are not compatible with synchronous sleeping nodes. The sleep timer If the device receives serial or RF data in Asynchronous cyclic sleep mode and Asynchronous cyclic sleep with pin wake up modes (SM = 4 or SM = 5), it starts a sleep timer (time until sleep). n If the device receives any data serially or by RF link, the timer resets. n Use ST (Wake Time) to set the duration of the timer. n When the sleep timer expires the device returns to sleep. Indirect messaging and polling To enable reliable communication with sleeping devices, you can use the CE (Routing/Messaging Mode) command to enable indirect messaging and polling. Indirect messaging only affects Point-toMultipoint (P2MP) unicast transmissions. Indirect messaging Indirect messaging is a communication mode designed for communicating with asynchronous sleeping devices. A device can enable indirect messaging by making itself an indirect messaging coordinator with the CE command. An indirect messaging coordinator does not immediately transmit a P2MP unicast when it is received over the serial port. Instead the device holds onto the data until it is requested via a poll. On receiving a poll, the indirect messaging coordinator sends a queued data packet (if available) to the requestor. Because it is possible for a polling device to be eliminated, a mechanism is in place to purge unrequested data packets. If the coordinator holds an indirect data packet for an indirect messaging poller for more than 2.5 times its SP value, then the packet is purged. We suggest setting the SP of the coordinator to the same value as the highest SP time that exists among the pollers in the network. If XBee®/XBee-PRO SX RF Module User Guide 43 Sleep modes Sleeping routers the coordinator is in API mode, a TxStatus message is generated for a purged data packet with a status of 0x75 (INDIRECT_MESSAGE_UNREQUESTED). An indirect messaging coordinator queues up as many data packets as it has buffers available. After the coordinator uses all of its available buffers, it holds transmission requests unprocessed on the serial input queue. After the serial input queue is full, the device de-asserts CTS (if hardware flow control is enabled). After receiving a poll or purging data from the indirect messaging queue the buffers become available again. Indirect messaging only functions with P2MP unicast messages. Indirect messaging has no effect on P2MP broadcasts, directed broadcasts, repeater packets, or DigiMesh packets. These messages are sent immediately when received over the serial port and are not put on the indirect messaging queue. Polling Polling is the automatic process by which a node can request data from an indirect messaging coordinator. To enable polling on a device, configure it as an indirect messaging poller with the CE command and set its DH:DL registers to match the SH:SL registers of the device that will function as the Indirect Messaging Coordinator. When you enable polling, the device sends a P2MP poll request regularly to the address specified by the DH:DL registers. When the device sends a P2MP unicast to the destination specified by the DH:DL of a polling device, the data also functions as a poll. When a polling device is also an asynchronous sleeping device, that device sends a poll shortly after waking from sleep. After that first poll is sent, the device sends polls in the normal manner described previously until it returns to sleep. Sleeping routers The Sleeping Router feature of DigiMesh makes it possible for all nodes in the network to synchronize their sleep and wake times. All synchronized cyclic sleep nodes enter and exit a low power state at the same time. This forms a cyclic sleeping network. For more information, see Become a sleep coordinator. Sleep coordinator sleep modes in the DigiMesh network In a synchronized sleeping network, one node acts as the sleep coordinator. During normal operations, at the beginning of a wake cycle the sleep coordinator sends a sync message as a broadcast to all nodes in the network. This message contains synchronization information and the wake and sleep times for the current cycle. All cyclic sleep nodes that receive a sync message remain awake for the wake time and then sleep for the specified sleep period. The sleep coordinator sends one sync message at the beginning of each cycle with the current wake and sleep times. All router nodes that receive this sync message relay the message to the rest of the network. If the sleep coordinator does not hear a rebroadcast of the sync message by one of its immediate neighbors, then it re-sends the message one additional time. If you change the SP or ST parameters, the network does not apply the new settings until the beginning of the next wake time. For more information, see Change sleep parameters. A sleeping router network is robust enough that an individual node can go several cycles without receiving a sync message, due to RF interference, for example. As a node misses sync messages, the time available for transmitting messages during the wake time reduces to maintain synchronization accuracy. By default, a device reduces its active sleep time progressively as it misses sync messages. XBee®/XBee-PRO SX RF Module User Guide 44 Sleep modes Synchronization messages Synchronization messages A sleep coordinator regularly sends sync messages to keep the network in sync. Unsynchronized nodes also send messages requesting sync information. Sleep compatible nodes use Deployment mode when they first power up and the sync message has not been relayed. A sleep coordinator in Deployment mode rapidly sends sync messages until it receives a relay of one of those messages. Deployment mode: n Allows you to effectively deploy a network. n Allows a sleep coordinator that resets to rapidly re-synchronize with the rest of the network. If a node exits deployment mode and then receives a sync message from a sleep coordinator that is in Deployment mode, it rejects the sync message and sends a corrective sync to the sleep coordinator. Use the SO (sleep options) command to disable deployment mode. This option is enabled by default. A sleep coordinator that is not in deployment mode sends a sync message at the beginning of the wake cycle. The sleep coordinator listens for a neighboring node to relay the sync. If it does not hear the relay, the sleep coordinator sends the sync one additional time. A node that is not a sleep coordinator and has never been synchronized sends a message requesting sync information at the beginning of its wake cycle. Synchronized nodes which receive one of these messages respond with a synchronization packet. If you use the SO command to configure nodes as non-coordinators, and if the non-coordinators go six or more sleep cycles without hearing a sync, they send a message requesting sync at the beginning of their wake period. The following diagram illustrates the synchronization behavior of sleep compatible devices. XBee®/XBee-PRO SX RF Module User Guide 45 Sleep modes XBee®/XBee-PRO SX RF Module User Guide Synchronization messages 46 Sleep modes Become a sleep coordinator Become a sleep coordinator In DigiMesh networks, a device can become a sleep coordinator in one of four ways: n Define a preferred sleep coordinator n A potential sleep coordinator misses three or more sync messages n Press the Commissioning Pushbutton twice on a potential sleep coordinator n Change the sleep timing values on a potential sleep coordinator Preferred sleep coordinator option You can specify that a node always act as a sleep coordinator. To do this, set the preferred sleep coordinator bit (bit 0) in the SO command to 1. A node with the sleep coordinator bit set always sends a sync message at the beginning of a wake cycle. To avoid network congestion and synchronization conflicts, do not set this bit on more than one node in the network. A node that is centrally located in the network can serve as a good sleep coordinator, because it minimizes the number of hops a sync message takes to get across the network. A sleep support node and/or a node that is mains powered is a good candidate to be a sleep coordinator. CAUTION! Use the preferred sleep coordinator bit with caution. The advantages of using the option become weaknesses if you use it on a node that is not in the proper position or configuration. Also, it is not valid to have the sleep coordinator option bit set on more than one node at a time. You can also use the preferred sleep coordinator option when you set up a network for the first time. When you start a network, you can configure a node as a sleep coordinator so it will begin sending sleep messages. After you set up the network, it is best to disable the preferred sleep coordinator bit. Resolution criteria and selection option There is an optional selection process with resolution criteria that occurs on a node if it loses contact with the network sleep coordinator. By default, this process is disabled. Use the SO command to enable this process. This process occurs automatically if a node loses contact with the previous sleep coordinator. If you enable the process on any sleep compatible node, it is eligible to become the sleep coordinator for the network. A sleep compatible node may become a sleep coordinator if it: n Misses three or more sync messages. n It is not configured as a non-coordinator by setting bit 1 of SO. If such a node wins out in the selection process, it becomes the new network sleep coordinator. It is possible for multiple nodes to declare themselves as the sleep coordinator. If this occurs, the firmware uses the following resolution criteria to identify the sleep coordinator from among the nodes using the selection process: XBee®/XBee-PRO SX RF Module User Guide 47 Sleep modes Become a sleep coordinator 1. Newer sleep parameters always take priority over older sleep parameters. The age of the sleep parameters is determined by a sequence number that increments when an overriding sync is sent. 2. Otherwise, the node with the preferred sleep coordinator bit set takes precedence. 3. Otherwise, a sleep support node—SM 7—takes priority over a node that is not a sleep support node—SM 8. 4. Otherwise, the node with highest serial number becomes the sleep coordinator. Commissioning Pushbutton option Use the Commissioning Pushbutton to select a device to act as the sleep coordinator. The Commissioning Pushbutton is mapped to DIO0 (pin 33) and enabled by default. If you enable the Commissioning Pushbutton functionality, you can immediately select a device as a sleep coordinator by pressing the Commissioning Pushbutton twice or by issuing the CB2 command. The device you select in this manner is still subject to the resolution criteria process. Only potential sleep coordinator nodes honor Commissioning Pushbutton nomination requests. A node configured as a non-sleep coordinator ignores commissioning button nomination requests. Overriding syncs Any sleep compatible node in the network that does not have the non-coordinator sleep option set can send an overriding sync and become the network sleep coordinator. An overriding sync effectively changes the synchronization of all nodes in the network to the ST and SP values of the node sending the overriding sync. It also selects the node sending the overriding sync as the network sleep coordinator. While this is a powerful operation, it may be an undesired side effect because the current sleep coordinator may have been carefully selected and it is not desired to change it. Additionally the current wake and sleep cycles may be desired rather than the parameters on the node sending the overriding sync. For this reason, it is important to know what kicks off an overriding sync. An overriding sync occurs whenever ST or SP is changed to a value different than OW or OS respectively. For example no overriding sync will occur if SP is changed from 190 to C8 if the network was already operating with OS at C8. On the other hand, if SP is changed from 190 to 190—meaning no change—and OS is C8, than an overriding sync will occur because the network parameters are being changed. Even parameters that seem unrelated to sleep can kick off an overriding sync. These are NH, NN, RN, and MT. When any of these parameters are changed, they can affect network traversal time. If such changes cause the configured value of ST to be smaller than the value needed for network traversal, then ST is increased and if that increased value is different than OW, then an overriding sync will occur. For most applications, we recommend configuring the NH, NN, RN, and MT network parameters during initial deployment only. The default values of NH and NN are optimized to work for most deployments. Additionally, it would be best to set ST and SP the same on all nodes in the network while keeping ST sufficiently large so that it will not be affected by an inadvertent change of NH, NN, RN, or MT. Sleep guard times To compensate for variations in the timekeeping hardware of the various devices in a sleeping router network, the network allocates sleep guard times at the beginning and end of the wake period. The size of the sleep guard time varies based on the sleep and wake times you select and the number of sleep cycles that elapse since receiving the last sync message. The sleep guard time guarantees that a destination module will be awake when the source device sends a transmission. As a node misses XBee®/XBee-PRO SX RF Module User Guide 48 Sleep modes Become a sleep coordinator more and more consecutive sync messages, the sleep guard time increases in duration and decreases the available transmission time. XBee®/XBee-PRO SX RF Module User Guide 49 Sleep modes Select sleep parameters Auto-early wake-up sleep option If you have nodes that are missing sync messages and could be going out of sync with the rest of the network, enabling an early wake gives the device a better chance to hear the sync messages that are being broadcast. Similar to the sleep guard time, the auto early wake-up option decreases the sleep period based on the number of sync messages a node misses. This option comes at the expense of battery life. Use the SO command to disable auto-early wake-up sleep. This option is enabled by default. Select sleep parameters Choosing proper sleep parameters is vital to creating a robust sleep-enabled network with a desirable battery life. To select sleep parameters that will be good for most applications, follow these steps: 1. Choose NN and NH. Based on the placement of the nodes in your network, select the appropriate values for the NH (Network Hops) and NN (Network Delay Slots) parameters. We optimize the default values of NH and NN to work for the majority of deployments. In most cases, we suggest that you do not modify these parameters from their default values. Decreasing these parameters for small networks can improve battery life, but take care to not make the values too small. 2. Calculate the Sync Message Propagation Time (SMPT). This is the maximum amount of time it takes for a sleep synchronization message to propagate to every node in the network. You can estimate this number with the following formula: SMPT = NN*NH*(MT+1)*18 ms. 3. Select the duty cycle you want. 4. Choose the sleep period and wake time. The wake time must be long enough to transmit the desired data as well as the sync message. The ST parameter automatically adjusts upwards to its minimum value when you change other AT commands that affect it (SP, NN, and NH). Use a value larger than this minimum. If a device misses successive sync messages, it reduces its available transmit time to compensate for possible clock drift. Budget a large enough ST time to allow for the device to miss a few sync messages and still have time for normal data transmissions. Sleep immediate In order to ensure that the needed messages have time to traverse the network, ST must be sufficiently large. Additionally, your application is a factor in determining what ST should be. When ST/SP increases, the batteries burn out faster. Yet, ST must be large enough for a functional network. To mitigate this problem, the Sleep Immediate command is available (in version 0x9009 and newer). The Sleep Immediate (SI) command can be sent by your application after it determines that all needed transmissions are completed. This not only puts the node that issues the command asleep, but it also sends a broadcast to put the whole network to sleep. The network will then remain asleep for the remainder of the wake time and the subsequent sleep time. Then the entire network will awaken again, resuming the same sleep cycle as before. XBee®/XBee-PRO SX RF Module User Guide 50 Sleep modes Synchronous pulse In the event that one or more nodes fail to receive the sleep immediate broadcast, they will not get the power savings, but they will still remain synchronized to the network because the sleep cycle would not have changed. Synchronous pulse The Synchronous pulse feature supports user applications that desire synchronizing operations across multiple devices in a network. This is done by pulsing the DIO9—ON_SLEEP—pin simultaneously on all devices in the network. Typically, this feature is used with a mains-powered application and transmissions are not inhibited except during the small window of time allocated for sending synchronization messages throughout the network. Configuration Generally, synchronous pulse is configured the same way as synchronous sleep. See the table below: AT Command Value Description D9 6 This causes a synchronous pulse line to be toggled low and then high on the DIO9 pin throughout the network. Note that D9 must be set to 1 for the ON_SLEEP indicator. This means that it is not possible to have both a synchronous pulse and an ON_SLEEP indicator. However, if a synchronously sleeping network is desired, D9 may still be used as a synchronous pulse with the obvious limitation that the network will not be able to transmit while it is asleep. SM 7 or 8 Setting SM to 7 or 8 allows the synchronization messages to be sent. They will not be sent and this feature will be disabled if SM is set to any other value. SP 0 Even with SM set to 8, the network still stays awake by setting SP to 0 on the sleep coordinator. ST ?? Set ST to the frequency desired for the synchronous pulse. If it is set too small, it is rounded up to a value that allows a synchronous pulse to be output every time DIO9 pulses. Some parameters—such as NH—can be made smaller in order to reduce the minimum value for ST. If it still is not possible to get synchronous pulses at small enough intervals to satisfy the application, then the microcontroller connected to DIO9 will be responsible for subdividing the time between each synchronous pulse. Accuracy Due to variations is traffic patterns and hopping patterns, perfect accuracy cannot be guaranteed. However, this feature is usually accurate within + or - 100 micro-seconds. If greater accuracy than that is required, this solution will not work for your application. Start a sleeping synchronous network By default, all new nodes operate in normal (non-sleep) mode. To start a synchronous sleeping network, follow these steps: XBee®/XBee-PRO SX RF Module User Guide 51 Sleep modes Add a new node to an existing network 1. Set SO to 1 to enable the preferred sleep coordinator option on one of the nodes. 2. Set its SM to a synchronous sleep compatible mode (7 or 8) with its SP and ST set to a quick cycle time. The purpose of a quick cycle time is to allow the network to send commands quickly through the network during commissioning. 3. Power on the new nodes within range of the sleep coordinator. The nodes quickly receive a sync message and synchronize themselves to the short cycle SP and ST set on the sleep coordinator. 4. Configure the new nodes to the sleep mode you want, either cyclic sleeping modes or sleep support modes. 5. Set the SP and ST values on the sleep coordinator to the values you want for the network. 6. In order to reduce the possibility of an unintended overriding sync, set SP and ST to the intended sleep/wake cycle on all nodes in the network. Be sure that ST is large enough to prevent it from being inadvertently increased by changing NN, NH, or MT. 7. Wait a sleep cycle for the sleeping nodes to sync themselves to the new SP and ST values. 8. Disable the preferred sleep coordinator option bit on the sleep coordinator unless you want a preferred sleep coordinator. 9. Deploy the nodes to their positions. Alternatively, prior to deploying the network you can use the WR command to set up nodes with their sleep settings pre-configured and written to flash. If this is the case, you can use the Commissioning Pushbutton and associate LED to aid in deployment: 1. If you are going to use a preferred sleep coordinator in the network, deploy it first. 2. If there will not be a preferred sleep coordinator, select a node for deployment, power it on and press the Commissioning Pushbutton twice. This causes the node to begin emitting sync messages. 3. Verify that the first node is emitting sync messages by watching its associate LED. A slow blink indicates that the node is acting as a sleep coordinator. 4. Power on nodes in range of the sleep coordinator or other nodes that have synchronized with the network. If the synchronized node is asleep, you can wake it by pressing the Commissioning Pushbutton once. 5. Wait a sleep cycle for the new node to sync itself. 6. Verify that the node syncs with the network. The associate LED blinks when the device is awake and synchronized. 7. Continue this process until you deploy all of the nodes. Add a new node to an existing network To add a new node to the network, the node must receive a sync message from a node already in the network. On power-up, an unsynchronized, sleep compatible node periodically sends a broadcast requesting a sync message and then sleeps for its SP period. Any node in the network that receives this message responds with a sync. Because the network can be asleep for extended periods of time, and cannot respond to requests for sync messages, there are methods you can use to sync a new node while the network is asleep. 1. Power the new node on within range of a sleep support node. Sleep support nodes are always awake and able to respond to sync requests promptly. XBee®/XBee-PRO SX RF Module User Guide 52 Sleep modes Change sleep parameters 2. You can wake a sleeping cyclic sleep node in the network using the Commissioning Pushbutton. Place the new node in range of the existing cyclic sleep node. Wake the existing node by holding down the Commissioning Pushbutton for two seconds, or until the node wakes. The existing node stays awake for 30 seconds and responds to sync requests while it is awake. If you do not use one of these two methods, you must wait for the network to wake up before adding the new node. Place the new node in range of the network with a sleep/wake cycle that is shorter than the wake period of the network. The new node periodically sends sync requests until the network wakes up and it receives a sync message. Change sleep parameters To change the sleep and wake cycle of the network, select any sleep coordinator capable node in the network and change the SP and/or ST of the node to values different than those the network currently uses. n If you use a preferred sleep coordinator or if you know which node acts as the sleep coordinator, we suggest that you use this node to make changes to network settings. n If you do not know the network sleep coordinator, you can use any node that does not have the non-sleep coordinator sleep option bit set. For details on the bit, see SO (Sleep Options). When you make changes to a node’s sleep parameters, that node becomes the network’s sleep coordinator unless it has the non-sleep coordinator option selected. It sends a sync message with the new sleep settings to the entire network at the beginning of the next wake cycle. The network immediately begins using the new sleep parameters after it sends this sync. Changing sleep parameters increases the chances that nodes will lose sync. If a node does not receive the sync message with the new sleep settings, it continues to operate on its old settings. To minimize the risk of a node losing sync and to facilitate the re-syncing of a node that does lose sync, take the following precautions: 1. Whenever possible, avoid changing sleep parameters. 2. Enable the missed sync early wake up sleep option in the SO command. This option is enabled by default. This command tells a node to wake up progressively earlier based on the number of cycles it goes without receiving a sync. This increases the probability that the un-synced node will be awake when the network wakes up and sends the sync message. Note Using this sleep option increases reliability but may decrease battery life. Nodes using this sleep option that miss sync messages increase their wake time and decrease their sleep time during cycles where they miss the sync message. This increases power consumption. When you are changing between two sets of sleep settings, choose settings so that the wake periods of the two sleep settings occur at the same time. In other words, try to satisfy the following equation: (SP1 + ST1) = N * (SP2 + ST2) where SP1/ST1 and SP2/ST2 are the desired sleep settings and N is an integer. XBee®/XBee-PRO SX RF Module User Guide 53 Sleep modes Rejoin nodes that lose sync Rejoin nodes that lose sync DigiMesh networks get their robustness from routing redundancies which may be available. We recommend architecting the network with redundant mesh nodes to increase robustness. If a scenario exists where the only route connecting a subnet to the rest of the network depends on a single node, and that node fails or the wireless link fails due to changing environmental conditions (a catastrophic failure condition), then multiple subnets may arise using the same wake and sleep intervals. When this occurs the first task is to repair, replace, and strengthen the weak link with new and/or redundant devices to fix the problem and prevent it from occurring in the future. When you use the default DigiMesh sleep parameters, separated subnets do not drift out of phase with each other. Subnets can drift out of phase with each other if you configure the network in one of the following ways: n If you disable the non-sleep coordinator bit in the SO command on multiple devices in the network, they are eligible for the network to nominate them as a sleep coordinator. For more details, see SO (Sleep Options). n If the devices in the network do not use the auto early wake-up sleep option. If a network has multiple subnets that drift out of phase with each other, get the subnets back in phase with the following steps: 1. Place a sleep support node in range of both subnets. 2. Select a node in the subnet that you want the other subnet to sync with. 3. Use this node to slightly change the sleep cycle settings of the network, for example, increment ST. 4. Wait for the subnet’s next wake cycle. During this cycle, the node you select to change the sleep cycle parameters sends the new settings to the entire subnet it is in range of, including the sleep support node that is in range of the other subnet. 5. Wait for the out of sync subnet to wake up and send a sync. When the sleep support node receives this sync, it rejects it and sends a sync to the subnet with the new sleep settings. 6. The subnets will now be in sync. You can remove the sleep support node. 7. You can also change the sleep cycle settings back to the previous settings. If you only need to replace a few nodes, you can use this method: 1. Reset the out of sync node and set its sleep mode to Synchronous Cyclic Sleep mode (SM = 8). 2. Set up a short sleep cycle. 3. Place the node in range of a sleep support node or wake a sleeping node with the Commissioning Pushbutton. 4. The out of sync node receives a sync from the node that is synchronized to the network. It then syncs to the network sleep settings. Diagnostics The following diagnostics are useful in applications that manage a sleeping router network: Query sleep cycle Use the OS and OW commands to query the current operational sleep and wake times that a device uses. XBee®/XBee-PRO SX RF Module User Guide 54 Sleep modes Diagnostics Sleep status Use the SS command to query useful information regarding the sleep status of the device. Use this command to query if the node is currently acting as a network sleep coordinator. Missed sync messages command Use the MS command to query the number of cycles that elapsed since the device received a sync message. Sleep status API messages When you use the SO command to enable this option, a device that is in API operating mode outputs modem status frames immediately after it wakes up and prior to going to sleep. XBee®/XBee-PRO SX RF Module User Guide 55 Networking methods The MAC and PHY layers 64-bit addresses Make a unicast transmission Make a broadcast transmission Delivery methods XBee®/XBee-PRO SX RF Module User Guide 57 57 58 58 58 56 Networking methods The MAC and PHY layers The MAC and PHY layers Most network protocols use the concept of layers to separate different components and functions into independent modules that developers can assemble in different ways. The PHY layer defines the physical and electrical characteristics of the network. It is responsible for managing the hardware that modulates and demodulates the RF bits. The MAC layer is responsible for sending and receiving RF frames. As part of each packet, there is a MAC layer data header that has addressing information as well as packet options. This layer implements packet acknowledgments (ACKs), packet tracking to eliminate duplicates, and so forth. n When a device is transmitting, it cannot receive packets. n When a device is not sleeping, it is either receiving or transmitting. n There are no beacons or master/slave requirements in the design of the MAC/PHY. The XBee/XBee-PRO SX RF Module uses a patented method for scanning and finding a transmission. When a device transmits, it sends out a repeated preamble pattern, a MAC header, optionally a network header, followed by packet data. A receiving device is able to scan all the channels to find a transmission during the preamble, then once it has locked into that channel it attempts to receive the whole packet. The following table shows the AT commands related to the MAC/PHY layers. AT command Function CM The Channel Mask is a user-defined list of channels that the device operates on. For additional information, see CM (Channel Mask). HP Change HP (Preamble ID) to make it so a group of devices will not interfere with another group of devices in the same vicinity. The advantage of changing this parameter is that a receiving device will not lock into a transmission of a transmitting device that does not have the same Preamble ID. ID Change ID (Network ID) to further keep devices from interfering with each other. The device matches this ID after it matches the preamble pattern and after it receives the MAC header. A unique network identifier distinguishes each network. For devices to communicate, they must be configured with the same network identifier. The ID parameter allows multiple networks to co-exist on the same physical channel. PL Sets the transmit (TX) power level. You can reduce the power level from the maximum to reduce current consumption or for testing. This comes at the expense of reduced radio range. RR Specifies the number of times a sending device attempts to get an ACK from a destination device when it sends a unicast packet. MT Specifies the number of times that a device repeatedly transmits a broadcast packet. This adds redundancy, which improves reliability. 64-bit addresses We assign each device a unique IEEE 64-bit address at the factory. When a device is in API operating mode and it sends a packet, this is the source address that the receiving device returns. XBee®/XBee-PRO SX RF Module User Guide 57 Networking methods Make a unicast transmission n Use the SH and SL commands to read this address. n The form of the address is: 0x0013A2XXXXXXXXXX. n The first six digits are the Digi Organizationally Unique Identifier (OUI). n The broadcast address is 0x000000000000FFFF. Make a unicast transmission To transmit to a specific device in Transparent operating mode: n Set DH:DL to the SH:SL of the destination device. To transmit to a specific device in API operating mode: n In the 64-bit destination address of the API frame, enter the SH:SL address of the destination device. Make a broadcast transmission To transmit to all devices in Transparent operating mode: n Set DH:DL to 0x000000000000FFFF. To transmit to all devices in API operating mode: n Set the 64-bit destination address to 0x000000000000FFFF. The scope of the broadcast changes based on the delivery method you choose. Delivery methods The TO (Transmit Options) command sets the default delivery method that the device uses when in Transparent mode. In API mode, the TxOptions field of the API frame overrides the TO command, if non-zero. The XBee/XBee-PRO SX RF Module supports three delivery methods: n Point-to-multipoint (TO = 0x40). n Repeater (directed broadcast) (TO = 0x80). n DigiMesh (TO = 0xC0). Point to Point / Point to Multipoint (P2MP) This delivery method does not use a network header, only the MAC header. In P2MP, the sending devices always send all messages directly to the destination. Other nodes do not repeat the packet. The sending device only delivers a P2MP unicast directly to the destination device, which must be in range of the sending device. In P2MP mode, the originator sends a unicast packet directly to the destination device—which must be in range. All other devices in range ignore the unicast. In P2MP mode the originator sends a broadcast MT+1 times, but the receiving nodes do not rebroadcast the packet. So, like the unicast transmission, the receiving device must be in range. All devices that receive a P2MP broadcast transmission output the data through the serial port. XBee®/XBee-PRO SX RF Module User Guide 58 Networking methods Delivery methods Repeater/directed broadcast This mode of operation allows messages to traverse a network and arrive at the destination node without requiring the overhead of route discovery. This is done in the network layer which does one of two things when it receives a message: 1. If this node is the destination node, then the message is output on the serial port. 2. If this node is not the destination node, then the message is rebroadcast. Since the message is a broadcast at the lowest layer, all nodes will receive the broadcasted or rebroadcasted message, but only the node whose address is the final destination will send the message to the serial port. The nodes that are not the final destination follow all the rules that otherwise apply to broadcasts: 1. Hops are limited by NH and BH. 2. Non-routing nodes—with CE = 2—will not repeat directed broadcasts. 3. Broadcasts are sent MT+1 times. DigiMesh networking A mesh network is a topology in which each node in the network is connected to other nodes around it. Each node cooperates in transmitting information. Mesh networking provides these important benefits: n Routing. With this technique, the message is propagated along a path by hopping from node to node until it reaches its final destination. n Ad-hoc network creation. This is an automated process that creates an entire network of nodes on the fly, without any human intervention. n Self-healing. This process automatically figures out if one or more nodes on the network is missing and reconfigures the network to repair any broken routes. n Peer-to-peer architecture. No hierarchy and no parent-child relationships are needed. n Quiet protocol. Routing overhead will be reduced by using a reactive protocol similar to AODV. n Route discovery. Rather than maintaining a network map, routes will be discovered and created only when needed. n Selective acknowledgments. Only the destination node will reply to route requests. n Reliable delivery. Reliable delivery of data is accomplished by means of acknowledgments. n Sleep modes. Low power sleep modes with synchronized wake are supported with variable sleep and wake times. XBee®/XBee-PRO SX RF Module User Guide 59 Networking methods Delivery methods With mesh networking, the distance between two nodes does not matter as long as there are enough nodes in between to pass the message along. When one node wants to communicate with another, the network automatically calculates the best path. A mesh network is also reliable and offers redundancy. For example, If a node can no longer operate because it has been removed from the network or because a barrier blocks its ability to communicate, the rest of the nodes can still communicate with each other, either directly or through intermediate nodes. Note Mesh networks use more bandwidth for administration and therefore have less available for payloads. Unicast addressing When devices transmit using DigiMesh unicast, the network uses retries and acknowledgments (ACKs) for reliable data delivery. In a retry and acknowledgment scheme, for every data packet that a device sends, the receiving device must send an acknowledgment back to the transmitting device to let the sender know that the data packet arrived at the receiver. If the transmitting device does not receive an acknowledgment then it re-sends the packet. It sends the packet a finite number of times before the system times out. The MR (Mesh Network Retries) parameter determines the number of mesh network retries. The sender device transmits RF data packets up to MR + 1 times across the network route, and the receiver transmits ACKs when it receives the packet. If the sender does not receive a network ACK within the time it takes for a packet to traverse the network twice, the sender retransmits the packet. To send unicast messages while in Transparent operating mode, set the DH and DL on the transmitting device to match the corresponding SH and SL parameter values on the receiving device. Routing A device within a mesh network determines reliable routes using a routing algorithm and table. The routing algorithm uses a reactive method derived from Ad-hoc On-demand Distance Vector (AODV). The firmware uses an associative routing table to map a destination node address with its next hop. A device sends a message to the next hop address, and the message either reaches its destination or forwards to an intermediate router that routes the message on to its destination. If a message has a broadcast address, it is broadcast to all neighbors, then all routers that receive the message rebroadcast the message MT+1 times. Eventually, the message reaches the entire network. XBee®/XBee-PRO SX RF Module User Guide 60 Networking methods Delivery methods Packet tracking prevents a node from resending a broadcast message more than MT+1 times. This means that a node that relays a broadcast will only relay it after it receives it the first time and it will discard repeated instances of the same packet. Route discovery Route discovery is a process that occurs when: 1. The source node does not have a route to the requested destination. 2. A route fails. This happens when the source node uses up its network retries without receiving an ACK. Route discovery begins by the source node broadcasting a route request (RREQ). We call any router that receives the RREQ and is not the ultimate destination, an intermediate node. Intermediate nodes may either drop or forward a RREQ, depending on whether the new RREQ has a better route back to the source node. If so, the node saves, updates and broadcasts the RREQ. When the ultimate destination receives the RREQ, it unicasts a route reply (RREP) back to the source node along the path of the RREQ. It does this regardless of route quality and regardless of how many times it has seen an RREQ before. This allows the source node to receive multiple route replies. The source node selects the route with the best round trip route quality, which it uses for the queued packet and for subsequent packets with the same destination address. Transmission timeouts When a device in API operating mode receives a Transmit Request (0x10, 0x11) frame, or a device in Transparent operating mode meets the packetization requirements (RO, RB), the time required to route the data to its destination depends on: n A number of configured parameters. n Whether the transmission is a unicast or a broadcast. n If the route to the destination address is known. Timeouts or timing information is provided for the following transmission types: n Broadcast transmission n Unicast transmission on a known route n Unicast transmission on an unknown route n Unicast transmission on a broken route Note The timeouts in this documentation are theoretical timeouts and are not precisely accurate. Your application should pad the calculated maximum timeouts by a few hundred milliseconds. When you use API operating mode, use Extended Transmit Status - 0x8B as the primary method to determine if a transmission is complete. Unicast one hop time unicastOneHopTime is a building block of many of the following calculations. It represents the amount of time it takes to send a unicast transmission between two adjacent nodes. The amount of time depends on the %H parameter. Transmit a broadcast All of the routers in a network must relay a broadcast transmission. XBee®/XBee-PRO SX RF Module User Guide 61 Networking methods Delivery methods The maximum delay occurs when the sender and receiver are on the opposite ends of the network. The NH and %H parameters define the maximum broadcast delay as follows: BroadcastTxTime = NH * NN * %8 Unless BH < NH, in which case the formula is: BroadcastTxTime = BH * NN * %8 Transmit a unicast with a known route When a device knows a route to a destination node, the transmission time is largely a function of the number of hops and retries. The timeout associated with a unicast assumes that the maximum number of hops is necessary, as specified by the NH command. You can estimate the timeout in the following manner: knownRouteUnicastTime=2*NH*MR*unicastOneHopTime Transmit a unicast with an unknown route If the transmitting device does not know the route to the destination, it begins by sending a route discovery. If the route discovery is successful, then the transmitting device transmits data. You can estimate the timeout associated with the entire operation as follows: unknownRouteUnicastTime=BroadcastTxTime+ (NH*unicastOneHopTime)+knownRouteUnicastTime Transmit a unicast with a broken route If the route to a destination node changes after route discovery completes, a node begins by attempting to send the data along the previous route. After it fails, it initiates route discovery and, when the route discovery finishes, transmits the data along the new route. You can estimate the timeout associated with the entire operation as follows: brokenRouteUnicastTime=BroadcastTxTime+(NH*unicastOneHopTime)+ (2*knownRouteUnicastTime) XBee®/XBee-PRO SX RF Module User Guide 62 Serial communication UART data flow SPI signals Slave mode characteristics Full duplex operation Low power operation Configuration considerations SPI and API mode SPI parameters Serial port selection UART flow control XBee®/XBee-PRO SX RF Module User Guide 64 64 65 66 66 67 67 67 67 68 63 Serial communication UART data flow UART data flow Devices that have a UART interface connect directly to the pins of the XBee/XBee-PRO SX RF Module as shown in the following figure. The figure shows system data flow in a UART-interfaced environment. Low-asserted signals have a horizontal line over the signal name. Serial data A device sends data to the XBee/XBee-PRO SX RF Module's UART through pin 4 DIN as an asynchronous serial signal. When the device is not transmitting data, the signals should idle high. For serial communication to occur, you must configure the UART of both devices (the microcontroller and the XBee/XBee-PRO SX RF Module) with compatible settings for the baud rate, parity, start bits, stop bits, and data bits. Each data byte consists of a start bit (low), 8 data bits (least significant bit first) and a stop bit (high). The following diagram illustrates the serial bit pattern of data passing through the device. The diagram shows UART data packet 0x1F (decimal number 31) as transmitted through the device. SPI signals The XBee/XBee-PRO SX RF Module supports SPI communications in slave mode. Slave mode receives the clock signal and data from the master and returns data to the master. The SPI port uses the following signals on the device: Signal Pin number Applicable AT command SPI_ATTN (Attention) 12 P9 SPI_SCLK (Serial clock) 14 P8 XBee®/XBee-PRO SX RF Module User Guide 64 Serial communication Slave mode characteristics Signal Pin number Applicable AT command SPI_SSEL (Slave select) 15 P7 SPI_MOSI (Master out, Slave in) 16 P6 SPI_MISO (Master in, Slave out) 17 P5 By default, the inputs have pull-up resistors enabled. Use the PR command to disable the pull-up resistors. When the SPI pins are not connected but the pins are configured for SPI operation, then the device requires the pull-ups for proper UART operation. Signal description SPI_MISO: When SPI_SSEL is asserted (low) and SPI_CLK is active, the device outputs the data on this line at the SPI_CLK rate. When SPI_SSEL is de-asserted (high), you should tri-state this output such that another slave device can drive the line. SPI_MOSI: The SPI master outputs data on this line at the SPI_CLK rate after it selects the desired slave. When you configure the device for SPI operations, this pin is an input. SPI_SCLK: The SPI master outputs a clock on this pin, and the rate must not exceed the maximum allowed, 6 Mb/s. When you configure the device for SPI operations, this pin is an input. This signal enables serial communication with the slave. SPI_SSEL: The SPI master outputs a low signal on this line to select the desired slave. When you configure the device for SPI operations, this pin is an input. This signal clocks data transfers on MOSI and MISO. SPI_ATTN: The device asserts this pin low when it has data to send to the SPI master. When you configure this pin for SPI operations, it is an output (not tri-stated). This signal alerts the master that the slave has data queued to send. The device asserts this pin as soon as data is available to send to the SPI master and it remains asserted until the SPI master has clocked out all available data. Slave mode characteristics In slave mode, the following apply: n SPI Clock rates up to 6 MHz (6 Mb/s) are possible. n Data is MSB first. n It uses Frame Format Mode 0. This means CPOL= 0 (idle clock is low) and CPHA = 0 (data is sampled on the clock’s leading edge). The picture below diagrams Mode 0. n The SPI port is setup for API mode and is equivalent to AP = 1. The following picture shows the frame format for SPI communications. XBee®/XBee-PRO SX RF Module User Guide 65 Serial communication Full duplex operation Full duplex operation When using SPI on the XBee/XBee-PRO SX RF Module the device uses API operation (AP = 1) without escaped characters to packetize data. SPI is a full duplex protocol, even when data is only available in one direction. This means that whenever a device receives data, it also transmits, and that data is normally invalid. Likewise, whenever a device transmits data, invalid data is probably received. To determine whether or not received data is invalid, the firmware places the data in API packets. SPI allows for valid data from the slave to begin before, at the same time, or after valid data begins from the master. When the master sends data to the slave and the slave has valid data to send in the middle of receiving data from the master, a full duplex operation occurs, where data is valid in both directions for a period of time. Not only must the master and the slave both be able to keep up with the full duplex operation, but both sides must honor the protocol. The following figure illustrates the SPI interface while valid data is being sent in both directions. Low power operation Sleep modes generally work the same on SPI as they do on UART. However, due to the addition of SPI mode, there is an option of another sleep pin, as described below. By default, Digi configures DIO8 (SLEEP_REQUEST) as a peripheral and during pin sleep it wakes the device and puts it to sleep. This applies to both the UART and SPI serial interfaces. If SLEEP_REQUEST is not configured as a peripheral and SPI_SSEL is configured as a peripheral, then pin sleep is controlled by SPI_SSEL rather than by SLEEP_REQUEST. Asserting SPI_SSEL (pin 15) by driving it low either wakes the device or keeps it awake. Negating SPI_SSEL by driving it high puts the device to sleep. XBee®/XBee-PRO SX RF Module User Guide 66 Serial communication Configuration considerations Using SPI_SSEL to control sleep and to indicate that the SPI master has selected a particular slave device has the advantage of requiring one less physical pin connection to implement pin sleep on SPI. It has the disadvantage of putting the device to sleep whenever the SPI master negates SPI_SSEL (meaning time is lost waiting for the device to wake), even if that was not the intent. If the user has full control of SPI_SSEL so that it can control pin sleep, whether or not data needs to be transmitted, then sharing the pin may be a good option in order to make the SLEEP_REQUEST pin available for another purpose. If the device is one of multiple slaves on the SPI, then the device sleeps while the SPI master talks to the other slave, but this is acceptable in most cases. If you do not configure either pin as a peripheral, then the device stays awake, being unable to sleep in SM1 mode. Configuration considerations The configuration considerations are: n How do you select the serial port? For example, should you use the UART or the SPI port? n If you use the SPI port, what data format should you use in order to avoid processing invalid characters while transmitting? n What SPI options do you need to configure? SPI and API mode The SPI only operates in API mode 1. The SPI does not support Transparent mode or API mode 2 (with escaped characters). This means that the AP configuration only applies to the UART interface and is ignored while using the SPI. SPI parameters Most host processors with SPI hardware allow you to set the bit order, clock phase and polarity. For communication with all XBee/XBee-PRO SX RF Modules, the host processor must set these options as follows: n Bit order: send MSB first n Clock phase (CPHA): sample data on first (leading) edge n Clock polarity (CPOL): first (leading) edge rises All XBee/XBee-PRO SX RF Modules use SPI mode 0 and MSB first. Mode 0 means that data is sampled on the leading edge and that the leading edge rises. MSB first means that bit 7 is the first bit of a byte sent over the interface. Serial port selection To enable the UART port, configure DIN and DOUT (P3 and P4 parameters) as peripherals. To enable the SPI port, enable SPI_MISO, SPI_MOSI, SPI_SSEL , and SPI_CLK (P5 through P9) as peripherals. If you enable both ports then output goes to the UART until the first input on SPI. When both the UART and SPI ports are enabled on power-up, all serial data goes out the UART. As soon as input occurs on either port, that port is selected as the active port and no input or output is allowed on the other port until the next device reset. XBee®/XBee-PRO SX RF Module User Guide 67 Serial communication UART flow control If you change the configuration so that only one port is configured, then that port is the only one enabled or used. If the parameters are written with only one port enabled, then the port that is not enabled is not used even temporarily after the next reset. If both ports are disabled on reset, the device uses the UART in spite of the wrong configuration so that at least one serial port is operational. Serial receive buffer When serial data enters the device through the DIN pin (or the MOSI pin), it stores the data in the serial receive buffer until the device can process it. Under certain conditions, the device may not be able to process data in the serial receive buffer immediately. If large amounts of serial data are sent to the device such that the serial receive buffer would overflow, then it discards new data. If the UART is in use, you can avoid this by the host side honoring CTS flow control. If the SPI is the serial port, no hardware flow control is available. It is your responsibility to ensure that the receive buffer does not overflow. One reliable strategy is to wait for a TX_STATUS response after each frame sent to ensure that the device has had time to process it. Serial transmit buffer When the device receives RF data, it moves the data into the serial transmit buffer and sends it out the UART or SPI port. If the serial transmit buffer becomes full and the system buffers are also full, then it drops the entire RF data packet. Whenever the device receives data faster than it can process and transmit the data out the serial port, there is a potential of dropping data. UART flow control You can use the RTS and CTS pins to provide RTS and/or CTS flow control. CTS flow control provides an indication to the host to stop sending serial data to the device. RTS flow control allows the host to signal the device to not send data in the serial transmit buffer out the UART. To enable RTS/CTS flow control, use the D6 and D7 commands. Note Serial port flow control is not possible when using the SPI port. CTS flow control If you enable CTS flow control (D7 command), when the serial receive buffer is 17 bytes away from being full, the device de-asserts CTS (sets it high) to signal to the host device to stop sending serial data. The device reasserts CTS after the serial receive buffer has 34 bytes of space. See FT (Flow Control Threshold) for the buffer size. In either case, CTS is not re-asserted until the serial receive buffer has FT-17 or less bytes in use. RTS flow control If you send the D6 command to enable RTS flow control, the device does not send data in the serial transmit buffer out the DOUT pin as long as RTS is de-asserted (set high). Do not de-assert RTS for long periods of time or the serial transmit buffer will fill. If the device receives an RF data packet and the serial transmit buffer does not have enough space for all of the data bytes, it discards the entire RF data packet. The UART Data Present Indicator is a useful feature when using RTS flow control. When enabled, the DIO19 line asserts (low asserted) when UART data is queued to be transmitted from the device. For more information, see P9 (DIO19/SPI_ATTN). XBee®/XBee-PRO SX RF Module User Guide 68 Serial communication UART flow control If the device sends data out the UART when RTS is de-asserted (set high) the device could send up to five characters out the UART port after RTS is de-asserted. XBee®/XBee-PRO SX RF Module User Guide 69 AT commands Special commands MAC/PHY commands Diagnostic commands - MAC statistics and timeouts Network commands Addressing commands Diagnostic - addressing commands Addressing discovery/configuration commands Security commands Serial interfacing commands I/O settings commands I/O sampling commands I/O line passing commands Sleep commands Diagnostic - sleep status/timing commands Command mode options Firmware version/information commands XBee®/XBee-PRO SX RF Module User Guide 71 72 77 79 82 85 86 88 90 93 106 108 113 116 118 119 70 AT commands Special commands Special commands The following commands are special commands. AC (Apply Changes) This command applies to the XBee/XBee-PRO SX RF Module. Immediately applies new settings without exiting Command mode. Parameter range N/A Default N/A FR (Software Reset) This command applies to the XBee/XBee-PRO SX RF Module. Resets the device. The device responds immediately with an OK and performs a reset 100 ms later. If you issue FR while the device is in Command Mode, the reset effectively exits Command mode. Parameter range N/A Default N/A RE (Restore Defaults) This command applies to the XBee/XBee-PRO SX RF Module. Restore device parameters to factory defaults. Parameter range N/A Default N/A WR (Write) This command applies to the XBee/XBee-PRO SX RF Module. Writes parameter values to non-volatile memory so that parameter modifications persist through subsequent resets. Note Once you issue a WR command, do not send any additional characters to the device until after you receive the OK response. Parameter range N/A XBee®/XBee-PRO SX RF Module User Guide 71 AT commands MAC/PHY commands Default N/A MAC/PHY commands The following AT commands are MAC/PHY commands. AF (Available Frequencies) This command applies to the XBee/XBee-PRO SX RF Module. You can query this read-only command to return a bitfield of the frequencies that are available in the device’s region of operation. This command returns a bitfield. Each bit corresponds to a physical channel. Note that the least significant bit in the bitmask selects the channel in the lowest frequency in the range. Channels for these data rates are spaced 250 kHz apart. Parameter range 0x7FF - 0x1F FFFF FFFF FFFF FFFF FFFF FFFF Default Operating frequency range Channel spacing Region BR Bitfield United States / Canada 0/1 0x1F ffff FFFF ffff FFFF 902,500 to 927,500 kHz ffff FFFF 250 kHz United States / Canada 2 0x03 FFFF ffff FFFF 902,750 to 927,250 kHz 500 kHz Australia 0/1 0x01 FFFF ffff FFFF 915,500 to 927,500 kHz 250 kHz Australia 2 0Xff FFFF 915,750 to 927,250 kHz 500 kHz New Zealand 0/1 0x1FF ffff FFFF 917,500 to 927,500 kHz 250 kHz New Zealand 2 0x7FF 922,250 to 927,250 kHz 500 kHz Brazil 0/1 0x1F ffff FFFF ffff FFFF 902,625 to 907,125 kHz and 915,375 to 927,625 kHz 250 kHz Brazil 2 0x07 ffff FFFF 902,750 to 906,350 kHz and 915,800 to 927,050 kHz 450 kHz France 0/1 0x7f FFFF 915,250 to 920,750 kHz 250 kHz France 2 0x0FFF 915,250 to 920,750 kHz 500 kHz CM (Channel Mask) This command applies to the XBee/XBee-PRO SX RF Module. XBee®/XBee-PRO SX RF Module User Guide 72 AT commands MAC/PHY commands CM allows you to selectively enable or disable channels used for RF communication. This is useful to avoid using frequencies that experience unacceptable levels of RF interference, or to operate two networks of radios on separate frequencies. When CM is queried, it returns the operating channel mask based on what value BR is set to. When BR is set to 2, a fixed channel mask is used (see the defaults below). A user-defined CM value is only used when BR is set to 0 or 1. This command is a bitfield. Each bit in the bitfield corresponds to a frequency as defined in the AF (Available Frequencies) command. When you set a bit in CM and the corresponding bit in AF is 1, then the device can choose that channel as an active channel for communication. Note For Australia and New Zealand, CM is read-only. Exactly MF (Minimum Frequencies) number of channels must be made available for the device to communicate on. All devices in a network must use an identical set of active channels in order to communicate. Separate networks that are in physical range of each other should either be configured to use separate channels or to use different HP (Preamble ID) and/or ID (Network IDs) to avoid receiving data from the other network. You may find the ED (Energy Detect) command useful when choosing what channels to enable or disable. The default CM mask spaces the channels across the entire 900 MHz band. Parameter range United States/Canada: 0x1 FFFF FFFF FFFF - 0x1F FFFF FFFF FFFF FFFF FFFF FFFF Australia/New Zealand: Read-only Brazil: 0x03 FFFF FFFF FFFF - 0x1F FFFF FFFF FFFF FFFF Default Country Default CM when BR is 0 or 1 Default CM when BR is 2 United States/Canada 0x05 5555 5555 5555 5555 5555 5555 0x00 0000 0000 0003 FFFF FFFF FFFF Australia 0x00 0000 0000 0000 01FF FFFF FFFF 0x00 0000 0000 0000 0000 00FF FFFF New Zealand 0x00 0000 0000 0000 01FF FFFF FFFF 0x00 0000 0000 0000 0000 0000 07FF Brazil 0x00 0000 001F FFFF FFFF FFF8 0000 0x00 0000 0000 0000 0007 FFFF FFFF MF (Minimum Frequencies) This command applies to the XBee/XBee-PRO SX RF Module. This read-only command returns the number of hopping channels that the device uses to comply with its region of operation. You can use this information to determine which available frequencies you want to enable with the CM command. MF may vary depending on the BR setting. Parameter range read-only Default United States/Canada: 0x32 (50 channels) XBee®/XBee-PRO SX RF Module User Guide 73 AT commands MAC/PHY commands The Default value of MF for the Australia/New Zealand firmware varies depending on the value you set BR to: BR value Australia default New Zealand default Brazil default 0 0x31 (49 channels) 0x29 (41 channels) 0 - 0x32 (50 channels) 1 0x31 (49 channels) 0x29 (41 channels) 1 - 0x32 (50 channels) 2 0x18 (24 channels) 0x0B (11 channels) 2 - 0x23 (35 channels) HP (Preamble ID) This command applies to the XBee/XBee-PRO SX RF Module. The preamble ID for which the device communicates. Only devices with matching preamble IDs can communicate with each other. Different preamble IDs minimize interference between multiple sets of devices operating in the same vicinity. When receiving a packet, the device checks this before the network ID, as it is encoded in the preamble, and the network ID is encoded in the MAC header. Parameter range 0 - 9 (usually) 0 - 7 (For some regions and values of BR. See BR (RF Data Rate) for details.) Default 0 ID (Network ID) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the user network identifier. Devices must have the same network identifier to communicate with each other. Devices can only communicate with other devices that have the same network identifier and channel configured. When receiving a packet, the device check this after the preamble ID. If you are using Original equipment manufacturer (OEM) network IDs, 0xFFFF uses the factory value. Parameter range 0 - 0x7FFF Default 0x7FFF MT (Broadcast Multi-Transmits) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the number of additional MAC-level broadcast transmissions. All broadcast packets are transmitted MT+1 times to ensure they are received. Parameter range 0-5 XBee®/XBee-PRO SX RF Module User Guide 74 AT commands MAC/PHY commands Default 3 BR (RF Data Rate) This command applies to the XBee/XBee-PRO SX RF Module. Sets and reads the device's RF data rate (the rate at which the device transmits and receives RF data over-the-air). Synchronous sleep is not supported when BR = 0. All devices on the network must have the same BR value set in order to communicate. BR directly affects the range of the device. The higher the RF data rate, the lower the receive sensitivity. BR also affects the number of hopping patterns (HP) and the number of channels based on region as shown in the following table: BR Region # of hopping patterns (HP) # of channels 0 or 1 Australia 10 49 0 or 1 Brazil 10 50 0 or 1 New Zealand 10 41 0 or 1 France 8 12 2 Australia 8 24 2 Brazil 10 35 2 New Zealand 8 11 2 France 8 12 Parameter range 0-2 Parameter RF data rate Receiver sensitivity 0 10 kb/s -113 dBm 1 110 kb/s -106 dBm 2 250 kb/s -103 dBm Default 2 PL (TX Power Level) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the power level at which the device transmits conducted power. Power levels are approximate. XBee®/XBee-PRO SX RF Module User Guide 75 AT commands MAC/PHY commands The XBee-PRO SX requires the power supply to be above 3.3 V to ensure 30 dBm output power. The following table shows the typical values over supply voltage. If using a USB interface board with an XBee-PRO SX module, you must supply external DC power. Power supply Output power @ PL = 2 3.3 to 3.6 V 30 dBm typical 3.0 V 29 dBm typical 2.6 V 27 dBm typical Note The device generates heat during RF transmission. There is an additional ground pad on the underside of the module that is used for heat dissipation. For more details, see PCB design and manufacturing. Parameter range 0-2 Setting XBee Tx power level XBee-PRO Tx Power level 0 0 dBm 21.5 dBm 1 10 dBm 27 dBm 2 13 dBm 30 dBm New Zealand specific: Setting Low/middle data rate High data rate 0 0 dBm 0 dBm 1 10 dBm 7.5 dBm 2 13 dBm 7.5 dBm Default 2 RR (Unicast Mac Retries) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the maximum number of MAC level packet delivery attempts for unicasts. If RR is nonzero, the sent unicast packets request an acknowledgment from the recipient. Unicast packets can be retransmitted up to RR times if the transmitting device does not receive a successful acknowledgment. Parameter range 0 - 0xF XBee®/XBee-PRO SX RF Module User Guide 76 AT commands Diagnostic commands - MAC statistics and timeouts Default 0xA (10 retries) ED (Energy Detect) This command applies to the XBee/XBee-PRO SX RF Module. Starts an energy detect scan. This command accepts an argument to specify the time in milliseconds to scan all channels. The device loops through all the available channels until the time elapses. It returns the maximal energy on each channel, a comma follows each value, and the list ends with a carriage return. The values returned reflect the energy level that ED detects in -dBm units. Parameter range 0 - 0x3A98 (15 seconds) Default N/A Diagnostic commands - MAC statistics and timeouts The following AT commands are MAC diagnostic commands and timeouts. Diagnostic commands are typically volatile and will not persist across a power cycle. BC (Bytes Transmitted) This command applies to the XBee/XBee-PRO SX RF Module. The number of RF bytes transmitted. The firmware counts bytes in every retry and retransmission. A packet includes not only the payload, but also the preamble, the MAC header, the network header, the application header, encryption overhead, and the CRC. The purpose of this count is to estimate battery life by tracking time spent performing transmissions. BC stops counting when it reaches a max value of 0xffffFFFF. But, you can reset the counter to any 32-bit value—for example 0—by appending a hexadecimal parameter to the command. Parameter range 0 - 0xFFFFFFFF Default N/A (0 after reset) DB (Last Packet RSSI) This command applies to the XBee/XBee-PRO SX RF Module. Reports the RSSI in -dBm of the last received RF data packet. DB returns a hexadecimal value for the dBm measurement. For example, if DB returns 0x60, then the RSSI of the last packet received was -96 dBm. The RSSI measurement is accurate within ±2 dB from approximately -50 dBm down to sensitivity. DB only indicates the signal strength of the last hop. It does not provide an accurate quality measurement for a multihop link. If the XBee/XBee-PRO SX RF Module has been reset and has not yet received a packet, DB reports 0. This value is volatile—the value does not persist in the device's memory after a power-up sequence. XBee®/XBee-PRO SX RF Module User Guide 77 AT commands Diagnostic commands - MAC statistics and timeouts Parameter range 0x28 - 0x6E (-40 dBm to -110 dBm) [read-only] Default 0 ER (Receive Count Error) This command applies to the XBee/XBee-PRO SX RF Module. This count increments when a device receives a packet that contains integrity errors of some sort. When the number reaches 0xFFFF, the firmware does not count further events. To reset the counter to any 16-bit value, append a hexadecimal parameter to the command. This value is volatile (the value does not persist in the device's memory after a power-up sequence). Occasionally random noise can cause this value to increment. The ER parameter is not reset by pin, serial port or cyclic sleep modes. Default N/A GD (Good Packets Received) This command applies to the XBee/XBee-PRO SX RF Module. This count increments when a device receives a good frame with a valid MAC header on the RF interface. Received MAC ACK packets do not increment this counter. Once the number reaches 0xFFFF, it does not count further events. To reset the counter to any 16-bit unsigned value, append a hexadecimal parameter to the command. This value is volatile (the value does not persist in the device's memory after a power-up sequence). Parameter range 0 - 0xFFFF Default N/A EA (MAC ACK Failure Count) This command applies to the XBee/XBee-PRO SX RF Module. This count increments whenever a MAC ACK timeout occurs on a MAC-level unicast. When the number reaches 0xFFFF, the firmware does not count further events. To reset the counter to any 16-bit unsigned value, append a hexadecimal parameter to the command. This value is volatile (the value does not persist in the device's memory after a power-up sequence). Parameter range 0 - 0xFFFF Default N/A XBee®/XBee-PRO SX RF Module User Guide 78 AT commands Network commands TR (Transmission Failure Count) This command applies to the XBee/XBee-PRO SX RF Module. This value is volatile—the value does not persist in the device's memory after a power-up sequence. Parameter range 0 - 0xFFFF Default N/A UA (Unicasts Attempted Count) This command applies to the XBee/XBee-PRO SX RF Module. The number of unicast transmissions expecting an acknowledgment (when RR > 0). This value is volatile—the value does not persist in the device's memory after a power-up sequence. Parameter range 0 - 0xFFFF Default N/A %H (MAC Unicast One Hop Time) This command applies to the XBee/XBee-PRO SX RF Module. The MAC unicast one hop time timeout in milliseconds. If you change the MAC parameters it can change this value. Parameter range [read-only] Default N/A %8 (MAC Broadcast One Hop Time) This command applies to the XBee/XBee-PRO SX RF Module. Parameter range [read-only] Default N/A Network commands The following commands are network commands. XBee®/XBee-PRO SX RF Module User Guide 79 AT commands Network commands CE (Routing / Messaging Mode) This command applies to the XBee/XBee-PRO SX RF Module. The routing and messaging mode of the device. A routing device repeats broadcasts. Indirect Messaging Coordinators do not transmit point-tomultipoint unicasts until an end device requests them. Setting a device as a poller causes it to regularly send polls to its Indirect Messaging Coordinator. Nodes can also be configured to route, or not route, multi-hop packets. Sets or displays the behavior (End Device versus Coordinator) of the device. Sets or displays whether the device is a coordinator. Parameter range 0-6 Parameter Description Routes packets 0 Standard router Yes 1 Indirect message coordinator Yes 2 Non-routing device No 3 Non-routing coordinator No 4 Indirect message poller Yes 5 N/A N/A 6 Non-routing poller No Default 0 C8 (Compatibility Options) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the operational compatibility with older versions of the firmware. Parameter range 4 Bit field: Bit Meaning Setting Description 2 Encryption compatibility 0 When encryption is enabled, AES Counter mode is used with a 256-bit key. 1 When encryption is enabled AES CBC mode is used with a 256-bit key. This bit should be set when using encryption with versions of the firmware prior to 9009. It may be used in all circumstances if set consistently throughout the network, but it disables the more secure counter mode encryption. XBee®/XBee-PRO SX RF Module User Guide 80 AT commands Network commands All other bits should be 0 for future compatibility. Default 0x04 BH (Broadcast Hops) This command applies to the XBee/XBee-PRO SX RF Module. The maximum transmission hops for broadcast data transmissions. This will not affect Point-toMultipoint transmissions (TO = 40). If you set BH greater than NH, the device uses the value of NH. Parameter range 0 - 0x20 Default 0 NH (Network Hops) This command applies to the XBee/XBee-PRO SX RF Module. The maximum number of hops expected to be seen in a network route. This value limits the number of hops used in a route discovery; thereby, it limits the number of hops allowed in a unicast. Additionally, NH is used to calculate the timeouts for a network acknowledgment. Parameter range 1 - 0x20 (1 - 32 hops) Default 7 MR (Mesh Unicast Retries) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the maximum number of network packet delivery attempts. If MR is non-zero, the packets a device sends request a network acknowledgment, and can be resent up to MR+1 times if the device does not receive an acknowledgment. Changing this value dramatically changes how long a route request takes. We recommend that you set this value to 1. Parameter range 0 - 7 mesh unicast retries Default 1 NN (Network Delay Slots) This command applies to the XBee/XBee-PRO SX RF Module. XBee®/XBee-PRO SX RF Module User Guide 81 AT commands Addressing commands Set or read the maximum random number of network delay slots before rebroadcasting a network packet. Parameter range 1 - 0x5 network delay slots Default 3 Addressing commands The following AT commands are addressing commands. SH (Serial Number High) This command applies to the XBee/XBee-PRO SX RF Module. Displays the upper 32 bits of the unique IEEE 64-bit extended address assigned to the XBee in the factory. The 64-bit source address is always enabled. This value is read-only and it never changes. Parameter range 0 - 0xFFFFFFFF [read-only] Default Set in the factory SL (Serial Number Low) This command applies to the XBee/XBee-PRO SX RF Module. Displays the lower 32 bits of the unique IEEE 64-bit RF extended address assigned to the XBee in the factory. The 64-bit source address is always enabled. This value is read-only and it never changes. Parameter range 0 - 0xFFFFFFFF [read-only] Default Set in the factory DH (Destination Address High) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the upper 32 bits of the 64-bit destination address. When you combine DH with DL, it defines the destination address that the device uses for transmissions in Transparent mode. The destination address is also used for I/O sampling in both Transparent and API modes. To transmit using a 16-bit address, set DH to 0 and DL less than 0xFFFF. 0x000000000000FFFF is the broadcast address. XBee®/XBee-PRO SX RF Module User Guide 82 AT commands Addressing commands Parameter range 0 - 0xFFFFFFFF Default 0 DL (Destination Address Low) This command applies to the XBee/XBee-PRO SX RF Module. Set or display the lower 32 bits of the 64-bit destination address. When you combine DH with DL, it defines the destination address that the device uses for transmissions in Transparent mode. The destination address is also used for I/O sampling in both Transparent and API modes. 0x000000000000FFFF is the broadcast address. Parameter range 0 - 0xFFFFFFFF Default 0xFFFF TO (Transmit Options) This command applies to the XBee/XBee-PRO SX RF Module. The bitfield that configures the transmit options for Transparent mode. The device's transmit options. The device uses these options for all transparent transmissions. API transmissions can override this using the TxOptions field in the API frame. DigiMesh is not supported if BR is set to 0, transmitted packets will be sent as point-topoint/multipoint in this case. Parameter range 0 - 0xFF Bit Meaning Description 6,7 Delivery method b’00 = b’01 = Point-multipoint b'10 = Repeater mode—directed broadcast of packets b’11 = DigiMesh—not available when BR = 0 When you set BR to 0 the TO option has the DigiMesh and Repeater mode disabled automatically. Default 0x40 When BR = 0 0xC0 When BR = 1 NI (Node Identifier) This command applies to the XBee/XBee-PRO SX RF Module. XBee®/XBee-PRO SX RF Module User Guide 83 AT commands Addressing commands Stores the node identifier string for a device, which is a user-defined name or description of the device. This can be up to 20 ASCII characters. n XCTU prevents you from exceeding the string limit of 20 characters for this command. If you are using another software application to send the string, you can enter longer strings, but the software on the device returns an error. Parameter range A string of case-sensitive ASCII printable characters from 0 to 20 bytes in length. A carriage return or a comma automatically ends the command. Default 0x20 (an ASCII space character) NT (Network Discovery Back-off) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the network discovery back-off parameter for a device. This sets the maximum value for the random delay that the device uses to send network discovery responses. Parameter range 0x20 - 0x2EE0 (x 100 ms) Default 0x82 (13 seconds) NO (Network Discovery Options) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the network discovery options value for the ND (Network Discovery) command on a particular device. The options bit field value changes the behavior of the ND command and what optional values the local device returns when it receives an ND command or API Node Identification Indicator (0x95) frame. Use NO to suppress or include a self-response to ND (Node Discover) commands. When NO bit 1 = 1, a device performing a Node Discover includes a response entry for itself. Parameter range 0x0 - 0x7 (bit field) Bit field Option Description 0x01 Append the DD (Digi Device Identifier) value to ND responses or API node identification frames. 0x02 Local device sends ND response frame out the serial interface when ND is issued. 0x04 Append the RSSI of the last hop to ND, FN, and responses or API node identification frames. XBee®/XBee-PRO SX RF Module User Guide 84 AT commands Diagnostic - addressing commands Default 0x0 CI (Cluster ID) This command applies to the XBee/XBee-PRO SX RF Module. The application layer cluster ID value. The device uses this value as the cluster ID for all data transmissions. If you set this value to 0x12 (loopback Cluster ID), the destination node echoes any transmitted packet back to the source device. Supported Cluster IDs 0x11: Transparent data (default) 0x12: Loopback 0x14: Test Link Request 0x94: Test Link Result 0x23: Memory Access (GPM) Parameter range 0 - 0xFFFF Default 0x11 (Transparent data cluster ID) Diagnostic - addressing commands The following AT command is a Diagnostic - addressing command. N? (Network Discovery Timeout) This command applies to the XBee/XBee-PRO SX RF Module. The maximum response time, in milliseconds, for ND (Network Discovery) responses and DN (Discover Node) responses. The timeout is the sum of NT (Network Discovery Back-off Time) and the network propagation time. Parameter range [read-only] Default N/A R? (Region) This command applies to the XBee/XBee-PRO SX RF Module. Indicates the region of the module. n USA/Canada = 1 n Australia = 2 XBee®/XBee-PRO SX RF Module User Guide 85 AT commands Addressing discovery/configuration commands n Brazil = 3 n New Zealand = 6 Parameter range 1, 2, 3, 6 [read-only] Default N/A Addressing discovery/configuration commands AG (Aggregator Support) This command applies to the XBee/XBee-PRO SX RF Module. The AG command sends a broadcast through the network that has the following effects on nodes that receive the broadcast: n The receiving node establishes a DigiMesh route back to the originating node, if there is space in the routing table. n The DH and DL of the receiving node update to the address of the originating node if the AG parameter matches the current DH/DL of the receiving node. n API-enabled devices with updated DH and DL send an Aggregate Addressing Update frame (0x8E) out the serial port. Note The AG command is only available on products that support DigiMesh. Parameter range Any 64-bit address Default N/A DN (Discover Node) This command applies to the XBee/XBee-PRO SX RF Module. Resolves an NI (Node identifier) string to a physical address (case sensitive). The following events occur after DN discovers the destination node: When DN is sent in Command mode: 1. The device sets DL and DH to the extended (64-bit) address of the device with the matching NI string. 2. The receiving device returns OK (or ERROR). 3. The device exits Command mode to allow for immediate communication. If an ERROR is received, then Command mode does not exit. When DN is sent as a local AT Command API frame (0x08): XBee®/XBee-PRO SX RF Module User Guide 86 AT commands Addressing discovery/configuration commands 1. The receiving device returns 0xFFFE followed by its 64-bit extended addresses in a Remote AT Command Response- 0x97. 2. The device returns an ERROR message if it is given without a destination node (that is without a parameter) or if the given destination node does not respond within N? milliseconds. Parameter range 20-byte ASCII string Default N/A ND (Network Discover) This command applies to the XBee/XBee-PRO SX RF Module. Discovers and reports all of the devices it finds on a network. If you send ND through a local API frame, each network node returns a separate Local AT Command Response - 0x88 or Remote AT Command Response- 0x97 frame, respectively. The command reports the following information after a jittered time delay. SH (4 bytes) SL (4 bytes) NI (variable, 0-20 bytes plus 0x00 character) DEVICE_TYPE (1 byte) STATUS (1 byte: reserved) PROFILE_ID (2 bytes) MANUFACTURER_ID (2 bytes) DIGI DEVICE TYPE (4 bytes. Optionally included based on NO settings.) RSSI OF LAST HOP (1 byte. Optionally included based on NO settings.) After (NT * 100) milliseconds, the command ends by returning a . If you send ND through a local AT Command (0x08) API frame, each network node returns a separate AT Command Response (0x88) or Remote Command Response (0x97) frame, respectively. The data consists of the bytes listed above without the carriage return delimiters. The NI string ends in a 0x00 null character. Broadcast an ND command to the network. If the command includes an optional node identifier string parameter, only those devices with a matching NI string respond without a random offset delay. If the command does not include a node identifier string parameter, all devices respond with a random offset delay. The NT setting determines the range of the random offset delay. The NO setting sets options for the Node Discovery. For more information about options that affect the behavior of the ND command Refer to the description of the NO command for options which affect the behavior of the ND command. WARNING! If the NT setting is small relative to the number of devices on the network, responses may be lost due to channel congestion. Regardless of the NT setting, because the random offset only mitigates transmission collisions, getting responses from all devices in the network is not guaranteed. XBee®/XBee-PRO SX RF Module User Guide 87 AT commands Security commands Parameter range N/A Default N/A FN (Find Neighbors) This command applies to the XBee/XBee-PRO SX RF Module. Discovers and reports all devices found within immediate (1 hop) RF range. FN reports the following information for each device it discovers: MY (always 0xFFFE) SH SL NI (Variable length) PARENT_NETWORK ADDRESS (2 bytes) (always 0xFFFE) DEVICE_TYPE (1 byte: 0 = Coordinator, 1 = Router, 2 = End Device) STATUS (1 byte: reserved) PROFILE_ID (2 bytes) MANUFACTURER_ID (2 bytes) DIGI DEVICE TYPE (4 bytes. Optionally included based on NO (Network Discovery Options) settings.) RSSI OF LAST HOP (1 byte. Optionally included based on NO (Network Discovery Options) settings.) If you send the FN command in Command mode, after (NT*100) ms + overhead time, the command ends by returning a carriage return, represented by . If you send the FN command through a local AT Command (0x08) or remote AT command (0x17) API frame, each response returns as a separate AT Command Response (0x88) or Remote Command Response (0x97) frame, respectively. The data consists of the bytes in the previous list without the carriage return delimiters. The NI string ends in a 0x00 null character. Parameter range N/A Default N/A Security commands The following AT commands are security commands. EE (Encryption Enable) This command applies to the XBee/XBee-PRO SX RF Module. Enable or disable 256-bit Advanced Encryption Standard (AES) encryption. Set this command parameter the same on all devices in a network. XBee®/XBee-PRO SX RF Module User Guide 88 AT commands Security commands See C8 (Compatibility Options) that affects whether to use CBC mode or CTR mode encryption. A 256bit AES key is used in both instances. Parameter range 0-1 Parameter Description 0 Encryption Disabled 1 Encryption Enabled Default 0 KY (AES Encryption Key) This command applies to the XBee/XBee-PRO SX RF Module. Sets the 256-bit network security key value that the device uses for encryption and decryption. This command is write-only. If you attempt to read KY, the device returns an OK status. Set this command parameter the same on all devices in a network. Parameter range 256-bit value (64 Hexadecimal digits) Default N/A 0 KZ (Remote AT Command Password) This command applies to the XBee/XBee-PRO SX RF Module. Sets a password to inhibit transmission and reception of remote AT commands without including the password in the request. The password is write-only and cannot be changed without knowing the current password. When you set KZ, it disables Remote AT Command Request - 0x17 frames and you must use Secure Remote AT Command Request frame - 0x18 frames. To change the password, enter two ASCII strings of 16 characters or less, separated by a space character. The first string is the old password and the second string is the new password. All ASCII characters other than white space characters and comma (,) are allowed in a password. Although we do not recommend it, you can include non-printable characters in the password if you enter them in API mode. The software allows all characters that are not password delimiters (SP, comma, CR, LF, TAB, vertical tab, and form feed), as part of the password. Each device has its own password, which may or may not match passwords on another device in the network. You must enable encryption when using a password so that even if the password is reset to the default value of 0 by using of RE (Restore Defaults), access to an active network is still inhibited due to the network key (KY) also being lost. XBee®/XBee-PRO SX RF Module User Guide 89 AT commands Serial interfacing commands Parameter range 3 to 33 ASCII characters (a minimum of three characters are required to enter two passwords separated by a space) Default 0 in ASCII. Note When KZ is set to any value other than the default, it cannot be read. However, when KZ is set to the default value it reads 0. Serial interfacing commands The following AT commands are serial interfacing commands. BD (Interface Data Rate) This command applies to the XBee/XBee-PRO SX RF Module. Sets and reads the serial interface data rate (baud rate) between the device and the host. The baud rate is the rate that the host sends serial data to the device. When you make an update to the interface data rate, the change does not take effect until the host issues the CN command and the device returns the OK response. The BD parameter does not affect the RF data rate. If you set the interface data rate higher than the RF data rate, you may need to implement a flow control configuration. The range between standard and non-standard baud rates (0x9B - 0x4B0) is invalid. The range between 0x2580 and 0x4AFF is also invalid. Non-standard interface data rates The firmware interprets any value within 0x4B0 - 0x2580 and 0x4B00 - 0x1C9468 as an actual baud rate. When the host sends a value above 0x4B0, the firmware stores the closest interface data rate represented by the number in the BD register. For example, to set a rate of 19200 b/s, send the following command line: ATBD4B00. Note When using XCTU, you can only set and read non-standard interface data rates using the XCTU Serial Console tool. You cannot access non-standard rates through the configuration section of XCTU. When you send the BD command with a non-standard interface data rate, the UART adjusts to accommodate the interface rate you request. In most cases, the clock resolution causes the stored BD parameter to vary from the sent parameter. Sending ATBD without an associated parameter value returns the value actually stored in the device’s BD register. The following table provides the parameters sent versus the parameters stored. BD parameter sent (HEX) Interface data rate (b/s) BD parameter stored (HEX) 0 1200 0 4 19,200 4 7 115,200 7 1C200 115,200 1B207 XBee®/XBee-PRO SX RF Module User Guide 90 AT commands Serial interfacing commands Parameter ranges 0 - xA (standard rates) 0x4B0 - 0x1C9468 (non-standard rates; 0x2581 to 0x4AFF not supported) Parameter Configuration (b/s) 0 1200 1 2400 2 4800 3 9600 4 19200 5 38400 6 57600 7 115200 8 230400 9 460800 10 921600 Default 3 NB (Parity) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the serial parity settings for UART communications. Parameter range 0x00 - 0x02 Parameter Description 0x00 No parity 0x01 Even parity 0x02 Odd parity Parameter Description 0 No parity 1 Even parity 2 Odd parity XBee®/XBee-PRO SX RF Module User Guide 91 AT commands Serial interfacing commands Default 0x00 SB (Stop Bits) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the number of stop bits in the data packet. Parameter range 0-1 Parameter Configuration 0 One stop bit 1 Two stop bits Default 0 RO (Packetization Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the number of character times of inter-character silence required before transmission begins when operating in Transparent mode. Set RO to 0 to transmit characters as they arrive instead of buffering them into one RF packet. Parameter range 0 - 0xFF (x character times) Default 3 FT (Flow Control Threshold) This command applies to the XBee/XBee-PRO SX RF Module. Set or display the flow control threshold. The device de-asserts CTS when FT bytes are in the UART receive buffer. It re-asserts CTS when less than FT-16 bytes are in the UART receive buffer. Parameter range 0x11 - 0x16F bytes Default 0x13F AP (API Enable) This command applies to the XBee/XBee-PRO SX RF Module. XBee®/XBee-PRO SX RF Module User Guide 92 AT commands I/O settings commands Set or read the API mode setting. The device can format the RF packets it receives into API frames and send them out the serial port. When you enable API, you must format the serial data as API frames because Transparent operating mode is disabled. Enables API Mode. The device ignores this command when using SPI. API mode 1 is always used. Parameter range 0-2 Parameter Description 0 Transparent mode, API mode is off. All UART input and output is raw data and the device uses the RO and RB parameters to delineate packets. 1 API Mode Without Escapes. The device packetizes all UART input and output data in API format, without escape sequences. 2 API Mode With Escapes. The device is in API mode and inserts escaped sequences to allow for control characters. The device passes XON (0x11), XOFF (0x13), Escape (0x7D), and start delimiter 0x7E as data. Default 0 AO (API Options) This command applies to the XBee/XBee-PRO SX RF Module. The API data frame output format for RF packets received. Use AO to enable different API output frames. Parameter range 0-2 Parameter Description 0 API Rx Indicator - 0x90, this is for standard data frames. 1 API Explicit Rx Indicator - 0x91, this is for Explicit Addressing data frames. 2 XTend DigiMesh API Rx Indicator - 0x80 Default 0 I/O settings commands The following AT commands are I/O settings commands. D0 (DIO0/AD0) This command applies to the XBee/XBee-PRO SX RF Module. XBee®/XBee-PRO SX RF Module User Guide 93 AT commands I/O settings commands Sets or displays the DIO0/AD0 configuration (pin 33). Parameter range 0-5 Parameter Description 0 Disabled 0 Unmonitored digital input 1 Commissioning Pushbutton 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 1 D1 (DIO1/AD1) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO1/AD1 configuration (pin 32). Parameter range 0, 2 - 5 Parameter Description 0 Disabled 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D2 (DIO2/AD2) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO2/AD2 configuration (pin 31). XBee®/XBee-PRO SX RF Module User Guide 94 AT commands I/O settings commands Parameter range 0, 2 - 5 Parameter Description 0 Disabled 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D3 (DIO3/AD3) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO3/AD3 configuration (pin 30). Parameter range 0, 2 - 5 Parameter Description 0 Disabled 0 Unmonitored digital input 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D4 (DIO4) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO4 configuration (pin 24). Parameter range 0, 2 - 5 XBee®/XBee-PRO SX RF Module User Guide 95 AT commands I/O settings commands Parameter Description 0 Disabled 0 Unmonitored digital input 1 N/A 2 ADC 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D5 (DIO5/ASSOCIATED_INDICATOR) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO5/ASSOCIATED_INDICATOR configuration (pin 28). Parameter range 0, 1, 3 - 5 Parameter Description 0 Disabled 1 Associate LED indicator - blinks when associated 2 N/A 3 Digital input 4 Digital output, default low 5 Digital output, default high Default 1 D6 (DIO6/RTS) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO6/RTS configuration (pin 29). Parameter range 0, 1, 3 - 5 XBee®/XBee-PRO SX RF Module User Guide 96 AT commands I/O settings commands Parameter Description 0 Disabled 1 RTS flow control 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 D7 (DIO7/CTS) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO7/CTS configuration (pin 25). Parameter range 0, 1, 3 - 7 Parameter Description 0 Disabled 1 CTS flow control 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high 6 RS-485 Tx enable, low Tx (0 V on transmit, high when idle) 7 RS-485 Tx enable high, high Tx (high on transmit, 0 V when idle) Default 0x1 D8 (DIO8/SLEEP_REQUEST) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO8/DTR/SLP_RQ configuration (pin 10). This line is also used with Pin Sleep, but pin sleep ignores the D8 configuration. It is always used to control pin sleep, regardless of configuration of D8. Parameter range 0, 1, 3 - 5 XBee®/XBee-PRO SX RF Module User Guide 97 AT commands I/O settings commands Parameter Description 0 Disabled 1 N/A 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high Default 1 D9 (DIO9/ON_SLEEP) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO9/ON_SLEEP configuration (pin 26). Parameter range 0, 1, 3 - 6 Parameter Description 0 Disabled 1 ON/SLEEP output 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high 6 Synchronous pulse output Default 1 P0 (DIO10/RSSI/PWM0 Configuration) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the PWM0/RSSI/DIO10 configuration (pin 7). When configured as a PWM output, you can use M0 to set the PWM duty cycle. Parameter range 0-5 XBee®/XBee-PRO SX RF Module User Guide 98 AT commands I/O settings commands Parameter Description 0 Disabled 1 RSSI PWM0 output 2 PWM0 output 3 Digital input 4 Digital output, low 5 Digital output, high Default 1 P1 (DIO11/PWM1 Configuration) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO11/PWM1 configuration (pin 8). When configured as a PWM1 output, you can use M1 to set the PWM duty cycle. Parameter range 0-5 Parameter Description 0 Disabled 1 32.768 kHz clock output 2 PWM1 output 3 Digital input 4 Digital output, low 5 Digital output, high Default 0 P2 (DIO12 Configuration) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO12 configuration (pin 5). Parameter range 0, 3 - 6 XBee®/XBee-PRO SX RF Module User Guide 99 AT commands I/O settings commands Parameter Description 0 Disabled 1 N/A 2 N/A 3 Digital input 4 Digital output, low 5 Digital output, high 6 RX LED Default 0 P3 (DIO13/DOUT) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO13/DOUT configuration (pin 3). Parameter range 0, 1 Parameter Description 0 Disabled 1 UART DOUT enabled Default 1 P4 (DIO14/DIN) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO14/DIN/CONFIG configuration (pin 4). Sets or displays the DIO14/DIN configuration (pin 4). The device enters Command mode at 9600 baud if you enable DIN and either of the following conditions is met: n A six second serial break is received during normal operation. n DIN is driven low upon power up or reset. The device sends an OK response out of the UART when it enters Command mode in this way. Parameter range 0-1 XBee®/XBee-PRO SX RF Module User Guide 100 AT commands I/O settings commands Parameter Description 0 Disabled 1 UART DIN/CONFIG enabled Default 1 P5 (DIO15/SPI_MISO) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO15/SPI_MISO configuration (pin 17). Parameter range 0, 1, 4, 5 Parameter Description 0 Disabled 1 SPI_MISO 2 N/A 3 N/A 4 Digital output low 5 Digital output high Default 1 P6 (SPI_MOSI) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO16/SPI_MOSI configuration (pin 16). Parameter range 0, 1, 4, 5 Parameter Description 0 Disabled 1 SPI_MOSI 2 N/A 3 N/A XBee®/XBee-PRO SX RF Module User Guide 101 AT commands I/O settings commands Parameter Description 4 Digital output low 5 Digital output, high Default 1 P7 (DIO17/SPI_SSEL ) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO17/SPI_SSEL configuration (pin 15). Parameter range 0, 1, 4, 5 Parameter Description 0 Disabled 1 SPI_SSEL 2 N/A 3 N/A 4 Digital output low 5 Digital output, high Default 1 P8 (DIO18/SPI_SCLK) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO18/SPI_SCLK configuration (pin 14). Parameter range 0, 1, 4, 5 Parameter Description 0 Disabled 1 SPI_SCLK 2 N/A 3 N/A XBee®/XBee-PRO SX RF Module User Guide 102 AT commands I/O settings commands Parameter Description 4 Digital output low 5 Digital output high Default 1 P9 (DIO19/SPI_ATTN) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the DIO19/SPI_ATTN configuration (pin 12). Parameter range 0, 1, 4 - 6 Parameter Description 0 Disabled 1 SPI_ATTN 2 N/A 3 N/A 4 Digital output low 5 Digital output high 6 UART data present indicator Default 1 PD (Pull Direction) This command applies to the XBee/XBee-PRO SX RF Module. The resistor pull direction bit field (1 = pull-up, 0 = pull-down) for corresponding I/O lines that are set by the PR command. Parameter range 0x0 - 0xFFFFF Default 0xFFFFF PR (Pull-up/Down Resistor Enable) This command applies to the XBee/XBee-PRO SX RF Module. PR and PD only affect lines that are configured as digital inputs or disabled. XBee®/XBee-PRO SX RF Module User Guide 103 AT commands I/O settings commands The following table defines the bit-field map for PR and PD commands. The bit field that configures internal pull-up/down resistors status for I/O lines. If you set a PR bit to 1, it enables the internal pull-up/down resistor, 0 specifies no internal pull-up/down. The following table defines the bit-field map for both the PR and PD commands. Bit I/O line Module pin 0 DIO4/AD4 24 1 DIO3/AD3 30 2 DIO2/AD2 31 3 DIO1/AD1 32 4 DIO0/AD0 33 5 DIO6/RTS 29 6 DIO8/SLEEP_REQUEST 9 7 DIO14/DIN/CONFIG 4 8 DIO5/ASSOCIATE 28 9 DIO9/On/SLEEP 26 10 DIO12 5 11 DIO10/RSSI/PWM0 7 12 DIO11/PWM1 8 13 DIO7/CTS 25 14 DIO13/DOUT 3 15 DIO15/SPI_MISO 17 16 DIO16/SPI_MOSI 16 17 DIO17/SPI_SSEL 15 18 DIO18/SPI_SCLK 14 19 DIO19/SPI_ATTN 12 Parameter range 0 - 0xFFFFF (bit field) Default 0xFFFFF M0 (PWM0 Duty Cycle) This command applies to the XBee/XBee-PRO SX RF Module. The duty cycle of the PWM0 line (pin 7). Use the P0 command to configure the line as a PWM output. XBee®/XBee-PRO SX RF Module User Guide 104 AT commands I/O settings commands Parameter range 0 - 0x3FF Default 0 M1 (PWM1 Duty Cycle) This command applies to the XBee/XBee-PRO SX RF Module. The duty cycle of the PWM1 line (pin 8). Use the P1 command to configure the line as a PWM output. Parameter range 0 - 0x3FF Default 0 LT (Associated LED Blink Time) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the Associate LED blink time. If you use the D5 command to enable the Associate LED functionality (DIO5/Associate pin), this value determines the on and off blink times for the LED when the device has joined the network. If LT = 0, the device uses the default blink rate: 500 ms for a sleep coordinator, 250 ms for all other nodes. Parameter range 0x14 - 0xFF (x 10 ms) Default 0 RP (RSSI PWM Timer) This command applies to the XBee/XBee-PRO SX RF Module. The PWM timer expiration in 0.1 seconds. RP sets the duration of pulse width modulation (PWM) signal output on the RSSI pin. The signal duty cycle updates with each received packet and shuts off when the timer expires. When RP = 0xFF, the output is always on. Parameter range 0 - 0xFF (x 100 ms) Default 0x28 (four seconds) XBee®/XBee-PRO SX RF Module User Guide 105 AT commands I/O sampling commands I/O sampling commands The following AT commands configure I/O sampling parameters. AV (Analog Voltage Reference) This command applies to the XBee/XBee-PRO SX RF Module. The analog voltage reference used for A/D sampling. Parameter range 0, 1 Parameter Description 0 1.25 V reference 1 2.5 V reference Default 1 IC (DIO Change Detect) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the digital I/O pins to monitor for changes in the I/O state. IC works with the individual pin configuration commands (D0 - D9, P0 - P2). If you enable a pin as a digital I/O, use the IC command to force an immediate I/O sample transmission when the DIO state changes. If sleep is enabled, the edge transition must occur during a wake period to trigger a change detect. IC is a bitmask you can use to enable or disable edge detection on individual digital I/O lines. Only DIO0 through DIO12 can be sampled using a Change Detect. Set unused bits to 0. Bit I/O line Module pin 0 DIO0 33 1 DIO1 32 2 DIO2 31 3 DIO3 30 4 DIO4 24 5 DIO5 28 6 DIO6 29 7 DIO7 25 8 DIO8 10 XBee®/XBee-PRO SX RF Module User Guide 106 AT commands I/O sampling commands Bit I/O line Module pin 9 DIO9 26 10 DIO10 7 11 DIO11 8 12 DIO12 5 Parameter range 0 - 0xFFFF (bit field) Default 0 IF (Sleep Sample Rate) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the number of sleep cycles that must elapse between periodic I/O samples. This allows the firmware to take I/O samples only during some wake cycles. During those cycles, the firmware takes I/O samples at the rate specified by IR. In addition, setting IF to zero allows I/O samples to occur before the device goes to sleep and to occur thereafter every wake cycle specified by IR. To enable periodic sampling, set IR to a non-zero value, and enable the analog or digital I/O functionality of at least one device pin. The sample rate is measured in milliseconds. For more information, see the following commands: Parameter range 0 - 0xFF Default 1 IR (Sample Rate) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the I/O sample rate to enable periodic sampling. When set, this parameter causes the device to sample all enabled DIO and ADC at a specified interval. To enable periodic sampling, set IR to a non-zero value, and enable the analog or digital I/O functionality of at least one device pin (see D0 (DIO0/AD0) -D9 (DIO9/ON_SLEEP), P0 (DIO10/RSSI/PWM0 Configuration)- P2 (DIO12 Configuration). WARNING! If you set IR to 1 or 2, the device will not keep up and many samples will be lost. Parameter range 0 - 0xFFFF (x 1 ms) XBee®/XBee-PRO SX RF Module User Guide 107 AT commands I/O line passing commands Default 0 IS (Immediate Sample) This command applies to the XBee/XBee-PRO SX RF Module. Immediately forces an I/O sample to be generated. If you issue the command to the local device, the sample data is sent out the local UART. If sent remotely, the sample data is returned as a AT Command Response - 0x88. If the device receives ERROR as a response to an IS query, there are no valid I/O lines to sample. Parameter range N/A Default N/A TP (Board Temperature) This command applies to the XBee/XBee-PRO SX RF Module. The current module temperature in degrees Celsius in 8-bit two’s compliment format. For example 0x1A = 26 °C, and 0xF6 = -10 °C. Parameter range This is a read-only parameter Default N/A %V (Voltage Supply Monitoring) This command applies to the XBee/XBee-PRO SX RF Module. Displays the supply voltage of the device in mV units. Parameter range This is a read-only parameter Default N/A I/O line passing commands The following AT commands are I/O line passing commands. I/O Line Passing allows the digital and analog inputs of a remote device to affect the corresponding outputs of the local device. You can perform Digital Line Passing on any of the Digital I/O lines. Digital Inputs directly map to Digital Outputs of each digital pin. Analog Line Passing can be performed only on the first two ADC lines: XBee®/XBee-PRO SX RF Module User Guide 108 AT commands I/O line passing commands n ADC0 corresponds with PWM0 n ADC1 corresponds with PWM1 IU (I/O Output Enable) This command applies to the XBee/XBee-PRO SX RF Module. Enable or disable I/O data received to be sent out UART/SPI using an API frame when AP = 1 or 2 and when I/O line passing is enabled. Parameter range 0-1 Parameter Description 0 Disabled 1 Enabled Default 1 IA (I/O Input Address) This command applies to the XBee/XBee-PRO SX RF Module. The source address of the device to which outputs are bound. Setting all bytes to 0xFF disables I/O line passing. Setting IA to 0xFFFF allows any I/O packet addressed to this device (including broadcasts) to change the outputs. The source address of the device to which outputs are bound. If an I/O sample is received from the address specified, any pin that is configured as a digital output or PWM changes its state to match that of the I/O sample. Set IA to 0xFFFFFFFFFFFFFFFF to disable I/O line passing. Set IA to 0xFFFF to allow any I/O packet addressed to this device (including broadcasts) to change the outputs. Parameter range 0 - 0xFFFF FFFF FFFF FFFF Default 0xFFFFFFFFFFFFFFFF (I/O line passing disabled) T0 (D0 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D0 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) XBee®/XBee-PRO SX RF Module User Guide 109 AT commands I/O line passing commands Default 0 T1 (D1 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D1 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T2 (D2 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D2 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T3 (D3 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D3 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T4 (D4 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D4 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) XBee®/XBee-PRO SX RF Module User Guide 110 AT commands I/O line passing commands Default 0 T5 (D5 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D5 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T6 (D6 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D6 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T7 (D7 Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D7 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 T8 (D8 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D8 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 XBee®/XBee-PRO SX RF Module User Guide 111 AT commands I/O line passing commands T9 (D9 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin D9 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 Q0 (P0 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin P0 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 Q1 (P1 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin P1 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 Q2 (P2 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin P2 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 XBee®/XBee-PRO SX RF Module User Guide 112 AT commands Sleep commands Q3 (P3 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin P3 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 Q4 (P4 Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long pin P4 holds a given value before it reverts to configured value. If set to 0, there is no timeout. Parameter range 0 - 0x1770 (x 100 ms) Default 0 PT (PWM Output Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Specifies how long both PWM outputs (P0, P1) output a given PWM signal before it reverts to zero. If set to 0, there is no timeout. This timeout only affects these pins when they are configured as PWM output. Parameter range 0 - 0x1770 (x 100 ms) Default 0xFF Sleep commands The following AT commands are sleep commands. SM (Sleep Mode) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the sleep mode of the device. Normal mode is always awake. Pin sleep modes allow you to wake the device with the SLEEP_ REQUEST line. Asynchronous cyclic mode sleeps for SP time and briefly wakes, checking for activity. Sleep Support mode is always awake but can effectively communicate with SM8 nodes. Synchronized Cyclic Sleep nodes sleep for SP and wake for ST time. Synchronous modes are unavailable if BR = 0 and are incompatible with asynchronous modes. XBee®/XBee-PRO SX RF Module User Guide 113 AT commands Sleep commands Parameter range 0, 1, 4, 5, 7, 8 Parameter Description 0 Normal. 1 Asynchronous Pin Sleep. In this mode, the SLEEP_RQ line controls the sleep/wake state of the device. 2 N/A 3 N/A 4 Asynchronous Cyclic Sleep. In this mode, the device periodically sleeps and wakes based on the SP and ST commands. 5 Asynchronous Cyclic Sleep Pin Wake. When you assert the SLEEP_RQ pin, the device enters a cyclic sleep mode similar to Asynchronous Cyclic Sleep. When you de-assert the SLEEP_RQ pin, the device immediately wakes up. The device does not sleep when you de-assert the SLEEP_RQ pin. 6 N/A 7 Sleep Support—this may also be used for synchronous pulse. 8 Synchronized Cyclic Sleep—this may also be used for synchronous pulse. Default 0 SO (Sleep Options) This command applies to the XBee/XBee-PRO SX RF Module. You can set or clear any of the available sleep option bits. You cannot set bit 0 and bit 1 at the same time. Parameter range 0 - 0x13E For synchronous sleep devices, the following sleep bit field options are defined: Bit Option 0 Preferred sleep coordinator; setting this bit causes a sleep compatible device to always act as sleep coordinator 1 Non-sleep coordinator; setting this bit causes a device to never act as a sleep coordinator 2 Enable API sleep status messages 3 Disable early wake-up for missed syncs 4 Enable node type equality (disables seniority based on device type) XBee®/XBee-PRO SX RF Module User Guide 114 AT commands Sleep commands Bit Option 5 Disable coordinator rapid sync deployment mode 8 Always wake for ST time. 10 Enable sync sleep randomize I/O sampling For asynchronous sleep devices, the following sleep bit field options are defined: Bit Option 8 Always wake for ST time 10 Enable sync sleep randomize I/O sampling Default 0x2 (non-sleep coordinator) SN (Number of Cycles Between ON_SLEEP) This command applies to the XBee/XBee-PRO SX RF Module. Set or read the number of sleep periods value. This command controls the number of sleep periods that must elapse between assertions of the ON_SLEEP line during the wake time of Asynchronous Cyclic Sleep. This allows external circuitry to sleep longer than the SP time. During cycles when ON_SLEEP is de-asserted, the device wakes up and checks for any serial or RF data. If it receives any such data, then it asserts the ON_SLEEP line and the device wakes up fully. Otherwise, the device returns to sleep after checking. This command does not work with synchronous sleep devices. Parameter range 1 - 0xFFFF Default 1 Example Set to 1 to set ON_SLEEP high after each SP time (default). If SN = 3, the ON_SLEEP line asserts only every third wakeup; SN = 9, every ninth wakeup; and so forth. SP (Sleep Time) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the device's sleep time. This command defines the amount of time the device sleeps per cycle. A time of 0 is used to indicate no sleep at all and is used for synchronous pulse on DIO9. Parameter range 0 - 0x15F900 (x 10 ms) (4 hours) XBee®/XBee-PRO SX RF Module User Guide 115 AT commands Diagnostic - sleep status/timing commands Default 0x12C (3 seconds) ST (Wake Time) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the wake time of the device. For devices in asynchronous sleep, ST defines the amount of time that a device stays awake after it receives RF or serial data. For devices in synchronous sleep or synchronous pulse, ST defines the amount of time that a device stays awake when operating in cyclic sleep mode. The command adjusts the value upwards automatically if it is too small to function properly based on other settings. For devices in synchronous sleep or synchronous pulse, the minimum wake time is a function of MT, SP, NH, NN, and platform dependent values. If you increase SP, NH, NN, or MT, the ST value raises automatically. The maximum value is one hour (0x36EE80 ms). Parameter range 0x1 - 0x36EE80 (x 1 ms) (one hour) Default 0xD08 (3.3 seconds) WH (Wake Host Delay) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the wake host timer value. You can use WH to give a sleeping host processor sufficient time to power up after the device asserts the ON_SLEEP line. If you set WH to a non-zero value, this timer specifies a time in milliseconds that the device delays after waking from sleep before sending data out the UART or transmitting an I/O sample. If the device receives serial characters, the WH timer stops immediately. When in synchronous sleep, the device shortens its sleep period by the WH value to ensure it is prepared to communicate when the network wakes up. When in this sleep mode, the device always stays awake for the WH time plus the amount of time it takes to transmit a one-hop unicast to another node. Parameter range 0 - 0xFFFF (x 1 ms) Default 0 Diagnostic - sleep status/timing commands The following AT commands are Diagnostic sleep status/timing commands. SS (Sleep Status) This command applies to the XBee/XBee-PRO SX RF Module. Queries a number of Boolean values that describe the device's status. XBee®/XBee-PRO SX RF Module User Guide 116 AT commands Diagnostic - sleep status/timing commands Bit Description 0 This bit is true when the network is in its wake state. 1 This bit is true if the node currently acts as a network sleep coordinator. 2 This bit is true if the node ever receives a valid sync message after it powers on. 3 This bit is true if the node receives a sync message in the current wake cycle. 4 This bit is true if you alter the sleep settings on the device so that the node nominates itself and sends a sync message with the new settings at the beginning of the next wake cycle. 5 This bit is true if you request that the node nominate itself as the sleep coordinator using the Commissioning Pushbutton or the CB2 command. 6 This bit is true if the node is currently in deployment mode. All other bits Reserved. Ignore all non-documented bits. Parameter range N/A [read-only] Default N/A OS (Operating Sleep Time) This command applies to the XBee/XBee-PRO SX RF Module. Reads the current network sleep time that the device is synchronized to, in units of 10 milliseconds. If the device has not been synchronized, then OS returns the value of SP. If the device synchronizes with a sleeping router network, OS may differ from SP. Parameter range N/A Default N/A OW (Operating Wake Time) This command applies to the XBee/XBee-PRO SX RF Module. Reads the current network wake time that a device is synchronized to, in 1 ms units. If the device has not been synchronized, then OW returns the value of ST. If the device synchronizes with a sleeping router network, OW may differ from ST. Parameter range N/A XBee®/XBee-PRO SX RF Module User Guide 117 AT commands Command mode options Default N/A MS (Missed Sync Messages) This command applies to the XBee/XBee-PRO SX RF Module. Reads the number of sleep or wake cycles since the device received a sync message. Parameter range N/A Default N/A SQ (Missed Sleep Sync Count) This command applies to the XBee/XBee-PRO SX RF Module. Counts the number of sleep cycles in which the device does not receive a sleep sync. Set the value to 0 to reset this value. When the value reaches 0xFFFF it does not increment anymore. Parameter range 0 - 0xFFFF Default N/A Command mode options The following commands are Command mode option commands. CC (Command Sequence Character) This command applies to the XBee/XBee-PRO SX RF Module. The character value the device uses to enter Command mode. The default value (0x2B) is the ASCII code for the plus (+) character. You must enter it three times within the guard time to enter Command mode. To enter Command mode, there is also a required period of silence before and after the command sequence characters of the Command mode sequence (GT + CC + GT). The period of silence prevents inadvertently entering Command mode. Parameter range 0 - 0xFF Recommended: 0x20 - 0x7F (ASCII) Default 0x2B (the ASCII plus character: +) XBee®/XBee-PRO SX RF Module User Guide 118 AT commands Firmware version/information commands CT (Command Mode Timeout) This command applies to the XBee/XBee-PRO SX RF Module. Sets or displays the Command mode timeout parameter. If a device does not receive any valid commands within this time period, it returns to Idle mode from Command mode. Parameter range 2 - 0x1770 (x 100 ms) Default 0x64 (10 seconds) CN (Exit Command Mode) This command applies to the XBee/XBee-PRO SX RF Module. Immediately exits Command Mode and applies pending changes. Parameter range N/A Default N/A GT (Guard Times) This command applies to the XBee/XBee-PRO SX RF Module. Set the required period of silence before and after the command sequence characters of the Command mode sequence (GT + CC + GT). The period of silence prevents inadvertently entering Command mode. Parameter range 0x2 - 0x3E8 (x 1 ms) Default 0x3E8 (one second) Firmware version/information commands The following AT commands are firmware version/information commands. VR (Firmware Version) This command applies to the XBee/XBee-PRO SX RF Module. Reads the firmware version on a device. Parameter range 0 - 0xFFFF [read-only] Default Set in the factory XBee®/XBee-PRO SX RF Module User Guide 119 AT commands Firmware version/information commands HV (Hardware Version) This command applies to the XBee/XBee-PRO SX RF Module. Display the hardware version number of the device. Parameter range 0 - 0xFFFF [read-only] Default Set in firmware HS (Hardware Series) This command applies to the XBee/XBee-PRO SX RF Module. Read the device's hardware series number. Parameter range 0 - 0xFFFF [read-only] Default 0x0A00 - set in the firmware DD (Device Type Identifier) This command applies to the XBee/XBee-PRO SX RF Module. Stores the Digi device type identifier value. Use this value to differentiate between multiple XBee devices. Parameter range 0 - 0xFFFFFFFF Default 0xF0000 NP (Maximum Packet Payload Bytes) This command applies to the XBee/XBee-PRO SX RF Module. Reads the maximum number of RF payload bytes that you can send in a transmission. Parameter range 0 - 0xFFFF (bytes) [read-only] Default 0x100 CK (Configuration CRC) This command applies to the XBee/XBee-PRO SX RF Module. Displays the cyclic redundancy check (CRC) of the current AT command configuration settings. XBee®/XBee-PRO SX RF Module User Guide 120 AT commands Firmware version/information commands This command allows you to detect an unexpected configuration change on a device. Use the code that the device returns to determine if a node has the configuration you want. After a firmware update this command may return a different value. Parameter range N/A Default N/A XBee®/XBee-PRO SX RF Module User Guide 121 Operate in API mode API mode overview Use the AP command to set the operation mode API frame format XBee®/XBee-PRO SX RF Module User Guide 123 123 123 122 Operate in API mode API mode overview API mode overview By default, the XBee/XBee-PRO SX RF Module acts as a serial line replacement (Transparent operation), it queues all UART data that it receive through the DI pin for RF transmission. When the device receives an RF packet, it sends the data out the DO pin with no additional information. The following behaviors are inherent to Transparent operation: n If device parameter registers are to be set or queried, a special operation is required for transitioning the device into Command Mode. API operating mode is an alternative to transparent mode. API mode is a frame-based protocol that allows you to direct data on a packet basis. It can be particularly useful in large networks where you need to control the destination of individual data packets or when you need to know which node a data packet was sent from. The device communicates UART data in packets, also known as API frames. This mode allows for structured communications with serial devices. It is helpful in managing larger networks and is more appropriate for performing tasks such as collecting data from multiple locations or controlling multiple devices remotely. Use the AP command to set the operation mode Use AP (API Enable) to specify the operation mode: AP command setting Description AP = 0 Transparent operating mode, UART serial line replacement with API modes disabled. This is the default option. AP = 1 API operation. AP = 2 API operation with escaped characters (only possible on UART). The API data frame structure differs depending on what mode you choose. API frame format An API frame consists of the following: n Start delimeter n Length n Frame data n Checksum API operation (AP parameter = 1) This is the recommended API mode for most applications. The following table shows the data frame structure when you enable this mode: XBee®/XBee-PRO SX RF Module User Guide 123 Operate in API mode API frame format Frame fields Byte Description Start delimiter 1 0x7E Length 2-3 Most Significant Byte, Least Significant Byte Frame data 4 - number (n) API-specific structure Checksum n+1 1 byte Any data received prior to the start delimiter is silently discarded. If the frame is not received correctly or if the checksum fails, the XBee replies with a radio status frame indicating the nature of the failure. API operation with escaped characters (AP parameter = 2) Setting API to 2 allows escaped control characters in the API frame. Due to its increased complexity, we only recommend this API mode in specific circumstances. API 2 may help improve reliability if the serial interface to the device is unstable or malformed frames are frequently being generated. When operating in API 2, if an unescaped 0x7E byte is observed, it is treated as the start of a new API frame and all data received prior to this delimiter is silently discarded. For more information on using this API mode, see the Escaped Characters and API Mode 2 in the Digi Knowledge base. API escaped operating mode works similarly to API mode. The only difference is that when working in API escaped mode, the software must escape any payload bytes that match API frame specific data, such as the start-of-frame byte (0x7E). The following table shows the structure of an API frame with escaped characters: Frame fields Byte Description Start delimiter 1 0x7E Length 2-3 Most Significant Byte, Least Significant Byte Characters escaped if needed Frame data 4-n API-specific structure Checksum n+1 1 byte Escaped characters in API frames If operating in API mode with escaped characters (AP parameter = 2), when sending or receiving a serial data frame, specific data values must be escaped (flagged) so they do not interfere with the data frame sequencing. To escape an interfering data byte, insert 0x7D and follow it with the byte to be escaped (XOR'ed with 0x20). The following data bytes need to be escaped: n 0x7E: start delimiter n 0x7D: escape character n 0x11: XON n 0x13: XOFF To escape a character: 1. Insert 0x7D (escape character). 2. Append it with the byte you want to escape, XOR'ed with 0x20. XBee®/XBee-PRO SX RF Module User Guide 124 Operate in API mode API frame format In API mode with escaped characters, the length field does not include any escape characters in the frame and the firmware calculates the checksum with non-escaped data. Example: escape an API frame To express the following API non-escaped frame in API operating mode with escaped characters: Frame Data Start delimiter Length Frame type Checksum Data 7E 00 0F 17 01 00 13 A2 00 40 AD 14 2E FF FE 02 4E 49 6D You must escape the 0x13 byte: 1. Insert a 0x7D. 2. XOR byte 0x13 with 0x20: 13 ⊕20 = 33 The following figure shows the resulting frame. Note that the length and checksum are the same as the non-escaped frame. Frame Data Start delimiter Length Frame type Checksum Data 7E 00 0F 17 01 00 7D 33 A2 00 40 AD 14 2E FF FE 02 4E 49 6D The length field has a two-byte value that specifies the number of bytes in the frame data field. It does not include the checksum field. Length field The length field is a two-byte value that specifies the number of bytes contained in the frame data field. It does not include the checksum field. Frame data This field contains the information that a device receives or will transmit. The structure of frame data depends on the purpose of the API frame: Frame data Start delimiter Length Frame type 1 2 3 4 0x7E MSB LSB API frame type Checksum Data 5 6 7 8 Data 9 ... n n+1 Single byte n Frame type is the API frame type identifier. It determines the type of API frame and indicates how the Data field organizes the information. n Data contains the data itself. This information and its order depend on the what type of frame that the Frame type field defines. Multi-byte values are sent big-endian. Calculate and verify checksums To calculate the checksum of an API frame: XBee®/XBee-PRO SX RF Module User Guide 125 Operate in API mode API frame format 1. Add all bytes of the packet, except the start delimiter 0x7E and the length (the second and third bytes). 2. Keep only the lowest 8 bits from the result. 3. Subtract this quantity from 0xFF. To verify the checksum of an API frame: 1. Add all bytes including the checksum; do not include the delimiter and length. 2. If the checksum is correct, the last two digits on the far right of the sum equal 0xFF. Example Consider the following sample data packet: 7E 00 0A 01 01 50 01 00 48 65 6C 6C 6F B8+ Byte(s) Description 7E Start delimiter 00 0A Length bytes 01 API identifier 01 API frame ID 50 01 Destination address low 00 Option byte 48 65 6C 6C 6F Data packet B8 Checksum To calculate the check sum you add all bytes of the packet, excluding the frame delimiter 7E and the length (the second and third bytes): 7E 00 0A 01 01 50 01 00 48 65 6C 6C 6F B8 Add these hex bytes: 01 + 01 + 50 + 01 + 00 + 48 + 65 + 6C + 6C + 6F = 247 Now take the result of 0x247 and keep only the lowest 8 bits which in this example is 0x47 (the two far right digits). Subtract 0x47 from 0xFF and you get 0xB8 (0xFF - 0x47 = 0xB8). 0xB8 is the checksum for this data packet. If an API data packet is composed with an incorrect checksum, the XBee/XBee-PRO SX RF Module will consider the packet invalid and will ignore the data. To verify the check sum of an API packet add all bytes including the checksum (do not include the delimiter and length) and if correct, the last two far right digits of the sum will equal FF. 01 + 01 + 50 + 01 + 00 + 48 + 65 + 6C + 6C + 6F + B8 = 2FF XBee®/XBee-PRO SX RF Module User Guide 126 API frames The following sections document API frame types. API frame exchanges Code to support future API frames 64-bit Transmit Request - 0x00 Local AT Command Request - 0x08 Queue Local AT Command Request - 0x09 Transmit Request - 0x10 Explicit Addressing Command Request - 0x11 Remote AT Command Request - 0x17 Secure Remote AT Command Request frame - 0x18 Modem Status - 0x8A Extended Transmit Status - 0x8B Route Information - 0x8D Aggregate Addressing Update - 0x8E 64-bit Receive Packet - 0x80 Local AT Command Response - 0x88 Transmit Status - 0x89 Receive Packet - 0x90 Explicit Receive Indicator - 0x91 Node Identification Indicator - 0x95 Remote AT Command Response- 0x97 XBee®/XBee-PRO SX RF Module User Guide 128 130 131 133 135 137 140 144 147 150 152 154 156 158 160 162 164 166 168 171 127 API frames API frame exchanges API frame exchanges Every outgoing API frame has a corresponding response (or ACK) frame that indicates the success or failure of the outgoing API frame. This section details some of the common API exchanges that occur. You can use the Frame ID field to correlate between the outgoing frames and associated responses. Note Using a Frame ID of 0 disables responses, which can reduce network congestion for non-critical transmissions. AT commands The following image shows the API frame exchange that takes place on the serial interface (UART or SPI) when you send a 0x08 AT Command Request or 0x09 AT Command-Queue Request to read or set a device parameter. To disable the 0x88 AT Command Response, set the frame ID to 0 in the request. Transmit and Receive RF data The following image shows the API exchanges that take place on the serial interface when a device sends a 0x10, or 0x11 Transmit Request to another device. The device sends the 0x8B Transmit Status frame at the end of a data transmission unless you set the frame ID to 0 in the transmit request. If the packet cannot be delivered to the destination, the 0x8B Transmit Status frame indicates the cause of failure. Use the AO command to choose the type of data frame you want to receive, either a (0x90) RX Indicator frame or a (0x91) Explicit Rx Indicator frame. XBee®/XBee-PRO SX RF Module User Guide 128 API frames API frame exchanges Remote AT commands The following image shows the API frame exchanges that take place on the serial interface when you send a 0x17 Remote AT Command frame The 0x97 Remote AT Command Response is always generated and you can use it to identify if the remote device successfully received and applied the command. Device Registration The following image shows the API frame exchanges that take place at the serial interface when registering a joining device to a trust center. XBee®/XBee-PRO SX RF Module User Guide 129 API frames Code to support future API frames Code to support future API frames If your software application supports the API, you should make provisions that allow for new API frames in future firmware releases. For example, you can include the following section of code on a host microprocessor that handles serial API frames that are sent out the device's DOUT pin: void XBee_HandleRxAPIFrame(_apiFrameUnion *papiFrame){ switch(papiFrame->api_id){ case RX_RF_DATA_FRAME: //process received RF data frame break; case RX_IO_SAMPLE_FRAME: //process IO sample frame break; case NODE_IDENTIFICATION_FRAME: //process node identification frame break; default: //Discard any other API frame types that are not being used break; } } XBee®/XBee-PRO SX RF Module User Guide 130 API frames 64-bit Transmit Request - 0x00 64-bit Transmit Request - 0x00 Response frame: Transmit Status - 0x89 Description This frame type is used to send serial payload data as an RF packet to a remote device with a corresponding 64-bit IEEE address. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Transmit Request - 0x10 to initiate API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 64-bit Transmit Request - 0x00 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. 5 64-bit Destination address Set to the 64-bit IEEE address of the destination device. If set to 0x000000000000FFFF, the broadcast address is used. 13 8-bit Options A bit field of options that affect the outgoing transmission: n Bit 0: Disable MAC ACK [0x01] n Bit 1: Reserved (set to 0) n Bit 2: Send packet with Broadcast PAN ID [0x04] l 802.15.4 firmwares only Note Option values may be combined. Set all unused bits to 0. 14-n variable RF data The serial data to be sent to the destination. Use NP to query the maximum payload size that can be supported based on current settings. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XBee®/XBee-PRO SX RF Module User Guide 131 API frames 64-bit Transmit Request - 0x00 Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast Sending a unicast transmission to a device with the 64-bit address of 0013A20012345678 with the serial data "TxData". The corresponding Transmit Status - 0x89 response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 11 00 52 00 13 A2 00 12 34 56 78 00 54 78 44 61 74 61 9E Frame type Frame ID 64-bit dest address Tx options RF data 0x00 0x52 0x0013A200 12345678 0x00 0x547844617461  Input Matches response "TxData" 64-bit broadcast Sending a broadcast transmission of the serial data "Broadcast" and suppressing the corresponding response by setting Frame ID to 0. 7E 00 14 00 00 00 00 00 00 00 00 FF FF 00 42 72 6F 61 64 63 61 73 74 6E Frame type Frame ID 64-bit dest address Tx options RF data 0x00 0x00 0x00000000 0000FFFF 0x00 0x42726F616463617374 Input Suppress response Broadcast address XBee®/XBee-PRO SX RF Module User Guide "Broadcast" 132 API frames Local AT Command Request - 0x08 Local AT Command Request - 0x08 Response frame: Local AT Command Response - 0x88 Description This frame type is used to query or set command parameters on the local device. Any parameter that is set with this frame type will apply the change immediately. If you wish to queue multiple parameter changes and apply them later, use the Queue Local AT Command Request - 0x09 instead. When querying parameter values, this frame behaves identically to Queue Local AT Command Request - 0x09: You can query parameter values by sending this frame with a command but no parameter value field—the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Local AT Command Response - 0x88 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x88 response is the same one set by the command in the 0x08 request frame. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Local AT Command Request - 0x08 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to0, the device will not emit a response frame. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set the local command parameter Set the NI string of the radio to "End Device". The corresponding Local AT Command Response - 0x88 with a matching Frame ID will indicate whether the parameter change succeeded. XBee®/XBee-PRO SX RF Module User Guide 133 API frames Local AT Command Request - 0x08 7E 00 0E 08 A1 4E 49 45 6E 64 20 44 65 76 69 63 65 38 Frame type Frame ID AT command Parameter value 0x08 0xA1 0x4E49 0x456E6420446576696365 Request Matches response "NI" "End Device" Query local command parameter Query the temperature of the module—TP command. The corresponding Local AT Command Response - 0x88 with a matching Frame ID will return the temperature value. 7E 00 04 08 17 54 50 3C Frame type Frame ID AT command Parameter value 0x08 0x17 0x5450 (omitted) Request Matches response "TP" Query the parameter XBee®/XBee-PRO SX RF Module User Guide 134 API frames Queue Local AT Command Request - 0x09 Queue Local AT Command Request - 0x09 Response frame: Local AT Command Response - 0x88 Description This frame type is used to query or set queued command parameters on the local device. In contrast to Local AT Command Request - 0x08, this frame queues new parameter values and does not apply them until you either: n Issue a Local AT Command using the 0x08 frame n Issue an AC command—queued or otherwise When querying parameter values, this frame behaves identically to Local AT Command Request - 0x08: You can query parameter values by sending this frame with a command but no parameter value field—the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Local AT Command Response - 0x88 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x88 response is the same one set by the command in the 0x09 request frame. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Queue Local AT Command Request - 0x09 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to0, the device will not emit a response frame. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register at a later time. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. XBee®/XBee-PRO SX RF Module User Guide 135 API frames Queue Local AT Command Request - 0x09 Queue setting local command parameter Set the UART baud rate to 115200, but do not apply changes immediately. The device will continue to operate at the current baud rate until the change is applied with a subsequent AC command. The corresponding Local AT Command Response - 0x88 with a matching Frame ID will indicate whether the parameter change succeeded. 7E 00 05 09 53 42 44 07 16 Frame type Frame ID AT command Parameter value 0x09 0x53 0x4244 0x07 Request Matches response "BD" 7 = 115200 baud Query local command parameter Query the temperature of the module (TP command). The corresponding Local AT Command Response - 0x88 frame with a matching Frame ID will return the temperature value. 7E 00 04 09 17 54 50 3B Frame type Frame ID AT command Parameter value 0x09 0x17 0x5450 (omitted) Request Matches response "TP" Query the parameter XBee®/XBee-PRO SX RF Module User Guide 136 API frames Transmit Request - 0x10 Transmit Request - 0x10 Response frame: Extended Transmit Status - 0x8B Description This frame type is used to send payload data as an RF packet to a specific destination. This frame type is typically used for transmitting serial data to one or more remote devices. The endpoints used for these data transmissions are defined by the SE and EP commands and the cluster ID defined by the CI command—excluding 802.15.4. To define the application-layer addressing fields on a per-packet basis, use the Explicit Addressing Command Request - 0x11 instead. Query the NP command to read the maximum number of payload bytes that can be sent. 64-bit addressing n For broadcast transmissions, set the 64-bit destination address to 0x000000000000FFFF n For unicast transmissions, set the 64-bit address field to the address of the desired destination node Format The following table provides the contents of the frame. For details on the frame structure, see API frame format. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Transmit Request - 0x10 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response frame. If set to 0, the device will not emit a response frame. 5 64-bit 64-bit destination address Set to the 64-bit IEEE address of the destination device. Broadcast address is 0x000000000000FFFF. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 15 8-bit Broadcast radius Sets the maximum number of hops a broadcast transmission can traverse. This parameter is only used for broadcast transmissions. If set to0—recommended—the value of NHspecifies the broadcast radius. 16 8-bit Transmit See the Transmit options bit field table below for available XBee®/XBee-PRO SX RF Module User Guide 137 API frames Offset Transmit Request - 0x10 Size Frame Field Description options options. If set to 0, the value of TO specifies the transmit options. 17-n variable Payload data Data to be sent to the destination device. Up to NP bytes per packet. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Transmit options bit field The available transmit options vary depending on the protocol being used. Bitfield options can be combined. Set all unused bits to 0. 0 Disable ACK [0x01] Disable acknowledgments on all unicasts. 1 Disable route discoveries [0x02] Disable Route Discovery on all DigiMesh unicasts. 2 Unicast NACK [0x04] Enable unicast NACK messages on DigiMesh transmissions When set, a failed transmission will generate a Route Information 0x8D frame for diagnosis. 3 Unicast trace route [0x08] Enable a unicast Trace Route on DigiMesh transmissions When set, the transmission will generate a Route Information 0x8D frame. 5 Reserved 6,7 Delivery method b’00 = If BR = 0 then packet type will be Point-multipoint otherwise it will be DigiMesh b’01 = Point-multipoint [0x40] b’10 = Repeater mode, Directed Broadcast [0x80] b’11 = DigiMesh—not available when BR = 0 [0xC0] Examples Each example is written without escapes (AP=1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast Sending a unicast transmission to a device with the 64-bit address of 0013A20012345678 with the serial data "TxData". Transmit options are set to 0, which means the transmission will send using the options set by the TO command. The corresponding Transmit Status - 0x89 response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 14 10 52 00 13 A2 00 12 34 56 78 FF FE 00 00 54 78 44 61 74 61 91 XBee®/XBee-PRO SX RF Module User Guide 138 API frames Transmit Request - 0x10 Frame type Frame ID 64-bit dest Reserved Bcast radius Options RF data 0x10 0x52 0x0013A200 12345678 0xFFFE 0x00 0x00 0x547844617461  Request Matches response Destination Unused N/A Will use TO "TxData" 64-bit broadcast Sending a broadcast transmission of the serial data "Broadcast" to neighboring devices and suppressing the corresponding response by setting Frame ID to 0. 7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 01 00 42 72 6F 61 64 63 61 73 74 60 Reserved Bcast radius Tx Options RF data 0x00000000 0000FFFF 0xFFFE 0x01 0x00 0x42726F616463617374 Broadcast address Unused Single hop broadcast Will use TO "Broadcast" Frame type Frame ID 64-bit dest 0x10 0x00 Request Suppress response XBee®/XBee-PRO SX RF Module User Guide 139 API frames Explicit Addressing Command Request - 0x11 Explicit Addressing Command Request - 0x11 Response frame: Extended Transmit Status - 0x8B Description This frame type is used to send payload data as an RF packet to a specific destination using application-layer addressing fields. The behavior of this frame is similar to Transmit Request 0x10, but with additional fields available for user-defined endpoints, cluster ID, and profile ID. This frame type is typically used for OTA updates, and serial data transmissions. Query NP (Maximum Packet Payload Bytes) to read the maximum number of payload bytes that can be sent. 64-bit addressing n For broadcast transmissions, set the 64-bit destination address to 0x000000000000FFFF n For unicast transmissions, set the 64-bit address field to the address of the desired destination node Reserved endpoints For serial data transmissions, the 0xE8 endpoint should be used for both source and destination endpoints. The active Digi endpoints are: n 0xE8 - Digi Data endpoint n 0xE6 - Digi Device Object (DDO)  endpoint Reserved cluster IDs For serial data transmissions, the 0x0011 cluster ID should be used. The following cluster IDs can be used on the 0xE8 data endpoint: n 0x0011- Transparent data cluster ID n 0x0012 - Loopback cluster ID:The destination node echoes any transmitted packet back to the source device. Cannot be used on XBee 802.15.4 firmware. Reserved profile IDs The Digi profile ID of 0xC105 should be used when sending serial data between XBee devices. Format The following table provides the contents of the frame. For details on the frame structure, see API frame specifications. XBee®/XBee-PRO SX RF Module User Guide 140 API frames Explicit Addressing Command Request - 0x11 Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Explicit Addressing Command Request - 0x11 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to0, the device will not emit a response frame. 5 64-bit 64-bit destination address Set to the 64-bit IEEE address of the destination device. Broadcast address is 0x000000000000FFFF. When using 16-bit addressing, set this field to 0xFFFFFFFFFFFFFFFF. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 15 8-bit Source Endpoint Source endpoint for the transmission. Serial data transmissions should use 0xE8. 16 8-bit Destination Endpoint Destination endpoint for the transmission. Serial data transmissions should use 0xE8. 17 16-bit Cluster ID The Cluster ID that the host uses in the transmission. Serial data transmissions should use 0x11. 19 16-bit Profile ID The Profile ID that the host uses in the transmission. Serial data transmissions between XBee devices should use 0xC105. 21 8-bit Broadcast radius Sets the maximum number of hops a broadcast transmission can traverse. This parameter is only used for broadcast transmissions. If set to 0 (recommended), the value of NH specifies the broadcast radius. 22 8-bit Transmit options See the Transmit options bit field table below for available options. If set to 0, the value of TO specifies the transmit options. 23-n variable Command data Data to be sent to the destination device. Up to NP bytes per packet. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Transmit options bit field The available transmit options vary depending on the protocol being used. Bitfield options can be combined. Set all unused bits to 0. 0 Disable ACK [0x01] Disable acknowledgments on all unicasts. XBee®/XBee-PRO SX RF Module User Guide 141 API frames Explicit Addressing Command Request - 0x11 1 Disable route discoveries [0x02] Disable Route Discovery on all DigiMesh unicasts. 2 Unicast NACK [0x04] Enable unicast NACK messages on DigiMesh transmissions When set, a failed transmission will generate a Route Information 0x8D frame for diagnosis. 3 Unicast trace route [0x08] Enable a unicast Trace Route on DigiMesh transmissions When set, the transmission will generate a Route Information 0x8D frame. 5 Reserved 6,7 Delivery method b’00 = If BR = 0 then packet type will be Point-multipoint otherwise it will be DigiMesh b’01 = Point-multipoint [0x40] b’10 = Repeater mode, Directed Broadcast [0x80] b’11 = DigiMesh—not available when BR = 0 [0xC0] Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast Sending a unicast transmission to an XBee device with the 64-bit address of 0013A20012345678 with the serial data "TxData". Transmit options are set to 0, which means the transmission will send using the options set by the TO command. This transmission is identical to a Transmit Request - 0x10 using default settings. The corresponding Extended Transmit Status - 0x8B response with a matching Frame ID will indicate whether the transmission succeeded. 7E 00 1A 11 87 00 13 A2 00 12 34 56 78 FF FE E8 E8 00 11 C1 05 00 00 54 78 44 61 74 61 B4 Fram e type Frame ID 64-bit dest 0x11 0x87 0x0013A2 0xFFFE 00 12345678 Explici t reque st Matche Destinati s on respon se Reserv ed Unused Sourc Des Clust e EP t EP er Bcast Tx Profil radiu optio e s ns Command data 0xE8 0xE 8 0x001 1 0xC10 0x00 5 0x00 0x547844617 461  Digi data Digi dat a Data Digi N/A profile Use TO "TxData" Loopback Packet Sending a loopback transmission to an device with the 64-bit address of 0013A20012345678 using Cluster ID 0x0012. To better understand the raw performance, retries and acknowledgements are disabled. XBee®/XBee-PRO SX RF Module User Guide 142 API frames Explicit Addressing Command Request - 0x11 The corresponding Extended Transmit Status - 0x8B response with a matching Frame ID can be used to verify that the transmission was sent. The destination will not emit a receive frame, instead it will return the transmission back to the sender. The source device will emit the receive frame—the frame type is determined by the value of AO—if the packet looped back successfully. 7E 00 1A 11 F8 00 13 A2 00 12 34 56 78 FF FE E8 E8 00 12 C1 05 00 01 54 78 44 61 74 61 41 Fram e type Frame ID 64-bit dest 0x11 0xF8 0x0013A2 0xFFFE 00 12345678 Explici t reque st Matche Destinati s on respon se Reserv ed Unused XBee®/XBee-PRO SX RF Module User Guide Sourc Des Clust e EP t EP er Bcast Tx Profil radiu optio e s ns Command data 0xE8 0xE 8 0x001 2 0xC10 0x00 5 0x01 0x547844617 461  Digi data Digi dat a Data Digi N/A profile Disabl e retries "TxData" 143 API frames Remote AT Command Request - 0x17 Remote AT Command Request - 0x17 Response frame: Remote AT Command Response- 0x97 Description This frame type is used to query or set AT command parameters on a remote device. For parameter changes on the remote device to take effect, you must apply changes, either by setting the Apply Changes options bit, or by sending an AC command to the remote. When querying parameter values you can query parameter values by sending this framewith a command but no parameter value field—the two-byte AT command is immediately followed by the frame checksum. When an AT command is queried, a Remote AT Command Response- 0x97 frame is populated with the parameter value that is currently set on the device. The Frame ID of the 0x97 response is the same one set by the command in the 0x17 request frame. Note Remote AT Command Requests should only be issued as unicast transmissions to avoid potential network disruption. Broadcasts are not acknowledged, so there is no guarantee all devices will receive the request. Responses are returned immediately by all receiving devices, which can cause congestion on a large network. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Remote AT Command Request - 0x17. 4 8-bit Frame ID Identifies the data frame for the host to correlate with a subsequent response. If set to 0, the device will not emit a response frame. 5 64-bit 64-bit destination address Set to the 64-bit IEEE address of the destination device. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 15 8-bit Remote command options Bit field of options that apply to the remote AT command request: n Bit 0: Disable ACK [0x01] n Bit 1: Apply changes on remote [0x02] l XBee®/XBee-PRO SX RF Module User Guide If not set, changes will not applied until the device receives an AC command or a subsequent 144 API frames Offset Remote AT Command Request - 0x17 Size Frame Field Description command change is received with this bit set n Bit 2: Reserved (set to 0) n Bit 3: Reserved (set to 0) n Bit 4: Send the remote command securely [0x10] Note Option values may be combined. Set all unused bits to 0. 16 16-bit AT command The two ASCII characters that identify the AT Command. 18-n variable Parameter value (optional) If present, indicates the requested parameter value to set the given register. If no characters are present, it queries the current parameter value and returns the result in the response. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes—AP = 1—and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set remote command parameter Set the NI string of a device with the 64-bit address of 0013A20012345678 to "Remote" and apply the change immediately. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will indicate success. 7E 00 15 17 27 00 13 A2 00 12 34 56 78 FF FE 02 4E 49 52 65 6D 6F 74 65 F6 Frame type Frame ID 64-bit dest Reserved Command options AT command Parameter value 0x17 0x27 0x0013A200 12345678 0xFFFE 0x02 0x4E49 0x52656D6F7465 Request Matches response Unused Apply Change "NI" "Remote" Queue remote command parameter change Change the PAN ID of a remote device so it can migrate to a new PAN, since this change would cause network disruption, the change is queued so that it can be made active later with a subsequent AC command or written to flash with a queued WR command so the change will be active after a power cycle. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will indicate success. 7E 00 11 17 68 00 13 A2 00 12 34 56 78 FF FE 00 49 44 04 51 D8 XBee®/XBee-PRO SX RF Module User Guide 145 API frames Remote AT Command Request - 0x17 Frame type Frame ID 64-bit dest Reserved Command options AT command Parameter value 0x17 0x68 0x0013A200 12345678 0xFFFE 0x00 0x4944 0x0451 Request Matches response Unused Queue Change "ID" Query remote command parameter Query the temperature of a remote device—TP command. The corresponding Remote AT Command Response- 0x97 with a matching Frame ID will return the temperature value. 7E 00 0F 17 FA 00 13 A2 00 12 34 56 78 FF FE 00 54 50 84 Frame type Frame ID 64-bit dest Reserved Command options AT command Parameter value 0x17 0xFA 0x0013A200 12345678 0xFFFE 0x00 0x5450 (omitted) Request Matches response Unused N/A "TP" Query the parameter XBee®/XBee-PRO SX RF Module User Guide 146 API frames Secure Remote AT Command Request frame - 0x18 Secure Remote AT Command Request frame - 0x18 Description The 0x18 frame is like the 0x17 frame except that it requires a password to function; See KZ (Remote AT Command Password). Use this frame to securely send remote AT commands. The frame requires a correct password to be included as part of the 0x18 command. If KZ is set: n The 0x17 frame fails. n The 0x18 frame only works if it includes the correct password and encryption is enabled. n Remote commands from other nodes are only accepted if they were sent from a node which also had KZ set. If KZ is not set: n You may send 0x17 frames. n You may send the 0x18 frame with the password field set with ASCII 0. Format The following table provides the contents of the frame. For details on frame structure, see API frame format. Frame data fields Offset Description Frame type 3 0x18 Frame ID 4 Identifies the frame to correlate with a subsequent remote command response (0x97). Password Length 5 Specifies how many bytes are in the Password field to follow. Does not include the Length byte itself. Password 6 The password itself. 64-bit destination address 7+password length The 64-bit address of the destination node which is receiving this command, MSB first, LSB last. Reserved 15+password length This field is unused for DigiMesh, but it can be used in protocols that support 16-bit addresses, for example Zigbee. For DigiMesh, the value of these two bytes does not matter. Command Options 17+password length If bit 1 is set (0x02), the remote node immediately applies changes in the AT command. If bit 1 is clear, you must send an AC command for the change to take effect. AT Command 18+password length Command name: two ASCII characters that identify the command. XBee®/XBee-PRO SX RF Module User Guide 147 API frames Secure Remote AT Command Request frame - 0x18 Frame data fields Offset Description Command Parameter 20+password length If present, indicates the parameter value you request for a given register. If no characters are present, it queries the register. Numeric parameter values are given in binary format. Example The following table shows an example frame to send a secure remote AT command to a node at address 0x0013a200 12345678 to set the baud rate to 07, which translates to 115,200 b/s. If the password configured with the KZ command is Nugget, encryption is enabled with EE, and the receiving node is also password protected for remote commands, the baud rate change will apply immediately. Frame data fields Offset Example Start delimiter 0 0x7E Length 1 0x00 (MSB) 2 0x17 (LSB) Frame type 3 0x18 Frame ID 4 0x01 Password Length 5 0x06 Password 6 0x4E (N) 7 0x75 (u) 8 0x67 (g) 9 0x67 (g) 10 0x65 (e) 11 0x74 (t) 12 0x00 (MSB) 13 0x13 14 0xA2 15 0x00 16 0x12 17 0x34 18 0x56 19 0X78 (LSB) 64-bit destination address XBee®/XBee-PRO SX RF Module User Guide 148 API frames Secure Remote AT Command Request frame - 0x18 Frame data fields Offset Example Reserved 20 0xFF 21 0xFE Command Options 22 0x02 (apply changes) AT Command 23 0x42 (B) 24 0x44 (D) Command Parameter 25 0x07 Checksum 26 0x21 XBee®/XBee-PRO SX RF Module User Guide 149 API frames Modem Status - 0x8A Modem Status - 0x8A Description This frame type is emitted in response to specific conditions. The status field of this frame indicates the device behavior. Format Frame Field Offset Size 0 8-bit 1 16-bit Length 3 8-bit Frame type Modem Status - 0x8A 4 8-bit Modem status Start Delimiter Description Indicates the start of an API frame. Number of bytes between the length and checksum. Complete list of modem statuses: 0x00 = Hardware reset or power up 0x01 = Watchdog timer reset 0x02 = Joined network 0x03 = Left network 0x06 = Coordinator started 0x07 = Network security key was updated 0x0B = Network woke up 0x0C = Network went to sleep 0x0D = Voltage supply limit exceeded 0x0E = Digi Remote Manager connected 0x0F = Digi Remote Manager disconnected 0x11 = Modem configuration changed while join in progress 0x12 = Access fault 0x13 = Fatal error 0x3B = Secure session successfully established 0x3C = Secure session ended 0x3D = Secure session authentication failed 0x3E = Coordinator detected a PAN ID conflict but took no action 0x3F = Coordinator changed PAN ID due to a conflict 0x32 = BLE Connect 0x33 = BLE Disconnect 0x34 = Bandmask configuration failed 0x35 = Cellular component update started 0x36 = Cellular component update failed 0x37 = Cellular component update completed 0x38 = XBee firmware update started 0x39 = XBee firmware update failed 0x3A = XBee firmware update applying 0x40 = Router PAN ID was changed by coordinator due to a conflict 0x42 = Network Watchdog timeout expired 0x80 through 0xFF = Stack error XBee®/XBee-PRO SX RF Module User Guide 150 API frames Offset Modem Status - 0x8A Size Frame Field Description Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Statuses for specific modem types are listed here. Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Boot status When a device powers up, it returns the following API frame: 7E 00 02 8A 00 75 Frame type Modem Status 0x8A 0x00 Status Hardware Reset XBee®/XBee-PRO SX RF Module User Guide 151 API frames Extended Transmit Status - 0x8B Extended Transmit Status - 0x8B Request frames: n Transmit Request - 0x10 n Explicit Addressing Command Request - 0x11 Description This frame type is emitted when a network transmission request completes. The status field of this frame indicates whether the request succeeded or failed and the reason. This frame type provides additional networking details about the transmission. This frame is only emitted if the Frame ID in the request is non-zero. Note Broadcast transmissions are not acknowledged and always return a status of 0x00, even if the delivery failed. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Transmit Status - 0x8B 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 7 8-bit Transmit retry count The number of application transmission retries that occur. 8 8-bit Delivery status Complete list of delivery statuses: 0x00 = Success 0x01 = MAC ACK failure 0x02 = CCA/LBT failure 0x03 = Indirect message unrequested / no spectrum available 0x21 = Network ACK failure 0x25 = Route not found 0x31 = Internal resource error 0x32 = Resource error lack of free buffers, timers, etc. 0x74 = Data payload too large 0x75 = Indirect message unrequested 9 8-bit Discovery Complete list of delivery statuses: XBee®/XBee-PRO SX RF Module User Guide 152 API frames Offset Extended Transmit Status - 0x8B Size Frame Field status EOF 8-bit Checksum XBee®/XBee-PRO SX RF Module User Guide Description 0x00 = No discovery overhead 0x02 = Route discovery 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). 153 API frames Route Information - 0x8D Route Information - 0x8D Request frames: n Transmit Request - 0x10 n Explicit Addressing Command Request - 0x11 Description This frame type contains the DigiMesh routing information for a remote device on the network. This route information can be used to diagnose marginal links between devices across multiple hops. This frame type is emitted in response to a DigiMesh unicast transmission request which has Trace Routing or NACK enabled. See Trace route option and NACK messages for more information. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Route Information - 0x8D 4 8-bit Source event Event that caused the route information to be generated: 0x11 = NACK 0x12 = Trace route 5 8-bit Data length 6 32-bit Timestamp System timer value on the node generating the Route Information Packet.The timestamp is in microseconds. Only use this value for relative time measurements because the time stamp count restarts approximately every hour. 10 8-bit ACK timeout count The number of MAC ACK timeouts that occur. 11 8-bit TX blocked count The number of times the transmission was blocked due to reception in progress. 12 8-bit Reserved Not used. 14 64-bit Destination address The 64-bit IEEE address of the final destination node of this network-level transmission. 21 64-bit Source The 64-bit IEEE address of the source node of this network-level XBee®/XBee-PRO SX RF Module User Guide The number of bytes that follow, excluding the checksum. If the length increases, new items have been added to the end of the list for future revisions. 154 API frames Offset Route Information - 0x8D Size Frame Field Description address transmission. 29 64-bit Responder address The 64-bit IEEE address of the node that generates this Route Information packet after it sends (or attempts to send) the data packet to the next hop (the Receiver node). 37 64-bit Receiver address The 64-bit IEEE address of the node that the device sends (or attempts to send) the data packet. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Checksum Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Routing information The following example represents a possible Route Information Packet. A device emits this frame when it performs a trace route enabled transmission from one device—serial number 0x0013A200 4052AAAA—to another—serial number 0x0013A200 4052DDDD—across a DigiMesh network. This particular frame indicates that the network successfully forwards the transmission from one device—serial number 0x0013A200 4052BBBB—to another device—serial number 0x0013A200 4052CCCC. 7E 00 2A 8D 12 27 6B EB CA 93 00 00 00 00 13 A2 00 40 52 DD DD 00 13 A2 00 40 52 AA AA 00 13 A2 00 40 52 BB BB 00 13 A2 00 40 52 CC CC 4E Sour Fra ce Data me even leng Timesta type t th mp 0x8D 0x12 Rout e Trace Rout e 0x27 ACK time out 0x6BEBC 0x00 A93 ~30 minutes XBee®/XBee-PRO SX RF Module User Guide TX Block Reser ed ved 0x00 No No retries error this hop Dest Source Responde address address r address Receive r address 0x00 0x0013A 200 4052DD DD 0x0013A 200 4052CC CC N/A Destinat Source ion 0x0013A 0x0013A20 200 0 4052AA 4052BBBB AA Node that sent this inform ation Next hop 155 API frames Aggregate Addressing Update - 0x8E Aggregate Addressing Update - 0x8E Description This frame type is emitted on devices that update it addressing information in response to a network aggregator issuing an addressing update. A network aggregator is defined by a device on the network who has had the AG (Aggregator Support) command issued. A device on the network who's current DH and DL matches the address provided in the AG command request will update DH and DL and emit this frame. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Field Offset Size 0 8-bit 1 16-bit Length 3 8-bit Frame type Aggregate Addressing Update - 0x8E 4 8-bit Reserved 5 64-bit New address Address to which DH and DL are being set. 13 64-bit Old address Address to which DH and DL were previously set. EOF 8-bit 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Start Delimiter Checksum Description Indicates the start of an API frame. Number of bytes between the length and checksum. Reserved for future functionality. This field returns 0. Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Aggregate address update In the following example, a device with destination address (DH/DL) of 0x0013A200 4052AAAA updates its destination address to 0x0013A200 4052BBBB. 7E 00 12 8E 00 00 13 A2 00 40 52 BB BB 00 13 A2 00 40 52 AA AA 19 XBee®/XBee-PRO SX RF Module User Guide 156 API frames Aggregate Addressing Update - 0x8E Frame type Reserved New address Old address 0x8E 0x00 0x0013A200 4052BBBB 0x0013A200 4052AAAA Update N/A What DH/DL is now set to What DH/DL was set to XBee®/XBee-PRO SX RF Module User Guide 157 API frames 64-bit Receive Packet - 0x80 64-bit Receive Packet - 0x80 Request frames: n Transmit Request - 0x10 n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a device configured with legacy API output—AO (API Options) = 2— receives an RF data packet from a device configured to use 64-bit source addressing—MY = 0xFFFE. Note This frame format is deprecated and should only be used by customers who require compatibility with legacy Digi RF products. For new designs, we encourage you to use Receive Packet 0x90 for reception of API transmissions. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Field Offset Size Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type 64-bit Receive Packet - 0x80 4 64-bit 64-bit source address The sender's 64-bit IEEE address. 12 8-bit RSSI Received Signal Strength Indicator. The Hexadecimal equivalent of (-dBm) value. For example if RX signal strength is -40 dBm, then 0x28 (40 decimal) is returned. 13 8-bit Options Bit field of options that apply to the received message: n Bit 0: Reserved n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: 802.15.4 only - Packet was broadcast across all PANs [0x04] Note Option values may be combined. 14-n variable RF data XBee®/XBee-PRO SX RF Module User Guide The RF payload data that the device receives. 158 API frames 64-bit Receive Packet - 0x80 Offset Size Frame Field EOF 8-bit Checksum Description 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast A device with the 64-bit address of 0013A20087654321 sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO = 2. 7E 00 11 80 00 13 A2 00 12 34 56 78 5E 01 54 78 44 61 74 61 11 Frame type 64-bit source RSSI Rx options Received data 0x80 0x0013A200 87654321 0x5E 0x01 0x547844617461  -94 dBm ACK was sent "TxData" Output XBee®/XBee-PRO SX RF Module User Guide 159 API frames Local AT Command Response - 0x88 Local AT Command Response - 0x88 Request frames: n Local AT Command Request - 0x08 n Queue Local AT Command Request - 0x09 Description This frame type is emitted in response to a local AT Command request. Some commands send back multiple response frames; for example, ND (Network Discover). Refer to individual AT command descriptions for details on API response behavior. This frame is only emitted if the Frame ID in the request is non-zero. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Local AT Command Response - 0x88 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 16-bit AT command The two ASCII characters that identify the AT Command. 7 8-bit Command status Status code for the host's request: 0 = OK 1 = ERROR 2 = Invalid command 3 = Invalid parameter 8-n variable Command data (optional) If the host requested a command parameter change, this field will be omitted. If the host queried a command by omitting the parameter value in the request, this field will return the value currently set on the device. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. XBee®/XBee-PRO SX RF Module User Guide 160 API frames Local AT Command Response - 0x88 Set local command parameter Host set the NI string of the local device to "End Device" using a 0x08 request frame. The corresponding Local AT Command Response - 0x88 with a matching Frame ID is emitted as a response: 7E 00 05 88 01 4E 49 00 DF Frame type Frame ID AT command Command Status Command data 0x88 0xA1 0x4E49 0x00 (omitted) Response Matches request "NI" Success Parameter changes return no data Query local command parameter Host queries the temperature of the local device—TP command—using a 0x08 request frame. The corresponding Local AT Command Response - 0x88 with a matching Frame ID is emitted with the temperature value as a response: 7E 00 07 88 01 54 50 00 FF FE D5 Frame type Frame ID AT command Command Status Command data 0x88 0x17 0x5450 0x00 0xFFFE Response Matches request "TP" Success -2 °C XBee®/XBee-PRO SX RF Module User Guide 161 API frames Transmit Status - 0x89 Transmit Status - 0x89 Request frames: n 64-bit Transmit Request - 0x00 n 16-bit Transmit Request - 0x01 Description This frame type is emitted when a transmit request completes. The status field of this frame indicates whether the request succeeded or failed and the reason. This frame is only emitted if the Frame ID in the request is non-zero. Note Broadcast transmissions are not acknowledged and always return a status of 0x00, even if the delivery failed. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Frame Field Offset Size 0 8-bit 1 16-bit Length 3 8-bit Frame type Transmit Status - 0x89 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 8-bit Delivery status Complete list of delivery statuses: 0x00 = Success 0x01 = No ACK received 0x02 = CCA failure 0x03 = Indirect message unrequested 0x04 = Transceiver was unable to complete the transmission 0x21 = Network ACK failure 0x22 = Not joined to network 0x2C = Invalid frame values (check the phone number) 0x31 = Internal error 0x32 = Resource error - lack of free buffers, timers, etc. 0x34 = No Secure Session Connection 0x35 = Encryption Failure 0x74 = Message too long 0x76 = Socket closed unexpectedly 0x78 = Invalid UDP port 0x79 = Invalid TCP port Start Delimiter Description Indicates the start of an API frame. Number of bytes between the length and checksum. XBee®/XBee-PRO SX RF Module User Guide 162 API frames Offset Transmit Status - 0x89 Size Frame Field Description 0x7A = Invalid host address 0x7B = Invalid data mode 0x7C = Invalid interface. 0x7D = Interface not accepting frames. 0x7E = A modem update is in progress. Try again after the update is complete. 0x80 = Connection refused 0x81 = Socket connection lost 0x82 = No server 0x83 = Socket closed 0x84 = Unknown server 0x85 = Unknown error 0x86 = Invalid TLS configuration (missing file, and so forth) 0x87 = Socket not connected 0x88 = Socket not bound Refer to the tables below for a filtered list of status codes that are appropriate for specific devices. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Delivery status codes Protocol-specific status codes follow Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Successful transmission Host sent a unicast transmission to a remote device using a 64-bit Transmit Request - 0x00 frame. The corresponding 0x89 Transmit Status with a matching Frame ID is emitted as a response to the request: 7E 00 03 89 52 00 24 Frame type Frame ID Delivery status 0x89 0x52 0x00 Response Matches request Success XBee®/XBee-PRO SX RF Module User Guide 163 API frames Receive Packet - 0x90 Receive Packet - 0x90 Request frames: n Transmit Request - 0x10 n Explicit Addressing Command Request - 0x11 Description This frame type is emitted when a device configured with standard API output—AO (API Options) = 0— receives an RF data packet. Typically this frame is emitted as a result of a device on the network sending serial data using the Transmit Request - 0x10 or Explicit Addressing Command Request - 0x11 addressed either as a broadcast or unicast transmission. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Receive Packet - 0x90 4 64-bit 64-bit source address The sender's 64-bit address. 12 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 14 8-bit Receive options Bit field of options that apply to the received message: XBee®/XBee-PRO SX RF Module User Guide Description n Bit 0: Packet was Acknowledged [0x01] n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: Reserved n Bit 3: Reserved n Bit 4: Reserved n Bit 5: Reserved n Bit 6: Reserved n Bit 6, 7: DigiMesh delivery method l b’00 = l b’01 = Point-multipoint [0x40] l b’10 = Directed Broadcast [0x80] l b’11 = DigiMesh [0xC0] 164 API frames Offset Receive Packet - 0x90 Size Frame Field Description Note Option values may be combined. 15-n variable Received data The RF payload data that the device receives. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast A device with the 64-bit address of 0013A20041AEB54E sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO = 0. 7E 00 12 90 00 13 A2 00 41 AE B5 4E FF FE C1 54 78 44 61 74 61 C4 Frame type 64-bit source Reserved Rx options Received data 0x90 0x0013A200 41AEB54E 0x5614 0xC1 0x547844617461  Unused ACK was sent in DigiMesh mode "TxData" Output XBee®/XBee-PRO SX RF Module User Guide 165 API frames Explicit Receive Indicator - 0x91 Explicit Receive Indicator - 0x91 Request frames: n Transmit Request - 0x10 n Explicit Addressing Command Request - 0x11 Description This frame type is emitted when a device configured with explicit API output—AO (API Options) bit1 set—receives a packet. Typically this frame is emitted as a result of a device on the network sending serial data using the Transmit Request - 0x10 or Explicit Addressing Command Request - 0x11 addressed either as a broadcast or unicast transmission. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Explicit Receive Indicator - 0x91 4 64-bit 64-bit source The sender's 64-bit address. address 12 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 14 8-bit Source endpoint Endpoint of the source that initiated transmission. 15 8-bit Destination endpoint Endpoint of the destination that the message is addressed to. 16 16-bit Cluster ID The Cluster ID that the frame is addressed to. 18 16-bit Profile ID The Profile ID that the fame is addressed to. 20 8-bit Receive options Bit field of options that apply to the received message for packets sent using Digi endpoints (0xDC-0xEE): XBee®/XBee-PRO SX RF Module User Guide n Bit 0: Packet was Acknowledged [0x01] n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: Reserved n Bit 3: Reserved n Bit 4: Reserved 166 API frames Offset Explicit Receive Indicator - 0x91 Size Frame Field Description n Bit 5: Reserved n Bit 6: Reserved n Bit 6, 7: DigiMesh delivery method l b’00 = l b’01 = Point-multipoint [0x40] l b’10 = Directed Broadcast [0x80] l b’11 = DigiMesh [0xC0] Note Option values may be combined. 21-n variable Received data The RF payload data that the device receives. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. 64-bit unicast A device with the 64-bit address of 0013A20087654321 sent a unicast transmission to a specific device with the payload of "TxData". The following frame is emitted if the destination is configured with AO > 1. 7E 00 18 91 00 13 A2 00 41 AE B5 4E FF FE E8 E8 00 11 C1 05 C1 54 78 44 61 74 61 1C Frame type 64-bit source 0x91 0x0013A200 0x87BD 41AEB54E Unused Explicit output Source Reserved EP XBee®/XBee-PRO SX RF Module User Guide Dest EP Cluster Profile Rx options 0xE8 0xE8 0x0011 0xC105 0xC1 0x54784461746 1  Digi data Digi data Data Digi profile ACK was sent in DigiMesh network "TxData" Received data 167 API frames Node Identification Indicator - 0x95 Node Identification Indicator - 0x95 Description This frame type is emitted when a node identification broadcast is received. The node identification indicator contains information about the identifying device, such as address, identifier string (NI), and other relevant data. A node identifies itself to the network under these conditions: n The commissioning button is pressed once. n A CB 1 command is issued. n A synchronous sleep node stays awake for 30 seconds in order to receive a sync message. It also sends out an identifying message. See ND (Network Discover) for information on the payload formatting. See NO (Network Discovery Options) for configuration options that modify the output of this frame. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Node Identification Indicator - 0x95 4 64-bit 64-bit source address The sender's 64-bit address. 12 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 14 8-bit Options Bit field of options that apply to the received message: XBee®/XBee-PRO SX RF Module User Guide n Bit 0: Packet was Acknowledged [0x01] n Bit 1: Packet was sent as a broadcast [0x02] n Bit 2: Reserved n Bit 4: Reserved n Bit 5: Reserved n Bit 6, 7: DigiMesh delivery method l b’00 = l b’01 = Point-multipoint [0x40] l b’10 = Directed Broadcast [0x80] l b’11 = DigiMesh [0xC0] 168 API frames Offset Node Identification Indicator - 0x95 Size Frame Field Description Note Option values may be combined. 15 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 17 64-bit 64-bit remote address The 64-bit address of the device that sent the Node Identification. 25 variable (2-byte minimum) Node identification string Node identification string on the remote device set by NI (Node Identifier). The identification string is terminated with a NULL byte (0x00). 27+NI 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 29+NI 8-bit Network device type What type of network device the remote identifies as: 0 = Coordinator 1 = Router 2 = End Device 30+NI 8-bit Source event The event that caused the node identification broadcast to be sent. 0 = Reserved 1 = Frame sent by node identification pushbutton event—see D0 (DIO0/AD0). 31+NI 16-bit Digi Profile ID The Digi application Profile ID—0xC105. 33+NI 16-bit Digi Manufacturer ID The Digi Manufacturer ID—0x101E. 35+NI 32-bit Device type identifier (optional) The user-defined device type on the remote device set by DD (Device Type Identifier). Only included if the receiving device has the appropriate NO (Network Discovery Options) bit set. EOF-1 8-bit RSSI (optional) The RSSI of the last hop that relayed the message. Only included if the receiving device has the appropriate NO (Network Discovery Options) bit set. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte—between length and checksum. Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Identify remote device A technician is replacing a DigiMesh device in the field and needs to have the its entry removed from a cloud server's database. The technician pushes the commissioning button on the old device once to send an identification broadcast. The server can use the broadcast to identify which device is being replaced and perform the necessary action. When the node identification broadcast is sent, every device that receives the message will flash the association LED and emit the following information frame: XBee®/XBee-PRO SX RF Module User Guide 169 API frames Node Identification Indicator - 0x95 7E 00 27 95 00 13 A2 00 12 34 56 78 FF FE C2 FF FE 00 13 A2 00 12 34 56 78 4C 48 37 35 00 FF FE 01 01 C1 05 10 1E 00 14 00 08 0D Frame type 64-bit source 0x95 0x0013A 0xFFFE 0xC2 200 1234567 8 Identifica tion Reser ved Unuse d Option 64-bit s remote DigiMe sh broadc ast XBee®/XBee-PRO SX RF Module User Guide NI String Reser ved Devi ce type 0x0013A 0x4C48373 0xFFFE 0x01 200 5 00 1234567 8 "LH75" + null Unuse d Rout er Eve nt Profi MFG  le ID ID 0x01 0xC1 05 Butt Digi on press 0x10 1E Digi 170 API frames Remote AT Command Response- 0x97 Remote AT Command Response- 0x97 Request frame: Remote AT Command Request - 0x17 Description This frame type is emitted in response to a Remote AT Command Request - 0x17. Some commands send back multiple response frames; for example, the ND command. Refer to individual AT command descriptions for details on API response behavior. This frame is only emitted if the Frame ID in the request is non-zero. Format The following table provides the contents of the frame. For details on frame structure, see API frame specifications. Offset Size Frame Field Description 0 8-bit Start Delimiter Indicates the start of an API frame. 1 16-bit Length Number of bytes between the length and checksum. 3 8-bit Frame type Remote AT Command Response - 0x97 4 8-bit Frame ID Identifies the data frame for the host to correlate with a prior request. 5 64-bit 64-bit source address The sender's 64-bit address. 13 16-bit Reserved Unused, but this field is typically set to 0xFFFE. 15 16-bit AT command The two ASCII characters that identify the AT Command. 17 8-bit Command status Status code for the host's request: 0x00 = OK 0x01 = ERROR 0x02 = Invalid command 0x03 = Invalid parameter 0x04 = Transmission failure 0x0C = Encryption error 18-n variable Parameter value (optional) If the host requested a command parameter change, this field will be omitted. If the host queried a command by omitting the parameter value in the request, this field will return the value currently set on the device. EOF 8-bit Checksum 0xFF minus the 8-bit sum of bytes from offset 3 to this byte (between length and checksum). XBee®/XBee-PRO SX RF Module User Guide 171 API frames Remote AT Command Response- 0x97 Examples Each example is written without escapes (AP = 1) and all bytes are represented in hex format. For brevity, the start delimiter, length, and checksum fields have been excluded. Set remote command parameter Host set the NI string of a remote device to "Remote" using a Remote AT Command Request - 0x17. The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted as a response: 7E 00 0F 97 27 00 13 A2 00 12 34 56 78 12 7E 4E 49 00 51 Frame type Frame ID 0x97 0x27 Response Matches request 64-bit source 0x0013A200 12345678 Reserved AT command Command Status Command data 0x127E 0x4E49 0x00 (omitted) Unused "NI" Success Parameter changes return no data Transmission failure Host queued the the PAN ID change of a remote device using a Remote AT Command Request - 0x17. Due to existing network congestion, the host will retry any failed attempts. The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted as a response: 7E 00 0F 97 27 00 13 A2 00 12 34 56 78 FF FE 49 44 04 EA Frame type Frame ID 0x97 0x27 Response Matches request 64-bit source 0x0013A200 12345678 Reserved AT command Command Status Command data 0xFFFE 0x4944 0x04 (omitted) Unused "ID" Transmission failure Parameter changes return no data Query remote command parameter Query the temperature of a remote device—TP (Board Temperature). The corresponding 0x97 Remote AT Command Response with a matching Frame ID is emitted with the temperature value as a response: 7E 00 11 97 27 00 13 A2 00 12 34 56 78 FF FE 54 50 00 00 2F A8 XBee®/XBee-PRO SX RF Module User Guide 172 API frames Remote AT Command Response- 0x97 Frame type Frame ID 0x97 0x27 Response Matches request 64-bit source Reserved 0x0013A200 12345678 XBee®/XBee-PRO SX RF Module User Guide AT command Command Status Command data 0x0013A200 12345678 0x4944 0x00 0x002F Unused "TP" Success +47 °C 173 Work with networked devices Network commissioning and diagnostics Local configuration Remote configuration Secure remote AT commands Establish and maintain network links Test links in a network - loopback cluster Test links between adjacent devices XBee®/XBee-PRO SX RF Module User Guide 175 175 175 176 178 180 180 174 Work with networked devices Network commissioning and diagnostics Network commissioning and diagnostics We call the process of discovering and configuring devices in a network for operation, "network commissioning." Devices include several device discovery and configuration features. In addition to configuring devices, you must develop a strategy to place devices to ensure reliable routes. To accommodate these requirements, modules include features to aid in placing devices, configuring devices, and network diagnostics. Local configuration You can configure devices locally using serial commands in Transparent or API mode, or remotely using remote API commands. Devices that are in API mode can send configuration commands to set or read the configuration settings of any device in the network. Remote configuration When you do not have access to the device's serial port, you can use a separate device in API mode to remotely configure it. To remotely configure devices, use the following steps. Send a remote command To send a remote command, populate the Remote AT Command Request - 0x17 with: 1. The 64-bit address of the remote device. 2. The correct command options value. 3. Optionally, the command and parameter data. 4. If you want a command response, set the Frame ID field to a non-zero value. The firmware only supports unicasts of remote commands. You cannot broadcast remote commands. XCTU has a Frames Generator tool that can assist you with building and sending a remote AT frame; see Frames generator tool in the XCTU User Guide. Apply changes on remote devices When you use remote commands to change the command parameter settings on a remote device, you must apply the parameter changes or they do not take effect. For example, if you change the BD parameter, the actual serial interface rate does not change on the remote device until you apply the changes. You can apply the changes using remote commands in one of three ways: 1. Set the apply changes option bit in the API frame. 2. Send an AC command to the remote device. 3. Send the WR command followed by the FR command to the remote device to save the changes and reset the device. Remote command response If a local device sends a command request to a remote device, and the API frame ID is non-zero, the remote device sends a remote command response transmission back to the local device. When the local device receives a remote command response transmission, it sends a remote command response API frame out its UART. The remote command response indicates: XBee®/XBee-PRO SX RF Module User Guide 175 Work with networked devices Secure remote AT commands 1. The status of the command, which is either success or the reason for failure. 2. In the case of a command query, it includes the register value. The device that sends a remote command does not receive a remote command response frame if: 1. It could not reach the destination device. 2. You set the frame ID to 0 in the remote command request. Secure remote AT commands Configuring a network through remote AT commands is powerful, but it also leaves the door open for configuration mistakes, or worse, malicious actions by an intruder. This is because it is easy to bring a network down through remote AT commands. We introduced secure remote AT commands to protect against such network attacks by requiring the user to enter a correct password with each remote command. How secure remote AT commands protect the network If a network exists without encryption enabled, anyone can introduce a new node into the network, configure the correct network parameters, and operate as a member of the network. Using remote commands, the network could be disabled. If a network exists with encryption enabled, then the above intrusion would not be possible without knowing the KY value. However, this would not prevent the intruder from hijacking a node operating in an encrypted network and using that node (that is already a member of the network with a correct encryption key) to negatively affect the network through remote AT commands. Secure remote AT commands protect against a hijacked device by requiring the correct password to be included with each remote command. Just like the network key, the password cannot be read from the device. Unlike the network key, it must be entered from the serial port for each remote command and the password may or may not be the same for each node in the network. In fact, for extra security (and more difficulty with network management), each node may have a different password. Password protection Enter the password with the KZ command. It is only used locally, which implies that it is not sent over the air. Secure remote AT commands do not offer authentication in the sense of a password being sent to a server which verifies the password. The password is only checked locally. The default password is ASCII 0. In order to set the password on a device, the old password must be followed by the new password. See KZ (Remote AT Command Password). Password recovery Inevitably, someone will be locked out of a node on their own network due to forgetting the password. If this occurs, you can enter RE (Restore Defaults), which restores the password to the default value of 0. Unfortunately, this is not without a side effect: RE also clears the network key. Therefore, you must reenter all network operating parameters, including the network key after sending RE. If both the KY and KZ parameters are forgotten, the only remaining alternative is to enter a new network key for each node in the network. XBee®/XBee-PRO SX RF Module User Guide 176 Work with networked devices Secure remote AT commands Secure remote command control Assuming the password is known, you can use the Secure Remote AT Command Request frame - 0x18 to send secure remote commands and include the known password in that frame. Such frames are free to be effective on any node in the network whether or not that node has a password set to a nondefault value. If the password is not set (KZ is 0), then you can send 0x17 frames the same as they could before the 0x18 frame type was introduced. However such frames will be rejected when sent to any node with the password set (KZ is not 0). Also, if the password is not set, you can send a 0x18 command with the password field set to 0. An undisclosed indicator in the OTA frame tells if the remote AT command is secure or not. This causes the receiving node to reject the incoming remote command if the receiving node has its password set. Security protections In order to harden the network against unauthorized access, several security protections are in place. In this context, a secure node is one which has the password set to a value other than 0, which is the default. Operational rule 0x97 error code 0x17 frames are not sent from a secure node. 0x09 0x18 frames are not sent if encryption is not enabled. 0x0A 0x18 frames are not sent unless the password matches the value given by the KZ command. 0x08 Secure nodes that receive remote AT commands do not execute those commands unless they are sent from a secure node. 0x09 The error code tells which operational rule was broken. Note Encryption must be enabled in order to send secure remote AT commands. Secure a network You can use remote commands to secure an existing network from a single gateway node. To apply KZ (Remote AT Command Password) across a network the entire network must already have encryption enabled. Use the following procedure: 1. Ensure encryption is already enabled on every node in the network. 2. Use Local AT Command Request - 0x08 to configure KZ on the origin node. 3. Use Secure Remote AT Command Request frame - 0x18 frames to set KZ remotely on every node in the network. 4. Keep track of the passwords for all protected devices in a secure manner. Note All gateway devices (any device that will receive 0x18 frames over its serial interface) must be kept physically secure. If an attacker gains physical access to a gateway device, he or she could XBee®/XBee-PRO SX RF Module User Guide 177 Work with networked devices Establish and maintain network links observe the password as it is communicated from the controller to the XBee/XBee-PRO SX RF Module. For the same reason, we recommend using at least two different passwords on a network—one for gateway devices, and one for standalone devices. Software downgrades When software version 9007 is installed, it prohibits a downgrade to the previous version. This rule is in place to protect against the following potential exploit: 1. A device with encryption enabled and a password set is hijacked from an operating network. 2. The intruder knows neither the network key nor the password, which are both stored on the node. 3. The intruder downgrades to the previous version of the firmware, which does not have a KZ command implemented. 4. In the downgrade process, the only parameters saved in flash will be those known by the old firmware loaded. An old firmware knows about KY and EE, but not KZ. Therefore, after the downgrade KY is saved but not KZ. 5. The intruder upgrades back to version 9007. Since KZ is no longer in flash, it reverts to its default value of 0. Since KY is still in flash it is still correct just as it was before the downgrade. 6. The intruder has a node in the network that is encrypted, has the right key, and is not secure. 7. Next, the intruder enters a password that he or she knows. 8. Finally, the intruder can send secure remote AT commands throughout the network, using his or her own password, and defeating the original attempt to secure the network. Reverting to a previous version of the software from version 9007 is prohibited in order to defeat this scenario. Establish and maintain network links Build aggregate routes In many applications, many or all of the nodes in the network must transmit data to a central aggregator node. In a new DigiMesh network, the overhead of these nodes discovering routes to the aggregator node can be extensive and taxing on the network. To eliminate this overhead, you can use the AG command to automatically build routes to an aggregate node in a DigiMesh network. To send a unicast, devices configured for Transparent mode (AP = 0) must set their DH/DL registers to the MAC address of the node that they need to transmit to. In networks of Transparent mode devices that transmit to an aggregator node it is necessary to set every device's DH/DL registers to the MAC address of the aggregator node. This can be a tedious process. A simple and effective method is to use the AG command to set the DH/DL registers of all the nodes in a DigiMesh network to that of the aggregator node. Upon deploying a DigiMesh network, you can send the AG command on the desired aggregator node to cause all nodes in the network to build routes to the aggregator node. You can optionally use the AG command to automatically update the DH/DL registers to match the MAC address of the aggregator node. The AG command requires a 64-bit parameter. The parameter indicates the current value of the DH/DL registers on a device; typically you should replace this value with the 64-bit address of the node sending the AG broadcast. However, if you do not want to update the DH/DL of the device XBee®/XBee-PRO SX RF Module User Guide 178 Work with networked devices Establish and maintain network links receiving the AG broadcast you can use the invalid address of 0xFFFE. The receiving nodes that are configured in API mode output an Aggregator Update API frame (0x8E) if they update their DH/DL address; for a description of the frame, see Aggregate Addressing Update - 0x8E. All devices that receive an AG broadcast update their routing table information to build a route to the sending device, regardless of whether or not their DH/DL address is updated. The devices use this routing information for future DigiMesh unicast transmissions. DigiMesh routing examples Example one: In a scenario where you deploy a network, and then you want to update the DH and DL registers of all the devices in the network so that they use the MAC address of the aggregator node, which has the MAC address 0x0013A200 4052C507, you could use the following technique. 1. Deploy all devices in the network with the default DH/DL of 0xFFFF. 2. Serially, send an ATAGFFFF command to the aggregator node so it sends the broadcast transmission to the rest of the nodes. All the nodes in the network that receive the AG broadcast set their DH to 0x0013A200 and their DL to 0x4052C507. These nodes automatically build a route to the aggregator node. Example two: If you want all of the nodes in the network to build routes to an aggregator node with a MAC address of 0x0013A200 4052C507 without affecting the DH and DL registers of any nodes in the network: 1. Send the ATAGFFFE command to the aggregator node. This sends an AG broadcast to all of the nodes in the network. 2. All of the nodes internally update only their routing table information to contain a route to the aggregator node. 3. None of the nodes update their DH and DL registers because none of the registers are set to the 0xFFFE address. Replace nodes You can use the AG command to update the routing table and DH/DL registers in the network after you replace a device. To update only the routing table information without affecting the DH and DL registers, use the process in example two, above. To update the DH and DL registers of the network, use example three, below. Example three: This example shows how to cause all devices to update their DH and DL registers to the MAC address of the sending device. In this case, assume you are using a device with a serial number of 0x0013A200 4052C507 as a network aggregator, and the sending device has a MAC address of 0x0013A200 F5E4D3B2 To update the DH and DL registers to the sending device's MAC address: 1. Replace the aggregator with 0x0013A200 F5E4D3B2. 2. Send the ATAG0013A200 4052C507 command to the new device. XBee®/XBee-PRO SX RF Module User Guide 179 Work with networked devices Test links in a network - loopback cluster Test links in a network - loopback cluster To measure the performance of a network, you can send unicast data through the network from one device to another to determine the success rate of several transmissions. To simplify link testing, the devices support a Loopback cluster ID (0x12) on the data endpoint (0xE8). The cluster ID on the data endpoint sends any data transmitted to it back to the sender. The following figure demonstrates how you can use the Loopback cluster ID and data endpoint to measure the link quality in a mesh network. The configuration steps for sending data to the loopback cluster ID depend on what mode the device is in. For details on setting the mode, see AP (API Enable). The following sections list the steps based on the device's mode. Transparent operating mode configuration (AP = 0) To send data to the loopback cluster ID on the data endpoint of a remote device: 1. Set the CI command to 0x12. 2. Set the DH and DL commands to the address of the remote device. After exiting Command mode, the device transmits any serial characters it received to the remote device, which returns those characters to the sending device. API operating mode configuration (AP = 1 or AP = 2) Send an Explicit Addressing Command Request - 0x11 using 0x12 as the cluster ID and 0xE8 as both the source and destination endpoint. The remote device echoes back the data packets it receives to the sending device. Test links between adjacent devices It often helps to test the quality of a link between two adjacent modules in a network. You can use the Test Link Request Cluster ID to send a number of test packets between any two devices in a network. To clarify the example, we refer to "device A" and "device B" in this section. To request that device B perform a link test against device A: 1. Use device A in API mode (AP = 1) to send an Explicit Addressing Command (0x11) frame to device B. 2. Address the frame to the Test Link Request Cluster ID (0x0014) and destination endpoint: 0xE6. XBee®/XBee-PRO SX RF Module User Guide 180 Work with networked devices Test links between adjacent devices 3. Include a 12-byte payload in the Explicit Addressing Command frame with the following format: Number of bytes Field name Description 8 Destination address The address the device uses to test its link. For this example, use the device A address. 2 Payload size The size of the test packet. Use the NP command to query the maximum payload size for the device. 2 Iterations The number of packets to send. This must be a number between 1 and 4000. 4. Device B should transmit test link packets. 5. When device B completes transmitting the test link packets, it sends the following data packet to device A's Test Link Result Cluster (0x0094) on endpoint (0xE6). 6. Device A outputs the following information as an API Explicit RX Indicator (0x91) frame: Number of bytes Field name Description 8 Destination address The address the device used to test its link. 2 Payload size The size of the test packet device A sent to test the link. 2 Iterations The number of packets that device A sent. 2 Success The number of packets that were successfully acknowledged. 2 Retries The number of MAC retries used to transfer all the packets. 1 Result 0x00 - the command was successful. 0x03 - invalid parameter used. 1 RR The maximum number of MAC retries allowed. 1 maxRSSI The strongest RSSI reading observed during the test. 1 minRSSI The weakest RSSI reading observed during the test. 1 avgRSSI The average RSSI reading observed during the test. Example Suppose that you want to test the link between device A (SH/SL = 0x0013A200 40521234) and device B (SH/SL=0x0013A 200 4052ABCD) by transmitting 1000 40-byte packets: Send the following API packet to the serial interface of device A. In the following example packet, whitespace marks fields, bold text is the payload portion of the packet: 7E 0020 11 01 0013A20040521234 FFFE E6 E6 0014 C105 00 00 0013A2004052ABCD 0028 03E8 EB XBee®/XBee-PRO SX RF Module User Guide 181 Work with networked devices Test links between adjacent devices When the test is finished, the following API frame may be received: 7E 0027 91 0013A20040521234 FFFE E6 E6 0094 C105 00 0013A2004052ABCD 0028 03E8 03E7 0064 00 0A 50 53 52 9F This means: n 999 out of 1000 packets were successful. n The device made 100 retries. n RR = 10. n maxRSSI = -80 dBm. n minRSSI = -83 dBm. n avgRSSI = -82 dBm. If the Result field does not equal zero, an error has occurred. Ignore the other fields in the packet. If the Success field equals zero, ignore the RSSI fields. The device that sends the request for initiating the Test link and outputs the result does not need to be the sender or receiver of the test. It is possible for a third node, "device C", to request device A to perform a test link against device B and send the results back to device C to be output. It is also possible for device B to request device A to perform the previously mentioned test. In other words, the frames can be sent by either device A, device B or device C and in all cases the test is the same: device A sends data to device B and reports the results. RSSI indicators The received signal strength indicator (RSSI) measures the amount of power present in a radio signal. It is an approximate value for signal strength received on an antenna. You can use the DB command to measure the RSSI on a device. DB returns the RSSI value measured in -dBm of the last packet the device received. This number can be misleading in multi-hop DigiMesh networks. The DB value only indicates the received signal strength of the last hop. If a transmission spans multiple hops, the DB value provides no indication of the overall transmission path, or the quality of the worst link, it only indicates the quality of the last link. To determine the DB value in hardware: 1. Use the RSSI module pin (pin 7). When the device receives data, it sets the RSSI PWM duty cycle to a value based on the RSSI of the packet it receives. This value only indicates the quality of the last hop of a multi-hop transmission. You could connect this pin to an LED to indicate if the link is stable or not. Discover all the devices on a network You can use the ND (Network Discovery) command to discover all devices on a network. When you send the ND command: 1. The device sends a broadcast ND command through the network. 2. All devices that receive the command send a response that includes their addressing information, node identifier string and other relevant information. For more information on the node identifier string, see NI (Node Identifier). ND is useful for generating a list of all device addresses in a network. XBee®/XBee-PRO SX RF Module User Guide 182 Work with networked devices Test links between adjacent devices When a device receives the network discovery command, it waits a random time before sending its own response. You can use the NT command to set the maximum time delay on the device that you use to send the ND command. n The device that sends the ND includes its NT setting in the transmission to provide a delay window for all devices in the network. n The default NT value is 0x82 (13 seconds). Discover devices within RF range n You can use the FN (Find Neighbors) command to discover the devices that are immediate neighbors (within RF range) of a particular device. n FN is useful in determining network topology and determining possible routes. You can send FN locally on a device in Command mode or you can use a local Local AT Command Request - 0x08. To use FN remotely, send the target node a Remote AT Command Request - 0x17 using FN as the name of the AT command. The device you use to send FN transmits a zero-hop broadcast to all of its immediate neighbors. All of the devices that receive this broadcast send an RF packet to the device that transmitted the FN command. If you sent FN remotely, the target devices respond directly to the device that sent the FN command. The device that sends FN outputs a response packet in the same format as an Local AT Command Response - 0x88. Trace route option In many networks, it is useful to determine the route that a DigiMesh unicast takes to its destination; particularly, when you set up a network or want to diagnose problems within a network. Note Because of the large number of Route Information Packet frames that a unicast with trace route enabled can generate, we suggest you only use the trace route option for occasional diagnostic purposes and not for normal operations. The Transmit Request (0x10) frame contains a trace route option, which transmits routing information packets to the originator of the unicast using the intermediate nodes. When a device sends a unicast with the trace route option enabled, the unicast transmits to its destination devices, which forward the unicast to its eventual destination. The destination device transmits a Route Information Packet (0x8D) frame back along the route to the unicast originator. The Route Information Packet frame contains: n Addressing information for the unicast. n Addressing information for the intermediate hop. n Other link quality information. For a full description of the Route Information Packet frame, see Route Information - 0x8D. Trace route example Suppose that you successfully unicast a data packet with trace route enabled from device A to device E, through devices B, C, and D. The following sequence would occur: XBee®/XBee-PRO SX RF Module User Guide 183 Work with networked devices Test links between adjacent devices n After the data packet makes a successful MAC transmission from device A to device B, device A outputs a Route Information Packet frame indicating that the transmission of the data packet from device A to device E was successful in forwarding one hop from device A to device B. n After the data packet makes a successful MAC transmission from device B to device C, device B transmits a Route Information Packet frame to device A. When device A receives the Route Information packet, it outputs it over its serial interface. n After the data packet makes a successful MAC transmission from device C to device D, device C transmits a Route Information Packet frame to device A (through device B). When device A receives the Route Information packet, it outputs it over its serial interface. n After the data packet makes a successful MAC transmission from device D to device E, device D transmits a Route Information Packet frame to device A (through device C and device B). When device A receives the Route Information packet, it outputs it over its serial interface. There is no guarantee that Route Information Packet frames will arrive in the same order as the route taken by the unicast packet. On a weak route, it is also possible for the transmission of Route Information Packet frames to fail before arriving at the unicast originator. NACK messages Transmit Request (0x10 and 0x11) frames contain a negative-acknowledge character (NACK) API option (Bit 2 of the Transmit Options field). If you use this option when transmitting data, when a MAC acknowledgment failure occurs on one of the hops to the destination device, the device generates a Route Information Packet (0x8D) frame and sends it to the originator of the unicast. This information is useful because it allows you to identify and repair marginal links. The Commissioning Pushbutton The XBee/XBee-PRO SX RF Module supports a set of commissioning and LED functions to help you deploy and commission devices. These functions include the Commissioning Pushbutton definitions and the associated LED functions. The following diagram shows how the hardware can support these features. XBee®/XBee-PRO SX RF Module User Guide 184 Work with networked devices Test links between adjacent devices To support the Commissioning Pushbutton and its associated LED functions, connect a pushbutton and an LED to device pins 33 and 28 respectively. Definitions To enable the Commissioning Pushbutton functionality on pin 33, set the D0 command to 1. The functionality is enabled by default. You must perform multiple button presses within two seconds. The following table provides the pushbutton definitions. Button presses Sleep configuration and sync status Action 1 Not configured for sleep Immediately sends a Node Identification broadcast transmission. All devices that receive this transmission blink their Associate LED rapidly for one second. All devices in API operating mode that receive this transmission send a Node Identification Indicator frame (0x95) out their UART. 1 Configured for asynchronous sleep Wakes the device for 30 seconds. Immediately sends a Node Identification broadcast transmission. All devices that receive this transmission blink their Associate LED rapidly for one second. All devices in API operating mode that receive this transmission send a Node Identification Indicator frame (0x95) out their UART. 1 Configured for synchronous sleep Wakes the module for 30 seconds or until the synchronized network goes to sleep. Queues a Node Identification broadcast transmission that it sends at the beginning of the next network wake cycle. XBee®/XBee-PRO SX RF Module User Guide 185 Work with networked devices Button presses Sleep configuration and sync status Test links between adjacent devices Action All devices that receive this transmission blink their Associate LED rapidly for one second. All devices in API operating mode that receive this transmission send a Node Identification Indicator frame (0x95) out their UART. 2 Not configured No effect. for synchronous sleep 2 Configured for synchronous sleep Causes a node configured with sleeping router nomination enabled to immediately nominate itself as the network sleep coordinator. For more information, see SO (Sleep Options). 4 Any Sends an RE command to restore device parameters to default values. Use the Commissioning Pushbutton Use the CB command to simulate button presses in software. Send CB with a parameter set to the number of button presses to perform. For example, if you send ATCB1, the device performs the action (s) associated with a single button press. Node Identification Indicator - 0x95 is similar to Remote AT Command Response- 0x97 – it contains the device’s address, node identifier string (NI command), and other relevant data. All devices in API operating mode that receive the Node Identification Indicator frame send it out their UART as a Node Identification Indicator frame. If you enable the Commissioning Pushbutton during sleep, it increases the sleeping current draw, especially in Asynchronous pin sleep (SM = 1) mode. When asleep, hold down the Commissioning Pushbutton for up to two seconds to wake the device from sleep, then issue the two or four button presses. Associate LED The Associate pin (pin 28) provides an indication of the device's sleep status and diagnostic information. To take advantage of these indications, connect an LED to the Associate pin. To enable the Associate LED functionality, set the D5 command to 1; it is enabled by default. If enabled, the Associate pin is configured as an output. This section describes the behavior of the pin. The Associate pin indicates the synchronization status of a sleep compatible XBee/XBee-PRO SX RF Module. If a device is not sleep compatible, the pin functions as a power indicator. Use the LT command to override the blink rate of the Associate pin. If you set LT to 0, the device uses the default blink time: 500 ms for a sleep coordinator, 250 ms otherwise. The following table describes the Associate LED functionality. Sleep mode LED status Meaning 0 On, blinking The device has power and is operating properly XBee®/XBee-PRO SX RF Module User Guide 186 Work with networked devices Test links between adjacent devices Sleep mode LED status Meaning 1, 4, 5 Off The device is in a low power mode 1, 4, 5 On, blinking The device has power, is awake and is operating properly 7 On, solid The network is asleep, or the device has not synchronized with the network, or has lost synchronization with the network 7, 8 On, slow blinking (500 ms blink time) The device is acting as the network sleep coordinator and is operating properly 7, 8 On, fast blinking (250 ms blink time) The device is properly synchronized with the network 8 Off The device is in a low power mode 8 On, solid The device has not synchronized or has lost synchronization with the network Diagnostics support The Associate pin works with the Commissioning Pushbutton to provide additional diagnostic behaviors to aid in deploying and testing a network. If you press the Commissioning Pushbutton once, the device transmits a broadcast Node Identification Indicator (0x95) frame at the beginning of the next wake cycle if the device is sleep compatible, or immediately if the device is not sleep compatible. If you enable the Associate LED functionality using the D5 command, a device that receives this transmission blinks its Associate pin rapidly for one second. XBee®/XBee-PRO SX RF Module User Guide 187 Monitor I/O lines Pin configurations Devices support both analog input and digital I/O line modes on several configurable pins. The following table provides typical parameters for the pin configuration commands (D0 - D9, P0 P2). Pin command parameter Description 0 Unmonitored digital input (disabled) 1 Reserved for pin-specific alternate functionality 2 Analog input (A/D pins) or PWM output (PWM pins) 3 Digital input, monitored 4 Digital output, low 5 Digital output, high 6-9 Alternate functionality, where applicable The following table provides the pin configurations when you set the configuration command for a particular pin. Device pin name Device pin number Configuration command DIO12 5 P2 PWM0 / RSSI / DIO10 7 P0 PWM1 / DIO11 8 P1 DTR / SLEEP_RQ / DIO8 10 D8 DIO4 24 D4 CTS / DIO7 25 D7 ON/SLEEP / DIO9 26 D9 ASSOC / AD5 / DIO5 15 D5 XBee®/XBee-PRO SX RF Module User Guide 188 Monitor I/O lines Pin configurations Device pin name Device pin number Configuration command RTS / DIO6 29 D6 AD3 / DIO3 30 D3 AD2 / DIO2 31 D2 AD1 / DIO1 32 D1 AD0 / DIO0 / Commissioning Pushbutton 33 D0 Use the PR command to enable internal pull up/down resistors for each digital input. Use the PD command to determine the direction of the internal pull up/down resistor. Queried sampling You can use the IS command to query the current state of all digital input and ADC lines on the device. If no inputs are defined, the command returns with an ERROR. If you send the IS command from Command mode, then the device returns a carriage return delimited list containing the following fields. Field Name Description 1 Sample sets Number of sample sets in the packet. Always set to 1. 2 Digital channel mask Indicates which digital I/O lines have sampling enabled. Each bit corresponds to one digital I/O line on the device. bit 0 = AD0/DIO0 bit 1 = AD1/DIO1 bit 2 = AD2/DIO2 bit 3 = AD3/DIO3 bit 4 = DIO4 bit 5 = ASSOC/DIO5 bit 6 = RTS/DIO6 bit 7 = CTS/GPIO7 bit 8 = DTR / SLEEP_RQ / DIO8 bit 9 = ON_SLEEP / DIO9 bit 10 = RSSI/DIO10 bit 11 = PWM/DIO11 bit 12 = CD/DIO12 For example, a digital channel mask of 0x002F means DIO0,1,2,3, and 5 are enabled as digital I/O. 1 Analog channel mask Indicates which lines have analog inputs enabled for sampling. Each bit in the analog channel mask corresponds to one analog input channel. bit 0 = AD0/DIO0 bit 1 = AD1/DIO1 bit 2 = AD2/DIO2 bit 3 = AD3/DIO3 bit 4 = AD4/DIO4 XBee®/XBee-PRO SX RF Module User Guide 189 Monitor I/O lines Field Periodic I/O sampling Name Description bit 5 = ASSOC/AD5/DIO5 Variable Sampled data set If you enable any digital I/O lines, the first two bytes of the data set indicate the state of all enabled digital I/O. Only digital channels that you enable in the Digital channel mask bytes have any meaning in the sample set. If do not enable any digital I/O on the device, it omits these two bytes. Following the digital I/O data (if there is any), each enabled analog channel returns two bytes. The data starts with AIN0 and continues sequentially for each enabled analog input channel up to AIN5. If you issue the IS command using a a local or remote AT Command API frame, then the device returns an AT Command Response (0x88) frame with the I/O data included in the command data portion of the packet. Example Sample AT response 0x01 [1 sample set] 0x0C0C [Digital Inputs: DIO 2, 3, 10, 11 enabled] 0x03 [Analog Inputs: A/D 0, 1 enabled] 0x0408 [Digital input states: DIO 3, 10 high, DIO 2, 11 low] 0x03D0 [Analog input: ADIO 0 = 0x3D0] 0x0124 [Analog input: ADIO 1 =0x120] Periodic I/O sampling Periodic sampling allows a device to take an I/O sample and transmit it to a remote device at a periodic rate. Use the IR command to set the periodic sample rate. n To disable periodic sampling, set IR to 0. n For all other IR values, the firmware samples data when IR milliseconds elapse and the sample data transmits to a remote device. The DH and DL commands determine the destination address of the I/O samples. Only devices with API operating mode enabled send I/O data samples out their serial interface. Devices that are in Transparent mode (AP = 0) discard the I/O data samples they receive. You must configure at least one pin as a digital or ADC input to generate sample data. A device with sleep enabled transmits periodic I/O samples at the IR rate until the ST time expires and the device can resume sleeping. For more information about setting sleep modes, see Sleep modes. Detect digital I/O changes When the network is setup for synchronous sleep there is an option to randomize a single I/O sample by setting SO bit 10—enables random I/O samples—and setting IR to zero where the sample will be randomized over the ST time period. In addition you can use IR in conjunction with SO bit 10 which will randomize the first I/O sample over the IR time period and thereafter I/O samples will occur on XBee®/XBee-PRO SX RF Module User Guide 190 Monitor I/O lines Detect digital I/O changes the IR interval sending x samples or x samples - 1. If the IR interval is greater than the ST time period then ST time will be used to randomize the I/O sample. You can configure devices to transmit a data sample immediately whenever a monitored digital I/O pin changes state. The IC command is a bitmask that you use to set which digital I/O lines to monitor for a state change. If you set one or more bits in IC, the device transmits an I/O sample as soon it observes a state change in one of the monitored digital I/O lines using edge detection. The figure below shows how I/O change detection can work with periodic sampling. In the figure, the gray dashed lines with a dot on top represent samples taken from the monitored DIO line. The top graph shows only IR samples, the bottom graph shows a combination of IR samples and IC (Change Detect). In the top graph, the humps indicate that the sample was not taken at that exact moment and needed to wait for the next IR sample period. Note Use caution when combining Change Detect sampling with sleep modes. IC only causes a sample to be generated if the change takes place during a wake period. If the device is sleeping when the digital input transition occurs, then no change is detected and an I/O sample is not generated. Use IR in conjunction with IC in this instance, since IR generates an I/O sample upon wakeup and ensures that the change is properly observed. XBee®/XBee-PRO SX RF Module User Guide 191 I/O line passing You can configure XBee/XBee-PRO SX RF Modules to perform analog and digital line passing. When a device receives an RF I/O sample data packet, you can set up the receiving device to update any enabled outputs (PWM and DIO) based on the data it receives. Digital I/O lines are mapped in pairs; pins configured as digital input on the transmitting device affect the corresponding digital output pin on the receiving device. For example: DI5 (pin 25) can only update DO5 (pin 25). For Analog Line Passing, the XBee/XBee-PRO SX RF Module has two PWM output pins that simulate the voltage measured by the ADC lines AD0 and AD1. For example, when configured as an ADC, AD0 (pin 33) updates PWM0 (pin 7); AD1 (pin 32) updates PWM1 (pin 8). The default setup is for outputs to not be updated. Instead, a device sends I/O sample data out the serial interface if the device is configured for API mode (AP = 1 or 2). You can use the IU command to disable sample data output. To enable updating the outputs, set the IA (I/O Input Address) parameter with the address of the device that has the appropriate inputs enabled. This effectively binds the outputs to a particular device’s input. This does not affect the ability of the device to receive I/O line data from other devices - only its ability to update enabled outputs. Set the IA parameter to 0xFFFF (broadcast address) to set up the device to accept I/O data for output changes from any device on the network. For line passing to function, the device configured with inputs must generate sample data. Refer to Pin configurations for information on how to configure digital and analog sampling. When outputs are changed from their non-active state, the device can be setup to return the output level to its non-active state. The timers are set using the Tn (Dn Output Timer) and PT (PWM Output Timeout) commands. The timers are reset every time the device receives a valid I/O sample packet with a matching IA address. You can adjust the IC (Change Detect) and IR (Sample Rate) parameters on the transmitting device to keep the outputs set to their active output if the system needs more time than the timers can handle. Configuration example As an example for a simple digital and analog link, you could set a pair of RF devices as follows: Command Description Device A Device B SH Serial Number High 0x0013A200 0x0013A200 SL Serial Number Low 0x12345678 0xABCDABCD DH Destination High 0x0013A200 0x00000000 XBee®/XBee-PRO SX RF Module User Guide 192 I/O line passing Configuration example Command Description Device A Device B DL Destination Low 0xABCDABCD 0x0000FFFF (broadcast) IA I/O Input Address 0x0013A200ABCDABCD 0x0013A20012345678 IR Sample Rate 0x7D0 (2 seconds) 0 (disabled) IC DIO Change Detect 0 (disabled) 0x1000 (DIO3 only) D1 DIO1/AD1 2 : ADC input N/A P1 DIO11/PWM1 N/A 2: PWM1 output PT PWM Output Timeout N/A 0x1E (3 seconds) D2 DIO2/AD2 3: Digital input 5: Digital output, HIGH D3 DIO3/AD3 5: Digital output, HIGH 3: Digital input T3 DIO3 Timeout 0x64 (10 seconds) N/A Command Description Device A Device B SH Serial Number High 0x0013A200 0x0013A200 SL Serial Number Low 0x12345678 0xABCDABCD DH Destination High 0x0013A200 0x00000000 DL Destination Low 0xABCDABCD 0x0000FFFF (broadcast) IA I/O Input Address 0x0013A200ABCDABCD 0x0013A20012345678 IR Sample Rate 0x7D0 (2 seconds) 0 (disabled) IC DIO Change Detect 0 (disabled) 0x8 (DIO3 only) D1 DIO1/AD1 2 : ADC input N/A P1 DIO11/PWM1 N/A 2: PWM1 output PT PWM Output Timeout N/A 0x1E (3 seconds) D2 DIO2/AD2 3: Digital input 5: Digital output, HIGH D3 DIO3/AD3 5: Digital output, HIGH 3: Digital input T3 DIO3 Timeout 0x64 (10 seconds) N/A In the example, both devices have I/O Line Passing enabled with appropriate inputs and outputs configured. The IA parameter determines which device on the network is allowed to affect the device’s outputs. Device A takes a periodic sample of all I/O lines every two seconds and transmits it as a unicast transmission to the address defined by DH and DL (in this case, Device B). Device B does not periodically sample, instead it monitors DIO3 for a binary change. When it detects a change on that pin, it generates a sample and transmits it as a broadcast to all devices on the network. When Device B receives a sample packet from Device A: XBee®/XBee-PRO SX RF Module User Guide 193 I/O line passing Configuration example n DIO2 on Device B outputs the state of DIO2 from Device A. n PWM1 outputs a duty cycle equivalent to the analog voltage read on AD1 of Device A. n A PWM timeout has been set to three seconds; if no sample is received, PWM1 returns to 0 V after this period. When Device A receives a sample packet from Device B: n DIO3 on Device A outputs the state of DIO3 from Device B. n A DIO3 timeout has been set to 10 seconds; if no sample is received, DIO3 reverts to a HIGH state after this period. Note By default, all Digital I/O lines have internal pull-up resistors enabled with the PR command. This causes inputs to float high. You can use the PD command to change the direction of the internal pull-up/down resistors. The XBee/XBee-PRO SX RF Module uses an internal reference voltage of 2.5 V for ADC lines, but you can use the AV command to set it to 1.25 VDC. XBee®/XBee-PRO SX RF Module User Guide 194 General Purpose Flash Memory General Purpose Flash Memory Access General Purpose Flash Memory General Purpose Flash Memory commands XBee®/XBee-PRO SX RF Module User Guide 196 196 197 195 General Purpose Flash Memory General Purpose Flash Memory General Purpose Flash Memory XBee/XBee-PRO SX RF Modules provides 119 512-byte blocks of flash memory that an application can read and write to. This memory provides a non-volatile data storage area that an application uses for many purposes. Some common uses of this data storage include: n Storing logged sensor data n Buffering firmware update data for a host microcontroller n Storing and retrieving data tables needed for calculations performed by a host microcontroller The General Purpose Memory (GPM) is also used to store a firmware update file for over-the-air firmware updates of the device itself. Access General Purpose Flash Memory To access the GPM of a target node locally or over-the-air, send commands to the MEMORY_ACCESS cluster ID (0x23) on the DIGI_DEVICE endpoint (0xE6) of the target node using explicit API frames. For a description of Explicit API frames, see Operate in API mode. To issue a GPM command, format the payload of an explicit API frame as follows: Byte offset in payload Number of bytes Field name General field description 0 1 GPM_CMD_ID Specific GPM commands are described in detail in the topics that follow. 1 1 GPM_OPTIONS Command-specific options. 2 2* GPM_BLOCK_NUM The block number addressed in the GPM. 4 2* GPM_START_INDEX The byte index within the addressed GPM block. 6 2* GPM_NUM_BYTES The number of bytes in the GPM_ DATA field, or in the case of a READ, the number of bytes requested. 8 varies GPM_DATA * Specify multi-byte parameters with big-endian byte ordering. When a device sends a GPM command to another device via a unicast, the receiving device sends a unicast response back to the requesting device's source endpoint specified in the request packet. It does not send a response for broadcast requests. If the source endpoint is set to the DIGI_DEVICE endpoint (0xE6) or Explicit API mode is enabled on the requesting device, then the requesting node outputs a GPM response as an explicit API RX indicator frame (assuming it has API mode enabled). The format of the response is similar to the request packet: XBee®/XBee-PRO SX RF Module User Guide 196 General Purpose Flash Memory General Purpose Flash Memory commands Byte offset in payload Number of bytes Field name General field description 0 1 GPM_CMD_ID This field is the same as the request field. 1 1 GPM_STATUS Status indicating whether the command was successful. 2 2* GPM_BLOCK_NUM The block number addressed in the GPM. 4 2* GPM_START_INDEX The byte index within the addressed GPM block. 6 2* GPM_NUM_BYTES The number of bytes in the GPM_DATA field. 8 varies GPM_DATA * Specify multi-byte parameters with big-endian byte ordering. General Purpose Flash Memory commands This section provides information about commands that interact with GPM: PLATFORM_INFO_REQUEST (0x00) A PLATFORM_INFO_REQUEST frame can be sent to query details of the GPM structure. Field name Command-specific description GPM_CMD_ID Should be set to PLATFORM_INFO_REQUEST (0x00). GPM_OPTIONS This field is unused for this command. Set to 0. GPM_BLOCK_NUM This field is unused for this command. Set to 0. GPM_START_INDEX This field is unused for this command. Set to 0. GPM_NUM_BYTES This field is unused for this command. Set to 0. GPM_DATA No data bytes should be specified for this command. PLATFORM_INFO (0x80) When a PLATFORM_INFO_REQUEST command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame. Field name Command-specific description GPM_CMD_ID Should be set to PLATFORM_INFO (0x80). GPM_STATUS A 1 in the least significant bit indicates an error occurred. All other bits are reserved at this time. XBee®/XBee-PRO SX RF Module User Guide 197 General Purpose Flash Memory General Purpose Flash Memory commands Field name Command-specific description GPM_BLOCK_NUM Indicates the number of GPM blocks available. GPM_START_INDEX Indicates the size, in bytes, of a GPM block. GPM_NUM_BYTES The number of bytes in the GPM_DATA field. For this command, this field will be set to 0. GPM_DATA No data bytes are specified for this command. Example A PLATFORM_INFO_REQUEST sent to a device with a serial number of 0x0013a200407402AC should be formatted as follows (spaces added to delineate fields): 7E 001C 11 01 0013A200407402AC FFFE E6 E6 0023 C105 00 00 00 00 0000 0000 0000 24 Assuming all transmissions were successful, the following API packets would be output the source node's serial interface: 7E 0007 8B 01 FFFE 00 00 00 76 7E 001A 91 0013A200407402AC FFFE E6 E6 0023 C105 C1 80 00 0077 0200 0000 EB ERASE (0x01) The ERASE command erases (writes all bits to binary 1) one or all of the GPM flash blocks. You can also use the ERASE command to erase all blocks of the GPM by setting the GPM_NUM_BYTES field to 0. Field name Command-specific description GPM_CMD_ID Should be set to ERASE (0x01). GPM_OPTIONS There are currently no options defined for the ERASE command. Set this field to 0. GPM_BLOCK_NUM Set to the index of the GPM block that should be erased. When erasing all GPM blocks, this field is ignored (set to 0). GPM_START_INDEX The ERASE command only works on complete GPM blocks. The command cannot be used to erase part of a GPM block. For this reason GPM_START_INDEX is unused (set to 0). GPM_NUM_BYTES Setting GPM_NUM_BYTES to 0 has a special meaning. It indicates that every flash block in the GPM should be erased (not just the one specified with GPM_BLOCK_NUM). In all other cases, the GPM_NUM_BYTES field should be set to the GPM flash block size. GPM_DATA No data bytes are specified for this command. ERASE_RESPONSE (0x81) When an ERASE command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame. XBee®/XBee-PRO SX RF Module User Guide 198 General Purpose Flash Memory General Purpose Flash Memory commands Field name Command-specific description GPM_CMD_ID Should be set to ERASE_RESPONSE (0x81). GPM_STATUS A 1 in the least significant bit indicates an error occurred. All other bits are reserved at this time. GPM_BLOCK_NUM Matches the parameter passed in the request frame. GPM_START_INDEX Matches the parameter passed in the request frame. GPM_NUM_BYTES The number of bytes in the GPM_DATA field. For this command, this field will be set to 0. GPM_DATA No data bytes are specified for this command. Example To erase flash block 42 of a target radio with serial number of 0x0013a200407402ac format an ERASE packet as follows (spaces added to delineate fields): 7E 001C 11 01 0013A200407402AC FFFE E6 E6 0023 C105 00 C0 01 00 002A 0000 0200 37 Assuming all transmissions were successful, the following API packets would be output the source node's serial interface: 7E 0007 8B 01 FFFE 00 00 00 76 7E 001A 91 0013A200407402AC FFFE E6 E6 0023 C105 C1 81 00 002A 0000 0000 39 WRITE (0x02) and ERASE_THEN_WRITE (0x03) The WRITE command writes the specified bytes to the GPM location specified. Before writing bytes to a GPM block it is important that the bytes have been erased previously. The ERASE_THEN_WRITE command performs an ERASE of the entire GPM block specified with the GPM_BLOCK_NUM field prior to doing a WRITE. Field name Command-specific description GPM_CMD_ID Should be set to WRITE (0x02) or ERASE_THEN_WRITE (0x03). GPM_OPTIONS There are currently no options defined for this command. Set this field to 0. GPM_BLOCK_NUM Set to the index of the GPM block that should be written. GPM_START_INDEX Set to the byte index within the GPM block where the given data should be written. GPM_NUM_BYTES Set to the number of bytes specified in the GPM_DATA field. Only one GPM block can be operated on per command. For this reason, GPM_START_INDEX + GPM_NUM_BYTES cannot be greater than the GPM block size. The number of bytes sent in an explicit API frame (including the GPM command fields) cannot exceed the maximum payload size of the device. The maximum payload size can be queried with the NP command. GPM_DATA The data to be written. XBee®/XBee-PRO SX RF Module User Guide 199 General Purpose Flash Memory General Purpose Flash Memory commands WRITE _RESPONSE (0x82) and ERASE_THEN_WRITE_RESPONSE (0x83) When a WRITE or ERASE_THEN_WRITE command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame. Field name Command-specific description GPM_CMD_ID Should be set to WRITE_RESPONSE (0x82) or ERASE_THEN_WRITE_ RESPONSE (0x83) GPM_STATUS A 1 in the least significant bit indicates an error occurred. All other bits are reserved at this time GPM_BLOCK_NUM Matches the parameter passed in the request frame GPM_START_INDEX Matches the parameter passed in the request frame GPM_NUM_BYTES The number of bytes in the GPM_DATA field. For this command, this field will be set to 0 GPM_DATA No data bytes are specified for these commands Example To write 15 bytes of incrementing data to flash block 22 of a target radio with serial number of 0x0013a200407402ac a WRITE packet should be formatted as follows (spaces added to delineate fields): 7E 002B 11 01 0013A200407402AC FFFE E6 E6 0023 C105 00 C0 02 00 0016 0000 000F 0102030405060708090A0B0C0D0E0F C5 Assuming all transmissions were successful and that flash block 22 was previously erased, the following API packets would be output the source node's serial interface: 7E 0007 8B 01 FFFE 00 00 00 76 7E 001A 91 0013A200407402AC FFFE E6 E6 0023 C105 C1 82 00 0016 0000 0000 4C READ (0x04) You can use the READ command to read the specified number of bytes from the GPM location specified. Data can be queried from only one GPM block per command. Field name Command-specific description GPM_CMD_ID Should be set to READ (0x04). GPM_OPTIONS There are currently no options defined for this command. Set this field to 0. GPM_BLOCK_NUM Set to the index of the GPM block that should be read. GPM_START_INDEX Set to the byte index within the GPM block where the given data should be read. GPM_NUM_BYTES Set to the number of data bytes to be read. Only one GPM block can XBee®/XBee-PRO SX RF Module User Guide 200 General Purpose Flash Memory Field name General Purpose Flash Memory commands Command-specific description be operated on per command. For this reason, GPM_START_INDEX + GPM_NUM_BYTES cannot be greater than the GPM block size. The number of bytes sent in an explicit API frame (including the GPM command fields) cannot exceed the maximum payload size of the device. You can query the maximum payload size with the NP AT command. GPM_DATA No data bytes should be specified for this command. READ_RESPONSE (0x84) When a READ command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame. Field name Command-specific description GPM_CMD_ID Should be set to READ_RESPONSE (0x84). GPM_STATUS A 1 in the least significant bit indicates an error occurred. All other bits are reserved at this time. GPM_BLOCK_NUM Matches the parameter passed in the request frame. GPM_START_INDEX Matches the parameter passed in the request frame. GPM_NUM_BYTES The number of bytes in the GPM_DATA field. GPM_DATA The bytes read from the GPM block specified. Example To read 15 bytes of previously written data from flash block 22 of a target radio with serial number of 0x0013a200407402ac a READ packet should be formatted as follows (spaces added to delineate fields): 7E 001C 11 01 0013A200407402AC FFFE E6 E6 0023 C105 00 C0 04 00 0016 0000 000F 3B Assuming all transmissions were successful and that flash block 22 was previously written with incrementing data, the following API packets would be output the source node's serial interface: 7E 0007 8B 01 FFFE 00 00 00 76 7E 0029 91 0013A200407402AC FFFE E6 E6 0023 C105 C1 84 00 0016 0000 000F 0102030405060708090A0B0C0D0E0F C3 FIRMWARE_VERIFY (0x05) and FIRMWARE_VERIFY_AND_INSTALL (0x06) Use the FIRMWARE_VERIFY and FIRMWARE_VERIFY_AND_INSTALL commands when remotely updating firmware on a device. For more information about firmware updates, see Update the firmware overthe-air. These commands check if the GPM contains a valid over-the-air update file. For the FIRMWARE_VERIFY_AND_INSTALL command, if the GPM contains a valid firmware image then the device resets and begins using the new firmware. XBee®/XBee-PRO SX RF Module User Guide 201 General Purpose Flash Memory General Purpose Flash Memory commands Field name Command-specific description GPM_CMD_ID Should be set to FIRMWARE_VERIFY (0x05) or FIRMWARE_VERIFY_ AND_INSTALL (0x06) GPM_OPTIONS There are currently no options defined for this command. Set this field to 0. GPM_BLOCK_NUM This field is unused for this command. Set to 0. GPM_START_INDEX This field is unused for this command. Set to 0. GPM_NUM_BYTES This field is unused for this command. Set to 0. GPM_DATA This field is unused for this command FIRMWARE_VERIFY_RESPONSE (0x85) When a FIRMWARE_VERIFY command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame. Field name Command-specific description GPM_CMD_ID Should be set to FIRMWARE_VERIFY_RESPONSE (0x85) GPM_STATUS A 1 in the least significant bit indicates the GPM does not contain a valid firmware image. A 0 in the least significant bit indicates the GPM does contain a valid firmware image. All other bits are reserved at this time. GPM_BLOCK_NUM This field is unused for this command. Set to 0. GPM_START_INDEX This field is unused for this command. Set to 0. GPM_NUM_BYTES This field is unused for this command. Set to 0. GPM_DATA This field is unused for this command FIRMWARE_VERIFY _AND_INSTALL_RESPONSE (0x86) When a FIRMWARE_VERIFY_AND_INSTALL command request has been unicast to a node, that node sends a response in the following format to the source endpoint specified in the requesting frame only if the GPM memory does not contain a valid image. If the image is valid, the device resets and begins using the new firmware. Field name Command-specific description GPM_CMD_ID Should be set to FIRMWARE_VERIFY_AND_INSTALL_RESPONSE (0x86). GPM_STATUS A 1 in the least significant bit indicates the GPM does not contain a valid firmware image. All other bits are reserved at this time. GPM_BLOCK_NUM This field is unused for this command. Set to 0. XBee®/XBee-PRO SX RF Module User Guide 202 General Purpose Flash Memory General Purpose Flash Memory commands Field name Command-specific description GPM_START_INDEX This field is unused for this command. Set to 0. GPM_NUM_BYTES This field is unused for this command. Set to 0. GPM_DATA This field is unused for this command. Example To verify a firmware image previously loaded into the GPM on a target device with serial number 0x0013a200407402ac, format a FIRMWARE_VERIFY packet as follows (spaces added to delineate fields): 7E 001C 11 01 0013A200407402AC FFFE E6 E6 0023 C105 00 00 05 00 0000 0000 0000 1F Assuming all transmissions were successful and that the firmware image previously loaded into the GPM is valid, the following API packets would be output the source node's serial interface: 7E 0007 8B 01 FFFE 00 00 00 76 7E 001A 91 0013A200407402AC FFFE E6 E6 0023 C105 C1 85 00 0000 0000 0000 5F XBee®/XBee-PRO SX RF Module User Guide 203 Update the firmware over-the-air This section provides instruction on how to update your firmware using wired updates and over-theair updates. Over-the-air firmware updates Distribute the new application Verify the new application Install the application XBee®/XBee-PRO SX RF Module User Guide 205 205 206 206 204 Update the firmware over-the-air Over-the-air firmware updates Over-the-air firmware updates There are two methods of updating the firmware on the device. You can update the firmware locally with XCTU using the device's serial port interface. You can also update firmware using the device's RF interface (over-the-air updating.) The over-the-air firmware update method provided is a robust and versatile technique that you can tailor to many different networks and applications. OTA updates are reliable and minimize disruption of normal network operations. In the following sections, we refer to the node that will be updated as the target node. We refer to the node providing the update information as the source node. In most applications the source node is locally attached to a computer running update software. There are three phases of the over-the-air update process: 1. Distribute the new application 2. Verify the new application 3. Install the application Distribute the new application The first phase of performing an over-the-air update on a device is transferring the new firmware file to the target node. Load the new firmware image in the target node's GPM prior to installation. XBee/XBee-PRO SX RF Modules use an encrypted binary (.ebin) file for both serial and over-the-air firmware updates. These firmware files are available on the Digi Support website and via XCTU. Send the contents of the .ebin file to the target device using general purpose memory WRITE commands. Erase the entire GPM prior to beginning an upload of an .ebin file. The contents of the .ebin file should be stored in order in the appropriate GPM memory blocks. The number of bytes that are sent in an individual GPM WRITE frame is flexible and can be catered to the user application. Example The example firmware version has an .ebin file of 55,141 bytes in length. Based on network traffic, we determine that sending a 128 byte packet every 30 seconds minimizes network disruption. For this reason, you would divide and address the .ebin as follows: GPM_BLOCK_NUM GPM_START_INDEX GPM_NUM_BYTES .ebin bytes 0 0 128 0 to 127 0 128 128 128 to 255 0 256 128 256 to 383 0 384 128 384 to 511 1 0 128 512 to 639 1 128 128 640 to 767 - - - - - - - - XBee®/XBee-PRO SX RF Module User Guide 205 Update the firmware over-the-air Verify the new application GPM_BLOCK_NUM GPM_START_INDEX GPM_NUM_BYTES .ebin bytes - - - - 107 0 54784 to 54911 107 128 54912 to 55039 107 256 101 55040 to 55140 Verify the new application For an uploaded application to function correctly, every single byte from the .ebin file must be properly transferred to the GPM. To guarantee that this is the case, GPM VERIFY functions exist to ensure that all bytes are properly in place. The FIRMWARE_VERIFY function reports whether or not the uploaded data is valid. The FIRMWARE_VERIFY_AND_INSTALL command reports if the uploaded data is invalid. If the data is valid, it begins installing the application. No installation takes place on invalid data. Install the application When the entire .ebin file is uploaded to the GPM of the target node, you can issue a FIRMWARE_ VERIFY_AND_INSTALL command. Once the target receives the command it verifies the .ebin file loaded in the GPM. If it is valid, then the device installs the new firmware. This installation process can take up to eight seconds. During the installation the device is unresponsive to both serial and RF communication. To complete the installation, the target module resets. AT parameter settings which have not been written to flash using the WR command will be lost. Important considerations Write all parameters with the WR command before performing a firmware update. Packet routing information is also lost after a reset. Route discoveries are necessary for DigiMesh unicasts involving the updated node as a source, destination, or intermediate node. Because explicit API Tx frames can be addressed to a local node (accessible via the SPI or UART) or a remote node (accessible over the RF port) the same process can be used to update firmware on a device in either case. XBee®/XBee-PRO SX RF Module User Guide 206 Regulatory information FCC (United States) ISED (Innovation, Science and Economic Development Canada) ACMA (Australia) RSM (New Zealand) Brazil (Anatel) IFETEL (Mexico) XBee®/XBee-PRO SX RF Module User Guide 208 223 224 224 225 228 207 Regulatory information FCC (United States) FCC (United States) These RF modules comply with Part 15 of the FCC rules and regulations. Compliance with the labeling requirements, FCC notices and antenna usage guidelines is required. In order to operate under Digi’s FCC Certification, integrators must comply with the following regulations: 1. The integrator must ensure that the text provided with this device (in the labeling requirements section that follows) is placed on the outside of the final product and within the final product operation manual. 2. The device may only be used with antennas that have been tested and approved for use with this device; refer to FCC antenna certifications. OEM labeling requirements WARNING! The Original Equipment Manufacturer (OEM) must ensure that FCC labeling requirements are met. This includes a clearly visible label on the outside of the final product enclosure that displays the text shown in the figure below. The following text is the required FCC label for OEM products containing the XBee-PRO SX RF Module: Contains FCC ID: MCQ-XBPSX The enclosed device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (i.) this device may not cause harmful interference and (ii.) this device must accept any interference received, including interference that may cause undesired operation. The following text is the required FCC label for OEM products containing the XBee SX RF Module: Contains FCC ID: MCQ-XBSX The enclosed device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (i.) this device may not cause harmful interference and (ii.) this device must accept any interference received, including interference that may cause undesired operation. FCC notices IMPORTANT: These RF modules have been certified by the FCC for use with other products without any further certification (as per FCC section 2.1091). Modifications not expressly approved by Digi could void the user’s authority to operate the equipment. IMPORTANT: Integrators must test final product to comply with unintentional radiators (FCC sections 15.107 & 15.109) before declaring compliance of their final product to Part 15 of the FCC rules. IMPORTANT: These RF modules have been certified for remote and base radio applications. If the module will be used for portable applications, the device must undergo SAR testing. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: Re-orient or relocate the receiving antenna, XBee®/XBee-PRO SX RF Module User Guide 208 Regulatory information FCC (United States) Increase the separation between the equipment and receiver, Connect equipment and receiver to outlets on different circuits, or Consult the dealer or an experienced radio/TV technician for help. XBee®/XBee-PRO SX RF Module User Guide 209 Regulatory information FCC (United States) RF exposure statement This statement must be included as a CAUTION statement in integrator product manuals. WARNING! This equipment is approved only for mobile and base station transmitting devices. Antenna(s) used for this transmitter must be installed to provide a separation distance of at least 34 cm from all persons and must not be co-located or operating in conjunction with any other antenna or transmitter. FCC antenna certifications WARNING! This device has been tested with the antennas listed in the tables of this section. When integrated into products, fixed antennas require installation preventing end users from replacing them with non-approved antennas. Antennas not listed in the tables must be tested to comply with FCC Section 15.203 (unique antenna connectors) and Section 15.247 (emissions). Fixed base station and mobile applications Digi devices are pre-FCC approved for use in fixed base station and mobile applications. When the antenna is mounted at least 34 cm from nearby persons, the application is considered a mobile application. Portable applications and SAR testing When the antenna is mounted closer than 34 cm to nearby persons, then the application is considered "portable" and requires an additional test be performed on the final product. This test is called Specific Absorption Rate (SAR) testing and measures the emissions from the device and how they affect the person. RF exposure statement This statement must be included as a CAUTION statement in integrator product manuals. WARNING! This equipment is approved only for mobile and base station transmitting devices. Antenna(s) used for this transmitter must be installed to provide a separation distance of at least 34 cm from all persons and must not be co-located or operating in conjunction with any other antenna or transmitter. XBee®/XBee-PRO SX RF Module User Guide 210 The following tables cover the antennas that are approved for use with the XBee-PRO SX RF Module. If applicable, the tables show the required cable loss between the device and the antenna. Digi does not carry all of these antenna variants. Contact Digi Sales for available antennas. Dipole antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Part number Type Connector Gain Required antenna cable loss Application A09-HSM-7 1 Straight half-wave RPSMA 2.1 dBi 0.4 dB Fixed / mobile A09-HASM-675 Articulated half-wave RPSMA 2.1 dBi 0.4 dB Fixed / mobile A09-HABMM-P5I Swivel half wave with 5" pigtail MMCX 2.1 dBi 0.4 dB Fixed / mobile A09-HBMM-P5I Straight half-wave with 6" pigtail MMCX 2.1 dBi 0.4 dB Fixed / mobile A09-HASM-7* Articulated half-wave RPSMA 2.1 dBi 0.4 dB Fixed A09-HRSM* Right angle half-wave RPSMA 2.1 dBi 0.4 dB Fixed A09-HG* Glass mounted half-wave RPSMA 2.1 dBi 0.4 dB Fixed A09-HATM* Articulated half-wave RPTNC 2.1 dBi 0.4 dB Fixed A09-H* Half-wave dipole RPSMA 2.1 dBi 0.4 dB Fixed Regulatory information XBee®/XBee-PRO SX RF Module User Guide XBee-PRO SX antenna options (30 dBm maximum RF power) Yagi antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. FCC (United States) 211 1Installers should apply additional torque to screw on the antenna. Type Gain Connector Required antenna cable loss Application A09-Y6NF* 2 element Yagi 6.1 dBi N 2.0 dB Fixed/mobile A09-Y7NF* 3 element Yagi 7.1 dBi N 3.0 dB Fixed/mobile A09-Y8NF 4 element Yagi 8.1 dBi N 4.0 dB Fixed/mobile A09-Y9NF* 4 element Yagi 9.1 dBi N 5.0 dB Fixed/mobile A09-Y10NF* 5 element Yagi 10.1 dBi N 6.0 dB Fixed/mobile A09-Y11NF 6 element Yagi 11.1 dBi N 7.0 dB Fixed/mobile A09-Y12NF* 7 element Yagi 12.1 dBi N 8.0 dB Fixed/mobile A09-Y13NF* 9 element Yagi 13.1 dBi N 9.0 dB Fixed/mobile A09-Y14NF* 14 element Yagi 14.0 dBi N 9.9 dB Fixed/mobile A09-Y6TM* 2 element Yagi 6.1 dBi RPTNC 2.0 dB Fixed/mobile A09-Y7TM* 3 element Yagi 7.1 dBi RPTNC 3.0 dB Fixed/mobile A09-Y8TM* 4 element Yagi 8.1 dBi RPTNC 4.0 dB Fixed/mobile A09-Y9TM* 4 element Yagi 9.1 dBi RPTNC 5.0 dB Fixed/mobile A09-Y10TM-P10I 5 element Yagi 10.1 dBi RPTNC 6.0 dB Fixed/mobile A09-Y11TM* 6 element Yagi 11.1 dBi RPTNC 7.0 dB Fixed/mobile A09-Y12TM* 7 element Yagi 12.1 dBi RPTNC 8.0 dB Fixed/mobile A09-Y13TM* 9 element Yagi 13.1 dBi RPTNC 9.0 dB Fixed/mobile A09-Y14TM* 14 element Yagi 14.0 dBi RPTNC 9.9 dB Fixed/mobile All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. 212 FCC (United States) Omni-directional base station antennas Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number Gain Connector Required antenna cable loss Application A09-F0NF* Fiberglass base station 0 dBi N - Fixed A09-F1NF* Fiberglass base station 1.0  dBi N - Fixed A09-F2NF-M Fiberglass base station 2.1 dBi N - Fixed A09-F3NF* Fiberglass base station 3.1 dBi N - Fixed A09-F4NF* Fiberglass base station 4.1 dBi N - Fixed A09-F5NF-M Fiberglass base station 5.1 dBi N - Fixed A09-F6NF* Fiberglass base station 6.1 dBi N 0.9 dB Fixed A09-F7NF* Fiberglass base station 7.1 dBi N 1.9 dB Fixed A09-F8NF-M Fiberglass base station 8.1 dBi N 2.9 dB Fixed A09-F0SM* Fiberglass base station 0 dBi RPSMA - Fixed A09-F1SM* Fiberglass base station 1.0 dBi RPSMA - Fixed A09-F2SM* Fiberglass base station 2.1 dBi RPSMA - Fixed A09-F3SM* Fiberglass base station 3.1 dBi RPSMA - Fixed A09-F4SM* Fiberglass base station 4.1 dBi RPSMA - Fixed A09-F5SM* Fiberglass base station 5.1 dBi RPSMA - Fixed A09-F6SM* Fiberglass base station 6.1 dBi RPSMA 0.9 dB Fixed A09-F7SM* Fiberglass base station 7.1 dBi RPSMA 1.9 dB Fixed A09-F8SM* Fiberglass base station 8.1 dBi RPSMA 2.9 dB Fixed A09-F0TM* Fiberglass base station 0 dBi RPTNC - Fixed A09-F1TM* Fiberglass base station 1.0 dBi RPTNC - Fixed A09-F2TM* Fiberglass base station 2.1 dBi RPTNC - Fixed 213 FCC (United States) Type Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number Type Gain Connector Required antenna cable loss Application A09-F3TM* Fiberglass base station 3.1 dBi RPTNC - Fixed A09-F4TM* Fiberglass base station 4.1 dBi RPTNC - Fixed A09-F5TM* Fiberglass base station 5.1 dBi RPTNC - Fixed A09-F6TM* Fiberglass base station 6.1 dBi RPTNC 0.9 dB Fixed A09-F7TM* Fiberglass base station 7.1 dBi RPTNC 1.9 dB Fixed A09-F8TM* Fiberglass base station 8.1 dBi RPTNC 2.9 dB Fixed A09-W7* Wire base station 7.1 dBi RPN 1.9 dB Fixed A09-W7SM* Wire base station 7.1 dBi RPSMA 1.9 dB Fixed A09-W7TM* Wire base station 7.1 dBi RPTNC 1.9 dB Fixed Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number Dome antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Part number Type Gain Connector Required antenna cable loss Application A09-D3PNF* Omnidirectional permanent mount 3.0 dBi N 0.4 dB Fixed/mobile A09-D3NF* Omnidirectional magnetic mount 3.0 dBi N 0.4 dB Fixed/mobile A09-D3PTM* Omnidirectional permanent mount 3.0 dBi RPTNC 0.4 dB Fixed/mobile A09-D3PSM* Omnidirectional permanent mount 3.0 dBi RPSMA 0.4 dB Fixed/mobile Monopole antennas 214 FCC (United States) All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Type Gain Connector Required antenna cable loss Application A09-QRAMM 3" Quarter wave wire 2.1 dBi MMCX - Fixed/mobile A09-QRSM-2.1* Quarter wave 2.1" right angle 3.3 dBi RPSMA 0.4 dB Fixed/mobile A09-QW* Quarter wave wire 1.9 dBi Permanent - Fixed/mobile A09-QSM-3* Quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QSM-3H* Heavy duty quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QBMM-P6I* Quarter wave w/ 6" pigtail 1.9 dBi MMCX - Fixed/mobile A09-QHSM-2* 2" straight 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-2* 2" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-170* 1.7" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QRSM-380* 3.8" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QAPM-520* 5.2" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QSPM-3* 3" straight screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3H* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number FCC (United States) 215 The following tables cover the antennas that are approved for use with the XBee SX RF Module. If applicable, the tables show the required cable loss between the device and the antenna. Dipole antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Part number Type Connector Gain Required antenna cable loss A09-HSM-7 1 Straight half-wave RPSMA 2.1 dBi 0.4 dB Fixed/mobile A09-HASM-675 Articulated half-wave RPSMA 2.1 dBi 0.4 dB Fixed/mobile A09-HABMM-P5I Swivel half wave with 5" pigtail MMCX 2.1 dBi 0.4 dB Fixed/mobile A09-HBMM-P5I Straight half-wave with 6" pigtail MMCX 2.1 dBi 0.4 dB Fixed/mobile A09-HASM-7* Articulated half-wave RPSMA 2.1 dBi 0.4 dB Fixed A09-HRSM* Right angle half-wave RPSMA 2.1 dBi 0.4 dB Fixed A09-HG* Glass mounted half-wave RPSMA 2.1dBi 0.4 dB Fixed A09-HATM* Articulated half-wave RPTNC 2.1 dBi 0.4 dB Fixed A09-H* Half-wave dipole RPSMA 2.1 dBi 0.4 dB Fixed Application Regulatory information XBee®/XBee-PRO SX RF Module User Guide XBee SX antenna options (13 dBm maximum RF power) Yagi antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. FCC (United States) 216 1Installers should apply additional torque to screw on the antenna. Gain Connector Required antenna cable loss Application A09-Y6NF* 2 element Yagi 6.1 dBi N - Fixed/mobile A09-Y7NF* 3 element Yagi 7.1 dBi N - Fixed/mobile A09-Y8NF 4 element Yagi 8.1 dBi N - Fixed/mobile A09-Y9NF* 4 element Yagi 9.1 dBi N - Fixed/mobile A09-Y10NF* 5 element Yagi 10.1 dBi N - Fixed/mobile A09-Y11NF 6 element Yagi 11.1 dBi N - Fixed/mobile A09-Y12NF* 7 element Yagi 12.1 dBi N - Fixed/mobile A09-Y13NF* 9 element Yagi 13.1 dBi N - Fixed/mobile A09-Y14NF* 10 element Yagi 14.1 dBi N - Fixed/mobile A09-Y14NF-ALT* 12 element Yagi 14.1 dBi N - Fixed/mobile A09-Y15NF 13 element Yagi 15.1 dBi N 0.7 dB Fixed/mobile A09-Y15NF-ALT* 15 element Yagi 15.1 dBi N 0.7 dB Fixed/mobile A09-Y6TM* 2 element Yagi 6.1 dBi RPTNC - Fixed/mobile A09-Y7TM* 3 element Yagi 7.1 dBi RPTNC - Fixed/mobile A09-Y8TM* 4 element Yagi 8.1 dBi RPTNC - Fixed/mobile A09-Y9TM* 4 element Yagi 9.1 dBi RPTNC - Fixed/mobile A09-Y10TM-P10* 5 element Yagi 10.1 dBi RPTNC - Fixed/mobile A09-Y11TM* 6 element Yagi 11.1 dBi RPTNC - Fixed/mobile A09-Y12TM* 7 element Yagi 12.1 dBi RPTNC - Fixed/mobile A09-Y13TM* 9 element Yagi 13.1 dBi RPTNC - Fixed/mobile A09-Y14TM* 10 element Yagi 14.1 dBi RPTNC - Fixed/mobile 217 FCC (United States) Type Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number Type Gain Connector Required antenna cable loss Application A09-Y14TM-ALT* 12 element Yagi 14.1 dBi RPTNC - Fixed/mobile A09-Y15TM* 13 element Yagi 15.1 dBi RPTNC 0.7 dB Fixed/mobile A09-Y15TM-P10I 15 element Yagi 15.1 dBi RPTNC 0.7 dB Fixed/mobile Omni-directional base station antennas Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Type Gain Connector Required antenna cable loss Application A09-F0NF* Fiberglass Base Station 0 dBi N - Fixed A09-F1NF* Fiberglass Base Station 1.0 dBi N - Fixed A09-F2NF-M* Fiberglass Base Station 2.1 dBi N - Fixed A09-F3NF* Fiberglass Base Station 3.1 dBi N - Fixed A09-F4NF* Fiberglass Base Station 4.1 dBi N - Fixed A09-F5NF-M Fiberglass Base Station 5.1 dBi N - Fixed A09-F6NF* Fiberglass Base Station 6.1 dBi N - Fixed A09-F7NF* Fiberglass Base Station 7.1 dBi N - Fixed A09-F8NF-M Fiberglass Base Station 8.1 dBi N 0.7 dB Fixed A09-F0SM* Fiberglass Base Station 0 dBi RPSMA - Fixed A09-F1SM* Fiberglass Base Station 1.0 dBi RPSMA - Fixed A09-F2SM* Fiberglass Base Station 2.1 dBi RPSMA - Fixed A09-F3SM* Fiberglass Base Station 3.1 dBi RPSMA - Fixed A09-F4SM* Fiberglass Base Station 4.1 dBi RPSMA - Fixed 218 FCC (United States) Part number Type Gain Connector Required antenna cable loss Application A09-F5SM* Fiberglass Base Station 5.1 dBi RPSMA - Fixed A09-F6SM* Fiberglass Base Station 6.1 dBi RPSMA - Fixed A09-F7SM* Fiberglass Base Station 7.1 dBi RPSMA - Fixed A09-F8SM* Fiberglass Base Station 8.1 dBi RPSMA 0.7 dB Fixed A09-F0TM* Fiberglass Base Station 0 dBi RPTNC - Fixed A09-F1TM* Fiberglass Base Station 1.0 dBi RPTNC - Fixed A09-F2TM* Fiberglass Base Station 2.1 dBi RPTNC - Fixed A09-F3TM* Fiberglass Base Station 3.1 dBi RPTNC - Fixed A09-F4TM* Fiberglass Base Station 4.1 dBi RPTNC - Fixed A09-F5TM* Fiberglass Base Station 5.1 dBi RPTNC - Fixed A09-F6TM* Fiberglass Base Station 6.1 dBi RPTNC - Fixed A09-F7TM* Fiberglass Base Station 7.1 dBi RPTNC - Fixed A09-F8TM* Fiberglass Base Station 8.1 dBi RPTNC 0.7 dB Fixed A09-W7* Wire Base Station 7.1 dBi RPN - Fixed A09-W7SM* Wire Base Station 7.1 dBi RPSMA - Fixed A09-W7TM* Wire Base Station 7.1 dBi RPTNC - Fixed Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number Dome antennas All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Type Gain Connector Required antenna cable loss Application A09-D3PNF* Omnidirectional permanent mount 3.0 dBi N 0.4 dB Fixed/mobile 219 FCC (United States) Part number Type Gain Connector Required antenna cable loss Application A09-D3NF* Omnidirectional magnetic mount 3.0 dBi N 0.4 dB Fixed/mobile A09-D3PTM* Omnidirectional permanent mount 3.0  dBi RPTNC 0.4 dB Fixed/mobile A09-D3PSM* Omnidirectional permanent mount 3.0 dBi RPSMA 0.4 dB Fixed/mobile Monopole antennas Regulatory information XBee®/XBee-PRO SX RF Module User Guide Part number All antenna part numbers followed by an asterisk (*) are not available from Digi. Consult with an antenna manufacturer for an equivalent option. Type Gain Connector Required antenna cable loss Application A09-QRAMM 3" Quarter wave wire 2.1 dBi MMCX - Fixed/mobile A09-QRSM-2.1* Quarter wave 2.1" right angle 3.3 dBi RPSMA 0.4 dB Fixed/mobile A09-QW* Quarter wave wire 1.9 dBi Permanent - Fixed/mobile A09-QSM-3* Quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QSM-3H* Heavy duty quarter wave straight 1.9 dBi RPSMA - Fixed/mobile A09-QBMM-P6I* Quarter wave w/ 6" pigtail 1.9 dBi MMCX - Fixed/mobile A09-QHSM-2* 2" straight 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-2* 2" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QHRSM-170* 1.7" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QRSM-380* 3.8" right angle 1.9 dBi RPSMA - Fixed/mobile A09-QAPM-520* 5.2" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QSPM-3* 3" straight screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile A09-QAPM-3H* 3" articulated screw mount 1.9 dBi Permanent - Fixed/mobile 220 FCC (United States) Part number Regulatory information FCC (United States) FCC publication 996369 related information In publication 996369 section D03, the FCC requires information concerning a module to be presented by OEM manufacturers. This section assists in answering or fulfilling these requirements. 2.1 General No requirements are associated with this section. 2.2 List of applicable FCC rules This module conforms to FCC Part 15.247. 2.3 Summarize the specific operational use conditions Certain approved antennas require attenuation for operation. For the XBee SX, see XBee SX antenna options (13 dBm maximum RF power). For the XBee-PRO SX, see XBee-PRO SX antenna options (30 dBm maximum RF power). Host product user guides should include the antenna table if end customers are permitted to select antennas. 2.4 Limited module procedures Not applicable. 2.5 Trace antenna designs While it is possible to build a trace antenna into the host PCB, this requires at least a Class II permissive change to the FCC grant which includes significant extra testing and cost. If an embedded trace or chip antenna is desired contact a Digi sales representative for information on how to engage with a lab to get the modified FCC grant. 2.6 RF exposure considerations For RF exposure considerations see RF exposure statement, XBee-PRO SX antenna options (30 dBm maximum RF power) and XBee SX antenna options (13 dBm maximum RF power). Host product manufacturers need to provide end-users a copy of the “RF Exposure” section of the manual: RF exposure statement. 2.7 Antennas A list of approved antennas is provided for the SX product. For the XBee SX, see XBee SX antenna options (13 dBm maximum RF power). For the XBee-PRO SX, see XBee-PRO SX antenna options (30 dBm maximum RF power). 2.8 Label and compliance information Host product manufacturers need to follow the sticker guidelines outlined in OEM labeling requirements. 2.9 Information on test modes and additional testing requirements Contact a Digi sales representative for information on how to configure test modes for the XBee SX and XBee-PRO SX modules. XBee®/XBee-PRO SX RF Module User Guide 221 Regulatory information FCC (United States) 2.10 Additional testing, Part 15 Subpart B disclaimer All final host products must be tested to be compliant to FCC Part 15 Subpart B standards. While the XBee SX and XBee-PRO SX modules were tested to be complaint to FCC unintentional radiator standards, FCC Part 15 Subpart B compliance testing is still required for the final host product. This testing is required for all end products, and XBee SX/XBee-PRO SX Part 15 Subpart B compliance does not affirm the end product’s compliance. See FCC notices for more details. XBee®/XBee-PRO SX RF Module User Guide 222 Regulatory information ISED (Innovation, Science and Economic Development Canada) ISED (Innovation, Science and Economic Development Canada) This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Le présent appareil est conforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitation est autorisée aux deux conditions suivantes : (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d'en compromettre le fonctionnement. Labeling requirements XBee SX Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product must display the following text: Contains Model XBSX Radio, IC: 1846A-XBSX The integrator is responsible for its product to comply with IC ICES-003 and FCC Part 15, Sub. B Unintentional Radiators. ICES-003 is the same as FCC Part 15 Sub. B and Industry Canada accepts FCC test report or CISPR 22 test report for compliance with ICES-003. XBee-PRO SX Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product must display the following text: Contains Model XBPSX Radio, IC: 1846A-XBPSX The integrator is responsible for its product to comply with IC ICES-003 and FCC Part 15, Sub. B Unintentional Radiators. ICES-003 is the same as FCC Part 15 Sub. B and Industry Canada accepts FCC test report or CISPR 22 test report for compliance with ICES-003. Transmitters for detachable antennas This radio transmitter has been approved by Industry Canada to operate with the antenna types listed in the tables in FCC antenna certifications with the maximum permissible gain and required antenna impedance for each antenna type indicated. Antenna types not included in this list, having a gain greater than the maximum gain indicated for that type, are strictly prohibited for use with this device. The required antenna impedance is 50 ohms. Le présent émetteur radio a été approuvé par Industrie Canada pour fonctionner avec les types d'antenne énumérés ci-dessous et ayant un gain admissible maximal et l'impédance requise pour chaque type d'antenne. Les types d'antenne non inclus dans cette liste, ou dont le gain est supérieur au gain maximal indiqué, sont strictement interdits pour l'exploitation de l'émetteur. Detachable antennas Under Industry Canada regulations, this radio transmitter may only operate using an antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that necessary for successful communication. Conformément à la réglementation d'Industrie Canada, le présent émetteur radio peut fonctionner avec une antenne d'un type et d'un gain maximal (ou inférieur) approuvé pour l'émetteur par Industrie Canada. Dans le but de réduire les risques de brouillage radioélectrique à l'intention des autres XBee®/XBee-PRO SX RF Module User Guide 223 Regulatory information ACMA (Australia) utilisateurs, il faut choisir le type d'antenne et son gain de sorte que la puissance isotrope rayonnée équivalente (p.i.r.e.) ne dépasse pas l'intensité nécessaire àl'établissement d'une communication satisfaisante. ACMA (Australia) Power requirements Regulations in Australia stipulate a maximum of 30 dBm EIRP (Effective Isotropic Radiated Power). The EIRP equals the sum (in dBm) of power output, antenna gain and cable loss and cannot not exceed 30 dBm. The EIRP formula for Australia is: power output + antenna gain - cable loss
XBP9X-DMUS-001 价格&库存
很抱歉,暂时无法提供与“XBP9X-DMUS-001”相匹配的价格&库存,您可以联系我们找货
