MTQ-H5-B02-SP
MTQ-H5-B02-SP
    MULTI-TECHSYSTEMS
    Module
    RF TXRX MODULE CELLULAR U.FL ANT
MTQ-H5-B02-SP 数据手册
MultiTech Dragonfly™ Embedded Cellular Modem & SoM (System-on-Module) BENEFITS • End device certified by leading carriers MultiTech Dragonfly embedded cellular modems and SoMs are fully certified and ™ • 4G-LTE Cat 4, Cat 1 and MNO approved, ready-to-integrate modules that offer developers the functionality of Cat M1 models a programmable computing platform with the convenience of an onboard cellular radio all in one compact design. From a software perspective, Dragonfly is compatible with • Developer friendly to integrate, quick to deploy and scale assets the Arm Mbed programming platform allowing for rapid prototyping, development and ® ™ deployment. With its integrated Cortex®-M4 processor, developers can host their application and have access to a full suite of interfaces for connecting sensors or other remote assets. • Long solution lifecycle reduces redesign time and cost As the first Arm Mbed cellular SoM listed on mbed.org that is industry certified and FEATURES deployment ready, applications can be written and compiled quickly online using • Lightweight SoM ideal for most IoT applications developer friendly libraries, downloaded and hosted within the Dragonfly. Dragonfly can be used as an embedded cellular SoM providing the maximum in design and application flexibility or it can be used as an embedded cellular modem requiring little or no modification to your existing design. fast and accurate location fix (select models) • Multiple I/O interfaces for This powerful suite of hardware and software products greatly reduces your time to market and makes your Internet of Things (IoT) device a reality today. Your Devices & Data • On-board GNSS or GPS for connecting most any “Thing” • Design in or retrofit Connecting Your Devices Insight + Action + Control Energy Alerts Financial / Retail Real-Time Management Healthcare Remote Monitoring Wireless Service Provider Asset Management Platform Reports www.multitech.com/dragonfly HIGHLIGHTS Host Your Applications Design in or Retrofit As the first Arm® Mbed™ cellular SoM listed on mbed.org that is industry certified and deployment ready, applications can be written and compiled quickly online using developer friendly libraries, downloaded and hosted within the MultiTech Dragonfly. Decision making and control is distributed to the edge, enabling data to be more actionable without the heavy lift required to implement complex M2M middleware and security protocols needed to deploy a low touch install. The Dragonfly can be used as an embedded cellular SoM providing the maximum in design and application flexibility or it can be used as an embedded cellular modem controlled through AT commands requiring little or no modification to your design. Connecting to the Dragonfly through its 40-pin board-to-board connector gives you access to all the programmable I/O interfaces. You can also connect to the Dragonfly using the industry standard micro USB port affording you the quickest time to market when your application only requires basic cellular connectivity. SPECIFICATIONS MTQ-L4G1-B02 MTQ-LNA7-B02 MTQ-LEU7-B02 MTQ-LAT3-B01 / MTQ-LAT3-B02 Performance LTE 3GPP Release 11 (Category 4; 150 Mbps peak downlink/50 Mbps peak uplink) with HSPA Fallback LTE 3GPP Release 11 (Category 4; 150 Mbps peak downlink/50 Mbps peak uplink) with HSPA Fallback LTE 3GPP Release 11 (Category 4; 150 Mbps peak downlink/50 Mbps peak uplink) with HSPA and GPRS Fallback LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) with HSPA Fallback Frequency Band (MHz) 4G FDD: B1(2100), B2(1900), B3(1800), B4(AWS1700), B5(850), B7(2600), B8(900), B12/B13(700), B18(850), B19(850), B20(800), B25(1900), B26(850), B28(700) TDD: B38(2600), B39(1900), B40(2300), B41(2500) 3G: B1(2100), B2(1900), B4(AWS1700), B5(850), B6(800), B8(900), B19(850) 2G: B2(1900), B3(1800), B5(850), B8(900) Models 4G: B2(1900), B4(AWS1700), B5(850), B12(700), B13(700) 3G: B2(1900), B4(AWS1700), B5(850) 3G: B1(2100), B8(900) 3G: B5(850), B2(1900) FTP, HTTP, SMTP, TCP, UDP, SSL GPS or GNSS Support Yes 3 UFL (Cellular, Rx Diversity & GPS) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) No 3 UFL (Cellular, Rx Diversity & GPS) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) I/O 2 UFL (Cellular, Rx Diversity/ MIMO) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) 2 UFL (Cellular, Rx Diversity/MIMO) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) N/A (B01) Cortex M4 (STM32F411RET) 512 Kbytes of Flash memory and 96 Kbytes of SRAM 1 x UART, 1 x HS USB (B01) 1 x UART, 1 x HS USB, 1 x SPI, 1 x I2C, up to 6 analog inputs and up to 16 digital input/output (B02) 1 x UART, 1 x HS USB Host Processor Dimensions Power Draw* 4G: B12/B13(700), B5(850), B4(AWS1700), B2(1900) 2G: B3(1800), B8(900) TCP/IP Functions Connectors 4G: B1(2100), B3(1800), B7(2600), B8(900), B20(800), B28A(700) 58.4mm x 34.9mm (2.3 x 1.375 inches) (B02) 5VDC; 562uA sleep/ power down mode, 27mA idle, 539mA max power Input Voltage (B02) 5VDC; 8.6mA sleep/ power down mode, 28mA idle, 712mA max power (B02) 5VDC; 9mA sleep/ power down mode, 792mA max power 3.3-5VDC (B01) 5VDC; 25mA sleep, 58mA idle, 540mA max power (B02) 5VDC; 25mA sleep, 38mA idle, 510mA max power 5VDC Environmental Operating Temperature -40° to +85° C Storage Temperature -40° to +85° C Relative Humidity 20% to 90% RH, non-condensing Certifications EMC/Radio Compliance FCC Part 15 Class B FCC Part 22, 24, 27 CE Mark, RED (EU) RCM (AU) Safety UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 Network Carrier Warranty * See device guide for more information. FCC Part 15 Class B FCC Part 22, 24, 27 PTCRB AT&T, Verizon AT&T, Verizon, T-Mobile† CE Mark, RED (EU) RCM (AU) FCC Part 15 Class B FCC Part 22, 24, 27 IEC60950-1 (EU) UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 N/A PTCRB EU Carriers AT&T 2-Years †Voice must be deactivated by AT commands to use on T-Mobile network, contact MultiTech for details MultiTech Connection Manager A software solution designed to greatly simplify and ease the installation, configuration and management of cellularconnectivity in MultiTech USB and serial cellular modems that lack intelligence to manage these functions. Connection Manager ensures that IoT edge applications using cellular backhaul can always communicate to the Internet whenever needed by ensuring the cellular connection is always ready for transmission, ensuring the smooth operation of real-world IoT use cases. AT Commands, traditionally used to manage these functions, can prove time-consuming and difficult to the un-initiated. Connection Manager provides a much easier and faster method of managing USB and serial cellular modems to ensure persistent connectivity to the cellular network. SPECIFICATIONS Models Performance Frequency Band (MHz) MTQ-LVW3-B01 / MTQ-LVW3-B02 MTQ-LSP3-B02 MTQ-MNA1-B01 / MTQ-MNA1-B02 LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) (No Fallback) LTE 3GPP Release 10 (Category 1; 10 Mbps peak downlink/ 5 Mbps peak uplink) LTE 3GPP Release 13 (Category M1; Up to 300 Kbps downlink & up to 375 Kbps uplink) 4G: B13(700), B4(AWS1700), B2(1900) 4G: B12(700), B5/25(850), B4(AWS1700), B2/25(1900), B25(1900+) TCP/IP Functions GPS or GNSS Support Connectors Host Processor I/O Verizon: B13(700), B4(AWS1700) FTP, HTTP, SMTP, TCP, UDP, SSL No Yes (GNSS) 2 UFL (Cellular, Rx Diversity/MIMO) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) 3 UFL (Cellular, Rx Diversity & GPS) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) 2 UFL (Cellular, GPS) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM (3FF) (B01) Cortex M4 (STM32F411RET) 512 Kbytes of Flash memory and 96 Kbytes of SRAM N/A (B01) Cortex M4 (STM32F411RET) 512 Kbytes of Flash memory and 96 Kbytes of SRAM (B01) 1 x UART, 1 x HS USB, 1 x SPI, 1 x I2C, up to 6 analog inputs and up to 16 digital input/output (B02) 1 x UART, 1 x HS USB Dimensions Power Draw* AT&T: B12(700), B4(AWS1700), B2(1900) 58.4mm x 34.9mm (2.3 x 1.375 inches) (B01) 5VDC; 38mA sleep, 57mA idle, 462mA max power (B02) 5VDC; 26mA sleep, 37mA idle, 450mA max power (B02) 5VDC; 5.4mA sleep, 33mA idle, 634mA max power Input Voltage (B01) 5VDC; 3.6mA sleep, 57mA idle, 195mA max power (B02)5VDC; 3.4mA sleep, 37mA idle, 176mA max power 5VDC Environmental Operating Temperature -40° to +85° C Storage Temperature -40° to +85° C Relative Humidity 20% to 90% RH, non-condensing Certifications FCC Part 15 Class B FCC Part 27 EMC/Radio Compliance UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 Safety Network Carrier Warranty * See device guide for more information. N/A Verizon PTCRB Sprint 2-Years AT&T/Verizon ORDERING INFORMATION Services & Warranty MultiTech Dragonfly™ Model Description MTQ-L4G1-B02 Embedded LTE Cat 4 Modem w/Fallback & GNSS MTQ-LNA7-B02 Embedded LTE Cat 4 Modem Region Global US/Can w/Fallback & GNSS (AT&T/Verizon) MTQ-LEU7-B02 Embedded LTE Cat 4 Modem w/Fallback MTQ-LAT3-B01 LTE Cat 1 Embedded Cellular SoM w/Fallback (AT&T) US/Can EU/AU MTQ-LAT3-B02 Embedded LTE Cat 1 Modem w/Fallback (AT&T) US/Can MTQ-LVW3-B01 LTE Cat 1 Embedded Cellular SoM (Verizon) MTQ-LVW3-B02 Embedded LTE Cat 1 Modem (Verizon) USA MTQ-LSP3-B02 Embedded LTE Cat 1 Modem w/GNSS (Sprint) USA MTQ-MNA1-B01 LTE Cat M1 Embedded Cellular SoM w/GNSS (AT&T/Verizon) US/Can MTQ-MNA1-B02 Embedded LTE Cat M1 Modem w/GNSS (AT&T/Verizon) US/Can Model Description Region MTUDK2-ST-CELL SocketModem® & Dragonfly Developer Kit USA Developer Kit Global Go to www.multitech.com for detailed product model numbers. MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs.These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. Technical Support Services At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk Produced in the U.S. of U.S. and non-U.S. components. Features and specifications are subject to change without notice. Trademarks and Registered Trademarks: MultiTech and the MultiTech logo, Dragonfly, SocketModem: Multi-Tech Systems, Inc. All other products and technologies are the trademarks or registered trademarks of their respective holders. 2022-01 • 86002177 • © 2022 Multi-Tech Systems, Inc. All rights reserved.
MTQ-H5-B02-SP 价格&库存
很抱歉,暂时无法提供与“MTQ-H5-B02-SP”相匹配的价格&库存,您可以联系我们找货
