HumPRO TM Series 900MHz
RF Transceiver Module
Data Guide
! Warning: Some customers may want Linx radio frequency (“RF”)
products to control machinery or devices remotely, including machinery
or devices that can cause death, bodily injuries, and/or property
damage if improperly or inadvertently triggered, particularly in industrial
settings or other applications implicating life-safety concerns (“Life and
Property Safety Situations”).
Table of Contents
1^
1^
2^
NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE
SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY
SITUATIONS. No OEM Linx Remote Control or Function Module
should be modified for Life and Property Safety Situations. Such
modification cannot provide sufficient safety and will void the product’s
regulatory certification and warranty.
2^
3^
5^
10^
10^
Customers may use our (non-Function) Modules, Antenna and
Connectors as part of other systems in Life Safety Situations, but
only with necessary and industry appropriate redundancies and
in compliance with applicable safety standards, including without
limitation, ANSI and NFPA standards. It is solely the responsibility of any
Linx customer who uses one or more of these products to incorporate
appropriate redundancies and safety standards for the Life and
Property Safety Situation application.
12^
13^
14^
15^
16^
18^
20^
20^
21^
22^
23^
23^
24^
25^
29^
30^
32^
33^
34^
34^
35^
Do not use this or any Linx product to trigger an action directly
from the data line or RSSI lines without a protocol or encoder/
decoder to validate the data. Without validation, any signal from
another unrelated transmitter in the environment received by the module
could inadvertently trigger the action.
All RF products are susceptible to RF interference that can prevent
communication. RF products without frequency agility or hopping
implemented are more subject to interference. This module does have
a frequency hopping protocol built in, but the developer should still be
aware of the risk of interference.
Do not use any Linx product over the limits in this data guide.
Excessive voltage or extended operation at the maximum voltage could
cause product failure. Exceeding the reflow temperature profile could
cause product failure which is not immediately evident.
Do not make any physical or electrical modifications to any Linx
product. This will void the warranty and regulatory and UL certifications
and may cause product failure which is not immediately evident.
Description
Features
Ordering Information
Absolute Maximum Ratings
Electrical Specifications
Typical Performance Graphs
Pin Assignments
Pin Descriptions
Pre-Certified Module Pin Assignments
Module Dimensions
Theory of Operation
Module Description
Overview
Addressing Modes
Automatic Addressing
Address Register Use
Acknowledgements and Assured Delivery
Frequency Hopping Spread Spectrum
Compatibility with the 250 Series
Networking
Transmitting Packets
Receiving Packets
Using the Buffer Empty (BE) Line
Exception Engine
Carrier Sense Multiple Access (CSMA)
Using the Command Response (CRESP) Line
Using the CMD Line
External Amplifier Control
AES Encryption
38^
39^
40^
40^
42^
43^
44^
45^
45^
48^
95^
96^
96^
97^
98^
98^
98^
100^
102^
102^
103^
104^
105^
106^
107^
108^
108^
108^
110^
112^
114^
Using the MODE_IND Line
Using the PB Line
Restore Factory Defaults
Using the Low Power Features
The Command Data Interface
Reading from Registers
Writing to Registers
Command Length Optimization
Example Code for Encoding Read/Write Commands
The Command Data Interface Command Set
Typical Applications
Usage Guidelines for FCC Compliance
Additional Testing Requirements
Information to the user
Product Labeling
FCC RF Exposure Statement
Antenna Selection
Castellation Version Reference Design
Power Supply Requirements
Antenna Considerations
Interference Considerations
Pad Layout
Microstrip Details
Board Layout Guidelines
Helpful Application Notes from Linx
Production Guidelines
Hand Assembly
Automated Assembly
General Antenna Rules
Common Antenna Styles
Regulatory Considerations
HumPROTM Series 900MHz
Data Guide
0.55"
(13.97)
Description
The HumPROTM Series is a frequency hopping
spread spectrum (FHSS) transceiver designed
for the reliable transfer of digital data. It has a
very fast lock time so that it can quickly wake
up, send data and go back to sleep, saving
power in battery-powered applications. The
module is available in the 915MHz frequency
band.
0.45"
(11.43)
0.07"
(1.78)
Figure 1: Package Dimensions
The module has several features that increase the data transfer reliability. It
ensures that no other modules are transmitting before it begins transmitting
data. Automatic acknowledgements ensure that the remote side received
valid data. Multiple hopping patterns enable several systems to operate
in proximity without interference. A standard UART interface is used for
module configuration and data transfer. A few simple serial commands are
all that are needed for configuration.
All modules have a unique 32-bit serial number that can be used as an
address. Source and destination addressing support point-to-point and
broadcast links. Address masking by the receiving module allows for
creating subnets. Other network topologies can also be implemented.
Housed in a tiny compact reflow-compatible SMD package, the transceiver
requires no external RF components except an antenna, which greatly
simplifies integration and lowers assembly costs. Versions are available that
have obtained FCC and Industry Canada modular certification.
Features
FHSS Algorithm
Fast Lock (
很抱歉,暂时无法提供与“HUM-900-PRO-CAS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+452.34720
- 256+180.48960
- 512+174.46320
- 1024+171.48240
