HUM-900-RC-CAS
HUM-900-RC-CAS
    LINXTECHNOLOGIES(灵思)
    SMD32
    HUM-900-RC-CAS
HUM-900-RC-CAS 数据手册
HumRC TM Series Remote Control and Sensor Transceiver Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 2^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 18^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does have a frequency hopping protocol built in, but the developer should still be aware of the risk of interference. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 3^ 6^ 16^ 16^ 19^ 20^ 21^ 22^ 23^ 24^ 24^ 25^ 25^ 26^ 27^ 27^ 28^ 28^ 29^ 30^ 32^ 32^ 33^ 34^ Description Features Ordering Information Absolute Maximum Ratings Electrical Specifications Typical Performance Graphs Pin Assignments Pin Descriptions Pre-Certified Module Pin Assignments Module Dimensions Theory of Operation Module Description Transceiver Operation Transmit Operation Receive Operation Acknowledgement Automatic Responses Permissions Mask The Pair Process Configuring the Status Lines External Amplifier Control Mode Indicator Reset to Factory Default Using the LVL_ADJ Line Receiver Duty Cycle Using the LATCH_EN Line Using the Low Power Features Triggered Transmissions Frequency Hopping 36^ 38^ 40^ 42^ 44^ 44^ 45^ 46^ 46^ 46^ 48^ 50^ 50^ 51^ 52^ 53^ 54^ 55^ 56^ 56^ 56^ 58^ 60^ 62^ The Command Data Interface Serial Setup Configuration for Stand-alone Operation Basic Hardware Operation Typical Applications Usage Guidelines for FCC and IC Compliance Additional Testing Requirements Information to the user Product Labeling FCC RF Exposure Statement Antenna Selection Castellation Version Reference Design Power Supply Requirements Antenna Considerations Interference Considerations Pad Layout Microstrip Details Board Layout Guidelines Helpful Application Notes from Linx Production Guidelines Hand Assembly Automated Assembly General Antenna Rules Common Antenna Styles Regulatory Considerations HumRC TM Series Remote Control and Sensor Transceiver Data Guide Description 0.55" (13.97) The HumRC™ Series transceiver is designed for reliable bi-directional remote control 0.45" applications. It consists of a highly optimized (11.43) Frequency Hopping Spread Spectrum (FHSS) RF transceiver and integrated remote control transcoder. The FHSS system allows higher RF output power and, therefore, longer range than narrowband radios. It also provides Figure 1: Package Dimensions much more noise immunity than narrowband radios, making the module suitable for use in noisy environments. 0.07" (1.78) Eight status lines can be set up in any combination of inputs and outputs for the transfer of button or contact states. A selectable acknowledgement indicates that the transmission was successfully received. Versions are available in the 902 to 928MHz and 2,400 to 2,483MHz frequency bands. Primary settings are hardware-selectable, which eliminates the need for an external microcontroller or other digital interface. For advanced features, optional software configuration is provided by a UART interface; however, no programming is required for basic operation. Housed in a compact reflow-compatible SMD package, the transceiver requires no external RF components except an antenna, which greatly simplifies integration and lowers assembly costs. Features • • • • • • • Low power consumption 232 possible addresses 8 status lines Bi-directional remote control Analog voltage and sensor inputs Low power receive modes Selectable acknowledgements • No external RF components required • No programming/tuning required • Serial interface for optional software operation/configuration • Tiny PLCC-32 footprint – 1 – Revised 9/15/2016 Ordering Information Electrical Specifications HumRC™ Series Transceiver Specifications Ordering Information Part Number Description Parameter Symbol Min. HUM-***-RC HumRC™ Series Remote Control Transceiver Power Supply HUM-900-RC-UFL HumRC™ Series Remote Control Transceiver, Certified, UFL Connector Operating Voltage VCC 2.0 HUM-900-RC-CAS HumRC™ Series Remote Control Transceiver, Certified, Castellation Connection Peak TX Supply Current lCCTX Typ. Max. Units 3.6 VDC Notes 2.4GHz at +1dBm 28 29 mA 1,2 19 20 mA 1,2 EVM-***-RC HumRC™ Series Carrier Board 2.4GHz at –10dBm EVM-900-RC-UFL HumRC™ Series Carrier Board with Certified module, UFL Connector 900MHz at +10dBm 36 38.5 mA 1,2 900MHz at 0dBm 22 24 mA 1,2 EVM-900-RC-CAS HumRC™ Series Carrier Board with Certified module, Castellation Connection MDEV-***-RC HumRC™ Series Master Development System 22 24 mA 1,2 27.5 28.5 mA 1,2 EVAL-***-RC Average TX Supply Current 2.4GHz at +1dBm 900MHz at +10dBm HumRC™ Series Basic Evaluation Kit *** = Frequency; 900MHz, 2.4GHz Figure 2: Ordering Information RX Supply Current lCCRX 25.5 28 mA 1,2,3 Standby Current lSBY 0.5 1.4 µA 1,2 Power-Down Current lPDN 0.5 1.4 µA 1,2 RF Section Operating Frequency Band Absolute Maximum Ratings Absolute Maximum Ratings Supply Voltage Vcc −0.3 to +3.9 Any Input or Output Pin −0.3 to VCC + 0.3 RF Input 0 VDC VDC dBm Operating Temperature −40 to +85 ºC Storage Temperature −40 to +85 ºC Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. Figure 3: Absolute Maximum Ratings FC MHz HUM-2.4-RC 2400 2483.5 MHz HUM-900-RC-ttt 902 928 MHz Number of Channels 25 Channel Spacing HUM-2.4-RC 2.03 MHz HUM-900-RC-ttt 500 kHz 38.4 kbps Modulation Rate Receiver Section Spurious Emissions -47 dBm Receiver Sensitivity 5 HUM-2.4-RC –95 –99 dBm 5 HUM-900-RC-ttt –94 –98 dBm 5 85 dB 0 +1 dBm 6 +8.5 +9.5 dBm 6 –41 dBc 6 RSSI Dynamic Range Transmitter Section Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. – 2 – Output Power PO HUM-2.4-RC HUM-900-RC-ttt Harmonic Emissions PH – 3 – TX Vcc HumRC™ Series Transceiver Specifications Parameter Symbol Min. Typ. Max. Units Notes Output Power Control Range VON TX Sx TX MODE_IND HUM-2.4-RC 56 dB 6 HUM-900-RC-ttt 40 dB 6 RX Sx 50 Ω 4 RX MODE_IND ºC 4 Antenna Port RF Impedance RIN Environmental Operating Temp. Range −40 +85 Timing Item Via VCC 108 ms 4 Via POWER_DOWN 57 ms 4 Via Standby 57 ms 4 Serial Command Response Status, Volatile R/W 1 10 ms 8 Analog Input Reading 6 16 ms 8 NV Update, Factory Reset 80 110 ms 8 IU to RU Status High 50 ms 7 Channel Dwell Time 13.33 ms C D E F 0.3*VCC VDC Input Logic Low VIL Logic High VIH 0.7*VCC Description BC – RX Initial Response – 8 to 50ms with no interference 1,4 TX Settle Response CD – Data – 4 tofrom 8usVCC or POWER_DOWN 2 AB– Data TXUpdate Response from Status line while IU in–idle EF Delay During Active Session 5 to 25ms EG – Shutdown Duration – 25 to 342ms TX Response from Status line while IU / RU idle in RX3 GH – RX MODE_IND Drop – 6 to 8ms BC RX Initial Response 1. 2. 3. Interface Section 4. CD Data Settle G H VOLM Logic High, MODE_IND, CONFIRM VOHM Logic Low VOL Logic High VOH 0.3*VCC 0.7*VCC 0.3*VCC 0.7*VCC VDC 1,9 VDC 1,9 8ms 12ms 1ms 4ms 50ms 4µs 8µs Data Update Delay During Active Session 5ms 25ms Shutdown Duration 25ms 342ms GH RX MODE_IND Drop 6ms 8ms From module off to VCC applied The module is set as an IU only and is in idle pending status line activation The module is set as an IU and RU and is idling in receive mode pending status line activation or receipt of a valid packet. Maximum 80ms if VCC < 2.6V 1,10 1,10 7. 8. No RF interference From end of command to start of response 9. 60mA source/sink 10. 6mA source/sink Figure 4: Electrical Specifications – 4 – Maximum EF Figure 5: HumRCTM Series Timings Logic Low, MODE_IND, CONFIRM Minimum EG VDC Output Measured at 3.3V VCC Measured at 25ºC Input power < –60dBm Characterized but not tested PER = 5% Into a 50-ohm load B AB – TX Power up Response –
HUM-900-RC-CAS 价格&库存
很抱歉,暂时无法提供与“HUM-900-RC-CAS”相匹配的价格&库存,您可以联系我们找货
HUM-900-RC-CAS
    • 1+524.46960
    • 256+209.27160
    • 512+202.28400
    • 1024+198.82800
