BL620-SA
BL620-SA
    LAIRD(莱尔德)
    模块
    RF TXRX MOD BLUETOOTH CHIP ANT
BL620-SA 数据手册
BL620 Series Central Mode BLE Module Featuring smart BASIC The BL600 Series modules from Laird have been enhanced with the addition of the BL620 part numbers. The BL620 uses the same module hardware as the BL600 but has a new firmware supporting Central mode connectivity. The BL620 makes it easy to add single-mode Bluetooth Low Energy (BLE), also known as Bluetooth Smart™, to small, portable, power-conscious devices, including those powered by AAA or coin cell batteries. The unique feature of this module is smartBASIC, an event-driven programming language that enables standalone operation of the module. smartBASIC on BL620 enables wireless connections to peripheral devices that are in turn connected to sensors so that the data can be collected via GATT operations. smartBASIC has been proven to speed time to market and significantly simplifies BLE integration for embedded devices. Based on the award winning Nordic Semiconductor nRF51822 chipset, BL620 modules provide exceptionally low power consumption with outstanding wireless range, all within a compact footprint of 19 mm x 12.5 mm. The modules incorporate all the hardware and firmware required to support development of BLE Central mode applications, including:       Support Portal: http://ews-support.lairdtech.com USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/bluetooth Radio hardware UART, SPI, I2C, ADC, and GPIO interfaces for connecting peripherals and sensors A complete BLE software stack Central role functionality with GATT client and server - Ability to connect up to four simultaneous connections Custom Services to suit any application’s needs Series addition of a packaged USB Dongle - BL620-US The BL620-US USB Dongle has been developed to take advantage of the BL620 module, providing the ability to add BLE Central Mode capabilities to Windows operating systems supporting a USB interface and virtual COM port. The control and configuration is via a standard virtual COM port and smartBASIC. The dongle provides the ability to load smartBASIC applications over the air (OTA) to a BL600 peripheral mode module. In addition to carrying FCC modular, IC, and CE approvals, BL620 modules are fully qualified as a Bluetooth End Products, enabling designers to integrate the modules in devices without the need for further Bluetooth Qualification testing. Customers can use the DVK-BL600 series low-cost developer’s kit including simple software tools to develop with the BL620 central mode firmware. BL620 Series Central Mode BLE Module Featuring smart BASIC CATEGORIES Wireless Specification Host Interfaces FEATURE Bluetooth® Frequency Max Transmit Power Receive Sensitivity Whisper Mode Link Budget Raw Data Rates Total UART GPIO SPI I2C ADC Services Control Protocols Encryption Supply Voltage AES Supply Power Consumption Current Physical Environmental Dimensions Operating Temperature Miscellaneous Development Tools Approvals Storage Temperature Lead Free Warranty Development Kit Bluetooth® FCC / IC / CE IMPLEMENTATION V4.0 – Single-Mode – Central mode 2.402 - 2.480 GHz 4dBm -91dBm (typical) Down to -55dBm (Transmit) 95 dB (@ 1 Mbps) 1 Mbps (over the air) 28 lines – multi function TX, RX, CTS, RTS DTR, DSR, DCD, RI can be implemented in smartBASIC (CTS, RTS, DTR, DSR, DCD, and RI are NOT connected on the BL620-US) Default 9600, N, ,8, 1 From 1,200 to 115,200bps Up to 28 lines 3 lines 2 lines 6 lines (plus ADC reference) GATT Client and Server Capability Any that can be implemented using smartBASIC 128 bit using CCM encryption 1.8V – 3.6V – internal LDO 2.1V – 3.6V – internal DCDC converter ‘System Idle’ – 3.5uA ‘Transmit’ – 10.5mA @ 0dBm 19mm x 12.5mm x 3mm -40° to +85° C when powered at 3.3 V +/- 10% -25° to +75° C when powered at 1.8V (contact Laird for any query) -40°C to +85°C Lead-free and RoHS compliant Limited Lifetime Warranty Development board and free Software Tools ** End Product Listing (EPL) All BL620 Series *The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/bluetooth for the most current specification. Ordering Information BL620-SA-0x BL620-SC-0x BL620-ST-0x BL620-US-0x DVK-BL600-SA / ST / SC-0x Single Mode BLE Module featuring smartBASIC (internal antenna) Single Mode BLE Module featuring smartBASIC (IPEX MHF4 antenna connector) Single Mode BLE Module featuring smartBASIC (trace pin) Packaged BL620 USB Dongle Development kit for each BL620 series module **Use standard DVK-BL600 and upgrade the firmware Version 1.0 Date 10/15/14 Description Initial Release Approver JK
BL620-SA 价格&库存
很抱歉,暂时无法提供与“BL620-SA”相匹配的价格&库存,您可以联系我们找货
