ZM2102
Datasheet
Integrated Z-Wave RF Module
The ZM2102 Z-Wave Module is a fully integrated RF
communication module that uses the unlicensed Short-RangeDevice (SRD) frequency band of 868.42MHz in Europe and
908.42MHz in US. The ZM2102 is dedicated for wireless control
and monitoring of residential products like lighting and appliance
control, energy management, access control, security and building
automation.
Together with the patented Z-Wave Protocol the ZM2102 Z-Wave
Module delivers a complete highly reliable RF communication
solution. The Z-Wave Protocol uses Frame Acknowledgement,
Retransmission, Collision Avoidance, Frame Checksum Check and
sophisticated Routing to assure reliable full home coverage.
Features
Interfaces
10 General Purpose I/O’s
Two Interrupt Inputs
Serial UART
SPI Interface
Triac Control Interface
PWM Output
Four multiplexed 12/8 bit
ADC inputs
ZW0201 Single Chip
Optimized 8051 CPU Core
32kbyte Flash
2kbyte SRAM
Power-On-Reset / BrownOut Detection
Supply Voltage: 2.1V-3.6V
Power Consumption
o TX@-5dBm = 24mA
o TX@0dBm = 36mA
o RX = 23mA
o Power down/sleep
mode = 2.5μA
RF
Freq: 908.42MHz (US) /
868.42MHz (EU)
High Sensitivity
(-102/-98dBm)
FSK Modulation
9.6kbps/40kbps Data Rate
-20dBm to 0dBm Output
power (ZW0201)
Complies with EN 300 220
and FCC CFR47 part 15
The ZM2102 Z-Wave Module contains the integrated ZW0201
Z-Wave Single Chip, system crystal and RF front-end circuitry. The
ZW0201 Single Chip is an integrated chip containing RF
Transceiver, 8051 MCU core, SRAM, Flash Memory for Z-Wave
Protocol and OEM Application software storage, Triac Controller
and a wide range of HW interfaces.
This complete RF solution makes it very easy for OEM customers
to RF enable their products without having to do the time
consuming work of designing, verifying and optimizing the RF
design and thereby enables faster time to market.
Zensys A/S
Applications
o
o
o
o
Home Automation
Lighting/Drape Control
Automated Meter Reading
Access Control
Universal Remote
Controls
Page 1 of 14
DSH10229-11-11
ZM2102 Z-Wave Module Datasheet
2006-11-10
Table of Contents
1
PRODUCT DESCRIPTION ...................................................................................................................3
1.1 Overview................................................................................................................................................3
1.2 Signal Description..................................................................................................................................4
1.3 RF Front-End.........................................................................................................................................5
1.3.1
RF input/output ...........................................................................................................................5
1.3.2
Antenna Matching.......................................................................................................................5
1.4 Z-Wave Module Programming ..............................................................................................................6
2
SPECIFICATIONS ................................................................................................................................7
2.1 ZW0201 Specification ...........................................................................................................................7
2.2 ZW0201 Single Chip Peripherals ..........................................................................................................7
2.3 RF Specification ....................................................................................................................................7
2.4 Electrical Specification ..........................................................................................................................8
2.4.1
Absolute Maximum Ratings........................................................................................................8
2.4.2
DC Characteristics......................................................................................................................8
2.5 Physical Specification............................................................................................................................9
2.6 Process Specification ............................................................................................................................9
2.7 Recommended PCB Footprint Outline................................................................................................10
2.8 Recommended Reflow Profile.............................................................................................................11
2.9 Application PCB Layout Recommendation .........................................................................................11
2.9.1
Supply Voltage .........................................................................................................................11
2.9.2
Ground Plane ...........................................................................................................................12
2.9.3
Antenna Interconnection...........................................................................................................12
3
SOFTWARE ........................................................................................................................................13
3.1 SPI Interface........................................................................................................................................13
3.2 EEPROM .............................................................................................................................................13
4
REFERENCES ....................................................................................................................................14
Zensys A/S
Product Description
CONFIDENTIAL
Page 2 of 14
DSH10229-11-11
2006-11-10
1 PRODUCT DESCRIPTION
1.1
Overview
The ZM2102 Z-Wave Module is a fully integrated module containing all the HW and SW required to
Z-Wave enable OEM products. The ZM2102 Z-Wave Module contains the Z-Wave ZW0201 Single Chip,
System Crystal, RF Front-end and RF Supply Voltage Filtering. Only the antenna needs to be
implemented by the developer designing the Z-Wave enabled product.
RF Supply
Voltage
Filtering
System
Crystal
Decoupling
ZW0201 Single Chip
32K bytes
Flash Memory
Z-Wave SW API
and
Application SW
2 kbytes
SRAM
Interrupt
Ctrl
General
Purpose
Timer
Pwr-On
POR/
Brownout
out
Timer 0/1
Watchdog
8/12 Bit
ADC
RF Transceiver
256 bytes
SRAM
UART
Triac
Ctrl
System
Clock
WUT
RF Front-End
8051W
CPU
Power
Mgt.
SPI
Ctrl
SFR
Modem
I/O Interfaces
Figure 1 ZM2102 Z-Wave Module Block Diagram
The ZM2102 Z-Wave Module contains a system crystal, why no external crystal is needed. In order to
get a high reliable and high performance RF communication, the RF Front-end has an optimized and
throughout tested matching circuitry, a narrow band SAW filter dedicated for Z-Wave communication and
there are filtering of the RF circuitry supply voltage.
The ZM2102 Z-Wave Module is connector-less using Castellation Notches for easy mounting of the
module to an OEM Application PCB. The ZM2102 Z-Wave Module has a top shield that improves noise
immunity of the module and enables the module to be mounted by a standard pick-and-place machine
on the production line.
The Z-Wave Protocol is designed to enable automatic network address assignment at installation, and
simple inclusion/exclusion of nodes. These protocol-handling techniques ensure easy installation,
expansion, and management of the Z-Wave control network. Furthermore each Z-Wave network has its
own unique Network Identifier preventing control problems or interference from neighboring networks.
The Z-Wave Protocol has a well-defined Application-Programming-Interface (API) enabling easy and fast
Application SW development.
Zensys A/S
Product Description
CONFIDENTIAL
Page 3 of 14
DSH10229-11-11
1.2
2006-11-10
Signal Description
6
5
4
3
2
1
Notch #
7
8
18
9
10
11
17
ZM2102
US 908.42MHz
0310
12 13 14 15
16
Signal Name
1
GND
2
RESET_N
3
P1.7 / INT1
4
P1.6 / PWM / INT0
5
P1.5
6
GND
7
P1.2 / MISO
8
P1.4 / SCK
1
9
P1.3 / MOSI
1
1
10
P1.1 / ADC3 / RXD
11
VCC
12
GND
13
P0.1 / ADC1 / TRIAC
14
P0.0 / ADC0 / ZEROX
15
P1.0 / ADC2 / TXD
16
GND
17
GND
18
RF in/out
Figure 2 ZM2102 Outline and Signals
Name
Notch #
I/O
ADC[3:0]
10, 13,
14, 15
I
GND
1, 6, 12,
16, 17
Power
3, 4
I/O
Interrupt: The signal can be either level or edge trigged. When in
power down mode, the ZM2102 Z-Wave Module’s MCU can be
woken up by asserting the interrupt signal.
3, 4, 5,
7, 8, 9,
10, 13,
14, 15
I/O
In/Out: General purpose I/O signal.
MISO1
7
I/O
Master-In-Slave-Out SPI interface: output in slave mode
operation and input in master mode operation.
MOSI1
9
I/O
Master Out Slave In SPI interface: input in slave mode operation
and output in master mode operation.
PWM
4
I/O
Pulse Width Modulator Output: Used for frequency variation
applications.
INT[1:0]
P[0.1-0.0],
P[1.7-1.0]
Zensys A/S
Description
Analog-to-Digital Converter input. The ADC is 12/8 bit and can
use either VCC or an internal/external voltage as reference.
ADC3: input
ADC2: input
ADC1: input / lower reference
ADC0: input / higher reference
Ground signal
Product Description
CONFIDENTIAL
Page 4 of 14
DSH10229-11-11
Name
2006-11-10
Notch #
I/O
RESET_N
2
I
RF
18
I/O
RF Input/Output
RXD
10
I/O
UART Receive Data: Supports 9.6kbaud, 38.4kbaud,
115.2kbaud.
SCK1
8
I/O
SPI Clock: Can be used as either master SPI clock output or
slave SPI clock input.
TRIAC
13
I/O
TRIAC Control: A triac controller is implemented in the ZW0201
Single Chip that can controls a triac on the Application Module
like light dimmer modules etc.
TXD
15
I/O
UART Transmit Data: Supports 9.6kbaud, 38.4kbaud,
115.2kbaud.
VCC
11
Power
ZEROX
14
I/O
1.
Description
Reset: Active low reset. The ZW0201 Single Chip has an
integrated Power-On-Reset and Brown-out detection circuitry.
ZM2102 supply voltage.
Zero Cross Detection: Zero cross detection signal used on
dimmer modules detecting 120/240V zero crossing.
Please note that the SPI interface (MISO, MOSI and SCK) is not available for the Application SW in some Z-Wave protocol
API’s, see [3]
Table 1 ZM2102 Signal Description
All signals in Table 1 except RF, VCC and GND are connected directly to the corresponding signals on
the ZW0201 Z-Wave Single Chip on the ZM2102 Z-Wave Module. A detailed description of these signals
is given in the ZW0201 Z-Wave Single Chip datasheet [1].
1.3
1.3.1
RF Front-End
RF input/output
The ZM2102 Z-Wave Module is equipped with a SAW filter that rejects the unwanted frequencies both in
receive and transmit operations.
ZM2102
ZW0201
RF IN/OUT
SAW
18
Figure 3 ZM2102 RF Front-end Circuitry
The RF input/output on the ZW0201 is a single ended input/output that is internally matched to 50 ohm.
1.3.2
Antenna Matching
The ZM2102 Z-Wave Module is using an antenna placed on the Application Module, the matching of the
external antenna to 50 ohm (SAW filter impedance) must be made on the Application Module.
As the ZM2102 Z-Wave Module is integrated into various products, different types of antennas can be
implemented to get the best RF performance, i.e. range and reliability. In [4], a good overview of the
Zensys A/S
Product Description
CONFIDENTIAL
Page 5 of 14
DSH10229-11-11
2006-11-10
different antennas is given as well as their pro’s and con’s. In the case the antenna is not 50ohm a
matching network must be implemented between the ZM2102 Z-Wave Module and the antenna. The
matching network can for example be a “pi” or a “T” structure as shown in Figure 4.
ZM2102
“T”
t t
“π”
ZM2102
pin 18
pin 18
Antenna
Antenna
Figure 4 “π” ant “T” structure for the antenna-matching network
1.4
The ZM2102 Z-Wave Module is programmed using the SPI interface and the RESET_N signal. For
detailed programming instructions see [2] and recommended programming tool(s) see [3].
Zensys A/S
Product Description
CONFIDENTIAL
Page 6 of 14
DSH10229-11-11
2006-11-10
2 SPECIFICATIONS
2.1
MCU
MCU Type
MCU speed
Flash
SRAM
SRAM (CPU)
MCU Peripherals
Interrupt sources
Description
Optimized 8-bit 8051 MCU core.
16 MHz (integrated clock divider, external crystal frequency is 32MHz)
32kbyte. Programmed through the SPI interface.
2kbyte
256byte
12/8-bit ADC, UART, SPI, 2x16 bit timers one with PWM mode, Watch
Dog Timer, Wake Up Timer, Power-on Reset/Brown-Out Detector.
Internal and external.
Table 2
2.2
MCU Specifications
Peripherals
Crystals
Optional Peripherals
Description
System Clock: 32MHz, ±10ppm@25°C, ±10ppm@-15°C to +85°C, 3ppm
aging per 5 years.
Alternative: 32MHz, ±8ppm@25°C, ±8ppm@-15°C to +85°C, 3ppm aging
per year.
EEPROM
Table 3
2.3
External Peripherals
RF Specification
RF
RF Data rate
RF frequency (center
frequency)
Modulation
Frequency deviation
Signal coding
RF filter
Typical RF receiver
sensitivity
ZW0201 RF Output Power
(RF transceiver output)
RF Input/Output Impedance
Range (typical)
RF regulatory
Description
9.6 kbps
40kbps
US: 9.6kbps: 908.42 MHz, 40kbps: 908.40 MHz
EU: 9.6kbps: 868.42 MHz, 40kbps: 868.40 MHz
Frequency Shift Keying (FSK)
Center frequency ± 20kHz
9.6kbps: Manchester Encoded
40kbps: NRZ
SAW Filter
US: Center frequency = 908MHz, BW = 20MHz
EU: Center frequency = 868MHz, BW = 20MHz
9.6kbps: -102dBm (including SAW filter)
40kbps: -98dBm (including SAW filter)
-20dBm to 0dBm
Typical Saw filter insertion loss: 2.2dB
50ohm @ respective EU/US frequencies
Indoor >30 meters line of sight, in unobstructed environment.
Outdoor > 60 meters line of sight
US: FCC Part 15
EU: R&TTE Directive 1999/5/EC, EN 300 220-3/2000
Table 4
Zensys A/S
RF Specifications
Specifications
CONFIDENTIAL
Page 7 of 14
DSH10229-11-11
2.4
2006-11-10
The “Absolute Maximum Ratings” specifies the conditions in which the ZM2102 Z-Wave Module is
guaranteed not to be damaged but correct operations are not guaranteed. Exceeding the “Absolute
Maximum Ratings” may destroy the ZM2102 Z-Wave Module. See “DC Characteristics” for guaranteed
operation limits.
2.4.1
Electrical
Value
Operating Temperature
-15°C to +85°C
Storage Temperature
-40°C to +85°C
Voltage on input pins
-0.3V to VCC+0.3V
Minimum Operating Voltage (VCC)
-0.3V
Maximum Operating Voltage (VCC)
4V
Table 5
2.4.2
DC Characteristics
The following DC characteristics are preliminary for the ZM2102 Z-Wave Module.
TA = 25°C, VCC = 3.3V (unless otherwise noted)
Symbol
Parameter
VCC
Digital Supply
Voltage
RRST1
Reset Pull-up
Resistor
Continuous Output
Current
Total continuous
output source/sink
current
Transmitting
IC
ICTOT
(16MHz system
2
clock)
Condition
Min
Typ
Max
Units
2.1
3.3
3.6
V
Integrated in ZW0201
10
One GPIO
-20
mA
All GPIO’s
-100
100
mA
Pout = -5dBm (Setting: 1B)
Pout = +0dBm (Setting: 2A)
Receiving
ICC
MΩ
24
36
mA
23
mA
2.5
μA
(16MHz system
3
clock)
Power Down4
TOP
Operating
Temperature
HOP
Operating Relative
Humidity
1.
2.
3.
4.
85
°C
8
80
The integrated Reset pull up is not for external circuitry. An external pull up resistor should be implemented.
The transceiver is in transmit mode with the MCU running. The ADC is off. The crystal is 32MHz.
The transceiver is in receive mode with the MCU running. The ADC is off. The crystal is 32MHz.
The ADC, transceiver, MCU and flash are shut down. The chip can be woken by brownout, an external reset
pulse, external interrupt (if enabled) or periodical wakeup by WUT (if enabled). POR cannot be disabled.
Table 6
Zensys A/S
-10
DC Characteristics
Specifications
CONFIDENTIAL
Page 8 of 14
DSH10229-11-11
2.5
2006-11-10
Description
Size
12.5mm. x 13.6mm. x 2.4mm (0.492” x 0.535” x 0.094”)
Weight
7g (with shield)
5g (without shield)
18
Table 7 Physical Specifications
2.6
Specification
Description
MSL-3
Moisture Level Verification tested according to JEDEC J-STD-020C
RoHS
Designed in compliance with The Restriction of Hazardous
Substances Directive (RoHS)
Table 8 Process Specifications
Zensys A/S
Specifications
CONFIDENTIAL
Page 9 of 14
DSH10229-11-11
2.7
2006-11-10
5.05 mm.
6.55 mm.
8.05 mm.
9.55 mm.
11.80 mm.
5
4
3
2
1
15.40 mm.
3.55mm.
0 mm.
6
14.30 mm.
10.15 mm.
7
8.65 mm.
8
7.15 mm.
9
5.65 mm.
10
4.15 mm.
11
17
6.90 mm.
15.40 mm.
1.40mm.
1.10mm.
1.45mm.
1.40mm.
8.65 mm.
16
11.80 mm.
6.55 mm.
15
9.55 mm.
14
8.05 mm.
13
5.05 mm.
0 mm.
12
3.55mm.
0 mm.
18
Ø0.55mm.
Ø0.70mm.
Figure 5 Recommend ZM2102 PCB footprint Outline
Zensys A/S
Specifications
CONFIDENTIAL
Page 10 of 14
DSH10229-11-11
2.8
2006-11-10
Figure 6 Recommended Reflow Temperature Profile
2.9
2.9.1
Supply Voltage
As the ZM2102 Z-Wave Module contains a RF transceiver good supply voltage decoupling is important.
Two decoupling capacitors should be placed at the VCC pin (EP11) a 4.7uF and a 100nF capacitor is
recommended. The two capacitors should be placed as close EP11 as possible and the capacitor should
be placed between the ZM2102 Z-Wave Module and the via that goes to the power plane as shown in
Figure 7.
Figure 7 Placement of decoupling capacitor (power pin, EP11)
Zensys A/S
Specifications
CONFIDENTIAL
Page 11 of 14
DSH10229-11-11
2.9.2
2006-11-10
Ground Plane
In order to minimize any noise coupling from noisy signals (typically power products) it is recommended
to insert as much ground cobber below the ZM2102 Z-Wave Module as possible on the Application PCB.
2.9.3
As the RF signal (EP18) is 50ohm the trace from the EP18 to the matching circuitry (see 1.3.2) must be
50ohm. The Application PCB designer must therefore take the PCB layer structure and thickness into
account when designing the 50ohm trace (either Microstrip or Stripline).
Zensys A/S
Specifications
CONFIDENTIAL
Page 12 of 14
DSH10229-11-11
2006-11-10
3 SOFTWARE
3.1
SPI Interface
The signals ‘P1.2/MISO’, ‘P1.4/SCK’ and ‘P1.3/MOSI’ signals are in some SW API’s used by the protocol
to store Routing Tables and HomeID in an external EEPROM. When these SW API’s are used, the
Application SW must not use these three signals. Table 9 shows the available SW API’s and in which the
SPI interface is used by the protocol.
SW API
SPI interface used by
Protocol
Slave
No
Routing Slave
No
Enhanced Slave
Yes
Controller
Yes
Static Controller
Yes
Installer
Yes
Bridge
Yes
Table 9 SW API / SPI availability
3.2
EEPROM
Some SW API’s require an external EEPROM to be implemented on the Application PCB for protocol
information storage (like routing table, HomeID etc.). The SPI interface is used to access the EEPROM
and the ‘P1.5’ signal (EP5) is used by the Z-Wave Protocol as EEPROM Chip Select. To assure proper
control of the EEPROM chip select signal during reset and power-up a pull up resistor on the P1.5 should
be implemented as shown in Figure 8.
+3.3
R1
10k
+3.3
U1
P1.5
MOSI
MISO
SCK
8
1
3
7
5
2
6
4
VCC
CS
WP
HOLD
SI
SO
SCK
GND
C1
33nF
AT25128N
Figure 8 External EEPROM
Only a part of the EEPROM is used for protocol data storage, the Application SW can use the remaining
memory area using an API call (see [3]). For the EEPROM memory area requirements of the protocol
API please refer to the documentation for the Z-Wave Controller code selected (see [3]).
Zensys A/S
Software
CONFIDENTIAL
Page 13 of 14
DSH10229-11-11
2006-11-10
4 REFERENCES
Always refer to latest document revision.
[1]
[2]
[3]
[4]
Zensys, DSH10560, Datasheet, ZW0201 with Developers Kit v4.1x
Zensys, APL10312, Application Note, Programming the 200-Series Z-Wave Single Chip Flash
Zensys, INS10247, Instruction, Z-Wave ZW0102/ZW0201 Application Programming Guide
Zensys, APL10045, Application Note, Antennas for Short Range Devices
Zensys A/S
References
CONFIDENTIAL
Page 14 of 14
