DATA SHEET
Transceiver Modules
TCM 3X0 and TCM 3X0C
The transceiver modules TCM 3x0 and TCM
3x0C enable the realization of highly efficient RF repeaters and transceivers for the
EnOcean 868 MHz and 315 MHz radio systems.
The module provides several built-in operating
modes. In addition a repeater functionality
(1 or 2 level) can be activated. Using the Dolphin
API library it is possible to write custom software
for the module. TCM 3x0/3x0C is in-system programmable.
Built-in operating modes
Unidirectional serial communication
Bidirectional serial communication
1-channel relay mode
4-channel relay mode
1-channel dimming mode
Features accessible via API:
Integrated 16MHz 8051 CPU with
32KB FLASH and 2kB SRAM
Various power down and sleep modes
down to 0.2µA current consumption
Up to 14 configurable I/Os
10bit ADC, 8bit DAC
© 2010 EnOcean | www.enocean.com
Energy Harvesting made easy with
EnOcean wireless standard
TCM 300 is a bidirectional system module for
maintenance-free sensor solutions based on the
EnOcean wireless standard.
Product variants
TCM 300/300C: SMD mountable module for
use with external antenna (868/315 MHz)
TCM 320/320C: Variant for vertical mounting
with pin connector. Whip antenna
(868/315 MHz). TCM 320C is backward compatible to TCM 220C
Type
Ordering Code
TCM
TCM
TCM
TCM
S3003-K300
S3003-K320
S3033-K300
S3033-K320
300
320
300C
320C
Subject to modifications | May 2010
DATA SHEET
EnOcean Dolphin System Architecture.
Open. Flexible. Expandable.
The distinguishing feature that sets Dolphin apart
from other wireless system architectures is energy
harvesting, which enables self-powered wireless
sensors and actuators. The Dolphin system architecture joins the components necessary for an energyautonomous wireless sensor system that operates
on a standardized wireless network. These include
energy conversion and storage components,
EnOcean wireless modules for energy management,
data acquisition, data processing and wireless data
transmission, and finally the software blocks operating system, API and application programs.
Benefits for OEM partner
Maintenance-free sensor solution with energy
harvesting
Simple expansion of portfolio to wireless-based
products using EnOcean wireless standard
Ready available and wide-ranging, interoperable
As an open and expandable hardware and software
architecture, Dolphin is future-oriented and fully
backward compatible with EnOcean-enabled devices
and system components already on the market.
system product portfolio
Fast implementation and time to market
Low investment in R&D, T&M, etc
Various evaluation tools obtainable to support
development
The hardware kernel of Dolphin is the EO3000I chip,
a basis for simply integrated modules. EnOcean
modules already have extensive firmware functionality implemented – such as basic switching, dimming and measuring – and can go straight into an
application without additional programming. Its
built-in application functions enable straightforward
start-up and system integration.
Features overview
Antenna
Frequency
Radio Standard
Data rate/Modulation type
Receiver Sensitivity (at 25°C)
Conducted Output Power
Power Supply
Current Consumption
Dimensions of PCB
Operating temperature
Radio Regulations
EnOcean Development Kit EDK 300 for TCM 300
Technical support
Competitive advantage over battery-powered
wireless solutions
New differentiated marketing advantages
Participation in EnOcean's eco-system
EnOcean is the wireless standard for sustainable
buildings
Pre-installed 9cm/15cm whip antenna (TCM 320/TCM 320C)
External whip or 50Ω antenna mountable (TCM 300/TCM 300C)
315.0 MHz (TCM 3X0C)/868.3 MHz (TCM 3X0)
Enocean 868 MHz/315 MHz
125 kbps/ASK
typ. –96 dBm (868MHz), -98 dBm (315MHz)
typ. 5 dBm
2.6V–3.3V (TCM 320/320C), 2.6V–4.5V (TCM 300/300C)
Receive mode: 33 mA
Transmit mode: 24 mA
TCM 320/320C: 36.5 x 18 x 5.5 mm (without pin connector)
TCM 300/TCM 300C: 22x19x3 mm
–25 up to +85°C
R&TTE EN 300 220 (TCM 300/TCM 320)
FCC CFR-47 Part 15 (TCM 300C/TCM 320C)
很抱歉,暂时无法提供与“TCM300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+176.320041+22.80298
