RF200PD1
RF200PD1
    SYNAPSE
    模块
    RF MODULE 250/500MBPS 2.4GHZ SMA
RF200PD1 数据手册
Wireless Technology to Control and Monitor Anything from Anywhere™ SYNAPSE RF Engines® Synapse offers a wide range of wireless modules that have been especially designed for ease of use and to speed up your product design time. Synapse designs modules with great care to ensure the best range possible. In addition to power amps to increase the transmit power we also use receive amps to provide 10 dBm additional link margin. We are also very careful to ensure that the maximum RF energy gets to the antenna instead of being wasted with poor antenna matching. Synapse’s modules offer a broad range of computing performance. From the entry level 8051 CPU all the way up to an ARM7 CPU, you have plenty of options regarding compute speed as well as available memory sizes. Each module comes with basic encryption built-in so that you can prevent casual attacks on the network and all modules have AES128 encryption available. RF Modules provide advantage over embedded RF designs:       All the RF design aspects have been taken care of for you RF certifications have already been completed No need to learn the electrical design requirements for the CPU Much faster design time to get your solution to prototype form rapidly Interchangeability of modules for different amplification or CPU needs without having to change your board footprint Simplified logistics - you have one component for RF and CPU requirements in your design instead of 20 to 30 components Our through-hole family of modules can be interchanged so that you can see how your project works at 2.4 GHz and then try it at 900 MHz using the same board footprint. And of course, all of our modules come with Synapse’s SNAP®, an award-winning, wireless mesh network operating system that is instant-on, self-healing, multi-hoping and supports over-the-air programming. The network is formed and managed for you automatically, and can even support wireless connectivity to Internet. SNAP provides an on-board Python interpreter for ease in writing applications. Synapse’s software development environment, Portal, is provided at no cost to developers. SNAP Mark™ scores represent Python instructions per second (see the RF module chart on the opposite side). This performance indicator measures the combination of IO and processor speed, and allows for a comparison of the relative performance of the application environment within each MCU. Synapse Wireless, Inc. 500 Discovery Drive, Huntsville, AL 35806 www.Synapse-Wireless.com (P) 256-852-7888 (TF) 877-982-7888 (F) 256-852-7862 Featuring SNAP Mark Wireless Technology to Control and Monitor Anything from Anywhere™ Synapse SNAP Modules Through-Hole Modules Surface-Mount Modules RF100PC6 RF100PD6 RF200P81 RF200PD1/ RF200PF1 11,400 11,400 39,240 39,240 3,952 3,952 3,952 39,240 3,952 3,952 43,500 39,240 User Application Scripts Uploadable Over-the-Air Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Core SNAP Network Upgradeable Over-the-Air No No No No No No No No No No Yes No SNAP Mark RF300PC1 RF300PD1 RF301PC1 / RF301PU1 RF266PC1 / RF266PU1 SM300PC1 SM301PC1/ SM301PU1 SM700PC1 / SM700PM1 SM200P81 Frequency Band 2.4 GHz 2.4 GHz 2.4 GHz 2.4 GHz 915 MHz 915 MHz 868 MHz 2.4 GHz 915 MHz 868 MHz 2.4 GHz 2.4 GHz Raw Bandwidth 250Kbps 250Kbps 2 Mbps 2 Mbps 150Kbps 150Kbps 150Kbps 2 Mbps 150Kbps 150Kbps 250Kbps 2 Mbps Memory Size 60K 60K 128K 128K 196K 196K 196K 128K 64K 196K 128K 128K RAM Size 4K 4K 16K 16K 4K 4K 4K 4K 4K 4K 96K 16K F RP-SMA External Chip RP-SMA External / F Chip RP-SMA External Chip / U.FL Chip / U.FL Chip Chip / U.FL F / MMCX Chip Yes Yes No Yes Yes Yes Yes Yes Yes Yes Yes No Antenna Receive Amp Transmit Amp Yes Yes No Yes Yes Yes Yes Yes Yes Yes Yes No Processor Size 8 bit 8 bit 8 bit 8 bit 8 bit 8 bit 8 bit 8 bit 8 bit 8 bit 32 bit 8 bit 33.86mm x 33.86mm 33.86mm x 33.86mm 33.86mm x 33.86mm 33.86mm x 33.86mm 33.86mm x 33.86mm 33.86mm x 33.86mm 33.86mm x 33.86mm 24.38mm x 32.94mm 29.8mm x 19mm 29.8mm x 19mm 25mm x 36mm 29.8mm x 19mm RF100 Pin Compatible Yes Yes Some Exception Some Exception See Datasheet See Datasheet See Datasheet *Digi Footprint -NA- -NA- -NA- -NA- Distance (Open Field) 2.5 miles 3 miles 1500ft 3 mi/2.5 mi 1 mile 3 miles 2500ft/1 mi 4000ft/1 mi 1 mile 2500ft/1 mi 1.5 miles / X 1500ft -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C to +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C -40°C / +85°C FCC,IC FCC,IC FCC, IC, CE FCC,IC,CE FCC,IC FCC,IC CE FCC,IC FCC,IC CE FCC, IC, CE FCC,IC, CE 19 19 20 20 15 15 15 15 19 19 46 33 Size Temperature Range Certifications I/O Pins A/D Pins 8 8 7 7 12 12 12 4 16 16 8 8 A/D Bits 10 10 10 10 10 10 10 10 10 10 12 10 Memory available for applications 15K 15K 58.5K 58.5K 64K 64K 64K 58K 64K 64K 58.5K 58.5K Basic encryption Included Included Included Included Included Included Included Included Included Included Included Included AES encryption RF150PC6 RF150PD6 Included Included Included Included Included Included Included Included Included Included RF100P86 users should migrate to RF100PC6 or RF200P81. *Pin-compatible with sockets already designed in for Digi International’s XBee® and XBee-PRO® RF modules. Customized modules with different antenna types or amplifications can be made. Please contact Sales at: 1.877.982.7888. Specifications subject to change without notice - confirm that data is current. 430128-01P
RF200PD1 价格&库存
很抱歉,暂时无法提供与“RF200PD1”相匹配的价格&库存,您可以联系我们找货
