MTSMC-G-F4-IP-ED.R1
MTSMC-G-F4-IP-ED.R1
    MULTI-TECHSYSTEMS
    Module
    MTSMC-G-F4-IP-ED.R1
MTSMC-G-F4-IP-ED.R1 数据手册
SocketModem GPRS ® Embedded Cellular Modem Universal Socket Benefits • Interchangeable communications devices • Quick-to-market • Global approvals • Easy migration to future networks The SocketModem® GPRS cellular modem is a complete, ready-to-integrate, communications device that offers standards-based GSM/GPRS Class 10 performance. This quick-to-market communications device allows developers to add wireless communication to products with a minimum of development time and expense. The intelligence of the embedded Universal IP™ stack, available on certain models, allows for automatic/persistent connectivity for mission critical applications and enhanced M2M functionality. The SocketModem GPRS cellular modem is based on industry-standard open interfaces and utilizes Multi-Tech's Universal Socket design. Features • GPRS Class 10 • Quad-band GSM 850/900/1800/1900 MHz • Packet data up to 85.6K bps • Universal Socket connectivity • Universal IP connectivity • Circuit-switched data up to 14,400 bps transparent and non-transparent • Short Message Services (SMS) • Advanced management features include phone book management, fixed dialing number, real time clock and alarm management • MMCX antenna connector and SIM socket • Serial interface supports DTE speeds to 115.2K bps • AT command compatible • MNP 2 error correction, V.42bis compression • Two-year warranty Highlights Specifications Applications. The SocketModem GPRS cellular modem is targeted at applications that periodically need to send or receive data over a wireless network. It is ideal for: Packet Data Features • Appliances • Remote diagnostics • Asset tracking • Remote metering • ATM terminals • Security systems • Automotive • Vending/gaming machines • Data collection • Other devices requiring wireless connectivity • Industrial and medical remote monitoring systems Universal Socket Connectivity. Multi-Tech’s Universal Socket is a flexible, comm-port architecture that provides cellular, Ethernet, PSTN or Wi-Fi network access with interchangeable communications devices. This means you can utilize one system design and populate it with your connectivity device of choice accommodating multiple connectivity requirements. In addition, you are assured a seamless migration to future technologies. Universal IP. Multi-Tech’s Universal IP consists of a common set of TCP/IP networking protocols and machine-to-machine (M2M) applications implemented using a standard AT command interface. Universal IP allows developers to write their host application one time while having the freedom to select from a growing number of Universal Socket communication devices. (Note: standard models contain a basic TCP/IP stack) SocketModem GPRS Pin-Out. The SocketModem GPRS cellular modem interfaces easily with existing products through a standard serial communication channel. The serial DTE channel is capable of transfer speeds to 115.2K bps and can be interfaced directly to a UART or microcontroller. The complete on-board RF transceiver interfaces with an antenna for direct connection to wireless SMS, circuit-switched dial-up, or packet data networks. It also includes an onboard LED to display network status. Developer's Kit. The Developer's Kit allows you to plug in the communications device and use it for testing, programming and evaluation. The kit includes one development board with RS-232 DB-25 connector, universal power supply, antenna and RS-232 cable. www.multitech.com 10/09 86002081 Circuit Switched Data Features Asynchronous, transparent & non-transparent up to 14.4K bps, MNP2 & V.42 bis SMS Features Text & PDU, Point-to-Point, cell broadcast Connectors Reduces Development Time. The SocketModem GPRS cellular modem enhances your product while you focus on developing its core features. It actually provides faster time-to-market because it relieves the burden and expense of obtaining PTCRB and RF approvals. World Headquarters Tel: (763) 785-3500 (800) 328-9717 GPRS Class 10, PBCCH support Coding Schemes: CS1 to CS4 Embedded TCP/IP stack Antenna: MMCX SIM: Standard 3V SIM receptacle IP Protocols Supported (MTSMC-G-F4-IP) DNS resolve, FTP client, Ping, POP3 client, PPP (dial-out), SMTP client, TCP RAW client & server, UDP RAW client & server, PAP, CHAP authentication M2M Applications (MTSMC-G-F4-IP) Automatic connect/reconnect, device monitor, modem emulation, Ping & TCP keep alive, wake-up on Caller ID, wake-up on ring Power Requirements 5VDC; 400mA typical, 1.4A maximum Physical Description 3.1" L x 1.4" W x 0.5" H; 1 oz. (7.8 cm x 3.5 cm x 1.2 cm; 28 g) Operating Environment -30° to +70° C (FCC certified from -30° to +50° C) Certifications CE Mark, R&TTE EMC: FCC Part 22, 24, EN 301 489-1, EN 301 489-7, RSS 132, 133 Safety: UL 60950-1, EN 60950-1, AS/NZS 60950:2000 Network: PTCRB Ordering Information Product MTSMC-G-F4* MTSMC-G-F4-ED† MTSMC-G-F4-V* MTSMC-G-F4-V-ED† MTSMC-G-F4-IP* MTSMC-G-F4-IP-ED† Copyright © 2009 by Multi-Tech Systems, Inc. All rights reserved. Region Global Global Global Global Global Global * Quad-band Modem, 850/1900 MHz default † Quad-band Modem, 900/1800 MHz default Made in Mounds View, MN, U.S.A. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: SocketModem, Universal IP, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Description GSM/GPRS Modem GSM/GPRS Modem GSM/GPRS Modem with Voice GSM/GPRS Modem with Voice GSM/GPRS Modem with Universal IP GSM/GPRS Modem with Universal IP Multi-Tech Systems (EMEA) France Tel: +(33) 1 49 19 22 06
MTSMC-G-F4-IP-ED.R1 价格&库存
很抱歉,暂时无法提供与“MTSMC-G-F4-IP-ED.R1”相匹配的价格&库存,您可以联系我们找货
MTSMC-G-F4-IP-ED.R1
  • 1+1677.870031+217.34285
  • 10+1481.7505810+191.93853
库存:47
