ISM340-USB
ISM340-USB
    INVENTEKSYSTEMS
    模块
    RFTXRXMODBLUE/WIFICHIP+U.FL
ISM340-USB 数据手册
ISM340/1-USB Product Specification INVENTEK SYSTEMS ISM34x-USB Embedded Serial-to-WiFi Module eS-WiFi™ 802.11 a/b/g/n, Bluetooth 4.0, NFC Preliminary Data Sheet DOC-DS-20089-1.0 Inventek Systems Page 1 ISM340/1-USB Product Specification Table of Contents 1 2 3 4 5 6 7 8 9 GENERAL DESCRIPTION ................................................................................................... 3 PART NUMBER DETAIL DESCRIPTION .......................................................................... 4 2.1 Ordering Information ...................................................................................................... 4 CERTIFICATIONS ................................................................................................................ 4 3.1 Limitations ...................................................................................................................... 4 3.2 Regulatory Compliance .................................................................................................. 4 3.3 FCC and IC User’s Manual Statements: ......................................................................... 5 SPECIFICATIONS ................................................................................................................. 8 4.1 Module Architecture ....................................................................................................... 8 4.2 External Antenna Connections ....................................................................................... 9 4.3 NFC Connector ............................................................................................................... 9 4.4 Environmental Specifications ......................................................................................... 9 4.5 External Antenna ............................................................................................................ 9 ON BOARD PROCESSOR .................................................................................................. 10 ISM340-USB Quick Start Guide .......................................................................................... 10 PRODUCT COMPLIANCE CONSIDERATIONS ............................................................. 11 REVISION CONTROL ........................................................................................................ 12 CONTACT INFORMATION ............................................................................................... 12 DOC-DS-20089-1.0 Inventek Systems Page 2 ISM340/1-USB Product Specification 1 GENERAL DESCRIPTION The Inventek IS340-USB Wi-Fi / BT dongle consist of an ISM4334x-M4G-L44 is an embedded wireless internet connectivity module that operates in the 2.4 & 5.0 GHz spectrum. The Wi-Fi module’s hardware consists of an ARM Cortex M4 host processor, Broadcom BCM43341/0 Dual-Band (2.4 GHz / 5 GHz) 802.11 a/b/g/n MAC/Baseband/Radio with Integrated Bluetooth 4.0 and NFC support. The module has two antenna options, an on board dual band chip 2.4 & 5 GHz or an U.FL connector for external 2.4 & 5 GHz antenna. There are two versions of the module offered, one that supports NFC (ISM43341-M4GL44) and one that does not (ISM43340-M4G-L44). Hardware Features       Dual port FTDI USb chip that can be used as a VCOM port or JTAG to program the ST microcontroller on board. On Board Flash for over the air updates 2.4 and 5 GHz antenna with a zero ohm resistor for a stuffing option for external antenna’s External connector for NFC along with a L/C circuit that can be tuned for your NFC antenna. The Wi-Fi module requires no operating system and has a completely integrated TCP/IP Stack. The module hardware can be used with Inventek’s AT Command set (IWIN) or with Broadcom’s WICEDTM SDK3.1.2 or later. Please download the Inventek 3.1.2 patch for the Broadcom SDK Typical Applications:        PDA, Pocket PC, computing devices. Building automation and smart energy control. Industrial sensing and remote equipment monitoring. Warehousing, logistics and freight management. PC and gaming peripherals. Printers, scanners, alarm and video systems. Medical applications including patient monitoring and remote diagnostics. DOC-DS-20089-1.0 Inventek Systems Page 3 ISM340/1-USB Product Specification 2 PART NUMBER DETAIL DESCRIPTION 2.1 Ordering Information Device Description Firmware Ordering Number ISM430-USB Wi-Fi/BT USB dongle USB ISM430-USB ISM431-USB Wi-Fi/BT & NFC USB dongle USB ISM430-USB 3 CERTIFICATIONS 3.1 Limitations Inventek Systems products are not authorized for use in safety-critical applications (such as life support) where a failure of the Inventek Systems product would reasonably be expected to cause severe personal injury or death. 3.2 Regulatory Compliance CE Regulator FCC IC RoHS Status In Process In Process Compliant DOC-DS-20089-1.0 Inventek Systems Page 4 ISM340/1-USB Product Specification 3.3 FCC and IC User’s Manual Statements: OEM INSTRUCTIONS: This module is limited to OEM installation only. OEM integrators must ensure that the end-user has no manual instructions to remove or install the module. OEM’s must comply with FCC marking regulation part 15 declaration of conformity (Section 2.925(e)). This module is to be installed only in mobile or fixed applications (Please refer to FCC CFR 47 Part 2.1091(b) for a definition of mobile and fixed devices). Separate approval is required for all other operating configurations, including portable configurations with respect to FCC CFR 47 Part 2.1093, and different antenna configurations. The antennas used with this module must be installed to provide a separation distance of at least 20cm from all persons, and must not be co-located or transmit simultaneously with any other antenna or transmitter, except in accordance with FCC multi transmitter product procedures. The ISM43340/1 Modules has been designed to operate with the following antennas and gains. Use with other antenna types or with these antenna types at higher gains is strictly prohibited. Manufacturer Inventek Inventek Type of Antenna Model Gain dBi U.FL port Antenna Chip Antenna W2.4-5P-U 2.6 (@ 2.4 GHz) 3.3 (@ 5 GHz) 1.4 (@ 2.4 GHz) 2.3 (@ 5 GHz) AA077 DOC-DS-20089-1.0 Type of Connector U.FL Chip Inventek Systems Page 5 ISM340/1-USB Product Specification Warning: changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate this equipment. A clearly visible label is required on the outside of the user’s (OEM) enclosure stat the following text: Contains FCC ID: 07P-341 Contains IC: 10147A-341 This transmitter module has been certified for FCC Part 15 operation; when installed in a host device, the host manufacturer is responsible for making sure that the host device with the transmitter installed continues to be compliant with Part 15B unintentional radiator requirements DOC-DS-20089-1.0 Inventek Systems Page 6 ISM340/1-USB Product Specification Industry Canada User’s Manual Statements: IC RSS-210/RSS-Gen NoticesOperation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of this device. L’opѐration est soumise aux deux conditions suivantes: (1) cet appareil ne peut pas provoquer d’interfѐrences et (2) cet apparial doit accepter toute interfѐrence, y compris les interfѐrences qui peuvent causer un mauvis fonctionment de l’appareil. Under Industry Canada regulations, this radio transmitter may only operate using an antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (e.i.r.p.) is not more than that necessary for successful communication. Sous la rѐglementation d’Industrie Canada, ce transmetteur radio ne peut fonctionner en utilisant une antenne d’un type et un maximum (ou moins) gain approuvѐes pour l’ѐmetteur par Industrie Canada. Pour rѐduire le risqué d’interference aux autres utilisateures, le type d’antenne et son gain doivent être choisis de maniѐre que la puissance isotrpe rayonnѐe ѐquivalente (PIRE) ne dѐpasse pas ce qui est nѐcessaire pour une communication rѐussie. The radio transmitter has been approved by Industry Canada to operate with the antenna types listed above with the maximum permissible gain and required antenna impedance for each antenna type indicated. Antenna types not included in this list having a gain greater than the maximum gain indicated for that type, are strictly prohibited for use with this device. Cet ѐmetteur de radio a ѐtѐ approuvѐ par Industrie Canada pour fonctionner avec les types d’antennes ѐnumѐrѐes ci-dessus avec le gain maximal admissible et impѐdance d’antenna requise pour chaque type d’antenne indiquѐ. Types d’antennes ne figurant pas dans cette liste, ayant un gain supѐrieur au gain maximum indiquѐ pour ce type, sont strictement interdites pour l’utilisation avec cet appareil. DOC-DS-20089-1.0 Inventek Systems Page 7 ISM340/1-USB Product Specification 4 SPECIFICATIONS 4.1 Module Architecture Figure 1 Inventek’s ISM340-USB / ISM341-USB with NFC Block Diagram DOC-DS-20089-1.0 Inventek Systems Page 8 ISM340/1-USB Product Specification 4.2 External Antenna Connections ISM34x-USB module is designed for use with an optional external antenna via a connection using the U.FL connector. A zero ohm resistor us used to select the external antenna Item Description Connector U.FL series Manufacturer I-PEX Co., Ltd. Part No. 20279-001E-01 Height 1.25 mm Width 2 mm DC 3.0 – 5.0 V Table 1 On-Board Antenna Connector 4.3 NFC Connector Conn HDR 1mm 2 POS SMD 1 Molex 501568-0207 4.4 Environmental Specifications Item Operating temperature range Storage temperature range Humidity Description -40 deg. C to +85 deg. C -40 deg. C to +85 deg. C 95% max non-condensing Note 1: The ISM34x-USB supports a functional operating range of -40°C to +85°C. However the optimal RF performance specified in this data sheet is only guaranteed for temperatures from -10°C to +65°C 4.5 External Antenna The Inventek U.FL PCB antenna will be tested for FCC and CE certification. The part number is W2.4-5P-U. It is a dual band 2.4/5 GHz PCB antenna with a U.FL connector. The Inventek W2.4-5P-U PCB antenna is FCC and CE certified and can be found on the Inventek Website. DOC-DS-20089-1.0 Inventek Systems Page 9 ISM340/1-USB Product Specification 5 ON BOARD PROCESSOR The eS-WiFi module is available with an ST Microcontroller, STM32F405 processor. STM32F405 (1 MB), Flash Microcontroller 6 ISM340-USB Quick Start Guide Installing the ISM340-USB dongle: Before you plug the board into your computer download and install the eS-WiFi PC demo software and Drivers: www.inventeksys.com/wp-content/uploads/Inventek_Systems_eS-WiFiDemo_v1.4_b2.zip Save the eS-Wifi Demo.zip Run as Administrator. Select Menu>Install Drivers on the eS-WiFi Demo to pre-install the drivers then plug-in the board. Identify serial Com port from Device. Set Baud rate to 115,200, 8 Data bits, 1 Stop bit , Parity None, and Flow control None The other option is to use a terminal program such as Hyper-terminal, PuTTY Install the Broadcom WICED SDK and install the platform Patch: WICED SDK http://community.broadcom.com/community/wiced-wifi ISM340 SDK patch: http://www.inventeksys.com/wp-content/uploads/Wiced3.1.2patch.zip DOC-DS-20089-1.0 Inventek Systems Page 10 ISM340/1-USB Product Specification 7 PRODUCT COMPLIANCE CONSIDERATIONS RoHS: Restriction of Hazardous Substances (RoHS) directive has come into force since 1st July 2006 all electronic products sold in the EU must be free of hazardous materials, such as lead. Inventek is fully committed to being one of the first to introduce lead-free products while maintaining backwards compatibility and focusing on a continuously high level of product and manufacturing quality. EMI/EMC: The Inventek module design embeds EMI/EMC suppression features and accommodations to allow for higher operational reliability in noisier (RF) environments and easier integration compliance in host (OEM) applications. FCC/CE: The module will be tested for FCC/IC/CE compliance. DOC-DS-20089-1.0 Inventek Systems Page 11 ISM340/1-USB Product Specification 8 REVISION CONTROL Document : ISM43341-M4G-L44 External Release Date 4/27/2014 Wi-Fi module DOC-DS-20089 Author KMT Revision 1.0 Comment Preliminary 9 CONTACT INFORMATION Inventek Systems 2 Republic Road Billerica Ma, 01862 Tel: 978-667-1962 Sales@inventeksys.com www.inventeksys.com Inventek Systems reserves the right to make changes without further notice to any products or data herein to improve reliability, function, or design. The information contained within is believed to be accurate and reliable. However Inventek Systems does not assume any liability arising out of the application or use of this information, nor the application or use of any product or circuit described herein, neither does it convey any license under its patent rights nor the rights of others. DOC-DS-20089-1.0 Inventek Systems Page 12
ISM340-USB 价格&库存
很抱歉,暂时无法提供与“ISM340-USB”相匹配的价格&库存,您可以联系我们找货
