LOW-POWER RF
MODULE FOR EUROPE
XBEE® 868LP
FOR EUROPE
RF module family operates in the 863-870 MHz range utilizing 30 channels
to deliver superior performance and interference immunity at 868 MHz
The XBee 868LP module was designed to provide a high-performance,
low-power module at an extremely competitive price point. The
XBee 868LP module can run either a proprietary DigiMesh® or pointto-multipoint networking protocol utilizing a low-power Energy
Micro microcontroller and an Analog Devices ADF7023 transceiver,
which offers industry-leading interference blocking. The XBee 868LP
operates between 863-870 MHz, making it deployable in several
regions throughout the world including approved European countries
and India by utilizing a software selectable channel masking feature.
The XBee 868LP is also the industry’s first RF module using 868 MHz
and surrounding frequencies for LBT + AFA (Listen Before Talk and
Adaptive Frequency Agility). This virtually eliminates interference by
BENEFITS
listening to the radio environment before any transmission starts,
and automatically shifting to a new channel when interference is
detected. This patent-pending frequency scan occurs automatically
and in a matter of microseconds so as not to impact performance.
The programmable version of the XBee 868LP module makes
customizing wireless applications easy. Programming directly on
the module eliminates the need for a separate host processor.
Because the wireless software is isolated, applications can be
developed with no risk to RF performance, security or additional
certifications.
APPLICATION EXAMPLE
– Industry’s first RF module to utilize LBT + AFA for
– Modules can operate in DigiMesh or point-to multipoint wireless networking topologies
Ethernet
– Programmable versions of the XBee 868LP enable
custom application development
8-bit Freescale™ S08 microprocessor brings custom
intelligence to the module
XBee-specific CodeWarrior® development tools
for easy programming
– Pin-compatible with other XBee SMT modules
UTILITY ENERGY
MANAGEMENT SYSTEMS
XBEE® 868 MHZ WIRELESS METER NETWORK
XBEE® 868LP
MODULE
– RF throughput up to 50 Kbps
Utility Meter
Utility Meter
Utility Meter
Modules
Digi Device
CloudSM
Technical
Services
Development
Kits
Cellular/VPN
CONCENTRATOR
GATEWAY
RELATED PRODUCTS
Gateways
DEVICE CLOUD
SPECIFICATIONS
XBee® 868LP for Europe
Programmable XBee® 868LP for Europe
HARDWARE
PROCESSOR
ADF7023 transceiver, Cortex™-M3 EFM32G230 @ 32 MHz
FREQUENCY BAND
863 MHz to 870 MHz
ANTENNA OPTIONS
U.FL, RF pad, PCB (PCB antenna only approved with 10 Kbps data rate)
PERFORMANCE
RF DATA RATE
10 Kbps or 80 Kbps
INDOOR/URBAN RANGE
Up to 370 ft (112 m) w/2.1 dBi antenna, up to 46 ft (14 m) w/PCB embedded antenna
OUTDOOR/LINE-OF-SIGHT RANGE
Up to 5.2 miles (8.4 km) w/2.1 dBi antenna, up to 0.4 miles (.64 km) w/PCB embedded antenna
TRANSMIT POWER
Up to 14 dBm (25 mW) E.I.R.P. w/ 2 dBi antenna, software selectable
RECEIVER SENSITIVITY
-101 dBm @ 80 Kbps, -106 dBm @ 10 Kbps
FEATURES
I/O
13
ANALOG INPUTS
4 channels 10-bit
OPERATING TEMPERATURE
-40° C to +85° C
NETWORKING TOPOLOGIES
DigiMesh®, Repeater, Point-to-point, Point-to-multipoint, Peer-to-peer
PROGRAMMABILITY
MEMORY
N/A
32 KB Flash / 2 KB RAM
CPU/CLOCK SPEED
N/A
HCS08 / Up to 50.33 MHz
POWER
SUPPLY VOLTAGE
2.7- 3.6 VDC
TRANSMIT CURRENT
48 mA
62 mA
RECEIVE CURRENT
27 mA
41 mA
SLEEP CURRENT
1.7 uA
2.3 uA
REGULATORY APPROVALS
ETSI (EUROPE)
CE
ROHS
Yes
Point-to-Multipoint / Star
DigiMesh
Top View
Side View
Bottom View
WWW.DIGI.COM
PART NUMBERS
DESCRIPTION
XB8-DMRS-002
XBee 865/868LP RF pad Antenna 80kbps
XB8-DMUS-002
XBee 865/868LP U.FL Antenna 80kbps
XB8-DMPS-002
XBee 865/868LP PCB Antenna 80kbps (Not Approved in Europe)
XB8-DPPS-001
XBee 865/868LP PCB Antenna 10kbps
XB8-DPRS-001
XBee 865/868LP RF pad Antenna 10kbps
XB8-DPUS-001
XBee 865/868LP U.FL Antenna 10kbps
XB8-DMPSB002
XBee DigiMesh 865/868LP PCB Antenna 80Kbps, 32K Programmable (Not Approved in Europe)
XB8-DMUSB002
XBee DigiMesh 865/868LP U.FL Antenna 80Kbps, 32K Programmable
XB8-DMRSB002
XBee DigiMesh 865/868LP RF Pad Antenna 80Kbps, 32K Programmable
XK8-DMS-0
XBee 865/868LP Dev Kit
Modules in this kit require additional configuration for use in India. See the Product Manual for more details
XK8-DMSB0
XBee 865/868LP Dev Kit 32K Programmable
FOR MORE INFORMATION
PLEASE VISIT WWW.DIGI.COM
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2015 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91001811
B1/915
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL FRANCE
+33-1-55-61-98-98 / www.digi.fr
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“XB8-DMRS-002”相匹配的价格&库存,您可以联系我们找货
