MOD-WIFI-ESP8266
MOD-WIFI-ESP8266
    OLIMEX
    模块
    RF TXRX MODULE WIFI TRACE ANT
MOD-WIFI-ESP8266 数据手册
CHANGING THE MODES OF MOD-WIFI-ESP8266 REFERENCE Revision A, January 2015 Designed by OLIMEX Ltd, 2014 All boards produced by Olimex LTD are ROHS compliant OLIMEX© 2014 MOD-WIFI-ESP8266 reference DISCLAIMER © 2015 Olimex Ltd. Olimex®, logo and combinations thereof, are registered trademarks of Olimex Ltd. Other product names may be trademarks of others and the rights belong to their respective owners. The information in this document is provided in connection with Olimex products. No license, express or implied or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Olimex products. This work is licensed under the Creative Commons Attribution-ShareAlike 3.0 Unported License. To view a copy of this license, visit http://www.creativecommons.org/licenses/by-sa/3.0/. This hardware design by Olimex LTD is licensed under a Creative Commons Attribution-ShareAlike 3.0 Unported License. The software is released under GPL. The product described in this document is subject to continuous development and improvements. All particulars of the product and its use contained in this document are given by OLIMEX in good faith. However all warranties implied or expressed including but not limited to implied warranties of merchantability or fitness for purpose are excluded. This document is intended only to assist the reader in the use of the product. OLIMEX Ltd. shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information or any incorrect use of the product. This evaluation board/kit is intended for use for engineering development, demonstration, or evaluation purposes only and is not considered by OLIMEX to be a finished end-product fit for general consumer use. Persons handling the product must have electronics training and observe good engineering practice standards. As such, the goods being provided are not intended to be complete in terms of required design-, marketing-, and/or manufacturing-related protective considerations, including product safety and environmental measures typically found in end products that incorporate such semiconductor components or circuit boards. Olimex currently deals with a variety of customers for products, and therefore our arrangement with the user is not exclusive. Olimex assumes no liability for applications assistance, customer product design, software performance, or infringement of patents or services described herein. THERE IS NO WARRANTY FOR THE DESIGN MATERIALS AND THE COMPONENTS USED TO CREATE MOD-WIFI-ESP8266. THEY ARE CONSIDERED SUITABLE ONLY FOR MOD-WIFI-ESP8266. Page 2 of 4 OLIMEX© 2014 MOD-WIFI-ESP8266 reference ESP8266 has three modes of operation: SDIO mode, UART mode and FLASH mode. By default the board is configured for FLASH mode operation. The jumpers for the default FLASH mode were set during production as follows: MTD0 is set to position 0; GPIO0 is set to position 1; GPIO2 is set to position 1. To access the other modes you would need to manipulate the on-board SMT jumpers called MTD0, GPIO0, and GPIO2. They are located at the bottom of the board near the UEXT connector. Each of the jumpers can be set to either position 0 or position 1. The jumpers are highlighted on the picture below: The positions for the all the modes are printed on the board itself. The table looks like this: MODE MTDO GPIO0 GPIO2 SDIO 1 x x UART 0 0 1 FLASH (DEFAULT) 0 1 1 JUMPER For example: Initially, you can't update the firmware of MOD-WIFI-ESP8266 since by the board starts in the default FLASH mode. In order to update the firmware of the board you would need to change the starting mode to UART. This is done by changing the position of the jumper named GPIO0 to 0. After the update is done – change the position of GPIO0 back to 1 again. In order to change the position of an SMT jumper like that you would need basic soldering skills. There are two things that you would need to do: Page 3 of 4 OLIMEX© 2014 MOD-WIFI-ESP8266 reference 1. Remove the original connection between the pads. If it was made using soldering – unsolder it and remove the soldering residue. If it was a hardware PCB connection – make sure to cut between the pads with a sharp tool (like a safety cutter). 2. Connect the pads of the desired position by soldering. Do not use a large amount of soldering residue. Do not keep the soldering iron pressed to the board longer than 10 seconds. Make sure that there is no left-over soldering residue which might lead to accidental short-circuits. If you want, you can add wires and a PTH jumper or a slide switch to the pads of the jumpers. This would allow easier change of the jumpers in future. More details about the three different modes might be found in the ESP8266 datasheet. Page 4 of 4
MOD-WIFI-ESP8266
物料型号:MOD-WIFI-ESP8266
器件简介:文档由OLIMEX公司设计,适用于工程开发、演示或评估用途,不适用于一般消费者使用。所有由OLIMEX生产的板卡均符合ROHS标准,无铅。
引脚分配:文档中提到了三个用于设置模块工作模式的SMT跳线:MTD0、GPIO0和GPIO2。这些跳线位于板卡底部,靠近UEXT连接器。
参数特性:ESP8266模块有三种工作模式:SDIO模式、UART模式和FLASH模式。默认情况下,模块配置为FLASH模式。要访问其他模式,需要操作板上的SMT跳线。
功能详解:文档提供了如何通过改变跳线设置来切换模块的工作模式。例如,要更新模块的固件,需要将启动模式更改为UART模式,这可以通过将名为GPIO0的跳线位置更改为0来实现。更新完成后,需要将GPIO0的位置改回1。
应用信息:文档指出,该评估板/套件仅适用于工程开发、演示或评估目的,并非OLIMEX认为的成品,不适合一般消费者使用。处理产品的人必须接受过电子培训,并遵守良好的工程实践标准。
封装信息:文档中没有提供封装信息,但提到了硬件设计遵循Creative Commons Attribution-ShareAlike 3.0 Unported License,软件在GPL下发布。
MOD-WIFI-ESP8266 价格&库存
很抱歉,暂时无法提供与“MOD-WIFI-ESP8266”相匹配的价格&库存,您可以联系我们找货
