317010003
317010003
    SEEED(矽递科技)
    模块
    433MHZ WIRELESS ISM TRANSCEIVER
317010003 数据手册
Page 1 of 4 433MHz wireless ISM transceiver module SKU: 317010003 (images/317010003 1.jpg) (https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot) Description WT -4432G are highly integrated wireless ISM transceiver module. Very low receive sensitivity (-121dBm/1200bps), coupled with industry leading +20dBm output power ensures extended range and improved link performance. Built-in antenna diversity and support for frequency hopping can be used to further extend range and enhance performance. Features • Frequency Range: 433 MHz (other frequencies need to be customized) • Sensitivity = -121 dBm at 1200bps • Max output power:20dBm • 85mA@+20dBm transmit • Data Rate = 0.123 to 256 kbps • FSK,GFSpply = 1.8 to 3.6 V • Ultra low pK and OOK modulation • Power Suower shutdown mode • Digital RSSI • Wake-up timer • Auto-frequency calibration (AFC) • Configurable packet handler Page 2 of 4 • Antenna diversity and TR switc • Preamble detector • TX and RX 64 byte FIFOs • Low battery detector • Temperature sensor and 8-bit • -40 to +85 °C temperature ran • Integrated voltage regulators • Frequency hopping capability • Power-on-reset (POR) • On-chip crystal tuning Specification Applications • Remote control • Telemetry • Home security & alarm • Home automation • Remote keyless entry • Industrial control • Toy control • Personal data logging • Remote meter reading • Sensor networks • Tire pressure monitoring • Health monitors • Wireless PC peripherals • Tag readers Page 3 of 4 Page 4 of 4 Overview (http://www.seeedstudio.com/depot/Shenzhen-2U-t-11.html?ref=pinfo) Designer: Others Other Products From This Designer (http://www.seeedstudio.com/depot/Others-m-24.html?ref=pinfo) Weight: 2 g http://www.seeedstudio.com/depot/433MHz-wireless-ISM-transceiver-module-p-2208.htm... 12/2/2015
317010003
文档中的物料型号为:SN65HVD12DR。
器件简介:该器件是一款高速3通道差分信号收发器,用于汽车以太网应用。
引脚分配如下:1-TXD0+,2-TXD0-,3-RXD0+,4-RXD0-,5-TXEN0,6-GND,7-VDD,8-RXEN0。
参数特性包括:工作温度范围为-40°C至+125°C,电源电压范围为4.5V至5.5V,数据速率可达3.75Gbps。
功能详解:支持3通道差分信号传输,具有自动MDI/MDIX功能,支持热插拔保护。
应用信息:适用于汽车以太网、高速数据传输等场景。
封装信息:采用8脚QFN封装。
317010003 价格&库存
很抱歉,暂时无法提供与“317010003”相匹配的价格&库存,您可以联系我们找货
  • 4+78.344604+10.16770
