GS1500M22
GS1500M22
    GAINSPAN
    模块
    RFTXRXMODULEWIFITRACE+U.FL
GS1500M22 数据手册
T BRIEF PR O D UCT B RI E F - P RE L IM IN AR Y GainSpan GS1500M 802.11b/g/n Low Power Wi-Fi® Module PRODUCT OVERVIEW The GS1500M is a fully certified module offering quick, easy and cost effective way for OEMs to enable leading edge Wi-Fi connectivity (802.11b/g/n) in their platforms. The module provides multiple serial UART or SPI interfaces, enabling connection to any embedded design utilizing the 8/16/32-bit microcontroller via simple commands. The GS1500M is an ideal solution for OEMs with limited or no Wi-Fi or RF expertise. The GS1500M solution dramatically reduces development time and eliminates the burden of testing and certification, allowing customers to exclusively focus on their core platforms. The module supports Wi-Fi PHY rates up to 72.2 Mbps and is fully compliant with 802.11b/g/n and meets worldwide regulatory requirements. The GS1500M also provides support for a peer-to-peer networking capabilities allowing Wi-Fi devices to connect to one another without an access point, enabling easy transfer of content anytime, anywhere. Multiple software configurations are available for running a stack or network services on the module. For applications utilizing a small 8 bit microcontroller host, the module supports a serial to Wi-Fi function and runs the full Wi-Fi and TCP/IP networking stacks, completely offloading the host. For applications utilizing more powerful microcontrollers, the networking stack and services can reside on the host while the module provides the IP to Wi-Fi functionality. In addition, it supports WEP/WPA/WPA2 security, Limited AP mode, Embedded Web Server as well as Wi-Fi Protected Setup (WPS) for ease of provisioning. BENEFITS • Brings leading edge Wi-Fi and web connectivity to any platform with a microcontroller and serial HOST interface (UART or SPI) • Self-contained solution minimizes host processor loading • Reduces development time while accelerating time to market • Pin and software compatible with GS1011M • Operates with standard 802.11b/g/n access points at speeds of up to 72.2 Mbps – Infrastructure/Limited-AP modes • Easy device provisioning using Limited-AP or Wi-Fi Protected Set-up (WPS) • Low power consumption through dynamic power management modes − Standby, Sleep and Deep Sleep FEATURES • Highly integrated 802.11b/g/n Wi-Fi radio • Supports peer-to-peer networking • Two serial UART ports − Clock Data rates of up to 921.6kbps GS1500M based embedded Wi-Fi IO application • Two SPI ports (Master and Slave modes) − Clock Data rates of up to 3Mbps • Firmware provides full Wi-Fi and networking stack services including TCP/UDP/IP, HTTP, DNS, DHCP and SSL • 802.11i Security − WEP, − WPA/WPA2 Personal, GS1500M based embedded Serial/IP to Wi-Fi application The module SKU is single sided, pin compatible with previous GS1011M modules, with castellation on the edges for I/O connection so module can be soldered down on customer application base-board. SKU GS1500M . Power Amplifier Internal PA − WPA/WPA2 Enterprise MODULE HIGHLIGHTS • Single power source of 3.3V Antenna Option • Certified Modules (FCC/IC/ETSI) PCB Trace or External Antenna (uFL) • Rich I/O interfaces such as SPI, UART, GPIO, I2C, ADC and JTAG PR O D UCT B RI E F - P RE LIM IN AR Y GS1500M MODULE SPECIFICATIONS Radio Protocol Supports IEEE 802.11b, 11g, 11n single stream RF Output Power (Typical) 14 dBm (802.11b), 12dBm (802.11n) RF Operating Frequency 2.412 - 2.484 GHz Supported Data Rates 802.11b (CCK): 1, 2, 5.5, 11 Mbps 802.11g (OFDM): 6, 9, 12, 18, 24, 36, 48, 54 Mbps 802.11n (1x1 HT20): MCS0-7 Antenna Options PCB Trace or uFL connector for external antenna Operating Temperature Industrial (-40° to +85°C) Security Protocols WEP, 802.11i WPA/WPA2 Personal Security (AES and TKIP), Enterprise Security (EAP-FAST, EAP-TLS, EAP-TTLS, PEAP) Networking Protocols UDP, TCP/IP (IPv4), DHCP, ARP, DNS, SSL, HTTP/HTTPS Client and Server Certifications and Compliance FCC, IC, ETSI, RoHS, Wi-Fi Alliance I/O Interface UART (2), SPI (2), I2C, ADC (2), WAKE, ALARM (2), GPIOs, PWM, JTAG Dimensions 1.45 in x 0.9 in Power Source 3.3V GS1500M BLOCK DIAGRAM TARGET APPLICATIONS The GainSpan GS1500M module is easily designed into embedded systems, allowing customers to develop a broad array of platforms that will connect to the Internet. In applications such as healthcare and fitness, smart energy, industrial controls, commercial/building automation, and consumer electronics. © 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com GS1500M PB v1.0 @GainSpan
GS1500M22 价格&库存
很抱歉,暂时无法提供与“GS1500M22”相匹配的价格&库存,您可以联系我们找货
