SM301PC1
SM301PC1
    SYNAPSE
    模块
    RF MODULE 150KBPS 868MHZ CHIP
SM301PC1 数据手册
Wireless Technology to Control and Monitor Anything from Anywhere™ SYNAPSE SM301 RF Engine Synapse’s SM301 RF Engines® are long-range, reliable, surface mount 868 MHz transmitter receiver modules. These small, low-powered modules can have a range of up to 1 mile and power consumption as low as 2µA. The SM301 RF Engines come pre-loaded with the Synapse SNAP® mesh network operating system and provide interoperability with all other SNAP RF Engines. SM301PC1 has chip antenna and SM301PU1 has U.FL antenna connector. SM301 Features:         15 GPIO and up to 18 A/D inputs One UART port for control or transparent data Low power modes: 2µA with internal timer running 192K total FLASH with 64K used by SNAP core, 64K free for uploadable SNAPpy scripts, and 64K reserved FHSS technology Small form factor surface mount 10-bit ADC CE Certified SM301 Specifications: Indoor Range Up to 500 ft. Frequency 868MHz Outdoor LOS Range Chip - 1500ft U.FL - 1mile Spreading Method FHSS Transmit Power Output 13dBm Modulation GFSK RF Data Rate 150kbps raw Dimensions 19.00 X 29.80mm Receiver Sensitivity -121dBm at 9.6kbps and 1E-3 BER -99dBm at 150kbps Operating Temperature -40 to 85 deg C. Supply Voltage 2.7 – 3.6V Antenna Options Chip or U.FL Transmit Current (Typ) 30mA at +13dBm TX UARTS with HW Flow Control 1 port Receive Current (Typ) 18mA GPIO 15 total, 18 with 10bit ADC Sleep Current (Typ) 2µA CE Yes Topology Mesh (SNAP) Number of Channels 16 Performance Power Requirement General Available I/O Agency Approval Networking SYNAPSE Wireless, Inc. 500 Discovery Drive, Huntsville, Alabama 35806 877 982-7888 · synapse-wireless.com SM301 RF Engine Please refer to the SNAP User’s Guide for the I/O pin-mappings used by the SNAP-OS. Part Number SM301PC1 has chip antenna and Part Number SM301PU1 has U.FL antenna connector. Pin Number A1 A2 A3 A4 A5 A6 A7 A8 B1 B2 B3 B4 B5 B6 B7 B8 C1 C2 C3 C4 C5 C6 C7 C8 D1 D2 D3 D4 D5 D6 D7 D8 Pin Name GND VCC VCC P2.2 P2.3 P1.6 NC (External Flash) P1.7 NC (External Flash) GND NC NC NC P2.1 P2.4 P1.5 NC (External Flash) P2.0 NC (External Flash) GND NC NC NC ANT_A P0.2_XTAL1 NC NC GND NC NC NC NC NC NC NC GND Pin Number E1 E2 E3 E4 E5 E6 E7 E8 F1 F2 F3 F4 F5 F6 F7 F8 G1 G2 G3 G4 G5 G6 G7 G8 H1 H2 H3 H4 H5 H6 H7 H8 Pin Name NC NC GPIO_0 NC NC NC NC RF OUT (Special Order) NC NC NC P0.0_VREF NC NC NC GND NC P2.5 P0.3_XTAL1 P0.5_RX P0.6_CNVSTR NC NC GND GND P2.7_C2D P2.6 P0.4_TX RESET#_C2CK P2.7_C2D NC GND More technical details are in SNAP Hardware Technical Manual, Synapse Customer Forum: forums.synapse-wireless.com. ERRATA Notice of potential SM301 radio problem with SNAP 2.4.20 and earlier If you turn the radio off and then back on using the rx() function in your scripts, then after invoking rx(True) your radio will experience poor performance caused by improper antenna control signals. How to correct radio problem: After invoking a rx(True) in your script, add the following two "radio pokes" to restore proper operation: pokeRadio(0x000c, 0x12) # GPIO_1 CONFIGURATION REG - set to TX pokeRadio(0x000d, 0x15) # GPIO_2 CONFIGURATION REG - set to RX © 2011 Synapse Wireless® All rights reserved. Patents pending. Specifications subject to change without notice–confirm data is current. 430135-01D
SM301PC1 价格&库存
很抱歉,暂时无法提供与“SM301PC1”相匹配的价格&库存,您可以联系我们找货
