AC4790-200A-485
AC4790-200A-485
    LAIRD(莱尔德)
    模块
    TXRX 900MHZ 3.3-5.5V FHSS 200MW
AC4790-200A-485 数据手册
Wireless Development Kits Proprietary RF Modules Innovative Technology for a Connected World THE FASTEST WAY TO WIRELESS Size, speed, range, power consumption, and cost are all important issues to engineers integrating RF connectivity. Laird Technologies addresses these issues with compact 2.4GHz, 900MHz, and 868MHz modules. Designed for fast OEM integration, our radios suit applications where both high reliability and long range are essential. Laird Technologies’ Development Kits provide a complete design environment to help engineers get up and running with our solutions in a matter of minutes. Each system includes the radio modules and accessories required to install and test RF, allowing for reduced R&D costs, quick agency certification, and fast time to market. Development Kits are not just for engineers working with tight resources, limited time or varying experience. All OEMs can benefit from our comprehensive tools and highly technical expertise in the complex field of RF. SOFTWARE ANTENNAS In an easy menu-driven format, our Windows-compatible software provides several helpful development utilities, allowing OEMs to quickly begin performing tests for configuration modes, range measurements, antenna evaluations, power management, and data throughput. Designers can easily program the radio modules to any desired configuration with the EEPROM Viewer/Editor feature. Antenna type, gain, and location are among the most critical elements of a wireless system. Laird Technologies’ kit allows OEMs to connect different antennas and evaluate their performance in various situations. In addition, our engineers can provide a comprehensive antenna review during the design process to determine the best antenna and location for the application. CONFIGURATION COMPLIANCE All Laird Technologies’ radio modules have configuration parameters stored in EEPROM that are used to customize the serial interface mode and provide for general system set-up. The modules ship with default parameters already configured to enable plug-and-play (these can be changed using our development tools or with custom interfaces developed by the OEM.) RF products are required to meet regulatory compliance such as FCC (USA), IC (Canada), and CE(Europe). Our radio module approvals help eliminate significant costs and time, even when regulatory compliance is still required for the final product. Laird Technologies’ experts can help guide OEMs through the approval process. FEATURES • Testing and tuning antennas • Optimizing system timing • Hardware and software integration • Finding best configuration for application • Increasing transmission range • Finding best mode for data rate and network global solutions: local support • Lowest Cost TM USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless Wireless development kits are also available for our range of standards based wireless modules, covering Bluetooth, 802.11 and ZigBee. Please contact Laird Technologies for further information or visit www.lairdtech.com/wireless. Wireless Development Kits Proprietary RF Modules Innovative Technology for a Connected World 2.4GHz Systems: What’s Included: Two (2) RF Modules PRM110 RF modules, -40º to +80ºC, 3.3V, serial interface, u.fl antenna connector, +4dBm to +21dBm power output PRM111 RF module, -40º to +80ºC, 3.3V, serial interface, integral antenna, +4dBm to +21dBm power output AC4424 RF Modules, -40º to +80ºC, 5V, TTL serial interface, MMCX antenna connector, 200mW power output AC4424 RF Modules, -40º to +80ºC, 5V, TTL serial interface, MMCX antenna connector, 100mW power output AC4424 RF Modules, -40º to +80ºC, 5V, TTL serial interface, MMCX antenna connector, 10mW power output AC4424 RF Modules, -40º to +80ºC, 5V, TTL serial interface, integral antenna, 10mW power output Choose from Laird Technologies’ 2.4GHz, 900MHz or 868MHz RF Modules Two (2) Adapter Boards RS232, RS485, 5V/3.3V serial TTL, and USB interfaces are supported. Features include: 1) loop-back for distance-testing using one computer 2) status/communications LED indicators 3) switches for easy configuration & reset 4) test points for troubleshooting One (1) Utilities CD Script-driven utilities include: DVK-PRM110 DVK-PRM111 SDK-AC4424-200 SDK-AC4424-100 SDK-AC4424-9 SDK-AC4424-9A 1) transmit/receive emulator 2) single-line command interface 900MHz Systems: 3) EEPROM viewer/editor; configuration AC4790 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface, MMCX antenna connector, 5mW–1000mW variable power output AC4790 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, MMCX antenna connector, 5mW–200mW variable power output AC4790 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, integral antenna, 5mW–200mW variable power output AC4790-1x1 tiny RF Modules, -40º to +80ºC, 3.3V, TTL serial interface, 10mW variable power output AC4490 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface, MMCX antenna connector, 5mW–1000mW variable power output AC4490 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, MMCX antenna connector, 5mW–200mW variable power output AC4490 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, integral antenna, 5mW–200mW variable power output AC4490-1x1 tiny RF Modules, -40º to +80ºC, 3.3V, TTL serial interface, 10mW variable power output information storage file 4) “What’s This?” Help File format provides descriptions of each configuration option 5) Error checker prevents configuration errors Two (2) AC Power Adapters Power for adapter board and radio module; USB and battery power optional Two (2) DB9 Serial Cables Connect the adapter boards to a PC via DB9 Two (2) USB Cables Connect the adapter boards to a PC via USB Two (2) Antennas Convenient, small antennas plug directly into the radio module’s connector. Longer range antennas are also available for external antenna modules. SDK-AC4790-1000M SDK-AC4790-200M SDK-AC4790-200A SDK-AC4790-1x1 SDK-AC4490-1000M SDK-AC4490-200M SDK-AC4490-200A SDK-AC4490-1x1 868MHz Systems: 2.4 GHz Models AC4868 RF Modules, -40º to +80ºC, 3.3V, TTL serial interface, MMCX antenna connector, 5–250mW power output AC4486 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, integral antenna, 5mW power output AC4486 RF Modules, -40º to +80ºC, 3.3V-5.5V, TTL serial interface, MMCX antenna, 5mW power output SDK-AC4868-250M SDK-AC4486-5A SDK-AC4486-5M The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/wireless for the most current specification. 900/863 GHz Model LT2510 Model 1X1-inch Model LWS-SPEC-LDKit 0109 Contact information: USA: +1 800 492 2320 EUROPE: +44 1628 858 940 ASIA: +852 2268 6567 Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. For further information please visit our website at www.lairdtech.com. Alternatively contact: wirelessinfo@lairdtech.com. Bluetooth® is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird Technologies. © 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc. EMAIL: wireless.systems@lairdtech.com
AC4790-200A-485 价格&库存
很抱歉,暂时无法提供与“AC4790-200A-485”相匹配的价格&库存,您可以联系我们找货
