NL-SW-LTE-GELS3-B
NL-SW-LTE-GELS3-B
    NIMBELINK
    DIP20
    RF TXRX MODULE CELLULAR U.FL ANT
NL-SW-LTE-GELS3-B 数据手册
Skywire​®​ LTE Cat 1 ELS31 Embedded Cellular Modem Datasheet NimbeLink Corp Updated: April 2020 PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 1 Table of Contents Table of Contents 2 Introduction Orderable Part Numbers Additional Resources Product Overview Block Diagram 4 4 4 4 5 Technical Specifications Electrical Specifications Absolute Maximum Ratings Recommended Ratings & Module Pin out Connectors J1 and J2 Connectors J3, X1, X2 Typical Power Consumption Mechanical Specifications Mechanical Characteristics Mating Connectors Device Placement Environmental Specifications 6 6 6 6 6 7 8 9 9 9 9 9 Important Design Considerations PWR_ON Signal Power Supply Requirements Serial Communications LED GPIO Control Power Off Power Cycling Internal Firewall Firmware Over-The-Air Updates (FOTA) RESET_nIN 10 10 10 10 10 11 11 12 12 12 13 Mounting Guidelines Board to Board connectors approach Solder to Board connection approach 13 13 14 Antenna Considerations Primary Antenna Requirements 16 16 PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 2 Diversity Antenna Requirements Recommended Antennas 16 17 Certifications Carrier Specific Geography Specific 17 17 17 Federal Regulatory Licensing 17 End Product Labeling Requirements 18 PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 3 1. Introduction 1.1 Orderable Part Numbers Orderable Device NL-SW-LTE-GELS3 NL-SW-LTE-GELS3-B NL-SW-LTE-GELS3-C NL-SW-LTE-GELS3-D NL-SW-LTE-GELS3-E NL-SIM-COM NL-SIM-IND Firmware Revision Operating Temperature Bands Fallback Network Type 4.3.1.0 4.3.2.0 25421 4.3.3.0 29979 4.3.3.0 36343 4.3.3.0f-40869 -30 to +85˚C -30 to +85˚C -30 to +85˚C -30 to +85˚C -30 to +85˚C -35˚C to +85˚C -40˚C to +105˚C B4, B13 B4, B13 B4, B13 B4, B13 B4, B13 None None None None None Verizon Verizon Verizon Verizon Verizon Verizon Verizon *Extended Temperature range is -40 to +90˚C, See Gemalto Documentation for Extended Temperature Behavior 1.2 Additional Resources The following documents or documentation resources are referenced within this document. ● ● ● Skywire® 4G LTE Cat 1 Verizon Product Page NL-SWDK User Manual 4.3.3.0 AT Command Manual 1.3 Product Overview Add robust cellular connectivity to your M2M devices with scalable radio technology with Skywire line of modems including ELS31 based LTE solutions. Extensive experience in designing and building embedded product solutions makes the NimbeLink Skywire® embedded cellular modem the smallest on the market. It uses the popular Skywire interface and supports multiple LTE bands and fallback capability minimizing costs of hardware and network access. The module is designed for volume production and is intended for OEMs to embed into end equipment designs. PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 4 1.4 Block Diagram PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 5 2. Technical Specifications 2.1 Electrical Specifications 2.1.1 Absolute Maximum Ratings Parameter Signal Maximum Rating Main Power Supply I/O Voltage Reference VCC VREF 5.5V 5.5V 2.1.2 Recommended Ratings & Module Pin out 2.1.2.1 Pin Name Directio n 1 VCC Input Connectors J1 and J2 Description Min Typical Main Power supply 3.0V 3.9V UART data out, I/O level tied to VREF VOL: GND to 0.55V Input UART data in, I/O level tied to VREF VIL: GND to 0.15V Input Ground Pin 2 DOUT Output 3 DIN 4 GND Max If not used 5.5V Must be implemented VOH: VREF x 0.67 to VREF VIH: VREF-0.4 V to VREF Must be implemented if USB not used, No connection Must be implemented if USB not used, No connection 0 Must be implemented 0V 3.8V 5.5V Must be implemented if no other method of resetting the modem is available. Drive with open collector output such as a N-Channel Mosfet. 3.0V 5V 5.25V No connection 5 RESET_nIN Input Emergency reset pin. Tie low for a minimum of 15 mS and released to activate. Internally pulled up to 3.8V. Drive with open collector output. Assert only in an emergency as the module will not gracefully exit the cellular network when asserted. 6 VUSB Input Supply for USB interface 7 USB_D+ I/O USB differential Data + signal No connection 8 USB_D- I/O USB differential Data - signal No connection VIH: VREF-0.4 V to VREF VIL: GND to 0.15V 9 DTR Input Modem Data Terminal Ready input 10 GND Input Ground Pin 0 11 GND Input Ground Pin 0 12 CTS Output Modem Clear to Send hardware flow control output PN 30122 rev 16 VOL: GND to 0.55V Tie to GND Must be implemented Must be implemented VOH: VREF x 0.67 to VREF No connection © NimbeLink Corp. 2020. All rights reserved. 6 13 V180 Output Signal drives high indicating the modem is powered on. May also be used to power external level shifters to interface to DIO7 or DIO8. Io(max) =50 mA. 0 1.65V 14 VREF Input Voltage reference for off board I/O signals. This signal drives the input voltage side of an onboard buffer which converts all external I/O voltage from VREF range to 1.8V range to drive the onboard cellular module. 15 GND Input Ground Pin 16 RTS Input 17 DIO8 I/O 18 DIO7 I/O 19 ADC1 Input Input 20 PWR_ON No connection 5.5V Must be implemented 0 Must be implemented VIL: GND to 0.15V VIH: VREF-0.4 V to VREF 0 1.8V No connection 0 1.8V No connection ADC_IN1 input on ELS31 module (10bit resolution) 0 1.8V No connection Modem PWR_ON signal. Assert low for at least 100 μs and then release to activate start sequence. Drive with open collector output. Internally pulled up to internal 3.8V rail with 1M ohm pull-up resistor. See Section 3.1 for more details. 0 5.5V Must be implemented. Modem Request to Send hardware flow control input Programmable GPIO_08 on ELS31 module. See GPIO section for further details Programmable GPIO_07 on ELS31 module. See GPIO section for further details 2.1.2.2 Connector Designator J3 1.8V or 3.3V 1.8V 3.8V Tie to GND Connectors J3, X1, X2 Description Connector Location Micro SIM Connector Bottom Side of Module X1 Primary Antenna Connection Topside of Module X2 Diversity Antenna Connection Topside of Module PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 7 2.1.2.3 Measurement Attenuation (dB) Typical Power Consumption AT+CSQ Min Current (mA) Average Current (mA) Peak Current (mA) Average Charge (μAh) Socket Dial 0 31 - 156.46 615.69 333.89 Socket Dial 20 28 - 140.32 659.04 299.237 Socket Dial 40 19 - 141.82 755.11 302.44 Off 0 - - 44.276 (μA) 5.322 11.091 Idle 0 31 - 48.6 378.23 12153.0 Idle - Lower Power 0 31 - 8.58 370.617 2086.78 PN 30122 rev 16 Notes Tested at 3.8V Time elapsed: 7.6758s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket, powering off Skywire. Tested at 3.8V Time elapsed: 7.6764s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket, powering off Skywire. Tested at 3.8V Time elapsed: 7.6781s Test: Opening socket, making HTTP POST, reading HTTP response, closing socket, powering off Skywire. Tested at 3.8V Connected to power, power button not pressed. 15 minute sample. Tested at 3.8V Registered on network, 15 minute sample period. Tested at 3.8V Registered on network, 15 minute sample period. Cell tower pages Skywire about once every two seconds (non-configurable). © NimbeLink Corp. 2020. All rights reserved. 8 2.2 Mechanical Specifications 2.2.1 Mechanical Characteristics Parameter Dimensions (excluding pin height, for solder to board applications) Dimensions (including pin height, for board to board connector applications) Weight Connector Insertion/Removal Typical Unit 29.0 x 33.60 x 6.63 29.0 x 33.60 x 10.73 0.3 hundreds mm mm oz Cycles 2.2.2 Mating Connectors Connector Designator Manufactu re J1, J2 3M J3 X1, X2 Molex Hirose Populated on Module 951110-2530-ARPR 786463001 U.FL-R-SMT(10) Recommended Mate Mate Manufacture 950510-6102-AR Acceptable alternate: NPPN101BFCN-RC 3M Sullins Connector Solutions Micro SIM Card CAB.011 Micro SIM Card Taoglas 2.2.3 Device Placement ⚠ Make sure the Skywire is installed in the correct orientation; failure to do so will damage the device and void the warranty. 2.3 Environmental Specifications Parameter Min Typical Max Unit Operating Temperature Extended Temperature* -30 -40 25 25 +85 +90 ˚C ˚C Operating Humidity 20 90 % Note Non-condensing * See Gemalto Documentation for Extended Temperature Behavior PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 9 3. Important Design Considerations 3.1 PWR_ON Signal To conserve power, the ELS31 does not automatically start up when power is applied. The baseboard design must supply a means to assert the PWR_ON signal low for at least 100 uS and then released to start-up the module. After asserting the PWR_ON signal, the modem will boot. The modem will send the URC ^SYSSTART that notifies the host application when the first AT command can be sent to the module. The boot time for the modem averages ~20 seconds. User software must wait for ^SYSSTART before attempting to communicate with the GELS3 modem. To power down the modem issue AT^SMSO to the modem via a AT command interface. Be sure not to disconnect the operating voltage until the V180 signal has gone low and until the URC "^SHUTDOWN" is displayed. 3.2 Power Supply Requirements The module will regularly consume high amounts of current on the Main Power Supply (VCC), up to 1.5A during active transmits and receives. The baseboard power supply should be designed to support peak currents up to 2 Amps. A 100uF capacitor should be placed near the VCC pin on the module to ensure ample energy is available, with a low inductance path to the VCC pin. For example power supply designs, there are multiple references available. See the NimbeLink Skywire Development Kit schematic for a switching regulator example. 3.3 Serial Communications The ELS31 can communicate over UART and/or USB. Design should implement one or both serial interfaces to be able to send commands to the modem. 3.4 LED The Skywire has an on board LED D1 connected to ELS31 on GPIO5. This is helpful for checking the network status and debugging. To setup the LED, issue the command: AT^SCFG="GPIO/mode/SYNC","std" For a solid-on LED when the Skywire is registered on the network, issue: AT^SLED=1 For a blinking LED when the Skywire is registered on the network, issue: AT^SLED=2 PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 10 For specific LED behavior and blink timings (if applicable), please consult the NL-SW-LTE-GELS3 AT Command Manual section for the ​AT^SLED​ command. 3.5 GPIO Control GPIO control is added to the design with Revision 4.3.2.0 firmware. Modem interface Pin 17 can be driven high or low using the following AT commands: Setup pin configuration: at^scfg="GPIO/mode/PULSE","gpio" ^SCFG: "GPIO/mode/PULSE","gpio" OK Disconnect GPIO: at^scpin=0,7 Set GPIO as output driving high(1.8V): at^scpin=1,7,1,1 Disconnect GPIO: at^scpin=0,7 Set GPIO as output driving low(0V): at^scpin=1,7,1,0 3.6 Power Off In order to properly power off the modem, you need to issue the following AT command: AT^SMSO If shutdown properly occurs, you will receive: ^SMSO: MS OFF OK ^SHUTDOWN Do not remove power from the Skywire until after the: ^SHUTDOWN response is received, otherwise you may lose data. In addition, do not issue any AT commands after issuing this command​. PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 11 3.7 Power Cycling Shutting down the ​Skywire using the method described in Section 3.6 is the recommended shutdown procedure. However, ​if during a power cycle the VCC voltage level does not drop below 0.5V before the modem is restarted, or during operation an unwanted voltage drop occurs that causes VCC to fall below the operating level, but not below 0.5V, the modem might not properly reboot, because its reset condition was not reached. In this scenario it is recommended to reset the module with RESET_nIN after startup. If the modem is configured to automatically boot when power is applied (ON_OFF is connected to GND/pulled low) then the RESET_nIN signal may be generated automatically using an external reset monitor If the RESET_nIN pin is not available users will need to wait for the VCC rail to discharge below 0.5V before reapplying power. Please note: Using the RESET_nIN pin is only recommended as a last resort for resetting the Skywire, as it forcibly removes the Skywire from the cellular network. 3.8 Internal Firewall By default, the NL-SW-LTE-GELS3 has an internal firewall enabled that is configured to prevent all inbound connections to systems connected to the modem. The instructions to allow two-way connections are available under NDA. To obtain these instructions, contact Product Support at product.support@nimbelink.com. If you do not have an NDA with us currently, please fill out and sign the form linked below and include it in your support inquiry. Please make sure to fill out all blanks in the form or the NDA will not be approved. https://nimbelink.com/Documentation/Skywire/1001463_Document-Guide.pdf 3.9 Firmware Over-The-Air Updates (FOTA) LTE networks are constantly being updated, improved, and enhanced with new features. As a result, carriers are making frequent network changes. Most will not negatively affect devices connected to those networks, but occasionally an update will prevent an unprepared device from connecting to the network, permanently. To account for these future changes, FOTA capability is being added to all cellular modules by each module manufacturer, and NimbeLink supports this PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 12 functionality in the Skywire family of embedded modems. However, there is often a requirement to implement support for this FOTA functionality in your device firmware. As a developer using the Skywire modem, it is required that your device firmware plan to accommodate FOTA updates after deployment. Failure to do so may result in interruption of your device's cellular connectivity if the carriers implement a network change. If the device can no longer access the network, FOTA cannot be used to resolve the situation after the fact. The only way to restore connectivity will be physical access to the device to perform the updates directly on the devices​. If you have any questions or concerns, please email product.support@nimbelink.com 3.10 RESET_nIN The RESET_nIN signal is internally connected to the modem's processor. A low level for more than 15mS will trigger the modem to reset. It is internally pulled up to 3.8V via a 10K ohm resistor. The RESET_nIN signal should only be used when the modem is not responding to commands for more than 5 seconds. Asserting the RESET_nIN signal causes the loss of all information stored in the modems volatile memory. Therefore it should only be used in case of emergency (e.g. if the modem is not responding or it reset/shutdown via AT commands fail). 4. Mounting Guidelines The Skywire embedded cellular modem supports multiple connection methods, the two primary methods are board to board connectors and soldering directly to the baseboard. 4.1 Board to Board connectors approach The Skywire interface calls for two, 10 pin, 2mm pitch female receptacles. There are many connector manufacturers that can be used; below is one readily available product: Manufacturer: 3M Alternate: Sullins Connector Solutions Part Number: 950510-6102-AR Alternate P/N: NPPN101BFCN-RC Typical part drawing and footprint information: PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 13 4.2 Solder to Board connection approach The module can be soldered directly to a PCB. The PCB should be designed with two rows of ten, 0.8mm plated thru holes spaced 2mm apart. The two rows should be 22mm apart. See drawing for recommended footprint. Measurements are in millimeters. U.FL locations are marked with circles, X1 and X2 on top side of board, J3 is Micro SIM card slot on bottom side of board. PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 14 PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 15 5. Antenna Considerations 5.1 Primary Antenna Requirements Designers should review latest ELS31 Hardware User Guide to ensure the information is up to date. PRIMARY ANTENNA REQUIRMENTS Frequency Range Bandwidth Impedance Input Power Depending on the frequency bands provided by the network operator, the customer shall use the most suitable antenna for those bands LTE B4(1700): 445MHz LTE B13(700c): 41MHz 50 ohm >24dB 5.2 Diversity Antenna Requirements Designers should review latest ELS31 Hardware User Guide to ensure the information is up to date. RX DIVERSITY ANTENNA REQUIRMENTS Frequency Range Bandwidth Impedance PN 30122 rev 16 Depending on the frequency bands provided by the network operator, the customer shall use the most suitable antenna for those bands LTE B4(1700): 45MHz LTE B13(700c): 10MHz 50 ohm © NimbeLink Corp. 2020. All rights reserved. 16 5.3 Recommended Antennas Type Manufacturer Primary & Diversity Primary & GPS 1 Taoglas​ 1 Taoglas​ Part Number TG.30.8113 MA.301.A.AB.001 Note 1​: U.FL to SMA adapter required. For applications not using the recommended antennas, developers must ensure that the selected antenna(s) meet certain requirements. In order to maintain FCC and carrier specific certifications the antennas cannot exceed the maximum gain levels listed here: Frequency Max Gain (dBi) 700 MHz Band 10.41 dBi 1700 MHz Band 6.5 dBi 6. Certifications 6.1 Carrier Specific NL-SW-LTE-GELS3 Verizon OD Certified 6.2 Geography Specific Federal Communications Commission (FCC47) part 22, 24 Complies with FCC47 Part 15 Class B Radiated and Conducted Emissions 7. Federal Regulatory Licensing 7.1 Export Control Classification Number (ECCN) ECCNs are five character alpha-numeric designations used on the Commerce Control List (CCL) to identify dual-use items for export control purposes. An ECCN categorizes items based on the nature of the product, i.e. type of commodity, software, or technology and its respective technical parameters. All Skywire Modems: 5A992.c PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 17 7.2 Harmonized Tariff Schedule Code HTS Code: 8517.62.0010 8. End Product Labeling Requirements Device Uses Approved Radio: NL-SW-LTE-GELS3 Contains FCC ID: QIPELS31-V and IC ID: 7830A-ELS31V. This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interferences, and (2) this device must accept any interference received, including interference that may cause undesired operation. PN 30122 rev 16 © NimbeLink Corp. 2020. All rights reserved. 18
NL-SW-LTE-GELS3-B 价格&库存
很抱歉,暂时无法提供与“NL-SW-LTE-GELS3-B”相匹配的价格&库存,您可以联系我们找货
