BISMS02BI-NA
BISMS02BI-NA
    LAIRD(莱尔德)
    模块
    RF TXRX MOD BLUETOOTH CHIP+U.FL
BISMS02BI-NA 数据手册
BISMS02BI Embedded Bluetooth® AT Module The Embedded Bluetooth® AT Module is designed for applications that demand a robust and reliable Bluetooth connection. This product is designed with solder connections for mounting directly onto a main PCB. The integrated highperformance, multilayer ceramic antenna is highly resistant to de-tuning, allowing great flexibility in positioning. As well as incorporating a fully approved Bluetooth protocol stack, the module includes a comprehensive AT style interface that dramatically reduces application development time from months to days. The Bluetooth surface mount module is shipped with the powerful Laird Technologies Terminal Control Center software that allows simple configuration of the adapter for rapid product development. This, in combination with the Laird Technologies’ AT style interface, reduces wireless connectivity development time from months to days. Key Features  Integrated antenna - up to 300m range  Class 1 with +6dBm transmit power     USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless               (maximum) Current consumption less than 36 mA Version 2.0 Bluetooth Fully integrated Bluetooth stack Audio supported through PCM connection Simple AT style command set interface -40°C to +85°C operating range Data transfer rate up to 300kbps Lead free – RoHS compliant Multipoint support Adaptive frequency hopping Field upgradeable 2 year warranty Supports Wi-Fi co-existence Fully approved end product – No approval cost Surface mounted design Wide ranging profile support: SPP, DUN and FTP HCI version available Field upgradeable over UART Benefits        Fully integrated Bluetooth stack Fastest time to market Low power consumption Lowest cost of ownership Robust design for surface mount applications Extensive technical support BISMS02BI Embedded Bluetooth® AT Module FEATURE IMPLEMENTATION Bluetooth® Frequency Max Transmit Power Min Transmit Power Receive Sensitivity Range Serial Interface GPIO Serial Parameters (UART Version only) Class 1 2.402 – 2.480 GHz +6dBm -27dBm Better than -84dB Up to 300m (free space) 3.0V UART 6 x digital GPIO Default: 9600,n,8,1 From 1200 bps to 921.6 kbps DTR, DRS, RTS, CTS, DCD, RI DCE or DTE mode
BISMS02BI-NA
PDF文档中的物料型号为:LTC3886ES5#PBF。
器件简介:LTC3886是一款同步降压型DC/DC转换器,具有高效率和高精度。
引脚分配如下:1-GND,2-SW,3-Vin,4-Vout,5-FB,6-EN/UV,7-Ith,8-RT,9-INTVcc,10-PD,11-PG,12-Mode,13-Mode,14-Iadj,15-GND,16-Vin。
参数特性包括:输入电压范围:4.5V至38V,输出电压范围:0.6V至38V,最大输出电流:3A。
功能详解:LTC3886采用恒定频率电流模式架构,提供效率高、噪声低的解决方案。
应用信息:适用于需要高效率和高电流输出的应用场景。
封装信息:采用16引脚QFN封装。
BISMS02BI-NA 价格&库存
很抱歉,暂时无法提供与“BISMS02BI-NA”相匹配的价格&库存,您可以联系我们找货
