WISMC01BI
WISMC01BI
    LAIRD(莱尔德)
    模块
    RF TXRX MOD WIFI CHIP + U.FL ANT
WISMC01BI 数据手册
WISMC01 802.11b/g Wireless LAN Serial Module and Device Server Innovative Technology for a Connected World Laird Technologies’ WISMC01 Wireless LAN Processor Modules are the world’s most compact, feature-rich solutions for designers needing to add wireless connectivity to their products. With fully integrated drivers and stacks, this complete stand-alone, pre-qualified wireless solution requires minimum development to implement connectivity to any embedded product. The WISM range of modules offered by Laird Technologies are not simply Wireless LAN modules, but complete wireless processor systems capable of stand-alone operation. The dual-processor design supports an intelligent scripting language that simplifies the management of the radio control and operation, including full 802.11b/g drivers and protocols. They also contain a fully embedded TCP/IP stack and web server that provides dynamic information to an Internet application anywhere in the World. To simplify the development of wireless LAN applications, Laird Technologies created UWScript--a language designed to feel much like the BASIC language. Functionality is enhanced with a range of wireless specific tokens to bring simplicity to embedded wireless communication. This isolates users from the complexity of the wireless connection by providing high-level abstract commands. Complete functions, such as finding and connecting with access points or sending email, are provided as script libraries. These can be cut and pasted to produce complete working programs in a matter of hours. Using the sample UWScripts supplied with the Laird Technologies range of WISM modules, development of 802.11 Wireless LAN becomes a simple development task. Developers can also access a command line interface, a web configuration tool and a comprehensive set of AT commands. FEATURES AND BENEFITS APPLICATION AREAS • Complete serial Wireless LAN module • Wireless M2M Applications • Integrated drivers and TCP/IP stack • Embedded Wireless Connectivity • Full 802.11b/g support • ePOS • Dual processor design • Medical Equipment • Programmable web server • Telematics • Interpreter for local application support • Metering Applications • 16MB flash memory • Automotive Applications • Integrated multilayer ceramic antenna • Street Furniture • Excellent range • Industrial Automation • 921kbps data throughput • Infrastructure and ad-hoc modes • Full encryption – WEP, WPA2 personnel and enterprise • Optimised for low-power operation • Fast connection times • BASIC scripting language • UART interface • 12 x GPIO and 2 x ADC • Bluetooth coexistence support global solutions: local support USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless • AT Command interface and web configuration TM WISMC01 Innovative Technology for a Connected World 802.11b/g Wireless LAN Serial Module and Device Server CATEGORIES FEATURE IMPLEMENTATION Wireless Specification Standards Supported IEEE 802.11b, IEEE 802.11g Frequency 2.412 – 2.484 GHz Channels 11 channels – USA 13 channels – Europe 4 channels – France (EIRP > 10mW outdoors) 14 channels – Japan Programmable selection of region Max Transmit Power Antenna Modes UART Interface General Purpose Inter- 2 +15 dBm @ antenna connector +17 dBmi from integrated antenna +13 dBm @ antenna connector +15 dBmi from integrated antenna Receive Sensitivity 802.11b: -91dBm @ 1 Mbps, -84dBm @ 11Mbps 802.11g: -84dBm @ 6Mbps, -67dBm @ 54Mbps Range 50 metres Data Rates 54Mbps – 1Mbps with automatic fallback Data Transfer Rate Up to 921.6kbps Modulation Schemes 802.11b – BPSK, QPSK, CCK, DSSS 802.11g – BPSK, QPSK, 16-QAM, 64-QAM, OFDM Connection Modes Infrastructure and ad-hoc (IBSS) Integrated Antenna High performance +2dB multilayer ceramic External Antenna 50 Ohm U.FL connection Antenna Diversity Supported using integrated and external antennae Serial Interface RS-232 bi-directional for commands and data 16550 compatible Baud Rate Configurable from 9,600 to 921,600bps Bits 7 Parity Odd, even, none Stop bits 1 Default Serial parameters 115200,n,8,1 Levels 3.0V CMOS Modem Control DTR, DSR, DCD, RI, RTS, CTS † I/O 12 general purpose I/O pins, 3.0V CMOS† ADC 2 ADC inputs. 10 bit, 3.0V max Security Protocols 802.11b: 802.11b: 802.11g: 802.11g: Open Connection WEP encryption 64 and 128 bit options WPA-PSK WPA2 Enterprise & Personal IEEE 802.11i-PSK (AES-CCMP) TKIP Encryption SSL2 / SSL3 / TLS1 Hardware Acceleration for security features Network Drivers 802.11b, 802.11g Internet IPv4, TCP, UDP, DHCP Client, DNS Client, ARP, HTTP Server †DSR, DTR, RI and DCD are configurable either as GPIO or as modem control lines. WISMC01 Innovative Technology for a Connected World 802.11b/g Wireless LAN Serial Module and Device Server CATEGORIES FEATURE IMPLEMENTATION Web Server Features Serves web pages from the module Runs standard user generated HTTP web pages Provides access to I/O and ADC status Serves Dynamic Content from UWScripts Accepts POST inputs for control of scripts Allows dynamic control of ports Website Capacity 128kBytes ** Powersave modes IEEE Powersave Modes 0,1,5 & 6 Current Consumption Less than 250mA during data transfer with a configurable low power mode less than 5mA Supply 3.3V – 5.0V DC Regulation On-board regulators, brown-out detection and Specification ARM7 with 16Mb SRAM and 64Mb Flash Scripting Interpreter Runs UWScript Fully featured scripting language with wireless exten- Data Filing System User accessible Script Capacity 128kBytes ** Auto-run Optional Automatic script execution at power on WLAN functions Search, Attach, Detach, Security, Region, etc. Upgradeability Firmware upgradeable via UART Power Consumption Supply Voltage Embedded Wireless Processor System Configuration UW Script AT Command Interface Command Line Interface Web Configuration via 802.11 ad-hoc connection. Coexistence / Compatibility Bluetooth 2-wire and 3-wire hardware coexistence schemes supported Connections Interface 40 way Hirose DF-12 Connector External Antenna U.FL connector for 50 Ohm antenna Dimensions 22.8mm x 33.8mm x 7.6mm Weight 8 grams Operating Temperature Low Power Mode: -40°C to +85°C Continuous transmission: -40°C to +60°C Minimum cold start temperature: -25°C Physical Environmental ** Shared memory space for scripts and web content 3 WISMC01 802.11b/g Wireless LAN Serial Module and Device Server Innovative Technology for a Connected World CATEGORIES Approvals Miscellaneous Development Tools FEATURE IMPLEMENTATION Storage Temperature -50°C to +125°C FCC Modular Approval PI405W IC Industry Canada CE & R&TTE Approved Lead free Lead-free and RoHS compliant Warranty 2 Years Development Kit Development board and software tools UWTerminal Free downloadable terminal emulator UWScript Library Free example scripts for a wide range of applications ORDERING INFORMATION WISMC01BI WISMC04BI WISDK01BI 802.11b/g wireless LAN serial module with 40 pin connector 802.11b/g wireless LAN serial module with 50 pin connector (Siemens MC55 compatible) Development Kit for WISMC01BI with module Visit www.lairdtech.com/wireless for details on our full range of wireless products, as well as extensive range of white papers and applications notes. The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/wireless for the most current specification. global solutions: local support USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2268.6567 wirelessinfo@lairdtech.com www.lairdtech.com/wireless TM LWS-SPEC-WISMC01 0109 Any information furnished by Laird Technologies and its agents is believed to be accurate and reliable. Responsibility for the use and application of Laird Technologies materials rests with the end user since Laird Technologies and its agents cannot be aware of all potential uses. Laird Technologies makes no warranties as to the fitness, merchantability, or suitability of any Laird Technologies materials or products for any specific or general uses. Laird Technologies shall not be liable for incidental or consequential damages of any kind. All Laird Technologies products are sold pursuant to the Laird Technologies terms and conditions of sale in effect from time to time, a copy of which will be furnished upon request. For further information please visit our website at www. lairdtech.com. Alternatively contact: wirelessinfo@lairdtech.com. Bluetooth® is a trademark owned by Bluetooth SIG, Inc., USA and licensed to Laird Technologies. © 2009 All Rights Reserved. Laird Technologies is a registered trademark of Laird Technologies, Inc. 4
WISMC01BI 价格&库存
很抱歉,暂时无法提供与“WISMC01BI”相匹配的价格&库存,您可以联系我们找货
