TRBLU23-00300
TRBLU23-00300
    LAIRD(莱尔德)
    模块
    MODULE BLUETOOTH BISMII W/UFL
TRBLU23-00300 数据手册
TRBLU23 Bluetooth® Intelligent Serial Module The Bluetooth® Intelligent Serial Module is specifically designed for applications where robust short range connectivity is required. This particular module provides a reliable Bluetooth connection that exceeds all requirements in terms of performance. The excellent range of up to 300 meters with very low power consumption of less than 36 mA makes this module a true class leader. Key Features     USA: +1.800.492.2320 Europe: +44.1628.858.940 Asia: +852.2923.0610 wirelessinfo@lairdtech.com www.lairdtech.com/wireless Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth                  Best-in-class range provides open field connectivity in excess of 300 meters Integrated high-performance ceramic antenna Adaptive frequency hopping to cope with interference from other wireless products Optimised receive sensitivity to provide long range initial connections that largely eliminate connection hysterisis A full industrial operating temperature range of -40°C to +85°C Data transfer rate up to 300 kbps Fully approved product Class 1 version 2.0 Bluetooth Receive sensitivity better than -84 dBm Support for 128 bit encryption Non-discoverable modes 40 way Hirose connector 2 X 8 bit ADCs 9 X GPIO Low power modes Lead free 2 year warranty Supports Wi-Fi co-existence Embedded Bluetooth stack Integrated antenna with up to 300m range External antenna version available As well as incorporating a fully approved embedded Bluetooth protocol stack, the module includes a comprehensive AT style interface that dramatically reduces the development time of applications from months to days. 1 Americas: +1-800-492-2320 Europe: +44-1628-858-940 Hong Kong: +852 2923 0610 TRBLU23 Bluetooth® Intelligent Serial Module FEATURE IMPLEMENTATION Bluetooth® Frequency Max Transmit Power Class 1 2.402 – 2.480 GHz +6 dBm (internal antenna - TRBLU23-00200) +4 dBm (at u.fl connector - TRBLU-23-00300) -27 dBm 2.5 mA typical Better than -84dB 300m (free space) 3.3 V UART 9 x digital GPIO Default: 9600,n,8,1 From 1200 bps to 921.6 kbps DTR, DRS, RTS, CTS, DCD, RI DCE or DTE mode Idle mode = 13mA Connected as master = 20mA 25.0 x 35.0 x 7.6 mm, 8 g Internal – Multilayer Ceramic External – Connection via U.FL connector Bluetooth 2.0 RoHS Compliant -40˚C to +85˚C 3.3 V Supported Supported Over UART 2 x 8bit UART, AT command set, Multipoint Up to 300 kbps Min Transmit Power Low Power Sniff Receive Sensitivity Range Serial Interface GPIO Serial Parameters Current Consumption Physical Size Antenna Bluetooth Qualified Lead Free Temperature Range Interface Levels Audio Multipoint Field Upgrades ADC Protocols Data Transfer Rate Ordering Information TRBLU23-00200 Bluetooth Serial Module with integrated antenna TRBLU23-00300 Bluetooth Serial Module with U.FL connector for external antenna The details contained within the document are subject to change. Download the product specification from www.lairdtech.com/wireless for the most current specification. Embedded Wireless Solutions Support Center: http://ews-support.lairdtech.com www.lairdtech.com/bluetooth 2 Version 1.0 Date Description Initial Release Approver Jonathan Kaye
TRBLU23-00300 价格&库存
很抱歉,暂时无法提供与“TRBLU23-00300”相匹配的价格&库存,您可以联系我们找货
