SG901-1028
SG901-1028
    SAGRAD
    Module
    MODULE WIFI RADIO 802.11B/G
SG901-1028 数据手册
SG901-1028 Miniature Wi-Fi Radio Overview Features The SG901-1028 is a single chip based 802.11b/g WLAN radio for embedded, lowpower and very small form factor mobile applications. The product conforms to the IEEE 802.11b and 802.11g protocols operating in the 2.45GHz ISM frequency band supporting OFDM data rates of 54, 48, 36, 24, 18, 12, 9, and 6Mbps. It also supports CCK data rates of 11 and 5.5Mbps and legacy data rates of 2 and 1Mbps. • FCC Module Certification • RoHs Compliant • Fully integrated 802.11 Solution • Custom drivers available for your host • Extremely small footprint • Ultra Low Current consumption • Fully compliant with the IEEE 802.11b and 802.11g WLAN standards • Support for 54, 48, 36, 24, 18, 12, 9, and 6Mbps OFDM, 11 and 5.5Mbps CCK and Legacy 2 and 1Mbps data rates • Single Chip 802.11b/g WLAN solution with fully integrated: The SG901-1028 is a fully integrated wireless radio including a ZIF transceiver, RF Synthesizer/VCO, high-speed data converters, an OFDM/CCK digital baseband processor, an ARM9-based MAC and a complete Power Management Unit. The on module Power Amplifier completes a highly integrated chip set solution. Host control is provided by either an SDIO or SPI interface. This complete design allows quick integration into a number of different applications. ° ° ° ° ° ° ° ° Zero IF (ZIF) transceiver Voltage Controlled Oscillator (VCO) High-Speed A/D and D/A Converters Radio Power Management Unit OFDM and CCK baseband processor ARM9 Media Access Controller (MAC) SPI serial host interface (up to 48MHz) SDIO serial host interface (up to 50MHz) • Intelligent Power Control, Including 802.11 Power Save Mode • Supports SPI interface • Supports SDIO interface Applications • Personal Digital Assistants (PDA) • Portable Computers • Hand-held Data Transfer Devices • Cameras • Computer Peripherals • Cable Replacement • Cellular Phones Ordering Information SG901-1028-C-TR SG901-1028-C-BLK SG901-1028-ET-TR SG901-1028-ET-BLK 1-321-255-0515 www.sagrad.com Commercial temperature, Tape and Reel Commercial temperature, Bulk Extended temperature, Tape and Reel Extended temperature, Bulk DOC#: SG914-0005 Rev 9.1 Block Diagram Wi-Fi MODULE Antenna Connector STLC4560 Power Management Unit Host Interface Connection SPI/SDIO ZIF Transceiver Power Amplifier Baseband Processor MAC High-Speed Data Converters FCC Certification Comment FCC ID Certified for use with these Antennas Other Antennas 1-321-255-0515 VRA-SG9011028 W1038 Pulse Antennas 2.4 – 2.5 GHz with Reverse SMA connector W1037 Pulse Antennas 2.4 – 2.5 GHz with Reverse SMA connector MLPV2400NGP PCTEL Ant 2.4 – 2.5 GHz with reverse SMA 13018-1 Beijing Evercommunication Ant 2.4 – 2.5 GHz with IPX (U.FL Compatible, recommended for cost sensitive applications) Additional Antennas may be added to the approval list at additional cost. Contact Sagrad for additional information WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 General Electrical Specifications Parameter Test Condition / Comment Min. Typ. Max. Units -0.3 4.0 V 0 70 °C Absolute Maximum Ratings 3.3V Supply Operating Conditions and Input Power Specifications Operating Temperature Range (See ordering information) 3.3V Supply VHIO Supply Commercial Extended temperature -30 Input Supply Voltage Power Management Unit 3.3V Supply input 3.0 Standby Mode Current Power Save Mode Current 3.3V, 25°C, POWERUP=1.8V, Sleep clock 32.768kHz 100mS beacon period, 75 byte beacons @ 1Mbps, short Preamble, DTIM = 3 Shutdown Current 3.3V 25°C, POWERUP=0V Peak TX Current During Transmitting packets, 3.3V, 25°C Peak RX Current During Receiving packets, 3.3V, 25°C Input Supply Voltage VHIO input supply determines Host CMOS logic levels Input Supply Current Standby Mode Current 3.3 420 85 °C 5.5 V 0.5 mA 2 mA 8 uA 520 mA 253 1.62 mA 1.8 1.98 V VHIO = 1.8V 0.5 6 mA VHIO = 1.8V 10 uA Digital Interface Specifications (25°C) Parameter Test Condition / Comment Min. Typ. Max. Units 0.8 1.98 V 0 0.3 V Digital Interface Specifications VIH POWER UP Input PMU Power up control. Active High VIL Pull-Down Host CMOS Inputs VIH 500 VHIO supply domain VIL VOH Host CMOS Outputs IOH = 0.2mA, VHIO supply domain VOL IOL = 2mA, VHIO supply domain Input Current VHIO supply domain VHIO V 0 0.3*VHIO V VHIO 0.2 VHIO V 0 0.4 V -1.0 +1.0 uA Frequency SLEEP_CLK Input Accuracy kΩ 0.7*VHIO 32.768 VHIO supply domain Duty Cycle 30 kHz 500 ppm 70 % Max. Units RF Characteristics (25°C) Parameter Test Condition / Comment RF Frequency Range 802.11 G 54Meg RF Output Power (note 1) Meeting FCC and 802.11 EVM 2500 12 MHz dBm Meeting FCC and 802.11 EVM 15 dBm 802.11 B 11Meg Meeting FCC and 802.11 EVM 15 dBm 802.11 G 6Meg -71 10% PER 802.11 B 11Meg FCC Compliance Typ. 802.11 G 6Meg 802.11 G 54Meg Receiver Sensitivity Min. 2400 dBm -88 dBm -84 dBm Passed FCC part 15C Note 1: Output Power is measured at the RF Antenna 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Inputs/Outputs Required ` Comment Digital Connector RF Connector Power Location LGA interface - (see connector pin list) Part Number Hirose U.FL-R-SMT(10) Location Top Side 3.3V Input Supply Voltage Connector Pin List SIGNAL NAME VHIO PIN NUMBER 28, 29 DESCRIPTION NOTES Supply Voltage for I/O's Recommended I/O voltage range 1.6V to 2.0V (nominal 1.8V) (see note 1). SPI_CSn 20 SPI_DI 22 SPI: Serial Host Chip Select/SDIO: Data 3 SPI: Serial Host Data Input/SDIO: Data 0 SPI_CLK 18 SPI: Clock/SDIO: CLK SPI_DO 19 SPI: Serial Host Data Output/SDIO: CMD SDIO_SDAT2 21 SDIO: Data 2 IRQ 23 SPI: Serial Host Interrupt/SDIO: Data 1 SERHOSTMODE 3 SPI/SDIO Select High = SPI, Low = SDIO POWER UP 4 Power Up Enable (from host) High = normal mode, Low = Sleep Mode SLEEPCLK 17 32.768 kHz Sleep Clock 3.3V 12, 13, 26, 27 GND 1, 2, 5, 6, 7, 8, 9, 10, 11, 14, 15, 16, 24, 25, 30, 31 Input Supply Further decoupling may be required to sustain 250mA inrush currents during packet transmission Ground Connections Note 1: This I/O supply operates to 3.3V. However, it is recommended that a level translator to 1.8V be used on host applications beyond 2.0V (i.e. TI-TXS0108 for SDIO). 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Encryption Support Feature Windows Linux CE WEP Yes Yes Yes TKIP Yes Yes Yes AES/CCMP (HW accel) Yes Yes Yes Security WPA Yes-WZC WPA2 Yes Third Party Supplicant Third Party Supplicant WZC (shared key), Third party suppl. Third Party Supplicant QoS HCF (Q1/2006) Q1/06 Q1/06 Q1/06 WMM Yes Yes Yes WMM U-APSD Yes Yes Yes EDCF Yes Yes Yes Q1/06 Q1/06 Q1/06 WMM-SA (Q1/2006) Cisco Standards CCX v1 Yes CCX v2 Yes Third Party Supplicant Third Party Supplicant Third Party Supplicant Third Party Supplicant Certifications 802.11d Support Yes Yes Yes WiFi Certification Yes Yes* Yes* (XP certification transfers) WHQL NA NA NA Bluetooth Coexistence PTA (802.15.2) Yes Yes Yes 802.11/BT on same Antenna Yes Yes Yes 802.11/BT on 2 Antennas Yes Yes Yes Data and Voice Simultaneously Yes Yes Yes Data and Data Simultaneously Yes Yes Yes Voice and Voice Simultaneously Yes Yes Yes *Throughput depends on SPI speed. We recommend a 33Mhz SPI to pass WiFi PDA Throughput requirements 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Software Support Little Endian 1-321-255-0515 Arm X Arm4 X Arm9e X Armi X i386 X mips X Big Endian X powerpc X sh X sh4 X thumb X xscale X WWW.SAGRAD.COM X DOC#: SG914-0005 rev. 9.1 HW/SW Overview - SoftMAC Architecture • User Space, WPA Supplicant – – Supplicant required to: •Handle user input/configuration WPA handshaking •Transport protocol (EAP/PEAP) •Handle certificates •Install keys in UMAC • Wi-Fi DRIVER – Allows for porting to custom embedded OS and Processor Host USERSPACE/WPA SPACE/WPASUPPLICANT SUPPLICANT USER 802.3 Frames Kernel DRV DRV DRV DRV Wi-Fi DRIVER* Upper API Driver API UMAC • UMAC – Binary Library file •Links with driver •Provides configuration API to: – Select encryption type – Set Key •Handles initial Authentication/Association to the AP •Configures LMAC for the correct encryption 802.11 Frames and control messages Resource management: frames, memory, timers, debug Wi-Fi Module • LMAC – – Binary file, contains ARM executable code Hardware encryption/decryption of data according to configured encryption type and key. Hardware Layer LMAC LMAC Customer responsible for porting the WiFi Driver and any user space applications such as the supplicant. SG923-0002 EVK PC-16/SPI Performance Kit (1) SG901-1028 802.11 b & g fully FCC certified Wi-Fi module soldered on a carrier board (1) PCMCIA board for SPI applications (1) Interposer board (1) Software Driver CD (1) Data sheet for the SG901-1028 (1) Schematics of interposer board (1) Schematics of PCMCIA board 1-321-255-0515 Interconnect API SG923-0003 SDIO/SPI Embedded Software Eval Kit (1) SG901-1028 802.11 b & g fully FCC certified Wi-Fi module soldered on carrier board (1) SDIO interface board for SDIO applications (1) Software Driver CD (1) Data sheet for the SG901-1028 (1) Schematics of SDIO board WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Mechanical • • Maximum Peak Reflow Temperature: 240oC Recommended Reflow Profile: • Moisture Level Sensitivity : 3 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Module Dimensions: Parameter Min. Typ. Dimension Length Width Height 24.51 19.00 3.63 Max. Units mm mm mm 0.043 [1.09] 0.146 [3.71] 0.143 [3.63] 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Recommended Layout NOTE: Center paddle is centered on package layout. 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1 Tape and Reel Information 10mm 4mm 36mm 44mm 36m m 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0005 rev. 9.1
SG901-1028 价格&库存
很抱歉,暂时无法提供与“SG901-1028”相匹配的价格&库存,您可以联系我们找货
