SG901-1047
SG901-1047
    SAGRAD
    模块
    MODULE WIFI 802.11 B/G 3.3V
SG901-1047 数据手册
SG901-1047 Flexible Interface Wi-Fi Radio Overview Features The SG901-1047 Kraken is an 802.11b/g WLAN assembly which includes an 802.11 radio designed for easy integration of 802.11 into existing and new products with very little development time. Kraken supports a variety of interfaces for simple integration with most any user product. • Linux OS sources available to support • Fully integrated FCC Certified 802.11 Solution • Ready for customer application integration • Control interface customization available • Customer can develop their own interfaces to their products. • Variety of Standard Communications Interfaces - 10/100Base-T (external magnetics) - 3 UART ports (TTL Level) - 2 USB ports – 1+1 Device/Host or 2 Host - 1 SPI port • GPIO and Peripherals - I2S Digital Audio interface - 8-bit camera interface - Timer I/O - Most serial and peripheral signals can be used for GPIO if not otherwise employed • 128Mbytes on board Flash • 16Mbytes on board RAM • Small, low-profile footprint • Low Current consumption • Fully compliant with IEEE 802.11b and g WLAN standards • Intelligent Power Control, Including 802.11 Power Save Mode • RoHs Compliant The SG901-1047 is a fully functional wireless radio including a single-chip 802.11b/g transceiver, an ARM9 processor, flash and SDRAM memories, and a 10/100 Ethernet combo. The system is shipped running Linux with Wi-Fi ready for customer use. Application software and OS changes are supported through the Linux system source code provided by Sagrad. The on board 802.1 radio conforms to the IEEE 802.11b and 802.11g protocols operating in the 2.45GHz ISM frequency band supporting OFDM data rates of 54, 48, 36, 24, 18, 12, 9, and 6Mbps. It also supports CCK data rates of 11 and 5.5Mbps and legacy data rates of 2 and 1Mbps. Kraken connects to the user system through a readily available 50-pin connector for power, ground, and all peripheral signaling. In addition to standard serial communications interfaces, RS233, Ethernet, USB, SPI, I2C, Kraken supports standard audio and camera connections as well. Installed Software: • U-Boot boot-loader • Linux 2.6 kernel • Wireless kernel driver Applications • Instant Wired ethernet to Wireless • Industrial Applications • High Speed Printers • Medical Markets • Remote Cameras • Embedded Systems • VOIP Systems • Wireless Internet Radio Ordering Information 1-321-255-0515 Packaging Order Number Bulk Only Bulk Only Eval Kit SG901-1047C-BLK 0ᑻ to 70ᑻC SG901-1047I-BLK -30ᑻ to 85ᑻC SG923-0004 WWW.SAGRAD.COM Temp Range DOC#: SG914-0011 rev. 2.2 SG901-1047 Kraken Block Diagram 3.3V 16Mbyte SDRAM 3.3V 128Mbyte NAND Voltage Regulators PWREN Samsung S3C2440A UART0 UART1 UART2 USB0 USB1 USB host USB device I2S SPI Camera Removable Debug Port 1-321-255-0515 JTAG SDIO 50pin Hirose Connector 10/100Mbps Ethernet Combo Ext Bus 3.3V SPI WWW.SAGRAD.COM Diamondback WiFi Module U.FL Antenna Connector DOC#: SG914-0011 rev. 2.2 General Electrical Specifications Parameter Test Condition / Comment Min. Typ. Max. Units 4.0 V Absolute Maximum Ratings 3.3V Supply -0.3 Operating Conditions and Input Power Specifications Operating Temperature Range Input Supply Voltage Standby Mode Current Power Save Mode Current 3.3V Supply SG901-1047C 0 70 °C SG901-1047I -30 85 °C Power Management Unit 3.3V Supply input 3.1 3.6 V 3.3 3.3V, 25°C, SDRAM data retained 5 mA 100mS beacon period, 75 byte beacons @ 1Mbps, short Preamble, DTIM = 3 10 mA Sleep Current 3.3V 25°C, no data retention, wakeup on events 380 uA Idle Wireless disabled, running full-speed 250 mA Average TX Current Full-speed, transmitting packets, 3.3V, 25°C 450 mA Average RX Current Full-speed, Receiving packets, 3.3V, 25°C 450 mA Digital Interface Specifications Parameter Test Condition / Comment Min. Typ. Max. Units 3.6 V Digital Interface Specifications VIH CMOS Inputs CMOS Outputs 2.0 VIL -.3 0.8 V Input Current -10 +10 uA VOH IOH = 4mA VOL IOL = 4mA 2.4 V .4 V Max. Units 2500 MHz RF Characteristics Parameter Test Condition / Comment RF Frequency Range RF Output Power Typ. 802.11 G 54Meg Meeting FCC and 802.11 EVM 802.11 G 6Meg Meeting FCC and 802.11 EVM 15 dBm 802.11 B 11Meg Meeting FCC and 802.11 EVM 15 dBm 802.11 G 54Meg Receiver Sensitivity 12 dBm -68 dBm -88 dBm 10% PER 802.11 G 6Meg FCC Compliance Min. 2400 Passed FCC part 15C Note 1: Output Power is measured at the RF Antenna 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0011 rev. 2.2 Connector Pinout and Description – Hirose DF12B(3.0)-50DS-0.5V SIGNAL NAME PIN NUMBER DESCRIPTION NOTES Ethernet Interface LAN_TPO- 3 Ethernet transmit negative LAN_TPO+ 4 Ethernet transmit positive external magnetics required external magnetics required LAN_TPI- 6 Ethernet receive negative external magnetics required LAN_TPI+ 7 Ethernet receive positive external magnetics required AC97 or I2S and Timer Signals TCLK0 11 Timer 0 clock input or GPIO TOUT2 12 Timer 2 output or GPIO TOUT3 13 Timer 3 output or GPIO I2S_LRCK 14 I2S frame output, AC97 SYNC, or GPIO I2S_SDO 15 I2S/AC97 serial data output or GPIO I2S_SDI 16 I2S/AC97 serial data input or GPIO I2S_SCLK 17 I2S/AC97 serial clock input/output or GPIO I2S_CDCLK 18 I2S master clock output, AC97 RST, GPIO RXD2 20 UART2 Receive Data (input) TXD2 21 UART2 Transmit Data (output) 3.3V CMOS level RXD1 22 UART1Receive Data (input) 3.3V CMOS level TXD1 23 UART1Transmit Data (output) 3.3V CMOS level RXD0 24 UART0 Receive Data (input) 3.3V CMOS level TXD0 25 UART0 Transmit Data (output) 3.3V CMOS level UARTs 3.3V CMOS level SPI SPI_CLK 27 SPI 1 Serial Clock SPI_MOSI 28 SPI 1 master out slave in or GPIO SPI_MISO 29 SPI 1 master in slave out or GPIO SS 30 SPI 1 slave select or GPIO USB_N1 32 USB host or device negative USB USB_P1 33 USB host or device positive USB_N0 34 USB host negative USB_P0 35 USB host positive Camera CAMD7 - 0 37, 38, 39, 40, 41, 42, 43, 44 Camera data bit 7 - 0 or GPIO CAMRESET 45 Camera reset output or GPIO CAMCLKOUT 46 Camera master clock output or GPIO CAMHREF 47 Camera horizontal sync input or GPIO CAMVSYNC 48 Camera vertical sync input or GPIO CAMPCLK 49 Camera pixel clock input or GPIO Power 3.3V 1, 2 GND 5, 8, 19, 26, 31, 36, 50 No Connect 1-321-255-0515 9, 10 Input Supply Ground Connections No internal connection WWW.SAGRAD.COM DOC#: SG914-0011 rev. 2.2 Mechanical 1-321-255-0515 WWW.SAGRAD.COM DOC#: SG914-0011 rev. 2.2
SG901-1047 价格&库存
很抱歉,暂时无法提供与“SG901-1047”相匹配的价格&库存,您可以联系我们找货
