SG901-1059-5C
SG901-1059-5C
    SAGRAD
    模块
    MODULE WIFI 802.11 B/G/N 5V
SG901-1059-5C 数据手册
SG901-1059 802.11 b/g/n Wireless USB Module Overview The SG901-1059 is a high speed module supporting all datarates and the latest standards including 802.11B/G/N Wi-Fi module with a USB 2.0 interface. This module’s high level of interoperability and its low cost is desirable for high volume applications. This product is suited for many embedded systems able to support Windows and Linux OS including high bandwidth applications such as set top box. Features      SG901-1059 WLAN module is designed to operate in 2.4GHz ISM frequency band, it applies a highly integrated MAC/BBP and RF single chip RT3070 with 150Mbps PHY rate supporting. Ralink fully complies with IEEE802.11n draft 3.0 and IEEE802.11b/g feature.    802.11b: 1, 2, 5.5, 11Mbps 802.11g: 6, 9, 12, 24, 36, 48, 54Mbps 802.11n: o (20MHz) MCS0-7, Support up to 72 Mbps o (40MHz) MCS0-7, Support up to 150Mbps OFDM, Peak rate 150Mbps Security support for 64/128 WEP, WPA, WPA2, TKIP, AES Operates in 2.4GHz frequency bands. Low Power Consumption Single antenna configuration; I-PEX receptacle for external antenna. Applications        Personal Digital Assistants (PDA) Hand-held Data Transfer Devices Video IP Cameras IP set top box GPS Internet radio apparatus Ordering Information SG901-1059-3.3-C (connector) – Bulk only SG901-1059-5.0-C (connector) – Bulk only SG901-1059-3.3-H (header) – Bulk only SG901-1059-5.0-H (header) – Bulk only 1-321-255-0515 WWW.SAGRAD.COM DOC#: 914-0016 rev. 3 Block Diagram System Block Diagram of SG901-1059 WLAN Module 1-321-255-0515 WWW.SAGRAD.COM DOC#: 914-0016 rev. 3 General Electrical Specifications Parameter Test Condition / Comment Min. Typ. Max. Units 7.0 V 0 +50 ᑻC -20 +85 ᑻC 5.2 V 3.48 V Absolute Maximum Ratings USB Supply -0.3 Operating Conditions and Input Power Specifications Operating Range Operating Temperature Range Storage Range USB 2.0/1.1 PC Interface Plug & Play Compatible YES Supply Voltage SG901-1059-5.0 4.75 Supply Voltage SG901-1059-3.3 3.14 3.3 RF Characteristics Parameter Test Condition / Comment Min. Typ. Internal Antenna Impedance RX Sensitivity 50 TX Spectral MASK Units Ohms 11b, 11Mbps -84 dBm 11g, 54Mbps -68 dBm (HT20) 11n, MSC7 -66 dBm (HT40) 11n, MSC7 TX Output Power Max. -62 dBm 11b, 11Mbps 18 19 20 dBm 11g, 54Mbps 15.5 17 18.5 dBm 802.11n (HT20) 14.5 16 17.5 dBm 802.11n (HT40) 14.5 16 17.5 dBm 110 mA CCK PASS OFDM PASS QPSK PASS BPSK PASS Preamble Length Long/Short Operating Current Interface Details Sagrad Part # Part Number Item ACESCONN 87213-0600l Host Interface Connector Host Interface Connector SG901-1066 SG901-1059-xx-C SG901-1059-xx-H 1-321-255-0515 Antenna WWW.SAGRAD.COM Comment External Antenna via an I-PEX receptacle 6 Pin 1.0mm Pitch Connector 6 Pin 2.0mm Male Header DOC#: 914-0016 rev. 3 Connector Pin List (Host Interface) 6-pin 1.0mm pitch connector SIGNAL NAME PIN NUMBER DESCRIPTION NOTES VCC (3.3 or 5.0 VDC) 1 Supply USB Standard Function UD- 2 Complementary USB Data USB Standard Function UD+ 3 Complementary USB Data USB Standard Function GND 4 Ground USB Standard Function LED 5 Low Active for WLAN LED Link. TX 6 Low Voltage to disable RF function 6-pin 2.0mm pitch male header SIGNAL NAME DESCRIPTION NOTES VCC (3.3 or 5.0 VDC) 1 Supply USB Standard Function UD- 2 Complementary USB Data USB Standard Function UD+ 3 Complementary USB Data USB Standard Function GND 4 Ground USB Standard Function TX 5 Low Voltage to disable RF function LED 6 Low Active for WLAN LED Link. 1-321-255-0515 PIN NUMBER WWW.SAGRAD.COM DOC#: 914-0016 rev. 3 Mechanical Drawing 6-pin 1.0 mm pitch male connector 6-pin 2.0 mm pitch male header For custom applications: the direction of the male header can be mounted upside down, please contact Sagrad Inc. for availability. 1-321-255-0515 WWW.SAGRAD.COM DOC#: 914-0016 rev. 3 Regulatory Approval Agency Approval Industry Canada In-Process FCC In-Process Part 15  CE  RoHS  Suggested Antennas • • Airgain N2420 Thinkyard T000701 & T000805 Software Support Operating System Driver Linux 2.4/2.6 Available Windows 2000/XP/VISTA Windows CE 5.0/6.0 Available Available Security Support • Complete Security Features – WPA/WP2, 64/128/152-bit WEP, WPS 1-321-255-0515 WWW.SAGRAD.COM DOC#: 914-0016 rev. 3
SG901-1059-5C
物料型号为SG901-1059。
该器件是一款支持802.11 b/g/n标准的无线USB模块,适用于2.4GHz ISM频段,拥有USB 2.0接口。
其主要特性包括: - 支持802.11b/g/n标准,速率可达150Mbps - 采用单天线配置,I-PEX接口用于外接天线 - 低功耗设计 - 提供多种封装选项,如SG901-1059-3.3-C和SG901-1059-5.0-H等
引脚分配为6针,包括3.3或5.0V的电源VCC、USB数据正负UD+和UD-、地线GND、用于WLAN指示的LED、用于禁用射频功能的TX。
参数特性包括: - 工作电压:SG901-1059-5.0为4.75-5.2V,SG901-1059-3.3为3.14-3.48V - 接收灵敏度:802.11b/g/n分别为-68dBm、-66dBm、-62dBm - 发射功率:802.11b/g/n(20MHz)/802.11n(40MHz)分别为18-20dBm、15.5-18.5dBm、14.5-17.5dBm - 工作电流:110mA
应用场景包括个人数字助理、手持数据传输设备、视频IP摄像头、IP机顶盒、GPS互联网收音机等。
封装信息提供了详细的机械图纸,包括6针1.0mm间距连接器和6针2.0mm间距的公头。
此外,模块还支持多种操作系统的驱动程序,包括Linux和Windows,并具备完整的安全特性,如WPA/WPA2、64/128/152位WEP和WPS。
SG901-1059-5C 价格&库存
很抱歉,暂时无法提供与“SG901-1059-5C”相匹配的价格&库存,您可以联系我们找货
