MTSMC-C1-N16-SP
MTSMC-C1-N16-SP
    MULTI-TECHSYSTEMS
    Module
    RF TXRX MODULE CELLULAR MMCX ANT
MTSMC-C1-N16-SP 数据手册
SocketModem CDMA ® Embedded Cellular Modem Universal Socket Benefits • Interchangeable communications devices • Quick-to-market • Global approvals • Easy migration to future networks The Multi-Tech SocketModem® CDMA cellular modem is a complete, ready-to-integrate communications device that offers standards-based dual-band CDMA2000 1xRTT performance. This quick-to-market communications device allows developers to add wireless communication to products with a minimum of development time and expense. The SocketModem CDMA cellular modem is based on industry-standard open interfaces and utilizes Multi-Tech's Universal Socket design. Features • CDMA2000 1xRTT • Qualcomm® MSM6050 chipset • CDMA IS-95A, IS-95B backwards compatible • Dual-band 800/1900 MHz CDMA • Universal Socket connectivity • Packet data up to 153.6K bps forward and reverse • Circuit-switched data up to 14.4K bps • Short Message Services (SMS) • MMCX antenna connector • Serial interface supports DTE speeds to 230K bps • AT command compatible • CDG 1 and 2 network certified • Two-year warranty Highlights Applications. The SocketModem CDMA cellular modem is targeted at applications that periodically need to send or receive data over a wireless network. It is ideal for: Developer's Kit. The Developer's Kit allows you to plug in the communications device and use it for testing, programming and evaluation. The kit includes one development board with RS-232 DB-25 connector, universal power supply, antenna and RS-232 cable. • Appliances • Remote diagnostics • Asset tracking • Remote metering • ATM terminals • Security systems Specifications • Automotive • Vending/gaming machines Packet Data Features • Data collection • Other devices requiring wireless connectivity • Industrial and medical remote monitoring systems CDMA2000 1xRTT, up to 153K bps forward & reverse channels Circuit Switched Data/Fax Features Integration Reduces Space, Power and Cost. The SocketModem CDMA cellular modem integrates the controller, RF transceiver, and antenna interface into one communications device. This integration requires low power, low real estate and provides an overall reduction in costs. IS-95A, IS-95B up to 14.4K bps SMS Features Text & PDU, Point-to-Point, cell broadcast Connectors Antenna: MMCX Reduces Development Time. The SocketModem CDMA cellular modem enhances your product while you focus on developing its core features. It actually provides faster time‑to‑market because it relieves the burden and expense of obtaining CDG 1 and 2 network and RF approvals. Power Requirements Management Features. The SocketModem CDMA cellular modem provides advanced management features including phone book management, fixed dialing number, real time clock and alarm management. Operating Environment SocketModem CDMA Pin-Out. The SocketModem CDMA cellular modem interfaces easily with existing products through a standard serial communication channel. The serial DTE channel is capable of transfer speeds to 230K bps and can be interfaced directly to a UART or microcontroller. The complete onboard RF transceiver interfaces with an antenna for direct connection to wireless SMS, circuit‑switched dial‑up, or packet data networks. It also includes an onboard LED to display network status. Universal Socket Connectivity. Multi-Tech’s Universal Socket is a flexible, comm-port architecture that provides cellular, Ethernet, PSTN or Wi-Fi® network access with interchangeable communications devices. This means you can utilize one system design and populate it with your connectivity device of choice accommodating multiple connectivity requirements. In addition, you are assured a seamless migration to future technologies. World Headquarters Tel: (763) 785-3500 (800) 328-9717 www.multitech.com 5/10 86002039 5VDC; 400mA typical, 700mA maximum Physical Description 3.1" L x 1.4" W x 0.5" H; 1.2 oz. (8.0 cm x 3.5 cm x 1.2 cm; 34 g) -30° to +70° C (FCC certified from -30° to +50° C) Certifications EMC: FCC Part 2, 15, 22, 24, EN 55022, EN 55024 Safety: cUL, EN 60950, UL 60950 Network: CDG 1 & 2 RoHS Compliant Ordering Information Product MTSMC-C* Ordering Codes -N2 -N3 -N16 Copyright © 2010 by Multi-Tech Systems, Inc. All rights reserved. Region Regional * Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. Made in Mounds View, MN, U.S.A. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: SocketModem, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Description 800/1900 MHz CDMA Modem Description For Sprint Networks (USA) For Verizon Networks (USA) For Aeris Networks (USA) Multi-Tech Systems (EMEA) France Tel: +(33) 1 49 19 22 06
MTSMC-C1-N16-SP 价格&库存
很抱歉,暂时无法提供与“MTSMC-C1-N16-SP”相匹配的价格&库存,您可以联系我们找货
