CC-WMX-LB58-VM-B
CC-WMX-LB58-VM-B
    DIGIINTERNATIONAL
    模块
    MOD WI-I.MX51 256MB FLASH 25PK
CC-WMX-LB58-VM-B 数据手册
ConnectCore® for i.MX51 Hardware Reference Manual Revision history—90001128 Revision Date Description M May, 2014 Correct inaccuracy and sharpen clarity on the high temp start up issue. N November, Miscellaneous editorial updates. Updated the voltages for the table in Coin 2014 cell input (VCC_COINCELL). Added a table of related publications. P June, 2017 Updated branding and added statements for RED compliance. R April, 2018 Added coin cell input topic. S January, 2019 Added backdrive caution. Trademarks and copyright Digi, Digi International, and the Digi logo are trademarks or registered trademarks in the United States and other countries worldwide. All other trademarks mentioned in this document are the property of their respective owners. © 2019 Digi International Inc. All rights reserved. Disclaimers Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International. Digi provides this document “as is,” without warranty of any kind, expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. Warranty To view product warranty information, go to the following website: www.digi.com/howtobuy/terms Customer support Gather support information: Before contacting Digi technical support for help, gather the following information:    Product name and model    Product serial number (s)    Firmware version    Operating system/browser (if applicable)    Logs (from time of reported issue)    Trace (if possible)    Description of issue    Steps to reproduce ConnectCore for i.MX51 Hardware Reference Manual 2 Contact Digi technical support: Digi offers multiple technical support plans and service packages. Contact us at +1 952.912.3444 or visit us at www.digi.com/support. Feedback To provide feedback on this document, email your comments to techcomm@digi.com Include the document title and part number (ConnectCore for i.MX51 Hardware Reference Manual, 90001128 S) in the subject line of your email. ConnectCore for i.MX51 Hardware Reference Manual 3 Contents About the module Features and functionality Module variant Block diagram CPU Module Module pinout Pinout legend Pinout definitions J1 pinout J2 pinout Power Module power supplies Supply inputs Supply outputs MC13892 power management Memory DDR2 SDRAM memory NAND flash memory Chip selects Chip select memory map Multiplexed GPIO GPIO multiplexing table Interfaces 1-Wire Accelerometer ADC and touch screen Synchronous Serial Interface (SSI) External Memory Interface (EMI) Ethernet 1 Ethernet 2 I2C Video subsystem Video Processing Unit (VPU) Image Processing Unit (IPU) Keypad Memory cards PWM RTC SPDIF SPI ConnectCore for i.MX51 Hardware Reference Manual 9 10 11 11 11 13 13 13 14 27 41 41 41 42 43 44 44 44 45 45 46 46 51 51 51 51 52 53 53 54 54 55 55 56 57 58 59 59 59 60 4 Watchdog timer UART USB Host and USB OTG WLAN 60 60 61 61 About the development board About the development board The development board Switches and push-buttons Power switch, S2 Reset button, S4 Power button, S11 User buttons, S3 and S5 Ident button, S10 Legend for multi-position switches UART 1 switch, S6 UART 2 switch, S7 Boot configuration switches, S8 and S9 Jumpers Battery enable, J5 Module power source, P29 LED 1, J16 LED 2, J9 Button 1, J28 Button 2, J29 UART3 / XBee selection, J30 and J31 WLAN disable, J17 Touch selection, J20 Coincell enable, J3 JTAG mod., J4 LEDs WLAN, LE12 Power LEDs, LE3, LE4, LE6 and LE7 User LEDs, LE49 and LE51 Serial status LEDs UART 1 status LEDs UART 2 status LEDs XBee Associate, LE50 Audio interface Line-out connector pinout, J18 Line-in connector pinout, J12 Microphone connector pinout, J15 Coin cell battery Camera interfaces X15 pinout X17 pinout Digital IO interface Digital I/O connector, X45 Ethernet 1 interface Ethernet 1, RJ-45 connector X7 Ethernet 2 interface Ethernet 2, connector J17 HDMI interface HDMI connector, J19 ConnectCore for i.MX51 Hardware Reference Manual 65 66 67 67 67 67 68 68 68 68 69 69 71 71 71 71 72 72 72 72 72 72 72 72 73 73 73 74 74 74 74 74 75 76 76 76 77 78 79 79 80 80 81 82 83 83 85 85 5 I2C interface I2C header, P22 JTAG interface Standard JTAG ARM connector, X13 LCD interfaces LCD 1 connector, P1 P1 pinout LCD 2 connector, P2 P2 pinout MicroSD™ card interface MicroSD connector, X14 Module connectors and signal rails Module connectors Signal rails, J25 and J26 J25 pinout J26 pinout Peripheral application header Peripheral application header, P21 Power-Over-Ethernet (PoE) - IEEE802.3af The PoE module PoE connector (power in), P17 PoE connector (power out), P18 Main power connector SD-card interface SD/MMC connector, X18 SPI interface SPI header, P24 UART interface Serial port 2, RS232, X27 Serial port 1, MEI interface, X30 Serial port 3, TTL interface, X19 USB host interface USB host connectors, J8 and J10 USB OTG interface USB OTG connector, J11 User interface Analog video interface Analog video connector, X32 WLAN interface Antenna connectors (WLAN) Digi XBee interface Digi XBee module connectors, X28 and X29 87 87 89 89 90 91 91 92 93 95 95 97 97 97 98 100 104 104 106 107 107 107 108 109 109 111 111 113 113 114 114 116 116 117 117 118 119 119 121 121 123 123 Module specifications Mechanical specifications Fasteners and appropriate torque Environmental specifications Network interface Antenna specifications: 802.11 a/b/g antenna Antenna specification: 802.11b/g antenna Ethernet 1 Ethernet 2 WLAN Electrical characteristics ConnectCore for i.MX51 Hardware Reference Manual 126 126 126 126 126 127 128 129 129 131 6 Charger vs. battery Supply voltages Supply current On-module power supplies I/O DC parameters 131 132 132 133 134 Module dimensions Top view Bottom view Side view Connectors 139 140 141 141 Regulatory information Federal Communication (FCC) regulatory information (USA only) RF exposure Modifications (FCC 15.21) Industry Canada Indoor/outdoor Japan certification Declaration of Conformity (DoC) CE mark (Europe) International EMC standards 142 142 143 143 143 143 144 144 145 Maximum power and frequency specifications ConnectCore for i.MX51 Hardware Reference Manual 7 About the module The network-enabled ConnectCore for i.MX51 is a highly integrated System-on-Module (SOM) solution based on the new Freescale ® i.MX51X application processor with a high-performance ARM® Cortex-A8® core, powerful multimedia options, and a complete set of peripherals. The module combines the fast integration, reliability and design flexibility of an off-the-shelf SOM with complete out-of-the-box software development support for platforms such as Microsoft ® Windows ® Embedded CE 6.0, Windows Embedded Compact 7Digi® Embedded Linux® and Timesys ® LinuxLink ®. With industry-leading performance and key features like a dual-display interface and a hardware encryption engine, the module is the ideal choice for a broad range of target markets including medical, digital signage, security/access control, retail, industrial/building automation, transportation and more. Complete and cost-efficient Digi JumpStart Kits™ for Microsoft Windows Embedded CE 6.0 and Linux allow immediate and professional embedded product development with dramatically reduced design risk and time-to-market. Features and functionality Block diagram Module pinout Power Memory Chip selects Multiplexed GPIO ConnectCore for i.MX51 Hardware Reference Manual 9 11 13 41 44 45 46 8 Features and functionality The ConnectCore for i.MX51 module is based on the i.MX51 processor from Freescale. This processor offers a high number of interfaces. Most of these interfaces are multiplexed and are not available simultaneously. The module has the following features: n High-end, low-power 32-bit System-on-Module n 600/800 MHZ ARM Cortex-A8 core l 32 kB L1 instruction and 32 kB L1 data cache l 256 kB L2 cache l NEON co-processor l Vector Floating Point (VFP) unit n SLC and MLC NAND flash support on module n Up to 512 MB 32-bit/200 MHZ DDR2-400 memory n Debug interfaces l Joint Test Action Group (JTAG) l Embedded Trace Macrocell™ (ETM) / Embedded Trace Buffer (ETB) n Real Time Clock (RTC) n Security co-processor l l Encryption: Advanced Encryption Standard (AES), Data Encryption Standard (DES), 3DES and RC4 Hashing algorithms: Message Digest (MD)5, Secure Hash Algorithm (SHA)-1, SHA-224 and SHA-256 n Timer n Watchdog n Up to three universal asynchronous receiver/transmitter (UART) ports, up to 4 Mb/s each n Up to three Serial Peripheral Interface (SPI), two of them up to 54 Mb/s each n Two Inter-Integrated Circuit (I2C) (up to 400 kb/s) n Three memory card interfaces (two for the wireless version of the module) l SD/Secure Digital Input Output (SDIO) - 1 and 4-bits (up to 200 Mb/s) l MultiMediaCard (MMC) - 1, 4 and 8-bits (up to 416 Mb/s) n USB n Up to 3x USB 2.0 High-Speed USB Host ports n One USB 2.0 On-The-Go USB port with integrated Physical Layer (PHY) on the module n 1-wire n Keypad 6x4 ConnectCore for i.MX51 Hardware Reference Manual 9 About the module Features and functionality n Two independent pulse-width modulation (PWM) interfaces n 8, 16-bit External Memory interface n General-purpose input/output (GPIO) with interrupt capabilities n Up to 3x 10-bit analog-to-digital converter (ADC) channels n Multimedia l 2x Camera ports l 2x Display ports l 4-wire touch screen n Sony/Philips Digital Interface Forma (SPDIF) output n Three I2S / Audio Codec '97 (AC’97) / Synchronous Serial Interfaces (SSI), up to 1.4Mb/s each n On-module three axis accelerometer (optional) n On-module 10/100 Ethernet controller (optional) n Second on-module 10/100Mb Ethernet interface (optional) n 2.4 GHz and 5 GHz Institute of Electrical and Electronics Engineers (IEEE) 802.11a/b/g/n wireless local area network (LAN) interface (optional) n Complete Microsoft Windows Embedded CE 6.0 and Linux platform support with full source code Module variant The ConnectCore for i.MX51 module is available with various population options such as network interfaces (Ethernet, wireless local area network [WLAN]), memory (flash, random-access memory [RAM]), processor (speed grade/operating temperature) and others. ConnectCore for i.MX51 Hardware Reference Manual 10 About the module Block diagram Block diagram The next figures show the block diagram of the Freescale i.MX515 central processing unit (CPU) and the block diagram of the ConnectCore for i.MX51 module. CPU Freescale i.MX515 Module ConnectCore I.MX51 ConnectCore for i.MX51 Hardware Reference Manual 11 About the module ConnectCore for i.MX51 Hardware Reference Manual Block diagram 12 About the module Module pinout Module pinout The module has two 180-pin connectors, J1 and J2. The following tables describe each pin, its properties, and its use on the module and development board. The DC parameters for each I/O type are defined in the I/O DC parameters. The “Use on module” column shows the connection of the signals on the module. The format of this column is “component: pad_name,” where “component” is the chip where the signals are connected, and “pad_name” is the name of the pad where the signals are connected as they are defined in the component’s datasheet. Pinout legend I Input O Output IO Input or output P Power # Low level active signal Pinout definitions GPIO - General Purpose IO UHVIO - Ultra High Voltage IO HSGPIO - High Speed GPIO LVIO - Low Voltage IO (meaning 1.8V) The I/O Type descriptions can be read as follows: n 18 - 1.8V logic level switching (for example, GPIO18) n 27 - 2.775V logic level switching (for example, GPIO27) n 31 - 3.15V logic level switching (for example, UHVIO31) n 33 - 3.3V logic level switching (for example, UHVIO33) The microprocessor used on this module, like all CMOS devices, can be driven into a latchup condition if any I/O pin is driven outside of its associated power rail. Care must be taken to: n Never drive an I/O pin beyond its positive rail or below ground. n Never drive an I/O pin from an external power source during the power-on or reset sequences. n Never hot-swap the module or interrupt its ground connection to external circuitry. Latch-up is a condition that can cause excessive current draw and result in excessive heating of the microprocessor or its power supplies. This excessive heating can permanently damage the microprocessor and/or its supporting components. ConnectCore for i.MX51 Hardware Reference Manual 13 About the module Module pinout J1 pinout Pin I/O Type Signal name Use on module Use on development board J1:1 GPIO27 CSI1_D8/GPIO3_12 i.MX51: CSI1_D8 Not used J1:2 GPIO27 CSI1_D9/GPIO3_13 i.MX51: CSI1_D9 Camera 1 reset J1:3 HSGPIO2 7 CSI1_D10 i.MX51: CSI1_D10 Camera 1 data J1:4 HSGPIO2 7 CSI1_D11 i.MX51: CSI1_D11 Camera 1 data J1:5 HSGPIO2 7 CSI1_D12 i.MX51: CSI1_D12 Camera 1 data J1:6 HSGPIO2 7 CSI1_D13 i.MX51: CSI1_D13 Camera 1 data J1:7 HSGPIO2 7 CSI1_D14 i.MX51: CSI1_D14 Camera 1 data J1:8 HSGPIO2 7 CSI1_D15 i.MX51: CSI1_D15 Camera 1 data J1:9 HSGPIO2 7 CSI1_D16 i.MX51: CSI1_D16 Camera 1 data J1:10 HSGPIO2 7 CSI1_D17 i.MX51: CSI1_D17 Camera 1 data J1:11 HSGPIO2 7 CSI1_D18 i.MX51: CSI1_D18 Camera 1 data J1:12 HSGPIO2 7 CSI1_D19 i.MX51: CSI1_D19 Camera 1 data J1:13 GPIO27 CSI1_VSYNC/GPIO3_14 i.MX51: CSI1_ VSYNC Camera 1 vertical synchronizatio n J1:14 GPIO27 CSI1_HSYNC/GPIO3_15 i.MX51: CSI1_ HSYNC Camera 1 horizontal synchronizatio n J1:15 GPIO27 CSI1_PIXCLK i.MX51: CSI1_ PIXCLK Camera 1 pixel clock J1:16 GPIO27 CSI1_MCLK i.MX51: CSI1_MCLK Camera 1 and 2 Master clock ConnectCore for i.MX51 Hardware Reference Manual Comments 14 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:17 - GND - - J1:18 - GND - - J1:19 WLAN WLAN_TDO WLAN: TDO Not used J1:20 WLAN WLAN_TCK WLAN: TCK Not used J1:21 WLAN WLAN_TDI WLAN: TDI Not used J1:22 WLAN WLAN_TMS WLAN: TMS Not used J1:23 WLAN WLAN_LED WLAN: LED_ON WLAN lightemitting diode (LED) J1:24 WLAN RS_BT_PRIORITY WLAN: BT_ PRIORITY Not used J1:25 WLAN RS_WLAN_ACTIVE WLAN: WLAN_ ACTIVE Not used J1:26 WLAN RS_BT_ACTIVE WLAN: BT_ACTIVE Not used J1:27 LVIO BOOT_MODE0 i.MX51: BOOT_ MODE0 Boot Mode selection Boot configuratio n not available in EA Kit J1:28 GPIO33 WLAN_DISABLE# WLAN Power Supply Switch WLAN Disable Jumper (J17) This signal switch ON/OFF the supply of WLAN J1:29 LVIO BOOT_MODE1 i.MX51: BOOT_ MODE1 Boot Mode selection Boot configuratio n not available in EA Kit J1:30 - VLIO MC13892: BATT Battery supply J1:31 - VLIO MC13892: BATT Battery supply J1:32 - VCHRG MC13892: CHRGRAW Charger supply J1:33 - +2.775V - - ConnectCore for i.MX51 Hardware Reference Manual Comments 15 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:34 - VCHRG MC13892: CHRGRAW Charger supply J1:35 - +2.775V - - J1:36 - +2.775V - - J1:37 PMIC_ GPO MC13892_GPO1 MC13892: GPO1 Reserved J1:38 - +2.775V - - J1:39 PMIC_ PWRON PMIC_PWRON1 MC13892: PWRON1 Connected to Power Button (S11) Suspend / Wake-up button J1:40 PMIC_ STDBY PMIC_STDBY_REQ i.MX51: PMIC_ STBY_REQ MC13892: STANDBY Reserved Output from i.MX51 to put MC13892 in low power mode J1:41 PMIC_ INT PMIC_INT_REQ i.MX51: PMIC_INT_ Reserved REQ This highpriority interrupt input on i.MX51 is not used. The output interrupt from PMIC is connected to standard interrupt GPIO_5 on i.MX51. J1:42 PMIC_ PWRGTDRV1 PWGTDRV MC13892: PWRGTDRV1 Not used J1:43 PMIC_ LED MC13892: CHRGLED Battery Charging LED J1:44 PMIC_ PWRGTDRV2 PWGTDRV MC13892: PWRGTDRV2 +3.3V_REG: ENABLE Not used CHRGLED ConnectCore for i.MX51 Hardware Reference Manual Comments Used on module to enable / disable the +3.3V supply 16 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board Comments J1:45 PMIC_SE CHRGSE1# MC13892: CHRGSE1# Charger detection circuit This circuit is needed to boot from charger J1:46 - VCC_COINCELL MC13892: LICELL Coincell voltage J1:47 - VLIO MC13892: BATT Battery supply J1:48 - VCHRG MC13892: CHRGRAW Charger supply J1:49 - VLIO MC13892: BATT Battery supply J1:50 - VCHRG MC13892:CHRGRA W Charger supply J1:51 - VLIO MC13892: BATT Battery supply J1:52 - VCHRG MC13892:CHRGRA W Charger supply J1:53 ETH ETH1_TX+ ETH_PHY: TXP Ethernet 1 Tx+ J1:54 ETH ETH1_RX+ ETH_PHY: RXP Ethernet 1 Rx+ J1:55 ETH ETH1_TX- ETH_PHY: TXN Ethernet 1 Tx- J1:56 ETH ETH1_RX- ETH_PHY: RXN Ethernet 1 Rx- J1:57 - GND - - J1:58 GPIO33 ETH1_LINK ETH_PHY: LED1 Ethernet 1 Link LED J1:59 GPIO27 DISPB2_SER_DIN/GPIO3_ 5 i.MX51: DISPB_2_ SER_DIN GPIO1 signal to LCD connectors J1:60 GPIO33 ETH1_ACTIVITY ETH_PHY: LED2 Ethernet 1 Activity LED J1:61 GPIO27 DISPB2_SER_RS/GPIO3_8 i.MX51: DISPB2_ SER_RS USB Host Reset ConnectCore for i.MX51 Hardware Reference Manual In Early Availability Kit USB host and Digital IO interface cannot be used at the same time. 17 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:62 GPIO27 DISPB2_SER_DIO/GPIO3_ 6 i.MX51: DISPB2_ SER_DIO User button 1 & Digital IO 7 J1:63 GPIO27 DISP2_DATA0/MII_ RXD3/USBH3_CLK i.MX51: DISP2_ DATA0 ETH_PHY: RXD3 LCD2 Data J1:64 GPIO27 DISPB2_SER_CLK_ GPIO3_7 i.MX51: DISPB2_ SER_CLK Camera 2 Reset J1:65 HSGPIO2 7 DISP2_DATA2 i.MX51: DISP2_ DATA2 LCD2 Data J1:66 GPIO27 DISP2_DATA1/MII_RX_ ER/USBH3_DIR i.MX51: DISP2_ DATA1 ETH_PHY: RXD4 LCD2 Data J1:67 HSGPIO2 7 DISP2_DATA4 i.MX51: DISP2_ DATA4 LCD2 Data J1:68 HSGPIO2 7 DISP2_DATA3 i.MX51: DISP2_ DATA3 LCD2 Data J1:69 GPIO27 DISP2_DATA6/MII_ TXD1/USBH3_STP i.MX51: DISP2_ DATA6 ETH_PHY: TXD1 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:70 HSGPIO2 7 DISP2_DATA5 i.MX51: DISP2_ DATA5 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:71 GPIO27 DISP2_DATA8/MII_ TXD3/USBH3_DATA0 i.MX51: DISP2_ DATA8 ETH_PHY: TDX3 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. ConnectCore for i.MX51 Hardware Reference Manual Comments Ethernet 1 and LCD2 cannot be used at the same time. Ethernet 1 and LCD2 cannot be used at the same time. 18 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board Comments J1:72 GPIO27 DISP2_DATA7/MII_ TXD2/UBH3_NXT i.MX51: DISP2_ DATA7 ETH_PHY: TDX2 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:73 GPIO27 DISP2_DATA10/MII_ COL/USBH3_DATA2 i.MX51: DISP2_ DATA10 ETH_PHY: COL LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:74 GPIO27 DISP2_DATA9/MII_ TXEN/USBH3_DATA1 i.MX51: DISP2_ DATA9 ETH_PHY: TXEN LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:75 GPIO27 DISP2_DAT12/MII_RX_ DV/USBH3_DATA4 i.MX51: DISP2_ DATA12 ETH_PHY: RXDV LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:76 GPIO27 DISP2_DAT11/MII_RX_ CLK/USBH3_DATA3 i.MX51: DISP2_ DATA11 ETH_PHY: RXCLK LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:77 GPIO27 DISP2_DATA14/MII_ RXD0/USBH3_DATA6 i.MX51: DISP2_ DATA14 ETH_PHY: RXD0 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:78 GPIO27 DISP2_DAT13/MII_TX_ CLK/USBH3_DATA5 i.MX51: DISP2_ DATA13 ETH_PHY: TXCLK LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:79 GPIO27 DI2_PIN2/MII_MDC i.MX51: DI2_PIN2 ETH_PHY: MDC LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. ConnectCore for i.MX51 Hardware Reference Manual 19 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board Comments J1:80 GPIO27 DISP2_DAT15/MII_ TXD0/USBH3_DATA7 i.MX51: DISP2_ DATA15 ETH_PHY: TXD0 LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:81 GPIO27 DI2_PIN4/MII_CRS i.MX51: DI2_PIN4 ETH_PHY: CRS LCD2 Data Ethernet 1 and LCD2 cannot be used at the same time. J1:82 - GND - - J1:83 RGB IOR i.MX51: IOR Not used J1:84 GPIO27 DI2_DISP_CLK/MII_RXD1 i.MX51: DI2_DISP_ CLK ETH_PHY: RXD1 LCD2 Data J1:85 RGB IOR_BACK i.MX51: IOR_BACK Not used J1:86 GPIO27 DI2_PIN3/MII_MDIO i.MX51: DI2_PIN3 ETH_PHY: MDIO LCD2 Data J1:87 RGB IOB i.MX51: IOB Not useD J1:88 IOG IOG i.MX51: IOG Not used J1:89 RGB IOB_BACK i.MX51: IOB_BACK Not used J1:90 RGB IOG_BACK i.MX51: IOG_BACK Not used J1:91 GPIO18 JTAG_TCK i.MX51: JTAG_TCK JTAG Connector J1:92 GPIO18 JTAG_TRST# i.MX51: JTAG_ TRST# JTAG Connector J1:93 GPIO18 JTAG_TMS i.MX51: JTAG_TMS JTAG Connector J1:94 GPIO18 JTAG_MOD# i.MX51: JTAG_ MOD# JTAG Mod Selection ConnectCore for i.MX51 Hardware Reference Manual Ethernet 1 and LCD2 cannot be used at the same time. Ethernet 1 and LCD2 cannot be used at the same time. 20 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:95 GPIO18 JTAG_TDI i.MX51: JTAG_TDI JTAG Connector J1:96 GPIO18 JTAG_DE# i.MX51: JTAG_DE_B JTAG Connector J1:97 GPIO18 JTAG_TDO i.MX51: JTAG_TDO JTAG Connector J1:98 LVIO RESET_IN# i.MX51: RESET_IN_ B MC13892: RESETB Not used Warm reset input to i.MX51. J1:99 LVIO POR# i.MX51: POR_B MC13892: RESETBMCU LCD 1 & 2 Reset, JTAG Connector and Reset Button (S4) Cold reset input to i.MX51. Used to reset the module and peripherals on the Dev. Kit. J1:10 0 - +1.8V - J1:10 1 - GND - J1:10 2 - GND - J1:10 3 ETH ETH2_TX+/ETH2_DA+ ETH_CTRL: TPO+ Ethernet 2 Tx+ J1:10 4 ETH ETH2_RX+/ETH2_DB+ ETH_CTRL: TPI+ Ethernet 2 Rx+ J1:10 5 ETH ETH2_TX-/ETH2_DA- ETH_CTRL: TPO- Ethernet 2 Tx- J1:10 6 ETH ETH2_RX-/ETH2_DB- ETH_CTRL: TPI- Ethernet 2 Rx- J1:10 7 - - - - - J1:10 8 - - - - - J1:10 9 - - - - - ConnectCore for i.MX51 Hardware Reference Manual Comments 21 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board Comments J1:11 0 - - - - - J1:11 1 GPIO33 ETH2_ACTIVITY# ETH_CTRL: GPIO1/LED2# Ethernet 2 Activity LED J1:11 2 GPIO33 ETH2_LINK# ETH_CTRL: GPIO0/LED1# Ethernet 2 Link LED J1:11 3 GPIO18 EIM_CS0/GPIO2_25 i.MX51: EIM_CS0 Peripheral Application Chip Select J1:11 4 GPIO18 EIM_CS1/GPIO2_26 i.MX51: EIM_CS1 Not used J1:11 5 GPIO18 EIM_CS2/GPIO2_27/FEC_ RDATA2/SISG5/CSI1_ D4/AUD5_TXD i.MX51: EIM_CS2 Not used J1:11 6 GPIO18 EIM_CS3/GPIO2_28/FEC_ RDATA3/SSI_EXT2_ CLK/CSI1_D5/AUD5_RXD i.MX51: EIM_CS3 Not used J1:11 7 GPIO18 EIM_CS4/GPIO2_29/FEC_ RX_ER/SSI_EXT1_ CLK/CSI1_D6/AUD5_TXC i.MX51: EIM_CS4 Not used J1:11 8 GPIO18 EIM_CS5/GPIO2_30/FEC_ CRS/DI1_EXT_CLK/CSI1_ D7/AUD5_TXFS i.MX51: EIM_CS4 EHT_CTRL: CS# Reserved J1:11 9 GPIO18 EIM_DTACK/GPIO2_31 i.MX51: EIM_DTACK Not used J1:12 0 GPIO18 EIM_LBA/GPIO3_1 i.MX51: EIM_LBA Not used J1:12 1 GPIO18 EIM_DA0/TRACE16 i.MX51: EIM_DA0 ETH_CTRL: A1 Peripheral Application Data / Address J1:12 2 GPIO18 EIM_DA1/TRACE17 i.MX51: EIM_DA1 ETH_CTRL: A2 Peripheral Application Data / Address J1:12 3 GPIO18 EIM_DA2/TRACE18 i.MX51: EIM_DA2 ETH_CTRL: A3 Peripheral Application Data / Address ConnectCore for i.MX51 Hardware Reference Manual 22 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:12 4 GPIO18 EIM_DA3/TRACE19 i.MX51: EIM_DA3 ETH_CTRL: A4 Peripheral Application Data / Address J1:12 5 - GND - - J1:12 6 GPIO18 EIM_DA5/TRACE21 i.MX51: EIM_DA5 ETH_CTRL: A6 Peripheral Application Data / Address J1:12 7 GPIO18 EIM_DA4/TRACE20 i.MX51: EIM_DA4 ETH_CTRL: A5 Peripheral Application Data / Address J1:12 8 GPIO18 EIM_DA7/TRACE23 i.MX51: EIM_DA7 ETH_CTRL: FIFO_ SEL Peripheral Application Data / Address J1:12 9 GPIO18 EIM_DA6/TRACE22 i.MX51: EIM_DA6 ETH_CTRL: A7 Peripheral Application Data / Address J1:13 0 - GND - - J1:13 1 GPIO18 EIM_DA8/TRACE24 i.MX51: EIM_DA8 Peripheral Application Data / Address J1:13 2 GPIO18 EIM_DA9/TRACE25 i.MX51: EIM_DA9 Peripheral Application Data / Address J1:13 3 GPIO18 EIM_DA10/TRACE26 i.MX51: EIM_DA10 Not used J1:13 4 GPIO18 EIM_DA11/TRACE27 i.MX51: EIM_DA11 Not used J1:13 5 - GND - - J1:13 6 GPIO18 EIM_DA13/TRACE29 i.MX51: EIM_DA13 Not used J1:13 7 GPIO18 EIM_DA12/TRACE28 i.MX51: EIM_DA12 Not used J1:13 8 GPIO18 EIM_DA15/TRACE31 i.MX51: EIM_DA15 Not used ConnectCore for i.MX51 Hardware Reference Manual Comments 23 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:13 9 GPIO18 EIM_DA14/TRACE30 i.MX51: EIM_DA14 Not used J1:14 0 - GND - - J1:14 1 GPIO18 EIM_D16/GPIO2_ 0/USBH2_DATA0/UART2_ CTS#/I2C1_SDA/AUD4_ RXFS/TRACE0/AUD5_TXD i.MX51: EIM_D16 ETH_CTRL: D0 Peripheral Application Data J1:14 2 GPIO18 EIM_D17/GPIO2_ 1/USBH2_DATA1/UART2_ RXD/UART3_ CTS#/SISG4/TRACE1/AUD 5_RXD i.MX51: EIM_D17 ETH_CTRL: D1 Peripheral Application Data J1:14 3 GPIO18 EIM_D18/GPIO2_ 2/USBH2_DATA2/UART2_ TXD/UART3_ RTS#/SISG5/TRACE2/AUD 5_TXC i.MX51: EIM_D18 ETH_CTRL: D2 Peripheral Application Data J1:14 4 GPIO18 EIM_D19/GPIO2_ 3/USBH2_DATA3/UART2_ RTS#/I2C1_SCL/AUD4_ RXC/TRACE3/AUD5_TXFS i.MX51: EIM_D19 ETH_CTRL: D3 Peripheral Application Data J1:14 5 - +3.15V - - J1:14 6 GPIO18 EIM_D21/GPIO2_ 5/USBH2_DATA5/AUD4_ RXD/TRACE5 i.MX51: EIM_D21 ETH_CTRL: D5 Peripheral Application Data J1:14 7 GPIO18 EIM_D20/GPIO2_ 4/USBH2_DATA4/AUD4_ TXD/TRACE4 i.MX51: EIM_D20 ETH_CTRL: D4 Peripheral Application Data J1:14 8 GPIO18 EIM_D23/GPIO2_ i.MX51: EIM_D23 ETH_CTRL: D7 7/USBH2_DATA7/SPDIF_ OUT1/AUD4_TXFS/TRACE7 Peripheral Application Data J1:14 9 GPIO18 EIM_D22/GPIO2_ 6/USBH2_DATA6/AUD4_ TXC/TRACE6 i.MX51: EIM_D22 ETH_CTRL: D8 Peripheral Application Data J1:15 0 - GND - - ConnectCore for i.MX51 Hardware Reference Manual Comments 24 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:15 1 GPIO18 EIM_D24/GPIO2_ 8/UART3_CTS#/I2C2_ SDA/AUD6_RXFS/TRACE8 i.MX51: EIM_D24 ETH_CTRL: D8 Peripheral Application Data J1:15 2 GPIO18 EIM_D25/KEY_ COL6/UART3_ RXD/UART2_ CTS#/CMPOUT1/TRACE9 i.MX51: EIM_D25 ETH_CTRL: D9 Peripheral Application Data J1:15 3 GPIO18 EIM_D26/KEY_ i.MX51: EIM_D26 COL7/UART3_TXD/UART2_ ETH_CTRL: D10 RTS#/CMPOUT2/TRACE10 Peripheral Application Data J1:15 4 GPIO18 EIM_D27/GPIO2_ 9/UART3_RTS#/I2C2_ SCL/AUD6_RXC/TRACE11 i.MX51: EIM_D27 ETH_CTRL: D11 Peripheral Application Data J1:15 5 - GND - - J1:15 6 GPIO18 EIM_D29/KEY_ ROW5/SISG1/AUD6_ RXD/TRACE13 i.MX51: EIM_D29 ETH_CTRL: D13 Peripheral Application Data J1:15 7 GPIO18 EIM_D28/KEY_ ROW4/SISG0/AUD6_ TXD/TRACE12 i.MX51: EIM_D28 ETH_CTRL: D12 Peripheral Application Data J1:15 8 GPIO18 EIM_D31/KEY_ ROW7/SISG03/AUD6_ TXFS/TRACE15 i.MX51: EIM_D31 ETH_CTRL: D15 Peripheral Application Data J1:15 9 GPIO18 EIM_D30/KEY_ ROW6/SISG2/AUD6_ TXC/TRACE14 i.MX51: EIM_D30 ETH_CTRL: D14 Peripheral Application Data J1:16 0 GPIO18 EIM_A17/GPIO2_11 i.MX51: EIM_A17 Not used J1:16 1 GPIO18 EIM_A16/GPIO2_10 i.MX51: EIM_A16 Not used J1:16 2 GPIO18 EIM_A19/GPIO2_13 i.MX51: EIM_A19 Not used J1:16 3 GPIO18 EIM_A18/GPIO2_12 i.MX51: EIM_A18 Not used ConnectCore for i.MX51 Hardware Reference Manual Comments 25 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:16 4 GPIO18 EIM_A21/GPIO2_15 i.MX51: EIM_A21 Boot Configuration Switch J1:16 5 GPIO18 EIM_A20/GPIO2_14 i.MX51: EIM_A20 Boot Configuration Switch J1:16 6 GPIO18 EIM_A23/GPIO2_17 i.MX51: EIM_A23 Not used J1:16 7 GPIO18 EIM_A22/GPIO2_16 i.MX51: EIM_A22 Not used J1:16 8 GPIO18 EIM_A25/GPIO2_ 19/USBH2_DIR/DI1_PIN4 i.MX51: EIM_A25 Not used J1:16 9 GPIO18 EIM_A24/GPIO2_ 18/USBH2_CLK i.MX51: EIM_A24 Not used J1:17 0 GPIO18 EIM_A27/GPIO2_ 21/USBH2_ NXT/SISG1/CSI2_DATA_ EN/DI1_PIN1 i.MX51: EIM_A27 XBEE_SLEEP_ RQ J1:17 1 GPIO18 EIM_A26/GPIO2_ 20/USBH2_ STP/SISG0/CSI1_DATA_ EN/DI2_EXT_CLK i.MX51: EIM_A26 Not used J1:17 2 GPIO18 EIM_OE#/GPIO2_24 i.MX51: EIM_OE ETH_CTRL: RD# Peripheral Application Output Enable J1:17 3 GPIO18 EIM_EB0 i.MX51: EIM_EB0 Not used J1:17 4 GPIO18 EIM_RW# i.MX51: EIM_RW ETH_CTRL: WR# Peripheral Application Read / Write J1:17 5 GPIO18 EIM_EB1 i.MX51: EIM_EB1 Not used J1:17 6 GPIO18 EIM_CRE/GPIO3_2 i.MX51: EIM_CRE Peripheral Application Interrupt input ConnectCore for i.MX51 Hardware Reference Manual Comments 26 About the module Module pinout Pin I/O Type Signal name Use on module Use on development board J1:17 7 GPIO18 EIM_EB2/GPIO2_ 22/TRCTL/FEC_ MDIO/SISG2/CSI1_ D2/AUD5_RXFS/CMPOUT1 i.MX51: EIM_EB2 Peripheral Application Byte Enable 2 J1:17 8 GPIO18 EIM_WAIT i.MX51: EIM_WAIT Not used J1:17 9 GPIO18 EIM_EB3/GPIO2_ 23/TRCLK/FEC_ RDATA1/SISG3/CSI1_ D3/AUD5_RXC/CMPOUT2 i.MX51: EIM_EB3 Peripheral Application Byte Enable 3 J1:18 0 GPIO18 EIM_BCLK i.MX51: EIM_BCLK Peripheral Application Clock Burst Comments By default not connected on Developmen t Board. J2 pinout CAUTION! Do not connect signals marked NANDF_* to GND during boot time if you want to boot from NAND flash. ConnectCore for i.MX51 Hardware Reference Manual 27 About the module Module pinout Use on module Use on Comments development board HSGPIO27 DISP1_DAT0 i.MX51: DISP1_ DAT0 HDMI, VGA and LCD1 Data HSGPIO27 DISP1_DAT1 i.MX51: DISP1_ DAT1 HDMI, VGA and LCD1 Data Pin Type J2:1 J2:2 Signal name J2:3 HSGPIO27 DISP1_DAT2 i.MX51: DISP1_ DAT2 HDMI, VGA and LCD1 Data J2:4 HSGPIO27 DISP1_DAT3 i.MX51: DISP1_ DAT3 HDMI, VGA and LCD1 Data J2:5 HSGPIO27 DISP1_DAT4 i.MX51: DISP1_ DAT4 HDMI, VGA and LCD1 Data J2:6 HSGPIO27 DISP1_DAT5 i.MX51: DISP1_ DAT5 HDMI, VGA and LCD1 Data J2:7 GPIO27 DISP1_DAT6 i.MX51: DISP1_ DAT6 HDMI, VGA and LCD1 Data, Boot Configuration J2:8 GPIO27 DISP1_DAT7 i.MX51: DISP1_ DAT7 HDMI, VGA and LCD1 Data, Boot Configuration J2:9 GPIO27 DISP1_DAT8 i.MX51: DISP1_ DAT8 HDMI, VGA and LCD1 Data, Boot Configuration J2:10 GPIO27 DISP1_DAT9 i.MX51: DISP1_ DAT9 HDMI, VGA and LCD1 Data, Boot Configuration J2:11 GPIO27 DISP1_DAT10 i.MX51: DISP1_ DAT10 HDMI, VGA and LCD1 Data, Boot Configuration ConnectCore for i.MX51 Hardware Reference Manual On the Development Kit, DISP1 and DISP2 are configured at 18bit, and connected to 24-bit LCDs. On the Development Kit, some DISP1 signals are used to configure the boot process. On the Early Availability Kit, DISP1 and DISP2 are configured at 24-bit, and connected to 24-bit LCDs. 28 About the module Module pinout Pin Type Signal name Use on module Use on Comments development board J2:12 GPIO27 DISP1_DAT11 i.MX51: DISP1_ DAT11 HDMI, VGA and LCD1 Data, Boot Configuration J2:13 GPIO27 DISP1_DAT12 i.MX51: DISP1_ DAT12 HDMI, VGA and LCD1 Data, Boot Configuration J2:14 GPIO27 DISP1_DAT13 i.MX51: DISP1_ DAT13 HDMI, VGA and LCD1 Data, Boot Configuration J2:15 GPIO27 DISP1_DAT14 i.MX51: DISP1_ DAT14 J2:16 GPIO27 DISP1_DAT15 i.MX51: DISP1_ DAT15 HDMI, VGA and LCD1 On the Development Data, Boot Kit, some DISP1 Configuration signals are used to configure the boot HDMI, VGA process. and LCD1 Data, Boot Configuration On the Early Availability Kit, HDMI, VGA DISP1 and DISP2 are and LCD1 configured at 24-bit, Data, Boot and connected to Configuration 24-bit LCDs. J2:17 GPIO27 DISP1_DAT16 i.MX51: DISP1_ DAT16 J2:18 GPIO27 DISP1_DAT17 i.MX51: DISP1_ DAT17 HDMI, VGA and LCD1 Data, Boot Configuration J2:19 GPIO27 DISP1_DAT18 i.MX51: DISP1_ DAT18 Not used J2:20 GPIO27 DISP1_DAT19 i.MX51: DISP1_ DAT19 Not used J2:21 GPIO27 DISP1_DAT20 i.MX51: DISP1_ DAT20 Boot Configuration J2:22 GPIO27 DISP1_DAT21 i.MX51: DISP1_ DAT21 Boot Configuration ConnectCore for i.MX51 Hardware Reference Manual On the Development Kit, DISP1 and DISP2 are configured at 18bit, and connected to 24-bit LCDs. 29 About the module Module pinout Pin Type Signal name Use on module Use on Comments development board J2:23 GPIO27 DISP1_DAT22 i.MX51: DISP1_ DAT22 LCD2 Data J2:24 GPIO27 DISP1_DAT23 i.MX51: DISP1_ DAT23 LCD2 Data J2:25 GPIO27 DI1_PIN2 i.MX51: DI1_PIN2 HDMI, VGA and LCD1 HSYNC J2:26 - GND - - J2:27 GPIO27 DI1_PIN11/GPIO3_ i.MX51: DI1_PIN11 0 LCD1 PWREN# J2:28 GPIO27 DI1_DISP_CLK HDMI, VGA and LCD1 Clock J2:29 GPIO27 DI1_PIN13/GPIO3_ i.MX51: DI1_PIN13 2 LCD1 and LCD2 GPIO2 J2:30 GPIO27 DI1_PIN3 i.MX51: DI1_PIN3 HDMI, VGA and LCD1 VSYNC J2:31 GPIO27 DI1_PIN15 i.MX51: DI1_PIN15 HDMI, VGA and LCD1 DRDY J2:32 GPIO27 DI1_PIN12/GPIO3_ i.MX51: DI1_PIN12 1 LCD2 PWREN# J2:33 GPIO27 DI_GP2 i.MX51: DI_GP2 Not used J2:34 GPIO27 DI_GP1 i.MX51: DI_GP1 Not used J2:35 GPIO27 DI_GP4/MII_RXD2 i.MX51: DI_GP4 LAN8710: RXD2 LCD2 DRDY J2:36 GPIO27 DI_GP3/MII_TX_ER i.MX51: DI_GP3 LAN8710: INT#/TXER/TXD4 Not used J2:37 GPIO27 DI1_D1_ CS/GPIO3_4 LCD1 and LCD2 Touch selection input ConnectCore for i.MX51 Hardware Reference Manual i.MX51: DI1_DISP_ CLK i.MX51: DI_D1_CS 30 About the module Module pinout Pin Type Signal name Use on module Use on Comments development board J2:38 GPIO27 DI1_D0_ CS/GPIO3_3 i.MX51: DI_D0_CS LCD1 and LCD2 Touch selection input J2:39 ADIN TOUCH_X1 MC13892: TSX1 LCD1 and LCD2 Touch X1 J2:40 ADIN ADIN5 MC13892: ADIN5 Reserved J2:41 ADIN TOUCH_X2 MC13892: TSX2 LCD1 and LCD2 Touch X2 Analog input from Touch Screen J2:42 ADIN ADIN6 MC13892: ADIN6 Not used Analog input J2:43 ADIN TOUCH_Y1 MC13892: TSY1 LCD1 and LCD2 Touch Y1 Analog input from Touch Screen J2:44 ADIN ADIN7 MC13892: ADIN7 Not used Analog input J2:45 ADIN TOUCH_Y2 MC13892: TSY2 LCD1 and LCD2 Touch Y2 Analog input from Touch Screen J2:46 - ADC_GND - - J2:47 - GND - - J2:48 PMIC_ STDBY ADTRIG MC13892: ADTRIG Not used J2:49 - SWBST MC13892: SWBST MC13892: VINUSB - J2:50 - LEDKP MC13892: LEDKP Reserved J2:51 PMIC_LED LEDR MC13892: LEDR Not used J2:52 - MC13892: LEDAD Reserved J2:53 PMIC_LED LEDG MC13892: LEDG Not used J2:54 - MC13892: LEDMD Reserved J2:55 PMIC_LED LEDB MC13892: LEDB Not used J2:56 - VSWLED - - J2:57 GPIO27 CSI2_D12/GPIO4_9 i.MX51: CSI2_D12 LEDAD LEDMD ConnectCore for i.MX51 Hardware Reference Manual Analog input from Touch Screen Used on the module to power USB PHY Camera 2 Data 31 About the module Module pinout Pin Type Signal name Use on module Use on Comments development board J2:58 GPIO27 CSI2_D13/GPIO4_ 10 i.MX51: CSI2_D13 Camera 2 Data J2:59 HSGPIO27 CSI2_D14 i.MX51: CSI2_D14 Camera 2 Data J2:60 HSGPIO27 CSI2_D15 i.MX51: CSI2_D15 Camera 2 Data J2:61 HSGPIO27 CSI2_D16 i.MX51: CSI2_D16 Camera 2 Data J2:62 HSGPIO27 CSI2_D17 i.MX51: CSI2_D17 Camera 2 Data J2:63 GPIO27 CSI2_D18/GPIO4_ 11 i.MX51: CSI2_D18 Camera 2 Data J2:64 GPIO27 CSI2_D19/GPIO4_ 12 i.MX51: CSI2_D19 Camera 2 Data J2:65 GPIO27 CSI2_ VSYNC/GPIO4_13 i.MX51: CSI2_ VSYNC Camera 2 VSYNC J2:66 GPIO27 CSI2_ HSYNC/GPIO4_14 i.MX51: CSI2_ HSYNC Camera 2 HSYNC J2:67 GPIO27 CSI2_PIXCLK_ GPIO4_15 i.MX51: CSI2_ PIXCLK Camera 2 PIXCLK J2:68 - GND - J2:69 - GND - J2:70 DIG_USB USB_OTG_ID i.MX51: ID USB OTG ID J2:71 AN_USB USB_OTG_DP i.MX51: DP USB OTG DP J2:72 - USB_OTG_VBUS i.MX51: VBUS USB OTG VBUS J2:73 AN_USB USB_OTG_DN i.MX51: DN USB OTG DN J2:74 GPIO27 GPIO1_8/USB_ PWR i.MX51: GPIO_8 Not used J2:75 - GND - - J2:76 GPIO27 GPIO1_ 2/PWM1/I2C2_SCL i.MX51: GPIO1_2 MMA7455LR1:SCL I 2C Bus Clock ConnectCore for i.MX51 Hardware Reference Manual 32 About the module Module pinout Use on Comments development board Pin Type Signal name Use on module J2:77 GPIO27 GPIO1_ 7/MMA7455LR_ INT1 i.MX51: GPIO1_7 Reserved MMA7455LR1:INT1 J2:78 GPIO27 GPIO1_ 3/PWM2/I2C2_SDA i.MX51: GPIO1_3 MMA7455LR1:SD J2:79 GPIO27 GPIO1_ 6/MMA7455LR_ INT2 i.MX51: GPIO1_6 Reserved MMA7455LR1:INT2 J2:80 PMIC_INT CLK32K_PER MC13892: CLK32K Not used J2:81 - GND - - J2:82 - GND - - J2:83 - CKIH1 i.MX51: CKIH1 Not used J2:84 - CKIH2 i.MX51: CKIH2 Not used J2:85 UHVIO33 SD2_DATA0/SD1_ DATA1/CSPI_MISO i.MX51: SD2_ DATA0 WLAN: SDIO_ DATA0 Reserved I 2C Bus Clock J2:86 UHVIO33 SD2_CLK/I2C1_ SDA/SPI_SCLK i.MX51: SD2_CLK WLAN: SDIO_CLK Reserved J2:87 UHVIO33 SD2_DATA1/SD1_ DATA5 i.MX51: SD2_ DATA1 WLAN: SDIO_ DATA1 Reserved J2:88 UHVIO33 SD2_CMD/I2C1_ SCL/SPI_MOSI i.MX51: SD2_CMD WLAN: SDIO_CMD Reserved J2:89 UHVI0O3 SD2_DATA2/SDI_ DATA6 i.MX51: SD2_ DATA2 WLAN: SDIO_ DATA2 Reserved J2:90 GPIO27 KEY_COL0 i.MX51: KEY_COL0 XBee Reset# J2:91 UHVIO33 SD2_DATA3/SD1_ DATA7/SPI_SS2 i.MX51: SD2_ DATA3 WLAN: SDIO_ DATA3 Reserved J2:92 GPIO27 KEY_COL1 i.MX51: KEY_COL1 Not used J2:93 GPIO27 KEY_ROW0 i.MX51: ROW0 Not used ConnectCore for i.MX51 Hardware Reference Manual Accelerometer interrupt Accelerometer Interrupt SD bus 2 connected to WLAN. In modules without WLAN this SD bus can be used in the development boards. 33 About the module Module pinout Pin Type Signal name Use on module Use on Comments development board J2:94 GPIO27 KEY_COL2 i.MX51: KEY_COL2 Not used J2:95 GPIO27 KEY_ROW1 i.MX51: ROW1 Not used J2:96 GPIO27 KEY_COL3 i.MX51: KEY_COL3 Not used J2:97 GPIO27 KEY_ROW2 i.MX51: ROW2 Not used J2:98 GPIO27 KEY_COL5/UART3_ CTS#/I2C2_SDA i.MX51: KEY_COL5 XBee RTS# J2:99 GPIO27 KEY_ROW3 i.MX51: KEY_ROW3 Not used J2:100 GPIO27 GPIO1_0/SD1_ CD#/SPI_SS2 i.MX51: GPIO1_0 HDMI Interrupt J2:101 GPIO27 KEY_COL4/UART3_ RTS#/I2C2_SCL i.MX51: KEY_COL4 XBee_ CTS#/UART3_ RTS selection J2:102 GPIO27 GPIO1_1/SD1_ WP#/SPI_MISO i.MX51: GPIO1_1 User Button 2 J2:103 GPIO27 OWIRE_ LINE/GPIO1_24 i.MX51: OWIRE_ LINE One-Wire, HDMI SPDIF J2:104 UHVIO31 SD1_DATA0/AUD5_ TXD/SPI_MOSI i.MX51: SD1_ DATA0 MicroSD TM Data J2:105 UHVIO31 SD1_CMD/AUD5_ RXFS/SPI_MOSI i.MX51: SD1_CMD MicroSD TM Command J2:106 UHVIO31 SD1_DATA1/AUD5_ RXD i.MX51: SD1_ DATA1 MicroSD TM Data J2:107 UHVIO31 SD1_CLK/AUD5_ RXC/SPI_SCLK i.MX51: SD1_CLK MicroSD TM Clock J2:108 UHVIO31 SD1_DATA2/AUD5_ TXC i.MX51: SD1_ DATA2 MicroSD TM Data J2:109 GPIO27 WDOG1# i.MX51: GPIO1_4 Reserved J2:110 UHVIO31 SD1_DATA3/AUD5_ TXFS/SPI_SS1 i.MX51: SD1_ DATA3 MicroSD TM Data J2:111 GPIO27 CSPI1_MOSI/I2C1_ i.MX51: CSPI1_ SDA/GPIO4_22 MOSI MC13892: MOSI ConnectCore for i.MX51 Hardware Reference Manual HDMI Interrupt and PMIC Watchdog input cannot be used at the same time. SPI_MOSI 34 About the module Pin Module pinout Type Use on Comments development board Signal name Use on module J2:112 GPIO27 CSPI1_SS0_ PMIC/AUD4_ TXC/GPIO4_24 i.MX51: CSPI1_SS0 Reserved MC13892: CS J2:113 GPIO27 CSPI1_ MISO/AUD4_ RXD/GPIO4_23 i.MX51: CSPI1_ MISO MC13892: MISO J2:114 GPIO27 CSPI1_SS1/AUD4_ TXD/GPIO4_25 i.MX51: CSPI1_SS1 SPI_SS1 J2:115 GPIO27 CSPI1_SCLK/I2C1_ SCL/GPIO4_27 i.MX51: CSPI1_ SCLK MC13892: CLK J2:116 GPIO27 CSPI1_RDY/AUD4_ TXFS/GPIO4_26 i.MX51: CSPI1_RDY LCD1 and LCD2 SPI Chip Select J2:117 GPIO27 UART1_ RXD/GPIO4_28 i.MX51: UART1_ RXD UART1 MEI J2:118 GPIO27 UART1_ RTS#/GPIO4_30 i.MX51: UART1_ RTS UART1 MEI J2:119 GPIO27 UART1_ i.MX51: UART1_ TXD/PWM2/GPIO4_ TXD 29 UART1 MEI J2:120 GPIO27 UART1_ CTS#/GPIO4_31 i.MX51: UART1_ CTS UART1 MEI J2:121 GPIO27 UART2_ RXD/GPIO1_20 i.MX51: UART2_ RXD UART2 Console J2:122 GPIO27 UART3_ RXD/UART1_ DTR#/GPIO1_22 i.MX51: UART3_ RXD UART3/XBee J2:123 GPIO27 UART2_ TXD/GPIO1_21 i.MX51: UART2_ TXD UART2 Console J2:124 GPIO27 UART3_ TXD/UART1_ DSR#/GPIO1_23 i.MX51: UART3_ TXD UART3/XBee J2:125 GPIO27 USBH1_ DATA2/UART2_ TXD_GPIO1_13 i.MX51: USBH1_ DATA2 USB Host J2:126 - GND - - ConnectCore for i.MX51 Hardware Reference Manual SPI_MISO SPI_SCLK 35 About the module Module pinout Signal name Use on module Use on Comments development board J2:127 GPIO27 USBH1_ DATA4/CSPI_ SS0/GPIO1_15 i.MX51: USBH1_ DATA4 USB Host J2:128 GPIO27 USBH1_ DATA0/UART2_ CTS#/GPIO1_11 i.MX51: USBH1_ DATA0 USB Host (default) and UART2 Console J2:129 GPIO27 USBH1_ DATA6/CSPI_ SS3/GPIO1_17 i.MX51: USBH1_ DATA6 USB Host J2:130 GPIO27 USBH1_ DATA1/UART2_ RXD/GPIO1_12 i.MX51: USBH1_ DATA1 USB Host J2:131 GPIO27 USBH1_DIR/SPI_ MOSI/GPIO1_ 26/I2C2_SDA i.MX51: USBH1_ DIR USB Host J2:132 GPIO27 USBH1_ DATA3/UART2_ RTS#/GPIO1_14 i.MX51: USBH1_ DATA3 USB Host (default) and UART2 Console J2:133 GPIO27 USBH1_STP/SPI_ RDY/GPIO1_27 i.MX51: USBH1_ STP USB Host J2:134 GPIO27 USBH1_ DATA5/CSPI_ SS1/GPIO1_16 i.MX51: USBH1_ DATA5 USB Host J2:135 GPIO27 USBH1_NXT/SPI_ MISO/GPIO1_28 i.MX51: USBH1_ NXT USB Host J2:136 GPIO27 USBH1_ DATA7/CSPI1_ SS3/SPI2_ SS3/GPIO1-18 i.MX51: USBH1_ DATA7 USB Host J2:137 GPIO27 AUD3_BB_ TXD/GPIO4_18 i.MX51: AUD3_BB_ TXD Audio CODEC and HDMI Audio J2:138 GPIO27 USBH1_CLK/SPI_ SCLK/GPIO1_ 25/I2C2_SCL/ i.MX51: USBH1_ CLK USB Host Pin Type ConnectCore for i.MX51 Hardware Reference Manual 36 About the module Module pinout Signal name Use on module Use on Comments development board J2:139 GPIO27 AUD3_BB_ RXD/UART3_ RXD/GPIO4_19 i.MX51: AUD_BB_ RXD Audio CODEC J2:140 - HS_I2C_ SCL/GPIO4_16 i.MX51: I2C_SCL Not used J2:141 GPIO27 AUD3_BB_ CK/GPIO4_20 i.MX51: AUD_BB_ CK Audio CODEC and HDMI Audio J2:142 - HS_I2C_ SDA/GPIO4_17 i.MX51: I2C_SDA Not used J2:143 - +3.3V - - J2:144 GPIO27 AUD3_BB_ FS/UART3_ TXD/GPIO4_21 i.MX51: AUD_BB_ FS Audio CODEC and HDMI Audio J2:145 UHVIO31 NANDF_D0/PATA_ D0/SD4_ DATA7/GPIO4_8 i.MX51: NANDF_D0 Reserved NAND_FLASH: I/O0 J2:146 - +3.3V - J2:147 UHVIO31 NANDF_D2/PATA_ D2/SD4_ DATA5/GPIO4_6 i.MX51: NANDF_D2 Reserved NAND_FLASH: I/O2 J2:148 UHVIO31 NANDF_D1/PATA_ D1/SD4_ DATA6/GPIO4_7 i.MX51: NANDF_D1 Reserved NAND_FLASH: I/O1 J2:149 UHVIO31 NANDF_D4/PATA_ D4/SD4_ CD/GPIO4_4 i.MX51: NANDF_D4 Reserved NAND_FLASH: I/O4 J2:150 UHVIO31 NANDF_D3/PATA_ D3/SD4_ DATA4/GPIO4_5 i.MX51: NANDF_D3 Reserved NAND_FLASH: I/O3 J2:151 UHVIO31 NANDF_D6/PATA_ D6/SD4_ LCTL/GPIO4_2 i.MX51: NANDF_D6 Reserved NAND_FLASH: I/O6 Pin Type ConnectCore for i.MX51 Hardware Reference Manual The HS_I2C interface is not working in i.MX51. The HS_I2C interface is not working in i.MX51. - 37 About the module Pin Module pinout Type Use on Comments development board Signal name Use on module J2:152 UHVIO31 NANDF_D5/PATA_ D5/SD4_ WP/GPIO4_3 i.MX51: NANDF_D5 Reserved NAND_FLASH: I/O5 J2:153 UHVIO31 NANDF_D8/PATA_ D8/GPIO4_0/SD3_ DATA0 i.MX51: NANDF_D8 SD/MMC Data J2:154 UHVIO31 NANDF_D7/PATA_ D7/GPIO4_1 i.MX51: NANDF_D7 Reserved NAND_FLASH: I/O7 J2:155 UHVIO31 NANDF_D10/PATA_ i.MX51: NANDF_ D10/GPIO3_ D10 30/SD3_D2 J2:156 UHVIO31 NANDF_D9/PATA_ D9/GPIO3_ 31/SD3_D1 J2:157 UHVIO31 NANDF_D12/PATA_ i.MX51: NANDF_ D12/GPIO3_ D12 28/SD3_D4 Reserved J2:158 UHVIO31 NANDF_D11/PATA_ i.MX51: NANDF_ D11/GPIO3_ D11 29/SD3_D3 SD/MMC Data J2:159 UHVIO31 NANDF_D14/PATA_ i.MX51: NANDF_ D14/GPIO3_ D14 26/SD3_D6 Reserved J2:160 UHVIO31 NANDF_D13/PATA_ i.MX51: NANDF_ D13/GPIO3_ D13 27/SD3_D5 Reserved J2:161 UHVIO31 NANDF_ CS0#/GPIO3_16 Reserved J2:162 UHVIO31 NANDF_D15/PATA_ i.MX51: NANDF_ D15/GPIO3_ D15 25/SD3_D7 Reserved J2:163 UHVIO31 NANDF_ CS2#/PATA_ CS0#/GPIO3_18 Digital I/O Connector ConnectCore for i.MX51 Hardware Reference Manual SD/MMC Data i.MX51: NANDF_D9 SD/MMC Data i.MX51: NANDF_ CS0 NAND_FLASH: CE# i.MX51: NANDF_ CS2 NAND_FLASH: NC 38 About the module Module pinout Signal name Use on module Use on Comments development board J2:164 UHVIO31 NANDF_ CS1#/GPIO3_17 i.MX51: NANDF_ CS1 NAND_FLASH: NC SD/MMC Write Protect J2:165 UHVIO31 NANDF_ CS4#/PATA_ DA0/GPIO3_20 i.MX51: NANDF_ CS4 Digital I/O Connector J2:166 UHVIO31 NANDF_ CS3#/PATA_ CS1#/GPIO3_19 i.MX51: NANDF_ CS3 NAND_FLASH: NC HDMI audio clock enable J2:167 UHVIO31 NANDF_ CS6#/PATA_ DA2/GPIO3_22 i.MX51: NANDF_ CS6 Digital I/O Connector J2:168 UHVIO31 NANDF_ CS5#/PATA_ DA1/GPIO3_21 i.MX51: NANDF_ CS5 Digital I/O Connector J2:169 UHVIO31 NANDF_RDY_ INT/GPIO3_24 i.MX51: NANDF_ RDY_INT SD/MMC Command J2:170 UHVIO31 NANDF_ CS7#/GPIO3_23 i.MX51: NANDF_ CS7 SD/MMC Clock J2:171 UHVIO31 NANDF_ WE#/PATA_ DIOW/GPIO3_3 i.MX51: NANDF_ Reserved WE_B NAND_FLASH: WE# J2:172 UHVIO31 GPIO_NAND/PATA_ i.MX51: GPIO_ INTRQ/GPIO3_12 NAND SD/MMC Card Detect J2:173 UHVIO31 NANDF_ALE/PATA_ BUFFER_ EN/GPIO3_5 i.MX51: NANDF_ ALE NAND_FLASH: ALE Reserved J2:174 UHVIO31 NANDF_RE#/PATA_ i.MX51: NANDF_ DIOR/GPIO3_4 RE_B NAND_FLASH: RE# Reserved J2:175 UHVIO31 NANDF_ WP#/PATA_ DMACK/GPIO3_7 Reserved J2:176 UHVIO31 NANDF_CLE/PATA_ i.MX51: NANDF_ RESET/GPIO3_6 CLE NAND_FLASH: CLE Pin Type ConnectCore for i.MX51 Hardware Reference Manual i.MX51: NANDF_ WP_B NAND_FLASH: WP# SD clock and Digital IO cannot be used at the same time. Reserved 39 About the module Module pinout Signal name Use on module Use on Comments development board J2:177 UHVIO31 NANDF_ RB1/PATA_ IORDY/GPIO3_9 i.MX51: NANDF_ RB1 NAND_FLASH: NC User LED2 and Digital I/O Connector Must not be low during NAND Boot J2:178 UHVIO31 NANDF_ RB0/PATA_ DMARQ/GPIO3_8 i.MX51: NANDF_ RB0 NAND_FLASH: R/B# Reserved Must not be low during NAND Boot J2:179 UHVIO31 NANDF_ RB3/GPIO3_11 i.MX51: NANDF_ RB3 NAND_FLASH: NC Digital I/O Connector Must not be low during NAND Boot J2:180 UHVIO31 NANDF_ RB2/GPIO3_10 i.MX51: NANDF_ RB2 NAND_FLASH: NC User LED1 and Digital I/O Connector Must not be low during NAND Boot Pin Type Notes: n Many of the i.MX51 pins above have more functions than those shown in the reference names. For a complete list of pin multiplexing see Chapter 4 - External Signals and Pin Multiplexing of the Freescale i.MX51 Multimedia Applications Processor Reference Manual, Rev. 1 (or later). n The signal name value listed for pins 85 and 115 (above) does not match what is listed in the schematics. This is simply a documentation error, functionality of these pins works according to what is listed in this guide. ConnectCore for i.MX51 Hardware Reference Manual 40 About the module Power Power Module power supplies The following figure shows the power supply scheme of the ConnectCore for i.MX51 module. Supply inputs The ConnectCore for i.MX51module has the following supply inputs: n Battery input (VLIO) n Charger input (VCHRG) n Coin Cell input (VCC_COINCELL) Coin cell input (VCC_COINCELL) The VCC_COINCELL pin allows connection to either a coin cell or a supercap. This permits the RTC to keep running when the VLIO and VCHRG are at 0 volts. You can program the PMIC to allow current to be output from this pin while VLIO or VCHRG are present to charge the supercap (or Secondary Lithium Manganese coin cell). When in charge mode, this pin can output 60uA and the PMIC can be configured for a charge termination voltage in the range +2.5V to +3.3V. The following table shows the current draw from the coin cell when there is no main battery attached: Mode Description RTC All blocks disabled, no main battery attached, coin cell is attached. 36 ConnectCore for i.MX51 Hardware Reference Manual Typ Max Unit 50 uA 41 About the module Power There are three types of components that can be connected to this pin: Lithium coin cells (Primary cell: non-rechargeable), Lithium coin cells (Secondary cell: rechargeable), and Supercaps. When a Primary Lithium coin cell is connected, the charger must be turned off and this pin is used strictly as an input. It is hazardous to attempt to charge Primary Lithium cells as they may vent or explode. Secondary Lithium coin cells are only made available directly to manufacturers of equipment that could use them, in that case they are normally required to design their product to prevent the user gaining access to this part since there is a danger to the user if by replacing it, they fit a primary type (the only sort that they are likely to be able to source) into the charging circuit. When a Secondary Lithium coin cell is used, the charge termination voltage is programmable. When a Supercap is used, the charge termination voltage should be set to the maximum value. The advantage of using a Primary Lithium coin cell is that the energy density usually allows years of service since the self discharge rate is low. The advantage of using a Secondary Lithium coin cell is that the self discharge rate is usually sufficient to allow a few months of support for the RTC before it will need recharging. The advantage of the Supercap is that it is intrinsically safe and can out-last the Primary Lithium coin cell option, however the self discharge rate is high meaning that a 1F capacitor at +25° C is likely to support the RTC for approximately 5 to 10 days. The minimum voltage of the coin cell supply is +2.5V. The maximum voltage of the coin cell supply is +3.6V. Supply outputs The ConnectCore for i.MX51 module provides the following supply outputs: n +3.3 V n +2.775 V n SWBT (+5 V) n +1.8 V n +3.15 V +3.3 V The ConnectCore for i.MX51 module has a DC/DC converter to generate a +3.3V supply. This supply is used on the module to power the WLAN interface, the Ethernet PHY and the Ethernet Controller. This power regulator can be enabled/disabled by the software to save power when the module is in the low power modes. The maximum current provided by this regulator is 1.2A. The current available to supply off-module components is 400mA for the wireless variants of the ConnectCore for i.MX51, and 800mA for the wired variant of the ConnectCore for i.MX51. +2.775 V This supply is used on the module to power the i.MX51 peripherals, the accelerometer and the i.MX51 image processing unit. The maximum current provided by this supply is 100mA. The current available to supply off-module components is 50mA. SWBT (+5 V) The voltage level of the SWBT supply is +5V. The maximum current provided by this supply is 300mA. ConnectCore for i.MX51 Hardware Reference Manual 42 About the module Power +1.8 V This supply is generated on the internal regulator of the PMIC. The maximum current provided by this supply is 250mA. +3.15 V This supply is used on the module to power the NAND Flash interface and the SD-card 1 interface. The maximum current provided by this supply is 350mA. The current available to supply off-module components is 300mA. MC13892 power management The ConnectCore for i.MX51 module is designed with Freescale MC13892 Power Management chip. This chip provides reference and supply voltages for the i.MX51 as well as for the peripheral devices. The MC13892 has four buck switchers, one +5V boost switcher and twelve low dropout regulators as well as other user interfaces. The following figure shows the block diagram of the MC13892. ConnectCore for i.MX51 Hardware Reference Manual 43 About the module Memory Memory DDR2 SDRAM memory The ConnectCore for i.MX51 module provides up to 512 MB of DDR2-400 Synchronous dynamic random access memory (SDRAM) memory. The module can support up to four 16-bit, 128Mb, DDR2-400 chips, configured as two banks of 32-bits of 128 Mb double data rate (DDR)2-400 memory. NAND flash memory The ConnectCore for i.MX51 module provides 512 MB of Negated AND (NAND)-Flash memory. On the module a 512 MB, 2Kbyte page, NAND-Flash chip is used. Options for other densities NAND Flash devices are available depending on the module variant. ConnectCore for i.MX51 Hardware Reference Manual 44 About the module Chip selects Chip selects Chip select memory map The ConnectCore for i.MX51 has eight chip select signals, two for dynamic memory and six for static memory. The table below shows the memory map of these chip select signals. Name Pin Address range DRAM_ CS0# Y4 DRAM_ CS1# Sixe [Mb] Usage Comments 0x9000_000-0x9FFF_ 256M FFFF DDR2 bank 0 First bank on module Y3 0xA000_00000xAFFF_FFFF 256M DDR2 bank 1 Second bank on module EIM_CS0 W6 0xB000_0000xB7FF_FFFF 128M External CS0# EIM_CS1 Y6 0xB800_0000xBFFF_FFFF 128M External CS1# EIM_CS2 Y7 0xC000_0000xC7FF_FFFF 128M External CS2# EIM_CS3 AC3 0xC800_0000xCBFF_FFFF 64M External CS3# EIM_CS4 AA6 0xCC00_0000xCDFF_FFFF 32M External CS4# EIM_CS5 AA5 0xCE00_0000xCFFE_FFFF 32M (minus 64K) External CS5# ConnectCore for i.MX51 Hardware Reference Manual Used for Ethernet Controller on module 45 About the module Multiplexed GPIO Multiplexed GPIO GPIO multiplexing table The ConnectCore for i.MX51 has four GPIO banks. Each bank provides 32 bidirectional general purpose input and output signals. The GPIO pins are multiplexed with other functions on the module. For each pin there are up to 8 muxing options (called ALT modes). By default all GPIO pins are configured to their respective GPIO signals. Since different modules require different pin settings (like pull up, keeper, etc) the i.MX51 has an IOMUX controller to configure the pin settings. The table below shows the ALT mode for each GPIO signal, the name of the Pad and the default use on the module. For a detailed description of all the muxing options for each pin, refer to the i.MX51 Hardware Reference Manual. WARNING! Do not connect signals marked NANDF_* to GND during boot time if you want to boot from NAND flash. GPIO Mode Pad On module default as GPIO1_0 ALT1 GPIO1_0 HDMI Interrupt GPIO1_1 ALT1 GPIO1_1 User Button 2 GPIO1_2 ALT0 GPIO1_2 I2C2_SCL GPIO1_3 ALT0 GPIO1_3 I2C2_SDA GPIO1_4 ALT0 GPIO1_4 Watchdog reset GPIO1_5 ALT0 GPIO1_5 MC13892 Interrupt GPIO1_6 ALT0 GPIO1_6 Accelerometer Interrupt 2 GPIO1_7 ALT0 GPIO1_7 Accelerometer Interrupt 1 GPIO1_8 ALT0 GPIO1_8 USB Power enable GPIO1_9 ALT0 GPIO1_9 Ethernet 2 Interrupt GPIO1_10 ALT7 DISP2_DAT11 Ethernet 1 GPIO1_11 ALT2 USBH1_DATA0 USB Host GPIO1_12 ALT2 USBH1_DATA1 USB Host GPIO1_13 ALT2 USBH1_DATA2 USB Host GPIO1_14 ALT2 USBH1_DATA3 USB Host GPIO1_15 ALT2 USBH1_DATA4 USB Host GPIO1_16 ALT2 USBH1_DATA5 USB Host ConnectCore for i.MX51 Hardware Reference Manual 46 About the module Multiplexed GPIO GPIO Mode Pad On module default as GPIO1_17 ALT2 USBH1_DATA6 USB Host GPIO1_18 ALT2 USBH1_DATA7 USB Host GPIO1_19 ALT5 DISP2_DAT6 Ethernet 1 GPIO1_20 ALT3 UART2_RXD UART2_RXD GPIO1_21 ALT3 UART2_TXD UART2_TXD GPIO1_22 ALT3 UART3_RXD UART3_RXD GPIO1_23 ALT3 UART3_TXD UART3_TXD GPIO1_24 ALT3 OWIRE_LINE S/PDIF Output GPIO1_25 ALT2 USBH1_CLK USB Host GPIO1_26 ALT2 USBH1_DIR USB Host GPIO1_27 ALT2 USBH1_STP USB Host GPIO1_28 ALT2 USBH1_NXT USB Host GPIO1_29 ALT5 DISP2_DAT7 Ethernet 1 GPIO1_30 ALT5 DISP2_DAT8 Ethernet 1 GPIO1_31 ALT5 DISP2_DAT9 Ethernet 1 GPIO2_0 ALT1 EIM_D16 EIM_D16 GPIO2_1 ALT1 EIM_D17 EIM_D17 GPIO2_2 ALT1 EIM_D18 EIM_D18 GPIO2_3 ALT1 EIM_D19 EIM_D19 GPIO2_4 ALT1 EIM_D20 EIM_D20 GPIO2_5 ALT1 EIM_D21 EIM_D21 GPIO2_6 ALT1 EIM_D22 EIM_D22 GPIO2_7 ALT1 EIM_D23 EIM_D23 GPIO2_8 ALT1 EIM_D24 EIM_D24 GPIO2_9 ALT1 EIM_D27 EIM_D27 GPIO2_10 ALT1 EIM_A16 GPIO GPIO2_11 ALT1 EIM_A17 GPIO GPIO2_12 ALT1 EIM_A18 GPIO GPIO2_13 ALT1 EIM_A19 GPIO GPIO2_14 ALT1 EIM_A20 GPIO ConnectCore for i.MX51 Hardware Reference Manual 47 About the module Multiplexed GPIO GPIO Mode Pad On module default as GPIO2_15 ALT1 EIM_A21 GPIO GPIO2_16 ALT1 EIM_A22 GPIO GPIO2_17 ALT1 EIM_A23 GPIO GPIO2_18 ALT1 EIM_A24 GPIO GPIO2_19 ALT1 EIM_A25 GPIO GPIO2_20 ALT1 EIM_A26 GPIO GPIO2_21 ALT1 EIM_A27 XBEE_SLEEP_RQ GPIO2_22 ALT1 EIM_EB2 EIM_EB2 GPIO2_23 ALT1 EIM_EB3 EIM_EB3 GPIO2_24 ALT1 EIM_OE EIM_OE GPIO2_25 ALT1 EIM_CS0 EIM_CS0 GPIO2_26 ALT1 EIM_CS1 GPIO GPIO2_27 ALT1 EIM_CS2 GPIO GPIO2_28 ALT1 EIM_CS3 GPIO GPIO2_29 ALT1 EIM_CS4 GPIO GPIO2_30 ALT1 EIM_CS5 Ethernet 2 Controller chip select GPIO2_31 ALT1 EIM_DTACK GPIO GPIO3_0 ALT4 DI1_PIN11 LCD1 PWREN GPIO3_1 ALT4 DI1_PIN12 LCD2 PWREN ALT1 EIM_LBA GPIO ALT4 DI1_PIN13 GPIO ALT1 EIM_CRE GPIO ALT4 DI1_D0_CS LCD Touch Screen interrupt ALT3 NANDF_WE_B NANDF_WE_B ALT4 DI1_D1_CS LCD1_TCH_INT/TCH_EXT# ALT3 NANDF_RE_B NANDF_RE_B ALT4 DISPB2_SER_DIN GPIO ALT3 NANDF_ALE ALT4 DISPB2_SER_DIO User Button 1 / GPIO ALT3 NANDF_CLE GPIO3_2 GPIO3_3 GPIO3_4 GPIO3_5 GPIO3_6 ConnectCore for i.MX51 Hardware Reference Manual NANDF_ALE NANDF_CLE 48 About the module Multiplexed GPIO GPIO Mode Pad GPIO3_7 ALT4 DISPB2_SER_CLK Camera 2 Reset ALT3 NANDF_WP_B NANDF_WP_B ALT4 DISPB2_SER_RS USB Host Reset signal ALT3 NANDF_RB0 NANDF_RB0 ALT3 NANDF_RB1 GPIO / User LED2 GPIO3_10 ALT3 NANDF_RB2 GPIO / User LED1 GPIO3_11 ALT3 NANDF_RB3 GPIO GPIO3_12 ALT3 CSI1_D8 Not used GPIO_NAND Card Detect input SD Card GPIO3_13 ALT3 CSI1_D9 Camera 1 Reset GPIO3_14 ALT3 CSI1_VSYNC CSI1_VSYNC GPIO3_15 ALT3 CSI1_HSYNC CSI1_HSYNC GPIO3_16 ALT3 NANDF_CS0 NANDF_CS0 GPIO3_17 ALT3 NANDF_CS1 SD Card write protect GPIO3_18 ALT3 NANDF_CS2 GPIO GPIO3_19 ALT3 NANDF_CS3 Not used GPIO3_20 ALT3 NANDF_CS4 GPIO GPIO3_21 ALT3 NANDF_CS5 GPIO GPIO3_22 ALT3 NANDF_CS6 GPIO GPIO3_23 ALT3 NANDF_CS7 SD3_CLK GPIO3_24 ALT3 NANDF_RDY_INT SD3_CMD# GPIO3_25 ALT3 NANDF_D15 SD3_DATA7 GPIO3_26 ALT3 NANDF_D14 SD3_DATA6 GPIO3_27 ALT3 NANDF_D13 SD3_DATA5 GPIO3_28 ALT3 NANDF_D12 SD3_DATA4 GPIO3_29 ALT3 NANDF_D11 SD3_DATA3 GPIO3_30 ALT3 NANDF_D10 SD3_DATA2 GPIO3_31 ALT3 NANDF_D9 SD3_DATA1 GPIO4_0 ALT3 NANDF_D8 SD3_DATA0 GPIO4_1 ALT3 NANDF_D7 NANDF_D7 GPIO3_8 GPIO3_9 ALT0 ConnectCore for i.MX51 Hardware Reference Manual On module default as 49 About the module Multiplexed GPIO GPIO Mode Pad On module default as GPIO4_2 ALT3 NANDF_D6 NANDF_D6 GPIO4_3 ALT3 NANDF_D5 NANDF_D5 GPIO4_4 ALT3 NANDF_D4 NANDF_D4 GPIO4_5 ALT3 NANDF_D3 NANDF_D3 GPIO4_6 ALT3 NANDF_D0 NANDF_D0 GPIO4_7 ALT3 NANDF_D1 NANDF_D1 GPIO4_8 ALT3 NANDF_D0 NANDF_D0 GPIO4_9 ALT3 CSI2_D12 CSI2_D12 GPIO4_10 ALT3 CSI2_D13 CSI2_D13 GPIO4_11 ALT3 CSI2_D18 CSI2_D18 GPIO4_12 ALT3 CSI2_D19 CSI2_D19 GPIO4_13 ALT3 CSI2_VSYNC CSI2_VSYNC GPIO4_14 ALT3 CSI2_HSYNC CSI2_HSYNC GPIO4_15 ALT3 CSI2_PIXCLK CSI2_PIXCLK GPIO4_16 ALT3 I2C1_CLK GPIO GPIO4_17 ALT3 I2C1_DAT GPIO GPIO4_18 ALT3 AUD3_BB_TXD AUD3_BB_TXD GPIO4_19 ALT3 AUD3_BB_RXD AUD3_BB_RXD GPIO4_20 ALT3 AUD3_BB_CK AUD3_BB_CK GPIO4_21 ALT3 AUD3_BB_FS AUD3_BB_FS GPIO4_22 ALT3 CSPI1_MOSI CSPI1_MOSI GPIO4_23 ALT3 CSPI1_MISO CSPI1_MISO GPIO4_24 ALT3 CSPI1_SS0 CSPI1_SS0 (MC13892 Chip select) GPIO4_25 ALT3 CSPI1_SS1 CSPI1_SS1 GPIO4_26 ALT3 CSPI1_RDY LCD SPI chip select GPIO4_27 ALT3 CSPI1_SCLK CSPI1_SCLK GPIO4_28 ALT3 UART1_RXD UART1_RXD GPIO4_29 ALT3 UART1_TXD UART1_TXD GPIO4_30 ALT3 UART1_RTS UART1_RTS GPIO4_31 ALT3 UART1_CTS UART1_CTS ConnectCore for i.MX51 Hardware Reference Manual 50 About the module Multiplexed GPIO Interfaces 1-Wire The ConnectCore for i.MX51 provides a 1-Wire communication interface. The module sends or receives one bit at a time. The required protocol for accessing the generic 1-Wire device is defined by Maxim. The main features of the 1-Wire interface are the following: n Performs the 1-Wire bus protocol to communicate with an external 1-Wire device n Provides a clock divider to generate a 1-Wire bus reference clock Accelerometer The module provides a three axis digital output accelerometer. This device is connected to the i.MX51 through the I 2C bus. The I 2C device address of the accelerometer is the following: Interface I2C Address (7 bits) Accelerometer (MMA7455L) 0 x 1D The main features of the accelerometer device are the following: n User assigned registers for offset calibration n Programmable threshold interrupt output n Level detection for motion recognition (shock, vibration, freefall) n Pulse detection for single or double pulse recognition n Selectable sensitivity (±2g, ±4g, ±8g) for 8-bit mode ADC and touch screen The module provides an eight channel 10-bit ADC. The ADC/Touch interface is integrated in the MC13892 power management device. You can use this ADC as a standard ADC or as a touch screen interface. The ADC runs at approximately 2MHz, and it has an auto calibration circuit which reduces the offset and gain errors. The main features of the ADC are the following: n Resolution: 10-bit n Differential linearity error: 1 LSB n Integral linearity error: 3 LSB n Conversion time per channel: 10 us n Low power consumption (1 mA of conversion current) n Analog input range: 0 ~ 2.4V n Five channels pre-assigned to battery interface measurements n Internal voltage scaling for pre-assigned measurements n Normal conversion mode and touch screen mode n The following table shows the ADC channel assignment in ADC and touch screen modes: ConnectCore for i.MX51 Hardware Reference Manual 51 About the module Multiplexed GPIO Channel ADC Mode Touch Screen Mode Touch Screen Inactive Mode 0 Battery Voltage Touch_X1 - 1 Battery Current Touch_X2 - 2 Application voltage (VBP) - - 3 Charger Voltage Touch_Y1 - 4 Charger Current Touch_Y2 General Purpose via TOUCH_X1 5 Battery Temperature Monitoring - General Purpose via TOUCH_X2 6 General Purpose ADIN6 Contact resistance General Purpose via TOUCH_Y1 7 General Purpose ADIN7 Contact resistance General Purpose via TOUCH_Y2 The ADC Mode, Touch Screen Mode and Touch Screen Inactive Mode are selected using the ADSEL, TSMOD0, TSMOD1 and TSMOD2 bits in the Freescale MC13892 Power Management chip. Channel 5 in ADC mode connects via ADIN5 but this is typically where a Thermistor is used to monitor the battery pack temperature. When battery temperature monitoring is not required, this input can be used as a general purpose ADC input but with the following considerations: 1. The power-up default state is for temperature monitoring via the Thermistor. The IMX51 module contains a resistor divider to apply the right bias to the ADIN5 pin to allow the unit to boot correctly (without requiring a Thermistor to be fitted). The software will first need to disable this function after which the analogue input may be connected to ADIN5. Once this is disabled, the real analogue input may be connected via this pin. 2. The presence of the resistor divider appears like a 5k Ω load, it follows that the tri-state buffer used to drive this input will need to have an output impedance of less than 5Ω if the 10-bit resolution is not to be compromised. An alternative approach is to disable the GPO1 pin of the MC13892 in software and use that pin as the input. In that case the input impedance will look like 20k Ω to GND. Therefore the tri-state buffer output impedance now needs to be 20Ω or lower. However this way results in the real input voltage being divided by 2 on the ADC input. When using GPO1 as the input, do not connect anything to ADIN5. Channel 6 in ADC mode may also monitor the Coin-cell input voltage. Channel 7 in ADC mode may also monitor the Die Temperature. Please note the UID voltage cannot be read nor is alternative input ADIN7B available. It is possible to support 7 ADC channels by alternating between the ADC mode and Touch Screen Inactive mode. For more information refer to the datasheet of the Freescale MC13892 Power Management chip. Synchronous Serial Interface (SSI) The ConnectCore for i.MX51 module provides up to three synchronous serial interfaces (SSI) that allows communicating with a variety of serial devices as standard CODECs, audio CODECs implementing the I 2S standard and Intel AC97 standard. SSI is typically used to transfer samples in a periodic manner. The SSI consists of independent transmitter and receiver sections with independent clock generation and frame synchronization. The main features of the SSI interface are the following: ConnectCore for i.MX51 Hardware Reference Manual 52 About the module Multiplexed GPIO n Independent (asynchronous) or shared (synchronous) transmit and receive sections operating in Master or Slave mode n Normal mode operation using frame sync n Network mode operation allowing multiple devices to share the port with as many as 32 time slots n Two sets of four 15 x 32 bits Transmit and Receive FIFOs. n Programmable data interface mode such like I 2S, LSB, MSB aligned n Programmable word length 8, 10, 12, 16, 18, 20, 22 or 24 bits n Program options for frame sync and clock generation n Programmable I 2S modes (Master, Slave or Normal) n AC97 support External Memory Interface (EMI) The module provides access to the external memory controller. This memory controller handles the interface to devices external to the chip, including generation of chip selects, clock and control for external peripherals and memory. It provides asynchronous access to devices with SRAM-like interface and synchronous access to devices with NOR Flash like or PSRAM like interfaces. The following lines of the memory controller are available on the module connectors: n Support for multiplexed address/data bus operations l 16-bit data/28-bit address in non-multiplexed address/data mode l 16-bit or 32-bit data/28-bit address in multiplexed address/data mode n Programmable data port size of each chip select n 28-bit address bus n Up to 5 chip selects n Read and write control lines n 2 x byte enable signals n Register/command selection line (CRE) Note 8-bit devices are supported by the EMI connecting to only one of the following three locations: n EIM_DA[7:0] pads n EIM_DA[15:8] pads n EIM_DA[31:24] pads Connection to the EIM_D[23:16] pads is not supported. Ethernet 1 The ConnectCore for i.MX51 provides a Fast Ethernet Controller (FEC) designed to support both 10 and 100 Mb/s Ethernet/IEEE 802.3 networks. A low power consumption 10/100 Ethernet transceiver (LAN8710A) from SMSC is used on the module to complete the interface to the media. The module does not provide a transformer and Ethernet connector. The PHY address on the MII bus is 0x7 (0b00111). The module also provides two status signals for activity and link LEDs. ConnectCore for i.MX51 Hardware Reference Manual 53 About the module Multiplexed GPIO Ethernet 2 The ConnectCore for i.MX51 module can provide a high-performance 10/100Mb Ethernet controller (LAN9221) with integrated MAC and PHY from SMSC as a second Ethernet port. The main features of this Ethernet controller are the following: n Embedded 16 Kbyte FIFO for packet buffers n Support burst-mode read for highest performance applications n Configurable interrupt pin with programmable hold-off timer n Compatible with IEEE 802.3, 802.3u standards n Integrate Fast Ethernet MAC/PHY transceiver in one chip n 10Mb/s and 100Mb/s data rate n Full and half duplex operations n 10/100Mb/s Auto-negotiation operation n Twisted pair crossover detection and auto-correction (HP Auto-MDIX) n IEEE 802.3x flow control for full-duplex operation n Wake-on-LAN capabilities n LED pins for various network activity indications The Ethernet controller is connected to CS5#. Its programmable polarity interrupt output is connected to the signal GPIO1_9. The module does not have a transformer and Ethernet connector. The module provides two status signals for activity and link LEDs. I2C The module provides two I2C interfaces. The I2C interfaces operate up to 400Kbps, depending on pad loading and timing. The I2C system is a true multiple master bus including arbitration and collision detection. The I2C port 2 interface is available on the development board (header P22). Two 2K2 pull-up resistors are provided on the module. The I2C port 1 interface is available through the main module connectors (J1 and J2) as well as on the corresponding signal rail connectors (J25 and J26), multiplexed with other interface functionality. The development board does not provide a dedicated header for access to I2C port 1. The I2C port 1 signals are available through the main module connectors as outlined below: n I2C1_SDA: l J1.141 - EIM_D16 (used on the module for external Ethernet controller, if present) l J2.111 - SPI1_MOSI (used on the module as communication channel for Freescale PMIC) l n J2.86 - SD2_CLK (used on the module as communication channel for Wireless LAN interface, if present) I2C1_SCL: l J1.144 - EIM_D19 (used on the module for external Ethernet controller, if present) l J2.115 - SPI1_SCLK (used on the module as communication channel with Freescale PMIC) l J2.88 - SD2_CMD (used on the module as communication channel for Wireless LAN interface, if present) ConnectCore for i.MX51 Hardware Reference Manual 54 About the module Multiplexed GPIO The I2C interface provides the following capabilities: n Compatibility with I2C bus standard n Multiple-master operation n Software programmable for one of 64 different serial clock frequencies n Software selectable acknowledge bit n Start and stop signal generation detection n Repeated START signal generation n Acknowledge bit generation/detection n Bus-busy detection Video subsystem The i.MX51 processor has a video subsystem that includes the following modules: n Video Processing Unit (VPU): a multi-standard video encoder/decoder n Image Processing Unit (IPU): providing connectivity to displays, related processing, synchronization and control n TV encoder (TVE) bride: providing optional translation from the digital display interface supported by the IPU to SDTV analog and some HDTV interfaces Video Processing Unit (VPU) The video processing unit of the i.MX51 is a high performance, multistandard video processing unit that can perform H.264 BP/MP/HP, VC-1 SP/MP/AP, MPEG4 SP/ASP, Divx, RV8/9, and MPEG2 MP decoding up to 1920 × 1088 resolution. It supports multiple video codecs simultaneously. The detailed features of the VPU are as follows: n Multi-standard video codec l H.264/AVC decoder for baseline profile, main profile and high profile l VC-1 decoder for simple profile, main profile and advanced profile l MPEG-4 decoder for simple profile, advanced simple profile except GMC l H.263 decoder for baseline profile l Divx Home Theater decoder for profile (version 3.x, 4.x, 5.x, 6.x) and Xvid l MPEG-2 decoder for main profile @ high level l RV decoder for profile 8/9/10 l H.264/AVC encoder for baseline profile l MPEG-4 encoder for simple profile l H.263 encoder for baseline profile l MJPEG encoder for baseline profile l Multiple codec: supports up to 4 decoding/encoding processes simultaneously, each process can have a different format ConnectCore for i.MX51 Hardware Reference Manual 55 About the module n Multiplexed GPIO Other features l Supports rotating and mirroring simultaneously. l Built-in de-ringing filter l Built-in de-blocking filter for MPEG-2/MPEG-4/Divx l Simultaneous multi-stream and multi-standard processing capability l Robust error detection Image Processing Unit (IPU) n Connect relevant devices - cameras, displays, graphics accelerators, TV encoders and decoders n Related image processing and manipulation: sensor image signal processing, display processing, image conversions, and so forth. n Synchronization and control capabilities (for example, to avoid tearing artifacts) The following figure shows the simplified block diagram of the IPU: The image processing unit has the following blocks: n Camera Sensor Interface - CSI l Controls a camera port; provides interface to an image sensor or a related device. The ConnectCore for i.MX51 has two camera blocks. ConnectCore for i.MX51 Hardware Reference Manual 56 About the module n Display Interface - DI l n Performs the processing required for data sent to display Image Converter - IC l n Controls the display ports Display Processor - DP l n Provides interface to displays, display controllers and related devices. The ConnectCore for i.MX51 has two camera blocks. Display Controller - DC l n Multiplexed GPIO Performs resizing, color conversion/correction, combining with graphics, and horizontal inversion Video De Interlacer - VDI l Performs video de interlacing (interlaced -> progressive) n Image Rotator - IRT n Image DMA Controller - IDMAC l l n Controls FIFOs for output from the CSIs to system memory Display Multi FIFO Controller - DMFC l n Controls the memory port; transfers data to/from system memory Sensor Multi FIFO Controller - SMFC l n Performs rotation (90 or 180 degrees) and inversion (vertical/horizontal) Controls FIFOs for IDMAC channels related to the display system Control Module - CM l Provides control and synchronization Keypad The module provides a keypad port that can be used as a keypad matrix interface or as general purpose input/output. The Keypad port is designed to interface with the keypad matrix with 2-point contact or 3-point contact keys. The Keypad port is designed to simplify the software task of scanning a keypad matrix. With appropriate software support, the Keypad port is capable of detecting, debouncing, and decoding one or multiple keys pressed simultaneously on the keypad. n Supports up to an 6 × 4 external keypad matrix n Port pins can be used as general purpose I/O n Open drain design n Glitch suppression circuit design n Multiple-key detection n Long key-press detection n Standby key-press detection n Synchronizer chain clear n Supports a 2-point and 3-point contact key matrix ConnectCore for i.MX51 Hardware Reference Manual 57 About the module Multiplexed GPIO Memory cards The ConnectCore for i.MX51 module provides up to four MMC/SD/SDIO interfaces. n MultiMediaCard (MMC) This is a universal low-cost data storage and communication media that is designed to cover a wide area of applications including mobile video and gaming, WLAN or other wireless networks. Old MMC cards are based on 7-pin serial bus with a single data pin, while the newer high-speed MMC communication is based on an advanced 11-pin serial bus designed to operate at lower voltage. n Secure Digital (SD) card This is an evolution of earlier MMC technology. It is specifically designed to meet the security, capacity, performance, and environment requirements inherent in newly emerging audio and video consumer electronic devices. The physical form factor, pin assignment and data transfer protocol are forward compatible with MMC, with some additions. Under the SD protocol, an SD card can be categorized as memory card, I/O card, or combo card (having both memory and I/O functions). The main features of the Memory Card interfaces are the following: n n Designed to work with MMC, MMC plus, MMC RS, SD memory, miniSD memory, SDIO, and SD Combo. Compatible with the following specifications: l MMC System Specification Version 4.2 l SD Host Controller Standard Specification Version 2.0 l SD Memory Card Specification Version 2.0: supports High-Capacity SD Memory Cards l SDIO Card Specification Version 2.0 Supports 1, 4, or 8 bit MMC modes and 1bit or 4 bit SD and SDIO modes l Card bus clock frequency up to 52 MHz l Up to 416 Mb/s of data transfer for MMC cards in 8-bit mode l Up to 200 Mb/s of data transfer for SD/SDIO cards in 4-bit mode l Allows cards to interrupt the host in 1-bit and 4-bit SDIO modes, also supports interrupt period The following table shows the memory card signals available on the module connectors: Signal Memory Card 1 Memory Card 2 Memory Card 3 Card Detect (CD #) √ Memory Card 4 √ CLK √ √ √ CMD √ √ √ LCTL √ √ WP# √ DATA3 - DATA0 √ DATA7 - DATA4 √ ConnectCore for i.MX51 Hardware Reference Manual √ √ √ √ √ √ 58 About the module Multiplexed GPIO PWM The ConnectCore for i.MX51 module provides two PWM interfaces. These PWM interfaces share the output pad in the i.MX51 CPU with the I 2C bus used on the module for the accelerometer. In order to use the PWM signals the I 2C bus must be disabled. The main features of the PWM interface are the following: n 16-bit up-counter with clock source selection n 4 × 16 FIFO to minimize interrupt overhead n 12-bit prescaler for division of clock n Sound and melody generation n Active high or active low configured output n Can be programmed to be active in low power and debug modes n Interrupts at compare and rollover RTC The ConnectCore for i.MX51 provides a Real Time Clock and a Secure Real Time clock. The real time clock function is provided including time and day counters as well as an alarm function. The RTC utilizes the 32.768KHz crystal oscillator for the time base and is powered by the coin cell backup supply when main supply has dropped below operational range. In configurations where the SRTC is used, the RTC can be disabled to conserve current drain. The accuracy of the 32.768KHz crystal used for the Real-Time Clock is ±20ppm. n RTC accuracy ±20ppm n 17-bit time of day counter n 15-bit day counter n Time of day alarm n Day alarm The secure real time clock helps to comply with issues arising out of different applications requiring secure and certifiable time, for example Digital Rights Management (DRM) schemes. The main features of the secure RTC interface are the following: n Secure 47-bit time counter n Non-secure 47-bit time counter n Use-mode protection. The SRTC cannot be configured by non-secured SW. n Re-programming protection. The SRTC cannot be altered or disabled after SRTC locked. n Clock source protection n Programmable secure and non-secure alarms with interrupt SPDIF The ConnectCore for i.MX51 has a Sony/Philips Digital Interface Transmitter (SPDIF Tx) audio module that allows the processor to transmit digital audio over it. For the SPDIF transmitter, the processor provides the audio data. Zero is always inserted in the user data. The SPDIF transmitter generates a SPDIF output bitstream in the biphase mark format (IEC958), which consists of audio data, channel status, and user data. In the SPDIF transmitter, the IEC958 biphase bit stream is generated on both edges of the SPDIF transmit clock. ConnectCore for i.MX51 Hardware Reference Manual 59 About the module n IEC 60958 format SPIDF output n 7 transmit clock source n Consumer channel status support n Support for interrupt and DMA Multiplexed GPIO SPI The module provides up to three SPI interfaces that can be configured in either master or slave mode. Two of the SPI interfaces contain one 64 x 32 receive buffer (RXFIFO) and one 64 x 32 transmit buffer (TXFIFO). The other SPI interface contains one 8 x 32 receive buffer and one 8 x 32 transmit buffer. n Full-duplex synchronous serial interface n Master/Slave configurable n Two SPI interfaces support SPI clocks up to 66MHz in both Master and Slave mode n One SPI interface supports SPI clocks up to 16.5MHz in both Master and Slave mode n Up to four chip selects (two chip select for SPI1) to support multiple peripherals n Transfer continuation function allows unlimited length data transfers n Polarity and phase of the chip select (SS#) and SPI Clock (SCLK) are configurable n Data ready output signal for fast data communication with fewer software interrupts n DMA support Watchdog timer The watchdog timer module protects against system failures by providing a method of escaping from unexpected events or programming errors. Once the watchdog module is activated, it must be serviced by the software on a periodic basis. If servicing does not take place, the timer times out. Upon a time-out, the watchdog timer module asserts the internal system reset signal. n A time-out counter with time-out periods from 0.5 to 128 seconds n Time resolution of 0.5 seconds n Configurable time-out counter that can be programmed to run or stop during low-power and debug modes n Programmable interrupt generation prior to time-out n Programmable time duration between interrupt and timeout events, from 0 to 128 seconds in steps of 0.5 seconds n Power down counter enabled out of any reset by default UART The module provides up to three UART ports. The UART 1 is a full-modem UART port with all the handshake signals available. The UART 2 and UART 3 ports are 4-wire UART ports with data lines RXD/TXD and the handshake lines RTS#/CTS#. The main features of these UART ports are the following: n 7 or 8 data bits n 1 or 2 stop bits n Programmable parity (even, odd, and no parity) ConnectCore for i.MX51 Hardware Reference Manual 60 About the module Multiplexed GPIO n Hardware flow control support for RTS# and CTS# signals (signals direction according to DEC mode) n Interrupt-based or DMA-based mode n Serial IR interface low-speed, IrDA-compatible (up to 115.2 Kbps) n Auto baud rate detection (up to 115.2 Kbps) n Programmable baud rate (up to 4Mb/s) n Two independent 32-byte FIFOs for receive and transmit USB Host and USB OTG The ConnectCore for i.MX51 provides three USB Host interfaces and one USB On-The-Go (OTG) interface. These interfaces conform to the USB 2.0 specification, the OTG supplement, and the ULPI specification. In addition to the normal USB functionality, the module also supports direct connections to on-board USB peripherals using serial or ULPI protocol. It also has serial/ULPI bypass mode connection and support for multiple interface types of ULPI and serial transceivers. Main features of the USB Host interfaces: n High-speed/full-speed/low-speed host n HS/FS ULPI compliant interface n Software configurable for full-speed/low-speed interface for serial transceivers n Full-speed transceiverless link logic (FS-TLL) for on board connection to a FS/LS USB peripheral n High-speed ULPI transceiverless link logic (HS-TLL) for onboard connection to a high- speed ULPI interface USB peripheral Main features of the USB OTG interface: n High-speed OTG n HS/FS ULPI compliant interface n Software configurable for ULPI or serial transceiver interface n High-speed (with ULPI transceiver), full-speed, and low-speed operation in host mode n High-speed (with ULPI transceiver), and full-speed operation in peripheral mode n Hardware support for OTG signaling, session request protocol, and host negotiation protocol n Up to 8 bidirectional endpoints WLAN In addition to the on-module Ethernet interface, the ConnectCore for i.MX51 module can also provide an optional 802.11a/b/g/n WLAN interface with data rates up to 54 Mb/s on the a/b/g band and up to 65 Mb/s on the n band. Two U.FL antenna connectors are provided on the module. ConnectCore for i.MX51 Hardware Reference Manual 61 About the module Multiplexed GPIO On the ConnectCore Wi-i.MX51 module variant, attach the antennas with the U.FL-RP-SMA female cable to the primary connector and secondary connector on the module. Note When disconnecting U.FL connectors, we strongly recommend the use of a U.FL plug extraction tool (Hirose P/N U.FL-LP-N-2 or U.FL-LP(V)-N-2) to avoid damage to the U.FL connectors on the module. To mate U.FL connectors, you must align the mating axes of both connectors. The “click” will confirm mated connection. Do not attempt insertion at an extreme angle. Cable specification: U.FL/W.FL to RP-SMA Attributes Attribute Property Impedance 50 Ohm Frequency Range 0 to 6 GHz Length 150 mm Temperature Range -40° to +90° C Loss 3.8dB/m (3 GHz) 5.6dB/m (6 GHz) Dimensions Note Dimensions are provided for reference purposes only. The actual antenna might vary. 1 = U.FL 2 = RP-SMA Note This module obtained its complete certification by using the cable described here. End users in North America should use a cable that matches these specifications to maintain the module’s certification. ConnectCore for i.MX51 Hardware Reference Manual 62 About the module ConnectCore for i.MX51 Hardware Reference Manual Multiplexed GPIO 63 About the development board The development board supports the ConnectCore for i.MX51 module. This section describes the interfaces of the development board and explains how to configure the board for your requirements. The development board has two 180-pin connectors that mate with the module connectors. About the development board Switches and push-buttons Jumpers LEDs Power LEDs, LE3, LE4, LE6 and LE7 Audio interface Coin cell battery Camera interfaces Digital IO interface Ethernet 1 interface Ethernet 2 interface HDMI interface I2C interface JTAG interface LCD interfaces MicroSD™ card interface Module connectors and signal rails J25 pinout J26 pinout Peripheral application header Power-Over-Ethernet (PoE) - IEEE802.3af Main power connector SD-card interface SPI interface UART interface USB host interface USB OTG interface User interface Analog video interface WLAN interface Digi XBee interface ConnectCore for i.MX51 Hardware Reference Manual 65 67 71 73 73 75 77 78 80 81 83 85 87 89 90 95 97 98 100 104 106 108 109 111 113 116 117 118 119 121 123 64 About the development board The development board supports the ConnectCore for i.MX51 module. This section describes the interfaces of the development board and explains how to configure the board for your requirements. The development board has two 180-pin connectors that mate with the module connectors. ConnectCore for i.MX51 Hardware Reference Manual 65 About the development board About the development board The development board ConnectCore for i.MX51 Hardware Reference Manual 66 About the development board Switches and push-buttons Switches and push-buttons Power switch, S2 The development board has an ON/OFF switch, S2. The power switch S2 can switch both 9V-30VDC input power supply and 12VDC coming out of the optional PoE module. However, if a power plug is connected to the DC power jack, the PoE is disabled. Reset button, S4 The reset push-button S4, resets the module and the peripherals on the development board. A pushbutton allows manual reset by connecting POR# or optionally RSTIN# to ground. Power button, S11 The power button S11, generates a Turn On/Turn Off interrupt to the MC13892 power management device on the module. ConnectCore for i.MX51 Hardware Reference Manual 67 About the development board Switches and push-buttons The Turn Off event does not directly power off the module. The module is powered off by the processor's response to this interrupt. The software can configure a user initiated power down, or a transition to a low power off mode by pressing this power button. When in Off mode or in low power mode, the module can be powered via the Turn On event generated by pressing the Power button. User buttons, S3 and S5 Use the user push-buttons to interact with the applications running on the ConnectCore for i.MX51 module. Use these module signals to implement the push-buttons: Signal name Button GPIO used DISPB2_SER_DIO/GPIO3_6/USER_KEY1 S3 GPIO3_8 GPIO1_1/SD1_WP#/SPI_MISO/USER_KEY2 S5 GPIO1_1 GPIO3_6 is used in User Button S3 and also in the Digital I/O connector for Digital I/O7. Ident button, S10 The Ident push-button S10 is associated to the commissioning input of the Digi XBee modules. This input provides a variety of simple functions to aid in deploying devices in a network. For a deeply description of this functionality please refer to the Digi XBee modules documentation. Legend for multi-position switches Switches S6, S7, S8 and S9 are multi-pin switches. In the description tables for these switches, the position is designated as S[switch number].[pin number]. For example, position 1 on switch S6 is specified as S6.1. UART 1 switch, S6 Use S6 to configure the line interface for serial port 1 MEI: Switch Pin Function S6.1 On = RS232 transceiver enabled RS4xx transceiver disabled Off = RS232 transceiver disabled RS4xx transceiver enabled ConnectCore for i.MX51 Hardware Reference Manual Comments 68 About the development board Switches and push-buttons Switch Pin Function Comments S6.2 On = Auto Power Down enabled Off = Auto Power Down disabled Auto Power Down is not supported on this board. This signal is only accessible to permit the user to completely disable the MEI interface for using the signals for other purposes. To disable the MEI interface, go into RS232 mode (S6.1 = ON) and activate the Auto Power Down feature (S6.2 = ON) - be sure that no cable is connected to connector X30. S6.3 On = 2-wire interface (RS4xx) Off = 4-wire interface (RS422) S6.4 On = Termination ON Off = No termination UART 2 switch, S7 Use S7 to configure the line interface for serial port 2 (console): Switch Pin Function Comments S7.1 On = Power save Off = Normal Operation If there is a valid RS232 signal at receiver inputs the UART will be in normal operation mode. If there is not a valid RS232 signal at receiver inputs the UART will be in shutdown mode. S7.2 On = Shutdown Off = Normal Operation Shutdown is the highest priority functionality. If switch S7.2 = ON, the UART 2 will be in shutdown mode independently of the position of S7.1. Boot configuration switches, S8 and S9 Use S8 to configure the source of the boot code when S9 is configures in internal boot, or to configure the source of the serial download when S9 is configured in serial downloader. SwitchPin Function Comments S8.1 On = Boot from expansion device Off = Boot from NAND Flash Applies only if switch S9 is configured in internal boot mode ConnectCore for i.MX51 Hardware Reference Manual 69 About the development board Switches and push-buttons SwitchPin Function Comments S8.2 On = Reserved Off = Boot from microSD™ Applies only if switch S9 is configured in internal boot mode and S8.1 is configured to boot from expansion device S8.3 / S8.4 On / On = UART1 (MEI) If S9 is configured in serial boot loader S8.3 / S8.4 On / Off = UART2 (Console) If S9 is configured in serial boot loader S8.3 / S8.4 Off / On = UART3 (TTL) If S9 is configured in serial boot loader S8.3 / S8.4 Off / Off = Reserved If S9 is configured in serial boot loader Use S9 to configure the module boot mode: Switch Pin Function Comments S9.1 / S9.2 Off / Off Internal Boot configured by switch S8 S9.1 / S9.2 Off / On Reserved S9.1 / S9.2 On / Off Internal Boot configured by fuse block S9.1 / S9.2 On / On Serial downloader For a detailed description of the ConnectCore for i.MX51 boot mode functionality, refer to the Freescale i.MX51 Processor Hardware Reference Manual. ConnectCore for i.MX51 Hardware Reference Manual 70 About the development board Jumpers Jumpers Battery enable, J5 When J5 is set, the development board can be powered by an external battery connected to J23. Module power source, P29 When set on positions 1-2, the 3.3V supply of the development board is generated on the +3.3V power regulator (U50). When set on positions 2-3, the +3.3V supply of the development board is generated on the module. LED 1, J16 When set, enables the User LED 1 (LE51) to show the status of this signal (on if low). ConnectCore for i.MX51 Hardware Reference Manual 71 About the development board Jumpers LED 2, J9 When set, enables the User LED 2 (LE49) to show the status of this signal (on if low). Button 1, J28 When set, enables the User Button 1 (S3). Button 2, J29 When set, enables the User Button 2 (S5). UART3 / XBee selection, J30 and J31 The UART 3 port is shared on the development board between the XBee module socket and the UART 3 connector (X19). When J30 and J31 are set to positions 1-2, the XBee module socket can be used. When J30 and J31 are set to positions 2-3, the UART 3 on the connector (X19) can be used. WLAN disable, J17 When set, this jumper disables the WLAN interface on the module. Touch selection, J20 When set, an external SPI touch screen controller is configured for the LCD 1 interface and the internal analog touch screen controller (on module) is configured for the LCD 2 interface. When removed, an internal touch screen controller is configured for the LCD 2 interface, and the internal analog touch screen controller (on module) is configured for the LCD 1 interface. Coincell enable, J3 When set, this jumper supplies the real time clock with +3V from the lithium coin cell battery, even if the board is switched off. JTAG mod., J4 When set, this jumper disables the JTAG interface for the ConnectCore for i.MX51. When removed, the JTAG interface is enabled. ConnectCore for i.MX51 Hardware Reference Manual 72 About the development board LEDs LEDs WLAN, LE12 LED indicating WLAN operational status. Power LEDs, LE3, LE4, LE6 and LE7 All power LEDs are red. The power supplies must be present: n LE3 ON indicates that +9VDC / +30VDC power is present n LE4 ON indicates that battery power is present n LE6 ON indicates that +5VDC power for the development board is present n LE7 ON indicates that +3.3VDC power for the development board is present ConnectCore for i.MX51 Hardware Reference Manual 73 About the development board Power LEDs, LE3, LE4, LE6 and LE7 User LEDs, LE49 and LE51 The user LEDs are controlled through applications running on the ConnectCore for i.MX51 module. You may use these module signals to implement the LEDs: Signal Name LED GPIO Used NANDF_RB2/MII_COL/SP12_SCLK/GPIO3_10 LE51 GPIO3_10 NANDF_RB1/PATA_IORDY/SPI2_RDY/GPIO3_9 LE49 GPIO3_9 Serial status LEDs The development board has two sets of serial port LEDs - four for serial port 1 and four for serial port 2. The LEDs are connected to the TTL side of the RS232 or RS4xx transceivers. n Green means corresponding signal high n Red means corresponding signal low n The intensity and color of the LED will change when the voltage is switching UART 1 status LEDs LED Reference Function RED GREEN LE60 LE45 TXD LE61 LE46 RXD# LE62 LE47 RTS# LE63 LE48 CTS# UART 2 status LEDs LED Reference Function RED GREEN LE41 LE40 TXD LE57 LE42 RXD LE58 LE43 RTS# LE59 LE44 CTS# XBee Associate, LE50 This LED is connected to the Associate output of the Digi XBee module. This LED provides information of the device's network status and diagnostics information. For a more in-depth description of this LED, refer to the Digi XBee modules documentation available at www.digi.com. ConnectCore for i.MX51 Hardware Reference Manual 74 About the development board Audio interface Audio interface The development board provides an audio interface with a line input channel, a line-output channel and a microphone input. A Wolfson WM8753L audio CODEC is used in the development board. This audio CODEC is controlled through the I2C port 2 of the ConnectCore for i.MX51. Digital audio data is sent/received between the audio CODEC and the ConnectCore for i.MX51 through an I 2S interface (AUD3 channel of the i.MX51 AUDMUX). The I2C device address of the audio CODEC is the following: Interface I2C Address (7 bits) Audio CODEC (WM8753L) 0 x 1A Three stereo audio jacks are provided on the development board: n J18 connector for LINE+OUT n J12 connector for LINE+IN n J15 connector for microphone ConnectCore for i.MX51 Hardware Reference Manual 75 About the development board Audio interface Line-out connector pinout, J18 Pin Signal 1 GND 2 LINE-OUT-RIGHT 3 LINE-OUT-LEFT 4 HEADPHONE-DETECT 5 - Line-in connector pinout, J12 Pin Signal 1 GND 2 LINE-IN-RIGHT 3 LINE-IN-LEFT 4 GND 5 GND Microphone connector pinout, J15 Pin Signal 1 GND 2 MIC-IN 3 MICBIAS 4 GND 5 GND ConnectCore for i.MX51 Hardware Reference Manual 76 About the development board Coin cell battery Coin cell battery Battery Holder Battery Vertical Coin-Cell Holder for CR2032 Battery Lithium coin cell, CR2032, 200mAh Keystone 1065 Renata CR2032N Ettinger 15.61.602 Panasonic CR2032N The development board provides a coin cell battery to back up the module’s integrated RTC while main power is disconnected. Jumper J3 controls if the coin cell battery power is available. ConnectCore for i.MX51 Hardware Reference Manual 77 About the development board Camera interfaces Camera interfaces The development board provides two camera interfaces connected to the camera sensor interfaces of the ConnectCore for i.MX51 CPU. The I2C bus of the ConnectCore for i.MX51CPU is used to configure and control the two cameras. The I2C device addresses of the Digi camera application kits (CC-ACC0MT9V111) are the following: Interface I2C Address (7 bits) Camera 1 0 x 5C Camera 2 0 x 48 Two 2 x 10 pin headers, X15 and X17, are provided on the development board for connecting two Digi camera application kits (optional) or customer specific hardware. n X15 connector for camera 1 n X17 connector for camera 2 ConnectCore for i.MX51 Hardware Reference Manual 78 About the development board Camera interfaces X15 pinout Pin Signal Pin Signal 1 +2.775V 2 GND 3 CSI1_D12 4 CSI1_D13 5 CSI1_D14 6 CSI1_D15 7 CSI1_D16 8 CSI1_D17 9 CSI1_D18 10 CSI1_D19 11 CSI1_MCLK 12 CSI1_PIXCLK 13 CSI1_HSYNC/GPIO3_15 14 CSI1_VSYNC/GPIO3_14 15 GPIO1_2/I2C2_SCL 16 GPIO1_3/I2C2_SDA 17 CSI1_D10 18 CAMRESET1#/GPIO3_13/CSI1_D19 19 GND 20 CSI1_D11 X17 pinout Pin Signal Pin Signal 1 +2.775V 2 GND 3 CSI2_D12/GPIO4_9 4 CSI2_D13/GPIO4_10 5 CSI2_D14 6 CSI2_D15 7 CSI2_D16 8 CSI2_D17 9 CSI2_D18/GPIO4_11 10 CSI2_D19/GPIO4_12 11 CSI1_MCLK 12 CSI2_PIXCLK/GPIO4_15 13 CSI2_HSYNC/GPIO4_14 14 CSI2_VSYNC/GPIO4_13 15 GPIO1_2/I2SC2_SCL 16 GPIO1_3/I2C2_SDA 17 - 18 CAMRESET2#/APIO3_7 19 GND 20 - ConnectCore for i.MX51 Hardware Reference Manual 79 About the development board Digital IO interface Digital IO interface Digital I/O connector, X45 The development board provides a 3.81mm green terminal block, X45, for accessing eight on chip digital GPIOs of the i.MX51 CPU. Pin Signal Voltage Level 1 GPIO3_11/SPI2_MISO/NANDF_RB3 +3.15V 2 GPIO3_18/NANDF_CS2# +3.15V 3 GPIO3_9/SPI2_RDY/USER_LED2/NANDF_RB1 +3.15V 4 GPIO3_10/SPI2_SCLK/USER_LED1/NANDF_RB2 +3.15V 5 GPIO3_20/NANDF_CS4# +3.15V ConnectCore for i.MX51 Hardware Reference Manual 80 About the development board Ethernet 1 interface Pin Signal Voltage Level 6 GPIO3_21/NANDF_CS5# +3.15V 7 GPIO3_22/NANDF_CS6# +3.15V 8 GPIO3_6/DISPB2_SER_DIO/USER_KEY1 +2.775 9 GND 0V On the development board, GPIO3_6 is connected to USER_KEY1. When using this signal as digital I/O, the USER_KEY1 should not be used. Note The digital I/O interface is not protected against ESD, over voltage or inverse polarity. Care must be taken when using these signals. WARNING! X45 pins 1, 3, and 4 should not be connected to GND during boot time if you intend to boot from NAND flash. Ethernet 1 interface ConnectCore for i.MX51 Hardware Reference Manual 81 About the development board Ethernet 1 interface The development board provides one 8-wire RJ-45 jack with integrated 1:1 transformers and link/activity LEDs for the Ethernet 1 interface. This interface is attached to the Fast Ethernet controller (FEC) of the i.MX51. The ConnectCore for i.MX51 module provides a 10/100 Ethernet PHY chip for this interface. The Ethernet 1 RJ-45 connector also supports 802.3af (PoE). Ethernet 1, RJ-45 connector X7 The table below shows the pinout of the Ethernet 1 RJ-45 connector. Pin Signal 802.3af End-Span (mode A) 802.3ad Mid-Span (mode B) 1 TXD+ Negative VPort Transmit data+ 2 TXD- Negative VPort Trandmit data- 3 RXD+ Positive VPort Receive data+ 4 EPWR+ Positive VPort Power from switch+ 5 EPWR+ Positive VPort Power from switch+ 6 RXD- 7 EPWR- Negative VPort Power from switch- 8 EPWR- Negative VportP Power from switch- Positive VPort Description Receive data- The table below shows the description of the Ethernet 1 LEDs. LED Description Yellow Network activity (speed): Green n Flashing - indicates network traffic n Off - no network traffic Network link: n On - indicates an active network link n Off - no network link present ConnectCore for i.MX51 Hardware Reference Manual 82 About the development board Ethernet 2 interface Ethernet 2 interface The development board provides a 2x20 expansion connector for connecting an optional Digi Ethernet adapter board (100M_ETHADPT) or customer specific setup. The Ethernet 2 interface is provided by an optional on-module Ethernet MAC/PHY. Note The ConnectCore for i.MX51 modules included in the development kits are supporting the Ethernet 2 interface. Ethernet 2, connector J17 The table below shows the pinout of the Ethernet 2 expansion connector. Pin Signal Pin Signal 1 GND 2 GND ConnectCore for i.MX51 Hardware Reference Manual 83 About the development board Ethernet 2 interface Pin Signal Pin Signal 3 ETH2_TX+ 4 ETH2_RX+ 5 ETH2_TX- 6 ETH2_RX- 7 GND 8 GND 9 Reserved (ETH2_DC+) 10 Reserved (ETH2_DD+) 11 Reserved (ETH2_DC-) 12 Reserved (ETH2_DD-) 13 GND 14 GND 15 ETH2_ACTIVITY# 16 ETH2_LINK# 17 - 18 - 19 - 20 - 21 - 22 - 23 - 24 - 25 - 26 - 27 - 28 - 29 - 30 - 31 - 32 - 33 - 34 - 35 - 36 - 37 - 38 - 39 - 40 - ConnectCore for i.MX51 Hardware Reference Manual 84 About the development board HDMI interface HDMI interface The development board provides an HDMI interface connected to the display interface 1 of the ConnectCore for i.MX51 CPU. An Analog Devices AD9389 HDMI transmitter is used in the development board. This HDMI transmitter is controlled through the I 2C port 2 of the ConnectCore for i.MX51. The I 2C device address of the HDMI transmitter is the following: Interface I2C Address (7 bits) HDMI transmitter (AD9389)2 0 x 39 HDMI connector, J19 The development board provides an HDMI connector, J19. The HDMI interface is connected to the Display 1 interface of the ConnectCore for i.MX51 CPU. The table below shows the pinout of the HDMI connector: ConnectCore for i.MX51 Hardware Reference Manual 85 About the development board HDMI interface Pin Signal 1 HDMI_TX2+ 2 GND 3 HDMI_TX2- 4 HDMI_TX1+ 5 GND 6 HDMI_TX1- 7 HDMI_TX0+ 8 GND 9 HDMI_TX0- 10 HDMI_TXC+ 11 GND 12 HDMI_TXC- 13 NC 14 NC 15 HDMI_SCL 16 HDMI_SDA 17 GND 18 +5V 19 HOTPLUG_DET ConnectCore for i.MX51 Hardware Reference Manual 86 About the development board I2C interface I2C interface I2C header, P22 Pin header P22 provides access to the i.MX51 I 2C port 2 interface. The I2C port 2 is connected to the following headers/interfaces on the development board. Interface I2C Address (7 bits) I2C Header - Camera 1 0 x 5 C (Digi CC-ACC-MT9V111) Camera 2 0 x 4 8 (Digi CC-ACC-MT9V111) HDMI Transmitter 0 x 39 LCD 1 - LCD 2 - ConnectCore for i.MX51 Hardware Reference Manual 87 About the development board I2C interface Interface I2C Address (7 bits) Audio CODEC 0 x 1A Peripheral connector - I 2C port 2 is connected to the following interfaces of the ConnectCore for i.MX51 module: Interface I2C Address (7 bits) Accelerometer (MMA7455L) 0 x 1D The table below provides the pinout of connector P22: Pin Function Defaults to 1 I2C_SDA GPIO1_3 2 +2.775V 3 I2_SCL 4 GND GPIO1_2 By default, this interface is configured to operate in GPIO mode. ConnectCore for i.MX51 Hardware Reference Manual 88 About the development board JTAG interface JTAG interface Standard JTAG ARM connector, X13 The standard JTAG ARM connector is a 20-pin header and can be used to connect development tools (ICS) such as Ronetix PEEDI or other. Pin Function Pin Function 1 +1.8V 2 +3.3V 3 JTAG_TRST# 4 GND 5 JTAG_TDI 6 GND 7 JTAG_TMS 8 GND 9 JTAG_TCK 10 GND 11 Reserved (RTCK) 12 GND ConnectCore for i.MX51 Hardware Reference Manual 89 About the development board LCD interfaces Pin Function Pin Function 13 JTAG_TDO 14 GND 15 JTAG_RESET# 16 GND 17 JTAG_DE# 18 GND 19 GND 20 GND Note In order to enable ETM functionality, Digi offers an optional ETM adapter board (sold separately, Digi P/N CC-ACC-MX51-ETM). Please contact us. LCD interfaces The development board provides two 2x40 pin, 1.27mm connectors for accessing a Digi-provided LCD application boards (CC-ACC0LCDW-70) or a user defined LCD application board. ConnectCore for i.MX51 Hardware Reference Manual 90 About the development board LCD interfaces n P1: corresponds to i.MX51 display interface 1 n P2: corresponds to i.MX51 display interface 2 LCD 1 connector, P1 This connector provides access to the following capabilities: n 18-bit (RGB x 8bit) LCD n SPI bus for a touch screen controller n Touch screen (on-module, shared with LCD2) n Interrupt input for touch screen n I 2C bus n 2 x GPIO n +3.3VDC supply and a 9-30VDC supply P1 pinout The table below shows the pinout of the LCD1 connector, P1: Pin Function Pin Function 1 LCD1_DATA16 (R0) 2 LCD1_DATA17 (R1) 3 LCD1_DATA12 (R2) 4 LCD1_DATA13 (R3) 5 LCD1_DATA14 (R4) 6 LCD1_DATA15 (R5) 7 LCD1_DATA16 (R6) 8 LCD1_DATA17 (R7) 9 - 10 - 11 - 12 - 13 GND 14 GND 15 LCD1_DATA10 (G0) 16 LCD1_DATA11 (G1) 17 LCD1_DATA6 (G2) 18 LCD1_DATA7 (G3) 19 LCD1_DATA8 (G4) 20 LCD1_DATA9 (G5) 21 LCD1_DATA10 (G6) 22 LCD1_DATA11 (G7) 23 - 24 - 25 - 26 - 27 GND 28 GND 29 LCD1_DATA4 (B0) 30 LCD1_DATA5 (B1) 31 LCD1_DATA0 (B2) 32 LCD1_DATA1 (B3) 33 LCD1_DATA2 (B4) 34 LCD1_DATA3 (B5) ConnectCore for i.MX51 Hardware Reference Manual 91 About the development board LCD interfaces Pin Function Pin Function 35 LCD1_DATA4 (B6) 36 LCD1_DATA5 (B7) 37 - 38 - 39 - 40 - 41 GND 42 GND 43 LCD1_BIAS 44 LCD1_PCLK 45 LCD1_PWREN# 46 GND 47 LCD1_VSYNC 48 LCD1_HSYNC 49 - 50 - 51 - 52 - 53 - 54 - 55 GND 56 GND 57 TOUCH_X1 58 TOUCH_Y1 59 TOUCH_X2 60 TOUCH_Y2 61 I2C2_SDA 62 I2C2_SCL 63 LCD_SPI_SS# 64 SPI1_CLK 65 SPI1_MOSI 66 SPI1_MISO 67 RESET# 68 LCD1_TOUCH_INT/EXT# 69 LCD1_GPIO1 70 LCD1_GPIO2 71 LCD_PENIRQ 72 GND 73 +3.3V 74 +3.3V 75 +9-30V 76 +9-30V 77 +9-30V 78 +9-30V 79 - 80 - LCD 2 connector, P2 This connector provides access to the following capabilities: n 18-bit (RGB x 8bit) LCD n SPI bus for a touch screen controller n Touch screen (on-module, shared with LCD1) n Interrupt input for touch screen n I 2C bus ConnectCore for i.MX51 Hardware Reference Manual 92 About the development board n 2 x GPIO n +3.3VDC supply and a 9-30VDC supply LCD interfaces P2 pinout The table below shows the pinout of the LCD2 connector, P2: Pin Function Pin Function 1 LCD2_DATA16 (R0) 2 LCD2_DATA17 (R1) 3 LCD2_DATA12 (R2) 4 LCD2_DATA13 (R3) 5 LCD2_DATA14 (R4) 6 LCD2_DATA15 (R5) 7 LCD2_DATA16 (R6) 8 LCD2_DATA17 (R7) 9 - 10 - 11 - 12 - 13 GND 14 GND 15 LCD2_DATA10 (G0) 16 LCD2_DATA11 (G1) 17 LCD2_DATA6 (G2) 18 LCD2_DATA7 (G3) 19 LCD2_DATA8 (G4) 20 LCD2_DATA9 (G5) 21 LCD2_DATA10 (G6) 22 LCD2_DATA11 (G7) 23 - 24 - 25 - 26 - 27 GND 28 GND 29 LCD2_DATA4 (B0) 30 LCD2_DATA5 (B1) 31 LCD2_DATA0 (B2) 32 LCD2_DATA1 (B3) 33 LCD2_DATA2 (B4) 34 LCD2_DATA3 (B5) 35 LCD2_DATA4 (B6) 36 LCD2_DATA5 (B7) 37 - 38 - 39 - 40 - 41 GND 42 GND 43 LCD2_BIAS 44 LCD2_PCLK 45 LCD2_PWREN# 46 GND 47 LCD2_VSYNC 48 LCD2_HSYNC 49 - 50 - 51 - 52 - ConnectCore for i.MX51 Hardware Reference Manual 93 About the development board LCD interfaces Pin Function Pin Function 53 - 54 - 55 GND 56 GND 57 TOUCH_X1 58 TOUCH_Y1 59 TOUCH_X2 60 TOUCH_Y2 61 I2C2_SDA 62 I2C2_SCL 63 LCD_SPI_SS# 64 SPI1_CLK 65 SPI1_MOSI 66 SPI1_MISO 67 RESET# 68 LCD2_TOUCH_INT/EXT# 69 LCD2_GPIO1 70 LCD2_GPIO2 71 LCD_PENIRQ 72 GND 73 +3.3V 74 +3.3V 75 +9-30V 76 +9-30V 77 +9-30V 78 +9-30V 79 LED_BCK+ 80 LED_BCK- ConnectCore for i.MX51 Hardware Reference Manual 94 About the development board MicroSD™ card interface MicroSD™ card interface MicroSD connector, X14 The development board provides one MicroSD card connector, X14. This interface is connected to the enhanced Secured Digital Host controller 1 (eSDHC1) of the i.MX51 CPU. The MicroSD connector used on the development board does not provide a card detect pin (pin-9 and pin-10 are connected to chassis). A hot-plug insertion or removal is not possible with this connector. The following table shows the pinout of the MicroSD connector: ConnectCore for i.MX51 Hardware Reference Manual 95 About the development board MicroSD™ card interface Pin Signal 1 SD_DATA2 2 SD_DATA3 3 SD_CMD 4 +3.3V 5 SD_CLK 6 GND 7 SD_DATA0 8 SD_DATA1 9 SD_CD (Connected to chassis) 10 SD_CD (Connected to chassis) ConnectCore for i.MX51 Hardware Reference Manual 96 About the development board Module connectors and signal rails Module connectors and signal rails Module connectors See the Module pinout for related information. Signal rails, J25 and J26 The development board provides two 2x80 pin signal rails, J25 and J26. These connectors provide most of the signals available on the module connectors and can be used for measurement or development purposes. n J25 corresponds to module connector J1 n J26 corresponds to module connector J2 ConnectCore for i.MX51 Hardware Reference Manual 97 About the development board J25 pinout J25 pinout Pin Signal Pin Signal 1 CSI1_D8 2 CSI1_D9 3 CSI1_D10 4 CSI1_D11 5 CSI1_D12 6 CSI1_D13 7 CSI1_D14 8 CSI1_D15 9 CSI1_D16 10 CSI1_D17 11 CSI1_D18 12 CSI1_D19 13 CSI1_VSYNC/GPIO3_14 14 CSI1_HSYNC/GPIO3_15 15 CSI1_PIXCLK 16 CSI1_MCLK 17 WLAN_TDO 18 WLAN_TCK 19 WLAN_TDI 20 WLAN_TMS 21 WLAN_LED 22 RS_BT_PRIORITY 23 RS_WLAN_ACTIVE 24 RS_BT_ACTIVE 25 +2.775V 26 WLAN_DISABLE# 27 +2.775V 28 +2.775V 29 MC13892_GPO1 30 +2.775V 31 PMIC_PWRON1 32 PMIC_STDBY_REQ 33 PMIC_INT_REQ 34 PWRGTDRV1 35 CHRGLED 36 PWRGTDRV2 37 CHRGSE1# 38 VCC_COINCELL 39 VLIO 40 +5V_IN 41 VLIO 42 +5V_IN 43 VLIO 44 +5V_IN 45 DISP2_SER_DIN/GPIO3_5 46 DISPB2_SER_DIO/GPIO3_6 47 DISPB2_SER_RS/GPIO3_8 48 DISPB2_SER_CLK/GPIO3_7 49 DISP2_DATA0/MII_RXD3/USBH3_CLK 50 DISP2_DATA1/MII_RX_ER/USBH3_DIR 51 DISP2_DATA2 52 DISP2_DATA3 53 DISP2_DATA4 54 DISP2_DATA5 55 DISP2_DATA6/MII_TXD1/USBH3_STP 56 DISP2_DATA7/MII_TXD2/USBH3_NXT ConnectCore for i.MX51 Hardware Reference Manual 98 About the development board J25 pinout Pin Signal Pin Signal 57 DISP2_DATA8/MII_TXD3/USBH3_ DATA0 58 DISP2_DATA9/MII_TXEN/USBH3_DATA1 59 DISP2_DATA10/MII_COL/USBH3_ DATA2 60 DISP2_DATA11/MII_RX_CLK/USBH3_ DATA3 61 DISP2_DATA12/MII_RX_DV/USBH3_ DATA4 62 DISP2_DATA13/MII_TX_CLK/USBH3_ DATA5 63 DISP2_DATA14/MII_RXD0/USBH3_ DATA6 64 DISP2_DATA15/MII_TXD0/USBH3_ DATA7 65 D12_PIN2/MII_MDC 66 D12_DISP_CLK/MII_RXD1 67 D12_PIN4/MII_CRS 68 D12_PIN3/MII_MDIO 69 IOR 70 IOG 71 IOR_BACK 72 IOG_BACK 73 IOB 74 JTAG_TRST# 75 IOB_BACK 76 JTAG_MOD# 77 JTAG_TCK 78 JTAG_DE# 79 JTAG_TMS 80 RESET_IN# 81 JTAG_TDI 82 +1.8V 83 JTAG_TDO 84 EIM_CS1/GPIO2_26 85 POR# 86 EIM_CS3/GPIO2_28 87 EIM_CS0/GPIO2_25 88 EIM_CS5_LAN9221_CS#/GPIO2_30 89 EIM_CS2/GPIO2_27 90 EIM_LBA/GPIO3_1 91 EIM_CS4/GPIO2_29 92 EIM_DA1/TRACE17 93 EIM_DTACK/GPIO2_31 94 EIM_DA3/TRACE19 95 EIM_DA0/TRACE16 96 EIM_DA5/TRACE21 97 EIM_DA2/TRACE18 98 EIM_DA7/TRACE23 99 EIM_DA4/TRACE20 100 EIM_DA9/TRACE25 101 EIM_DA6/TRACE22 102 EIM_DA11/TRACE27 103 EIM_DA8/TRACE 24 104 EIM_DA13/TRACE29 105 EIM_DA10/TRACE26 106 EIM_DA15/TRACE31 107 EIM_DA12/TRACE28 108 EIM_DA17/TRACE1 109 EIM_DA14/TRACE30 110 EIM_DA19/TRACE3 ConnectCore for i.MX51 Hardware Reference Manual 99 About the development board J26 pinout Pin Signal Pin Signal 111 EIM_DA16/TRACE0 112 EIM_DA21/TRACE5 113 EIM_DA18/TRACE2 114 EIM_DA23/TRACE7 115 +3.15V 116 EIM_DA25/TRACE9 117 EIM_DA20/TRACE4 118 EIM_DA27/TRACE11 119 EIM_DA22/TRACE6 120 EIM_DA29/TRACE13 121 EIM_DA24/TRACE8 122 EIM_DA31/TRACE15 123 EIM_DA26/TRACE10 124 EIM_A17/GPIO2_11 125 EIM_DA28/TRACE12 126 EIM_A19/GPIO2_13 127 EIM_DA30/TRACE14 128 EIM_A21/GPIO2_15 129 EIM_A16/GPIO2_10 130 EIM_A23/GPIO2_17 131 EIM_A18/GPIO2_12 132 EIM_A25/GPIO2_19 133 EIM_A20/GPIO2_14 134 EIM_A27/GPIO2_21 135 EIM_A22/GPIO2_16 136 EIM_OE#/GPIO2_24 137 EIM_A24/GPIO2_18 138 EIM_RW# 139 EIM_A26.GPIO2_20 140 EIM_CRE/GPIO3_2 141 EIM_EB0 142 EIM_WAIT 143 EIM_EB1 144 GND 145 EIM_EB2/GPIO2_22/TRCTL 146 EIM_BCLK 147 EIM_EB3/GPIO2_23/TRCLK 148 GND 149 NANDF_ALE/GPIO3_5 150 NAND_RE#/SD3_DATA1/GPIO3_4 151 NANDF_WP#/SD3_DATA2/GPIO3_7 152 NANDF_CLE/GPIO3_6 153 NANDF_RB1_SP12_RDY/GPIO3_9 154 NANDF_RB0/SD3_DATA3/GPIO3_8 155 NANDF_RB3/SP12_MISO/GPIO3_11 156 NANDF_R2/SP12_SCLK/GPIO3_10 157 - 158 - 159 - 160 - J26 pinout Pin Signal Pin Signal 1 DISP1_DAT0 2 DISP1_DAT1 3 DISP1_DAT2 4 DISP1_DAT3 ConnectCore for i.MX51 Hardware Reference Manual 100 About the development board J26 pinout Pin Signal Pin Signal 5 DISP1_DAT4 6 DISP1_DAT5 7 DISP1_DAT6 8 DISP1_DAT7 9 DISP1_DAT8 10 DISP1_DAT9 11 DISP1_DAT10 12 DISP1_DAT11 13 DISP1_DAT12 14 DISP1_DAT13 15 DISP1_DAT14 16 DISP1_DAT15 17 DISP1_DAT16 18 DISP1_DAT17 19 DISP1_DAT18 20 DISP1_DAT19 21 DISP1_DAT20 22 DISP1_DAT21 23 DISP1_DAT22 24 DISP1_DAT23 25 DI1_PIN2 26 DI1_DISP_CLK 27 DI1_PIN11/GPIO3_0 28 DI1_PIN3 29 DI1_PIN13/GPIO3_2 30 DI1_PIN12/GPIO3_1 31 DI1_PIN15 32 DI_GP1 33 DI_GP2 34 DI_GP3/MII_TX_ER 35 DI_GP4/MII_RXD2 36 DI1_D0_CS/GPIO3_3 37 DI1_D1_CS/GPIO3_4 38 ADIN5 39 TOUCH_X1 40 ADIN6 41 TOUCH_X2 42 ADIN7 43 TOUCH_Y1 44 ADC_GND 45 TOUCH_Y2 46 ADTRIG 47 SWBST 48 - 49 LEDR 50 - 51 LEDG 52 - 53 LEDB 54 - 55 CSI2_D12/GPIO4_9 56 CSI2_D13/GPIO4_10 57 CSI2_D14 58 CSI2_D15 59 CSI2_D16 60 CSI2_D17 61 CSI2_D18/GPIO4_11 62 CSI2_D19/GPIO4_12 ConnectCore for i.MX51 Hardware Reference Manual 101 About the development board J26 pinout Pin Signal Pin Signal 63 CSI2_VSYNC/GPIO4_13 64 CSI2_HSYNC/GPIO4_14 65 CSI2_PIXCLK/GPIO4_15 66 GPIO1_8/USB_PWR 67 GPIO1_7/MMA7455LR_INT1 68 GPIO1_2/PWM1/I2C2_SCL 69 GPIO1_6/MMA7455LR_INT2 70 GPIO1_3/PWM2/I2C2_SDA 71 CKIH1 72 CLK32K_PER 73 SD2_DATA0/SD1_DATA4/SPI_MOSI 74 CKIH2 75 SD2_DATA1/SD1_DATA5 76 SD2_CLK/I2C1_SDA/SPI_SCLK 77 SD2_DATA2/SD1/DATA6 78 SD2_CMD/I2C1_SCL/SPI_MOSI 79 SD2_DATA3/SD1_DATA7/SPI_SS2 80 KEY_COL0 81 ROW0 82 KEY_COL1 83 ROW1 84 KEY_COL2 85 ROW2 86 KEY_COL3 87 ROW3 88 KEY_COL5/UART3_CTS#/I2C2_SDA 89 KEY_COL4/UART3_RTS#/I2C2_SCL 90 GPIO1_0/SD1_CD#/SPI_SS2 91 OWIRE_LINE/GPIO1_24 92 GPIO1_1/SD1_WP#/SPI_MISO 93 SC1_CMD/AUD5_RXFS/SPI_MOSI 94 SD1_DAT0/AUD5_TXD/SPI_MOSI 95 SD1_CLK/AUD5_RXC/SPI_SCLK 96 SD1_DATA1/AUD5_RXD 97 WDOG1#/GPIO1_4 98 SD1_DATA2/AUD5_TXC 99 CSPI1_MOSI/I2C1_SDA/GPIO4_22 100 SD1_DATA3/AUD5_TXFS/SPI_SS1 101 CSPI1_MISO/AUD4_RXD/GPIO4_23 102 CSPI1_SS0_PMIC/AUD4_TXC/GPIO4_24 103 CSPI1_SCLK/I2C1_SDA/GPIO4_27 104 CSPI1_SS1/AUD4_TXD/GPIO4_25 105 UART1_RXD/GPIO4_28 106 CSPI1_RDY/AUD4_TXFS/GPIO4_26 107 UART1_TXD/PWM2/GPIO4_29 108 UART1_RTS#/GPIO4_30 109 UART2_RXD/GPIO1_20 110 UART1_CTS#/GPIO4_31 111 UART2_TXD/GPIO1_21 112 UART3_RXD/UART1_DTR#/GPIO1_22 113 USBH1_DATA2/UART2_TXD/GPIO1_13 114 UART3_TXD/UART1_DSR#/GPIO_23 115 USBH1_DATA4/SPI_SS0/GPIO1_15 116 USBH1_DATA0/UART2_CTS#/GPIO1_11 117 USBH1_DATA6/SPI_SS2/GPIO1_17 118 USBH1_DATA1/UART2_RXD/GPIO1_12 119 USBH1_DIR/SPI_MOSI/GPIO1_26/I2C2_ SDA 120 USBH1_DATA3/UART2_RTS#/GPIO1_14 ConnectCore for i.MX51 Hardware Reference Manual 102 About the development board J26 pinout Pin Signal Pin Signal 121 USBH1_STP/SPI_RDY/GPIO1_27 122 USBH1_DATA5/SPI_SS1/GPIO1_16 123 USBH1_NXT/SPI_MISO/GPIO1_28 124 USBH1_DATA7/SPI_SS3/SPI2_SS3/GPIO1_ 18 125 AUD3_BB_TXD/GPIO4_18 126 USBH1_CLK/SPI_SCLK/GPIO1_25/I2C2_ SCL 127 AUD3_BB_RXD/UART3_RXD/GPIO4_19 128 HS_I2C_SCL/GPIO4_16 129 AUD3_BB_CK/GPIO4_20 130 HS_I2C_SDA/GPIO4_17 131 +3.3V MOD 132 AUD3_BB_FS/UART3_TXD/GPIO4_21 133 NANDF_D0/PATA_D0/SD4_DATA7/GPIO4_ 8 134 +3.3V 135 NANDF_D2/PATA_D2/SD4_DATA5/GPIO4_ 6 136 NANDF_D1/PATA_D1/SD4_DATA6/GPIO4_7 137 NANDF_D4/PATA_D4/SD4_CD/GPIO4_4 138 NANDF_D3/PATA_D3/SD4_DATA4/GPIO4_5 139 NANDF_D6/PATA_D6/SD4_LCTL/GPIO4_2 140 NANDF_D5/PATA_D5/SD4_WP#/GPIO4_3 141 NANDF_D8/PATA_D8/GPIO4_0/SD3_ DATA0 142 NANDF_D7/PATA_D7/GPIO4_1 143 NANDF_D10/PATA_D10/GPIO3_30/SD3_ D2 144 NANDF_D9/PATA_D9/GPIO3_31/SD3_D1 145 NANDF_D12/PATA_D12/GPIO3_28/SD3_ D4 146 NANDF_D11/PATA_D11/GPIO3_29/SD3_D3 147 NANDF_D14/PATA_D14/GPIO3_26/SD3_ D6 148 NANDF_D13/PATA_D13/GPIO3_27/SD3_D5 149 NANDF_CS0#/GPIO3_16 150 NANDF_D15/PATA_D15/GPIO3_25/SD3_D7 151 NANDF_CS2#/PATA_CS0#/GPIO3_18 152 NANDF_CS1#/GPIO3_17 153 NANDF_CS4#/PATA_DA0/GPIO3_20 154 NANDF_CS3#/PATA_CS1#/GPIO3_19 155 NANDF_CS6#/PATA_DA2/GPIO3_22 156 NANDF_CS5#/PATA_DA1/GPIO3_21 157 NANDF_RDY_INT/GPIO3_24 158 NANDF_CS7#/GPIO3_23 159 NANDF_WE#/PATA_DIOW/GPIO3_3 160 GPIO_NAND/PATA_INTRQ/GPIO3_12 ConnectCore for i.MX51 Hardware Reference Manual 103 About the development board Peripheral application header Peripheral application header The development board provides one, 2x25-pin, 2.54mm pitch header for applications-specific daughter cards/expansion boards: n P21, Peripheral application header. Provides access to a 16-bit data bus, 10-bit address bus and control signals (such as CS#, OE#, WE#), as well as I2C and power (+3.3V). Using these signals you can connect Digi-specific extension modules or your own custom daughter card to the module's address/data bus and other interfaces. Peripheral application header, P21 Pin Signal Pin Signal 1 2 GND ConnectCore for i.MX51 Hardware Reference Manual D0 104 About the development board Peripheral application header Pin Signal Pin Signal 3 D1 4 D2 5 D3 6 GND 7 D4 8 D5 9 D6 10 D7 11 GND 12 D8 13 D9 14 D10 15 D11 16 GND 17 D12 18 D13 19 D14 20 D15 21 GND 22 8-bit / 16-bit (default) 23 GND 24 +3.3V 25 +3.3V 26 A0 27 A1 28 A2 29 A3 30 GND 31 A4 32 A5 33 A6 34 A7 35 GND 36 A8 37 A9 38 GND 39 CS0# 40 I2C2_SDA/GPIO1_3 41 WE# 42 OE# 43 I2C2_SCL/GPIO1_2 44 GPIO3_2 45 +3.3V 46 +3.3V 47 BE2# 48 BE3# 49 BCLK 50 GND The voltage level of the data, address and control signals provided by the module is +1.8V. A level shifter is provided on the development board to buffer and change the voltage level of most peripheral application signals on this header to +3.3V. The Data bus signals D0 - D15 are connected to the i.MX51 data bus signals D16 - D31. The Address bus signals A0 - A9 are connected to the i.MX51 data/address bus signals DA0 - DA9. The BE2# signal is connected to the i.MX51 byte enable 2 (D16 - D23). The BE3# signal is connected to the i.MX51 byte enable 3 (D24 - D31). ConnectCore for i.MX51 Hardware Reference Manual 105 About the development board Power-Over-Ethernet (PoE) - IEEE802.3af The BCLK signal corresponds to the i.MX51 burst clock signal. This clock signal is not buffered, and its voltage level is +1.8V. This signal is connected to the peripheral connector through a 0R resister. By default, this resistor is not populated. The I2C interface corresponds to i.MX51 I2C port 2. For more information, refer to About the module. The signal GPIO3_2 can only be used as an input signal to the i.MX51. This signal is intended to be used as interrupt line in the peripheral boards. Power-Over-Ethernet (PoE) - IEEE802.3af The development board provides two PoE module connectors, P17 and P18, to plug a Digi PoE module (DG-ACC-POE). The PoE module is an optional accessory item that can be plugged on the development board through the two connectors. n P17, input connector: provides access to the PoE signals from the Ethernet connector n P18, output connector: provides the output power supply from the PoE module ConnectCore for i.MX51 Hardware Reference Manual 106 About the development board Power-Over-Ethernet (PoE) - IEEE802.3af The PoE module Plug in the PoE module at a right angle to the development board, as shown in the picture below. Note the PoE module is part of the optional Digi 802.3af application kit (sold separately, Digi P/N DGACC-POE). PoE connector (power in), P17 The table below provides the pinout of the PoE input connector: Pin Signal 1 POE_TX_CT 2 POE_RX_CT 3 POE_RJ45_4/5 4 POE_RJ45_7/8 PoE connector (power out), P18 The table below provides the pinout of the PoE output connector: Pin Signal 1 +12V_PoE 2 +12V_PoE ConnectCore for i.MX51 Hardware Reference Manual 107 About the development board Main power connector Pin Signal 3 GND 4 GND 5 PoE_GND 6 PoE_GND Main power connector The main power connector (X24) is a barrel connector for the development board’s 9-30VDC power supply. The figure below shows the polarity. ConnectCore for i.MX51 Hardware Reference Manual 108 About the development board SD-card interface SD-card interface SD/MMC connector, X18 The development board provides one SD/MMC card connector, X18. This interface is connected to the enhanced Secured Digital Host controller 3 (eSDHC3) of the i.MX51 CPU. The following table provides the pinout of the SD/MMC connector: Pin Function 1 SD_DATA3 2 SD_CMD# 3 GND ConnectCore for i.MX51 Hardware Reference Manual 109 About the development board SD-card interface Pin Function 4 +3.3V 5 SD_CLK 6 GND 7 SD_DATA0 8 SD_DATA1 9 SD_DATA2 10 - 11 - 12 - 13 - 14 SD_CD# 15 SD_WP# ConnectCore for i.MX51 Hardware Reference Manual 110 About the development board SPI interface SPI interface SPI header, P24 The development board provides access to the SPI interface on the module using the SPI header, P24. This interface is connected to i.MX51 ECSPI1 port. The SPI bus is connected to the following interfaces on the development board: Interface Chip Select SPI Header CSPI1_SS1/GPIO4_25 LCD1 GPIO4_26 (*) LCD2 GPIO4_26 (*) ConnectCore for i.MX51 Hardware Reference Manual 111 About the development board SPI interface Interface Chip Select (*) the SPI chip select signal for the two LCD interfaces is generated with a logic combination of GPIO4_26 and the touch selection jumper (J20). The SPI bus is connected to the following interfaces of the ConnectCore for i.MX51 module. Interface Chip Select MC13892 Power Management CSPI1_SS0/GPIO4_24 The table below provides the pinout of the SPI header: Pin Function Defaults to 1 +2.775V 2 SPI_MOSI/GPIO4_22 GPIO4_22 3 SPI_MISO/GPIO4_23 GPIO4_23 4 SPI_SCLK/GPIO4_27 GPIO4_27 5 SPI_SS1/GPIO4_25 GPIO4_25 6 GND By default, SPI pins are configured as GPIO signals. ConnectCore for i.MX51 Hardware Reference Manual 112 About the development board UART interface UART interface Serial port 2, RS232, X27 The serial (UART) port 2 connector, X27, is a DB-9 male connector, which is also used as the standard console port. This asynchronous serial port is operating in DTE mode and requires a null-modem cable to connect to a computer serial port. The serial port 2 interface is connected to i.MX51 UART port 2. The corresponding line driver on the development board can be enabled or disabled using switch S7. Refer to Switches and push-buttons for more information. Serial port 2 pins are allocated as shown: Pin Function Defaults to 1 NC - 2 RXD GPIO1_20 ConnectCore for i.MX51 Hardware Reference Manual 113 About the development board UART interface Pin Function Defaults to 3 TXD GPIO1_21 4 NC - 5 GND - 6 NC - 7 RTS# GPIO1_14 8 CTS# GPIO1_11 9 NC - By default, serial port 2 signals are configured as GPIO signals. Serial port 1, MEI interface, X30 The serial (UART) port 1 connector, X30, is a DB-9 male connector. This asynchronous serial port is operating in DTE mode and requires a null-modem cable to connect to a computer serial port. The serial port 1 MEI (multiple electrical interface) interface corresponds to i.MX51 UART port 1. The line drivers are configured using the switch S6. Refer to Switches and push-buttons for more information. Serial port 1 pins are allocated as shown: Pin RS232 Function RS232 Default RS485 Function RS485Default 1 - - CTS- - 2 RXD GPIO4_28 RX+ GPIO4_28 3 TXD GPIO4_29 TX+ GPIO4_29 4 - - RTS- - 5 GND - GND - 6 - - RX- - 7 RTS# GPIO4_30 RTS+ GPIO4_30 8 CTS# GPIO4_31 CTS+ GPIO4_31 9 - - TX- - By default, serial port 1 signals are configured as GPIO signals. Serial port 3, TTL interface, X19 The serial (UART) port 3 interface is a TTL interface connected to a 2x5 pin, 2.54mm connector, X19. The connector supports only TTL level signals. The serial port 3 interface is connected to i.MX51 UART port 3. Serial port 3 pins are allocated as shown: ConnectCore for i.MX51 Hardware Reference Manual 114 About the development board UART interface Pin Function Defaults to 1 NC - 2 NC - 3 RXD GPIO1_22 4 RTS# KEY_COL4 5 TXD GPIO1_23 6 CTS# KEY_COL5 7 NC - 8 NC - 9 GND - 10 +3.3V - By default, serial port 3 signals are configured to their respective GPIO or KEY_COL signals. Serial port 3 is connected to the X19 connector and to the XBee module socket. Two jumpers (J30 and J31) are used in the development board to select the connector where serial port 3 will be available. Refer to Jumpers for more information. By default serial port 3 CTS# signal is not connected to X19. A 0Ω resistor, R44, must be manually populated to connect this signal to the X19 connector. ConnectCore for i.MX51 Hardware Reference Manual 115 About the development board USB host interface USB host interface USB host connectors, J8 and J10 The development board provides four standard type A receptacles for a USB host connection. A 4-Port USB hub is used in the development board to convert the USB host port 1 of the module into four USB host ports. The module supports low, full and high speed USB 2.0 connectivity. ConnectCore for i.MX51 Hardware Reference Manual 116 About the development board USB OTG interface USB OTG interface USB OTG connector, J11 The development board provides a standard mini-AB type receptacle for a USB OTG connection. The module supports full and high speed USB2.0 connectivity. ConnectCore for i.MX51 Hardware Reference Manual 117 About the development board User interface User interface The development board provides two user buttons and two user LEDs connected to GPIO signals of the i.MX51. The user buttons and the user LEDs can be enabled or disabled by correctly setting the corresponding jumpers. The table below shows the GPIO signal assigned to the user interface, and the jumpers used to enable/disable the buttons and LEDs: Signal GPIO USER_BUTTON1 GPIO3_6 USER_LED1# Jumper Comment J28 10K pull-up to +2.775V on the development board GPIO3_10 J16 ConnectCore for i.MX51 Hardware Reference Manual 118 About the development board Signal Analog video interface GPIO Jumper Comment USER_BUTTON2 GPIO1_1 J29 10K pull-up to +2.775V on the development board USER_LED2# J9 GPIO3_9 Analog video interface Analog video connector, X32 The development board provides an Analog Video connector. This connector is a 15-pin female connector, labeled X32. The Analog Video interface is connected to the Display 1 interface of the i.MX51 CPU. The table below shows the pinout of the Analog Video connector. ConnectCore for i.MX51 Hardware Reference Manual 119 About the development board Analog video interface Pin Signal 1 VGA_RED 2 VGA_GREEN 3 VGA_BLUE 4 NC 5 GND 6 RED_RETURN 7 GREEN_RETURN 8 BLUE_RETURN 9 NC 10 GND 11 NC 12 NC 13 HSYNC# 14 VSYNC# 15 NC ConnectCore for i.MX51 Hardware Reference Manual 120 About the development board WLAN interface WLAN interface Antenna connectors (WLAN) The development board provides the following connectors for the WLAN interface: n P12 and P13: these two UFL connectors are used to connect the WLAN interface of the ConnectCore for i.MX51 to the development board. Two coaxial cables are used for this connection. n P14 and P15: these two RP-SMA connectors are used to connect two (primary and secondary) WLAN antennas The following picture shows the WLAN antenna connections. ConnectCore for i.MX51 Hardware Reference Manual 121 About the development board ConnectCore for i.MX51 Hardware Reference Manual WLAN interface 122 About the development board Digi XBee interface Digi XBee interface Digi XBee module connectors, X28 and X29 The development board provides two 10-pin, 2.0mm connectors, X28 and X29, supporting a Digi XBee module. The XBee serial port is shared with UART port 3 on the development board. Two jumpers (J30 and J31) are used in the development board to select the connector where serial port 3 will be available. Refer to Jumpers for more information. The table below shows the pinout of the XBee module connectors. ConnectCore for i.MX51 Hardware Reference Manual 123 About the development board Digi XBee interface Pin Signal Pin Signal X28-1 +3.3V X29-1 IDENT X28-2 XBEE_DOUT X29-2 X28-3 XBEE_DIN X29-3 X28-4 NC X29-4 X28-5 XBEE_RESET# X29-5 XBEE_RTS# X28-6 - X29-6 ASSOC X28-7 - X29-7 X28-8 - X29-8 ON/SLEEP# X28-9 XBEE_SLEEP_RQ X29-9 XBEE_CTS# X28-10 GND ConnectCore for i.MX51 Hardware Reference Manual X29-10 124 Module specifications This section provides ConnectCore for i.MX51 module specifications. Mechanical specifications Environmental specifications Network interface Electrical characteristics ConnectCore for i.MX51 Hardware Reference Manual 126 126 126 131 125 Module specifications Mechanical specifications Mechanical specifications Length 82 mm (3.228 inches) Width: 50 mm (1.968 inches) Height : PCB: 1.40 mm (0.055 inches) Top side part: 3.60 mm (0.142 inches) Bottom side part: 2.20 mm (0.087 inches) Fasteners and appropriate torque We recommend using a M2x8mm PCB standoff with a slotted cheese head screw, DIN 84, M2x04, 6MM (Digi P/N MA00898) in combination with a flat washer, DIN 125, M2, Nylon 6 (Digi P/N MA01617). Additionally, we recommend the use of a torque key with 10 cNm. Do not use a standard metal M2 washer. Environmental specifications Operating temperature: 600MHz variant: -40º C to +85º C (-40º F to +185º F) 800MHz variant: -20º C to +70º C (-4º F to +158º F) Storage temperature: -40º C to +125º C (-40º F to +257º sF) Network interface Antenna specifications: 802.11 a/b/g antenna Attributes Attribute Band 1 Band 2 Frequency 2.4 ~ 2.4835 GHz 5.15 ~ 6 GHz Bandwidth 120MHz 875MHz Wavelength 1/4 Wave 1/4 Wave Impedance 50 Ohm 50 Ohm VSWR < 19 typ. Center < 19 typ. Center Connector RP-SMA RP-SMA ConnectCore for i.MX51 Hardware Reference Manual 126 Module specifications Network interface Attribute Band 1 Band 2 Gain 2.3dBi 3.6dBi Dimension See the measurements in the drawing after this table Part Number ANT-DB1-RAF-RPS Dimensions Note Dimensions are provided for reference purposes only. The actual antenna might vary. Antenna specification: 802.11b/g antenna Attributes Attribute Property Frequency 2.4 ~ 2.5GHz Power Output 2W DB Gain 2dBi VSWR < or = 2.0 ConnectCore for i.MX51 Hardware Reference Manual 127 Module specifications Network interface Attribute Property Dimension 108.5 mm% 10.0mm Weight 10.5g Temperature Rating -40 °to +80° C Part Number DG-ANT-20DP-BG Dimensions Note Dimensions are provided for reference purposes only. The actual antenna might vary. Ethernet 1 Standard: IEEE 802.3/802.3u Physical layer: 10/100Base Data rate: 10/100 Mb/s Mode: Full or half duplex ConnectCore for i.MX51 Hardware Reference Manual 128 Module specifications Network interface Ethernet 2 Standard: IEEE 802.3/802.3u Physical layer: 10/100Base Data rate: 10/100 Mb/s Mode: Full or half duplex WLAN Standard n IEEE 802.11a/b/g/e/i/h/j standards n Single-stream IEEE 802.11n Frequency band n 2.400 - 2.500 GHz (Low Band) n 4.900 - 5.850 GHz (High Band) Data rates n 802.11n :6.5, 13, 19.5, 26, 39,52, 58.5, 65 Mb/s n 802.11a/g :6, 9, 12, 18, 24, 36, 48, 54 Mb/s n 802.11b :1, 2, 5.5, 11 Mb/s Media access control n Dynamic selection of fragment threshold, data rate and antenna depending on the channel statistics n WPA, WPA2 and WMM support Wireless medium n 802.11b/g: Direct Sequence-Spread Spectrum (DSSS) and Orthogonal Frequency Divisional Multiplexing (OFDM) n 802.11a/n: OFDM DFS client n This module supports the DFS Client only between 5.25 - 5.35 GHz and 5.50 - 5.70 GHz bands. It does not support being DFS Master, or can it be connected to an Ad hoc network in these ConnectCore for i.MX51 Hardware Reference Manual 129 Module specifications Network interface bands. n This device cannot act as an access point on the non-DFS legacy frequency in the 5.15 and 5.25 GHz bands. Modulation DSSS n Differential Binary Shift Keying (DBPSK) @ 1 Mb/s n Differential Quadrature Phase Shift Keying (DQPSK) @ 2 Mb/s n Complementary Code Keying (CCK) @ 5.5 Mb/s and 11 Mb/s n BPSK @ 6 and 9 Mb/s n QPSK @ 12 and 18 Mb/s n 16-Quadrature Amplitude Modulation (QAM) @24 and 36 Mb/s n 64-QAM @ 48 and 54 Mb/s Frequency bands n 2.412 to 2.472 GHz (ETSI) n 2.412 to 2.462 GHz (FCC) n 5.150 to 5.250 GHz (ETSI) ISM Band 1 n 5.250 to 5.350 GHz (ETSI) ISM Band 2 excluding TPC and DFS Client n 5.470 to 5.725 GHz (ETSI) ISM Band 3 excluding TPC and DFS Client n 5.150 to 5.250 GHz (U-NII-1) n 5.250 to 5.350 GHz (U-NII-2) excluding TPC and DFS Client n 5.470 to 5.725 GHz (U-NII Worldwide) excluding TPC and DFS Client n 5.725 to 5.825 GHz (U-NII-3) Available transmit power settings (typical +- (2 dBm)@25°C) (Maximum power settings will vary according to individual country regulations.) n IEEE 802.11b (~16 mW ETSI) (~37 mW FCC 15.247) @ 1, 2, 5.5 and 11 Mb/s n IEEE 802.11g (~ 10 mW ETSI) (~72 mW FCC 15.247) @ 6, 12, 18, 24, 36 and 54 Mb/s n IEEE 802.11n 2.4 GHz Band (~12.5 mW ETSI) (~83 mW FCC 15.247) n IEEE 802.11a & IEEE 802.11n (~15mW ETSI) (5.150 to 5.250 GHz ~17 mW FCC 15.407) (5.250 to 5.350 GHz ~17 mW FCC 15.407) (5.470 to 5.725 GHz ~22 mW FCC 15.407) (5.725 to 5.850 GHz ~28 mW FCC 15.247) @ 6, 12, 18, 24, 36 and 54 Mb/s and @ 6.5, 13, 19.5, 26, 39,52, 58.5, 65 Mb/s ConnectCore for i.MX51 Hardware Reference Manual 130 Module specifications Electrical characteristics Receive sensitivity Data Rate (bg Mode) Typical Sensitivity (+ / - 1.5 dBm) 1 Mb/s -94.0 dBm (< 8% PER) 2 Mb/s -89.0 dBm (< 8% PER) 11 Mb/s -86.0 dBm (< 8% PER) 6 Mb/s -89.0 dBm (< 10% PER) 54 Mb/s -74.0 dBm (< 10% PER) 645Mb/s -71.0 dBm (< 10% PER) Data Rate (a Mode) Typical Sensitivity ( + / - 1.5 dBm) 6 Mb/s -88.0 dBm (< 10% PER) 54 Mb/s -72.0 dBm (< 10% PER) Data Rate (bg Mode) Typical Sensitivity (+ / - 1.5 dBm) 65 Mb/s -69.0 dBm (< 10% PER) Electrical characteristics Charger vs. battery The ConnectCore for i.MX51 can be supplied solely either through the battery input or also through the charger input, although the VLIO input is the preferred method. When using solely the charger input, and when no battery is connected to VLIO, the ConnectCore for i.MX51 will not be functional across the entire rated temperature of the product. As an example, when using the product at -20C, the ConnectCore for the i.MX51 will not be functional due to the internals state machine of the module PMIC. To override this limitation for all instances, you must generate a battery voltage on the carrier board. Different options are available for simulating a battery voltage - below is one example, based on three Schottky diodes in series. ConnectCore for i.MX51 Hardware Reference Manual 131 Module specifications Electrical characteristics Note When using the charger as unique power source for the ConnectCore for i.MX51 module, the CHRGSE1# (J1.45) pin must be forced low as a charger attach indicator. Supply voltages Parameter Symbol Min Typ Max Unit Battery Input VLIO 3.4 3.7 4.8 V Charger Input VCHRG 3.4 5 5.6 V Coin cell Input for RTC VCC_COINCELL 2.5 3 3.6 V Supply current The following table provides current draw guidance utilizing the power management capabilities of the module. The module variant used for the measurements works at 800MHz, with 512 MB NAND Flash, 512 MB DDR2, dual Ethernet, WLAN, and accelerometer. A Windows Embedded CE kernel with power management capabilities has been used to make the current consumption measurements. A different kernel (Linux or Windows CE) with a different driver configuration will show different current consumption values. The ConnectCore for i.MX51 module can be powered from an external battery (VLIO) or from a battery charger (VCHRG). Current drawn by the modules is different depending on the supply voltage used. The following tables show the current drawn by the module from the two power supplies. The current drawn by the module is highly dependent on the number and type of interfaces used. To make some current measurements three different interface configurations have been defined: ConnectCore for i.MX51 Hardware Reference Manual 132 Module specifications Electrical characteristics Interface Configuration Interfaces Used Minimum Console, Ethernet. +3.3V of development board drawn from external power supply. Typical VGA, USB Host (two devices connected), Audio, Ethernet, Console. +3.3V of development board drawn from module. Maximum Display1, Display2, Camera1, Camera2, USB OTG, USB Host (four devices connected), Audio, Ethernet, Console, WLAN, SD Card, microSD™ Card. +3.3V of development board drawn from module. The ConnectCore for i.MX51 supports several power modes. The current drawn by the module is highly dependent on the power modes. To make some current measurements, five different power modes have been defined: Interface Configuration Interfaces Used Full Load System running at 100% CPU load. Normal Normal operating state. User interacting with the device. User Idle After a long period of user inactivity some devices are turned off. System Idle In this state the user is not using the system, even passively, and devices that are not actively doing work are turned off. Suspend This is the sleep state, no threads are running, the CPU is idle, the peripherals are turned off, and the system can wake up only by means of hardware wake-source interrupt. The tables below show the current drawn by the module for the different power modes and the different interface configurations. On-module power supplies The following table provides the on-module power supplies available through the module connectors, which can be used to supply the components integrated on a customer baseboard. Supply Source +2.775V PMIC VIOHI LDO +1.8V PMIC VGEN3 LDO Off-module Comments Output Load Voltage Capacity Available Current +2.775V 100mA max 50mA max +1.8V 250mA max 250mA max ConnectCore for i.MX51 Hardware Reference Manual Used on module to power IPU, Peripheral interfaces, Accelerometer, I 2C, Ethernet PHY, and bootstraps 133 Module specifications Electrical characteristics Off-module Comments Output Load Voltage Capacity Available Current Supply Source +3.3V DC/DC Converter +3.3V 1.2A max 400mA max (*) Used on module to power WLAN, Ethernet Controller and Ethernet PHY +3.15V PMIC VGEN2 LDO +3.15V 350mA max 300mA max Used on module to power NAND Flash SD1 and fuse interface SWBST PMIC +5V Boost Switcher +5V 300mA max 300mA max (*)The off-module available current for the wired variant modules is 800mA. I/O DC parameters This section includes the DC parameters of the following I/O types: n General Purpose I/O and High-Speed General Purpose I/O (GPIOxx/HSGPIOxx) n Low Voltage I/O (LVIO) n Ultra High Voltage I/O (UHVIOxx) n WLAN n PMIC_GPO, PMIC_PWRON, PMIC_STDBY, PMIC_INT, PMIC_PWDRV, PMIC_SE, PMIC_CHRGLED, and PMIC_LED n Ethernet (ETH) n Analog RGB n ADC subsystem (ADIN) n Digital and analog USB (DIG_USB, AN)USB) The I/O type associated to each I/O signal of the module is shown in Module pinout. The following table shows the General Purpose I/O and High-Speed General Purpose I/O (GPIOxx/HSGPIOxx) DC parameters. The “xx” reference signifies the supply voltage level. Parameter Symbol Min Typ Supply Voltage VDD xx = 18 xx = 27 xx = 33 1.65 2.5 3.0 1.8 1.95 2.775 3.1 3.3 3.6 Voh (Vol USB) VDD-0.15 VDD-0.43 - VDD+0.3 VDD+0.3 V Vol (Vol USB) - 0.15 0.43 V High-level output voltage Low-level output voltage ConnectCore for i.MX51 Hardware Reference Manual -- Max Unit V 134 Module specifications Electrical characteristics Parameter Symbol Min High-level output current Ioh - Low drive - Medium drive - High drive - Max drive -1.9 -3.7 -5.2 -5.6 Iol - Low drive - Medium drive - High drive - Max drive 1.9 3.7 5.2 5.6 High-level input voltage VIH 0.7 x VDD - VDD Low-level input voltage VIL 0 - 0.3 x VDD V Input Current (no/pull) Iin - - 2 µA Input Current (22kΩ/pull-up) Iin - - 161 µA Input Current (47kΩ/pull-up) Iin - - 76 µA Input Current (100kΩ/pull-up) Iin - - 36 µA Input Current (100kΩ/pull-down) Iin - - 36 µA Keeper circuit resistance - - 17 - kΩ Output driver impedance Rout - Low drive - Medium drive - High drive - Max drive 80 40 27 20 104 52 35 26 250 125 83 62 Ω Low-level output current Typ Max - - Unit mA - mA V The following table shows the LVIO DC parameters. Parameter Symbol Min Typ Max Unit Supply Voltage VDD 1.65 1.8 1.95 V High-level output voltage Voh VDD-0.15 - - V Low-level output voltage Vol - - 0.15 V High-level output current Ioh - Low drive - Medium drive - High drive - Max drive - - -2.1 -4.2 -6.3 -8.4 Iol - Low drive - Medium drive - High drive - Max drive 2.1 4.2 6.3 8.4 Low-level output current ConnectCore for i.MX51 Hardware Reference Manual mA - mA 135 Module specifications Electrical characteristics Parameter Symbol Min Typ Max Unit High-level input voltage VIH 0.7 x VDD - VDD Low-level input voltage VIL 0 - 0.3 x VDD V Input Current (no/pull) Iin - - 1 µA Input Current (22kΩ/pull-up) Iin - - 161 µA Input Current (47kΩ/pull-up) Iin - - 76 µA Input Current (100kΩ/pull-up) Iin - - 36 µA Input Current (100kΩ/pull-down) Iin - - 36 µA Keeper circuit resistance - - 17 - kΩ Output driver impedance Rout - Low drive - Medium drive - High drive - Max drive 80 40 27 20 150 75 51 38 250 125 83 62 Ω V The following table shows the Ultra-High Voltage I/O (UHVIOxx) DC parameters. The “xx” reference signifies the supply voltage level. Parameter Symbol Min Typ Supply Voltage VDD xx = 31 xx = 33 3.0 3.0 3.15 3.6 3.3 3.6 High-level output voltage Voh (USB, WLAN) VDD-0.15 VDD-0.43 - VDD-0.15 V VDD-0.43 Low-level output voltage Vol (USB, WLAN) - -- 0.15 0.43 Ioh - Low drive -5.1 - Medium drive -10.2 - High drive -15.3 - - Iol - Low drive 5.1 - Medium drive 10.2 - High drive 15.3 - High-level output current Low-level output current Max Unit V V mA mA High-level input voltage VIH 0.7 x VDD - VDD Low-level input voltage VIL 0 - 0.3 x VDD V Input Current (no/pull) Iin - - 10 µA Input Current (22kΩ/pull-up) Iin - - 202 µA ConnectCore for i.MX51 Hardware Reference Manual V 136 Module specifications Electrical characteristics Parameter Symbol Min Typ Max Unit Input Current (75kΩ/pull-up) Iin - - 61 µA Input Current (100kΩ/pull-up) Iin - - 47 µA Input Current (360kΩ/pull-down) Iin - - 5.7 µA Keeper circuit resistance - - 17 - kΩ Output driver impedance Rout - Low drive 114 - Medium drive 57 - High drive 38 135 67 45 206 103 69 Ω ConnectCore for i.MX51 Hardware Reference Manual 137 Module dimensions This section shows the dimensions of the ConnectCore for i.MX51 module, dimensions are in millimeters. Top view Bottom view Side view Connectors ConnectCore for i.MX51 Hardware Reference Manual 139 140 141 141 138 Module dimensions Top view Top view ConnectCore for i.MX51 Hardware Reference Manual 139 Module dimensions Bottom view Bottom view ConnectCore for i.MX51 Hardware Reference Manual 140 Module dimensions Side view Side view Connectors The ConnectCore for i.MX51 module uses two Berg/FCI connectors. The following table shows the reference number of the connectors used on the module and the reference number of the connectors used in the development board. The mated height of the module and the development board is 5mm. Device Berg/FCI Connector ConnectCore for i.MX51 module 61082-181409LF ConnectCore for i.MX51 development board 61083-184409LF ConnectCore for i.MX51 Hardware Reference Manual 141 Regulatory information The ConnectCore for i.MX51 product complies with the following standards. Federal Communication (FCC) regulatory information (USA only) Radio Frequency Interface (RFI) (FCC 15.105) This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to correct the interference by one or more of the following measures: n Reorient or relocate the receiving antenna. n Increase the separation between the equipment and the receiver. n Connect the equipment into an outlet that is on a circuit different from the receiver. n Consult the dealer or an experienced radio/TV technician for help. Labeling Requirements (FCC 15.19) This device complies with Part 15 of FCC rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. If the FCC ID is not visible when installed inside another device, then the outside of the device into which the module is installed must also display a label referring to the enclosed module FCC ID. RF exposure RF Exposure considerations require that a 20cm separation distance between users and the installed antenna location shall be maintained at all times when the module is energized. OEM installers must consider suitable module and antenna installation locations in order to assure this in 20cm separation, and end users be also be advised to the requirement. ConnectCore for i.MX51 Hardware Reference Manual 142 Regulatory information Federal Communication (FCC) regulatory information (USA only) Modifications (FCC 15.21) Changes or modifications to this equipment not expressly approved by Digi may void the user’s authority to operate this equipment. Industry Canada This digital apparatus does not exceed the Class B limits for radio noise emissions from digital apparatus set out in the Radio Interference Regulations of the Canadian Department of Communications. Le present appareil numerique n’emet pas de bruits radioelectriques depassant les limites applicables aux appareils numeriques de la class B prescrites dans le Reglement sur le brouillage radioelectrique edicte par le ministere des Communications du Canada. The maximum antenna gain permitted in the bands 5250-5350 MHz and 5470-5725 MHz to comply with the e.i.r.p limit is, according to RSS-210 section A9.2(2) n 250mW conducted power n 1.0W max EIRP This limit is met with the highest gain antenna listed, antennafactor ANT-DB1-RAF-RPS. The maximum antenna gain permitted in the band 5725-5825 MHz to comply with the e.i.r.p limit specified for non point-to-point operation is, according to RSS-210 section A9.2(3): n 1W conducted power n 4.0W max EIRP This limit is met with the highest gain antenna listed,antennafactor ANT-DB1-RAF-RPS. OEM installers and users are cautioned to take note that high-power radars are allocated as primary users (meaning they have priority) of the bands 5250-5330 MHz and 5650-5850 MHz and these radars could cause interference and /or damage to devices operating in these frequency bands. Indoor/outdoor When the ConnectCore for i.MX51 module is installed in devices that can be used outdoors, the channels in the band 5150-5250 MHz must be disabled to comply with US and Canadian regulatory requirements. The OEM users are encouraged to inform end users of this restriction as well. Japan certification この製品は、周波数帯域 5.15 ~ 5.35 GHz で動作しているときは、 屋内においてのみ使用可能です。 This device has been granted a designation number by Ministry of Internal Affairs and Communications according to: Ordinance concerning Technical Regulations Conformity Certification etc. of Specified Radio Equipment (特定無線設備の技術基準適合証明等に関する規) Article 2 clause 1 item 19 Approval n°: 202WW09115541 Article 2 clause 1 item 19 (2) Approval n°: 202GZ09115541 Article 2 clause 1 item 19 (3) ConnectCore for i.MX51 Hardware Reference Manual 143 Regulatory information Federal Communication (FCC) regulatory information (USA only) Approval n°: 202XW09115541 Article 2 clause 1 item 19 (3) (2) Approval n°: 202YW09115541 This device should not be modified (otherwise the granted designation number will be invalid). Declaration of Conformity (DoC) Digi has issued Declarations of Conformity for the ConnectCore for i.MX51 concerning emissions, EMC, and safety. For more information, see www.digi.com/resources/certifications. Important note Digi customers assume full responsibility for learning and meeting the required guidelines for each country in their distribution market. Refer to the radio regulatory agency in the desired countries of operation for more information. CE mark (Europe) The ConnectCore for i.MX51 is certified for use in several European countries. For information, visit www.digi.com/resources/certifications. If the ConnectCore for i.MX51 is incorporated into a product, the manufacturer must ensure compliance of the final product with articles 3.1a and 3.1b of the RE Directive (Radio Equipment Directive). A Declaration of Conformity must be issued for each of these standards and kept on file as described in the RE Directive (Radio Equipment Directive). Furthermore, the manufacturer must maintain a copy of the ConnectCore for i.MX51 user manual documentation and ensure the final product does not exceed the specified power ratings, antenna specifications, and/or installation requirements as specified in the user manual. OEM labeling requirements The 'CE' marking must be affixed to a visible location on the OEM product. CE labeling requirements The CE mark shall consist of the initials “CE” taking the following form: n If the CE marking is reduced or enlarged, the proportions given in the above graduated drawing must be respected. n The CE marking must have a height of at least 5mm except where this is not possible on account of the nature of the apparatus. n The CE marking must be affixed visibly, legibly, and indelibly. ConnectCore for i.MX51 Hardware Reference Manual 144 Regulatory information Federal Communication (FCC) regulatory information (USA only) International EMC standards The ConnectCore for i.MX51 meets the following standards: Standards Emissions FCC Part 15 Subpart B IS-003 Immunity EN 55022 EN 55024 Safety UL 60950-1 CSA C22.2, No. 60950-1 EN 60950-1 ConnectCore for i.MX51 Hardware Reference Manual 145 Maximum power and frequency specifications Maximum power Associated frequencies 88 mW 13 overlapping channels each 22MHz wide and spaced at 5MHz. Centered at 2.412 to 2.472MHz. 28 mW 165 overlapping channels each 22 or 40MHz wide and spaced at 5MHz. Centered at 5180 to 5825MHz. ConnectCore for i.MX51 Hardware Reference Manual 146
CC-WMX-LB58-VM-B 价格&库存
很抱歉,暂时无法提供与“CC-WMX-LB58-VM-B”相匹配的价格&库存,您可以联系我们找货
