XBee® & XBee-PRO® ZB
ZigBee® Embedded RF Module Family for OEMs
Embedded RF modules provide low-cost, low-power
wireless connectivity using the ZigBee PRO Feature Set.
Overview
XBee and XBee-PRO ZB embedded RF modules provide cost-effective
wireless connectivity to devices in ZigBee mesh networks. Utilizing the
ZigBee PRO Feature Set, these modules are interoperable with other
ZigBee devices, including devices from other vendors*.
Application Highlight
Products in the XBee family are easy to use. They require no
configuration or additional development; users can have their network
up and running in a matter of minutes.
Programmable versions of the XBee-PRO ZB module make
customizing ZigBee applications easy. Programming directly on the
module eliminates the need for a separate processor. Because the
wireless software is isolated, applications can be developed with no
risk to RF performance or security.
XBee modules are available in a variety of protocols and frequencies.
The common hardware footprint shared by Digi’s XBee modules
means users can substitute one XBee for another with minimal
development time and risk.
*Interoperability requires the ZigBee Feature Set or ZigBee PRO Feature Set to be
deployed on all devices. Contact Digi Support for details.
Features/Benefits
Related Products
Gateways
Development Kits
Modules
Network Extenders
Interoperability with ZigBee compliant devices*
No configuration needed for out-of-the-box RF
communications
Common XBee footprint for a variety of RF modules
ZigBee mesh networking protocol
- Improved data traffic management
- Remote firmware updates
- Self-healing and discovery for network stability
Programmable versions of the XBee-PRO ZB enable
custom ZigBee application development
- 8-bit Freescale™ S08 microprocessor brings
intelligence to devices
- CodeWarrior® development tools for easy
customization
Adapters
Sensors
www.digi.com
XBee® ZB
Platform
XBee-PRO® ZB
Programmable XBee-PRO® ZB
Performance
250 Kbps
RF Data Rate
133 ft (40 m)
Indoor/Urban Range
400 ft (120 m)
2 miles (3200 m) / Int’l 5000 ft (1500 m)
1.25 mW (+1 dBm) / 2 mW (+3 dBm) boost mode
63 mW (+18 dBm) / Int’l 10 mW (+10 dBm)
-96 dBm in boost mode
-102 dBm
Outdoor/RF Line-of-Sight Range
Transmit Power
Receiver Sensitivity (1% PER)
300 ft (90 m)
Features
Yes
Adjustable Power
3.3V CMOS UART, ADC, DIO
I/O Interface
3.3V CMOS UART, SPI, I2C, PWM, DIO, ADC
API or AT commands, local or over-the-air
Configuration Method
2.4 GHz
Frequency Band
DSSS (Direct Sequence Spread Spectrum)
Interference Immunity
1200 bps - 1 Mbps
Serial Data Rate
ADC Inputs
(4) 10-bit ADC inputs
Digital I/O
10
Chip, Wire Whip, U.FL, RPSMA
Antenna Options
PCB Embedded Antenna, Wire Whip, U.FL, RPSMA
-40º C to +85º C, 0-95% humidity non-condensing
Operating Temperature
Programmability
Memory
N/A
32 KB Flash / 2 KB RAM
CPU/Clock Speed
N/A
HCS08 / Up to 50.33 MHz
Networking & Security
128-bit AES
Encryption
Retries/Acknowledgments
Reliable Packet Delivery
IDs and Channels
PAN ID, 64-bit IEEE MAC, 16 channels
PAN ID, 64-bit IEEE MAC, 15 channels
2.1 - 3.6VDC
2.7 - 3.6VDC
Power Requirements
Supply Voltage
Transmit Current
35 mA / 45 mA boost mode @ 3.3VDC
205 mA
220 mA
Receive Current
38 mA / 40 mA boost mode @ 3.3VDC
47 mA
62 mA
很抱歉,暂时无法提供与“XBP24-BSIT-001”相匹配的价格&库存,您可以联系我们找货
