XBP24BZ7UIT-004J
XBP24BZ7UIT-004J
    DIGIINTERNATIONAL
    模块
    XBEE PRO SET S2B 10MW U.FL
XBP24BZ7UIT-004J 数据手册
XBee® & XBee-PRO® ZB ZigBee® Embedded RF Module Family for OEMs Embedded RF modules provide low-cost, low-power wireless connectivity using the ZigBee PRO Feature Set. Overview XBee and XBee-PRO ZB embedded RF modules provide cost-effective wireless connectivity to devices in ZigBee mesh networks. Utilizing the ZigBee PRO Feature Set, these modules are interoperable with other ZigBee devices, including devices from other vendors*. Application Highlight Products in the XBee family are easy to use. They require no configuration or additional development; users can have their network up and running in a matter of minutes. Programmable versions of the XBee-PRO ZB module make customizing ZigBee applications easy. Programming directly on the module eliminates the need for a separate processor. Because the wireless software is isolated, applications can be developed with no risk to RF performance or security. XBee modules are available in a variety of protocols and frequencies. The common hardware footprint shared by Digi’s XBee modules means users can substitute one XBee for another with minimal development time and risk. *Interoperability requires the ZigBee Feature Set or ZigBee PRO Feature Set to be deployed on all devices. Contact Digi Support for details. Features/Benefits Related Products Gateways Development Kits Modules Network Extenders • Interoperability with ZigBee compliant devices* • No configuration needed for out-of-the-box RF communications • Common XBee footprint for a variety of RF modules • ZigBee mesh networking protocol - Improved data traffic management - Remote firmware updates - Self-healing and discovery for network stability • Programmable versions of the XBee-PRO ZB enable custom ZigBee application development - 8-bit Freescale™ S08 microprocessor brings intelligence to devices - CodeWarrior® development tools for easy customization Adapters Sensors www.digi.com XBee® ZB Platform XBee-PRO® ZB Programmable XBee-PRO® ZB Performance 250 Kbps RF Data Rate 133 ft (40 m) Indoor/Urban Range 400 ft (120 m) 2 miles (3200 m) / Int’l 5000 ft (1500 m) 1.25 mW (+1 dBm) / 2 mW (+3 dBm) boost mode 63 mW (+18 dBm) / Int’l 10 mW (+10 dBm) -96 dBm in boost mode -102 dBm Outdoor/RF Line-of-Sight Range Transmit Power Receiver Sensitivity (1% PER) 300 ft (90 m) Features Yes Adjustable Power 3.3V CMOS UART, ADC, DIO I/O Interface 3.3V CMOS UART, SPI, I2C, PWM, DIO, ADC API or AT commands, local or over-the-air Configuration Method 2.4 GHz Frequency Band DSSS (Direct Sequence Spread Spectrum) Interference Immunity 1200 bps - 1 Mbps Serial Data Rate ADC Inputs (4) 10-bit ADC inputs Digital I/O 10 Chip, Wire Whip, U.FL, RPSMA Antenna Options PCB Embedded Antenna, Wire Whip, U.FL, RPSMA -40º C to +85º C, 0-95% humidity non-condensing Operating Temperature Programmability Memory N/A 32 KB Flash / 2 KB RAM CPU/Clock Speed N/A HCS08 / Up to 50.33 MHz Networking & Security 128-bit AES Encryption Retries/Acknowledgments Reliable Packet Delivery IDs and Channels PAN ID, 64-bit IEEE MAC, 16 channels PAN ID, 64-bit IEEE MAC, 15 channels 2.1 - 3.6VDC 2.7 - 3.6VDC Power Requirements Supply Voltage Transmit Current 35 mA / 45 mA boost mode @ 3.3VDC 205 mA 220 mA Receive Current 38 mA / 40 mA boost mode @ 3.3VDC 47 mA 62 mA
XBP24BZ7UIT-004J
物料型号:XBee和XBee-PRO ZB
器件简介:这些模块提供低成本、低功耗的无线连接,使用ZigBee PRO特性集,与其他ZigBee设备兼容。
引脚分配:文档中未明确列出具体的引脚分配图,但提到了模块的物理尺寸。
参数特性: - RF数据速率:XBee-PRO ZB为250Kbps - 室内/城市范围:XBee为133英尺(40米),XBee-PRO ZB为300英尺(90米) - 室外/射频直视范围:XBee为400英尺(120米),XBee-PRO ZB可达2英里(3200米)或更远 - 发射功率:XBee为1.25mW,XBee-PRO ZB为63mW - 接收灵敏度:XBee在增益模式下为-96dBm,XBee-PRO ZB未提供具体数值
功能详解: - ZigBee网状网络协议 - 远程固件更新 - 自我修复和发现以提高网络稳定性 - 可编程版本的XBee-PRO ZB模块允许自定义ZigBee应用开发
应用信息:文档中未提供具体的应用案例,但提到这些模块易于使用,无需配置或额外开发,可以快速部署网络。
封装信息:文档中提供了模块的尺寸信息,但没有详细描述封装类型。
XBP24BZ7UIT-004J 价格&库存
很抱歉,暂时无法提供与“XBP24BZ7UIT-004J”相匹配的价格&库存,您可以联系我们找货
