317030022
317030022
    SEEED(矽递科技)
    模块
    LINKIT MT2502A MODULE -SCALE FOR
317030022 数据手册
Page 1 of 4 (images/317030022 1_02.jpg) LinkIt MT2502A Module -Scale for IoT solution SKU: 317030022 Description LinkIt MT2502A Module is a low-cost and low-power consumption IoT SiP module. The module is an operating deisgned for Wearables and Internet of Things(IoT)devices that can Page 2 of 4 connect to other smart devices or directly to cloud applications and services. It integrates voice-band,audio-band,base-band analog front-end and full-featured power management unit. With its embedded support for GPRS/GSM, this highly integrated SoC design avoids the need for multiple chips, meaning smaller devices and reduced costs for device creators, as well as eliminating the need for compatibility tests. This module is complemented by Wi-Fi and GNSS chips, offering high performance and low power consumption to devices with more sophisticated communication or location acquisition requirements.With LinkIt MT2502A Module, it’s easier and cheaper for device manufacturers to produce desirable, functional wearable products. Features: General • Integrated voice-band, audio-band and base-band analog front-end • Integrated full-featured power management unit MCU subsystem • • • • • • • • • ARM7EJ-S TM 32-bit RISC processor Java hardware acceleration for fast Java-based games and applets High-performance multi-layer AHB bus Dedicated DMA bus with 16 DMA channels On-chip boot ROM for factory flash programming Watchdog timer for system crash recovery 3 sets of general-purpose timers Circuit switch data coprocessor Division coprocessor Serial flash interfaces • Supports various operating frequency combinations for serial flash • Supports QPI and SPI serial flash User interfaces • • • • • • • • 5-row x 5-column keypad controller with hardware scanner Supports multiple key presses for gaming Dual SIM/USIM controller with hardware T=0/T=1 protocol control Real-time clock(RTC) operating with a low-quiescent-current power supply General-purpose I/Os(GPIOs) available for auxiliary applications 2 sets of Pulse Width Modulation(PWM) output 24 external interrupt lines 1 external channel auxiliary 10-bit A/D converter Page 3 of 4 Security • Supports security key and chip random ID Connectivity • 3 UARTs with hardware flow control and supports baud rate up to 921600bps • FS/LS USB 1.1 device controller • Multimedia card, secure digital Memoy Card, host controller with flexible I/O voltage power • Supports 4-bit SDIO interface for SDIO peripherals as well as WIFI connectivity • DAI/PCM and I2S interface for audio applications • I2C master interface for peripheral management including image sensors • SPI master/slave interface for peripheral management. Power management • Li-ion battery charger • 12 LDOs for the power supply of memory card, camera, Bluetooth, RF, SIM card and other diversified usage. • 1 open-drain output switches to supply/control the LED • LDO type vibrator • One NMOS switch to control keypad LED • Thermal overload protection • Under-voltage protection • Different levels of power-down modes with sophisticated software control enables excellent power saving performance Test and debugging • Built-in digital and analog loop back modes for both audio and baseband front-end • DAI port complies with GSM Rec.11.10 • JTAG port for debugging embedded MCU Specification: Model Name: AI2502S05 Chipset: MT2502A Core: ARM7 EJ-STM Clock Speed: 260MHz Flash: 16MB RAM: 4MB Operation Conditions • Temperature: -20℃~70℃(Operating),-40℃~85℃(Storage) • Humidity:10~95%(Operating),5~95%(Storage) • Dimension:17mm x 15mm x 1.8mm(Max.) Page 4 of 4 • Package:LGA Electrical Specifications • Digital IO Pins:TBD(Pin Count),3.3V(Voltage) • Analog Input Pins:TBD(Pin Count),0~5V(Voltage) • PWM Output Pins: Max Resolution:13bit                   Max Frequency@Resolution:                       1.6kHz@13bit                       50.8KHz@8bit                       800kHz@4bit • • • • I2C(master only): 100Kbps, 400Kbps, 3.4Mbps SPI (master only): 104Kbps~26Mbps GSM/GPRS: 850/900/1800/1900 MHz Bluetooth: BR/EDR/BLE(Dual Mode) Overview Weight: 0 g http://www.seeedstudio.com/depot/LinkIt-MT2502A-Module-Scale-for-IoT-solution-p-23... 12/1/2015
317030022 价格&库存
很抱歉,暂时无法提供与“317030022”相匹配的价格&库存,您可以联系我们找货
