BLM2425M7S60P
LDMOS 2-stage power MMIC
Rev. 5 — 13 September 2018
Product data sheet
1. Product profile
1.1 General description
60W dual path, 2-stage power MMIC transistor for Industrial, Scientific and Medical (ISM)
applications at frequencies from 2400 MHz to 2500 MHz.
The BLM2425M7S60P is designed for high power CW applications and is assembled in a
high performance plastic package.
Table 1.
Application performance
Per section unless otherwise specified.
Test signal
CW
f
VDS
PL
Gp
ηD
(MHz)
(V)
(W)
(dB)
2450
32
30
27.5
45
1.2 Features and benefits
High efficiency
High power gain
Excellent ruggedness
Excellent thermal stability
Integrated ESD protection
Biasing of individual stages is externally accessible
On-chip matching for ease of use
Designed for broadband operation (frequency 2400 MHz to 2500 MHz)
For RoHS compliance see the product details on the Ampleon website
1.3 Applications
Industrial, scientific and medical applications in the frequency range 2400 MHz to
2500 MHz.
BLM2425M7S60P
2. Pinning information
2.1 Pinning
pin 1 index
VDS(A1)
VGS(A2)
VGS(A2)
RF_IN_A
VGS(A1)
VGS(A1)
n.c.
n.c.
VGS(B1)
VGS(B1)
RF_IN_B
VGS(B2)
VGS(B2)
VDS(B1)
1
2
3
4
5
6
7
16
RF_OUT_
VDS(A2)
8
9
10
11
12
13
14
15
RF_OUT_
VDS(B2)
amp00795
Transparent top view
The exposed backside of the package is the ground terminal of the device.
Fig 1.
Pin configuration
2.2 Pin description
Table 2.
BLM2425M7S60P
Product data sheet
Pin description
Symbol
Pin
Description
VDS(A1)
1
drain-source voltage of stage A1
VGS(A2)
2, 3
gate-source voltage of stage A2
RF_IN_A
4
RF input path A
VGS(A1)
5, 6
gate-source voltage of stage A1
n.c.
7
not connected
n.c.
8
not connected
VGS(B1)
9, 10
gate-source voltage of stage B1
RF_IN_B
11
RF input path of B
VGS(B2)
12, 13 gate-source voltage of stage B2
VDS(B1)
14
drain-source voltage of stage B1
RF_OUT_B/VDS(B2)
15
RF output path B / drain source voltage of stage B2
RF_OUT_A/VDS(A2)
16
RF output path A / drain source voltage of stage A2
GND
flange RF ground
All information provided in this document is subject to legal disclaimers.
© Ampleon Netherlands B.V. 2018. All rights reserved.
2 of 13
BLM2425M7S60P
3. Ordering information
Table 3.
Type number
Package
Name Description
BLM2425M7S60P -
Version
plastic, heatsink small outline package; 16 leads (flat)
SOT1211-3
4. Block diagram
VDS(A1)
RF_OUT_A / VDS(A2)
RF_IN_A
VGS(A1)
VGS(A2)
VGS(B2)
VGS(B1)
RF_OUT_B / VDS(B2)
RF_IN_B
VDS(B1)
aaa-018263
Fig 2.
Block diagram of BLM2425M7S60P
5. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDS
VGS
Min
Max
Unit
65
V
gate-source voltage
0.5
+13
V
VGS(sense)
sense gate-source voltage
0.5
+9
V
Tstg
storage temperature
65
+150
C
225
C
150
C
Tj
junction temperature
Tcase
case temperature
[1]
BLM2425M7S60P
Product data sheet
Conditions
[1]
Continuous use at maximum temperature will affect the reliability, for details refer to the online MTF
calculator.
3 of 13
BLM2425M7S60P
6. Thermal characteristics
Table 5.
Measured for total device.
Symbol Parameter
Rth(j-c)
[1]
Conditions
thermal resistance from
junction to case
Value Unit
final stage; Tcase = 90 C; PL = 60 W
[1]
0.91
K/W
When operated with a CW signal.
7. Characteristics
Table 6.
DC characteristics
Tcase = 25 °C; per section unless otherwise specified.
Symbol
Parameter
Conditions
Min Typ
Max Unit
Final stage
V(BR)DSS
drain-source breakdown voltage VGS = 0 V; ID = 0.422 mA
65
V
VGS(th)
gate-source threshold voltage
VDS = 10 V; ID = 42 mA
1.5
1.9
2.3
V
VGSq
gate-source quiescent voltage
VDS = 28 V; ID = 253 mA
1.7
2.1
2.5
V
IDSS
drain leakage current
VGS = 0 V; VDS = 28 V
1.4
A
IDSX
drain cut-off current
VGS = VGS(th) + 3.75 V;
VDS = 10 V
7.8
A
IGSS
gate leakage current
VGS = 11 V; VDS = 0 V
140
nA
gfs
forward transconductance
VDS = 10 V; ID = 1478 mA
2.85 -
S
RDS(on)
drain-source on-state resistance VGS = VGS(th) + 3.75 V;
ID = 1.48 A
350
m
IDq
quiescent drain current
208 233
257
mA
main transistor: VDS = 28 V
sense transistor: ID = 7 mA;
VDS = 28 V
Driver stage
V(BR)DSS
drain-source breakdown voltage VGS = 0 V; ID = 0.116 mA
65
V
VGS(th)
VDS = 10 V; ID = 11.6 mA
1.4
1.9
2.4
V
VGSq
VDS = 28 V; ID = 69.6 mA
1.7
2.1
2.5
V
IDSS
1.4
A
IDSX
VDS = 10 V
2.2
A
IGSS
140
nA
gfs
VDS = 10 V; ID = 406 mA
0.8
S
RDS(on)
ID = 0.4 A
2350 -
m
IDq
67
75
mA
83
VDS = 28 V
BLM2425M7S60P
Product data sheet
4 of 13
BLM2425M7S60P
Table 7.
RF Characteristics
Test signal: CW at f = 2450 MHz; RF performance at VDS = 32 V; IDq1 = 25 mA; IDq2 = 50 mA;
Tcase = 25 °C; per section unless otherwise specified; in a class-AB production circuit.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Gp
power gain
PL = 30 W
26
27.5
dB
D
drain efficiency
PL = 30 W
41.5
45
RLin
input return loss
PL = 30 W
18
13.8 dB
8. Test information
8.1 Ruggedness
The BLM2425M7S60P is capable of withstanding a load mismatch corresponding to
VSWR = 15 : 1 through all phases under the following conditions: VDS = 32 V;
IDq1 = 25 mA; IDq2 = 50 mA; f = 2450 MHz; per section unless otherwise specified.
8.2 Impedance information
Table 8.
Typical impedance
Measured load-pull data. Typical values per section unless otherwise specified.
ZS [1]
f
ZL [1]
(MHz)
(Ω)
(Ω)
2400
19.1 + j43.2
5.3 j2.4
2450
16.8 + j38.8
5.0 j2.3
2500
14.4 + j33.0
4.4 j2.4
[1]
ZS and ZL defined in Figure 3
drain
ZL
gate
ZS
001aaf059
Fig 3.
BLM2425M7S60P
Product data sheet
Definition of transistor impedance
5 of 13
BLM2425M7S60P
8.3 Test circuit
90 mm
C24
C16
C22
C11
C7
C26
C20
C5
C27
C8
R1
C1
C18
C3
R2
C13 C14
R3
C4
R4
C2
C9
90 mm
C17
C28
C6
C25
C10
C19
C21
C12
C23
C15
amp00796
Printed-Circuit Board (PCB): Rogers RO4350; r = 3.48; height = 0.762 mm; thickness copper
plating = 35 m.
See Table 9 for a list of components.
Fig 4.
Component layout
Table 9.
List of components
See Figure 4 for component layout.
Component
Description
Value
C1, C2
multilayer ceramic chip capacitor
1 pF
C3, C4, C5, C6
1 F, 50 V
Remarks
[1]
Murata: GRM32RR71H105KA01L
C7, C10
8.2 pF
[2]
C8, C9, C13, C14
8.2 pF
[1]
C11, C12, C21, C22
10 F, 50 V
C15, C16, C23, C24
electrolytic capacitor
220 F, 63 V
[2]
C17, C18
1.6 pF
[2]
C19, C20, C25, C26
8.2 pF
[2]
C27, C28
0.4 pF
[2]
R1, R2, R3, R4
SMD resistor
[1]
American Technical Ceramics type 100A or capacitor of same quality
[2]
American Technical Ceramics type 100B or capacitor of same quality
BLM2425M7S60P
Product data sheet
SMD 0805
6 of 13
BLM2425M7S60P
8.4 Graphical data
Performance curves are measured per section.
aaa-017619
29
50
Gp
(dB)
27
25
(1)
(1)
(2)
(2)
(3)
(3)
Gp
23
21
ηD
19
25
30
35
40
45
PL (dBm)
aaa-017620
28
ηD
Gp
(dB)
27
30
26
10
24
50
40
30
(1)
(2)
(3)
(1)
(2)
(3)
Gp
10
VDS = 32 V; IDq1 = 25 mA; IDq2 = 50 mA.
10
40
PL (W)
50
(1) f = 2400 MHz
(2) f = 2450 MHz
(2) f = 2450 MHz
(3) f = 2500 MHz
(3) f = 2500 MHz
Power gain and drain efficiency as function of
output power; typical values
Fig 6.
aaa-017622
50
ηD
ηD
40
(1) f = 2400 MHz
Fig 5.
50
PL
(dBm)
45
aaa-017624
35
Gp
(dB)
30
40
25
(1)
(2)
(3)
35
15
25
10
15
Pi (dBm)
10
2300
30
2350
2400
2450
2500
2550
f (MHz)
2600
VDS = 32 V; IDq1 = 25 mA; IDq2 = 50 mA; PL = 30 W.
(1) f = 2400 MHz
(2) f = 2450 MHz
(3) f = 2500 MHz
Fig 7.
Output power as a function of input power;
typical values
BLM2425M7S60P
Product data sheet
Fig 8.
Power gain as a function of frequency; typical
values
7 of 13
BLM2425M7S60P
9. Package outline
SOT1211-3
(18.01)
(2.15)
(15.44)
(0.75)
7.45
15
16
A
L 0.05 A
R1.38
9.96(1)
16.00
9.78
15.96 B0.20
(7.04)
(4.47)
E 0.10 (4)
P2.00 0.1Z
R0.16 max.
1
14
1.50
1.00 (12x)
0.35 (14x) (3)
20.75(1)
R1.00
0.10
metal protrusion 4x
(ground) in corners (2)
1.57 (5)
0.22 B0.05
L 0.25 B
+0.08
3.92 - 0.03
L 0.05 B
R0.32
B
20.57
Min. 5.5
Min. 7.8
(0.20) molding compound around
the perimeter of the heatsink
R0.60(4x)
pin 17 (6)
L 0.25 B
5.50 (3)
Min. 15.5
Min. 18.5
Package outline drawing:
units in mm.
Tolerances unless otherwise stated:
Revision:
Angle: B 1° Revision date:
Dimension: B 0.05
SOT1211-3
Fig 9.
Third angle projection
1
7/26/2018
Sheet 1 of 2
Package outline SOT1211-3 (sheet 1 of 2)
BLM2425M7S60P
Product data sheet
8 of 13
BLM2425M7S60P
SOT1211-3
Drawing Notes
Description
Items
Dimensions are excluding mold protrusion. Areas located adjacent to the leads have a maximum mold protrusion of 0.25
(1)
mm (per side) and 0.62 mm max. in length. In between the 14 leads the protrusion is 0.25 mm. max. At all other areas the
(2)
The metal protrusion (tie bars) in the corner will not stick out of the molding compound protrusions (detail A).
(3)
The lead dambar (metal) protrusions are not included. Add 0.14 mm max to the total lead dimension at the dambar location.
(4)
The lead coplanarity over all leads is 0.1 mm maximum.
(5)
Dimension is measured 0.5 mm from the edge of the top package body.
(6)
The hatched area indicates the exposed metal heatsink.
(7)
The leads and exposed heatsink are plated with matte Tin (Sn).
mold protrusion is maximum 0.15 mm per side. See also detail B.
location of metal protrusion (2)
DETAIL A
SCALE 25:1
B
A
0 .2
a
5m
x. (
1)
lead dambar
location
2m
5
0.1
ax
ma
x.
m
.2 5
ax
. (1
(1)
(1)
DETAIL B
SCALE 50:1
units in mm.
Revision:
Dimension: B 0.05
SOT1211-3
1
7/26/2018
Sheet 2 of 2
Fig 10. Package outline SOT1211-3 (sheet 2 of 2)
BLM2425M7S60P
Product data sheet
9 of 13
BLM2425M7S60P
10. Handling information
CAUTION
This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling
electrostatic sensitive devices.
Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or
equivalent standards.
Table 10.
ESD sensitivity
ESD model
Class
Charged Device Model (CDM); According to ANSI/ESDA/JEDEC standard JS-002
C2A [1]
Human Body Model (HBM); According to ANSI/ESDA/JEDEC standard JS-001
1A [2]
[1]
CDM classification C2A is granted to any part that passes after exposure to an ESD pulse of 500 V.
[2]
HBM classification 1A is granted to any part that passes after exposure to an ESD pulse of 250 V.
11. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CW
Continuous Wave
ESD
LDMOS
Laterally Diffused Metal Oxide Semiconductor
MMIC
Monolithic Microwave Integrated Circuit
MTF
Median Time to Failure
RoHS
Restriction of Hazardous Substances
SMD
Surface Mounted Device
VSWR
Voltage Standing Wave Ratio
12. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BLM2425M7S60P v.5
20180913
Product data sheet
BLM2425M7S60P v.4
Modifications:
Figure 1 on page 2; figure updated
Table 3 on page 3; package outline version changed from SOT1211-2 to SOT1211-3
Figure 4 on page 6; figure updated
Section 9 on page 8; package outline version changed from SOT1211-2 to SOT1211-3
BLM2425M7S60P v.4
20170629
Product data sheet
BLM2425M7S60P v.3
BLM2425M7S60P v.3
20150909
Product data sheet
BLM2425M7S60P#2
BLM2425M7S60P#2
20150901
Objective
BLM2425M7S60P v.1
BLM2425M7S60P v.1
20150518
Objective data sheet
BLM2425M7S60P
Product data sheet
10 of 13
BLM2425M7S60P
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.ampleon.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Ampleon does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Ampleon sales office. In
case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Ampleon and its customer, unless Ampleon and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be valid
in which the Ampleon product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Ampleon does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Ampleon takes no responsibility for
the content in this document if provided by an information source outside of
Ampleon.
In no event shall Ampleon be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost profits,
lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Ampleon’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Ampleon.
Right to make changes — Ampleon reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Ampleon products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction of an
BLM2425M7S60P
Product data sheet
Ampleon product can reasonably be expected to result in personal injury,
death or severe property or environmental damage. Ampleon and its
suppliers accept no liability for inclusion and/or use of Ampleon products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Ampleon makes no representation
or warranty that such applications will be suitable for the specified use without
further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Ampleon products, and Ampleon accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Ampleon product is suitable and
fit for the customer’s applications and products planned, as well as for the
planned application and use of customer’s third party customer(s). Customers
should provide appropriate design and operating safeguards to minimize the
risks associated with their applications and products.
Ampleon does not accept any liability related to any default, damage, costs or
problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Ampleon products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Ampleon does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Ampleon products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.ampleon.com/terms, unless otherwise agreed in a valid written
individual agreement. In case an individual agreement is concluded only the
terms and conditions of the respective agreement shall apply. Ampleon
hereby expressly objects to applying the customer’s general terms and
conditions with regard to the purchase of Ampleon products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
11 of 13
BLM2425M7S60P
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Ampleon product is automotive qualified, the product
is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Ampleon
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Ampleon’s warranty of the product for such
automotive applications, use and specifications, and (b) whenever customer
uses the product for automotive applications beyond Ampleon’s specifications
such use shall be solely at customer’s own risk, and (c) customer fully
indemnifies Ampleon for any liability, damages or failed product claims
resulting from customer design and use of the product for automotive
applications beyond Ampleon’s standard warranty and Ampleon’s product
specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Any reference or use of any ‘NXP’ trademark in this document or in or on the
surface of Ampleon products does not result in any claim, liability or
entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of
the NXP group of companies and any reference to or use of the ‘NXP’
trademarks will be replaced by reference to or use of Ampleon’s own
trademarks.
14. Contact information
For more information, please visit: http://www.ampleon.com
For sales office addresses, please visit: http://www.ampleon.com/sales
BLM2425M7S60P
Product data sheet
12 of 13
BLM2425M7S60P
15. Contents
1
1.1
1.2
1.3
2
2.1
2.2
3
4
5
6
7
8
8.1
8.2
8.3
8.4
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 3
Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5
Ruggedness . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Impedance information . . . . . . . . . . . . . . . . . . . 5
Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Handling information. . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
Date of release: 13 September 2018
Document identifier: BLM2425M7S60P
