NJG1103F1-TE1
NJG1103F1-TE1
    NJR(新日本无线)
    MTP6
    IC MMIC AMP 1.5/1.9GHZ MTP6
NJG1103F1-TE1 数据手册
NJG1103F1 1.5/1.9GHz LOW NOISE AMPLIFIER GaAs MMIC nGENERAL DESCRIPTION NJG1103F1 is a Low Noise Amplifier GaAs MMIC designed for 1.5GHz and 1.9GHz band digital cellular phone and Japanese PHS handsets. This amplifier provides low noise figure, high gain and high IP3 operated by single low positive power supply. This amplifier can be tuned to wide frequency point. (Best for 1.5GHz or 1.9GHz) Small package of MTP6-1 is adopted. nFEATURES lLow voltage operation lLow current consumption lHigh small signal gain nPACKAGE OUTLINE NJG1103F1 +2.7V typ. 3mA typ. 16dB typ. @f=1.489GHz 14dB typ. @f=1.9GHz 1.2dB typ. @f=1.489GHz 1.4dB typ. @f=1.9GHz -4dBm typ. @f=1.489+1.4891GHz -3dBm typ. @f=1.9+1.9001GHz +12dBm typ. @f=1.489+1.4891GHz +11dBm typ. @f=1.9+1.9001GHz MTP6-1 (Mount Size: 2.8 x 2.9 x 1.2mm) lLow Noise Figure lHigh Input IP3 lHigh Output IP3 lPackage nPIN CONFIGURATION F1 TYPE (Top View) 1 6 Pin connection 2 5 3 4 Note: 1.LNAOUT 2.EXTIND 3.GND 4.GND 5.GND 6.LNAIN is package orientation mark. -1- NJG1103F1 nABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL Drain Voltage Input Power VDD Pin Power Dissipation Operating Temperature Storage Temperature (Ta=+25°C, Zs=Zl=50Ω) RATINGS UNITS CONDITIONS 5.0 +10 V dBm PD Topr 150 -40~+85 mW °C Tstg -55~+125 °C VDD=2.7V nELECTRICAL CHARACTERISTICS 1 (1.5GHz Band) (VDD=2.7V, f=1.489GHz, Ta=+25°C, Zs=Zl=50Ω, Circuit: Application 1) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Operating Frequency Drain Voltage freq1 VDD Operating Current Small Signal Gain Gain Flatness Noise Figure Pout at 1dB Gain Compression point Input 3rd Order Intercept Point LNAIN Port VSWR LNAOUT Port VSWR IDD Gain Gflat NF RF OFF f=1.47~1.52GHz P-1dB IIP3 f=1.489+1.4891GHz VSWRi VSWRo 1.470 2.5 1.489 2.7 1.520 4.5 GHz V 14.0 - 3.0 16.0 0.5 1.2 3.8 18.0 1.0 1.4 mA dB dB dB -6.0 -2.0 - dBm -7.0 -4.0 - dBm - 2.0 2.0 3.0 3.0 nELECTRICAL CHARACTERISTICS 2 (1.9GHz Band) (VDD=2.7V, f=1.9GHz, Ta=+25°C, Zs=Zl=50Ω, Circuit: Application 2) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Operating Frequency freq2 1.89 1.90 1.92 GHz Drain Voltage VDD 2.5 2.7 4.5 V Operating Current IDD RF OFF 3.0 3.8 mA Small Signal Gain Gain Flatness Noise Figure Pout at 1dB Gain Compression point Input 3rd Order Intercept Point LNAIN Port VSWR LNAOUT Port VSWR -2- Gain Gflat NF 12.0 - 14.0 0.5 1.4 16.0 1.0 1.6 dB dB dB -4.5 -0.5 - dBm -6.0 -3.0 - dBm VSWRi - 2.0 3.0 VSWRo - 2.0 3.0 f=1.89~1.92GHz P-1dB IIP3 f=1.9+1.9001GHz NJG1103F1 (1.5GHz Band) S21,S11,S22,S12 vs. frequency NF,Gain vs.frequency (V =2.7V,I =3.0mA) (V =2.7V,I =3.0mA) DD 2.6 DD 2.2 16 15 2 14 1.8 12 1.6 10 1.4 8 1.2 6 NF(dB) 1 S21,S11,S22(dB) 20 Gain Gain(dB) 18 2.4 40 30 S21 S22 -10 -5 -20 0.6 0 1.4 1.42 1.44 1.46 1.48 1.5 1.52 1.54 1.56 1.58 1.6 -25 S11 S12 0.5 0.75 1 1.25 1.5 -40 1.75 2 2.25 -50 2.5 frequency(GHz) Pin vs. Pout,IM3 (V =2.7V,I =3.0mA,f=1489+1489.1MHz) (V =2.7V,I =3.0mA,freq=1.489GHz) DD DD 10 5 0 0 -10 Pout,IM3(dBm) Pout(dBm) -20 -30 Pin vs. Pout P-1dB=-1.1dBm -5 10 0 -10 -15 DD 20 0 2 10 50 5 4 frequency(GHz) DD 10 0.8 NF DD 25 20 S12(dB) nTYPICAL CHARACTERISTICS -10 -15 DD Pout -20 IM3 -30 -40 -20 -50 -25 -60 -30 -40 -70 -40 IIP3=-3.8dBm -35 -30 -25 -20 -15 -10 -5 0 -35 -30 -25 Pin(dBm) -20 -15 -10 -5 0 Pin(dBm) Gain vs. V NF,I DD ( f=1.489GHz ) DD vs. V DD ( f=1.489GHz ) 17 1.2 3.4 1.1 3.3 15 14.5 3.2 0.9 3.1 0.8 3 I DD 14 2.5 3 3.5 4 V (V) DD 4.5 5 0.7 2.5 2.9 3 3.5 4 4.5 5 V (V) DD -3- DD 15.5 1 I (mA) NF 16 NF(dB) Gain(dB) 16.5 NJG1103F1 nTYPICAL CHARACTERISTICS -4- (1.5GHz Band) NJG1103F1 nTYPICAL CHARACTERISTICS (1.5GHz Band) S21 vs. frequency(~20GHz) S12 vs. frequency(~20GHz) (V =2.7V,I =3.0mA) DD (V =2.7V,I =3.0mA) DD DD 50 20 40 15 30 10 20 S12(dB) S21(dB) 25 5 0 -5 10 0 -10 -10 -20 -15 -30 -20 -40 -25 -50 0 2 4 6 8 10 12 14 16 18 20 0 2 4 frequency(GHz) 8 10 12 14 16 18 20 S22 vs. frequency(~20GHz) (VDD =2.7V,IDD =3.0mA) 25 6 frequency(GHz) S11 vs. frequency(~20GHz) (VDD =2.7V,IDD =3.0mA) 25 20 20 15 15 10 10 S22(dB) S11(dB) DD 5 0 -5 5 0 -5 -10 -10 -15 -15 -20 -20 -25 -25 0 2 4 6 8 10 12 14 frequency(GHz) 16 18 20 0 2 4 6 8 10 12 14 16 18 20 frequency(GHz) -5- NJG1103F1 nTYPICAL CHARACTERISTICS (1.5GHz Band) Scattering Parameter Table 1 VDD=2.7V, IDD=3.0mA, Zo=50Ω S11 S21 Freq mag ang mag ang (GHz) (units) (deg) (units) (deg) 0.1 1.000 -3.577 0.030 -96.974 0.2 1.000 -7.804 0.008 29.498 0.3 1.000 -11.749 0.017 -17.030 0.4 1.000 -15.677 0.039 -22.484 0.5 1.000 -18.892 0.069 -35.493 0.6 1.000 -22.855 0.105 -43.917 0.7 0.989 -25.943 0.148 -52.340 0.8 1.000 -29.192 0.211 -60.102 0.9 0.967 -32.626 0.283 -68.097 1.0 0.978 -34.942 0.384 -76.173 1.1 0.952 -38.109 0.517 -84.022 1.2 0.958 -40.122 0.721 -92.837 1.3 0.939 -42.825 1.026 -103.156 1.4 0.944 -45.403 1.595 -118.935 1.5 0.912 -49.324 2.620 -147.296 1.6 0.848 -51.073 3.159 163.534 1.7 0.835 -48.490 2.335 124.924 1.8 0.854 -48.500 1.669 105.980 1.9 0.859 -49.077 1.305 94.208 2.0 0.856 -49.978 1.080 86.597 2.1 0.858 -50.862 0.930 79.499 2.2 0.843 -51.565 0.827 74.248 2.3 0.843 -52.644 0.752 69.058 2.4 0.825 -53.066 0.693 65.124 2.5 0.823 -54.104 0.651 60.824 2.6 0.806 -54.425 0.618 56.840 2.7 0.805 -55.530 0.592 52.933 2.8 0.793 -56.240 0.567 49.451 2.9 0.783 -57.285 0.550 45.760 3.0 0.778 -58.456 0.536 41.775 4 S12 mag ang (units) (deg) 0.000 -28.893 0.001 123.060 0.001 90.574 0.001 61.254 0.002 70.970 0.002 68.009 0.002 71.027 0.002 52.546 0.001 54.258 0.001 65.410 0.001 -172.907 0.001 -143.350 0.004 -145.335 0.008 -153.556 0.017 -174.933 0.026 141.392 0.023 107.004 0.018 92.352 0.015 84.686 0.014 83.498 0.013 82.364 0.012 82.389 0.012 82.449 0.012 84.137 0.011 87.269 0.012 89.464 0.012 91.483 0.013 93.498 0.013 92.174 0.013 94.705 3 8.2nH S11 5 2 6 1 Ref. 1000pF VDD S22 Ref. Scattering Parameter Evaluation Circuit -6- S22 mag (units) 1.000 1.000 1.000 1.000 1.000 1.000 0.999 0.999 0.993 0.992 0.990 0.979 0.960 0.893 0.647 0.117 0.638 0.834 0.896 0.933 0.941 0.958 0.959 0.969 0.967 0.975 0.974 0.980 0.975 0.980 ang (deg) -3.994 -8.157 -11.932 -15.939 -19.427 -23.659 -27.163 -31.190 -34.941 -39.139 -43.543 -48.600 -55.801 -67.092 -88.575 -8.962 -2.204 -16.766 -24.947 -30.122 -33.659 -36.464 -38.653 -40.685 -42.276 -44.085 -45.755 -47.284 -48.847 -50.377 NJG1103F1 (1.9GHz Band) NF,Gain vs.frequency S21,S11,S22,S12 vs. frequency (V =2.7V,I =3.0mA) DD 2.6 25 2.4 18 20 2.2 16 15 Gain 1.8 12 1.6 10 NF 1.4 Gain(dB) 14 8 1.2 6 1 4 0.8 2 0.6 S21,S11,S22(dB) 20 2 NF(dB) (V =2.7V,I =3.0mA) DD DD 50 40 30 S21 10 20 S22 5 10 0 0 -10 -5 S11 -10 -20 -30 -15 -20 0 1.8 1.82 1.84 1.86 1.88 1.9 1.92 1.94 1.96 1.98 DD 2 -40 S12 -50 -25 1 frequency(GHz) S12(dB) nTYPICAL CHARACTERISTICS 1.25 1.5 1.75 2 2.25 2.5 2.75 3 frequency(GHz) Pin vs. Pout,IM3 Pin vs. Pout (V =2.7V,I =3.0mA,f=1900+1900.1MHz) (V =2.7V,I =3.0mA,freq=1.9GHz) DD 10 10 DD DD 0 5 -10 Pout,IM3(dBm) 0 P-1dB=-0.5dBm -5 -10 -15 Pout -20 -30 IM3 -40 -50 -20 -60 -25 IIP3=-3.2dBm -30 -40 -35 -30 -25 -20 -15 -10 -5 -70 -40 0 -35 -30 -25 Gain vs. V NF,I DD ( f=1.9GHz ) -15 -10 -5 0 DD vs. V DD ( f=1.9GHz ) 15 1.4 3.4 14.5 NF 1.3 3.3 14 13.5 13 1.2 3.2 1.1 3.1 1 12.5 3 I DD 12 2.5 3 3.5 4 V (V) DD 4.5 5 0.9 2.5 2.9 3 3.5 4 4.5 5 V (V) DD -7- DD NF(dB) Gain(dB) -20 Pin(dBm) Pin(dBm) I (mA) Pout(dBm) DD NJG1103F1 nTYPICAL CHARACTERISTICS -8- (1.9GHz Band) NJG1103F1 nTYPICAL CHARACTERISTICS (1.9GHz Band) S12 vs. frequency(~20GHz) S21 vs. frequency(~20GHz) (V =2.7V,I =3.0mA) (V =2.7V,I =3.0mA) DD DD DD 50 20 40 15 30 10 20 S12(dB) S21(dB) 25 5 0 -5 10 0 -10 -10 -20 -15 -30 -20 -40 -50 -25 0 2 4 6 8 10 12 14 16 18 0 20 2 4 6 8 10 12 14 16 18 frequency(GHz) frequency(GHz) S11 vs. frequency(~20GHz) S22 vs. frequency(~20GHz) DD 20 (V =2.7V,I =3.0mA) (V =2.7V,I =3.0mA) 25 DD DD 25 20 20 15 15 10 10 S22(dB) S11(dB) DD 5 0 -5 5 0 -5 -10 -10 -15 -15 -20 -20 -25 DD -25 0 2 4 6 8 10 12 14 frequency(GHz) 16 18 20 0 2 4 6 8 10 12 14 16 18 20 frequency(GHz) -9- NJG1103F1 nTYPICAL CHARACTERISTICS (1.9GHz Band) Scattering Parameter Table 2 VDD=2.7V, IDD=3.0mA, Zo=50Ω S11 S21 Freq mag ang mag ang (GHz) (units) (deg) (units) (deg) 0.1 1.000 -3.466 0.013 -99.853 0.2 1.000 -7.836 0.003 120.878 0.3 1.000 -11.376 0.011 -23.230 0.4 1.000 -15.369 0.024 -31.645 0.5 1.000 -18.524 0.045 -34.983 0.6 1.000 -22.254 0.068 -44.466 0.7 0.987 -25.261 0.096 -51.466 0.8 0.994 -28.510 0.134 -58.880 0.9 0.962 -31.527 0.173 -65.887 1.0 0.972 -33.806 0.227 -72.166 1.1 0.946 -36.765 0.287 -80.123 1.2 0.951 -38.499 0.370 -86.666 1.3 0.931 -40.743 0.466 -93.543 1.4 0.936 -42.455 0.612 -101.148 1.5 0.922 -44.128 0.816 -109.855 1.6 0.927 -46.084 1.122 -120.983 1.7 0.915 -48.182 1.603 -137.240 1.8 0.900 -50.392 2.281 -162.468 1.9 0.853 -51.550 2.711 159.780 2.0 0.829 -50.493 2.315 125.880 2.1 0.835 -49.844 1.803 104.689 2.2 0.829 -49.732 1.426 91.557 2.3 0.834 -50.427 1.192 82.277 2.4 0.821 -50.628 1.027 75.650 2.5 0.821 -51.483 0.922 69.553 2.6 0.806 -51.476 0.841 64.184 2.7 0.805 -52.354 0.782 59.683 2.8 0.798 -52.928 0.731 55.213 2.9 0.786 -53.597 0.692 51.129 3.0 0.784 -54.637 0.665 46.939 4 S12 mag ang (units) (deg) 0.001 -40.688 0.000 111.001 0.001 77.901 0.001 60.826 0.002 73.639 0.002 64.832 0.002 59.880 0.002 62.909 0.002 62.762 0.001 64.214 0.001 59.903 0.000 104.075 0.001 -144.742 0.002 -131.875 0.004 -140.321 0.007 -150.577 0.012 -161.035 0.018 -178.320 0.026 152.338 0.026 124.607 0.023 107.196 0.020 99.244 0.018 94.680 0.017 92.857 0.016 91.557 0.015 91.315 0.015 91.885 0.014 91.583 0.015 95.367 0.015 101.051 3 5.6nH S11 5 2 6 1 Ref. 1000pF VDD S22 Ref. Scattering Parameter Evaluation Circuit - 10 - S22 mag ang (units) (deg) 1.000 -3.792 1.000 -7.797 1.000 -11.547 1.000 -15.222 1.000 -18.774 1.000 -22.517 0.998 -25.988 0.997 -29.586 0.994 -32.980 0.994 -36.537 0.993 -40.081 0.990 -43.600 0.987 -47.623 0.979 -52.301 0.962 -58.048 0.927 -66.488 0.830 -79.157 0.584 -100.354 0.052 -128.112 0.468 12.049 0.718 -6.837 0.827 -17.772 0.876 -24.741 0.906 -29.743 0.920 -33.371 0.934 -36.756 0.939 -39.453 0.947 -41.774 0.945 -43.991 0.955 -46.322 NJG1103F1 nRECOMMEND CIRCUIT 1 (1.5GHz Band) 4 3 8.2nH Zo=50Ω IN 5 2 6 1 1000pF VDD Zo=50Ω OUT 10nH 8.2nH nRECOMMEND CIRCUIT 2 (1.9GHz Band) 4 3 5.6nH Zo=50Ω IN 5 2 6 1 5.6nH 1000pF VDD Zo=50Ω OUT 4.7nH - 11 - NJG1103F1 nRECOMMENDED PCB DESIGN C1 (Top View) L3 L1 IN VDD OUT L2 PCB : FR4, t=0.2mm MICROSTRIP LINE WIDTH=0.4mm(Z0=50Ω) PCB SIZE : 14.0x14.0mm PARTS LIST - 12 - PARTS ID 1.5GHz 1.9GHz COMMENT L1 8.2nH 4.7nH TAIYO-YUDEN (HK1005) L2 10nH 5.6nH TAIYO-YUDEN (HK1005) L3 8.2nH 5.6nH TAIYO-YUDEN (HK1005) C1 1000pF 1000pF MURATA (GRM36) NJG1103F1 nPACKAGE OUTLINE (MTP6-1) Lead material Lead surface finish Molding material UNIT Weight Cautions on using this product This product contains Gallium-Arsenide (GaAs) which is a harmful material. • Do NOT eat or put into mouth. • Do NOT dispose in fire or break up this product. • Do NOT chemically make gas or powder with this product. • To waste this product, please obey the relating law of your country. : Copper : Solder plating : Epoxy resin : mm : 15mg [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. This product may be damaged with electric static discharge (ESD) or spike voltage. Please handle with care to avoid these damages. - 13 -
NJG1103F1-TE1 价格&库存
很抱歉,暂时无法提供与“NJG1103F1-TE1”相匹配的价格&库存,您可以联系我们找货
