BLM6G10-30,118
BLM6G10-30,118
    AMPLEON(安谱隆)
    SOT834-1
    TRANS SOT834-1
BLM6G10-30,118 数据手册
BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 30 W LDMOS 2-stage power MMIC for base station applications at frequencies from 860 MHz to 960 MHz. Available in Gull Wing for surface mount (SOT822-1) or flat lead (SOT834-1). Table 1. Application information Typical RF performance at Th = 25 C. Mode of operation 2-carrier W-CDMA [1] f VDS PL(AV) Gp D IMD3 ACPR (MHz) (V) (W) (dB) (%) (dBc) (dBc) f1 = 935; f2 = 945 28 2 29 11.5 48.5[1] 52[1] Test signal: 3GPP; test model 1; 64 DPCH; PAR = 7 dB at 0.01 % probability on CCDF per carrier; carrier spacing 10 MHz. CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features and benefits  Typical 2-carrier W-CDMA performance at a frequency of 940 MHz:  Average output power = 2 W  Gain = 29 dB (typ)  Efficiency = 11.5 %  IMD3 = 48.5 dBc  ACPR = 52 dBc  Integrated temperature compensated bias  Excellent thermal stability  Biasing of individual stages is externally accessible  Integrated ESD protection  Small component size, very suitable for PA size reduction  On-chip matching (input matched to 50 , output partially matched)  High power gain  Designed for broadband operation (860 MHz to 960 MHz) BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 2. Pinning information 2.1 Pinning BLM6G10-30 BLM6G10-30G GND 1 VDS1 2 n.c. 3 n.c. 4 n.c. 5 RF input 6 n.c. 7 VGS1 8 VGS2 9 16 GND 15 n.c. 14 RF output/VDS2 13 n.c. VDS1 10 GND 11 12 GND 001aak500 Transparent top view Fig 1. Pin configuration 2.2 Pin description Table 2. Pin description Pin Description 1, 11, 12, 16 GROUND 2 VDS1 3, 4, 5, 7, 13, 15 n.c. 6 RF_INPUT 8 VGS1 9 VGS2 10 VDS1 14 RF_OUTPUT/VDS2 flange RF_GROUND BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLM6G10-30 - HSOP16F: plastic, heatsink small outline package; 16 leads (flat) SOT834-1 BLM6G10-30G - HSOP16: plastic, heatsink small outline package; 16 leads SOT822-1 4. Block diagram VDS1 RF_input 2 14 6 VGS1 8 VGS2 9 RF_output/VDS2 TEMPERATURE COMPENSATED BIAS 001aan771 Fig 2. Block diagram of BLM6G10-30 and BLM6G10-30G 5. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0 +13 V ID1 first stage drain current - 3 A ID2 second stage drain current - 9 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 6. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Value Unit Rth(j-c)1 first stage thermal resistance from junction to case Tcase = 80 C; PL = 2 W; 2-carrier W-CDMA [1] 7.5 K/W Rth(j-c)2 second stage thermal resistance Tcase = 80 C; PL = 2 W; from junction to case 2-carrier W-CDMA [1] 2.3 K/W [1] Thermal resistance is determined under specific RF operating conditions. BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 7. Characteristics Table 6. Characteristics Mode of operation: 2-carrier W-CDMA; PAR 7 dB at 0.01 % probability on CCDF; 3GPP test model 1; 1-64 PDPCH; f1 = 922.5 MHz; f2 = 932.5 MHz; f3 = 947.5 MHz; f4 = 957.5 MHz; VDS = 28 V; IDq1 = 105 mA; IDq2 = 250 mA; Th = 25 C unless otherwise specified. Symbol Parameter Conditions PL(AV) average output power Gp power gain PL(AV) = 2 W Min Typ Max Unit - 2 - W 27 29 31 dB RLin input return loss PL(AV) = 2 W - 15 12 dB D drain efficiency PL(AV) = 2 W 10 11.5 - % IMD3 third-order intermodulation distortion PL(AV) = 2 W - 48.5 45 dBc ACPR adjacent channel power ratio PL(AV) = 2 W - 52 dBc 48.5 8. Application information 8.1 Ruggedness The BLMG10-30 and BLM6G10-30G are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 32 V; IDq1 = 105 mA; IDq2 = 288 mA; PL = 30 W (CW). 8.2 Impedance information Table 7. Typical impedance f Zi[1] ZL[2] MHz   850 43.6  j0 3  j0.8 860 43.5  j0.25 3.2  j0.7 880 43.4  j0.4 3.4  j0.5 900 43.4  j0.6 3.5  j0.2 920 43.5  j0.9 3.45  j0 940 43.6  j1.3 3.2  j0.1 960 43.6  j1.7 3  j0.1 980 43.6  j2 2.7  j0.1 [1] Device input impedance as measured from gate to ground. [2] Test circuit impedance as measured from drain to ground. BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 8.3 Performance curves Performance curves are measured in a BLM6G10-30G application circuit. 001aak501 35 15 ηD (%) Gp (dB) 33 13 001aak502 −46 IMD3, ACPR (dBc) IMD3 −48 ηD 31 11 Gp −50 29 9 ACPR −52 27 7 25 880 920 5 1000 960 −54 880 920 960 f (MHz) Tcase = 25 C; VDS = 28 V; PL(AV) = 2 W; IDq1 = 105 mA; IDq2 = 288 mA; carrier spacing = 10 MHz. Fig 3. 2-carrier W-CDMA power gain and drain efficiency as function of frequency; typical values 001aak503 36 Gp (dB) 34 32 Gp (1) 30 (1) (2) (3) Gp (2) 56 ηD (%) 48 40 Tcase = 25 C; VDS = 28 V; PL(AV) = 2 W; IDq1 = 105 mA; IDq2 = 288 mA; carrier spacing = 10 MHz. Fig 4. 2-carrier W-CDMA adjacent channel power ratio (5 MHz) and adjacent channel power ratio (10 MHz) as function of frequency; typical values 001aak504 −20 Gp (dB) −30 32 −40 28 24 (3) (2) (1) IMD3 Gp (3) 26 16 24 (3) (2) (1) ACPR 0 1 −50 8 ηD 22 10−1 102 10 −60 10−1 PL(AV) (W) 1 102 10 PL(AV) (W) VDS = 28 V; IDq1 = 105 mA; IDq2 = 288 mA; f = 940 MHz; carrier spacing = 10 MHz. (1) Tcase = 30 C VDS = 28 V; IDq1 = 105 mA; IDq2 = 288 mA; f = 940 MHz; carrier spacing = 10 MHz. (1) Tcase = 30 C (2) Tcase = 25 C (2) Tcase = 25 C (3) Tcase = 85 C (3) Tcase = 85 C Fig 5. 1000 f (MHz) 2-carrier W-CDMA power gain and drain efficiency as function of average output power and temperature; typical values Fig 6. 2-carrier W-CDMA adjacent power channel ratio and third order intermodulation distortion as function of average output power and temperature; typical values BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 001aak505 31 Gp (dB) 001aak506 −20 IMD (dBc) −30 (1) (2) (3) 29 −40 27 IMD3 −50 (4) (5) (6) −60 25 −70 IMD5 23 IMD7 −80 21 0 10 20 30 40 50 60 PL (W) −90 10−1 70 1 102 10 PL(PEP) (W) IDq1 = 105 mA; IDq2 = 288 mA. IDq1 = 105 mA; IDq2 = 288 mA; f1 = 940 MHz; f2 = 940.1 MHz. (1) f = 940 MHz; VDS = 24 V (2) f = 940 MHz; VDS = 28 V (3) f = 940 MHz; VDS = 32 V (4) f = 880 MHz; VDS = 24 V (5) f = 880 MHz; VDS = 28 V (6) f = 880 MHz; VDS = 32 V Fig 7. One-tone CW power gain as function of output power and drain-source voltage; typical value Fig 8. Two-tone CW intermodulation distortion as function of peak envelope load power; typical value 001aak507 60 PL(M) (W) (1) 40 (2) (3) 20 0 820 880 940 f (MHz) 1000 Test signal: IS-95 with pilot, paging, sync and 6 traffic channels (Walsh codes 8 to 13). PAR = 9.7 dB at 0.01 % probability on the CCDF. (1) Tcase = 30 C (2) Tcase = 25 C (3) Tcase = 80 C Fig 9. Single-carrier peak output power (peaks 3 dB compressed) as function of frequency and temperature; typical values BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 8.4 Application circuit BLM6G1030 BOARD 3 DEV REV1 001aan772 Fig 10. Class-AB application circuit BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC C7 C13 VDS1 C18 C12 C14 VDS2 C4 C5 C6 C8 C1 R1 C11 C10 C9 C2 R2 VGS1 VGS2 S1 C3 C16 BLM6G1030 BOARD 3 DEV REV1 C15 C17 001aan773 See Table 8 for list of components. Fig 11. Component layout for class-AB application circuit Table 8. List of components For application circuit, see Figure 11. Printed-Circuit Board (PCB): Rogers 4350B; r = 3.5 F/m; thickness = 0.762 mm; Cu (top/bottom metallization). Component Description Value C1, C2, C5, C13, C16 multilayer ceramic chip capacitor 100 nF C3, C4, C14, C17 multilayer ceramic chip capacitor 4.7 F; 50 V C6, C12, C15 multilayer ceramic chip capacitor 68 pF C7 electrolytic capacitor 220 F; 35 V C8, C9 multilayer ceramic chip capacitor 11 pF [1] C10, C11 multilayer ceramic chip capacitor 4.3 pF [1] C18 electrolytic capacitor 470 F; 35 V R1 SMD resistor 1.5 k R2 SMD resistor 3.3 k [1] Remarks [1] American Technical Ceramics type 100A or capacitor of same quality. BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 9. Test information C17 C11 C18 C9 C13 VDS1 VDS2 C1 C4 C6 C7 C16 C3 R1 C15 C8 C5 R2 S1 C2 VGS1 VGS2 VDS1 C12 BLM6G1030 BOARD 3 JSH REV2 C10 VDS2 C14 001aan774 Striplines are on a Rogers 4350B Printed-Circuit Board (PCB) with r = 3.5; thickness = 0.762 mm. See Table 9 for a list of components. Fig 12. Component layout for 860 MHz to 960 MHz circuit for 2-carrier W-CDMA Table 9. List of components For test circuit see Figure 12. Component Description C1, C2, C13, C14 multilayer ceramic chip capacitor 4.7 F TDK4532X7R1E475Mt020U C3, C4, C5, C11, C12 multilayer ceramic chip capacitor 100 nF Murata X7R or equivalent C6, C9, C10 multilayer ceramic chip capacitor 68 pF [1] C7, C8 multilayer ceramic chip capacitor 11 pF [1] C15 multilayer ceramic chip capacitor 6.2 pF [1] C16 multilayer ceramic chip capacitor 5.1 pF [1] C17, C18 electrolytic capacitor 220 F; 63 V R1 SMD resistor 1.5 k R2 SMD resistor 3.3 k S1 short [1] Value Remarks piece of copper foil American Technical Ceramics type 100A or capacitor of same quality. BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 10. Package outline HSOP16F: plastic, heatsink small outline package; 16 leads (flat) SOT834-1 D A E E2 c y X HE v A D1 e3 (2×) D2 w bp2 16 12 A2 E1 pin 1 index Q1 detail X 1 11 w Z e (6×) bp1 (5×) e1 (2×) e2 (4×) w bp (10×) 0 5 scale Dimensions Unit(1) mm max nom min 10 mm A2 bp bp1 bp2 c D(1) D1 D2 E(1) E1 E2 3.5 0.43 1.09 5.87 0.32 16.0 13.0 1.1 11.1 6.2 2.9 3.2 0.28 0.94 5.72 0.23 15.8 12.6 0.9 10.9 5.8 2.5 e e1 e2 e3 HE Q1 16.2 1.7 15.8 1.5 1.02 1.37 5.69 3.81 References IEC JEDEC JEITA w y Z 2.5 0.25 0.25 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version v 0.1 2.0 sot834-1_po European projection Issue date 03-10-22 10-10-20 SOT834-1 Fig 13. Package outline SOT834-1 BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC HSOP16: plastic, heatsink small outline package; 16 leads SOT822-1 A E D E2 X c y HE v A D1 e3 (2×) D2 bp2 w 16 12 Q A2 E1 A pin 1 index (A3) A1 A4 θ 1 Lp 11 detail X w Z e (6×) e1 (2×) bp1 (5×) e2 (4×) w bp (10×) Q v w y 1.5 0 5 mm max nom min 0.25 0.25 A A1 A2 0.2 3.5 3.6 A3 A4 bp bp1 bp2 c D(1) D1 0.06 0.43 1.09 5.87 0.32 16.0 13.0 D2 E(1) E1 E2 1.1 11.1 6.2 2.9 0.35 0 3.2 e e1 2.5 8° 2.0 0° e3 HE Lp 14.5 1.1 13.9 0.8 1.02 1.37 5.69 3.81 −0.06 0.28 0.94 5.72 0.23 15.8 12.6 0.9 10.9 5.8 2.5 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included Outline version e2 θ 0.1 1.4 scale Dimensions Unit(1) 10 mm Z References IEC JEDEC JEITA sot822-1_po European projection Issue date 07-02-08 10-10-20 SOT822-1 Fig 14. Package outline SOT822-1 BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 11. Handling information 11.1 Moisture sensitivity Table 10. Moisture sensitivity level Test methodology Class JESD-22-A113 3 12. Abbreviations Table 11. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel LDMOS Laterally Diffused Metal Oxide Semiconductor MMIC Monolithic Microwave Integrated Circuit PA Power Amplifier PAR Peak-to-Average power Ratio PDPCH transmission Power of the Dedicated Physical CHannel RF Radio Frequency SMD Surface Mounted Devices VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 13. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BLM6G10-30_BLM6G10-30G#3 20150901 - Modifications: Product data sheet BLM6G10-30_BLM6G10-30G v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLM6G10-30_BLM6G10-30G v.2 20110301 Product data sheet - BLM6G10-30_BLM6G10-30G v.1 20090828 Objective data sheet - BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 BLM6G10-30_BLM6G10-30G v.1 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 15. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLM6G10-30_BLM6G10-30G#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLM6G10-30; BLM6G10-30G W-CDMA 860 MHz - 960 MHz power MMIC 16. Contents 1 1.1 1.2 2 2.1 2.2 3 4 5 6 7 8 8.1 8.2 8.3 8.4 9 10 11 11.1 12 13 14 14.1 14.2 14.3 14.4 15 16 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 3 Block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 4 Ruggedness . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Performance curves . . . . . . . . . . . . . . . . . . . . . 5 Application circuit . . . . . . . . . . . . . . . . . . . . . . . 7 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Handling information. . . . . . . . . . . . . . . . . . . . 12 Moisture sensitivity . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLM6G10-30_BLM6G10-30G#3
BLM6G10-30,118 价格&库存
很抱歉,暂时无法提供与“BLM6G10-30,118”相匹配的价格&库存,您可以联系我们找货
