XBIB-U-DEV
Reference Guide
20 Pin Header
Maps to standard through
hole XBEE pins
Through Hole
XBee Sockets
DS2: DIO12
DS3: DIO11
DS4: DIO4
Programming Header
Header used to program
XBee Programmable
modules
SPI
Only used for
SMT modules
Self Power Module
Advanced users only – will void
warranty. R31 must be depopulated
to power module using V+ and GND
from J2 and J5. Sense lines can be
connected to S+ and S- for sensing
power supplies. CAUTION: Voltage
not regulated. Applying incorrect
voltage can cause fire and serious
injury. See Note 1.
SPI Power
Connect to power
board from 3.3V
Current Testing
Depopulating R31 allows a current
probe to be inserted across P6
terminals. The current though
P6/R31 powers the module only.
Other supporting circuitry is
powered by a different trace.
Reset button
Loopback Jumper
Populating P8 with a loopback
jumper causes transmissions
both from the module and
from the USB to loopback.
DC barrel plug: 6-20V
Module can be powered by
the USB or DC supply.
When plugged in
simultaneously the DC
supply powers the board.
Indicator LEDs
DS5: ON/ SLEEP
User Buttons
Connected to DIO lines
for user implementation
LED Indicator
Yellow: UART Tx, RF Rx
Green: UART Rx, RF Tx
Red: Associate
RSSI Indicator
USB
NOTE 1: Powering board with J2 and J5
without R31 removed can cause shorts if USB
or barrel plug power is connected. Applying
too high of a voltage will destroy electronic
circuitry in the module and other board
components and/or cause injury.
很抱歉,暂时无法提供与“XBIB-U-DEV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+696.315391+90.34635
