RBK-ZW500DEV-EMB2
RBK-ZW500DEV-EMB2
    SIGMADESIGNS
    DEV KIT FOR Z-WAVE 500SERIES
RBK-ZW500DEV-EMB2 数据手册
Embedded Dev Kits | Z-Wave | Sigma Designs Page 1 of 10 Z-WAVE EMBEDDED DEVELOPMENT KIT For Embedded Z-Wave Software and Hardware Development Sigma Designs' Z-Wave Embedded Development Kit consists of the hardware and software tools required for Z-Wave embedded product development. The Z-Wave Embedded Development Kit includes sample embedded applications for quick prototyping, Z-Wave protocol sniffer tools for analyzing and resolving issues, and Z-Wave RF modules for building prototypes. The Z-Wave Embedded Development Kit is comprised of two hardware kits and an SDK that when combined provide all the necessary tools to develop Z-Wave embedded products. The Base Kit consists of the standard hardware needed for all developers. The Regional Kits provides the hardware with regional frequency dependancy. The downloadable Z-Wave Protocol SDK provides all the embedded software components. All licensees of the Z-Wave Embedded Development Kit are entitled to free online support and training. BUY A DEV KIT Purchasing a dev kit is the first step to developing Z-Wave products. Dev Kits are available http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 2 of 10 for purchase from our global distributor partners. contact a distributor » BENEFITS • One kit covers all Z-Wave regions • Access to download center for complete Z-Wave protocol stack and API function • Versatile development module for easy hardware prototyping • Application Framework included for fast application prototyping (Sample Code Libraries) • Real-time Z-Wave Zniffer included for frame flow • Developer-friendly instructions, user guides, application notes, and more KEY FEATURES • Comes with license to use Z-Wave technology world-wide • Access to protocol SDK • All hardware needed to develop embedded Z-Wave applications TARGET APPLICATIONS • Z-Wave end devices such as door locks, lights, sensors, and thermostats http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 3 of 10 Z-Wave Base Kit What's in the box? The Z-Wave Base Kit consists of development platform boards, power supply units, cables, etc., that are used to program Z-Wave modules with a Z-Wave application. Z-Wave Regional Kit The Z-Wave Regional Kits is available in three frequency variants and consists of Z-Wave ZDB5101, ZDB5202, ZDB5304 reference design modules that are RF-matched for specific regions. The Z-Wave Regional Kits also contains samples for prototype development. Z-Wave Protocol SDK The Z-Wave Protocol SDK is available for download on the Z-Wave Technical Site (ZTS); access to the download center is included with the Z-Wave Embedded Development Kit. From the ZTS, developers can access all relevant technical documentation, developer's FAQ, known issues database, etc. http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 4 of 10 HARDWARE IN THE BASE KIT • 4 x ZDP03A — Z-Wave development platform • 4 x Flexi antenna — Antennas for ZDB5xxx • 4 x USB cable — To connect to ZDP03A • 1 x Battery pack — To make ZDP03A portable • 4 x Power supply unit — For ZDP03A • 1 x UZB-S — USB stick network-sniffer • 1 x Getting Started with Z-Wave • 4 x ZM5101 3 REGIONAL KITS Europe* (E), USA* (U), Japan* (H) each containing: • 2 x ZDB5101 • 2 x ZDB5202 • 1 x ZDB5304 • 1 x UZB — USB stick static controller • 4 x ZM5202 • 4 x ZM5304 * may be re-programmed to support additional countries see full list (/about_z-wave#where_zwave_works) SOFTWARE DEVELOPERS KIT - DOWNLOADABLE • Embedded sample applications • Z-Wave Plus Application Framework • Development tools ◦ Z-Wave Programmer ◦ Z-Wave Zniffer ◦ Build environments http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 5 of 10 ◦ All necessary tools to build your Z-Wave application Z-Wave Protocol Development Z-WAVE PROTOCOL SDK The Z-Wave Protocol Developer's Kit (SDK) is intended to help developers creating Z-Wave-enabled products in a fast and cost-effective manner. The software consists of Z-Wave libraries supporting controller and slave devices, as well as sample code for a broad range of home automation applications. Along with the SDK, licencees get access to network sniffer tools and tools to assist you in assessing and optimizing RF performance. Z-WAVE PLUS APPLICATION FRAMEWORK Developing firmware for new Z-Wave products is simpler, thanks to the Z-Wave Plus Application Framework. The Application Framework provides sample code for many common devices, plus a modular library of robust, field-tested code that can be readily re-used. The Application Framework helps eliminate errors and minimizes the need for custom coding. As a result, the process of creating new Z-Wave applications is streamlined, typically taking less than a week or two for most new devices. http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 6 of 10 MINIMUM REQUIREMENTS • Windows 7 or higher • Keil PK51 ver 9.53 More Info ZM5101 (/products#ZM5101) | ZM5202 (/products#ZM5202) Z-Wave Protocol • RF solution in single chip • Sub-1GHz • Multi-speed: 40...100 kbps • Low communication latency • Wireless Mesh Networking • Every node is a repeater • Extremely robust • Self-healing http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015 Embedded Dev Kits | Z-Wave | Sigma Designs Page 7 of 10 • Extremely simple setup: Plug & Play • Versatile support of installation tools • Ultra low power • Ideal for battery-powered sensors • Interoperable • Proven Device and Command Classes • Comprehensive certifi cation program • Some Z-Wave ASIC peripherals may require customer code development Z-Wave Embedded Dev Kit brochure » (/docs/brochures/Z-Wave_Embedded_Dev_Kit_br.pdf) Where to Buy a Dev Kit GLOBAL & US DISTRIBUTORS Digi-Key Scott Raeker, Z-Wave Specialist Tel: +1.800.338.4105 x1630 scott.raeker@digikey.com (mailto:scott.raeker@digikey.com) http://z-wave.sigmadesigns.com/embedded_dev_kit 8/4/2015
RBK-ZW500DEV-EMB2 价格&库存
很抱歉,暂时无法提供与“RBK-ZW500DEV-EMB2”相匹配的价格&库存,您可以联系我们找货
