WRL-13231
WRL-13231
    SPARKFUNELECTRONICS
    ESP8266 THING
WRL-13231 数据手册
  ESP8266 Thing Hookup Guide Introduction Over the past year, the ESP8266 has been a growing star among IoT or WiFi-related projects. It's an extremely cost-effective WiFi module, that -- with a little extra effort -- can be programmed just like any microcontroller. Unfortunately, the ESP8266 has mostly only been available in a tiny, modular form, which, with limited I/O and a funky pin-out, can be difficult to build a project around. WiFi Module - ESP8266  WRL-13678 The ESP8266 WiFi module. Great for piggybacking onto an Arduino, hard to build a project around. SparkFun's new development board for the ESP8266 breaks out all of the module's pins, and comes equipped with a LiPo charger, power supply, and all of the other supporting circuitry it requires. We lovingly call it the Thing -it's the perfect foundation for your Internet of Things. SparkFun ESP8266 Thing  WRL-13231 SparkFun ESP8266 Thing Starter Kit  KIT-15258 Introducing the SparkFun Thing! Product Showcase: SparkFun ESP8266 Thing & Thing Dev Start… Start… Having trouble viewing the videos? Try resizing the video by clicking on the shortcut to view the product showcase in full screen. Covered in this Tutorial This tutorial will familiarize you with all things SparkFun Thing. It's split into sections, which cover: Hardware Overview -- A quick rundown of the Thing's components and pinout. Powering the Thing -- The Thing can be powered through either USB or a LiPo battery. Programming the Thing -- Interface a 3.3V FTDI Basic with the Thing to program it. Hardware Assembly -- Tips and recommendations on what to solder to the Thing's I/O pins. Installing the ESP8266 Arduino Addon -- The Thing can be programmed using Arduino! Just follow the instructions here to install the board definitions. Example Sketch: AP Web Server -- Set the Thing up as an access point and use it to serve web pages. Using the Arduino Addon -- There are a few key differences between programming the Thing and any other Arduino board. Required Materials To follow along with this tutorial, and get up-and-running with the Thing, you may need a few extra tools and materials. This wishlist includes everything we use in this tutorial to program and use the Thing if you are ordering the board individually: ESP8266 Thing Hookup Guide SparkFun Wish List SparkFun ESP8266 Thing WRL-13231 The SparkFun ESP8266 Thing is a breakout and development board for the ESP8266 WiFi SoC – a leading platfor… (2) Arduino Stackable Header - 10 Pin PRT-11376 This is a 10-pin female header, with extra long legs -- great for stacking R3-compatible Arduino shields! Pins are sp… SparkFun Cerberus USB Cable - 6ft CAB-12016 You've got the wrong USB cable. It doesn't matter which one you have, it's the wrong one. But what if you could ha… SparkFun FTDI Basic Breakout - 3.3V DEV-09873 This is the newest revision of our [FTDI Basic](http://www.sparkfun.com/commerce/product_info.php?products_id=… Lithium Ion Battery - 850mAh PRT-13854 These are very slim, extremely light weight batteries based on Lithium Ion chemistry. Each cell outputs a nominal 3… Suggested Reading Before continuing on with this tutorial, you may want to familiarize yourself with some of these topics if they're unfamiliar to you: How to Solder: Through-Hole Soldering Serial Communication This tutorial covers everything you need to know about through-hole soldering. Asynchronous serial communication concepts: packets, signal levels, baud rates, UARTs and more! How to Power a Project Logic Levels A tutorial to help figure out the power requirements of your project. Learn the difference between 3.3V and 5V devices and logic levels. Hardware Overview The ESP8266 Thing is a relatively simple board. The pins are broken out to two parallel, breadboard-compatible rows. USB and LiPo connectors at the top of the board provide power -- controlled by the nearby ON/OFF switch. And LEDs towards the inside of the board indicate power, charge, and status of the IC. Here's a quick overview of the Thing's main components: The Pinout The Thing's I/O headers can be broken down into three sections: Serial Programming Header This six-pin header will be the main point of contact between the Thing and your development computer. The pinout of this header matches the extremely common "FTDI header." That means you can interface it with either a 3.3V FTDI Basic or a 3.3V I/O FTDI Cable to program and debug the Thing. For a quick breakdown of the pins on this header, consult the table below. If a pin is directly tied to an ESP8266 I/O, it'll be noted: Pin Label ESP8266 I/O # DTR Notes Performs auto-reset, and puts the ESP8266 into bootloader mode. Connects through a capacitor to RESET, and a buffer to the ESP8266's GPIO0. TXO 7 ESP8266 UART1 data output. RXI 8 ESP8266 UART1 data input. 3V3 By default, this pin does not supply the ESP8266 directly (a jumper on the back can change that). NC Not connected to anything on the Thing. GND Ground (0V). I2C Header I2C is a very popular communication protocol in the embedded world. Whether you want to hook the Thing up to a motion sensor, light sensor, digital-to-analog converter, or OLED display, I2C is often the protocol of choice. This header includes four pins -- all that should be required to connect an I2C device up to the Thing. Pin Label ESP8266 I/O # Notes GND Ground (0V). 3V3 3.3V SDA 2 Can either be used as ESP8266 GPIO2 or I2C serial data (SDA). SCL 14 Can either be used as ESP8266 GPIO14 or I2C serial clock (SCL). Also used as the SPI clock (SCLK). This pinout matches that of most of our I2C-based breakout boards, so you can piggyback them right on top of the Thing. If you need the extra I/O, instead of I2C, the SDA and SCL pins can be used as GPIO 2 and 14 respectively. The SCL pin also serves as the clock (SCLK) for the ESP8266's SPI interface. General I/O Header The rest of the power, control, and I/O pins are broken out on the other side of the board. They are: Pin Label ESP8266 I/O # Notes GND Ground (0V). VIN USB connected: ~4.5V output LiPo connected (no USB): ~3.7V output No supply: Can be used as a voltage supply input to the 3.3V regulator. 5 5 0 0 4 4 13 13 Hardware SPI MOSI 12 12 Hardware SPI MISO XPD 16 Can be connected to reset to set the ESP8266 into deep sleep mode. ADC A0 A 10-bit ADC with a maximum voltage of 1V. EN This pin is also tied to the on-board LED. ESP8266 enable pin. HIGH = on, LOW = off. Pulled HIGH on-board. What happened to the rest of the GPIO pins? Why the eclectic pin-numbering scheme? We're taking what the ESP8266 gives us. Unfortunately, most of the remaining GPIO are connected to the on-board SPI flash memory IC, which stores the ESP8266's program memory and potentially other data. Back of the Thing Flipping the Thing over revels a few trace jumpers and test points, which you may find handy for your application. Jumpers Jumper Label Default Setting Notes DTR Closed Allows for auto-reset while programming the ESP8266, but makes serial debugging difficult. I2C PU Closed Connects 10kΩ pull-up resistors to the SDA and SCL pins. FTDI VCC Open Connects the 3V3 pin on the serial header directly to the ESP8266's 3.3V supply. Of these jumpers, the DTR one is the most commonly modified. The DTR output of the FTDI Basic is used for two purposes: to reset the ESP8266 and pull GPIO0 low (putting the chip in bootloader mode). Keeping this jumper closed enables programming, but makes debugging via the Serial Monitor difficult, as the board will reset into bootloader mode whenever the terminal opens. Using and modifying this jumper is discussed later in this tutorial. The FTDI_VCC jumper defaults to open to ensure that, if a 3.3V Logic (5V power) FTDI Cable is used to program the Thing, 5V isn't accidentally delivered to the IC. Also, most 3.3V FTDI boards don't have a lot of juice to supply on the 3.3V bus (they often supply about 50mA max). Test Points These pins are made available just in case they become necessary to your project. The six pins bundled up together are connected to the Thing's on-board SPI flash memory, but if you really need the extra GPIO, or want to experiment with the pins, they're available. The RST pin is more useful, but we didn't leave room to break it out -- at least not directly. RST is tied through a 0.1µF capacitor to the DTR pin, to allow for automatic reset during programming. For many applications that need the RST pin, toggling the DTR pin works as well. Putting the ESP8266 into deep sleep is one such application. Selecting the Antenna The Thing's default WiFi antenna is a PCB trace antenna based on this TI app note. It's cost-effective and actually works really well! If you need to connect a more sensitive antenna to the chip, a U.FL connector is also available on the board, but isn't connected by default to the ESP8266's antenna pin. To connect this antenna to the chip, you'll need to heat up the 0Ω resistor and rotate it 90°: An (ugly, uncleaned) resistor swapped from printed antenna to U.FL antenna. A soldering iron, pair of tweezers, (2) steady hands, and good set of eyes should be enough to accomplish the task. Why Are There Unpopulated Parts? We initially set out to make the Thing a secure, common-sensor base station. The empty pads you see are landing spots for three unique IC's: ATECC108A -- A "full turnkey Elliptic Curve Digital Signature Algorithm (ECDSA) engine", which can be used for unique serial numbers, hashing, key storage, or random numbers. A great start to securing your IoT project! TMP102 Temperature Sensor -- A simple, 12-bit, digital temperature sensor. TSL2561 Light Sensor -- A nifty luminosity/light sensor. If you are lucky to have obtained this sensor, the spot is available to populate. Unfortunately, the TSL2561 sensor is EOL so you will need to opt to use a different light sensor and connect via the the PTH along the sides of the board. Plus a few footprints for decoupling capacitors. After a late change of heart, we decided to keep the board as low cost as possible (that's the ESP8266's best feature!), while leaving the option for later expansion. The pads are still there. If you want to add any of these components, hopefully all you should need is a hot air station (maybe probably not a Heaterizer) and some tweezers. Powering the Thing The Thing provides for two methods of power delivery: USB or LiPo. The USB connector on the Thing is of the Micro-B variety. A micro-B cable plugged into either a computer USB port or a 5V USB Wall Wart can power the Thing. Any of our single-cell LiPo batteries will also work to power the Thing -- they all have the same 2-pin JST connector. Add an 850mAh LiPo and an LSM9DS0 9DoF IMU to the Thing, to create an IoT motion sensor. If both USB and LiPo are connected to the Thing, it'll take power from the USB port and charge the LiPo battery at up to 500mA. Electrical Characteristics The ESP8266's maximum voltage is 3.6V, so the Thing has an onboard 3.3V regulator to deliver a safe, consistent voltage to the IC. That means the ESP8266's I/O pins also run at 3.3V, you'll need to level shift any 5V signals running into the IC. The input to this regulator can either be delivered by USB, LiPo battery, or through the VIN pin. Max Input Voltage: If you supply power to the board through the VIN, make sure the voltage does not exceed 6V. That's the maximum input voltage of the AP2112K-3.3V regulator the board uses. Alternatively, if you have an external, regulated, supply you'd like to deliver directly to the ESP8266, you can supply that voltage through the 3V3 pin (on the I2C header). While this voltage doesn't have to be 3.3V, it must be within the range of 1.7-3.6V. Current Ratings On average, the Thing pulls about 80mA. WiFi transmits and receives can momentarily increase that draw. Here's a table, transcribed from the ESP8266 datasheet, with some of the more common current characteristics. Parameter Typical Max Unit Transmit 802.11b (1 Mbps) 215 mA Transmit 802.11b (11 Mbps) 197 mA Transmit 802.11g (54 Mbps) 145 mA Transmit 802.11n 135 mA Receive 802.11b 60 mA Receive 802.11g 60 mA Receive 802.11n 62 mA Standby 0.9 mA Deep Sleep 10 µA Maximum I/O Pin Drive Capability 12 mA If your application requires maximum battery life, you'll likely need to make liberal use of the ESP8266's deep sleep functionality. That'll be covered later in this tutorial. Programming the Thing The ESP8266 has a built-in serial bootloader, which allows for easy programming and re-programming. You don't need a specialized, expensive programmer -- just a simple, USB-to-Serial converter. We use a 3.3V FTDI Basic to program the Thing, but other serial converters with 3.3V I/O levels should work (e.g. FTDI Cable 5V VCC-3.3V I/O, FT231X Breakout, CH340G Basic Breakout). Just make sure to install the respective drivers for your converter and get the compatible USB cable. The converter does need a DTR line in addition to the RX and TX pins. SparkFun FTDI Basic Breakout - 3.3V FTDI Cable 5V VCC-3.3V I/O  DEV-09873  DEV-09717 SparkFun FT231X Breakout SparkFun Serial Basic Breakout - CH340G  BOB-13263  DEV-14050 Note: While programming the Thing, it's best to power it off USB. We've noticed programming is more likely to fail if the Thing is only powered via the battery. Depending on your setup, there is a few methods of programming the ESP8266 Thing. Below are a few ways to program the ESP8266 Thing using a serial-to-USB converter. Method 1: Two USB Cables The FTDI Basic's 6-pin header matches up exactly to the Thing's 6-pin serial port header. To set up for programming, simply connect the FTDI directly to this port -- take care to match up the DTR and GND pins! If you solder female headers to the Thing, plugging a 6-pin row of right-angle male headers between the FTDI and header helps create a temporary programming interface. The header pins are small on one side, so make sure that there is contact between the two boards while uploading. If you're short on USB ports, the SparkFun Cerberus Cable might be just what you need. Method 2: One USB Cable with Jumper Wire If you only have one USB cable, you can connect a USB-to-serial converter to the ESP8266 Thing's serial programming header. You will just need to connect 3V3 on the serial programming header side to the 3V3 on the I2C header together with a jumper wire. Below is an example of the CH340G serial basic connected with the jumper wire connecting the 3.3V pins. Note: If the ESP8266 Thing is not connected to a breadboard, you can directly connect the female header of your USB-to-serial converter to the male header side of the ESP8266 Thing instead of using 6x jumper wires to connect the boards together. You will still need to connect the 3.3V pins using a jumper wire. ⚡ Warning: Make sure to disconnect the LiPo battery from the ESP8266 Thing when connecting a USB-toserial converter if you decide to add a jumper wire between the 3V3 pins to prevent conflicting voltages. Method 3: One USB Cable with Solder Jumper A third method is to add a solder jumper to the jumper pads labeled as "FTDI VCC" to connect the 3V3 pins together between the serial programming header and the I2C header. You can then connect a USB-to-serial converter to the serial programming header as stated earlier. ⚡ Warning: Make sure to disconnect the LiPo battery from the ESP8266 Thing when connecting a USB-toserial converter if you decide to add solder to the jumper pads to prevent conflicting voltages. Hardware Assembly Oh. We're getting ahead of ourselves. To connect the FTDI programmer to your Thing you'll need to solder something to the Thing. If you've never soldered before, this is a great time to start! These solder points are easy, through-hole pins, check out our How to Solder - Through-hole Soldering for help getting started. What, exactly, you solder to the board depends both on how you'll use it in your project, and how you'll interface it with the programmer. When it comes to selecting a header (or wire) to solder, there are a variety of options. We've tried a lot of them with the Thing: 10-pin Stackable Headers make it convenient to both breadboard the Thing and jumper wire out of it. Or you can mix and match headers to best fit your needs. Right-angle male headers may help to interface between the FTDI and the Thing. Straight male headers are a good choice for low-profile connections. Straight female headers may help with connecting to I2C sensors. And, of course, wire can be soldered to any of the pins that have a long way to connect to something. Once you've soldered up at least the programming port, you're ready to load some code onto the Thing. Let's blink some LEDs and IoT (Internet our Thing). Installing the ESP8266 Arduino Addon There are a variety of development environments that can be equipped to program the ESP8266. You can go with a simple Notepad/gcc setup, or fine-tune an Eclipse environment, use a virtual machine provided by Espressif, or come up with something of your own. Fortunately, the amazing ESP8266 community recently took the IDE selection a step further by creating an Arduino addon. If you're just getting started programming the ESP8266, this is the environment we recommend beginning with, and the one we'll document in this tutorial. This ESP8266 addon for Arduino is based on the amazing work by Ivan Grokhotkov and the rest of the ESP8266 community. Check out the ESP8266 Arduino GitHub repository for more information. GITHUB ESP8266 CORE FOR ARDUINO Installing the Addon With the Arduino Boards Manager With the release of Arduino 1.6.4, adding third party boards to the Arduino IDE is easily achieved through the new board manager. If you're running an older version of Arduino (1.6.3 or earlier), we recommend upgrading now. As always, you can download the latest version of Arduino from Arduino.cc. To begin, we'll need to update the board manager with a custom URL. Open up Arduino, then go to the Preferences (File > Preferences). Then, towards the bottom of the window, copy this URL into the "Additional Board Manager URLs" text box: http://arduino.esp8266.com/stable/package_esp8266com_index.json If you already have a URL in there, and want to keep it, you can separate multiple URLs by placing a comma between them. (Arduino 1.6.5 added an expanded text box, separate links in here by line.) Hit OK. Then navigate to the Board Manager by going to Tools > Boards > Boards Manager. There should be a couple new entries in addition to the standard Arduino boards. Look for esp8266. Click on that entry, then select Install. The board definitions and tools for the ESP8266 Thing include a whole new set of gcc, g++, and other reasonably large, compiled binaries, so it may take a few minutes to download and install (the archived file is ~110MB). Once the installation has completed, an Arduino-blue "INSTALLED" will appear next to the entry. Selecting the ESP8266 Thing Board With the Board addon installed, all that's left to do is select "ESP8266 Thing" from the Tools > Boards menu. Then select your FTDI's port number under the Tools > Port menu. Example Sketch: Blink To verify that everything works, try uploading the old standard: Blink. Instead of blinking pin 13, like you may be used to though, toggle pin 5, which is attached to the onboard LED. #define ESP8266_LED 5 void setup() { pinMode(ESP8266_LED, OUTPUT); } void loop() { digitalWrite(ESP8266_LED, HIGH); delay(500); digitalWrite(ESP8266_LED, LOW); delay(500); } If the upload fails, first make sure the ESP8266 Thing is turned on -- the red "PWR" LED should be illuminated. Faster Uploads! The serial upload speed defaults to 115200 bps, which is reliable, but can feel a bit slow. You can increase the upload speed by a factor of about 8 by selecting 921600 under the Tools > Upload Speed menu. This faster upload speed can be slightly less reliable, but will save you loads of time! There are still some bugs to be fleshed out of the esptool, sometimes it may take a couple tries to successfully upload a sketch. If you continue to fail, try turning the ESP8266 Thing on then off, or unplug then replug the FTDI in. If you still have trouble, get in touch with our amazing tech support team. Example Sketch: AP Web Server Not only can the ESP8266 connect to a WiFi network and interact with the Internet, but it can also set up a network of its own, allowing other devices to connect directly to it. This example demonstrates how to turn the ESP8266 into an access point (AP), and serve up web pages to any connected client. Copy and paste the code from below in the Arduino IDE. Then hit the upload button. #include ////////////////////// // WiFi Definitions // ////////////////////// const char WiFiAPPSK[] = "sparkfun"; ///////////////////// // Pin Definitions // ///////////////////// const int LED_PIN = 5; // Thing's onboard, green LED const int ANALOG_PIN = A0; // The only analog pin on the Thing const int DIGITAL_PIN = 12; // Digital pin to be read WiFiServer server(80); void setup() { initHardware(); setupWiFi(); server.begin(); } void loop() { // Check if a client has connected WiFiClient client = server.available(); if (!client) { return; } // Read the first line of the request String req = client.readStringUntil('\r'); Serial.println(req); client.flush(); // Match the request int val = -1; // We'll use 'val' to keep track of both the // request type (read/set) and value if set. if (req.indexOf("/led/0") != -1) val = 0; // Will write LED low else if (req.indexOf("/led/1") != -1) val = 1; // Will write LED high else if (req.indexOf("/read") != -1) val = -2; // Will print pin reads // Otherwise request will be invalid. We'll say as much in HTML // Set GPIO5 according to the request if (val >= 0) digitalWrite(LED_PIN, val); client.flush(); // Prepare the response. Start with the common header: String s = "HTTP/1.1 200 OK\r\n"; s += "Content-Type: text/html\r\n\r\n"; s += "\r\n\r\n"; /*Note: Uncomment the line below to refresh automatically * for every 1 second. This is not ideal for large pages * but for a simple read out, it is useful for monitoring * your sensors and I/O pins. To adjust the fresh rate, * adjust the value for content. For 30 seconds, simply * change the value to 30.*/ //s += "\r\n";//auto refresh page // If we're setting the LED, print out a message saying we did if (val >= 0) { s += "LED is now "; s += (val)?"on":"off"; } else if (val == -2) { // If we're reading pins, print out those values: s += "Analog Pin = "; s += String(analogRead(ANALOG_PIN)); s += ""; // Go to the next line. s += "Digital Pin 12 = "; s += String(digitalRead(DIGITAL_PIN)); } else { s += "Invalid Request. Try /led/1, /led/0, or /read."; } s += "\n"; // Send the response to the client client.print(s); delay(1); Serial.println("Client disonnected"); // The client will actually be disconnected // when the function returns and 'client' object is detroyed } void setupWiFi() { WiFi.mode(WIFI_AP); // Do a little work to get a unique-ish name. Append the // last two bytes of the MAC (HEX'd) to "Thing-": uint8_t mac[WL_MAC_ADDR_LENGTH]; WiFi.softAPmacAddress(mac); String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) + String(mac[WL_MAC_ADDR_LENGTH - 1], HEX); macID.toUpperCase(); String AP_NameString = "ESP8266 Thing " + macID; char AP_NameChar[AP_NameString.length() + 1]; memset(AP_NameChar, 0, AP_NameString.length() + 1); for (int i=0; i
WRL-13231 价格&库存
很抱歉,暂时无法提供与“WRL-13231”相匹配的价格&库存,您可以联系我们找货
WRL-13231
    • 1+150.27120
    • 200+59.96160
    • 500+57.95280
