RBK-ZW500DEV-CON
RBK-ZW500DEV-CON
    SIGMADESIGNS
    DEV KIT FOR Z-WAVE 500SERIES
RBK-ZW500DEV-CON 数据手册
Controller Dev Kits | Z-Wave | Sigma Designs Page 1 of 11 Z-WAVE CONTROLLER DEVELOPMENT KIT The resources and assets you need to develop featurerich, IoT-enabled Z-Wave Controllers FASTER TIME TO MARKET AND REDUCED COST The Z-Wave controller developers kit give you the fastest and easiest way to develop feature rich Z-Wave controller applications. It contains both the Z/IP Gateway and Z-Ware offering as full source code releases, to use and/or modify for your Z-Wave Controller. INTELLIGENCE IN THE HOME The Z-Wave for CE SDK contains a working IoT gateway prototype. Just connect power and download the Z/IP Gateway application on the supplied BeagleBone board that is all you need to do to bring all of your Z-Wave devices to the Internet of Things. Along with the Z/IP gateway you get the Z-Ware C Library which converts your Z-Wave devices to easily manageable software objects for you to build your own IoT application on top off putting all the smart home intelligence in the home. INTELLIGENCE IN THE CLOUD http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 2 of 11 The Z-Wave for Portal SDK contains a Z-Wave Plus certified portal evaluation server running on Ubuntu Linux. The server is built on open source software such as Apache webserver and OpenLDAP that is combined with Z-Ware C Library and Z-Ware web API plugin to form a solid prototype for an IoT Smart Home Service. The evaluation server utilizes the ZIPR low cost Z/IP Gateway reference design in the home and the Z-Ware intelligence in the cloud service. BUY A DEV KIT For a list of global distributors and details about what is included in a Z-Wave Dev Kit contact a distributor » KEY BENEFITS • Faster time to market • Reduced development cost • SDKs contains full source code • One kit covers all Z-Wave regions • Access to Z-Wave technical website • Rapid IoT gateway development • Industry-standard TI BeagleBone™ • License to use Z-Wave technology world-wide http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 3 of 11 TARGET APPLICATIONS • Gateways • Televisions • Set-top boxes • Consumer electronics • Cloud-based services SDK Building Blocks Z/IP GATEWAY Z/IP is a UDP/IP wrapper for Z-Wave command classes, Z/IP Gateway is an application that handles all communication between Z-Wave and Z/IP in a similar way that a home router handles the communication between the home PC and the internet. The Z/IP gateway handles all the Z-Wave housekeeping such as network managment, Z-Wave Security, mailbox for battery driven devices, Z/IP packaging and multichannel support. Z/IP Gateway utilizes DTLS for LAN security and can also connect to a remote server through a secure TLS1.1 tunnel making it ideal for use with a portal server. ZIPGW 2.X REQUIREMENTS • FLASH memory 4Mb (code size: 500kb, non-volatile memory: 512kb, libssl+libusb1: 2Mb, firmware update) • SRAM memory 8Mb • Linux system ◦ libssl, libusb1 ◦ TUN/TAP and 802 Ethernet bridge ◦ 32-bit MCUs (200MHz+) capable of running Linux http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 4 of 11 Z-WARE C LIBRARY The library contains a C API that can connect to a Z/IP Gateway and discover all connect Z-Wave devices exposing them as software objects. The Software objects can be used as building blocks to design an intelligent home gateway or combined with the Z-Ware Apache Web API Plugin as part of an intelligent Portal solution. Z-WARE C LIBRARY REQUIREMENTS • FLASH: 1MB • RAM: 1MB ◦ 32-bit MCUs (200MHz+) capable of running Linux Z-WARE APACHE WEB API PLUGIN The plugin is used to combine Z-Ware C Library and Z-Ware Apps with standard technologies, such as OpenLDAP and Apache Server, to form a starting point for portal solution developers. The Z-Ware Portal is designed to serve a Z/IP Gateway, such as the ZIPR, through secure IP tunnels. Z-WARE WEB API PLUGIN REQUIREMENTS • Apache Web server • Ubuntu Linux 12.04LTS Z-WARE APPS Z-Ware Apps is a collection of user interface samples for smart TVs, PCs, tablets, smart phones. http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 5 of 11 Z-Ware Apps provide a cohesive design across all platforms, creating a consistent user experience for Z-Ware Portal and allowing the end consumer to perform complex tasks with the touch of a button. The Z-Ware Apps is designed with a focus on optimizing consumer experience. Z-Ware Apps offers a consistent experience no matter which device is being used. Z-Ware Apps are easily customizable and can be modifi ed to include company names, logos and even a color scheme to keep with branding look and feel guidelines. Z-Ware Apps are supplied as source code, as part of the Z-Ware for Portal SDK enabling developers to customize the user interface and tailor it for specific end-customer needs. Z-Wave For CE SDK http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 6 of 11 BeagleBone™ Black UZB USB Stick Bridge INTELLIGENCE IN THE HOME The SDK is targeted at contains all the software building blocks needed to design a Smart Home solution. Taking the complexity of the Z-Wave protocol away and representing all the devices in the Z-Wave Network as software objects that you as a developer can use. http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 7 of 11 The Z/IP Gateway is included with a host build environment in Ubuntu Linux creating targets for the TI BeagleBone Black. The Z/IP Gateway connects to a UZB controller reference design as default but all of the 500 series modules and SoCs can be used with the Z-Wave for CE SDK and SerialAPI binaries are included in the kit. The Z-Ware C library is offered with an easy-to-understand C API for you as a developer to design an application utilizing. HARDWARE FOR THE CE SDK • 3x UZB USB Stick Bridge Controller ◦ 1x E HW - contains EU protocol ◦ 1x U HW - contains US protocol ◦ 1x H HW - contains JP protocol • 1x TI BeagleBone™ Black http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 8 of 11 Z-Wave For Portal SDK INTELLIGENCE IN THE CLOUD The Z-Ware for Portal SDK contains an evalutaion server running on Ubuntu Linux that combines Z-Ware and Z-Ware Apps with standard technology, such as OpenLDAP and Apache Server, to form a starting point for portal solution developers. The Z-Ware Portal is designed to serve a Z/IP Gateway, such as the ZIPR or the Z/IP Gateway from the Z-Wave for CE SDK. All the components of the server are off ered as source code with a build environment for Ubuntu Linux. HARDWARE FOR THE PORTAL SDK • 3x ZIPR-CE ◦ 1x E HW - contains EU protocol http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015 Controller Dev Kits | Z-Wave | Sigma Designs Page 9 of 11 ◦ 1x U HW - contains US protocol ◦ 1x H HW - contains JP protocol FOR RF TEST AND DEBUGGING • 3x ZDB5101 E/U/H • 1x UZB-S - USB Stick Network-Sniffer Controller Dev Kit brochure » (/docs/brochures/Z-Wave_Controller_Dev_Kit_br.pdf) Where to Buy a Dev Kit GLOBAL & US DISTRIBUTORS Digi-Key Scott Raeker, Z-Wave Specialist Tel: +1.800.338.4105 x1630 scott.raeker@digikey.com (mailto:scott.raeker@digikey.com) http://z-wave.sigmadesigns.com/controller_dev_kit 8/4/2015
RBK-ZW500DEV-CON 价格&库存
很抱歉,暂时无法提供与“RBK-ZW500DEV-CON”相匹配的价格&库存,您可以联系我们找货
