Page 1 of 2
Export Restrictions
This product has some level of export control/restriction, so may be delayed by
2-3 business days when shipping outside the United States. Contact us with
questions, or we will contact you after you place your order.
SparkFun Bluetooth Mate Gold
W R L- 125 80 R OH S
1
images are CC BY-NC-SA 3.0
Description: The Bluetooth Mate Gold is very similar to our BlueSMiRF modem, but
it is designed specifically to be used with our Arduino Pros and LilyPad Arduinos.
These modems work as a serial (RX/TX) pipe, and are a great wireless replacement
for serial cables. Any serial stream from 2400 to 115200bps can be passed
seamlessly from your computer to your target. We’ve tested these units successfully
over open air at 350ft (106m)!
Bluetooth Mate has the same pin out as the FTDI Basic, and is meant to plug directly
into an Arduino Pro, Pro Mini, or LilyPad Mainboard. Because we’ve arranged the
pins to do this, you cannot directly plug the Bluetooth Mate to an FTDI Basic board
(you’ll have to swap TX and RX).
This unit ships with an RN-41 class 1 bluetooth module, a very easy-to-use and well
documented bluetooth module. Make sure you check out the datasheet and
command set links below. If you don’t need the extra range, check out the Bluetooth
Mate Silver which uses a Class 2 module which has less range.
Page 2 of 2
The Bluetooth Mate has on-board voltage regulators, so it can be powered from any
3.3 to 6VDC power supply. We’ve got level shifting all set up so the RX and TX pins
on the remote unit are 3-6VDC tolerant. Do not attach this device directly to a serial
port. You will need an RS232 to TTL converter circuit if you need to attach this to a
computer.
Unit comes without a connector; if you want to connect it to an Arduino Pro, we’d
suggest the 6-pin right-angle female header.
Note: If you are looking for the ability to use the FTDI directly with your Bluetooth
Mate check out our Crossover Breakout for FTDI!
Note: The hardware reset pin of the RN-41 module is broken out on the bottom side
of the board. This pin is mislabeled as ‘PIO6’, it is actually PIO4. Should you need to
reset the Mate, pull this pin high upon power-up, and then toggle it 3 times.
Features:
v6.15 Firmware
Designed to work directly with Arduino Pro’s and LilyPad main boards
FCC Approved Class 1 Bluetooth® Radio Modem
Very robust link both in integrity and transmission distance (100m) - no more
buffer overruns!
Low power consumption : 25mA avg
Hardy frequency hopping scheme - operates in harsh RF environments like
WiFi, 802.11g, and Zigbee
Encrypted connection
Frequency: 2.402~2.480 GHz
Operating Voltage: 3.3V-6V
Serial communications: 2400-115200bps
Operating Temperature: -40 ~ +70C
Built-in antenna
Dimensions:
• Board: 1.75x0.65"
https://www.sparkfun.com/products/12580
11/16/2015
很抱歉,暂时无法提供与“WRL-12580”相匹配的价格&库存,您可以联系我们找货
