Page 1 of 2
Export Restrictions
This product has some level of export control/restriction, so may be delayed by
2-3 business days when shipping outside the United States. Contact us with
questions, or we will contact you after you place your order.
SparkFun Venus GPS Logger - SMA
Connector
G PS - 10920 ROHS
images are CC BY-NC-SA 3.0
Description: The smallest, most powerful, and most versatile GPS receiver we carry
just got more powerful. The Venus638FLPx is the successor to the Venus634LPx and
has improved sensitivity and a faster update rate. The new module can be configured
to an amazingly powerful 20Hz update rate. With 29mA operating current and high
sensitivity, this receiver seriously opens new doors for tracking. Module outputs the
standard NMEA-0183 or SkyTraq Binary sentences at a default rate of 9600bps
(adjustable to 115200bps).
The Venus638FLPx has improved sensitivity, an integrated LNA (with multipath
detection and suppression), built-in RTC, and integrated single power supply making
it very simple to use.
Not sure which GPS module is right for you? Check out our GPS Buying Guide!
Features:
20Hz Update rate
-148dBm cold start sensitivity
-165dBm tracking sensitivity
29 second cold start TTFF
Page 2 of 2
3.5 second TTFF with AGPS
1 second hot start
2.5m accuracy
Multipath detection and suppression
Jamming detection and mitigation
SBAS (WAAS / EGNOS) support
67mW full power navigation
Works directly with active or passive antenna
Supports external SPI flash memory data logging
IC 32M Serial Flash Memory
Complete receiver in 10mm x 10mm x 1.3mm size
Contains LNA, SAW Filter, TCXO, RTC Xtal, LDO
Can be powered by a 3.7V LiPo battery (or any 3.5 - 12V supply) through the
JST connector or 3.3V regulated supply.
Dimensions: 1.25 x 0.75 inches
https://www.sparkfun.com/products/10920
11/16/2015
很抱歉,暂时无法提供与“GPS-10920”相匹配的价格&库存,您可以联系我们找货
