XBIB-R-DEV
XBIB-R-DEV
    DIGIINTERNATIONAL
    BOARD XBEE/XBEE PRO RS-232XBEE
XBIB-R-DEV 数据手册
XBIB-R-DEV Reference Guide 20 Pin Header Maps to standard through hole XBEE pins Through Hole XBee Headers Programming Header Header used to program XBee Programmable modules Self Power Module Advanced users only – will void warranty. R31 must be depopulated to power module using V+ and GND from J2 and J5. Sense lines can be connected to S+ and S- for sensing power supplies. CAUTION: Voltage not regulated. Applying incorrect voltage can cause fire and serious injury. See Note 1. Indicator LEDs DS5: ON/ SLEEP DS2: DIO12 DS3: DIO11 DS4: DIO4 Current Testing Depopulating R31 allows a current probe to be inserted across P6 terminals. The current though P6/R31 powers the module only. Other supporting circuitry is powered by a different trace. User Buttons Connected to DIO lines for user implementation Reset button DC barrel plug: 6-20V LED Indicator Yellow: UART Tx, RF Rx Green: UART Rx, RF Tx Red: Associate RS232 RSSI Indicator NOTE 1: Powering board with J2 and J5 without R31 removed can cause shorts if barrel plug power is connected. Applying too high of a voltage will destroy electronic circuitry in the module and other board components and/or cause injury.
XBIB-R-DEV 价格&库存
很抱歉,暂时无法提供与“XBIB-R-DEV”相匹配的价格&库存,您可以联系我们找货
XBIB-R-DEV
    • 1+696.315391+90.34635
