DVK-BT900-SA
DVK-BT900-SA
    LAIRD(莱尔德)
    DEV KIT FOR BT900-SA
DVK-BT900-SA 数据手册
BT900 Series A Bluetooth v4.0 Dual Modules with smartBASIC SMALL. SMART. SIMPLE Laird’s BT900 modules reduce engineering burden and design risk when integrating Bluetooth and Bluetooth Low Energy into any OEM device. A small form factor, optimized power schemes and smartBASIC language provide a secure, stable BT environment for any embedded design. Let Laird’s innovative BT900 series and decades of expertise in Bluetooth module design speed your product to market.        Bluetooth v4.0 dual mode (BT and BLE) Supports SPP + any BLE Peripheral or Central roles Supports simultaneous BT and BLE connections Hostless operation – No need for external MCU reducing overall BOM Broad range of hardware interfaces: UART, I2C, SPI, ADC, GPIO Small footprint (19mm x 12.5mm x 2.5 mm) smartBASIC powers rapid design and deployment Features at a Glance FLEXIBLE FOR ANY CHALLENGE: A COMPLETE SOLUTION Cortex M3 microcontroller and smartBASIC create truly hostless operation and enable power/throughput flexibility and sleep mode control. SPEED TO MARKET WITH smartBASIC Easily write event-driven apps for any use case and run in the module. No toolchain required. FULL, COMPREHENSIVE BLUETOOTH SOLUTION The best of Bluetooth: Dual Mode, Simultaneous BT + BLE, and SPP + BLE Peripheral / Central Roles. GLOBAL APPROVALS – MAKE YOURSELF AT HOME Carries several modular FCC, IC, CE, MIC and Bluetooth SIG approvals PERSONAL SUPPORT FROM DESIGN TO MANUFACTURE Support works onsite with Laird engineering to speed your design to market. Contact Sales - Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958 Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 Application Areas Logistics and Barcode Scanners Point of Sale Terminals Health and Medical Devices For documentation, software, sample apps and more visit: http://www.lairdtech.com/products/BT900-Series BT900 – Bluetooth v4.0 Dual Modules with smartBASIC Product Brief Key Specifications Category Wireless Specification Feature Bluetooth® Frequency Transmit Power Specification V4.0 – Dual-Mode 2.402 - 2.480 GHz + 8 dBm (maximum) Configurable down to -20 dBm Receive Sensitivity -90 dBm (typical) Link Budget 98 dB Raw Data Rates (Air) 3 Mbps (Classic BT – BR/EDR) Host Interface and UART Interface TX, RX, CTS, RTS. DTR, DSR, DCD, RI can be implemented Peripherals in smartBASIC-using General Purpose I/O Default 115200, N, 8, 1. From 1200 bps to 921,600 bps Other GPIO (18 maximum – configurable), I2C (1 configurable from GPIO) SPI (1 from GPIO), ADC (2 from GPIO), Wi-Fi / BT Coexistence (3 dedicated pins) Profiles Bluetooth Low Energy GATT Client & Peripheral – Any Custom Services Classic Bluetooth Serial Port Profile (SPP) – Up to 600 kbps Programmability smartBASIC On-board programming language similar to BASIC smartBASIC application Via UART or Over the Air Control Protocols Any that can be implemented using smartBASIC vSP – Virtual Serial Port for BLE Maximum Connections Classic Bluetooth 7 clients Bluetooth Low Energy 5 clients FW upgrade smartBASIC engine FW upgrade Via UART Coexistence 802.11 (Wi-Fi) 3 wire CSR schemes supported (Unity-3;Unity-3e) Supply Voltage Supply 1.8V – 3.6V Power Consumption Current Max Peak Current (@ +8dBm TX) – 85 mA Standby Doze (@ 4MHz) – 2.7 mA Deep Sleep – 233 uA (external signal wake up) Physical Dimensions 19 mm x 12.5 mm x 2.5 mm Pad Pitch 0.8 mm Environmental Operating -40°C to +85°C Storage -40°C to +85°C Miscellaneous Lead Free Lead-free and RoHS compliant Development Kit Development board and free software tools Development Tools Utilities Windows, Android, and iOS applications Software Tools Bluetooth® Complete Declaration ID Approvals FCC / IC / CE / MIC All BT900 Series Warranty 1-Year Warranty For full specifications on BT900 modules, please see the BT900 Datasheet (Hardware Integration Guide). Did You Know? LSR, a Laird Business, is a leader in Wireless Product Development, offering true end-to-end solutions through its array of services & technical expertise      Contact Sales - RF Hardware & Antenna Design Software/Firmware Development Mobile App / Cloud Development Industrial Design Mechanical Engineering Americas: Europe: +1 262 375 4400 +44 1628 940 ext. 958     On-Site FCC/IC/CE/Giteki/RCM EMC Certification Wireless & Antenna Testing EMC Emissions Testing International Testing Services Korea: +82 10 2622 3935 Hong Kong: +852 2923 0610 CS-Sales@lairdtech.com 262.375.4400 www.lsr.com For documentation, software, sample apps and more visit: http://www.lairdtech.com/products/BT900-Series
DVK-BT900-SA
- 物料型号:BT900 Series - 器件简介:模块支持SPP + 任何BLE外设或中心角色,支持同时连接BT和BLE,无需外部MCU即可实现无主机操作,提供广泛的硬件接口,包括UART、I2C、SPI、ADC和GPIO。 - 引脚分配:文档中未明确列出引脚分配,但提到了TX、RX、CTS、RTS等通用I/O引脚。 - 参数特性:包括蓝牙v4.0双模式、2.402-2.480 GHz频率范围、最大发射功率+8 dBm(可配置至-20 dBm)、接收灵敏度-90 dBm(典型值)、链路预算98 dB、空中原始数据速率3 Mbps(经典蓝牙-BR/EDR)等。 - 功能详解:smartBASIC编程语言允许在模块上轻松编写事件驱动的应用程序,支持通过UART或空中方式进行应用程序编程。 - 应用信息:适用于物流和条码扫描器、销售点终端、健康和医疗设备等领域。 - 封装信息:尺寸为19 mm x 12.5 mm x 2.5 mm,焊盘间距为0.8 mm。
DVK-BT900-SA 价格&库存
很抱歉,暂时无法提供与“DVK-BT900-SA”相匹配的价格&库存,您可以联系我们找货
