2479
2479
    ADAFRUIT
    HOLDER BATTERY 3CELL AAA PC MNT
2479 数据手册
Introducing the Adafruit Bluefruit LE UART Friend Created by Kevin Townsend https://learn.adafruit.com/introducing-the-adafruit-bluefruit-le-uart-friend Last updated on 2022-09-05 08:53:19 PM EDT ©Adafruit Industries Page 1 of 161 Table of Contents Introduction • • • • • So it's a Fancy Pants Wireless UART Adapter? Download our free Android/iOS app and you're ready to rock! You can do a lot more too!  Why Use Adafruit's Module? Technical Specifications Pinouts • • • • 7 10 Power Pins UART Pins Other Pins Reverse Side Breakouts Assembly 13 • Prepare the header strip: • Add the breakout board: • And Solder! Wiring • • • • Wiring for Arduino Uno Wiring for an Arduino MEGA Not Connecting? Try a Power Cycle Wiring for an FTDI Cable Factory Reset • • • • 15 19 Factory Reset via DFU Pin FactoryReset Sample Sketch AT+FACTORYRESET Factory Reset via FCTR Test Pad DFU Updates 22 • Adafruit Bluefruit LE Connect Current Measurements • • • • 23 Test Conditions Fast Advertising Mode Slow Advertising Mode Connected Mode (UART) Software 25 Configuration! 26 • • • • • • • • • Which board do you have? Bluefruit Micro or Feather 32u4 Bluefruit Feather M0 Bluefruit LE Bluefruit LE SPI Friend Bluefruit LE UART Friend or Flora BLE Configure the Pins Used Common settings: Software UART Hardware UART ©Adafruit Industries Page 2 of 161 • • • • • • Mode Pin SPI Pins Software SPI Pins Select the Serial Bus UART Based Boards (Bluefruit LE UART Friend & Flora BLE) SPI Based Boards (Bluefruit LE SPI Friend) ATCommand 32 • Opening the Sketch • Configuration • Running the Sketch BLEUart 36 • Opening the Sketch • Configuration • Running the Sketch HIDKeyboard • • • • • • • Opening the Sketch Configuration Running the Sketch Bonding the HID Keyboard Android iOS OS X Controller • • • • • • • 49 Opening the Sketch Configuration Running the Sketch Using Bluefruit LE Connect in Controller Mode Streaming Sensor Data Control Pad Module Color Picker Module HeartRateMonitor • • • • • • 41 56 Opening the Sketch Configuration If Using Hardware or Software UART Running the Sketch nRF Toolbox HRM Example CoreBluetooth HRM Example UriBeacon 61 • Opening the Sketch • Configuration • Running the Sketch HALP! 63 Data Mode 65 • Switching Command/Data Mode via +++ Command Mode 68 • Hayes/AT Commands ©Adafruit Industries Page 3 of 161 • • • • • Test Command Mode '=?' Write Command Mode '=xxx' Execute Mode Read Command Mode '?' Dynamically Switching Modes via +++ Standard AT • • • • • AT ATI ATZ ATE +++ General Purpose • • • • • • 91 AT+BLEPOWERLEVEL AT+BLEGETADDRTYPE AT+BLEGETADDR AT+BLEGETPEERADDR AT+BLEGETRSSI BLE Services • • • • • • 84 AT+BLEBEACON AT+BLEURIBEACON Deprecated: AT+EDDYSTONEENABLE AT+EDDYSTONEURL AT+EDDYSTONECONFIGEN AT+EDDYSTONESERVICEEN AT+EDDYSTONEBROADCAST BLE Generic • • • • • 78 AT+BAUDRATE AT+HWADC AT+HWGETDIETEMP AT+HWGPIO AT+HWGPIOMODE AT+HWI2CSCAN AT+HWVBAT AT+HWRANDOM AT+HWMODELED AT+UARTFLOW Beacon • • • • • • • 74 AT+FACTORYRESET AT+DFU AT+HELP AT+NVMWRITE AT+NVMREAD AT+MODESWITCHEN Hardware • • • • • • • • • • 71 94 AT+BLEUARTTX AT+BLEUARTTXF AT+BLEUARTRX AT+BLEUARTFIFO AT+BLEKEYBOARDEN AT+BLEKEYBOARD ©Adafruit Industries Page 4 of 161 • • • • • • • • • • • • • • AT+BLEKEYBOARDCODE Modifier Values HID Keyboard Codes AT+BLEHIDEN AT+BLEHIDMOUSEMOVE AT+BLEHIDMOUSEBUTTON AT+BLEHIDCONTROLKEY AT+BLEHIDGAMEPADEN AT+BLEHIDGAMEPAD AT+BLEMIDIEN AT+BLEMIDIRX AT+BLEMIDITX AT+BLEBATTEN AT+BLEBATTVAL BLE GAP • • • • • • • • • AT+GAPCONNECTABLE AT+GAPGETCONN AT+GAPDISCONNECT AT+GAPDEVNAME AT+GAPDELBONDS AT+GAPINTERVALS AT+GAPSTARTADV AT+GAPSTOPADV AT+GAPSETADVDATA BLE GATT • • • • • • • 126 AT+DBGMEMRD AT+DBGNVMRD AT+DBGSTACKSIZE AT+DBGSTACKDUMP History • • • • • • • • • 118 GATT Limitations AT+GATTCLEAR AT+GATTADDSERVICE AT+GATTADDCHAR AT+GATTCHAR AT+GATTLIST AT+GATTCHARRAW Debug • • • • 111 Version Version Version Version Version Version Version Version Version 131 0.7.7 0.7.0 0.6.7 0.6.6 0.6.5 0.6.2 0.5.0 0.4.7 0.3.0 GATT Service Details 138 • UART Service ©Adafruit Industries Page 5 of 161 UART Service 138 • Characteristics • TX (0x0002) • RX (0x0003) Software Resources • • • • • • • • • • • 139 Bluefruit LE Client Apps and Libraries Bluefruit LE Connect (Android/Java) Bluefruit LE Connect  (iOS/Swift) Bluefruit LE Connect for OS X (Swift) Bluefruit LE Command Line Updater for OS X (Swift) Deprecated: Bluefruit Buddy (OS X) ABLE (Cross Platform/Node+Electron) Bluefruit LE Python Wrapper Debug Tools AdaLink (Python) Adafruit nRF51822 Flasher (Python) BLE FAQ 146 Device Recovery 157 • How to Recover a Bluefruit Board • Still Having Problems? Downloads 160 • Files • Schematic • Board Layout ©Adafruit Industries Page 6 of 161 Introduction Would you like to add powerful and easy-to-use Bluetooth Low Energy to your robot, art or other electronics project? Heck yeah! With BLE now included in modern smart phones and tablets, its fun to add wireless connectivity. So what you really need is the new Adafruit Bluefruit LE UART Friend! The Bluefruit LE UART Friend makes it easy to add Bluetooth Low Energy connectivity to anything with a hardware or software serial port. We even have nice hardware flow control so you won't have to think about losing data. Connect to your Arduino or other microcontroller or even just a standard FTDI cable for debugging and testing. ©Adafruit Industries Page 7 of 161 This multi-function module can do quite a lot! For most people, they'll be very happy to use the standard Nordic UART RX/TX connection profile. In this profile, the Bluefruit acts as a data pipe, that can 'transparently' transmit back and forth from your iOS or Android device. You can use our iOS App (https://adafru.it/iCi) or Android App (https:// adafru.it/f4G), or write your own to communicate with the UART service (https:// adafru.it/iCF). So it's a Fancy Pants Wireless UART Adapter? The board is capable of much more than just sending strings over the air!  Thanks to an easy to learn AT command set (https://adafru.it/iCG), you have full control over how the device behaves, including the ability to define and manipulate your own GATT Services and Characteristics (https://adafru.it/iCH), or change the way that the device advertises itself for other Bluetooth Low Energy devices to see. You can also use the AT commands  to query the die temperature, check the battery voltage, and more, check the connection RSSI or MAC address, and tons more. Really, way too long to list here! Download our free Android/iOS app and you're ready to rock! Using our Bluefruit iOS App (https://adafru.it/iCi) or Android App (https://adafru.it/f4G), you can quickly get your project prototyped by using your iOS or Android phone/ tablet as a controller. We have a color picker (https://adafru.it/iCI), quaternion/ ©Adafruit Industries Page 8 of 161 accelerometer/gyro/magnetometer or location (GPS) (https://adafru.it/iCI), and an 8button control game pad (https://adafru.it/iCI). You can do a lot more too!  • The Bluefruit can also act like an HID Keyboard (https://adafru.it/iCJ) (for devices that support BLE HID) • Can become a BLE Heart Rate Monitor (https://adafru.it/iCK) (a standard profile for BLE) - you just need to add the pulse-detection circuitry • Turn it into a UriBeacon (https://adafru.it/iCL), the Google standard for Bluetooth LE beacons. Just power it and the 'Friend will bleep out a URL to any nearby devices with the UriBeacon app installed. • Built in over-the-air bootloading capability so we can keep you updated with the hottest new firmware. (https://adafru.it/iCM) Use any Android or iOS device to get updates and install them! Why Use Adafruit's Module? There are plenty of BLE modules out there, with varying quality on the HW design as well as the firmware.   One of the biggest advantages of the Adafruit Bluefruit LE family is that we wrote all of the firmware running on the devices ourselves from scratch. ©Adafruit Industries Page 9 of 161 We control every line of code that runs on our modules ... and so we aren't at the mercy of any third party vendors who may or may not be interested in keeping their code up to date or catering to our customer's needs. Because we control everything about the product, we add features that are important to our customers, can solve any issues that do come up without begging any 3rd parties, and we can even change Bluetooth SoCs entirely if the need ever arises! Technical Specifications • ARM Cortex M0 core running at 16MHz • 256KB flash memory • 32KB SRAM • Peak current draw • Transport: UART @ 9600 baud with HW flow control (CTS+RTS required!) • 5V-safe inputs (Arduino Uno friendly, etc.) • On-board 3.3V voltage regulation • Bootloader with support for safe OTA firmware updates • Easy AT command set to get up and running quickly Pinouts HW flow control (CTS+RTS) should always be used with the nRF51822. The UART peripheral block is designed in a way that more or less requires HW flow control for reliable UART communication, with a very small internal buffer and tight timing limitations due to the SoftDevice architecture (Nordic's proprietary Bluetooth Low Energy stack). ©Adafruit Industries Page 10 of 161 Power Pins • VIN: This is the power supply for the module, supply with 3.3-16V power supply input. This will be regulated down to 3.3V to run the chip • GND: The common/GND pin for power and logic UART Pins • TXO - This is the UART Transmit pin out of the breakout (Bluefruit LE --> MCU), it's at 3.3V logic level. • RXI - This is the UART Receive pin into the breakout (MCU --> Bluefruit LE). This has a logic level shifter on it, you can use 3-5V logic. • CTS - Clear to Send hardware flow control pin into the the breakou (MCU --> Bluefruit LE). Use this pin to tell the Bluefruit that it can send data back to the microcontroller over the TXO pin. This pin is pulled high by default and must be set to ground in order to enable data transfer out! If you do not need hardware flow control, tie this pin to ground it is a level shifted pin, you can use 3-5V logic • RTS - Read to Send flow control pin out of the module (Bluefruit LE --> MCU). This pin will be low when its fine to send data to the Bluefruit. In general, at 9600 baud we haven't seen a need for this pin, but you can watch it for full flow control! This pin is 3.3V out Other Pins • MOD: Mode Selection. The Bluefruit has two modes, Command and Data. You can keep this pin disconnected, and use the slide switch to select the mode. Or, you can control the mode by setting this pin voltage, it will override the switch setting!  High = Command Mode, Low = UART/DATA mode. This pin is level shifted, you can use 3-5V logic • DFU: Setting this pin low when you power the device up will force the Bluefruit LE module to enter a special firmware update mode to update the firmware over the air.  Once the device is powered up, this pin can also be used to perform a factory reset.  Wire the pin to GND for >5s until the two LEDs start to blink, then release the pin (set it to 5V or logic high) and a factory reset will be performed. ©Adafruit Industries Page 11 of 161 Reverse Side Breakouts On the back we also have a few breakouts! Opt VBat: If you fancy, you can solder on a JST 2-PH connector (http://adafru.it/1769), this will let you easily plug in a Lithium Ion or other battery pack. This connector pad is diode protected so you can use both Vin and VBat and the regulator will automatically switch to the higher voltage Opt. 32 KHz: If you're doing some funky low power work, we wanted to give you the option of solderin in a 32khz oscillator.  (https://adafru.it/f4U)Our firmware doesn't support it yet but its there! SWC: This is the SWD clock pin, 3v logic - for advanced hackers! SWD: This is the SWD data pin, 3v logic - for advanced hackers! 3Vo: This is the output from the 3V regulator, for testing and also if you really need regulated 3V, up to 250mA available FCR: This is the factory reset pin. When all else fails and you did something to really weird out your module, tie this pad to ground while powering up the module and it will factory reset. You should try the DFU reset method first tho (see that tutorial page)   ©Adafruit Industries Page 12 of 161 Assembly Prepare the header strip: Cut the strip to length if necessary. It will be easier to solder if you insert it into a breadboard - long pins down Add the breakout board: Place the breakout board over the pins so that the short pins poke through the breakout pads ©Adafruit Industries Page 13 of 161 And Solder! Be sure to solder all pins for reliable electrical contact. Solder the longer power/data strip first (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https:// adafru.it/aTk)). ©Adafruit Industries Page 14 of 161 You're done! Check your solder joints visually and continue onto the next steps Wiring You can use the Bluefruit LE UART friend with any microcontroller with 3 or 5V logic. Here we will demonstrate software serial with an Arduino UNO and hardware serial with an Arduino MEGA. Depending on whether your microcontroller has a hardware or software UART, adjust pins as necessary! Wiring for Arduino Uno To connect the Bluefruit LE UART Friend to your Arduino Uno using the default pinout in our sample sketches, connect the pins up as follows: • MOD to Pin 12 • CTS to Pin 11 • TXO to Pin 10 • RXI to Pin 9 • VIN to 5V • RTS to Pin 8 • GND to GND The wiring diagram below shows how this might look on your system: ©Adafruit Industries Page 15 of 161 All of these pins are 'flexible' and you can change them around as necessary after you get your setup running nicely, but we recommend starting out with our default wiring. Wiring for an Arduino MEGA This is the recommended approach on an Arduino MEGA. This should also work for an Arduino Micro, Leonardo, or any other board with a hardware serial port. To connect the Bluefruit LE UART Friend to an Arduino MEGA (Serial1 in this case), use the following pinout and make sure you've selected HW UART as the constructor in your sample sketches (they default to SW Serial): • TX1 to RXI • RX1 to TXO • +5V  to VIN • GND to GND • Also connect CTS on the Bluefruit LE Module to GND ©Adafruit Industries Page 16 of 161 The HW Serial constructor can be seen below, and should be uncommented in the sample sketches: /* ...or hardware serial, which does not need the RTS/CTS pins. Uncomment this line */ Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, BLUEFRUIT_UART_MODE_PIN); Not Connecting? Try a Power Cycle If the example sketch does not appear to connect, like this: ©Adafruit Industries Page 17 of 161 Then double check your wiring and make sure the slide switch is in the CMD position. If that all seems OK, you can also try power cycling the Bluefruit LE UART Friend. Simply remove the 5V wire for a sec and then reconnect it. Then try running the sketch again. Hopefully it'll start responding then. Wiring for an FTDI Cable Since the UART Friend is, well, a serial port, you can use an FTDI Friend or cable to quickly connect using any serial console. You won't get MODE or DFU connections, so don't forget to flick the mode switch as necessary if you want to be in a particular mode. ©Adafruit Industries Page 18 of 161 Simply insert an FTDI cable directly into the Bluefruit LE UART Friend header by using the six pins in the middle, being careful to align the power pins up correctly (the red wire to VIN and the black wire to GND): Factory Reset There are several methods that you can use to perform a factory reset on your Bluefruit LE module if something gets misconfigured, or to delete persistent changes like UriBeacon or advertising payload changes, etc. These methods are the same for both UART and SPI versions of Bluefruit LE Factory Reset via DFU Pin If you hold the DFU pin low (set the pin to GND) for >5 seconds, the red and blue LEDs next to the module will start blinking and the device will perform a factory reset as soon as you release the DFU pin (disconnecting it from GND). If you have a DFU button instead of a pin, just hold the button down. ©Adafruit Industries Page 19 of 161 FactoryReset Sample Sketch There is a FactoryReset sample sketch in the Adafruit Bluefruit LE library, which can be access in the File > Examples > Adafruit_BluefruitLE_nRF51 folder (See the Software section of this tutorial (https://adafru.it/iCj) for instructions on installing the library): ©Adafruit Industries Page 20 of 161 Upload this sketch and open the Serial Monitor and it should perform a factory reset for you: AT+FACTORYRESET You can also perform a factory reset by sending the AT+FACTORYRESET command to your Bluefruit LE module in your favorite terminal emulator or using the ATCommand ( https://adafru.it/iCk) example sketch. AT+FACTORYRESET OK This command will also cause the device to reset. ©Adafruit Industries Page 21 of 161 Factory Reset via FCTR Test Pad On the bottom of the Bluefruit LE Friend board or shields there is a test pad or pin that exposes the Factory Reset pin on the modules (marked FCR or F.RST). Setting this pad low when the device is powered up will cause a factory reset at startup. DFU Updates We're constantly working on the Bluefruit LE firmware to add new features, and keep up to date with what customers need and want. To make sure you stay up to date with those changes, we've included an easy to use over the air updater on all of our nRF51 based Bluefruit LE modules. ©Adafruit Industries Page 22 of 161 Adafruit Bluefruit LE Connect Updating your Bluefruit LE device to the latest firmware is as easy as installing Adafrui t's Bluefruit LE Connect application (https://adafru.it/f4G) (Android) from the Google Play Store or Bluefruit LE Connect for iOS (https://adafru.it/f4H) from the Apple App Store. Any time a firmware update is available, the application will propose to download the latest binaries and take care of all the details of transferring them to your Bluefruit device, ans shown in the video below: Current Measurements The following tables give you an idea of the average current draw in three different operating modes with the Bluefruit LE UART Friend: • Fast Advertising Mode (the first 30 seconds after power up) • Slow Advertising Mode (>30s since power up) • Connected Mode (using the UART profile in this case) Test Conditions The board was powered from a fully charged 1200mAh 4.2V LIPO (https://adafru.it/ dyW) cell running at 4.2V. Power efficiency will generally increase as the LIPO battery voltage drops, so 4.2V should be considered a worst case scenario. • Power Supply: 1200mAh 4.2V LIPO Cell (at 4.2V) • Firmware: 0.6.2 Fast Advertising Mode The first 30 seconds that the Bluefruit LE UART Friend is powered up it will enter 'Fast Advertising Mode', which sends an advertising packet once every 100ms. • Average Current: 1.44mA • Peak Current: 13.5mA • Expected Battery Life: 832 hours (~34.6 days) ©Adafruit Industries Page 23 of 161 The MODE LEDs can be seen blinking in regular intervals as the three rectangular bumps at the bottom of the chart. Slow Advertising Mode After 30 seconds the Bluefruit LE UART Friend will enter 'Slow Advertising Mode', which sends an advertising packet once every 546.25ms. • Average Current: 1.25mA • Peak Current: 13.5mA • Expected Battery Life: 956 hours (~40 days) ©Adafruit Industries Page 24 of 161 Connected Mode (UART) The following measurements illustrate the average current draw in connected mode (with the connected LED enabled).  UART mode was used as a test case. • Average Current: 1.86mA • Peak Current: 15.2mA • Expected Battery Life: 645 hours (~26.8 days) Software In order to try out our demos, you'll need to download the Adafruit BLE library for the nRF51 based modules such as this one (a.k.a. Adafruit_BluefruitLE_nRF51) You can check out the code here at github, (https://adafru.it/f4V) but its likely easier to just download by clicking: Download Adafruit_BluefruitLE_nRF51 https://adafru.it/f4W Rename the uncompressed folder Adafruit_BluefruitLE_nRF51 and check that the Ada fruit_BluefruitLE_nRF51 folder contains Adafruit_BLE.cpp and Adafruit_BLE.h (as well as a bunch of other files) Place the Adafruit_BluefruitLE_nRF51 library folder your arduinosketchfolder/libraries/ folder. You may need to create the libraries subfolder if its your first library. Restart the IDE. ©Adafruit Industries Page 25 of 161 We also have a great tutorial on Arduino library installation at: http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https:// adafru.it/aYM) After restarting, check that you see the library folder with examples: Configuration! Before you start uploading any of the example sketches, you'll need to CONFIGURE the Bluefruit interface - there's a lot of options so pay close attention! Which board do you have? There's a few products under the Bluefruit name: If you are using the Bluefruit LE Shield then you have an SPI-connected NRF51822 module. You can use this with Atmega328 (Arduino UNO or compatible), ATmega32u4 (Arduino Leonardo, compatible) or ATSAMD21 (Arduino Zero, compatible) and possibly others. Your pinouts are Hardware SPI, CS = 8, IRQ = 7, RST = 4 ©Adafruit Industries Page 26 of 161 Bluefruit Micro or Feather 32u4 Bluefruit If you have a Bluefruit Micro or Feather 32u4 Bluefruit LE then you have an ATmega32u4 chip with Hardware SPI, CS = 8, IRQ = 7, RST = 4 Feather M0 Bluefruit LE If you have a Feather M0 Bluefruit LE then you have an ATSAMD21 chip with Hardware SPI, CS = 8, IRQ = 7, RST = 4 Bluefruit LE SPI Friend If you have a stand-alone module, you have a bit of flexibility with wiring however we strongly recommend Hardware SPI, CS = 8, IRQ = 7, RST = 4 You can use this with just about any microcontroller with 5 or 6 pins ©Adafruit Industries Page 27 of 161 Bluefruit LE UART Friend or Flora BLE If you have a stand-alone UART module you have some flexibility with wiring. However we suggest hardware UART if possible. You will likely need to use the flow control CTS pin if you are not using hardware UART. There's also a MODE pin You can use this with just about any microcontroller with at least 3 pins, but best used with a Hardware Serial/UART capable chip! Configure the Pins Used You'll want to check the Bluefruit Config to set up the pins you'll be using for UART or SPI Each example sketch has a secondary tab with configuration details. You'll want to edit and save the sketch to your own documents folder once set up. ©Adafruit Industries Page 28 of 161 Common settings: You can set up how much RAM to set aside for a communication buffer and whether you want to have full debug output. Debug output is 'noisy' on the serial console but is handy since you can see all communication between the micro and the BLE // ---------------------------------------------------------------------------------------------// These settings are used in both SW UART, HW UART and SPI mode // ---------------------------------------------------------------------------------------------#define BUFSIZE 128 // Size of the read buffer for incoming data #define VERBOSE_MODE true // If set to 'true' enables debug output Software UART If you are using Software UART, you can set up which pins are going to be used for RX, TX, and CTS flow control. Some microcontrollers are limited on which pins can be used! Check the SoftwareSerial library documentation for more details // SOFTWARE UART SETTINGS #define BLUEFRUIT_SWUART_RXD_PIN #define BLUEFRUIT_SWUART_TXD_PIN #define BLUEFRUIT_UART_CTS_PIN #define BLUEFRUIT_UART_RTS_PIN 9 10 11 -1 // // // // Required for software serial! Required for software serial! Required for software serial! Optional, set to -1 if unused Hardware UART If you have Hardware Serial, there's a 'name' for it, usually Serial1 - you can set that up here: // HARDWARE UART SETTINGS #ifdef Serial1 // this makes it not complain on compilation if there's no Serial1 #define BLUEFRUIT_HWSERIAL_NAME Serial1 #endif Mode Pin For both hardware and software serial, you will likely want to define the MODE pin. There's a few sketches that dont use it, instead depending on commands to set/unset the mode. Its best to use the MODE pin if you have a GPIO to spare! ©Adafruit Industries Page 29 of 161 #define BLUEFRUIT_UART_MODE_PIN 12 // Set to -1 if unused SPI Pins For both Hardware and Software SPI, you'll want to set the CS (chip select) line, IRQ (interrupt request) line and if you have a pin to spare, RST (Reset) // SHARED SPI SETTINGS #define BLUEFRUIT_SPI_CS #define BLUEFRUIT_SPI_IRQ #define BLUEFRUIT_SPI_RST if unused 8 7 4 // Optional but recommended, set to -1 Software SPI Pins If you don't have a hardware SPI port available, you can use any three pins...its a tad slower but very flexible // SOFTWARE SPI SETTINGS #define BLUEFRUIT_SPI_SCK #define BLUEFRUIT_SPI_MISO #define BLUEFRUIT_SPI_MOSI 13 12 11 Refer to the table above to determine whether you have SPI or UART controlled Bluefruits! Select the Serial Bus Once you've configured your pin setup in the BluefruitConfig.h file, you can now check and adapt the example sketch. The Adafruit_BluefruitLE_nRF51 library supports four different serial bus options, depending on the HW you are using: SPI both hardware and software type, and UART both hardware and software type. UART Based Boards (Bluefruit LE UART Friend & Flora BLE) This is for Bluefruit LE UART Friend & Flora BLE boards. You can use either software serial or hardware serial. Hardware serial is higher quality, and less risky with respect ©Adafruit Industries Page 30 of 161 to losing data. However, you may not have hardware serial available! Software serial does work just fine with flow-control and we do have that available at the cost of a single GPIO pin. For software serial (Arduino Uno, Adafruit Metro) you should uncomment the software serial contructor below, and make sure the other three options (hardware serial & SPI) are commented out. // Create the bluefruit object, either software serial...uncomment these lines SoftwareSerial bluefruitSS = SoftwareSerial(BLUEFRUIT_SWUART_TXD_PIN, BLUEFRUIT_SWUART_RXD_PIN); Adafruit_BluefruitLE_UART ble(bluefruitSS, BLUEFRUIT_UART_MODE_PIN, BLUEFRUIT_UART_CTS_PIN, BLUEFRUIT_UART_RTS_PIN); For boards that require hardware serial (Adafruit Flora, etc.), uncomment the hardware serial constructor, and make sure the other three options are commented out /* ...or hardware serial, which does not need the RTS/CTS pins. Uncomment this line */ Adafruit_BluefruitLE_UART ble(BLUEFRUIT_HWSERIAL_NAME, BLUEFRUIT_UART_MODE_PIN); SPI Based Boards (Bluefruit LE SPI Friend) For SPI based boards, you should uncomment the hardware SPI constructor below, making sure the other constructors are commented out: /* ...hardware SPI, using SCK/MOSI/MISO hardware SPI pins and then user selected CS/ IRQ/RST */ Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST); If for some reason you can't use HW SPI, you can switch to software mode to bit-bang the SPI transfers via the following constructor: /* ...software SPI, using SCK/MOSI/MISO user-defined SPI pins and then user selected CS/IRQ/RST */ Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_SCK, BLUEFRUIT_SPI_MISO, BLUEFRUIT_SPI_MOSI, BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST); ©Adafruit Industries Page 31 of 161 ATCommand The ATCommand example allows you to execute AT commands from your sketch, and see the results in the Serial Monitor.  This can be useful for debugging, or just testing different commands out to see how they work in the real world. It's a good one to start with! Opening the Sketch To open the ATCommand sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select atcommand: This will open up a new instance of the example in the IDE, as shown below: ©Adafruit Industries Page 32 of 161 Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If using software or hardware Serial UART: • This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode if you do not configure & connect a MODE pin • Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done) Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: ©Adafruit Industries Page 33 of 161 To send an AT command to the Bluefruit LE module, enter the command in the textbox at the top of the Serial Monitor and click the Send button: The response to the AT command will be displayed in the main part of the Serial Monitor. The response from 'ATI' is shown below: ©Adafruit Industries Page 34 of 161 You can do pretty much anything at this prompt, with the AT command set. Try AT+HE LP to get a list of all commands, and try out ones like AT+HWGETDIETEMP (get temperature at the nRF51822 die) and AT+HWRANDOM (generate a random number) ©Adafruit Industries Page 35 of 161 BLEUart The BLEUart example sketch allows you to send and receive text data between the Arduino and a connected Bluetooth Low Energy Central device on the other end (such as you mobile phone using the Adafruit Bluefruit LE Connect application for And roid (https://adafru.it/f4G) or iOS (https://adafru.it/f4H) in UART mode). Opening the Sketch To open the ATCommand sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select bleuart_cmdmode: This will open up a new instance of the example in the IDE, as shown below: ©Adafruit Industries Page 36 of 161 Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If using software or hardware Serial UART: • This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode if you do not configure & connect a MODE pin • Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done) ©Adafruit Industries Page 37 of 161 Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: Once you see the request, use the App to connect to the Bluefruit LE module in UART mode so you get the text box on your phone Any text that you type in the box at the top of the Serial Monitor will be sent to the connected phone, and any data sent from the phone will be displayed in the serial monitor: ©Adafruit Industries Page 38 of 161 You can see the incoming string here in the Adafruit Bluefruit LE Connect app below (iOS in this case): ©Adafruit Industries Page 39 of 161 The response text ('Why hello, Arduino!') can be seen below: ©Adafruit Industries Page 40 of 161 HIDKeyboard The HIDKeyboard example shows you how you can use the built-in HID keyboard AT commands to send keyboard data to any BLE-enabled Android or iOS phone, or other device that supports BLE HID peripherals. Opening the Sketch To open the ATCommand sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select hidkeyboard: ©Adafruit Industries Page 41 of 161 This will open up a new instance of the example in the IDE, as shown below: Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If using software or hardware Serial UART: • This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode! ©Adafruit Industries Page 42 of 161 • Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done) Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: ©Adafruit Industries Page 43 of 161 To send keyboard data, type anything into the textbox at the top of the Serial Monitor and click the Send button. ©Adafruit Industries Page 44 of 161 Bonding the HID Keyboard Before you can use the HID keyboard, you will need to 'bond' it to your phone or PC.  The bonding process establishes a permanent connection between the two devices, meaning that as soon as your phone or PC sees the Bluefruit LE module again it will automatically connect. The exact procedures for bonding the keyboard will varying from one platform to another. When you no longer need a bond, or wish to bond the Bluefruit LE module to another device, be sure to delete the bonding information on the phone or PC, otherwise you may not be able to connect on a new device! Android To bond the keyboard on a Bluetooth Low Energy enabled Android device, go to the Settings application and click the Bluetooth icon. These screenshots are based on Android 5.0 running on a Nexus 7 2013. The exact appearance may vary depending on your device and OS version. Inside the Bluetooth setting panel you should see the Bluefruit LE module advertising itself as Bluefruit Keyboard under the 'Available devices' list: ©Adafruit Industries Page 45 of 161 Tapping the device will start the bonding process, which should end with the Bluefruit Keyboard device being moved to a new 'Paired devices' list with 'Connected' written underneath the device name: To delete the bonding information, click the gear icon to the right of the device name and the click the Forget button: ©Adafruit Industries Page 46 of 161 iOS To bond the keyboard on an iOS device, go to the Settings application on your phone, and click the Bluetooth menu item. The keyboard should appear under the OTHER DEVICES list: Once the bonding process is complete the device will be moved to the MY DEVICES category, and you can start to use the Bluefruit LE module as a keyboard: ©Adafruit Industries Page 47 of 161 To unbond the device, click the 'info' icon and then select the Forget this Device option in the menu: OS X To bond the keyboard on an OS X device, go to the Bluetooth Preferences window and click the Pair button beside the Bluefruit Keyboard device generated by this example sketch: To unbond the device once it has been paired, click the small 'x' icon beside Bluefruit Keyboard: ©Adafruit Industries Page 48 of 161 ... and then click the Remove button when the confirmation dialogue box pops up: Controller The Controller sketch allows you to turn your BLE-enabled iOS or Android device in a hand-held controller or an external data source, taking advantage of the wealth of sensors on your phone or tablet. You can take accelerometer or quaternion data from your phone, and push it out to your Arduino via BLE, or get the latest GPS co-ordinates for your device without having to purchase (or power!) any external HW. Opening the Sketch To open the Controller sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select controller: ©Adafruit Industries Page 49 of 161 This will open up a new instance of the example in the IDE, as shown below: Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If using software or hardware Serial UART: • This tutorial will also be easier to use if you wire up the MODE pin, you can use any pin but our tutorial has pin 12 by default. You can change this to any pin. If ©Adafruit Industries Page 50 of 161 you do not set the MODE pin then make sure you have the mode switch in CMD mode • If you are using a Flora or otherwise don't want to wire up the Mode pin, set the BLUEFRUIT_UART_MODE_PIN to -1 in the configuration tab so that the sketch will use the +++ method to switch between Command and Data mode! • Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done) Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: Using Bluefruit LE Connect in Controller Mode Once the sketch is running you can open Adafruit's Bluefruit LE Connect application (available for Android (https://adafru.it/f4G) or iOS (https://adafru.it/f4H)) and use the C ontroller application to interact with the sketch.  (If you're new to Bluefruit LE Connect, have a look at our dedicated Bluefruit LE Connect learning guide (https://adafru.it/ iCm).) ©Adafruit Industries Page 51 of 161 On the welcome screen, select the Adafruit Bluefruit LE device from the list of BLE devices in range: Then from the activity list select Controller: This will bring up a list of data points you can send from your phone or tablet to your Bluefruit LE module, by enabling or disabling the appropriate sensor(s). Streaming Sensor Data You can take Quaternion (absolute orientation), Accelerometer, Gyroscope, Magnetometer or GPS Location data from your phone and send it directly to your Arduino from the Controller activity. By enabling the Accelerometer field, for example, you should see accelerometer data update in the app: ©Adafruit Industries Page 52 of 161 The data is parsed in the example sketch and output to the Serial Monitor as follows: Accel Accel Accel Accel Accel 0.20-0.51 0.22-0.50 0.25-0.51 0.21-0.47 0.27-0.48 ©Adafruit Industries -0.76 -0.83 -0.83 -0.76 -0.82 Page 53 of 161 Note that even though we only print 2 decimal points, the values are received from the App as a full 4-byte floating point. Control Pad Module You can also use the Control Pad Module to capture button presses and releases by selecting the appropriate menu item: This will bring up the Control Pad panel, shown below: Button presses and releases will all be logged to the Serial Monitor with the ID of the button used: Button Button Button Button 8 8 3 3 pressed released pressed released Color Picker Module You can also send RGB color data via the Color Picker module, which presents the following color selection dialogue: ©Adafruit Industries Page 54 of 161 This will give you Hexadecimal color data in the following format: RGB #A42FFF You can combine the color picker and controller sample sketches to make colorconfigurable animations triggered by buttons in the mobile app-- very handy for ©Adafruit Industries Page 55 of 161 wearables! Download this combined sample code (configured for Feather but easy to adapt to FLORA, BLE Micro, etc.) to get started: feather_bluefruit_neopixel_animation_controller.zip https://adafru.it/kzF HeartRateMonitor The HeartRateMonitor example allows you to define a new GATT Service and associated GATT Characteristics, and update the characteristic values using standard AT commands. Opening the Sketch To open the ATCommand sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select heartratemonitor: This will open up a new instance of the example in the IDE, as shown below: ©Adafruit Industries Page 56 of 161 Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If Using Hardware or Software UART This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode if you do not configure & connect a MODE pin This demo uses some long data transfer strings, so we recommend defining and connecting both CTS and RTS to pins, even if you are using hardware serial. ©Adafruit Industries Page 57 of 161 If you are using a Flora or just dont want to connect CTS or RTS, set the pin #define's to -1 and Don't forget to also connect the CTS pin on the Bluefruit to ground! (The Flora has this already done) If you are using RTS and CTS, you can remove this line below, which will slow down the data transmission // this line is particularly required for Flora, but is a good idea // anyways for the super long lines ahead! ble.setInterCharWriteDelay(5); // 5 ms Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: ©Adafruit Industries Page 58 of 161 If you open up an application on your mobile device or laptop that support the standard Heart Rate Monitor Service (https://adafru.it/f4I), you should be able to see the heart rate being updated in sync with the changes seen in the Serial Monitor: nRF Toolbox HRM Example The image below is a screenshot from the free nRF Toolbox (https://adafru.it/e9M) app lication from Nordic on Android (also available on iOS (https://adafru.it/f4J)), showing the incoming Heart Rate Monitor data: ©Adafruit Industries Page 59 of 161 CoreBluetooth HRM Example The image below is from a freely available CoreBluetooth sample application (https:// adafru.it/f4K) from Apple showing how to work with Bluetooth Low Energy services and characteristics: ©Adafruit Industries Page 60 of 161 UriBeacon The UriBeacon example shows you how to use the built-in UriBeacon AT commands to configure the Bluefruit LE module as a UriBeacon advertiser, following Google's Physical Web UriBeacon (https://adafru.it/edk) specification. Opening the Sketch To open the ATCommand sketch, click on the File > Examples > Adafruit_BluefruitLE_nRF51 folder in the Arduino IDE and select uribeacon: This will open up a new instance of the example in the IDE, as shown below. You can edit the URL that the beacon will point to, from the default http://www.adafruit.com or just upload as is to test ©Adafruit Industries Page 61 of 161 Configuration Check the Configuration! page earlier to set up the sketch for Software/Hardware UART or Software/Hardware SPI. The default is hardware SPI If using software or hardware Serial UART: • This tutorial does not need to use the MODE pin, make sure you have the mode switch in CMD mode if you do not configure & connect a MODE pin • Don't forget to also connect the CTS pin on the Bluefruit to ground if you are not using it! (The Flora has this already done) Running the Sketch Once you upload the sketch to your board (via the arrow-shaped upload icon), and the upload process has finished, open up the Serial Monitor via Tools > Serial Monitor, and make sure that the baud rate in the lower right-hand corner is set to 115200: ©Adafruit Industries Page 62 of 161 At this point you can open the Physical Web Application for Android (https://adafru.it/ edi) or for iOS (https://adafru.it/edj), and you should see a link advertising Adafruit's website:  HALP! ©Adafruit Industries Page 63 of 161 When using the Bluefruit Micro or a Bluefruit LE with Flora/Due/Leonardo/Micro the examples dont run? We add a special line to setup() to make it so the Arduino will halt until it sees you've connected over the Serial console. This makes debugging great but makes it so you cannot run the program disconnected from a computer. Solution? Once you are done debugging, remove these two lines from setup() while (!Serial); delay(500); I can't seem to "Find" the Bluefruit LE! Getting something like this? For UART/Serial Bluefruits: • Check you have the MODE switch in CMD and the MODE pin not wired to anything if it isnt used! • If you are trying to control the MODE from your micro, make sure you set the MODE pin in the sketch • Make sure you have RXI and TXO wired right! They are often swapped by accident • Make sure CTS is tied to GND if you are using hardware serial and not using CTS • Check the MODE red LED, is it blinking? If its blinking continuously, you might be in DFU mode, power cycle the module! ©Adafruit Industries Page 64 of 161 • If you are using Hardware Serial/Software Serial make sure you know which one and have that set up If using SPI Bluefruit: • Make sure you have all 5 (or 6) wires connected properly. • If using hardware SPI, you need to make sure you're connected to the hardware SPI port, which differs depending on the main chipset. If using Bluefruit Micro: • Make sure you change the RESET pin to #4 in any Config file. Also be sure you are using hardware SPI to connect! Data Mode By placing the BLEFriend module in 'UART Data' mode (set the mode selection switch to UART or setting the MODE pin to gound) you can use the module as a 'transparent UART connection' to the Bluefruit app. This makes data transfer super simple. Data is sent to the app when any 9600 baud data is received on the RXI pin and any data from the app is automatically transmitted via the TXO pin In order to keep from overloading your microcontroller, you can use the flow control pins. Keep the CTS pin high until you're ready for more data, then ground it to let the Bluefruit module know you're ready for more data! This mode uses hardware flow control! You must set the CTS pin to ground in order to enable the TXO pin, so if you're wondering why its not sending data, check that CTS is being used right! You can determine if you are in Data Mode by looking at the mode LED.  It should blink two times followed by a three second pause, as shown below: ©Adafruit Industries Page 65 of 161 You can then connect the the app in UART mode and send/receive data transparently ©Adafruit Industries Page 66 of 161 Switching Command/Data Mode via +++ On either side of the connection (via the Arduino Uno or in your mobile app), you can dynamically switch between command and data mode by sending the "+++\n" string, as detailed in the +++ command summary (https://adafru.it/iCN). ©Adafruit Industries Page 67 of 161 If you start in data mode, you can send text for example, with "+++\nATI\n+++\n", which will cause the Bluefruit LE module to switch to command mode, execute the ATI command, and then switch back to data mode. The +++ command can be sent from either side, making it possible to execute commands from the mobile application as well as on the Bluefruit LE side. # Start in Data Mode > Hello, World! Data mode! # Send command to switch modes > +++ # Bluefruit LE module switches to CMD mode # Send ATI command and wait for the response > ATI < BLEFRIEND < nRF51822 QFAAG00 < B122AAC33F3D2296 < 0.6.2 < 0.6.2 < May 01 2015 < OK # Switch back to DATA mode > +++ < OK # We're back in data mode now Welcome back! Command Mode By placing the BLEFriend module in 'Command' mode (set the mode selection switch to CMD or setting the MODE pin to a high voltage) you can enter a variety of Hayes AT style commands to configure the device or retrieve basic information about the module of BLE connection. In order to keep from overloading your microcontroller, you can use the flow control pins. Keep the CTS pin high until you're ready for more data, then ground it to let the Bluefruit module know you're ready for more data! This mode uses hardware flow control! You must set the CTS pin to ground in order to enable the TXO pin, so if you're wondering why its not responding to commands, check that CTS is being used right! You can determine if you are in Command Mode by looking at the mode LED.  It should blink three times followed by a three second pause, as shown below: ©Adafruit Industries Page 68 of 161 Hayes/AT Commands When operating in command mode, the Bluefruit LE Pro modules use a Hayes ATstyle command set  (https://adafru.it/ebJ)to configure the device. The advantage of an AT style command set is that it's easy to use in machine to machine communication, while still being somewhat user friendly for humans. Test Command Mode '=?' 'Test' mode is used to check whether or not the specified command exists on the system or not.   Certain firmware versions or configurations may or may not include a specific command, and you can determine if the command is present by taking the command name and appending '=?' to it, as shown below AT+BLESTARTADV=? If the command is present, the device will reply with 'OK'.  If the command is not present, the device will reply with 'ERROR'. AT+BLESTARTADV=? OK\r\n AT+MISSINGCMD=? ERROR\r\n Write Command Mode '=xxx' 'Write' mode is used to assign specific value(s) to the command, such as changing the radio's transmit power level using the command we used above. ©Adafruit Industries Page 69 of 161 To write a value to the command, simple append an '=' sign to the command followed by any paramater(s) you wish to write (other than a lone '?' character which will be interpreted as test mode): AT+BLEPOWERLEVEL=-8 If the write was successful, you will generally get an 'OK' response on a new line, as shown below: AT+BLEPOWERLEVEL=-8 OK\r\n If there was a problem with the command (such as an invalid parameter) you will get an 'ERROR' response on a new line, as shown below: AT+BLEPOWERLEVEL=3 ERROR\r\n Note: This particular error was generated because '3' is not a valid value for the AT+BLEPOWERLEVEL command.  Entering '-4', '0' or '4' would succeed since these are all valid values for this command. Execute Mode 'Execute' mode will cause the specific command to 'run', if possible, and will be used when the command name is entered with no additional parameters. AT+FACTORYRESET You might use execute mode to perform a factory reset, for example, by executing the AT+FACTORYRESET command as follows: AT+FACTORYRESET OK\r\n NOTE: Many commands will perform the same action whether they are sent to the command parser in 'execute' or 'read' mode. For example, the following commands will produce identical results: AT+BLEGETPOWERLEVEL -4\r\n OK\r\n ©Adafruit Industries Page 70 of 161 AT+BLEGETPOWERLEVEL? -4\r\n OK\r\n If the command doesn't support execute mode, the response will normally be 'ERROR' on a new line. Read Command Mode '?' 'Read' mode is used to read the current value of a command.  Not every command supports read mode, but you generally use this to retrieve information like the current transmit power level for the radio by appending a '?' to the command, as shown below: AT+BLEPOWERLEVEL? If the command doesn't support read mode or if there was a problem with the request, you will normally get an 'ERROR' response. If the command read was successful, you will normally get the read results followed by 'OK' on a new line, as shown below: AT+BLEPOWERLEVEL? -4\r\n OK\r\n Note: For simple commands, 'Read' mode and 'Execute' mode behave identically. Dynamically Switching Modes via +++ When operating in Command Mode you can dynamically switch to Data Mode (and back again) in software via the +++ command (https://adafru.it/iCN).  See the full command description for details. Standard AT The following standard Hayes/AT commands are available on Bluefruit LE modules: ©Adafruit Industries Page 71 of 161 AT Acts as a ping to check if we are in command mode. If we are in command mode, we should receive the 'OK' response. Codebase Revision: 0.3.0 Parameters: None Output: None AT OK ATI Displays basic information about the Bluefruit module. Codebase Revision: 0.3.0 Parameters: None Output: Displays the following values: • Board Name • Microcontroller/Radio SoC Name • Unique Serial Number • Core Bluefruit Codebase Revision • Project Firmware Revision • Firmware Build Date • Softdevice, Softdevice Version, Bootloader Version (0.5.0+) ATI BLEFRIEND nRF51822 QFAAG00 FB462DF92A2C8656 0.5.0 0.5.0 Feb 24 2015 S110 7.1.0, 0.0 OK ©Adafruit Industries Page 72 of 161 Updates: • Version 0.4.7+ of the firmware adds the chip revision after the chip name if it can be detected (ex. 'nRF51822 QFAAG00'). • Version 0.5.0+ of the firmware adds a new 7th record containing the softdevice, softdevice version and bootloader version (ex. 'S110 7.1.0, 0.0'). ATZ Performs a system reset. Codebase Revision: 0.3.0 Parameters: None Output: None ATZ OK ATE Enables or disables echo of input characters with the AT parser Codebase Revision: 0.3.0 Parameters: '1' = enable echo, '0' = disable echo Output: None # Disable echo support ATE=0 OK #Enable echo support ATE=1 OK ©Adafruit Industries Page 73 of 161 +++ Dynamically switches between DATA and COMMAND mode without changing the physical CMD/UART select switch. When you are in COMMAND mode, entering '+++\n' or '+++\r\n' will cause the module to switch to DATA mode, and anything typed into the console will go direct to the BLUE UART service. To switch from DATA mode back to COMMAND mode, simply enter '+++\n' or '+++\r\n' again (be sure to include the new line character!), and a new 'OK' response will be displayed letting you know that you are back in COMMAND mode (see the two 'OK' entries in the sample code below). Codebase Revision: 0.4.7 Parameters: None Output: None Note that +++ can also be used on the mobile device to send and receive AT command on iOS or Android, though this should always be used with care. See the AT+MODESWITCHEN command to control the availability of the +++ command ATI BLEFRIEND nRF51822 QFAAG00 B122AAC33F3D2296 0.4.6 0.4.6 Dec 22 2014 OK +++ OK OK General Purpose The following general purpose commands are available on all Bluefruit LE modules: ©Adafruit Industries Page 74 of 161 AT+FACTORYRESET Clears any user config data from non-volatile memory and performs a factory reset before resetting the Bluefruit module. Codebase Revision: 0.3.0 Parameters: None Output: None AT+FACTORYRESET OK As of version 0.5.0+ of the firmware, you can perform a factory reset by holding the DFU button down for 10s until the blue CONNECTED LED lights up, and then releasing the button. AT+DFU Forces the module into DFU mode, allowing over the air firmware updates using a dedicated DFU app on iOS or Android. Codebase Revision: 0.3.0 Parameters: None Output: None The AT parser will no longer responsd after the AT+DFU command is entered, since normal program execution effectively halts and a full system reset is performed to start the bootloader code AT+DFU OK ©Adafruit Industries Page 75 of 161 AT+HELP Displays a comma-separated list of all AT parser commands available on the system. Codebase Version: 0.3.0 Parameters: None Output: A comma-separated list of all AT parser commands available on the system. The sample code below may not match future firmware releases and is provided for illustration purposes only AT+HELP AT+FACTORYRESET,AT+DFU,ATZ,ATI,ATE,AT+DBGMEMRD,AT+DBGNVMRD,AT+HWLEDPOLARITY,AT+HWLED,AT+HWGETD OK AT+NVMWRITE Writes data to the 256 byte user non-volatile memory (NVM) region. Codebase Version: 0.7.0 Parameters: • offset: The numeric offset for the first byte from the starting position in the user NVM • datatype: Which can be one of STRING (1), BYTEARRAY (2) or INTEGER (3) • data: The data to write to NVM memory (the exact payload format will change based on the specified datatype). Output: Nothing # Write 32768 as an integer starting at byte 16 in user NVM AT+NVMWRITE=16,INTEGER,32768 OK ©Adafruit Industries Page 76 of 161 AT+NVMREAD Reads data from the 256 byte user non-volatile memory (NVM) region. Codebase Version: 0.7.0 Parameters: • offset: The numeric offset for the first byte from the starting position in the user NVM • size: The number of bytes to read • datatype: The type used for the data being read, which is required to properly parse the data and display it as a response.  The value can be one of STRING (1), BYTEARRAY (2) or INTEGER (3) Output: The data read back, formatted based on the datatype argument. # Read an integer back from position 16 in user NVM AT+NVMREAD=16, 4, INTEGER 32768 OK AT+MODESWITCHEN Enables or disables mode switches via the '+++' command on the BLE peripheral of BLE UART side of the connection. Codebase Version: 0.7.1 Parameters: • location: This can be a string, either 'local' or 'ble' indicating which side should have the '+++' command enabled or disabled, 'local' being the Bluefruit peripheral and 'ble' being the phone or tablet. • state: '0' to disable '+++' mode switches, '1' to enable them. Output: None By default, '+++' is enabled locally, and disabled in BLE ©Adafruit Industries Page 77 of 161 # Disable reomte '+++' mode switches AT+MODESWITCHEN=ble,0 OK Hardware The following commands allow you to interact with the low level HW on the Bluefruit LE module, such as reading or toggling the GPIO pins, performing an ADC conversion ,etc.: AT+BAUDRATE Changes the baud rate used by the HW UART peripheral on the nRF51822. Note that we do not recommend using higher baudrates than 9600 because the nRF51 UART can drop characters! Codebase Revision: 0.7.0 Parameters: Baud rate, which must be one of the following values: • 1200 • 2400 • 4800 • 9600 • 14400 • 19200 • 28800 • 38400 • 57600 • 76800 • 115200 • 230400 • 250000 • 460800 • 921600 • 1000000 Output: The current baud rate ©Adafruit Industries Page 78 of 161 # Set the baud rate to 115200 AT+BAUDRATE=115200 OK # Check the current baud rate AT+BAUDRATE 115200 OK AT+HWADC Performs an ADC conversion on the specified ADC pin Codebase Revision: 0.3.0 Parameters: The ADC channel (0..7) Output: The results of the ADC conversion AT+HWADC=0 178 OK AT+HWGETDIETEMP Gets the temperature in degree celcius of the BLE module's die.  This can be used for debug purposes (higher die temperature generally means higher current consumption), but does not corresponds to ambient temperature and can not be used as a replacement for a normal temperature sensor. Codebase Revision: 0.3.0 Parameters: None Output: The die temperature in degrees celcius AT+HWGETDIETEMP 32.25 OK ©Adafruit Industries Page 79 of 161 AT+HWGPIO Gets or sets the value of the specified GPIO pin (depending on the pin's mode). Codebase Revision: 0.3.0 Parameters: The parameters for this command change depending on the pin mode. OUTPUT MODE: The following comma-separated parameters can be used when updating a pin that is set as an output: • Pin numbers • Pin state, where: ◦ 0 = clear the pin (logic low/GND) ◦ 1 = set the pin (logic high/VCC) INPUT MODE: To read the current state of an input pin or a pin that has been configured as an output, enter the pin number as a single parameter. Output: The pin state if you are reading an input or checking the state of an input pin (meaning only 1 parameter is supplied, the pin number), where: • 0 means the pin is logic low/GND • 1 means the pin is logic high/VCC Trying to set the value of a pin that has not been configured as an output will produce an 'ERROR' response. Some pins are reserved for specific functions on Bluefruit modules and can not be used as GPIO. If you try to make use of a reserved pin number an 'ERROR' response will be generated. # Set pin 14 HIGH AT+HWGPIO=14,1 OK # Set pin 14 LOW AT+HWGPIO=14,0 OK # Read the current state of pin 14 ©Adafruit Industries Page 80 of 161 AT+HWGPIO=14 0 OK # Try to update a pin that is not set as an output AT+HWGPIOMODE=14,0 OK AT+HWGPIO=14,1 ERROR AT+HWGPIOMODE This will set the mode for the specified GPIO pin (input, output, etc.). Codebase Revision: 0.3.0 Parameters: This command one or two values (comma-separated in the case of two parameters being used): • The pin number • The new GPIO mode, where: ◦ 0 = Input ◦ 1 = Output ◦ 2 = Input with pullup enabled ◦ 3 = Input with pulldown enabled Output: If a single parameters is passed (the GPIO pin number) the current pin mode will be returned. Some pins are reserved for specific functions on Bluefruit modules and can not be used as GPIO. If you try to make use of a reserved pin number an 'ERROR' response will be generated. # Configure pin 14 as an output AT+HWGPIOMODE=14,0 OK # Get the current mode for pin 14 AT+HWPGIOMODE=14 0 OK ©Adafruit Industries Page 81 of 161 AT+HWI2CSCAN Scans the I2C bus to try to detect any connected I2C devices, and returns the address of devices that were found during the scan process. Codebase Revision: 0.3.0 Parameters: None Output: A comma-separated list of any I2C address that were found while scanning the valid address range on the I2C bus, or nothing is no devices were found. # I2C scan with two devices detected AT+HWI2CSCAN 0x23,0x35 OK # I2C scan with no devices detected AT+HWI2CSCAN OK AT+HWVBAT Returns the main power supply voltage level in millivolts Codebase Revision: 0.3.0 Parameters: None Output: The VBAT level in millivolts AT+HWVBAT 3248 OK AT+HWRANDOM Generates a random 32-bit number using the HW random number generator on the nRF51822 (based on white noise). Codebase Revision: 0.4.7 ©Adafruit Industries Page 82 of 161 Parameters: None Output: A random 32-bit hexadecimal value (ex. '0x12345678') AT+HWRANDOM 0x769ED823 OK AT+HWMODELED Allows you to override the default behaviour of the MODE led (which indicates the operating mode by default). Codebase Revision: 0.6.6 Parameters: LED operating mode, which can be one of the following values: • disable or DISABLE or 0 - Disable the MODE LED entirely to save power • mode or MODE or 1 - Default behaviour, indicates the current operating mode • hwuart or HWUART or 2 - Toggles the LED on any activity on the HW UART bus (TX or RX) • bleuart or BLEUART or 3 - Toggles the LED on any activity on the BLE UART Service (TX or RX characteristic) • spi or SPI or 4 - Toggles the LED on any SPI activity • manual or MANUAL or 5 - Manually sets the state of the MODE LED via a second comma-separated parameter, which can be on, off, or toggle. Output: If run with no parameters, returns an upper-case string representing the current MODE LED operating mode from the fields above # Get the curent MODE LED setting AT+HWMODELED MODE OK # Change the MODE LED to indicate BLE UART activity AT+HWMODELED=BLEUART OK # Manually toggle the MODE LED AT+HWMODELED=MANUAL,TOGGLE OK ©Adafruit Industries Page 83 of 161 AT+UARTFLOW Enables or disable hardware flow control (CTS + RTS) on the UART peripheral block of the nRF51822. Codebase Revision: 0.7.0 Parameters: HW flow control state, which can be one of: • on • off •0 •1 Output: If run with no parameters, returns a number representing whether flow control is enabled (1) or disabled (0). # Check the current flow control state AT+UARTFLOW 1 OK # Disable HW flow control AT+UARTFLOW=off OK Beacon Adafruit's Bluefruit LE modules currently support the following 'Beacon' technologies: • Beacon (Apple) via AT+BLEBEACON • UriBeacon (Google) via AT+BLEURIBEACON (deprecated) • Eddystone (Google) via AT+EDDYSTONE* Modules can be configured to act as 'Beacons' using the following commands: AT+BLEBEACON Codebase Revision: 0.3.0 ©Adafruit Industries Page 84 of 161 Parameters: The following comma-separated parameters are required to enable beacon mode: • Bluetooth Manufacturer ID (uint16_t) • 128-bit UUID • Major Value (uint16_t) • Minor Value (uint16_t) • RSSI @ 1m (int8_t) Output: None # Enable Apple iBeacon emulation # Manufacturer ID = 0x004C AT+BLEBEACON=0x004C,01-12-23-34-45-56-67-78-89-9A-AB-BC-CD-DE-EFF0,0x0000,0x0000,-59 OK # Reset to change the advertising data ATZ OK # Enable Nordic Beacon emulation # Manufacturer ID = 0x0059 AT+BLEBEACON=0x0059,01-12-23-34-45-56-67-78-89-9A-AB-BC-CD-DE-EFF0,0x0000,0x0000,-59 OK # Reset to change the advertising data ATZ OK AT+BLEBEACON will cause the beacon data to be stored in non-volatile config memory on the Bluefruit LE module, and these values will be persisted across system resets and power cycles. To remove or clear the beacon data you need to enter the 'AT+FACTORYRESET' command in command mode. Entering Nordic Beacon emulation using the sample code above, you can see the simulated beacon in Nordic's 'Beacon Config' tool below: ©Adafruit Industries Page 85 of 161 AT+BLEURIBEACON Converts the specified URI into a UriBeacon (https://adafru.it/edk) advertising packet, and configures the module to advertise as a UriBeacon (part of Google's Physical Web (https://adafru.it/ehZ) project). ©Adafruit Industries Page 86 of 161 To view the UriBeacon URIs you can use one of the following mobile applications: • Android 4.3+: Physical Web (https://adafru.it/edi) on the Google Play Store • iOS: Physical Web (https://adafru.it/edj) in Apple's App Store Codebase Revision: 0.4.7 Parameters: The URI to encode (ex. http://www.adafruit.com/blog (https://adafru.it/ei0)) Output: None of a valid URI was entered (length is acceptable, etc.). AT+BLEURIBEACON=http://www.adafruit.com/blog OK # Reset to change the advertising data ATZ OK If the supplied URI is too long you will get the following output: AT+BLEURIBEACON=http://www.adafruit.com/this/uri/is/too/long URL is too long ERROR If the URI that you are trying to encode is too long, try using a shortening service like bit.ly, and encode the shortened URI. UriBeacon should be considered deprecated as a standard, and EddyStone should be used for any future development. No further development will happen in the Bluefruit LE firmware around UriBeacon. Deprecated: AT+EDDYSTONEENABLE This command will enable Eddystone (https://adafru.it/fSA) support on the Bluefruit LE module. Eddystone support must be enabled before the other related commands can be used. Codebase Revision: 0.6.6 Parameters: 1 or 0 (1 = enable, 0 = disable) ©Adafruit Industries Page 87 of 161 Output: The current state of Eddystone support if no parameters are provided (1 = enabled, 0 = disabled) This command was removed in firmware 0.7.0 to avoid confusion. Use AT+EDDYSTONESERVICEEN in 0.7.0 and higher. # Enable Eddystone support AT+EDDYSTONEENABLE=1 OK # Check the current Eddystone status on the module AT+EDDYSTONEENABLE 1 OK AT+EDDYSTONEURL This command will set the URL for the Eddystone-URL (https://adafru.it/fSB) protocol. Codebase Revision: 0.6.6 Parameters:  • The URL to encode (mandatory) • An optional second parameter indicates whether to continue advertising the Eddystone URL even when the peripheral is connected to a central device • Firmware 0.6.7 added an optional third parameter for the RSSI at 0 meters value. This should be measured by the end user by checking the RSSI value on the receiving device at 1m and then adding 41 to that value (to compensate for the signal strength loss over 1m), so an RSSI of -62 at 1m would mean that you should enter -21 as the RSSI at 0m.  Default value is -18dBm. Output: Firmware = 0.6.7 running this command with no parameters will return the current URL. # Set the Eddystone URL to adafruit AT+EDDYSTONEURL=http://www.adafruit.com OK # Set the Eddystone URL to adafruit and advertise it even when connected AT+EDDYSTONEURL=http://www.adafruit.com,1 OK ©Adafruit Industries Page 88 of 161 AT+EDDYSTONECONFIGEN This command causes the Bluefruit LE module to enable the Eddystone URL config service for the specified number of seconds. This command should be used in combination with the Physical Web application from Google, available for Android (https://adafru.it/edi) or iOS (https://adafru.it/edj).  Run this command then select the 'Edit URL' option from the app to change the destination URL over the air. Codebase Revision: 0.6.6 Parameters: The number of seconds to advertised the config service UUID Output: None # Start advertising the Eddystone config service for 5 minutes (300s) AT+EDDYSTONECONFIGEN=300 OK AT+EDDYSTONESERVICEEN Adds or removes the Eddystone service from the GATT table (requires a reset to take effect). Codebase Revision: 0.7.0 Parameters: Whether or not the Eddystone service should be enabled or not, using on of the following values: • on • off •1 •0 Output: If the command is executed with no parameters it will disable a numeric value indicating whether the service is enabled (1) or disabled (0). You must perform a system reset for this command to take effect. ©Adafruit Industries Page 89 of 161 # Enable Eddystone service AT+EddyStonServiceEn=on OK AT+EddyStonServiceEn=1 OK # Disable Eddystone service AT+EddyStonServiceEn=off OK AT+EddyStonServiceEn=0 OK AT+EDDYSTONEBROADCAST This command can be used to start of stop advertising the Eddystone payload using the URL stored in non-volatile memory (NVM). Codebase Revision: 0.7.0 Parameters: Whether or not the payload should be broadcast, using one of the following values: • on • off •1 •0 Output: If executed with no parameters, the current broadcast state will be displayed as a numeric value. # Enable broadcasting current setting of EddyStone (stored previously on nvm) AT+EddyStoneBroadcast=on OK AT+EddyStoneBroadcast=1 OK # Disable broadcasting current setting of EddyStone (still stored on nvm) AT+EddyStoneBroadcast=off OK AT+EddyStoneBroadcast=0 OK ©Adafruit Industries Page 90 of 161 BLE Generic The following general purpose BLE commands are available on Bluefruit LE modules: AT+BLEPOWERLEVEL Gets or sets the current transmit power level for the module's radio (higher transmit power equals better range, lower transmit power equals better battery life). Codebase Revision: 0.3.0 Parameters: The TX power level (in dBm), which can be one of the following values (from lowest to higher transmit power): • -40 • -20 • -16 • -12 • -8 • -4 •0 •4 Output: The current transmit power level (in dBm) The updated power level will take effect as soon as the command is entered. If the device isn't connected to another device, advertising will stop momentarily and then restart once the new power level has taken effect. # Get the current TX power level (in dBm) AT+BLEPOWERLEVEL 0 OK # Set the TX power level to 4dBm (maximum value) AT+BLEPOWERLEVEL=4 OK # Set the TX power level to -12dBm (better battery life) AT+BLEPOWERLEVEL=-12 OK # Set the TX power level to an invalid value ©Adafruit Industries Page 91 of 161 AT+BLEPOWERLEVEL=-3 ERROR AT+BLEGETADDRTYPE Gets the address type (for the 48-bit BLE device address). Normally this will be '1' (random), which means that the module uses a 48-bit address that was randomly generated during the manufacturing process and written to the die by the manufacturer. Random does not mean that the device address is randomly generated every time, only that a one-time random number is used. Codebase Revision: 0.3.0 Parameters: None Output: The address type, which can be one of the following values: • 0 = public • 1 = random AT+BLEGETADDRTYPE 1 OK AT+BLEGETADDR Gets the 48-bit BLE device address. Codebase Revision: 0.3.0 Parameters: None Output: The 48-bit BLE device address in the following format: 'AA:BB:CC:DD:EE:FF' AT+BLEGETADDR E4:C6:C7:31:95:11 OK ©Adafruit Industries Page 92 of 161 AT+BLEGETPEERADDR Gets the 48-bit address of the peer (central) device we are connected to. Codebase Revision: 0.6.5 Parameters: None Output: The 48-bit address of the connected central device in hex format. The command will return ERROR if we are not connected to a central device. Please note that the address returned by the central device is almost always a random value that will change over time, and this value should generally not be trusted. This command is provided for certain edge cases, but is not useful in most day to day scenarios. AT+BLEGETPEERADDR 48:B2:26:E6:C1:1D OK AT+BLEGETRSSI Gets the RSSI value (Received Signal Strength Indicator), which can be used to estimate the reliability of data transmission between two devices (the lower the number the better). Codebase Revision: 0.3.0 Parameters: None Output: The RSSI level (in dBm) if we are connected to a device, otherwise '0' # Connected to an external device AT+BLEGETRSSI -46 OK # Not connected to an external device AT+BLEGETRSSI 0 OK ©Adafruit Industries Page 93 of 161 BLE Services The following commands allow you to interact with various GATT services present on Bluefruit LE modules when running in Command Mode. AT+BLEUARTTX This command will transmit the specified text message out via the UART Service (http s://adafru.it/iCn) while you are running in Command Mode. Codebase Revision: 0.3.0 Parameters: The message payload to transmit. The payload can be up to 240 characters (since AT command strings are limited to a maximum of 256 bytes total). Output: This command will produce an ERROR message if you are not connected to a central device, or if the internal TX FIFO on the Bluefruit LE module is full. As of firmware release 0.6.2 and higher, AT+BLEUARTTX can accept a limited set of escape code sequences: • \r = carriage return • \n = new line • \t = tab • \b = backspace • \\ = backward slash As of firmware release 0.6.7 and higher, AT+BLEUARTTX can accept the following escape code sequence since AT+BLEUARTTX=? has a specific meaning to the AT parser: • \? = transmits a single question mark As of firmware release 0.7.6 and higher, AT+BLEUARTTX can accept the following escape code sequence: • \+ = transmit a single '+' character without having to worry about `+++` mode switch combinations ©Adafruit Industries Page 94 of 161 ESCAPE SEQUENCE NOTE: If you are trying to send escape sequences in code via something like 'ble.print("...");' please note that you will need to send a double back-slash for the escape code to arrive as-intended in the AT command. For example: ble.println("AT+BLEUARTTX=Some Test\\r\\n"); You must be connected to another device for this command to execute # Send a string when connected to another device AT+BLEUARTTX=THIS IS A TEST OK # Send a string when not connected AT+BLEUARTTX=THIS IS A TEST ERROR TX FIFO Buffer Handling Starting with firmware version 0.6.7, when the TX FIFO buffer is full a 200ms blocking delay will be used to see if any free space becomes available in the FIFO before returning ERROR. The exact process is detailed in the flow chart below: Note: The TX FIFO full check will happen for each GATT transaction (of up to 20 bytes of data each), so large data transfers may have multiple 200ms wait states. You can use the AT+BLEUARTFIFO=TX (https://adafru.it/id3) command to check the size of the TX FIFO before sending data to ensure that you have enough free space available in the buffer. ©Adafruit Industries Page 95 of 161 The TX FIFO has the following size, depending on the firmware version used: • Firmware =0.6.7: 1024 characters wide It IS possible with large data transfers that part of the payload can be transmitted, and the command can still produce an ERROR if the FIFO doesn't empty in time in the middle of the payload transfer (since data is transmitted in maximum 20 byte chunks). If you need to ensure reliable data transfer, you should always check the TX FIFO size before sending data, which you can do using the AT+BLEUARTFIFO command. If not enough space is available for the entire payload, add a SW delay until enough space is available. Any single AT+BLEUARTTX command can fit into the FIFO, but multiple large instances of this command may cause the FIFO to fill up mid transfer. AT+BLEUARTTXF This is a convenience function the serves the same purpose as AT+BLEUARTTX, but data is immediately sent in a single BLE packet ('F' for force packet). This command will accept a maximum of 20 characters, which is the limit of what can be send in a single packet. Codebase Revision: 0.7.6 Parameters: See AT+BLEUARTTX Output: See AT+BLEUARTTX AT+BLEUARTRX This command will dump the UART service (https://adafru.it/iCn)'s RX buffer to the display if any data has been received from from the UART service while running in Command Mode. The data will be removed from the buffer once it is displayed using this command. Any characters left in the buffer when switching back to Data Mode will cause the buffered characters to be displayed as soon as the mode switch is complete (within the limits of available buffer space, which is 1024 bytes on current black 32KB SRAM ©Adafruit Industries Page 96 of 161 devices, or 160 bytes for the blue first generation BLEFriend board based on 16KB SRAM parts). Codebase Revision: 0.3.0 Parameters: None Output: The RX buffer's content if any data is available, otherwise nothing. You can also use the AT+BLEUARTFIFO=RX command to check if any incoming data is available or not. # Command results when data is available AT+BLEUARTRX Sent from Android OK # Command results when no data is available AT+BLEUARTRX OK AT+BLEUARTFIFO This command will return the free space available in the BLE UART TX and RX FIFOs.  If you are transmitting large chunks of data, you may want to check if you have enough free space in the TX FIFO before sending, keeping in mind that individual GATT packets can contain up to 20 user bytes each. Codebase Revision: 0.6.7 Parameters: Running this command with no parameters will return two commaseparated values indicating the free space in the TX buffer, following by the RX buffer.  To request a specific buffer, you can execute the command with either a "TX" or "RX" value (For example: "AT+BLEUARTFIFO=TX"). Output: The free space remaining in the TX and RX FIFO buffer if no parameter is present, otherwise the free space remaining in the specified FIFO buffer. AT+BLEUARTFIFO 1024,1024 OK AT+BLEUARTFIFO=TX 1024 OK ©Adafruit Industries Page 97 of 161 AT+BLEUARTFIFO=RX 1024 OK AT+BLEKEYBOARDEN This command will enable GATT over HID (GoH) keyboard support, which allows you to emulate a keyboard on supported iOS and Android devices.  By default HID keyboard support is disabled, so you need to set BLEKEYBOARDEN to 1 and then perform a system reset before the keyboard will be enumerated and appear in the Bluetooth preferences on your phone, where if can be bonded as a BLE keyboard. Codebase Revision: 0.5.0 Parameters: 1 or 0 (1 = enable, 0 = disable) Output: None As of firmware version 0.6.6 this command is now an alias for AT+BLEHIDEN You must perform a system reset (ATZ) before the changes take effect! Before you can use your HID over GATT keyboard, you will need to bond your mobile device with the Bluefruit LE module in the Bluetooth preferences panel. # Enable BLE keyboard support then reset AT+BLEKEYBOARDEN=1 OK ATZ OK # Disable BLE keyboard support then reset AT+BLEKEYBOARDEN=0 OK ATZ OK AT+BLEKEYBOARD Sends text data over the BLE keyboard interface (if it has previously been enabled via AT+BLEKEYBOARDEN). ©Adafruit Industries Page 98 of 161 Any valid alpha-numeric character can be sent, and the following escape sequences are also supported: • \r - Carriage Return • \n - Line Feed • \b - Backspace • \t - Tab • \\ - Backslash As of version 0.6.7 you can also use the following escape code when sending a single character ('AT+BLEKEYBOARD=?' has another meaning for the AT parser): • \? - Question mark Codebase Revision: 0.5.0 Parameters: The text string (optionally including escape characters) to transmit Output: None # Send a URI with a new line ending to execute in Chrome, etc. AT+BLEKEYBOARD=http://www.adafruit.com\r\n OK # Send a single question mark (special use case, 0.6.7+) AT+BLEKEYBOARD=\? OK AT+BLEKEYBOARDCODE Sends a raw hex sequence of USB HID keycodes to the BLE keyboard interface including key modifiers and up to six alpha-numeric characters. This command accepts the following string-encoded byte array payload, matching the way HID over GATT sends keyboard data: • Byte 0: Modifier • Byte 1: Reserved (should always be 00) • Bytes 2..7: Hexadecimal value(s) corresponding to the HID keys (if no character is used you can enter '00' or leave trailing characters empty) ©Adafruit Industries Page 99 of 161 After a keycode sequence is sent with the AT+BLEKEYBOARDCODE command, you must send a second AT+BLEKEYBOARDCODE command with at least two 00 characters to indicate the keys were released! Modifier Values The modifier byte can have one or more of the following bits set: • Bit 0 (0x01): Left Control • Bit 1 (0x02): Left Shift • Bit 2 (0x04): Left Alt • Bit 3 (0x08): Left Window • Bit 4 (0x10): Right Control • Bit 5 (0x20): Right Shift • Bit 6 (0x40): Right Alt • Bit 7 (0x80): Right Window Codebase Revision: 0.5.0 Parameters: A set of hexadecimal values separated by a hyphen ('-').  Note that these are HID scan code values, not standard ASCII values! Output: None HID Keyboard Codes A list of hexademical-format HID keyboard codes can be found here (https://adafru.it/ cQV) (see section 7), and are listed below for convenience sake: HID key code values don't correspond to ASCII key codes! For example, 'a' has an HID keycode value of '04', and there is no keycode for an upper case 'A' since you use the modifier to set upper case values. For details, google 'usb hid keyboard scan codes', and see the example below. 0x00Reserved 0x01Keyboard 0x02Keyboard 0x03Keyboard 0x04Keyboard 0x05Keyboard 0x06Keyboard 0x07Keyboard (no event indicated) ErrorRollOver POSTFail ErrorUndefined a and A b and B c and C d and D ©Adafruit Industries Page 100 of 161 0x08Keyboard e and E 0x09Keyboard f and F 0x0AKeyboard g and G 0x0BKeyboard h and H 0x0CKeyboard i and I 0x0DKeyboard j and J 0x0EKeyboard k and K 0x0FKeyboard l and L 0x10Keyboard m and M 0x11Keyboard n and N 0x12Keyboard o and O 0x13Keyboard p and P 0x14Keyboard q and Q 0x15Keyboard r and R 0x16Keyboard s and S 0x17Keyboard t and T 0x18Keyboard u and U 0x19Keyboard v and V 0x1AKeyboard w and W 0x1BKeyboard x and X 0x1CKeyboard y and Y 0x1DKeyboard z and Z 0x1EKeyboard 1 and ! 0x1FKeyboard 2 and @ 0x20Keyboard 3 and # 0x21Keyboard 4 and $ 0x22Keyboard 5 and % 0x23Keyboard 6 and ^ 0x24Keyboard 7 and & 0x25Keyboard 8 and * 0x26Keyboard 9 and ( 0x27Keyboard 0 and ) 0x28Keyboard Return (ENTER) 0x29Keyboard ESCAPE 0x2AKeyboard DELETE (Backspace) 0x2BKeyboard Tab 0x2CKeyboard Spacebar 0x2DKeyboard - and (underscore) 0x2EKeyboard = and + 0x2FKeyboard [ and { 0x30Keyboard ] and } 0x31Keyboard \ and | 0x32Keyboard Non-US # and ~ 0x33Keyboard ; and : 0x34Keyboard ' and " 0x35Keyboard Grave Accent and Tilde 0x36Keyboard, and < 0x37Keyboard . and > 0x38Keyboard / and ? 0x39Keyboard Caps Lock 0x3AKeyboard F1 0x3BKeyboard F2 0x3CKeyboard F3 0x3DKeyboard F4 0x3EKeyboard F5 0x3FKeyboard F6 0x40Keyboard F7 0x41Keyboard F8 0x42Keyboard F9 0x43Keyboard F10 0x44Keyboard F11 0x45Keyboard F12 0x46Keyboard PrintScreen 0x47Keyboard Scroll Lock 0x48Keyboard Pause 0x49Keyboard Insert 0x4AKeyboard Home 0x4BKeyboard PageUp 0x4CKeyboard Delete Forward ©Adafruit Industries Page 101 of 161 0x4DKeyboard End 0x4EKeyboard PageDown 0x4FKeyboard RightArrow 0x50Keyboard LeftArrow 0x51Keyboard DownArrow 0x52Keyboard UpArrow 0x53Keypad Num Lock and Clear 0x54Keypad / 0x55Keypad * 0x56Keypad 0x57Keypad + 0x58Keypad ENTER 0x59Keypad 1 and End 0x5AKeypad 2 and Down Arrow 0x5BKeypad 3 and PageDn 0x5CKeypad 4 and Left Arrow 0x5DKeypad 5 0x5EKeypad 6 and Right Arrow 0x5FKeypad 7 and Home 0x60Keypad 8 and Up Arrow 0x61Keypad 9 and PageUp 0x62Keypad 0 and Insert 0x63Keypad . and Delete 0x64Keyboard Non-US \ and | 0x65Keyboard Application 0x66Keyboard Power 0x67Keypad = 0x68Keyboard F13 0x69Keyboard F14 0x6AKeyboard F15 0x6BKeyboard F16 0x6CKeyboard F17 0x6DKeyboard F18 0x6EKeyboard F19 0x6FKeyboard F20 0x70Keyboard F21 0x71Keyboard F22 0x72Keyboard F23 0x73Keyboard F24 0x74Keyboard Execute 0x75Keyboard Help 0x76Keyboard Menu 0x77Keyboard Select 0x78Keyboard Stop 0x79Keyboard Again 0x7AKeyboard Undo 0x7BKeyboard Cut 0x7CKeyboard Copy 0x7DKeyboard Paste 0x7EKeyboard Find 0x7FKeyboard Mute 0x80Keyboard Volume Up 0x81Keyboard Volume Down 0x82Keyboard Locking Caps Lock 0x83Keyboard Locking Num Lock 0x84Keyboard Locking Scroll Lock 0x85Keypad Comma 0x86Keypad Equal Sign 0x87Keyboard International1 0x88Keyboard International2 0x89Keyboard International3 0x8AKeyboard International4 0x8BKeyboard International5 0x8CKeyboard International6 0x8DKeyboard International7 0x8EKeyboard International8 0x8FKeyboard International9 0x90Keyboard LANG1 0x91Keyboard LANG2 ©Adafruit Industries Page 102 of 161 0x92Keyboard 0x93Keyboard 0x94Keyboard 0x95Keyboard 0x96Keyboard 0x97Keyboard 0x98Keyboard 0x99Keyboard 0x9AKeyboard 0x9BKeyboard 0x9CKeyboard 0x9DKeyboard 0x9EKeyboard 0x9FKeyboard 0xA0Keyboard 0xA1Keyboard 0xA2Keyboard 0xA3Keyboard 0xA4Keyboard 0xE0Keyboard 0xE1Keyboard 0xE2Keyboard 0xE3Keyboard 0xE4Keyboard 0xE5Keyboard 0xE6Keyboard 0xE7Keyboard LANG3 LANG4 LANG5 LANG6 LANG7 LANG8 LANG9 Alternate Erase SysReq/Attention Cancel Clear Prior Return Separator Out Oper Clear/Again CrSel/Props ExSel LeftControl LeftShift LeftAlt Left GUI RightControl RightShift RightAlt Right GUI The following example shows how you can use this command: # send 'abc' with left shift key (0x02) --> 'ABC' AT+BLEKEYBOARDCODE=02-00-04-05-06-00-00 OK # Indicate that the keys were released (mandatory!) AT+BLEKEYBOARDCODE=00-00 OK AT+BLEHIDEN This command will enable GATT over HID (GoH) support, which allows you to emulate a keyboard, mouse or media controll on supported iOS, Android, OSX and Windows 10 devices.  By default HID support is disabled, so you need to set BLEHIDEN to 1 and then perform a system reset before the HID devices will be enumerated and appear in on your central device. Codebase Revision: 0.6.6 Parameters: 1 or 0 (1 = enable, 0 = disable) Output: None ©Adafruit Industries Page 103 of 161 You normally need to 'bond' the Bluefruit LE peripheral to use the HID commands, and the exact bonding process will change from one operating system to another. If you have previously bonded to a device and need to clear the bond, you can run the AT+FACTORYRESET command which will erase all stored bond data on the Bluefruit LE module. # Enable GATT over HID support on the Bluefruit LE module AT+BLEHIDEN=1 OK # Reset so that the changes take effect ATZ OK AT+BLEHIDMOUSEMOVE Moves the HID mouse or scroll wheen position the specified number of ticks. All parameters are signed 8-bit values (-128 to +127).  Positive values move to the right or down, and origin is the top left corner. Codebase Revision: 0.6.6 Parameters: X Ticks (+/-), Y Ticks (+/-), Scroll Wheel (+/-), Pan Wheel (+/-) Output: None # Move the mouse 100 ticks right and 100 ticks down AT+BLEHIDMOUSEMOVE=100,100 OK # Scroll down 20 pixels or lines (depending on context) AT+BLEHIDMOUSEMOVE=,,20, OK # Pan (horizontal scroll) to the right (exact behaviour depends on OS) AT+BLEHIDMOUSEMOVE=0,0,0,100 AT+BLEHIDMOUSEBUTTON Manipulates the HID mouse buttons via the specific string(s). ©Adafruit Industries Page 104 of 161 Codebase Revision: 0.6.6 Parameters: Button Mask String [L][R][M][B][F], Action [PRESS][CLICK][DOUBLECLICK] [HOLD] • L = Left Button • R = Right Button • M = Middle Button • B = Back Button • F = Forward Button • If the second parameter (Action) is "HOLD", an optional third parameter can be passed specifying how long the button should be held in milliseconds. Output: None # Double click the left mouse button AT+BLEHIDMOUSEBUTTON=L,doubleclick OK # Press the left mouse button down, move the mouse, then release L # This is required to perform 'drag' then stop type operations AT+BLEHIDMOUSEBUTTON=L OK AT+BLEHIDMOUSEMOVE=-100,50 OK AT+BLEHIDMOUSEBUTTON=0 OK # Hold the backward mouse button for 200 milliseconds (OS dependent) AT+BLEHIDMOUSEBUTTON=B,hold,200 OK AT+BLEHIDCONTROLKEY Sends HID media control commands for the bonded device (adjust volume, screen brightness, song selection, etc.). Codebase Revision: 0.6.6 Parameters: The HID control key to send, followed by an optional delay in ms to hold the button ©Adafruit Industries Page 105 of 161 The control key string can be one of the following values: • System Controls (works on most systems) ◦ BRIGHTNESS+ ◦ BRIGHTNESS• Media Controls (works on most systems) ◦ PLAYPAUSE ◦ MEDIANEXT ◦ MEDIAPREVIOUS ◦ MEDIASTOP • Sound Controls (works on most systems) ◦ VOLUME ◦ MUTE ◦ BASS ◦ TREBLE ◦ BASS_BOOST ◦ VOLUME+ ◦ VOLUME◦ BASS+ ◦ BASS◦ TREBLE+ ◦ TREBLE• Application Launchers (Windows 10 only so far) ◦ EMAILREADER ◦ CALCULATOR ◦ FILEBROWSER • Browser/File Explorer Controls (Firefox on Windows/Android only) ◦ SEARCH ◦ HOME ◦ BACK ◦ FORWARD ◦ STOP ◦ REFRESH ◦ BOOKMARKS ©Adafruit Industries Page 106 of 161 You can also send a raw 16-bit hexadecimal value in the '0xABCD' format. A full list of 16-bit 'HID Consumer Control Key Codes' can be found here  (https://adafru.it/cQV)(se e section 12). Output: Normally none. If you are not bonded and connected to a central device, this command will return ERROR. Make sure you are connected and HID support is enabled before running these commands. # Toggle the sound on the bonded central device AT+BLEHIDCONTROLKEY=MUTE OK # Hold the VOLUME+ key for 500ms AT+BLEHIDCONTROLKEY=VOLUME+,500 OK # Send a raw 16-bit Consumer Key Code (0x006F = Brightness+) AT+BLEHIDCONTROLKEY=0x006F OK AT+BLEHIDGAMEPADEN Enables HID gamepad support in the HID service. By default the gamepad is disabled as of version 0.7.6 of the firmware since it causes problems on iOS and OS X and should only be used on Android and Windows based devices. Codebase Revision: 0.7.6 Parameters: Whether the gamepad service should be enabled via one of the following values: • on • off •1 •0 Output: If executed with no parameters, a numeric value will be returned indicating whether the battery service is enabled (1) or disabled (0). This command requires a system reset to take effect. ©Adafruit Industries Page 107 of 161 AT+BLEHIDGAMEPAD Sends a specific HID gamepad payload out over BLE Codebase Revision: 0.7.0 Parameters: The following comma-separated parameters are available: • x:  LEFT, RIGHT: If X=-1 then 'LEFT' is pressed, if X=1 then 'RIGHT' is pressed, if X=0 then neither left nor right are pressed • y: UP, DOWN: If Y=-1 then 'UP' is pressed, if Y=1 then 'DOWN' is pressed, if Y=0 then neither up nor down are pressed • buttons: 0x00-0xFF, which is a bit mask for 8 button 0-7 Output: Nothing HID gamepad is disabled by default as of version 0.7.6, and must first be enabled via AT+BLEHIDGAMEPADEN=1 before it can be used. Note: You need to send both 'press' and 'release' events for each button, otherwise the system will think that the button is still pressed until a release state is received. # Press 'RIGHT' and 'Button0' at the same time AT+BLEHIDGAMEPAD=1,0,0x01 # Press 'UP' and 'Button1' + 'Button0' at the same time AT+BLEHIDGAMEPAD=0,-1,0x03 AT+BLEMIDIEN Enables or disables the BLE MIDI service. Codebase Revision: 0.7.0 Parameters: State, which can be one of: • on • off ©Adafruit Industries Page 108 of 161 •0 •1 Output: If executed with no parameters, it will return the current state of the MIDI service as an integer indicating if it is enabled (1) or disabled (0). Note: This command will require a reset to take effect. # Check the current state of the MIDI service AT+BLEMIDIEN 1 OK # Enable the MIDI Service AT+BLEMIDIEN=1 OK AT+BLEMIDIRX Reads an incoming MIDI character array from the buffer. Codebase Revision: 0.7.0 Parameters: None Output: The midi event in byte array format AT+BLEMIDIRX 90-3C-7F OK AT+BLEMIDITX Sends a MIDI event to host. Codebase Revision: 0.7.0 Parameters: The MIDI event in hex array format, which can be either: • A series of full MIDI events (up to 4 events) • Exactly 1 full MIDI event + several running events without status (up to 7) ©Adafruit Industries Page 109 of 161 Output: None # Send 1 event (middle C with max velocity) AT+BLEMIDITX=90-3C-7F OK # Send 2 events AT+BLEMIDITX=90-3C-7F-A0-3C-7F OK # Send 1 full event + running event AT+BLEMIDITX=90-3C-7F-3C-7F OK AT+BLEBATTEN Enables the Battery Service following the definition from the Bluetooth SIG. Codebase Revision: 0.7.0 Parameters: Whether the battery service should be enabled, via on of the following values: • on • off •1 •0 Output: If executed with no parameters, a numeric value will be returned indicating whether the battery service is enabled (1) or disabled (0). This command requires a system reset to take effect. # Enable the Battery Service AT+BLEBATTEN=1 OK AT+BLEBATTVAL Sets the current battery level in percentage (0..100) for the Battery Service (if enabled). Codebase Revision: 0.7.0 ©Adafruit Industries Page 110 of 161 Parameters: The percentage for the battery in the range of 0..100. Output: If executed with no parameters, the current battery level stored in the characteristic. # Set the battery level to 72% AT+BLEBATTVAL=72 OK BLE GAP GAP (https://adafru.it/iCo), which stands for the Generic Access Profile, governs advertising and connections with Bluetooth Low Energy devices. The following commands can be used to configure the GAP settings on the BLE module. You can use these commands to modify the advertising data (for ex. the device name that appears during the advertising process), to retrieve information about the connection that has been established between two devices, or the disconnect if you no longer wish to maintain a connection. AT+GAPCONNECTABLE This command can be used to prevent the device from being 'connectable'. Codebase Revision: 0.7.0 Parameters: Whether or not the device should advertise itself as connectable, using one of the following values: • yes • no •1 •0 Output: The 'connectable' state of the device if no parameter is provided # Make the device non-connectable (advertising only) AT+GAPCONNECTABLE=0 OK ©Adafruit Industries Page 111 of 161 # Check the current connectability status AT+GAPCONNECTABLE 1 OK AT+GAPGETCONN Diplays the current connection status (if we are connected to another BLE device or not). Codebase Revision: 0.3.0 Parameters: None Output: 1 if we are connected, otherwise 0 # Connected AT+GAPGETCONN 1 OK # Not connected AT+GAPGETCONN 0 OK AT+GAPDISCONNECT Disconnects to the external device if we are currently connected. Codebase Revision: 0.3.0 Parameters: None Output: None AT+GAPDISCONNECT OK ©Adafruit Industries Page 112 of 161 AT+GAPDEVNAME Gets or sets the device name, which is included in the advertising payload for the Bluefruit LE module Codebase Revision: 0.3.0 Parameters: • None to read the current device name • The new device name if you want to change the value Output: The device name if the command is executed in read mode Updating the device name will persist the new value to non-volatile memory, and the updated name will be used when the device is reset. To reset the device to factory settings and clean the config data from memory run the AT+FACTORYRESET command. # Read the current device name AT+GAPDEVNAME UART OK # Update the device name to 'BLEFriend' AT+GAPDEVNAME=BLEFriend OK # Reset to take effect ATZ OK AT+GAPDELBONDS Deletes and bonding information stored on the Bluefruit LE module. Codebase Revision: 0.3.0 Parameters: None Output: None ©Adafruit Industries Page 113 of 161 AT+GAPDELBONDS OK AT+GAPINTERVALS Gets or sets the various advertising and connection intervals for the Bluefruit LE module. Be extremely careful with this command since it can be easy to cause problems changing the intervals, and depending on the values selected some mobile devices may no longer recognize the module or refuse to connect to it. Codebase Revision: 0.3.0 Parameters: If updating the GAP intervals, the following comma-separated values can be entered: • Minimum connection interval (in milliseconds) • Maximum connection interval (in milliseconds) • Fast Advertising interval (in milliseconds) • Fast Advertising timeout (in seconds) • >= 0.7.0: Low power advertising interval (in milliseconds), default = 417.5 ms To save power, the Bluefruit modules automatically drop to a lower advertising rate after 'fast advertising timeout' seconds. The default value is 30 seconds ('Fast Advertising Timeout'). The low power advertising interval is hard-coded to approximately 0.6s in firmware < 0.7.0. Support to control the low power interval was added in the 0.7.0 firmware release via an optional fifth parameter. Please note the following min and max limitations for the GAP parameters: • Absolute minimum connection interval: 10ms • Absolute maximum connection interval: 4000ms • Absolute minimum fast advertising interval: 20ms • Absolute maximum fast advertisting interval: 10240ms • Absolute minimum low power advertising interval: 20ms • Absolute maximum low power advertising interval: 10240ms ©Adafruit Industries Page 114 of 161 If you only wish to update one interval value, leave the other comma-separated values empty (ex. ',,110,' will only update the third value, advertising interval). Output: If reading the current GAP interval settings, the following comma-separated information will be displayed: • Minimum connection interval (in milliseconds) • Maximum connection interval (in milliseconds) • Advertising interval (in milliseconds) • Advertising timeout (in milliseconds) Updating the GAP intervals will persist the new values to non-volatile memory, and the updated values will be used when the device is reset. To reset the device to factory settings and clean the config data from memory run the AT+FACTORYRESET command. # Read the current GAP intervals AT+GAPINTERVALS 20,100,100,30 # Update all values AT+GAPINTERVALS=20,200,200,30 OK # Update only the advertising interval AT+GAPINTERVALS=,,150, OK AT+GAPSTARTADV Causes the Bluefruit LE module to start transmitting advertising packets if this isn't already the case (assuming we aren't already connected to an external device). Codebase Revision: 0.3.0 Parameters: None Output: None # Command results when advertising data is not being sent AT+GAPSTARTADV OK # Command results when we are already advertising AT+GAPSTARTADV ©Adafruit Industries Page 115 of 161 ERROR # Command results when we are connected to another device AT+GAPSTARTADV ERROR AT+GAPSTOPADV Stops advertising packets from being transmitted by the Bluefruit LE module. Codebase Revision: 0.3.0 Parameters: None Output: None AT+GAPSTOPADV OK AT+GAPSETADVDATA Sets the raw advertising data payload to the specified byte array (overriding the normal advertising data), following the guidelines in the Bluetooth 4.0 or 4.1 Core Specification (https://adafru.it/ddd). In particular, Core Specification Supplement (CSS) v4 contains the details on common advertising data fields like 'Flags' (Part A, Section 1.3) and the various Service UUID lists (Part A, Section 1.1). A list of all possible GAP Data Types is available on the Bluetooth SIG's Generic Access Profile (https://adafru.it/cYs) page. The Advertising Data payload consists of Generic Access Profile (https://adafru.it/cYs)  data that is inserted into the advertising packet in the following format: [U8:LEN] [U8:Data Type Value] [n:Value] WARNING: This command requires a degree of knowledge about the low level details of the Bluetooth 4.0 or 4.1 Core Specification, and should only be used by expert users. Misuse of this command can easily cause your device to be undetectable by central devices in radio range. ©Adafruit Industries Page 116 of 161 WARNING: This command will override the normal advertising payload and may prevent some services from acting as expected. To restore the advertising data to the normal default values use the AT+FACTORYRESET command. For example, to insert the 'Flags' Data Type (Data Type Value 0x01), and set the value to 0x06/0b00000110 (BR/EDR Not Supported and LE General Discoverable Mode) we would use the following byte array: 02-01-06 • 0x02 indicates the number of bytes in the entry • 0x01 is the 'Data Type Value (https://adafru.it/cYs)' and indicates that this is a 'Fla g' • 0x06 (0b00000110) is the Flag value, and asserts the following fields (see Core Specification 4.0, Volume 3, Part C, 18.1): ◦ LE General Discoverable Mode (i.e. anyone can discover this device) ◦ BR/EDR Not Supported (i.e. this is a Bluetooth Low Energy only device) If we also want to include two 16-bit service UUIDs in the advertising data (so that listening devices know that we support these services) we could append the following data to the byte array: 05-02-0D-18-0A-18 • 0x05 indicates that the number of bytes in the entry (5) • 0x02 is the 'Data Type Value (https://adafru.it/cYs)' and indicates that this is an 'I ncomplete List of 16-bit Service Class UUIDs' • 0x0D 0x18 is the first 16-bit UUID (which translates to 0x180D, corresponding to the Heart Rate Service (https://adafru.it/ddB)). • 0x0A 0x18 is another 16-bit UUID (which translates to 0x180A, corresponding to the Device Information Service (https://adafru.it/ecj)). Including the service UUIDs is important since some mobile applications will only work with devices that advertise a specific service UUID in the advertising packet. This is true for most apps from Nordic Semiconductors, for example. ©Adafruit Industries Page 117 of 161 Codebase Revision: 0.3.0 Parameters: The raw byte array that should be inserted into the advertising data section of the advertising packet, being careful to stay within the space limits defined by the Bluetooth Core Specification. Response: None # Advertise as Discoverable and BLE only with 16-bit UUIDs 0x180D and 0x180A AT+GAPSETADVDATA=02-01-06-05-02-0d-18-0a-18 OK The results of this command can be seen in the screenshot below, taken from a sniffer analyzing the advertising packets in Wireshark. The advertising data payload is higlighted in blue in the raw byte array at the bottom of the image, and the packet analysis is in the upper section: BLE GATT GATT (https://adafru.it/iCp), which standards for the Generic ATTribute Profile, governs data organization and data exchanges between connected devices.  One device (the peripheral) acts as a GATT Server, which stores data in Attribute records, and the second device in the connection (the central) acts as a GATT Client, requesting data from the server whenever necessary. The following commands can be used to create custom GATT services and characteristics on the BLEFriend, which are used to store and exchange data. ©Adafruit Industries Page 118 of 161 Please note that any characteristics that you define here will automatically be saved to non-volatile FLASH config memory on the device and re-initialised the next time the device starts. You need to perform a system reset via 'ATZ' before most of the commands below will take effect! GATT Limitations The commands below have the following limitations due to SRAM and resource availability, which should be kept in mind when creating or working with customer GATT services and characteristics. These values apply to firmware 0.7.0 and higher: • Maximum number of services: 10 • Maximum number of characteristics: 30 • Maximum buffer size for each characteristic: 32 bytes • Maximum number of CCCDs: 16 If you want to clear any previous config value, enter the 'AT+FACTORYRESET' command before working on a new peripheral configuration. AT+GATTCLEAR Clears any custom GATT services and characteristics that have been defined on the device. Codebase Revision: 0.3.0 Parameters: None Response: None AT+GATTCLEAR OK ©Adafruit Industries Page 119 of 161 AT+GATTADDSERVICE Adds a new custom service definition to the device. Codebase Revision: 0.3.0 Parameters: This command accepts a set of comma-separated key-value pairs that are used to define the service properties.  The following key-value pairs can be used: • UUID: The 16-bit UUID to use for this service.  16-bit values should be in hexadecimal format (0x1234). • UUID128: The 128-bit UUID to use for this service.  128-bit values should be in the following format: 00-11-22-33-44-55-66-77-88-99-AA-BB-CC-DD-EE-FF  Response: The index value of the service in the custom GATT service lookup table. (It's important to keep track of these index values to work with the service later.) Note: Key values are not case-sensitive Only one UUID type can be entered for the service (either UUID or UUID128) # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a battery service (UUID = 0x180F) to the peripheral AT+GATTADDSERVICE=UUID=0x180F 1 OK # Add a battery measurement characteristic (UUID = 0x2A19), notify enabled AT+GATTADDCHAR=UUID=0x2A19,PROPERTIES=0x10,MIN_LEN=1,VALUE=100 1 OK # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a custom service to the peripheral AT+GATTADDSERVICE=UUID128=00-11-00-11-44-55-66-77-88-99-AA-BB-CC-DD-EE-FF 1 OK # Add a custom characteristic to the above service (making sure that there # is no conflict between the 16-bit UUID and bytes 3+4 of the 128-bit service UUID) AT+GATTADDCHAR=UUID=0x0002,PROPERTIES=0x02,MIN_LEN=1,VALUE=100 ©Adafruit Industries Page 120 of 161 1 OK AT+GATTADDCHAR Adds a custom characteristic to the last service that was added to the peripheral (via AT+GATTADDSERVICE). AT+GATTADDCHAR must be run AFTER AT+GATTADDSERVICE, and will add the new characteristic to the last service definition that was added. As of version 0.6.6 of the Bluefruit LE firmware you can now use custom 128-bit UUIDs with this command. See the example at the bottom of this command description. Codebase Revision: 0.3.0 Parameters: This command accepts a set of comma-separated key-value pairs that are used to define the characteristic properties.  The following key-value pais can be used: • UUID: The 16-bit UUID to use for the characteristic (which will be insert in the 3rd and 4th bytes of the parent services 128-bit UUID). This value should be entered in hexadecimal format (ex. 'UUID=0x1234'). This value must be unique, and should not conflict with bytes 3+4 of the parent service's 128-bit UUID. • PROPERTIES: The 8-bit characteristic properties field, as defined by the Bluetooth SIG. The following values can be used: ◦ 0x02 - Read ◦ 0x04 - Write Without Response ◦ 0x08 - Write ◦ 0x10 - Notify ◦ 0x20 - Indicate • MIN_LEN: The minimum size of the values for this characteristic (in bytes, min = 1, max = 20, default = 1) • MAX_LEN: The maximum size of the values for the characteristic (in bytes, min = 1, max = 20, default = 1) • VALUE: The initial value to assign to this characteristic (within the limits of 'MIN_LEN' and 'MAX_LEN'). Value can be an integer ("-100", "27"), a hexadecimal value ("0xABCD"), a byte array ("aa-bb-cc-dd") or a string ("GATT!"). ©Adafruit Industries Page 121 of 161 • >=0.7.0 - DATATYPE: This argument indicates the data type stored in the characteristic, and is used to help parse data properly.  It can be one of the following values: ◦ AUTO (0, default) ◦ STRING (1) ◦ BYTEARRAY (2) ◦ INTEGER (3) • >=0.7.0 - DESCRIPTION: Adds the specified string as the characteristic description entry • >=0.7.0 - PRESENTATION: Adds the specified value as the characteristic presentation format entry Response: The index value of the characteristic in the custom GATT characteristic lookup table. (It's important to keep track of these characteristic index values to work with the characteristic later.) Note: Key values are not case-sensitive Make sure that the 16-bit UUID is unique and does not conflict with bytes 3+4 of the 128-bit service UUID # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a battery service (UUID = 0x180F) to the peripheral AT+GATTADDSERVICE=UUID=0x180F 1 OK # Add a battery measurement characteristic (UUID = 0x2A19), notify enabled AT+GATTADDCHAR=UUID=0x2A19,PROPERTIES=0x10,MIN_LEN=1,VALUE=100 1 OK # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a custom service to the peripheral AT+GATTADDSERVICE=UUID128=00-11-00-11-44-55-66-77-88-99-AA-BB-CC-DD-EE-FF 1 OK # Add a custom characteristic to the above service (making sure that there # is no conflict between the 16-bit UUID and bytes 3+4 of the 128-bit service UUID) AT+GATTADDCHAR=UUID=0x0002,PROPERTIES=0x02,MIN_LEN=1,VALUE=100 1 OK ©Adafruit Industries Page 122 of 161 Version 0.6.6 of the Bluefruit LE firmware added the ability to use a new 'UUID128' flag to add custom 128-bit UUIDs that aren't related to the parent service UUID (which is used when passing the 16-bit 'UUID' flag). To specify a 128-bit UUID for your customer characteristic, enter a value resembling the following syntax: # Add a custom characteristic to the above service using a # custom 128-bit UUID AT+GATTADDCHAR=UUID128=00-11-22-33-44-55-66-77-88-99-AA-BB-CC-DD-EEFF,PROPERTIES=0x02,MIN_LEN=1,VALUE=100 1 OK Version 0.7.0 of the Bluefruit LE firmware added the new DESCRIPTION and PRESENT ATION keywoards, corresponding the the GATT Characteristic User Description (https: //adafru.it/oIA) and the GATT Characteristic Presentation Format (https://adafru.it/oIB)  Descriptors. The DESCRIPTION field is a string that contains a short text description of the characteristic.  Some apps may not display this data, but it should be visible using something like the Master Control Panel application from Nordic on iOS and Android. The PRESENTATION field contains a 7-byte payload that encapsulates the characteristic presentation format data.  It requires a specific set of bytes and values to work properly. See the following link for details on how to format the payload: https ://developer.bluetooth.org/gatt/descriptors/Pages/DescriptorViewer.aspx? u=org.bluetooth.descriptor.gatt.characteristic_presentation_format.xml (https:// adafru.it/oIB) The following example shows how you might use both of these new fields: AT+GATTADDCHAR=UUID=0x2A37, PROPERTIES=0x10, MIN_LEN=2, MAX_LEN=3, VALUE=00-40, DESCRIPTION=HRM Measurement, PRESENTATION=17-00-AC-27-01-00-00 For the Characteristic Presentation Format we have: • Format = IEEE-11073 32-bit FLOAT (Decimal 23, Hex 0x17) • Exponent = 0/None • Unit = Thermodynamic temperature: Degrees Fahrenheit (0x27AC) - Bluetooth LE Unit List (https://adafru.it/oID) • Namespace = Bluetooth SIG Assigned Number (0x01) • Description = None (0x0000) ©Adafruit Industries Page 123 of 161 The results from Nordic's Master Control Panel app can be seen below: AT+GATTCHAR Gets or sets the value of the specified custom GATT characteristic (based on the index ID returned when the characteristic was added to the system via AT+GATTADDCHAR). Codebase Revision: 0.3.0 Parameters: This function takes one or two comma-separated functions (one parameter = read, two parameters = write). • The first parameter is the characteristic index value, as returned from the AT+GATTADDCHAR function. This parameter is always required, and if no second parameter is entered the current value of this characteristic will be returned. • The second (optional) parameter is the new value to assign to this characteristic (within the MIN_SIZE and MAX_SIZE limits defined when creating it). Response: If the command is used in read mode (only the characteristic index is provided as a value), the response will display the current value of the characteristics.  If the command is used in write mode (two comma-separated values are provided), the characteristics will be updated to use the provided value. # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a battery service (UUID = 0x180F) to the peripheral AT+GATTADDSERVICE=UUID=0x180F 1 OK ©Adafruit Industries Page 124 of 161 # Add a battery measurement characteristic (UUID = 0x2A19), notify enabled AT+GATTADDCHAR=UUID=0x2A19,PROPERTIES=0x10,MIN_LEN=1,VALUE=100 1 OK # Read the battery measurement characteristic (index ID = 1) AT+GATTCHAR=1 0x64 OK # Update the battery measurement characteristic to 32 (hex 0x20) AT+GATTCHAR=1,32 OK # Verify the previous write attempt AT+GATTCHAR=1 0x20 OK AT+GATTLIST Lists all custom GATT services and characteristics that have been defined on the device. Codebase Revision: 0.3.0 Parameters: None Response: A list of all custom services and characteristics defined on the device. # Clear any previous custom services/characteristics AT+GATTCLEAR OK # Add a battery service (UUID = 0x180F) to the peripheral AT+GATTADDSERVICE=UUID=0x180F 1 OK # Add a battery measurement characteristic (UUID = 0x2A19), notify enabled AT+GATTADDCHAR=UUID=0x2A19,PROPERTIES=0x10,MIN_LEN=1,VALUE=100 1 OK # Add a custom service to the peripheral AT+GATTADDSERVICE=UUID128=00-11-00-11-44-55-66-77-88-99-AA-BB-CC-DD-EE-FF 2 OK # Add a custom characteristic to the above service (making sure that there # is no conflict between the 16-bit UUID and bytes 3+4 of the 128-bit service UUID) AT+GATTADDCHAR=UUID=0x0002,PROPERTIES=0x02,MIN_LEN=1,VALUE=100 2 OK # Get a list of all custom GATT services and characteristics on the device AT+GATTLIST ID=01,UUID=0x180F ID=01,UUID=0x2A19,PROPERTIES=0x10,MIN_LEN=1,MAX_LEN=1,VALUE=0x64 ©Adafruit Industries Page 125 of 161 ID=02,UUID=0x11, UUID128=00-11-00-11-44-55-66-77-88-99-AA-BB-CC-DD-EE-FF ID=02,UUID=0x02,PROPERTIES=0x02,MIN_LEN=1,MAX_LEN=1,VALUE=0x64 OK AT+GATTCHARRAW This read only command reads binary (instead of ASCII) data from a characteristic. It is non-printable but has less overhead and is easier when writing libraries in Arduino. Codebase Revision: 0.7.0 Parameters: The numeric ID of the characteristic to display the data for Output: Binary data corresponding to the specified characteristic. Note: This is a specialized command and no NEWLINE is present at the end of the command! Debug The following debug commands are available on Bluefruit LE modules: Use these commands with care since they can easily lead to a HardFault error on the ARM core, which will cause the device to stop responding. AT+DBGMEMRD Displays the raw memory contents at the specified address. Codebase Revision: 0.3.0 Parameters: The following comma-separated parameters can be used with this command: • The starting address to read memory from (in hexadecimal form, with or without the leading '0x') • The word size (can be 1, 2, 4 or 8) • The number of words to read ©Adafruit Industries Page 126 of 161 Output: The raw memory contents in hexadecimal format using the specified length and word size (see examples below for details) # Read 12 1-byte values starting at 0x10000009 AT+DBGMEMRD=0x10000009,1,12 FF FF FF FF FF FF FF 00 04 00 00 00 OK # Try to read 2 4-byte values starting at 0x10000000 AT+DBGMEMRD=0x10000000,4,2 55AA55AA 55AA55AA OK # Try to read 2 4-byte values starting at 0x10000009 # This will fail because the Cortex M0 can't perform misaligned # reads, and any non 8-bit values must start on an even address AT+DBGMEMRD=0x10000009,4,2 MISALIGNED ACCESS ERROR AT+DBGNVMRD Displays the raw contents of the config data section of non-volatile memory Codebase Revision: 0.3.0 Properties: None Output: The raw config data from non-volatile memory AT+DBGNVMRD FE CA 38 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ©Adafruit Industries 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 52 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Page 127 of 161 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 OK 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BA 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AT+DBGSTACKSIZE Returns the current stack size, to help detect stack overflow or detect stack memory usage when optimising memory usage on the system. Codebase Revision: 0.4.7 Parameters: None Output: The current size of stack memory in bytes AT+DBGSTACKSIZE 1032 OK AT+DBGSTACKDUMP Dumps the current stack contents. Unused sections of stack memory are filled with '0xCAFEFOOD' to help determine where stack usage stops. This command is purely for debug and development purposes. Codebase Revision: 0.4.7 ©Adafruit Industries Page 128 of 161 Parameters: None Output: The memory contents of the entire stack region AT+DBGSTACKDUMP 0x20003800: CAFEF00D 0x20003810: CAFEF00D 0x20003820: CAFEF00D 0x20003830: CAFEF00D 0x20003840: CAFEF00D 0x20003850: CAFEF00D 0x20003860: CAFEF00D 0x20003870: CAFEF00D 0x20003880: CAFEF00D 0x20003890: CAFEF00D 0x200038A0: CAFEF00D 0x200038B0: CAFEF00D 0x200038C0: CAFEF00D 0x200038D0: CAFEF00D 0x200038E0: CAFEF00D 0x200038F0: CAFEF00D 0x20003900: CAFEF00D 0x20003910: CAFEF00D 0x20003920: CAFEF00D 0x20003930: CAFEF00D 0x20003940: CAFEF00D 0x20003950: CAFEF00D 0x20003960: CAFEF00D 0x20003970: CAFEF00D 0x20003980: CAFEF00D 0x20003990: CAFEF00D 0x200039A0: CAFEF00D 0x200039B0: CAFEF00D 0x200039C0: CAFEF00D 0x200039D0: CAFEF00D 0x200039E0: CAFEF00D 0x200039F0: CAFEF00D 0x20003A00: CAFEF00D 0x20003A10: CAFEF00D 0x20003A20: CAFEF00D 0x20003A30: CAFEF00D 0x20003A40: CAFEF00D 0x20003A50: CAFEF00D 0x20003A60: CAFEF00D 0x20003A70: CAFEF00D 0x20003A80: CAFEF00D 0x20003A90: CAFEF00D 0x20003AA0: CAFEF00D 0x20003AB0: CAFEF00D 0x20003AC0: CAFEF00D 0x20003AD0: CAFEF00D 0x20003AE0: CAFEF00D 0x20003AF0: CAFEF00D 0x20003B00: CAFEF00D 0x20003B10: CAFEF00D 0x20003B20: CAFEF00D 0x20003B30: CAFEF00D 0x20003B40: CAFEF00D 0x20003B50: CAFEF00D 0x20003B60: CAFEF00D 0x20003B70: CAFEF00D 0x20003B80: CAFEF00D 0x20003B90: CAFEF00D 0x20003BA0: CAFEF00D 0x20003BB0: CAFEF00D 0x20003BC0: CAFEF00D ©Adafruit Industries CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D CAFEF00D Page 129 of 161 0x20003BD0: 0x20003BE0: 0x20003BF0: 0x20003C00: 0x20003C10: 0x20003C20: 0x20003C30: 0x20003C40: 0x20003C50: 0x20003C60: 0x20003C70: 0x20003C80: 0x20003C90: 0x20003CA0: 0x20003CB0: 0x20003CC0: 0x20003CD0: 0x20003CE0: 0x20003CF0: 0x20003D00: 0x20003D10: 0x20003D20: 0x20003D30: 0x20003D40: 0x20003D50: 0x20003D60: 0x20003D70: 0x20003D80: 0x20003D90: 0x20003DA0: 0x20003DB0: 0x20003DC0: 0x20003DD0: 0x20003DE0: 0x20003DF0: 0x20003E00: 0x20003E10: 0x20003E20: 0x20003E30: 0x20003E40: 0x20003E50: 0x20003E60: 0x20003E70: 0x20003E80: 0x20003E90: 0x20003EA0: 0x20003EB0: 0x20003EC0: 0x20003ED0: 0x20003EE0: 0x20003EF0: 0x20003F00: 0x20003F10: 0x20003F20: 0x20003F30: 0x20003F40: 0x20003F50: 0x20003F60: 0x20003F70: 0x20003F80: 0x20003F90: 0x20003FA0: 0x20003FB0: 0x20003FC0: 0x20003FD0: 0x20003FE0: 0x20003FF0: OK CAFEF00D CAFEF00D CAFEF00D 00000004 CAFEF00D CAFEF00D 00000001 20001BB0 00000006 20001C6C 20001D38 00000001 00550000 000080E8 60140000 80000000 00000000 200018D4 0000011C 00000000 0000011C 0000011C 00000048 0001E326 000080E8 61C78000 0000A1FC 00000000 000080E8 622C8000 40011000 00000000 62780000 00000000 20003DF8 00000200 00000001 00000001 2000311B 20002050 20002050 20002050 20002050 00000001 00000000 00021263 20003ED8 20003ED4 00000008 FFFFFFFF 20302058 20002050 32002050 20002050 00000000 20003F40 200030D4 000001D8 6C383025 1FFF4000 200020C7 FFFFFFFF 200020B4 200020B0 CAFEF00D FFFFFFFF 00000000 ©Adafruit Industries CAFEF00D CAFEF00D CAFEF00D 20001D04 00001098 CAFEF00D 200018D8 000134A5 00000006 20001D44 00000005 00012083 00000001 00000009 20002764 000080E8 0001E4D9 00000000 0001BCE1 0001BC1D 0001BDA9 FFFFFFF9 00000010 00000001 0001E9CF 000080E8 0002125C 0012A236 00000009 0012A29B 000185EF 00000004 00018579 20003054 0002085D 0001F663 2000311B 00000000 00000042 200030D4 20003F1B 0001FFA3 0001FF8B 0012A54E 20002050 00000005 20002050 20003054 20003F64 00000008 2000311B 00000000 32303032 200030D4 20002050 200030D4 20003F60 00016559 00000058 00000028 000166C5 200020B8 000180AD 200020B0 CAFEF00D FFFFFFFF 00000000 CAFEF00D CAFEF00D 00000000 CAFEF00D CAFEF00D 00001006 20001C50 0000100D 20001C38 00000006 20001D38 200018C8 80E80000 60900000 0009608F 00000000 80E80000 80E80000 0000203A 80E80000 80E80000 008B8000 0000A000 80E80000 00000000 00000048 00000000 00000000 00004998 00000042 00006E10 0000000C 2000311B 20002050 00000001 00000001 0001F631 0000000C 200030D4 20002050 20002050 00000005 00000010 00000020 200030D4 0000000C 200030D4 00000000 00000084 00000001 0001F631 0000000C 00323330 20002050 00000020 00000004 000001D6 0000000C 200030D4 00000028 000166AD 2000306C 1FFF4000 1FFF4000 200020B4 1FFF4000 00000000 CAFEF00D CAFEF00D CAFEF00D FFFFEF68 CAFEF00D 200018D8 00000004 20001D28 20001D44 00000005 00000000 000013D3 4FC40000 000080E8 000080E8 00129F5F 200018C8 000000FF 0001BC1D 0001BCE1 0001BDA9 0001BC1D 00000009 51538000 00000009 00000504 000080E8 0001E4D9 000080E8 0001E479 00000000 00000000 0001ACDF 00000001 200030D4 200030D4 00020A6D 200030D4 00020AD7 00020833 0001FF89 20003ED8 00020491 00022409 0001FF8B 20003F74 00020187 20003F75 FFFFFFFF 00000008 00020A6D 200030D4 000258D7 00020833 000001CE 0001ED83 000001D7 00000000 FFFFFFFF 000217F8 00017ED9 200030D4 200020B0 0001A63D 00000002 00000000 00016113 Page 130 of 161 History This page tracks additions or changes to the AT command set based on the firmware version number (which you can obtain via the 'ATI' command): Version 0.7.7 The following AT commands and features were added in the 0.7.7 release: • Added AT+BLEUARTTXF (F for force) to immediately send the specified data out in an BLE UART packet (max 20 bytes), bypassing any FIFO delays and avoiding packets potentially being transmitted in two transactions. • Adjusted BLE UART service to use min connection interval as the tx interval • Added AT+DFUIRQ to enable using the DFU Pin for IRQ purposes when there is a supported event on the nRF51822 • Enabled the internal pullup resistor on the CS pin for Bluefruit SPI boards • Added AT+MODESWITCHEN to enable/disable +++ mode switching from the local (serial or SPI) or BLE UART side. By default local = enabled, ble = disabled, meaning commands can only be executed via the local interface by default. • Implemented a '\+' escape code to immediately send '+' chars without trigger the +++ delay waiting for further similar input • Added AT+BLEHIDGAMEPADEN to separately enable HID Gamepad, since iOS/ OSX has a conflict with gamepad devices causing HID keyboard to not work properly. The following bugs were fixed in release 0.7.7: • Fixed a factory reset issue when a long delay occurs in app_error_handler() • Fixed an issue where strings were being truncated at 64 chars in UART • Fixed HID keyboard support not working with iOS 9 & 10 Version 0.7.0 The following AT commands were added in the 0.7.0 release: • AT+BAUDRATE Change the HW UART baudrate ©Adafruit Industries Page 131 of 161 • AT+UARTFLOW Enable or disable HW UART flow control • AT+BLEMIDIEN=on/off/0/1 Enable/disable MIDI service, requires a reset to take effect • AT+BLEMIDITX Send a MIDI event • AT+BLEMIDIRX Receive an available MIDI event • AT+GATTCHARRAW Added this read only command to read binary (instead of ASCII) data from a characteristic. It is non-printable but less overhead and easier for writing library in Arduino • AT+NVMWRITE=offset,datatype,data Writes data to 256 byte user NVM. Datatype must be STRING (1), BYTEARRAY (2), or INTEGER (3) • AT+NVMREAD=offset,size,datatype Reads data back from 256 bytes user NVM • AT+NVMREADRAW=offset,size binary data Binary data (instead of ASCII) is returned, ending with "OK\r\n". It is non-printable but less overhead and easier to use in some situations. • AT+BLEHIDGAMEPAD=x,y,buttons ◦ X is LEFT, RIGHT: X=-1 LEFT is pressed, X=1 RIGHT is pressed, X=0 no pressed ◦ Y is UP, DOWN: Y=-1 i UP, Y=1 is DOWN, Y=0 no pressed ◦ Button [0x00-0xFF] is a bit mask for 8 button 0-7 • AT+GAPCONNECTABLE=on/off/1/0 Allow/disallow connection to the device • AT+EDDYSTONESERVICEEN Add/remove EddyStone service to GATT table (requires reset) • AT+EDDYSTONEBROADCAST=on/off/0/1 Start/stop broadcasting url using settings from NVM • AT+BLEBATTEN=on/off/1/0 Enable battery service. Reset required due to the service change. • AT+BLEBATTVAL=percent Updates the Battery level, percent is 0 to 100 ©Adafruit Industries Page 132 of 161 The following commands were changed in the 0.7.0 release: • AT+GATTADDCHAR ◦ Added a DATATYPE option to indicate the data type for the GATT characteristic's payload. Valid option are: AUTO (0, default), STRING (1), BYTEARRAY (2), INTEGER (3) ◦ Added characteristic user description option via the DESCRIPTION flag ◦ Added characteristic presentation format support via the PRESENTATION flag • AT+GAPINTERVALS Added a new 'adv_lowpower_interval' parameter, default value is 417.5 ms. Current arguments are now:  min_conn, max_conn, adv_interval, adv_timeout, adv_lowpower_interval Key bug fixes and changes in this release: • Significant BTLE UART speed and reliability improvements • Added callback support (work in progress) for: ◦ BLE UART RX ◦ GATT Characteristic(s) RX ◦ MIDI RX ◦ Connect/Disconnect • Increased MAX_LEN for each characteristic from 20 to 32 bytes • Changed the default GAP parameters: ◦ Advertising interval = 20ms ◦ Min connection interval = 20 ms ◦ Max connection interval = 40 ms • Increased the maximum number of CCCDs saved to flash from 8 to 16 • Eddystone config service disabled by default • Removed AT+EDDYSTONEENABLE to avoid confusion • Changed advertising timeout for Eddystone to 'unlimited' • Fixed Write-No-Response characteristic property, which wasn't being handled properly • Fixed timing constraints to meet Apple design guidelines • Fixed systick to ms calculation • Fixed all tests with google eddystone validator except for writing tx_power = 1 dB (not valid on nrf51) ©Adafruit Industries Page 133 of 161 • Fixed a bug where writing from the central does not update the value on the characteristic correctly • Fixed an issue with HID examples, where when paired with Central, a disconnect then reconnect could not send HID reports anymore Version 0.6.7 The following AT commands were added in the 0.6.7 release: • AT+BLEUARTFIFO Returns the number of free bytes available in the TX and RX FIFOs for the Bluetooth UART Service. The following commands were changed in the 0.6.7 release: • AT+BLEUARTTX If the TX FIFO is full, the command will wait up to 200ms to see if the FIFO size decreases before exiting and returning an ERROR response due to the FIFO being full. • AT+BLEURIBEACON This command will go back to using the old (deprecated) UriBeacon UUID (0xFED8), and only the AT+EDDYSTONEURL command will use the newer Eddystone UUID (0xFEAA). • AT+BLEKEYBOARD and AT+BLEUARTTX These commands now accept '\?' as an escape code since 'AT+BLEKEYBOARD=?' has another meaning for the AT parser. To send a single question mark the following command should be used: 'AT+BLEKEYBOARD=\?' or 'AT+BLEUARTTX=\?' • AT+EDDYSTONEURL This command now accepts an optional third parameter for RSSI at 0m value (default is -18dBm).  Running this command with no parameters ('AT+EDDYSTONEURL\r\n') will now return the current URL. Key bug fixes in this release: • The FIFO handling for the Bluetooth UART Service was improved for speed and stability, and the TX and RF FIFOs were increased to 1024 bytes each. ©Adafruit Industries Page 134 of 161 • An issue where a timer overflow was causing factory resets every 4 hours or so has been resolved. • Fixed a problem with the GATT server where 'value_len' was being incorrectly parsed for integer values in characteristics where 'max_len' >4 Version 0.6.6 The following AT commands were added in the 0.6.6 release: • AT+EDDYSTONEURL Update the URL for the beacon and switch to beacon mode • AT+EDDYSTONEENABLE Enable/disable beacon mode using the configured url • AT+EDDYSTONECONFIGEN Enable advertising for the the Eddystone configuration service for the specified number of seconds • AT+HWMODELED Allows the user to override the default MODE LED behaviour with one of the following options: DISABLE, MODE, HWUART, BLEUART, SPI, MANUAL • AT+BLECONTROLKEY Allows HID media control values to be sent to a bonded central device (volume, screen brightness, etc.) • AT+BLEHIDEN Enables or disables BLE HID support in the Bluefruit LE firmware (mouse, keyboard and media control) • AT+BLEMOUSEMOVE To move the HID mouse • AT+BLEMOUSEBUTTON To set the state of the HID mouse buttons The following commands were changed in the 0.6.6 release: • AT+BLEKEYBOARDEN - Now an alias for AT+BLEHIDEN • AT+GATTADDCHAR - Added a new UUID128 field to allow custom UUIDs Key bug fixes in this release: • Fixed issues with long beacon URLs • Fixed big endian issue in at+blebeacon for major & minor number ©Adafruit Industries Page 135 of 161 Known issues with this release: • Windows 10 seems to support a limited number of characteristics for the DIS service. We had to disable the Serial Number characteristic to enable HID support with windows 10. Version 0.6.5 The following AT commands were added in the 0.6.5 release: • AT+BLEGETPEERADDR (https://adafru.it/iCq) The following commands were changed in the 0.6.5 release: • Increased the UART buffer size (on the nRF51) from 128 to 256 bytes • +++ now responds with the current operating mode • Fixed a bug with AT+GATTCHAR values sometimes not being saved to NVM • Fixed a bug with AT+GATTCHAR max_len value not being taken into account after a reset (min_len was always used when repopulating the value) Version 0.6.2 This is the first release targetting 32KB SRAM parts (QFAC). 16KB SRAM parts can't be used with this firmware due to memory management issues, and should use the earlier 0.5.0 firmware. The following AT commands were changed in the 0.6.2 release: • AT+BLEUARTTX (https://adafru.it/iCr) Basic escape codes were added for new lines, tabs and backspace • AT+BLEKEYBOARD (https://adafru.it/iCr) Also works with OS X now, and may function with other operating systems that support BLE HID keyboards ©Adafruit Industries Page 136 of 161 Version 0.5.0 The following AT commands were added in the 0.5.0 release: • AT+BLEKEYBOARDEN (https://adafru.it/iCr) • AT+BLEKEYBOARD (https://adafru.it/iCr) • AT+BLEKEYBOARDCODE (https://adafru.it/iCr) The following AT commands were changed in the 0.5.0 release: • ATI (https://adafru.it/iCs) The SoftDevice, SoftDevice version and bootloader version were added as a new (7th) record. For Ex: "S110 7.1.0, 0.0" indicates version 7.1.0 of the S110 softdevice is used with the 0.0 bootloader (future boards will use a newer 0.1 bootloader). Other notes concerning 0.5.0: Starting with version 0.5.0, you can execute the AT+FACTORYRESET command at any point (and without a terminal emulator) by holding the DFU button down for 10 seconds until the blue CONNECTED LED starts flashing, then releasing it. Version 0.4.7 The following AT commands were added in the 0.4.7 release: • +++ (https://adafru.it/iCs) • AT+HWRANDOM (https://adafru.it/iCt) • AT+BLEURIBEACON (https://adafru.it/iCu) • AT+DBGSTACKSIZE (https://adafru.it/iCv) • AT+DBGSTACKDUMP (https://adafru.it/iCv) The following commands were changed in the 0.4.7 release: • ATI  (https://adafru.it/iCs)The chip revision was added after the chip name. Whereas ©Adafruit Industries Page 137 of 161 ATI would previously report 'nRF51822', it will now add the specific HW revision if it can be detected (ex 'nRF51822 QFAAG00') Version 0.3.0 • First public release GATT Service Details Data in Bluetooth Low Energy is organized around units called 'GATT Services (https:/ /adafru.it/iCp)' and 'GATT Characteristics'.  To expose data to another device, you must instantiate at least one service on your device. Adafruit's Bluefruit LE Pro modules support some 'standard' services, described below (more may be added in the future). UART Service The UART Service is the standard means of sending and receiving data between connected devices, and simulates a familiar two-line UART interface (one line to transmit data, another to receive it). The service is described in detail on the dedicated UART Service (https://adafru.it/iCn)  page. UART Service Base UUID: 6E400001-B5A3-F393-E0A9-E50E24DCCA9E This service simulates a basic UART connection over two lines, TXD and RXD. It is based on a proprietary UART service specification by Nordic Semiconductors. Data sent to and from this service can be viewed using the nRFUART apps from Nordic Semiconductors for Android and iOS. This service is available on every Bluefruit LE module and is automatically started during the power-up sequence. ©Adafruit Industries Page 138 of 161 Characteristics Nordic’s UART Service includes the following characteristics: Name TX RX Mandatory Yes Yes UUID 0x0002 0x0003 Type U8[20] U8[20] R X W X N I X R = Read; W = Write; N = Notify; I = Indicate Characteristic names are assigned from the point of view of the Central device TX (0x0002) This characteristic is used to send data back to the sensor node, and can be written to by the connected Central device (the mobile phone, tablet, etc.). RX (0x0003) This characteristic is used to send data out to the connected Central device. Notify can be enabled by the connected device so that an alert is raised every time the TX channel is updated. Software Resources To help you get your Bluefruit LE module talking to other Central devices, we've put together a number of open source tools for most of the major platforms supporting Bluetooth Low Energy. Bluefruit LE Client Apps and Libraries Adafruit has put together the following mobile or desktop apps and libraries to make it as easy as possible to get your Bluefruit LE module talking to your mobile device or laptop, with full source available where possible: ©Adafruit Industries Page 139 of 161 Bluefruit LE Connect (https://adafru.it/f4G) (Android/Java) Bluetooth Low Energy support was added to Android starting with Android 4.3 (though it was only really stable starting with 4.4), and we've already released Bluefrui t LE Connect to the Play Store (https://adafru.it/f4G). The full source code (https://adafru.it/fY9) for Bluefruit LE Connect for Android is also available on Github to help you get started with your own Android apps.  You'll need a recent version of Android Studio (https://adafru.it/fYa) to use this project. Bluefruit LE Connect (https://adafru.it/f4H)  (iOS/Swift) Apple was very early to adopt Bluetooth Low Energy, and we also have an iOS version of the Bluefruit LE Connect (https://adafru.it/f4H) app available in Apple's app store. The full swift source code for Bluefruit LE Connect for iOS is also available on Github. You'll need XCode and access to Apple's developper program to use this project: • Version 1.x source code: https://github.com/adafruit/Bluefruit_LE_Connect (https: //adafru.it/ddv) • Version 2.x source code: https://github.com/adafruit/Bluefruit_LE_Connect_v2 (h ttps://adafru.it/o9E) Version 2.x of the app is a complete rewrite that includes iOS, OS X GUI and OS X command-line tools in a single codebase. ©Adafruit Industries Page 140 of 161 Bluefruit LE Connect for OS X (https:// adafru.it/o9F) (Swift) This OS X desktop application is based on the same V2.x codebase as the iOS app, and gives you access to BLE UART, basic Pin I/O and OTA DFU firmware updates from the convenience of your laptop or mac. This is a great choice for logging sensor data locally and exporting it as a CSV, JSON or XML file for parsing in another application, and uses the native hardware on your computer so no BLE dongle is required on any recent mac. The full source is also available on Github (https://adafru.it/o9E). ©Adafruit Industries Page 141 of 161 Bluefruit LE Command Line Updater for OS X (https://adafru.it/pLF) (Swift) This experimental command line tool is unsupported and provided purely as a proof of concept, but can be used to allow firmware updates for Bluefruit devices from the command line. This utility performs automatic firmware updates similar to the way that the GUI application does, by checking the firmware version on your Bluefruit device (via the Device Information Service), and comparing this against the firmware versions available online, downloading files in the background if appropriate. Simply install the pre-compiled tool via the DMG file (https://adafru.it/pLF) and place it somewhere in the system path, or run the file locally via './bluefruit' to see the help menu: $ ./bluefruit bluefruit v0.3 Usage: bluefruit <command> [options...] Commands: Scan peripherals: Automatic update: Custom firmware: uuid <uuid>] Show this screen: Show version: scan update [--enable-beta] [--uuid <uuid>] dfu --hex <filename> [--init <filename>] [---help --version Options: --uuid <uuid> If present the peripheral with that uuid is used. If not present a list of peripherals is displayed --enable-beta If not present only stable versions are used Short syntax: -u = --uuid, -b = --enable-beta, -h = --hex, -i = --init, -v = --version, -? = --help Deprecated: Bluefruit Buddy (https://adafru.it/mCn) (OS X) This native OS X application is a basic proof of concept app that allows you to connect to your Bluefruit LE module using most recent macbooks or iMacs. You can get basic information about the modules and use the UART service to send and receive data. The full source for the application is available in the github repo at Adafruit_BluefruitL E_OSX (https://adafru.it/mCo). ©Adafruit Industries Page 142 of 161 ABLE (https://adafru.it/ijB) (Cross Platform/Node+Electron) ABLE (https://adafru.it/ijB) (Adafruit Bluefruit LE Desktop) is a cross-platform desktop application based on Sandeep Misty's noble library (https://adafru.it/ijC) and the Electr on (https://adafru.it/ijD) project from Github (used by Atom). It runs on OS X, Windows 7+ and select flavours of Linux (Ubuntu tested locally).  Windows 7 support is particularly interesting since Windows 7 has no native support for Bluetooth Low Energy but the noble library talks directly to supported Bluetooth 4.0 USB dongles (http://adafru.it/1327) to emulate BLE on the system (though at this stage it's still in early BETA and drops the connection and takes more care to work with). This app allows you to collect sensor data or perform many of the same functionality offered by the mobile Bluefruit LE Connect apps, but on the desktop. The app is still in BETA, but full source (https://adafru.it/ijE) is available in addition to the easy to use pre-compiled binaries (https://adafru.it/ijB). ©Adafruit Industries Page 143 of 161 Bluefruit LE Python Wrapper (https://adafru.it/fQF) As a proof of concept, we've played around a bit with getting Python working with the native Bluetooth APIs on OS X and the latest version of Bluez on certain Linux targets. There are currently example sketches showing how to retreive BLE UART data as well as some basic details from the Device Information Service (DIS). This isn't an actively support project and was more of an experiment, but if you have a recent Macbook or a Raspberry Pi and know Python, you might want to look at Adafru it_Python_BluefruitLE (https://adafru.it/fQF) in our github account. Debug Tools If your sense of adventure gets the better of you, and your Bluefruit LE module goes off into the weeds, the following tools might be useful to get it back from unknown lands. These debug tools are provided purely as a convenience for advanced users for device recovery purposes, and are not recommended unless you're OK with potentially bricking your board. Use them at your own risk. ©Adafruit Industries Page 144 of 161 AdaLink (https://adafru.it/fPq) (Python) This command line tool is a python-based wrapper for programming ARM MCUs using either a Segger J-Link (https://adafru.it/fYU) or an STLink/V2 (https://adafru.it/ijF). You can use it to reflash your Bluefruit LE module using the latest firmware from the Bluefr uit LE firmware repo (https://adafru.it/edX). Details on how to use the tool are available in the readme.md file on the main Adafruit _Adalink (https://adafru.it/fPq) repo on Github. Completely reprogramming a Bluefruit LE module with AdaLink would require four files, and would look something like this (using a JLink): adalink nrf51822 --programmer jlink --wipe --program-hex "Adafruit_BluefruitLE_Firmware/softdevice/ s110_nrf51_8.0.0_softdevice.hex" --program-hex "Adafruit_BluefruitLE_Firmware/bootloader/bootloader_0002.hex" --program-hex "Adafruit_BluefruitLE_Firmware/0.6.7/blefriend32/ blefriend32_s110_xxac_0_6_7_150917_blefriend32.hex" --program-hex "Adafruit_BluefruitLE_Firmware/0.6.7/blefriend32/ blefriend32_s110_xxac_0_6_7_150917_blefriend32_signature.hex" You can also use the AdaLink tool to get some basic information about your module, such as which SoftDevice is currently programmed or the IC revision (16KB SRAM or 32KB SRAM) via the --info command: $ adalink nrf51822 -p jlink --info Hardware ID : QFACA10 (32KB) Segger ID : nRF51822_xxAC SD Version : S110 8.0.0 Device Addr : **:**:**:**:**:** Device ID : **************** Adafruit nRF51822 Flasher (https://adafru.it/fVL) (Python) Adafruit's nRF51822 Flasher is an internal Python tool we use in production to flash boards as they go through the test procedures and off the assembly line, or just testing against different firmware releases when debugging. It relies on AdaLink or OpenOCD beneath the surface (see above), but you can use this command line tool to flash your nRF51822 with a specific SoftDevice, Bootloader and Bluefruit firmware combination. ©Adafruit Industries Page 145 of 161 It currently supports using either a Segger J-Link or STLink/V2 via AdaLink, or GPIO on a Raspberry Pi (https://adafru.it/fVL) if you don't have access to a traditional ARM SWD debugger.  (A pre-built version of OpenOCD for the RPi is included in the repo since building it from scratch takes a long time on the original RPi.) We don't provide active support for this tool since it's purely an internal project, but made it public just in case it might help an adventurous customer debrick a board on their own. $ python flash.py --jtag=jlink --board=blefriend32 --softdevice=8.0.0 -bootloader=2 --firmware=0.6.7 jtag : jlink softdevice : 8.0.0 bootloader : 2 board : blefriend32 firmware : 0.6.7 Writing Softdevice + DFU bootloader + Application to flash memory adalink -v nrf51822 --programmer jlink --wipe --program-hex "Adafruit_BluefruitLE_Firmware/softdevice/s110_nrf51_8.0.0_softdevice.hex" -program-hex "Adafruit_BluefruitLE_Firmware/bootloader/bootloader_0002.hex" -program-hex "Adafruit_BluefruitLE_Firmware/0.6.7/blefriend32/ blefriend32_s110_xxac_0_6_7_150917_blefriend32.hex" --program-hex "Adafruit_BluefruitLE_Firmware/0.6.7/blefriend32/ blefriend32_s110_xxac_0_6_7_150917_blefriend32_signature.hex" ... BLE FAQ Can I talk to Classic Bluetooth devices with a Bluefruit LE modules? No.  Bluetooth Low Energy and 'Classic' Bluetooth are both part of the same Bluetooth Core Specification -- defined and maintained by the Bluetooth SIG -- but they are completely different protocols operating with different physical constraints and requirements.  The two protocols can't talk to each other directly. Can my Bluefruit LE module connect to other Bluefruit LE peripherals No, the Bluefruit LE firmware from Adafruit is currently peripheral only, and doesn't run in Central mode, which would cause the module to behave similar to your mobile phone or BLE enabled laptop. If you required Central support, you should look at the newer nRF52832 or nRF52840 based products like the Adafruit Feather nRF52840 (https://adafru.it/ DLQ) which contains a SoftDevice which is capable of running in either Central or Peripheral mode. The nRF518322 based products (such as the one used in this ©Adafruit Industries Page 146 of 161 learning guide) are not capable of running in Central mode because it isn't supported by the SoftDevice they use, and it isn't possible to update the SoftDevice safely without special hardware. I just got my Bluefruit board and  when I run a sketch it hangs forever on the 'Connecting...' stage! There are several possible explanations here, but the first thing to try is to: 1. Disconnect and close the Bluefruit LE Connect app if it's open 2. Disable BLE on your mobile device 3. Restart your Bluefruit sketch and HW 4. Turn BLE back on again (on the mobile device) 5. Open the Bluefruit LE Connect mobile app again and try to connect again If problems persist, try performing a Factory Reset of your device (see the appropriate learning guide for details on how to do this since it varies from one board to another). Why are none of my changes persisting when I reset with the sample sketches? In order to ensure that the Bluefruit LE modules are in a known state for the Adafruit demo sketches, most of them perform a factory reset at the start of the sketch. This is useful to ensure that the sketch functions properly, but has the side effect of erasing any custom user data in NVM and setting everything back to factory defaults every time your board comes out of reset and the sketch runs. To disable factory reset, open the demo sketch and find the FACTORYRESET_ENABLE flag and set this to '0', which will prevent the factory reset from happening at startup. If you don't see the 'FACTORYRESET_ENABLE' flag in your .ino sketch file, you probably have an older version of the sketches and may need to update to the latest version via the Arduino library manager. ©Adafruit Industries Page 147 of 161 Do I need CTS and RTS on my UART based Bluefruit LE Module? Using CTS and RTS isn't strictly necessary when using HW serial, but they should both be used with SW serial, or any time that a lot of data is being transmitted. The reason behind the need for CTS and RTS is that the UART block on the nRF51822 isn't very robust, and early versions of the chip had an extremely small FIFO meaning that the UART peripheral was quickly overwhelmed. Using CTS and RTS significantly improves the reliability of the UART connection since these two pins tell the device on the other end when they need to wait while the existing buffered data is processed. To enable CTS and RTS support, go into the BluefruitConfig.h file in your sketch folder and simply assign an appropriate pin to the macros dedicated to those functions (they may be set to -1 if they aren't currently being used). Enabling both of these pins should solve any data reliability issues you are having with large commands, or when transmitting a number of commands in a row. How can I update to the latest Bluefruit LE Firmware? The easiest way to keep your Bluefruit LE modules up to date is with our Bluefruit LE Connect app for Android (https://adafru.it/f4G) or Bluefruit LE Connect for iOS (https://adafru.it/f4H).  Both of these apps include a firmware update feature that allows you to automatically download the latest firmware and flash your Bluefruit LE device in as safe and painless a manner as possible. You can also roll back to older versions of the Bluefruit LE firmware using these apps if you need to do some testing on a previous version. Which firmware version supports 'xxx'? We regularly release Bluefruit LE firmware images (https://adafru.it/edX) with bug fixes and new features. Each AT command in this learning guide lists the minimum firmware version required to use that command, but for a higher level overview of the changes from one firmware version to the next, consult the firmware history page (https://adafru.it/iCw). ©Adafruit Industries Page 148 of 161 Does my Bluefruit LE device support ANCS? ANCS is on the roadmap for us (most likely in the 0.7.x release family), but we don't currently support it since there are some unusual edge cases when implementing it as a service. My Bluefruit LE device is stuck in DFU mode ... what can I do? If your device is stuck in DFU mode for some reason and the firmware was corrupted, you have several options. First, try a factory reset by holding down the DFU button for about 10 seconds until the CONN LED starts flashing, then release the DFU button to perform a factory reset.  If this doesn't work, you may need to reflash your firmware starting from DFU mode, which can be done in one of the following ways: Bluefruit LE Connect (Android) • Place the module in DFU mode (constant LED blinky) • Open Bluefruit LE Connect • Connect to the 'DfuTarg' device • Once connected, you will see a screen with some basic device information. Click the '...' in the top-right corner and select Firmware Updates • Click the Use Custom Firmware button • Select the appropriate .hex and .init files (copied from the Bluefruit LE Firmware repo (https://adafru.it/edX)) ... for the BLEFRIEND32 firmware version 0.6.7, this would be: ◦ Hex File: blefriend32_s110_xxac_0_6_7_150917_blefriend32.hex ◦ Init File: blefriend32_s110_xxac_0_6_7_150917_blefriend32_init.dat • Click Start Update Unfortunately, the iOS app doesn't yet support custom firmware updates from DFU mode yet, but we will get this into the next release. Nordic nRF Toolbox You can also use Nordic's nRF Toolbox application to update the firmware using the OTA bootloader. On Android: • Open nRF Toolbox (using the latest version) ©Adafruit Industries Page 149 of 161 • Click the DFU icon • Click the Select File button • Select Application from the radio button list, then click OK • Find the appropriate .hex file (ex. 'blefriend32_s110_xxac_0_6_7_150917_blefriend32.hex') • When asked about the 'Init packet', indicate Yes, and select the appropriate *_init.dat file (for example: 'blefriend32_s110_xxac_0_6_7_150917_blefriend32_init.dat'). • Click the Select Device button at the bottom of the main screen and find the DfuTarg device, clicking on it • Click the Upload button, which should now be enabled on the home screen • This will begin the DFU update process which should cause the firmware to be updated or restored on your Bluefruit LE module On iOS: • Create a .zip file containing the .hex file and init.dat file that you will use for the firmware update.  For example: ◦ Rename 'blefriend32_s110_xxac_0_6_7_150917_blefriend32.hex' to application.hex ◦ Rename 'blefriend32_s110_xxac_0_6_7_150917_blefriend32_init.dat' to application.dat • Upload the .zip file containing the application.hex and application.dat files to your iPhone using uTunes, as described here (https://adafru.it/iCx) • Open the nRF Toolbox app (using the latest version) • Click the DFU icon • Click the Select File text label • Switch to User Files to see the .zip file you uploaded above • Select the .zip file (ex. blefriend32_065.zip) • On the main screen select Select File Type • Select application • On the main screen select SELECT DEVICE • Select DfuTarg • Click the Upload button which should now be enabled • This will begin the DFU process and your Bluefruit LE module will reset when the update is complete • If you get the normal 2 or 3 pulse blinky pattern, the update worked! Adafruit_nRF51822_Flasher As a last resort, if you have access to a Raspberry Pi, a Segger J-Link or a STLink/ V2, you can also try manually reflashing the entire device, as described in the FAQ above (https://adafru.it/iCy), with further details on the Software Resources (https:// adafru.it/iCz) page. ©Adafruit Industries Page 150 of 161 How do I reflash my Bluefruit LE module over SWD? Reflashing Bluefruit LE modules over SWD (ex. switching to the sniffer firmware and back) is at your own risk and can lead to a bricked device, and we can't offer any support for this operation!  You're on your own here, and there are unfortunately 1,000,000 things that can go wrong, which is why we offer two separate Bluefruit LE Friend boards -- the sniffer and the normal Bluefruit LE Friend board with the non-sniffer firmware, which provides a bootloader with fail safe features that prevents you from ever bricking boards via OTA updates. AdaLink (SWD/JTAG Debugger Wrapper) Transitioning between the two board types (sniffer and Bluefruit LE module) is unfortunately not a risk-free operation, and requires external hardware, software and know-how to get right, which is why it isn't covered by our support team. That said ... if you're determined to go down that lonely road, and you have a Segger J-Link (https://adafru.it/fYU) (which is what we use internally for production and development), or have already erased your Bluefruit LE device, you should have a look at AdaLink (https://adafru.it/fPq), which is the tool we use internally to flash the four files required to restore a Bluefruit LE module. (Note: recent version of AdaLink also support the cheaper STLink/V2 (http://adafru.it/ 2548), though the J-Link is generally more robust if you are going to purchase a debugger for long term use.) The mandatory Intel Hex files are available in the Bluefruit LE Firmware repo (https://adafru.it/edX). You will need to flash:  • An appropriate bootloader image • An appropriate SoftDevice image • The Bluefruit LE firmware image • The matching signature file containing a CRC check so that the bootloader accepts the firmware image above (located in the same folder as the firmware image) The appropriate files are generally listed in the version control .xml file (https:// adafru.it/fPr) in the firmware repository. If you are trying to flash the sniffer firmware (at your own risk!), you only need to flash a single .hex file, which you can find here (https://adafru.it/fYV). The sniffer doesn't require a SoftDevice image, and doesn't use the fail-safe bootloader -which is why changing is a one way and risky operation if you don't have a supported SWD debugger. ©Adafruit Industries Page 151 of 161 Adafruit_nF51822_Flasher We also have an internal python tool available that sits one level higher than AdaLink (referenced above), and makes it easier to flash specific versions of the official firmware to a Bluefruit LE module.  For details, see the Adafruit_nRF51822_Flasher (https://adafru.it/fVL) repo. Can I access BETA firmware releases? The latest versions of the Bluefruit LE Connect applications for iOS and Android allow you to optionally update your Bluefruit LE modules with pre-release or BETA firmware.   This functionality is primarilly provided as a debug and testing mechanism for support issues in the forum, and should only be used when trying to identify and resolve specific issues with your modules! Enabling BETA Releases on iOS • Make sure you have at least version 1.7.1 of Bluefruit LE Connect • Go to the Settings page • Scroll to the bottom of the Settings page until you find Bluefruit LE • Click on the Bluefruit LE icon and enable the Show beta releases switch • You should be able to see any BETA releases available in the firmware repo now when you use Bluefruit LE Connect Enabling BETA Releases on Android • Make sure you have the latest version of Bluefruit LE Connect • Open the Bluefruit LE Connect application • Click the "..." icon in the top-right corner of the app's home screen • Select Settings • Scroll down to the Software Updates section and enable Show beta releases • You should be able to see any BETA releases available in the firmware repo now when you use Bluefruit LE Connect Why can't I see my Bluefruit LE device after upgrading to Android 6.0? In Android 6.0 there were some important security changes (https://adafru.it/ jcU) that affect Bluetooth Low Energy devices.  If location services are unavailable ©Adafruit Industries Page 152 of 161 (meaning the GPS is turned off) you won't be able to see Bluetooth Low Energy devices advertising either. See this issue (https://adafru.it/jcV) for details. Be sure to enable location services on your Android 6.0 device when using Bluefruit LE Connect or other Bluetooth Low Energy applications with your Bluefruit LE modules. What is the theoretical speed limit for BLE? This depends on a variety of factors, and is determined by the capabilities of the central device (the mobile phone, etc.) as much as the peripheral. Taking the HW limits on the nR51822 into account (max 6 packets per connection interval, and a minimum connection interval of 7.5ms) you end up with the following theoretical limits on various mobile operating systems: • iPhone 5/6 + IOS 8.0/8.1 6 packets * 20 bytes * 1/0.030 s = 4 kB/s = 32 kbps • iPhone 5/6 + IOS 8.2/8.3 3 packets * 20 bytes * 1/0.030 s = 2 kB/s = 16 kbps • iPhone 5/6 + IOS 8.x with nRF8001 1 packet * 20 bytes * 1/0.030 s = 0.67 kB/s = 5.3 kbps • Nexus 4 4 packets * 20 bytes * 1/0.0075 s = 10.6 kB/s = 84 kbps • Nordic Master Emulator Firmware (MEFW) with nRF51822 0.9.0 1 packet * 20 bytes * 1/0.0075 = 2.67 kB/s = 21.33 kbps • Nordic Master Emulator Firmware (MEFW) with nRF51822 0.11.0 6 packets * 20 bytes * 1/0.0075 = 16 kB/s = 128 kbps There are also some limits imposed by the Bluefruit LE firmware, but we are actively working to significantly improve the throughput in the upcoming 0.7.0 release, which will be available Q2 2016.  The above figures are useful as a theoretical maximum to decide if BLE is appropriate for you project or not. UPDATE: For more specific details on the limitations of various Android versions and phones, see this helpful post from Nordic Semiconductors (https://adafru.it/ sKc). Can my Bluefruit board detect other Bluefruit boards or Central devices? No. All of our Bluefruit LE modules currently operate in peripheral mode, which means they can only advertise their own existence via the advertising payload. The ©Adafruit Industries Page 153 of 161 central device (usually your phone or laptop) is responsible for listening for these advertising packets, starting the connection process, and inititating any transactions between the devices.  There is no way for a Bluefruit module to detect other Bluefruit modules or central devices in range, they can only send their own advertising data out and wait for a connection request to come in. How can I determine the distance between my Bluefruit module and my phone in m/ft? The short answer is: you can't. RF devices normally measure signal strength using RSSI, which stands for Received Signal Strength Indicator, which is measured in dBm.  The closer the devices are the strong the RSSI value generally is (-90dBm is much weaker than -60dBm, for example), but there is no reliable relationship between RSSI values in dBm and distance in the real world.  If there is a wall between devices, RSSI will fall.  If there is a lot of interference on the same 2.4GHz band, RSSI will fall. Depending on the device, if you simply change the antenna orientation, RSSI will fall.  You can read the RSSI value between two connected devices with the  AT+BLEGETRSSI command, but there are no meaningful and repeatable conclusions that can be drawn from this value about distance other than perhaps 'farther' or 'closer' in a very loose sense of the terms. How far away from my phone can I have my Bluefruit LE module? This depends on a number of factors beyond the module itself such as antenna orientation, the antenna design on the phone, transmit power on the sending node, competing traffic in the same 2.4GHz bandwidth, obstacles between end points, etc. It could be as low as a couple meters up to about 10 meters line of sight, but generally Bluetooth Low Energy is designed for very short range and will work best in the 5-6 meter or less range for reliable communication, assuming normal Bluefruit firmware settings. How many GATT services and characteristics can I create? For firmware 0.7.0 and higher, the following limitations are present: • Maximum number of services: 10 • Maximum number of characteristics: 30 ©Adafruit Industries Page 154 of 161 • Maximum buffer size for each characteristic: 32 bytes • Maximum number of CCCDs: 16 Is it possible to modify or disable the built in GATT services and characteristics (DIS, DFU, etc.)? No, unfortunately you can't. We rely on the Device Information Service (https:// adafru.it/q9E) (DIS) contents to know which firmware and bootloader version you are running, and wouldn't be able to provide firmware updates without being able to trust this information, which i why it's both mandatory and read only. Similarly, the DFU service is mandatory to maintain over the air updates and disabling it would create more problems that it's presence would cause. How can I use BlueZ and gatttool with Bluefruit modules? BlueZ has a bit of a learning curve associated with it, but you can find some notes below on one option to send and receive data using the BLE UART Service built into all of our Bluefruit LE modules and boards. These commands may change with different versions of BlueZ. Version 5.21 was used below. # Initialise the USB dongle $ sudo hciconfig hci0 up # Scan for the UART BLE device $ sudo hcitool lescan D6:4E:06:4F:72:86 UART # Start gatttool, pointing to the UART device found above $ sudo gatttool -b D6:4E:06:4F:72:86 -I -t random --sec-level=high [D6:4E:06:4F:72:86][LE]> connect Attempting to connect to D6:4E:06:4F:72:86 Connection successful # Scan for primary GATT Services [D6:4E:06:4F:72:86][LE]> primary attr handle: 0x0001, end grp handle: 00001800-0000-1000-8000-00805f9b34fb attr handle: 0x0008, end grp handle: 00001801-0000-1000-8000-00805f9b34fb attr handle: 0x0009, end grp handle: e50e24dcca9e attr handle: 0x000f, end grp handle: 0000180a-0000-1000-8000-00805f9b34fb 0x0007 uuid: 0x0008 uuid: 0x000e uuid: 6e400001-b5a3-f393-e0a90xffff uuid: # Get the handles for the entries in the UART service (handle 0x0009) [D6:4E:06:4F:72:86][LE]> char-desc handle: 0x0001, uuid: 00002800-0000-1000-8000-00805f9b34fb handle: 0x0002, uuid: 00002803-0000-1000-8000-00805f9b34fb handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb handle: 0x0004, uuid: 00002803-0000-1000-8000-00805f9b34fb ©Adafruit Industries Page 155 of 161 handle: handle: handle: handle: handle: handle: handle: handle: handle: handle: handle: handle: handle: 0x0005, 0x0006, 0x0007, 0x0008, 0x0009, 0x000a, 0x000b, 0x000c, 0x000d, 0x000e, 0x000f, 0x0010, 0x0011, uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: uuid: 00002a01-0000-1000-8000-00805f9b34fb 00002803-0000-1000-8000-00805f9b34fb 00002a04-0000-1000-8000-00805f9b34fb 00002800-0000-1000-8000-00805f9b34fb 00002800-0000-1000-8000-00805f9b34fb 00002803-0000-1000-8000-00805f9b34fb 6e400002-b5a3-f393-e0a9-e50e24dcca9e 00002803-0000-1000-8000-00805f9b34fb 6e400003-b5a3-f393-e0a9-e50e24dcca9e 00002902-0000-1000-8000-00805f9b34fb 00002800-0000-1000-8000-00805f9b34fb 00002803-0000-1000-8000-00805f9b34fb 00002a27-0000-1000-8000-00805f9b34fb # 6e400002 (handle 0x000b) = TX characteristic # 6e400003 (handle 0x000d) = RX characteristic # Optional (but maybe helpful) ... scan for CCCD entries [D6:4E:06:4F:72:86][LE]> char-read-uuid 2902 handle: 0x000e value: 00 00 # # # # # Enable notifications on the RX characteristic (CCCD handle = 0x000e) 0100 = get notifications 0200 = get indications 0300 = get notifications + indications 0000 = disable notifications + indications [D6:4E:06:4F:72:86][LE]> char-write-req 0x000e 0100 Characteristic value was written successfully # Just to make sure it was updated [D6:4E:06:4F:72:86][LE]> char-read-hnd 0x000e Characteristic value/descriptor: 01 00 # Writing "test" in the Serial Monitor of the Arduino sketch should # cause this output not that notifications are enabled: Notification handle = 0x000d value: 74 65 73 74 # Write something to the TX characteristic (handle = 0x000b) # This should cause E F G H to appear in the Serial Monitor [D6:4E:06:4F:72:86][LE]> char-write-cmd 0x000b 45 [D6:4E:06:4F:72:86][LE]> char-write-cmd 0x000b 46 [D6:4E:06:4F:72:86][LE]> char-write-cmd 0x000b 47 [D6:4E:06:4F:72:86][LE]> char-write-cmd 0x000b 48 # To send multiple bytes [D6:4E:06:4F:72:86][LE]> char-write-cmd 0x000B 707172737475 # If you are running the callbackEcho sketch and notifications # are enabled you should get this response after the above cmd: Notification handle = 0x000d value: 70 71 72 73 74 75 -------------# If you just want to enable constant listening, enter the following command from the CLI: $ sudo gatttool -b D6:4E:06:4F:72:86 -t random --char-write-req -a 0x000e -n 0100 -listen # This should give us the following output as data is written on the Uno, # though we can't send anything back: Characteristic value was written successfully Notification handle = 0x000d value: 74 65 73 74 Notification handle = 0x000d value: 6d 6f 72 65 20 74 65 73 74 ©Adafruit Industries Page 156 of 161 Can I use the IRQ pin to wake my MCU up from sleep when BLE UART data is available? No, on SPI-based boards the IRQ pin is used to indicate that an SDEP response is available to an SDEP command. For example, when you sent the `AT+BLEUARTRX` command as an SDEP message, the Bluefruit firmware running on the nRF51822 will parse the message, prepare an SDEP response, and trigger the IRQ pin to tell the MCU that the response is ready. This is completely independant from the BLE UART service, which doesn't have interrupt capability at present. Can I also update the sketch running on the device using Bluefruit LE Connect? No, only the core firmware can be updated over the air. Sketches need to be loaded using the Arduino IDE and serial bootloader. Device Recovery Sometimes, bad things unfortunately happen. Thankfully, 99% of the time it's purely a SW issue and the Bluefruit devices have a robust bootloader with some fail safes that can almost always recover your device. How to Recover a Bluefruit Board 1. Force DFU Mode at Startup The first step is to force your board into a special bootloader mode, which will prevent any faulty user sketches or corrupted config data from causing problems. • Connect the DFU pin to GND with a jumper cable, or if your board has a DFU button hold the button down when adding power to your board (connecting the USB cable, etc.) • Once the device is powered, you should see a faster DFU MODE blinky pattern that lets you know you are in bootloader mode. • Now remove the jumper cable between DFU and GND (to prevent going into DFU mode when you reset) Remove the jumper cable between DFU and GND once you are in DFU mode so that you exit it during the next reset! ©Adafruit Industries Page 157 of 161 2. Update the Bluefruit Firmware Next, update your device to the latest Bluefruit firmware using the Bluefruit LE Connect app. We regularly fix bugs, and it's always a good idea to be on the latest release. You can perform a firmware update in DFU mode, although the Bluefruit board may appear as DfuTarg in the Bluefruit LE Connect app, and you will will need to select the right firmware 'family' for you board. Because bootloader mode is a fail safe mode and has a small subset of Bluefruit's features, we can't tell the Bluefruit LE Connect app very many details about our HW. As such, you will need to indicate which firmware type to flash ... specifically, whether to flash the UART of SPI based firmware. Be sure to select the right one, based on your product and the table below: BLEFRIEND32 Firmware (UART, 32KB SRAM) • Bluefruit UART Friend V2 (https://adafru.it/edl) • Bluefruit LE UART Friend (https://adafru.it/tYD) BLESPIFRIEND Firmware (SPI) • Bluefruit LE SPI Friend (https://adafru.it/fLp) • Bluefruit LE Shield (http://adafru.it/2746) • Bluefruit LE Micro (https://adafru.it/tYE) • Feather 32u4 Bluefruit LE (https://adafru.it/tYF) • Feather M0 Bluefruit LE (http://adafru.it/2995) 3. Flash a Test Sketch Once the core Bluefruit firmware has been updated, flash a test sketch to the device from the Arduino IDE, such as the following blinky code: // the setup function runs once when you press reset or power the board void setup() { // initialize digital pin LED_BUILTIN as an output. pinMode(LED_BUILTIN, OUTPUT); } // the loop function runs over and over again forever void loop() { digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second ©Adafruit Industries Page 158 of 161 digitalWrite(LED_BUILTIN, LOW); delay(1000); // turn the LED off by making the voltage LOW // wait for a second } 4. Perform a Factory Reset Once the core Bluefruit firmware has been updated, the final step is to perform a factory reset. • With the board still powered up, connect the DFU pin to GND • Leave the pin set to GND (or hold the DFU button down) for >5 seconds until the BLUE status LED starts to blink • Remove the DFU jumper cable or release the DFU button This will cause a factory reset which will wipe all config data, and should restore your board, getting you back to a normal state in most situations! Still Having Problems? Hop on over to our support forums (https://adafru.it/dYq) clearly explaining your problem along with the following information, and, we'll be happy to help: • You product name and ideally the product ID • The Bluefruit firmware version you are using (available at the top of the Serial Monitor output on most example sketches) • The Operating System your are using • The Arduino IDE version you are using Providing the above information in your first post will skip a round of two of back and forth and you'll get an answer from us quicker, saving everyone time and effort! Be sure to see the FAQ section of this learning guide as well, which has answer to many common problems! ©Adafruit Industries Page 159 of 161 Downloads Files • MDBT Datasheet (https://adafru.it/oYE) • EagleCAD PCB files on GitHub (https://adafru.it/rDV) • Fritzing object in the Adafruit Fritzing Library (https://adafru.it/aP3) Schematic Board Layout All measurements are in inches. ©Adafruit Industries Page 160 of 161 ©Adafruit Industries Page 161 of 161
很抱歉,暂时无法提供与“2479”相匹配的价格&库存,您可以联系我们找货
