P522304-02
P522304-02
    ETHERTRONICS
    CELL ANTENNA DEMO BOARD 5-BAND
P522304-02 数据手册
DATASHEET Part No. P522304 / 9000154 Product: Broadband FR4 Embedded Cellular Antenna Part No. P522304 / 9000154 Broadband FR4 Embedded Cellular Antenna 850 / 900 / 1800 / 1900 / 2100 MHz Supports: Broadband LTE (OCTA-BAND), LTE CAT-M, NB-IoT, SigFox, LoRa, Cellular LPWA, RPMA, Firstnet KYOCERA AVX’s Broadband Embedded Cellular antenna utilizes Isolated Magnetic Dipole™ (IMD) technology which address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. Mirrored version variant offered as 9000154. Stays in Tune *Mirrored version offered as 9000154 Broadband FR4 Embedded Cellular Antenna Low Band 824 – 960 MHz High Band 1710 - 2170 MHz KEY BENEFITS Reduced Costs and Time-to-Market Standard antenna eliminates design fees and cycle time associated with a custom solution; getting products to market faster. Greater Flexibility with Unique Form Factors KYOCERA AVX’s technology helps you deliver more advanced ergonomic designs without adverse impact on product performance. Reliability Comply with latest RoHS requirements APPLICATIONS • • • • • • Medical applications Home automation Smart metering M2M, Industrial devices IoT Firstnet 10/1/2019 • • • • • • Automotive Healthcare Point of Sale Tracking Cellular 3G Systems IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. KYOCERA AVX IMD antennas resist detuning; providing a robust radio link regardless of the usage position KYOCERA AVX antennas use patented IMD technology in many antenna configurations to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. Electrical Specifications Typical Characteristics, on 50 x 110 mm PCB Frequency Efficiency VSWR Peak Gain Polarization Power Handling Radiation Pattern Feed Point Impedance 824 - 960 MHz 1710 - 2170 MHz 62% 55% 2.5:1 max 2.7:1 max 0 dBi 0.7 dBi Linear 2 Watts CW Omni-directional 50 ohms unbalanced Mechanical Specifications & Ordering Part Number Ordering Part # P522304 Dimensions (mm) 35.0 x 9.0 x 3.2 Weight (grams) 2.1 Mounting SMT (P&P) Packaging 1,120 pcs/reel; 5,600 pcs/box Demo Board Proprietary P522304-02 www.KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Dimensions Typical antenna dimensions (mm) Part Number A (mm) B (mm) C (mm) P522304 35.0 ± 0.3 9.0 ± 0.2 3.2 ± 0.3 A B Top View C Height Pin #3 Pin #4 Pin Descriptions Pin #2 Pin #1 Pin #5 Pin# 1 2 3 4 5 Description Feed Ground Dummy Pad Dummy Pad Low Band Tuning Bottom View © KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. 50 110 Low Band VSWR Low Band Efficiency © KYOCERA AVX P522304-02 VSWR and Efficiency Plots (Off-Ground) Typical Performance on 50 x 110 mm PCB High Band VSWR High Band Efficiency tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Measured at 1870 MHz Measured at 910 MHz Antenna Radiation Patterns Typical Performance on 50 x 110 mm PCB Measured @ 910, 1870 MHz © KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Layout (On-Ground) Typical layout dimensions (mm) Pin #2 S2 S1 P1 P2 Pin #1 Pin #5 Pin #4 Pin #3 VIAs * VIAS: Diam. 0.2mm, (no vias on transmission lines). Via holes must be covered by solder mask 50Ω Transmission Line Pin Descriptions Pin# Description Feed 1 Ground 2 Dummy Pad 3 Dummy Pad 4 Low Band Tuning 5 Matching & Tuning Component Values Component P1 S1 S2 P2 R1 – R7 Value 3.6nH 1.2pF 15nH 1.8pF DNI Tolerance ±0.05nH ±0.05pF ±0.3nH ±0.05pF N/A Antenna Outline Default Pi Matching Network values and (R1- R7) tuning instructions can be found under Antenna Matching Structure.. R1 R7 © KYOCERA AVX R6 R4 R3 R2 R5 tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Matching Structure Typical matching values on 50 x 110 mm PCB Demo Board Back View Demo Board Front View Pin #2 Pin #5 Pin #1 Vias Pin #4 Pin #3 Low Band Tuning Antenna Matching [ R1 ] [ S1 ] [ P2 ] [ P1 ] [ S2 ] Tune Low Band Lower (Add 0Ω) Tune Low Band Higher (Cut Bridge Trace) [ R2 ] [ R3 ] [ R4 ] [ R15 ] [ R6 ] [ R7 ] (Antenna Matching): pads are directly inline with the antenna feed trace. *Cut Trace between pads shifts resonant frequency higher *Bridging gaps with 0 ohm resistors shifts resonant frequency lower Pin Descriptions Pin# 1 2 3 4 5 (Low Band Tuning) Description Feed Ground Dummy Pad Dummy Pad Low Band Tuning R1 1 2 3 P1 Default Matching 3.6nH Tolerance ±0.05nH © KYOCERA AVX S1 1.2pF ± 0.05pF P1 S2 R3 R4 R5 R6 R7 5 4 P2 (Antenna Matching) R2 S1 S2 15nH ±0.3nH 50ohm P2 1.8pF ± 0.05pF (R1 - R7) DNI N/A tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Demo Board Demo Board Front View/Back View Part Number A (mm) B (mm) C (mm) P522304-02 110 50.0 15.0 C Antenna Outline A P522304-02 B Front View © KYOCERA AVX Back View tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. P522304 Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Recommended Reflow Soldering Profile The recommended method for soldering the antenna to the board is forced convection reflow soldering. The following suggestions provide information on how to optimize the reflow process for the FR4 antenna: *Adjust the reflow duration to create good solder joints without raising the antenna temperature beyond the allowed maximum of 260° C. © KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com
P522304-02 价格&库存
很抱歉,暂时无法提供与“P522304-02”相匹配的价格&库存,您可以联系我们找货
