113990018
113990018
    SEEED(矽递科技)
    2KM LONG RANGE RF LINK KITS W/ E
113990018 数据手册
    2KM Long Range RF link kits w/ encoder and decoder This is a super long-range 433mhz RF link kit. It comes with VCO, PLL technology, steady frequency and super anti-jamming ability. You can directly use it with your projects, like wireless data transport, remote control, etc. Specifications Parameter  Value  Working voltage  Receiver(3‐5V), Transmitter(3‐9V)  Working current  ≤2.5mA(5.0VDC)  Principle of operation  Superhet(VCO, PLL)  Modulation  OOK/ASK  Parameter  Value  Working band  433.92MHz (customized service available)  Bandwidth  1.5MHz  Sensitivity  ‐105dBm (50Ω)  Rate  <5Kbps  Decoding form  PT2272  Antenna length  18cm  Transmission range  2 km  Application Ideas  Wireless switch  Remote transmission  Wireless control Hardware Overview Getting Started  Please follow the Instruction to hook up the communication system.  Connect battery, button and transmit boards. Note Please use 3-5V power source! 9V will damage the receiver board. Connect battery, LEDs and receiver boards. Note Do not put RX module and TX module too close: this would prevent them to work. Make sure that the RX module and TX module are at least 1 meter away from each other.  When we press the button on the Transmitter side, the related LED on receiver side will be turned on. Resources  [Instruction] Transmitter and receiver Setup Manual https://github.com/SeeedDocument/2KM_Long_Range_RF_link_kits_w_encoder_and_ decoder/raw/master/res/2KM_RF.rar  [Datasheet] Datasheet for PT2272 and PT2262 http://www.datasheetcatalog.org/datasheet/PrincetonTechnologyCorporation/mXusxsq. pdf Tech Support Please submit any technical issue into our forum or drop mail to techsupport@seeed.cc.        http://wiki.seeedstudio.com/2KM_Long_Range_RF_link_kits_w_encoder_and_decoder/3‐6‐19
113990018 价格&库存
很抱歉,暂时无法提供与“113990018”相匹配的价格&库存,您可以联系我们找货
